path: root/fs/ufs
2009-04-02fs/ufs: return f_fsid for statfs(2)Coly Li
Make ufs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27ufs: copy symlink data into the correct union memberDuane Griffin
Copy symlink data into the union member it is accessed through. Although this shouldn't make a difference to behaviour it makes the code easier to follow and grep through. It may also prevent problems if the struct/union definitions change in the future. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27ufs: ensure fast symlinks are NUL-terminatedDuane Griffin
Ensure fast symlink targets are NUL-terminated, even if corrupted on-disk. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27ufs: don't truncate longer ufs2 fast symlinksDuane Griffin
ufs2 fast symlinks can be twice as long as ufs ones, however the code was using the ufs size in various places. Fix that so ufs2 symlinks over 60 characters aren't truncated. Note that we copy the entire area instead of using the maxsymlinklen field from the superblock. This way we will be more robust against corruption (of the superblock). While we are at it, use memcpy instead of open-coding it with for loops. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27ufs: validate maximum fast symlink size from superblockDuane Griffin
The maximum fast symlink size is set in the superblock of certain types of UFS filesystem. Before using it we need to check that it isn't longer than the available space we have in the inode. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26ufs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: Evgeniy Dushistov <dushistov@mail.ru>
2009-03-22Update my email addressGertjan van Wingerde
Update all previous incarnations of my email address to the correct one. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-22fs/Kconfig: move ufs outAlexey Dobriyan
2008-11-14CRED: Wrap task credential accesses in the UFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04Revert "UFS: add const to parser token table"Linus Torvalds
This reverts commit f9247273cb69ba101877e946d2d83044409cc8c5 (and fb2e405fc1fc8b20d9c78eaa1c7fd5a297efde43 - "fix fs/nfs/nfsroot.c compilation" - that fixed a missed conversion). The changes cause problems for at least the sparc build. Let's re-do them when the exact issues are resolved. Requested-by: Andrew Morton <akpm@linux-foundation.org> Requested-by: Steven Whitehouse <swhiteho@redhat.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: move function-macros from quota.h to quotaops.hJan Kara
Move declarations of some macros, which should be in fact functions to quotaops.h. This way they can be later converted to inline functions because we can now use declarations from quota.h. Also add necessary includes of quotaops.h to a few files. [akpm@linux-foundation.org: fix JFS build] [akpm@linux-foundation.org: fix UFS build] [vegard.nossum@gmail.com: fix QUOTA=n build] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Arjen Pool <arjenpool@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24UFS: add const to parser token tableSteven Whitehouse
This patch adds a "const" to the parser token table. I've done an allmodconfig build to see if this produces any warnings/failures and the patch includes a fix for the only warning that was produced. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Alexander Viro <aviro@redhat.com> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13ufs: remove unneeded ufs_put_inode prototypeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: replace __inline with inlineHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: remove unused fs64_add and fs64_subMarcin Slusarz
remove fs64_add and fs64_sub - they probably weren't ever used because their prototypes used u32 instead of __fs64 Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: [bl]e*_add_cpu conversionMarcin Slusarz
replace all: big/little_endian_variable = cpu_to_[bl]eX([bl]eX_to_cpu(big/little_endian_variable) + expression_in_cpu_byteorder); with: [bl]eX_add_cpu(&big/little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19fs/ufs/balloc.c: fix sparc64 printk warningAndrew Morton
fs/ufs/balloc.c: In function `ufs_change_blocknr': fs/ufs/balloc.c:317: warning: long long unsigned int format, long unsigned int arg (arg 2) fs/ufs/balloc.c:317: warning: long long unsigned int format, long unsigned int arg (arg 3) sector_t is u64 and we don't know what type the architecture uses to implement u64. Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23ufs: fix parenthesisation in ufs_set_fs_state()Roel Kluin
This bug snuck in with commit 252e211e90ce56bf005cb533ad5a297c18c19407 Author: Mark Fortescue <mark@mtfhpc.demon.co.uk> Date: Tue Oct 16 23:26:31 2007 -0700 Add in SunOS 4.1.x compatible mode for UFS Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Mark Fortescue <mark@mtfhpc.demon.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08drop linux/ufs_fs.h from userspace export and relocate it to fs/ufs/ufs_fs.hMike Frysinger
Per previous discussions about cleaning up ufs_fs.h, people just want this straight up dropped from userspace export. The only remaining consumer (silo) has been fixed a while ago to not rely on this header. This allows use to move it completely from include/linux/ to fs/ufs/ seeing as how the only in-kernel consumer is fs/ufs/. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ufs: fix symlink creation on ufs2Evgeniy Dushistov
If we create symlink on UFS2 filesystem under Linux, it looks wrong under other OSes, because of max symlink length field was not initialized properly, and data blocks were not used to save short symlink names. [akpm@linux-foundation.org: add missing fs32_to_cpu()] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Steven <stevenaaus@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop UFS from using iget() and read_inode()David Howells
Stop the UFS filesystem from using iget() and read_inode(). Replace ufs_read_inode() with ufs_iget(), and call that instead of iget(). ufs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ufs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05ufs: fix nexstep dir block sizeEvgeniy Dushistov
This patch fixes regression, introduced since 2.6.16. NextStep variant of UFS as OpenStep uses directory block size equals to 1024. Without this change, ufs_check_page fails in many cases. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Dave Bailey <dsbailey@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30revert "ufs: Fix mount check in ufs_fill_super()"Andrew Morton
Evgeniy said: I wonder on what type of UFS do you test this patch? NetBSD and FreeBSD do not use "fs_state", they use "fs_clean" flag, only Solaris does check like this: fs_state + fs_time == FSOK. That's why parentheses was like that. At now with linux-2.6.24-rc1-git1, I get: fs need fsck, but NetBSD's fsck says that's all ok. I suggest revert this patch. Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Satyam Sharma <satyam.sharma@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: Fix mount check in ufs_fill_super()Satyam Sharma
The current code skips the check to verify whether the filesystem was previously cleanly unmounted, if (flags & UFS_ST_MASK) == UFS_ST_44BSD or UFS_ST_OLD. This looks like an inadvertent bug that slipped in due to parantheses in the compound conditional to me, especially given that ufs_get_fs_state() handles the UFS_ST_44BSD case perfectly well. So, let's fix the compound condition appropriately. Signed-off-by: Satyam Sharma <satyam@infradead.org> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: implement show_optionsEvgeniy Dushistov
An implementation of show_options method for UFS. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add in SunOS 4.1.x compatible mode for UFSMark Fortescue
Add in support for SunOS 4.1.x flavor of BSD 4.2 UFS filing system Macros have been put in to alow suport for the old static table Cylinder Groups but this implementation does not use them yet. This also fixes Solaris UFS filing system access by disabling fast symbolic links as Sun's version of UFS does not support on-disk fast symbolic links. Tested by: Ppartitioning a new disk using SunOS 4.1.1, creating a UFS filing system on one of the partitions and writing some files to the filing system. Using Linux-2.6.22 (patched) to read the files and then write a shed load of files to the UFS partition. Using SunOS 4.1.1 to verify the filing system is OK and to check the files. The test host is a sun4c SS1 Clone. [akpm@linux-foundation.org: coding style fixes] [adobriyan@gmail.com: fix oops] Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ufs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-25ufs: fix sun stateEvgeniy Dushistov
Different types of ufs hold state in different places, to hide complexity of this, there is ufs_get_fs_state, it returns state according to "UFS_SB(sb)->s_flags", but during mount ufs_get_fs_state is called, before setting s_flags, this cause message for ufs types like sun ufs: "fs need fsck", and remount in readonly state. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2: ufs/super.cvignesh babu
Replace (n & (n-1)) with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-17ufs proper handling of zero link caseEvgeniy Dushistov
This patch should fix or partly fix this bug: http://bugzilla.kernel.org/show_bug.cgi?id=8276 The problem is: - if we see "zero link case" during reading inode operation, we call ufs_error(which remount fs readonly), but not "mark" inode as bad (1) - in readonly case we do not fill some data structures, which are used in read and write case (2) - VFS call ufs_delete_inode if link count is zero (3) so (1)->(3)->(2) cause oops, this patch should fix such scenario Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jim Paris <jim@jtan.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs2: tindirect truncate fixEvgeniy Dushistov
During modification of code to support UFS2 writing, the case with "three indirect" blocks in truncate path was missed, this patch fixes this situation. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs: zeroize the rest of block in truncateEvgeniy Dushistov
This patch fix behaviour in such test scenario: lseek(fd, BIG_OFFSET) write(fd, buf, sizeof(buf)) truncate(BIG_OFFSET) truncate(BIG_OFFSET + sizeof(buf)) read(fd, buf...) Because of if file big enough(BIG_OFFSET) we start allocate space by block, ordinary block size > page size, so we should zeroize the rest of block in truncate(except last framgnet, about which VFS should care), to not get garbage, when we extend file. Also patch corrects conversion from pointer to block to physical block number, this helps in case of not common used UFS types. And add to debug output inode number. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs: prepare write + change blocks on the flyEvgeniy Dushistov
This fixes "change blocks numbers on the fly" in case when "prepare write page" is in the call chain, in this case some buffers may be not uptodate and not mapped, we should care to map them and load from disk. This patch was tested with: - ufs regressions simple tests - fsx-linux - ltp(20060306) - untar and build kernel Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs2: more correct work with timeEvgeniy Dushistov
This patch corrects work with time in UFS2 case. 1) According to UFS2 disk layout modification/access and so on "time" should be hold in two variables one 64bit for seconds and another 32bit for nanoseconds, at now for some unknown reason we suppose that "inode time" holds in three variables 32bit for seconds, 32bit for milliseconds and 32bit for nanoseconds. 2) We set amount of nanoseconds in "VFS inode" to 0 during read, instead of getting values from "on disk inode"(this should close http://bugzilla.kernel.org/show_bug.cgi?id=7991). Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Bjoern Jacke <bjoern@j3e.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
