path: root/fs/ufs/util.c
2008-02-08drop linux/ufs_fs.h from userspace export and relocate it to fs/ufs/ufs_fs.hMike Frysinger
Per previous discussions about cleaning up ufs_fs.h, people just want this straight up dropped from userspace export. The only remaining consumer (silo) has been fixed a while ago to not rely on this header. This allows use to move it completely from include/linux/ to fs/ufs/ seeing as how the only in-kernel consumer is fs/ufs/. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-10[PATCH] ufs endianness annotationsAl Viro
2006-08-06[PATCH] ufs: handle truncated pagesEvgeniy Dushistov
ufs_get_locked_page is called twice in ufs code, one time in ufs_truncate path(we allocated last block), and another time when fragments are reallocated. In ideal world in the second case on allocation/free block layer we should not know that things like `truncate' exists, but now with such crutch like ufs_get_locked_page we can (or should?) skip truncated pages. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] ufs: ufs_get_locked_page() race fixEvgeniy Dushistov
As discussed earlier: http://lkml.org/lkml/2006/6/28/136 this patch fixes such issue: `ufs_get_locked_page' takes page from cache after that `vmtruncate' takes page and deletes it from cache `ufs_get_locked_page' locks page, and reports about EIO error. Also because of find_lock_page always return valid page or NULL, we have no need to check it if page not NULL. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] ufs: truncate should allocate block for last byteEvgeniy Dushistov
This patch fixes buggy behaviour of UFS in such kind of scenario: open(, O_TRUNC...) ftruncate(, 1024) ftruncate(, 0) Such a scenario causes ufs_panic and remount read-only. This happen because of according to specification UFS should always allocate block for last byte, and many parts of our implementation rely on this, but `ufs_truncate' doesn't care about this. To make possible return error code and to know about old size, this patch removes `truncate' from ufs inode_operations and uses `setattr' method to call ufs_truncate. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: ubh_ll_rw_block cleanupEvgeniy Dushistov
In ufs code there is function: ubh_ll_rw_block, it has parameter how many ufs_buffer_head it should handle, but it always called with "1" on the place of this parameter. This patch removes unused parameter of "ubh_ll_wr_block". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: easy debugEvgeniy Dushistov
Currently to turn on debug mode "user" has to edit ~10 files, to turn off he has to do it again. This patch introduce such changes: 1)turn on(off) debug messages via ".config" 2)remove unnecessary duplication of code 3)make "UFSD" macros more similar to function 4)fix some compiler warnings Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: wrong type castEvgeniy Dushistov
There are two ugly macros in ufs code: #define UCPI_UBH ((struct ufs_buffer_head *)ucpi) #define USPI_UBH ((struct ufs_buffer_head *)uspi) when uspi looks like struct { struct ufs_buffer_head ; } and USPI_UBH has some sence, ucpi looks like struct { struct not_ufs_buffer_head; } To prevent bugs in future, this patch convert macros to inline function and fix "ucpi" structure. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: ufs_trunc_indirect: infinite cycleEvgeniy Dushistov
Currently, ufs write support have two sets of problems: work with files and work with directories. This series of patches should solve the first problem. This patch is similar to http://lkml.org/lkml/2006/1/17/61 this patch complements it. The situation the same: in ufs_trunc_(not direct), we read block, check if count of links to it is equal to one, if so we finish cycle, if not continue. Because of "count of links" always >=2 this operation cause infinite cycle and hang up the kernel. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
