commit 46d0b24c5ee10a15dfb25e20642f5a5ed59c5003 upstream.
userfaultfd_release() should clear vm_flags/vm_userfaultfd_ctx even if
mm->core_state != NULL.
Otherwise a page fault can see userfaultfd_missing() == T and use an
already freed userfaultfd_ctx.
Link: http://lkml.kernel.org/r/20190820160237.GB4983@redhat.com
Fixes: 04f5866e41fb ("coredump: fix race condition between mmget_not_zero()/get_task_mm() and core dumping")
Reported-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Cc: Peter Xu <peterx@redhat.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Jann Horn <jannh@google.com>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: <stable@vger.kernel.org>
dumping
commit 04f5866e41fb70690e28397487d8bd8eea7d712a upstream.
The core dumping code has always run without holding the mmap_sem for
writing, despite that is the only way to ensure that the entire vma
layout will not change from under it. Only using some signal
serialization on the processes belonging to the mm is not nearly enough.
This was pointed out earlier. For example in Hugh's post from Jul 2017:
https://lkml.kernel.org/r/alpine.LSU.2.11.1707191716030.2055@eggly.anvils
"Not strictly relevant here, but a related note: I was very surprised
to discover, only quite recently, how handle_mm_fault() may be called
without down_read(mmap_sem) - when core dumping. That seems a
misguided optimization to me, which would also be nice to correct"
In particular because the growsdown and growsup can move the
vm_start/vm_end the various loops the core dump does around the vma will
not be consistent if page faults can happen concurrently.
Pretty much all users calling mmget_not_zero()/get_task_mm() and then
taking the mmap_sem had the potential to introduce unexpected side
effects in the core dumping code.
Adding mmap_sem for writing around the ->core_dump invocation is a
viable long term fix, but it requires removing all copy user and page
faults and to replace them with get_dump_page() for all binary formats
which is not suitable as a short term fix.
For the time being this solution manually covers the places that can
confuse the core dump either by altering the vma layout or the vma flags
while it runs. Once ->core_dump runs under mmap_sem for writing the
function mmget_still_valid() can be dropped.
Allowing mmap_sem protected sections to run in parallel with the
coredump provides some minor parallelism advantage to the swapoff code
(which seems to be safe enough by never mangling any vma field and can
keep doing swapins in parallel to the core dumping) and to some other
corner case.
In order to facilitate the backporting I added "Fixes: 86039bd3b4e6"
however the side effect of this same race condition in /proc/pid/mem
should be reproducible since before 2.6.12-rc2 so I couldn't add any
other "Fixes:" because there's no hash beyond the git genesis commit.
Because find_extend_vma() is the only location outside of the process
context that could modify the "mm" structures under mmap_sem for
reading, by adding the mmget_still_valid() check to it, all other cases
that take the mmap_sem for reading don't need the new check after
mmget_not_zero()/get_task_mm(). The expand_stack() in page fault
context also doesn't need the new check, because all tasks under core
dumping are frozen.
Link: http://lkml.kernel.org/r/20190325224949.11068-1-aarcange@redhat.com
Fixes: 86039bd3b4e6 ("userfaultfd: add new syscall to provide memory externalization")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Peter Xu <peterx@redhat.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Jann Horn <jannh@google.com>
Acked-by: Jason Gunthorpe <jgg@mellanox.com>
commit 01e881f5a1fca4677e82733061868c6d6ea05ca7 upstream.
Calling UFFDIO_UNREGISTER on virtual ranges not yet registered in uffd
could trigger an harmless false positive WARN_ON. Check the vma is
already registered before checking VM_MAYWRITE to shut off the false
positive warning.
Link: http://lkml.kernel.org/r/20181206212028.18726-2-aarcange@redhat.com
Fixes: 29ec90660d68 ("userfaultfd: shmem/hugetlbfs: only allow to register VM_MAYWRITE vmas")
Reported-by: syzbot+06c7092e7d71218a2c16@syzkaller.appspotmail.com
Acked-by: Mike Rapoport <rppt@linux.ibm.com>
commit 29ec90660d68bbdd69507c1c8b4e33aa299278b1 upstream.
After the VMA to register the uffd onto is found, check that it has
VM_MAYWRITE set before allowing registration. This way we inherit all
common code checks before allowing to fill file holes in shmem and
hugetlbfs with UFFDIO_COPY.
The userfaultfd memory model is not applicable for readonly files unless
it's a MAP_PRIVATE.
Link: http://lkml.kernel.org/r/20181126173452.26955-4-aarcange@redhat.com
Fixes: ff62a3421044 ("hugetlb: implement memfd sealing")
Reviewed-by: Hugh Dickins <hughd@google.com>
Fixes: 4c27fe4c4c84 ("userfaultfd: shmem: add shmem_mcopy_atomic_pte for userfaultfd support")
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: stable@vger.kernel.org
commit 31e810aa1033a7db50a2746cd34a2432237f6420 upstream.
The fix in commit 0cbb4b4f4c44 ("userfaultfd: clear the
vma->vm_userfaultfd_ctx if UFFD_EVENT_FORK fails") cleared the
vma->vm_userfaultfd_ctx but kept userfaultfd flags in vma->vm_flags
that were copied from the parent process VMA.
As the result, there is an inconsistency between the values of
vma->vm_userfaultfd_ctx.ctx and vma->vm_flags which triggers BUG_ON
in userfaultfd_release().
Clearing the uffd flags from vma->vm_flags in case of UFFD_EVENT_FORK
failure resolves the issue.
Link: http://lkml.kernel.org/r/1532931975-25473-1-git-send-email-rppt@linux.vnet.ibm.com
Fixes: 0cbb4b4f4c44 ("userfaultfd: clear the vma->vm_userfaultfd_ctx if UFFD_EVENT_FORK fails")
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Reported-by: syzbot+121be635a7a35ddb7dcb@syzkaller.appspotmail.com
Cc: Eric Biggers <ebiggers3@gmail.com>
commit 1e2c043628c7736dd56536d16c0ce009bc834ae7 upstream.
Use huge_ptep_get() to translate huge ptes to normal ptes so we can
check them with the huge_pte_* functions. Otherwise some architectures
will check the wrong values and will not wait for userspace to bring in
the memory.
Link: http://lkml.kernel.org/r/20180626132421.78084-1-frankja@linux.ibm.com
Fixes: 369cd2121be4 ("userfaultfd: hugetlbfs: userfaultfd_huge_must_wait for hugepmd ranges")
Signed-off-by: Janosch Frank <frankja@linux.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
commit 0cbb4b4f4c44f54af268969b18d8deda63aded59 upstream.
The previous fix in commit 384632e67e08 ("userfaultfd: non-cooperative:
fix fork use after free") corrected the refcounting in case of
UFFD_EVENT_FORK failure for the fork userfault paths.
That still didn't clear the vma->vm_userfaultfd_ctx of the vmas that
were set to point to the aborted new uffd ctx earlier in
dup_userfaultfd.
Link: http://lkml.kernel.org/r/20171223002505.593-2-aarcange@redhat.com
Reported-by: syzbot <syzkaller@googlegroups.com>
Reviewed-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
When reading the event from the uffd, we put it on a temporary
fork_event list to detect if we can still access it after releasing and
retaking the event_wqh.lock.
If fork aborts and removes the event from the fork_event all is fine as
long as we're still in the userfault read context and fork_event head is
still alive.
We've to put the event allocated in the fork kernel stack, back from
fork_event list-head to the event_wqh head, before returning from
userfaultfd_ctx_read, because the fork_event head lifetime is limited to
the userfaultfd_ctx_read stack lifetime.
Forgetting to move the event back to its event_wqh place then results in
__remove_wait_queue(&ctx->event_wqh, &ewq->wq); in
userfaultfd_event_wait_completion to remove it from a head that has been
already freed from the reader stack.
This could only happen if resolve_userfault_fork failed (for example if
there are no file descriptors available to allocate the fork uffd). If
it succeeded it was put back correctly.
Furthermore, after find_userfault_evt receives a fork event, the forked
userfault context in fork_nctx and uwq->msg.arg.reserved.reserved1 can
be released by the fork thread as soon as the event_wqh.lock is
released. Taking a reference on the fork_nctx before dropping the lock
prevents an use after free in resolve_userfault_fork().
If the fork side aborted and it already released everything, we still
try to succeed resolve_userfault_fork(), if possible.
Fixes: 893e26e61d04eac9 ("userfaultfd: non-cooperative: Add fork() event")
Link: http://lkml.kernel.org/r/20170920180413.26713-1-aarcange@redhat.com
Reported-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
This is an enhancement to avoid a non cooperative userfaultfd manager
having to unregister all regions before it can close the uffd after all
userfaultfd activity completed.
The UFFDIO_UNREGISTER would serialize against the handle_userfault by
taking the mmap_sem for writing, but we can simply repeat the page fault
if we detect the uffd was closed and so the regular page fault paths
should takeover.
Link: http://lkml.kernel.org/r/20170823181227.19926-1-aarcange@redhat.com
Acked-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
No ABI change, but this will make it more explicit to software that ptid
is only available if requested by passing UFFD_FEATURE_THREAD_ID to
UFFDIO_API. The fact it's a union will also self document it shouldn't
be taken for granted there's a tpid there.
Link: http://lkml.kernel.org/r/20170802165145.22628-7-aarcange@redhat.com
Cc: Alexey Perevalov <a.perevalov@samsung.com>
Cc: Maxime Coquelin <maxime.coquelin@redhat.com>
It could be useful for calculating downtime during postcopy live
migration per vCPU. Side observer or application itself will be
informed about proper task's sleep during userfaultfd processing.
Process's thread id is being provided when user requeste it by setting
UFFD_FEATURE_THREAD_ID bit into uffdio_api.features.
Link: http://lkml.kernel.org/r/20170802165145.22628-6-aarcange@redhat.com
Signed-off-by: Alexey Perevalov <a.perevalov@samsung.com>
In some cases, userfaultfd mechanism should just deliver a SIGBUS signal
to the faulting process, instead of the page-fault event. Dealing with
page-fault event using a monitor thread can be an overhead in these
cases. For example applications like the database could use the
signaling mechanism for robustness purpose.
Database uses hugetlbfs for performance reason. Files on hugetlbfs
filesystem are created and huge pages allocated using fallocate() API.
Pages are deallocated/freed using fallocate() hole punching support.
These files are mmapped and accessed by many processes as shared memory.
The database keeps track of which offsets in the hugetlbfs file have
pages allocated.
Any access to mapped address over holes in the file, which can occur due
to bugs in the application, is considered invalid and expect the process
to simply receive a SIGBUS. However, currently when a hole in the file
is accessed via the mapped address, kernel/mm attempts to automatically
allocate a page at page fault time, resulting in implicitly filling the
hole in the file. This may not be the desired behavior for applications
like the database that want to explicitly manage page allocations of
hugetlbfs files.
Using userfaultfd mechanism with this support to get a signal, database
application can prevent pages from being allocated implicitly when
processes access mapped address over holes in the file.
This patch adds UFFD_FEATURE_SIGBUS feature to userfaultfd mechnism to
request for a SIGBUS signal.
See following for previous discussion about the database requirement
leading to this proposal as suggested by Andrea.
http://www.spinics.net/lists/linux-mm/msg129224.html
Link: http://lkml.kernel.org/r/1501552446-748335-2-git-send-email-prakash.sangappa@oracle.com
Signed-off-by: Prakash Sangappa <prakash.sangappa@oracle.com>
Cc: Shuah Khan <shuah@kernel.org>
Now when shmem VMAs can be filled with zero page via userfaultfd we can
report that UFFDIO_ZEROPAGE is available for those VMAs
Link: http://lkml.kernel.org/r/1497939652-16528-7-git-send-email-rppt@linux.vnet.ibm.com
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
include/linux/mm_types.h
mm/huge_memory.c
I removed the smp_mb__before_spinlock() like the following commit does:
8b1b436dd1cc ("mm, locking: Rework {set,clear,mm}_tlb_flush_pending()")
and fixed up the affected commits.
When the process exit races with outstanding mcopy_atomic, it would be
better to return ESRCH error. When such race occurs the process and
it's mm are going away and returning "no such process" to the uffd
monitor seems better fit than ENOSPC.
Link: http://lkml.kernel.org/r/1502111545-32305-1-git-send-email-rppt@linux.vnet.ibm.com
Suggested-by: Michal Hocko <mhocko@suse.com>
Now that there are no users of smp_mb__before_spinlock() left, remove
it entirely.
There may still be threads waiting on event_wqh at the time the
userfault file descriptor is closed. Flush the events wait-queue to
prevent waiting threads from hanging.
Link: http://lkml.kernel.org/r/1501398127-30419-1-git-send-email-rppt@linux.vnet.ibm.com
Fixes: 9cd75c3cd4c3d ("userfaultfd: non-cooperative: add ability to report
non-PF events from uffd descriptor")
In the non-cooperative userfaultfd case, the process exit may race with
outstanding mcopy_atomic called by the uffd monitor. Returning -ENOSPC
instead of -EINVAL when mm is already gone will allow uffd monitor to
distinguish this case from other error conditions.
Unfortunately I overlooked userfaultfd_zeropage when updating
userfaultd_copy().
Link: http://lkml.kernel.org/r/1501136819-21857-1-git-send-email-rppt@linux.vnet.ibm.com
Fixes: 96333187ab162 ("userfaultfd_copy: return -ENOSPC in case mm has gone")
Cc: Michal Hocko <mhocko@kernel.org>
A poisoned or migrated hugepage is stored as a swap entry in the page
tables. On architectures that support hugepages consisting of
contiguous page table entries (such as on arm64) this leads to ambiguity
in determining the page table entry to return in huge_pte_offset() when
a poisoned entry is encountered.
Let's remove the ambiguity by adding a size parameter to convey
additional information about the requested address. Also fixup the
definition/usage of huge_pte_offset() throughout the tree.
Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Steve Capper <steve.capper@arm.com>
Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE)
Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Calculation of start end end in __wake_userfault function are not used
and can be removed.
Link: http://lkml.kernel.org/r/1494930917-3134-1-git-send-email-rppt@linux.vnet.ibm.com
So I've noticed a number of instances where it was not obvious from the
code whether ->task_list was for a wait-queue head or a wait-queue entry.
Furthermore, there's a number of wait-queue users where the lists are
not for 'tasks' but other entities (poll tables, etc.), in which case
the 'task_list' name is actively confusing.
To clear this all up, name the wait-queue head and entry list structure
fields unambiguously:
struct wait_queue_head::task_list => ::head
struct wait_queue_entry::task_list => ::entry
For example, this code:
rqw->wait.task_list.next != &wait->task_list
... is was pretty unclear (to me) what it's doing, while now it's written this way:
rqw->wait.head.next != &wait->entry
... which makes it pretty clear that we are iterating a list until we see the head.
Other examples are:
list_for_each_entry_safe(pos, next, &x->task_list, task_list) {
list_for_each_entry(wq, &fence->wait.task_list, task_list) {
... where it's unclear (to me) what we are iterating, and during review it's
hard to tell whether it's trying to walk a wait-queue entry (which would be
a bug), while now it's written as:
list_for_each_entry_safe(pos, next, &x->head, entry) {
list_for_each_entry(wq, &fence->wait.head, entry) {
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
Anon and hugetlbfs handle FOLL_DUMP set by get_dump_page() internally to
__get_user_pages().
shmem as opposed has no special FOLL_DUMP handling there so
handle_mm_fault() is invoked without mmap_sem and ends up calling
handle_userfault() that isn't expecting to be invoked without mmap_sem
held.
This makes handle_userfault() fail immediately if invoked through
shmem_vm_ops->fault during coredumping and solves the problem.
The side effect is a BUG_ON with no lock held triggered by the
coredumping process which exits. Only 4.11 is affected, pre-4.11 anon
memory holes are skipped in __get_user_pages by checking FOLL_DUMP
explicitly against empty pagetables (mm/gup.c:no_page_table()).
It's zero cost as we already had a check for current->flags to prevent
futex to trigger userfaults during exit (PF_EXITING).
Link: http://lkml.kernel.org/r/20170615214838.27429-1-aarcange@redhat.com
Reported-by: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: <stable@vger.kernel.org> [4.11+]
fdinfo for userfault file descriptor reports UFFD_API_FEATURES. Up
until recently, the UFFD_API_FEATURES was defined as 0, therefore
corresponding field in fdinfo always contained zero. Now, with
introduction of several additional features, UFFD_API_FEATURES is not
longer 0 and it seems better to report actual features requested for the
userfaultfd object described by the fdinfo.
First, the applications that were using userfault will still see zero at
the features field in fdinfo. Next, reporting actual features rather
than available features, gives clear indication of what userfault
features are used by an application.
Link: http://lkml.kernel.org/r/1491140181-22121-1-git-send-email-rppt@linux.vnet.ibm.com
Merge 5-level page table prep from Kirill Shutemov:
"Here's relatively low-risk part of 5-level paging patchset. Merging it
now will make x86 5-level paging enabling in v4.12 easier.
The first patch is actually x86-specific: detect 5-level paging
support. It boils down to single define.
The rest of patchset converts Linux MMU abstraction from 4- to 5-level
paging.
Enabling of new abstraction in most cases requires adding single line
of code in arch-specific code. The rest is taken care by asm-generic/.
Changes to mm/ code are mostly mechanical: add support for new page
table level -- p4d_t -- where we deal with pud_t now.
v2:
- fix build on microblaze (Michal);
- comment for __ARCH_HAS_5LEVEL_HACK in kasan_populate_zero_shadow();
- acks from Michal"
* emailed patches from Kirill A Shutemov <kirill.shutemov@linux.intel.com>:
mm: introduce __p4d_alloc()
mm: convert generic code to 5-level paging
asm-generic: introduce <asm-generic/pgtable-nop4d.h>
arch, mm: convert all architectures to use 5level-fixup.h
asm-generic: introduce __ARCH_USE_5LEVEL_HACK
asm-generic: introduce 5level-fixup.h
x86/cpufeature: Add 5-level paging detection
It's a void function, so there is no return value;
Link: http://lkml.kernel.org/r/20170309150817.7510-1-david@redhat.com
Signed-off-by: David Hildenbrand <david@redhat.com>
userfaultfd_remove() has to be execute before zapping the pagetables or
UFFDIO_COPY could keep filling pages after zap_page_range returned,
which would result in non zero data after a MADV_DONTNEED.
However userfaultfd_remove() may have to release the mmap_sem. This was
handled correctly in MADV_REMOVE, but MADV_DONTNEED accessed a
potentially stale vma (the very vma passed to zap_page_range(vma, ...)).
The fix consists in revalidating the vma in case userfaultfd_remove()
had to release the mmap_sem.
This also optimizes away an unnecessary down_read/up_read in the
MADV_REMOVE case if UFFD_EVENT_FORK had to be delivered.
It all remains zero runtime cost in case CONFIG_USERFAULTFD=n as
userfaultfd_remove() will be defined as "true" at build time.
Link: http://lkml.kernel.org/r/20170302173738.18994-3-aarcange@redhat.com
Cc: Pavel Emelyanov <xemul@parallels.com>
We have a memleak in the ->new ctx if the uffd of the parent is closed
before the fork event is read, nothing frees the new context.
Link: http://lkml.kernel.org/r/20170302173738.18994-2-aarcange@redhat.com
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Don't stop running dup_fctx() even if userfaultfd_event_wait_completion
fails as it has to run userfaultfd_ctx_put on all ctx to pair against
the userfaultfd_ctx_get that was run on all fctx->orig in
dup_userfaultfd.
Link: http://lkml.kernel.org/r/20170224181957.19736-4-aarcange@redhat.com
Similar to the handle_userfault() case, also make sure to never attempt
to send any event past the PF_EXITING point of no return.
This is purely a robustness check.
Link: http://lkml.kernel.org/r/20170224181957.19736-3-aarcange@redhat.com
Patch series "userfaultfd non-cooperative further update for 4.11 merge
window".
Unfortunately I noticed one relevant bug in userfaultfd_exit while doing
more testing. I've been doing testing before and this was also tested
by kbuild bot and exercised by the selftest, but this bug never
reproduced before.
I dropped userfaultfd_exit as result. I dropped it because of
implementation difficulty in receiving signals in __mmput and because I
think -ENOSPC as result from the background UFFDIO_COPY should be enough
already.
Before I decided to remove userfaultfd_exit, I noticed userfaultfd_exit
wasn't exercised by the selftest and when I tried to exercise it, after
moving it to a more correct place in __mmput where it would make more
sense and where the vma list is stable, it resulted in the
event_wait_completion in D state. So then I added the second patch to
be sure even if we call userfaultfd_event_wait_completion too late
during task exit(), we won't risk to generate tasks in D state. The
same check exists in handle_userfault() for the same reason, except it
makes a difference there, while here is just a robustness check and it's
run under WARN_ON_ONCE.
While looking at the userfaultfd_event_wait_completion() function I
looked back at its callers too while at it and I think it's not ok to
stop executing dup_fctx on the fcs list because we relay on
userfaultfd_event_wait_completion to execute
userfaultfd_ctx_put(fctx->orig) which is paired against
userfaultfd_ctx_get(fctx->orig) in dup_userfault just before
list_add(fcs). This change only takes care of fctx->orig but this area
also needs further review looking for similar problems in fctx->new.
The only patch that is urgent is the first because it's an use after
free during a SMP race condition that affects all processes if
CONFIG_USERFAULTFD=y. Very hard to reproduce though and probably
impossible without SLUB poisoning enabled.
This patch (of 3):
I once reproduced this oops with the userfaultfd selftest, it's not
easily reproducible and it requires SLUB poisoning to reproduce.
general protection fault: 0000 [#1] SMP
Modules linked in:
CPU: 2 PID: 18421 Comm: userfaultfd Tainted: G ------------ T 3.10.0+ #15
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.10.1-0-g8891697-prebuilt.qemu-project.org 04/01/2014
task: ffff8801f83b9440 ti: ffff8801f833c000 task.ti: ffff8801f833c000
RIP: 0010:[<ffffffff81451299>] [<ffffffff81451299>] userfaultfd_exit+0x29/0xa0
RSP: 0018:ffff8801f833fe80 EFLAGS: 00010202
RAX: ffff8801f833ffd8 RBX: 6b6b6b6b6b6b6b6b RCX: ffff8801f83b9440
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800baf18600
RBP: ffff8801f833fee8 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: ffffffff8127ceb3 R12: 0000000000000000
R13: ffff8800baf186b0 R14: ffff8801f83b99f8 R15: 00007faed746c700
FS: 0000000000000000(0000) GS:ffff88023fc80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007faf0966f028 CR3: 0000000001bc6000 CR4: 00000000000006e0
Call Trace:
do_exit+0x297/0xd10
SyS_exit+0x17/0x20
tracesys+0xdd/0xe2
Code: 00 00 66 66 66 66 90 55 48 89 e5 41 54 53 48 83 ec 58 48 8b 1f 48 85 db 75 11 eb 73 66 0f 1f 44 00 00 48 8b 5b 10 48 85 db 74 64 <4c> 8b a3 b8 00 00 00 4d 85 e4 74 eb 41 f6 84 24 2c 01 00 00 80
RIP [<ffffffff81451299>] userfaultfd_exit+0x29/0xa0
RSP <ffff8801f833fe80>
---[ end trace 9fecd6dcb442846a ]---
In the debugger I located the "mm" pointer in the stack and walking
mm->mmap->vm_next through the end shows the vma->vm_next list is fully
consistent and it is null terminated list as expected. So this has to
be an SMP race condition where userfaultfd_exit was running while the
vma list was being modified by another CPU.
When userfaultfd_exit() run one of the ->vm_next pointers pointed to
SLAB_POISON (RBX is the vma pointer and is 0x6b6b..).
The reason is that it's not running in __mmput but while there are still
other threads running and it's not holding the mmap_sem (it can't as it
has to wait the even to be received by the manager). So this is an use
after free that was happening for all processes.
One more implementation problem aside from the race condition:
userfaultfd_exit has really to check a flag in mm->flags before walking
the vma or it's going to slowdown the exit() path for regular tasks.
One more implementation problem: at that point signals can't be
delivered so it would also create a task in D state if the manager
doesn't read the event.
The major design issue: it overall looks superfluous as the manager can
check for -ENOSPC in the background transfer:
if (mmget_not_zero(ctx->mm)) {
} else {
return -ENOSPC;
It's safer to roll it back and re-introduce it later if at all.
[rppt@linux.vnet.ibm.com: documentation fixup after removal of UFFD_EVENT_EXIT]
Link: http://lkml.kernel.org/r/1488345437-4364-1-git-send-email-rppt@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/20170224181957.19736-2-aarcange@redhat.com
__do_fault assumes vmf->page has been initialized and is valid if
VM_FAULT_NOPAGE is not returned by vma->vm_ops->fault(vma, vmf).
handle_userfault() in turn should return VM_FAULT_NOPAGE if it doesn't
return VM_FAULT_SIGBUS or VM_FAULT_RETRY (the other two possibilities).
This VM_FAULT_NOPAGE case is only invoked when signal are pending and it
didn't matter for anonymous memory before. It only started to matter
since shmem was introduced. hugetlbfs also takes a different path and
doesn't exercise __do_fault.
Link: http://lkml.kernel.org/r/20170228154201.GH5816@redhat.com
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Convert all non-architecture-specific code to 5-level paging.
It's mostly mechanical adding handling one more page table level in
places where we deal with pud_t.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/mm.h>
We are going to split <linux/sched/mm.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/mm.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
The APIs that are going to be moved first are:
mm_alloc()
__mmdrop()
mmdrop()
mmdrop_async_fn()
mmdrop_async()
mmget_not_zero()
mmput()
mmput_async()
get_task_mm()
mm_access()
mm_release()
Include the new header in the files that are going to need it.
Apart from adding the helper function itself, the rest of the kernel is
converted mechanically using:
git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)->mm_count);/mmgrab\(\1\);/'
git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)\.mm_count);/mmgrab\(\&\1\);/'
This is needed for a later patch that hooks into the helper, but might
be a worthwhile cleanup on its own.
(Michal Hocko provided most of the kerneldoc comment.)
Link: http://lkml.kernel.org/r/20161218123229.22952-1-vegard.nossum@oracle.com
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: David Rientjes <rientjes@google.com>
Fix typos and add the following to the scripts/spelling.txt:
an user||a user
an userspace||a userspace
I also added "userspace" to the list since it is a common word in Linux.
I found some instances for "an userfaultfd", but I did not add it to the
list. I felt it is endless to find words that start with "user" such as
"userland" etc., so must draw a line somewhere.
Link: http://lkml.kernel.org/r/1481573103-11329-4-git-send-email-yamada.masahiro@socionext.com
Link: http://lkml.kernel.org/r/1485542673-24387-6-git-send-email-rppt@linux.vnet.ibm.com
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Allow userfaultfd monitor track termination of the processes that have
memory backed by the uffd.
[rppt@linux.vnet.ibm.com: add comment]
Link: http://lkml.kernel.org/r/20170202135448.GB19804@rapoport-lnxLink: http://lkml.kernel.org/r/1485542673-24387-4-git-send-email-rppt@linux.vnet.ibm.com
When a non-cooperative userfaultfd monitor copies pages in the
background, it may encounter regions that were already unmapped.
Addition of UFFD_EVENT_UNMAP allows the uffd monitor to track precisely
changes in the virtual memory layout.
Since there might be different uffd contexts for the affected VMAs, we
first should create a temporary representation for the unmap event for
each uffd context and then notify them one by one to the appropriate
userfault file descriptors.
The event notification occurs after the mmap_sem has been released.
[arnd@arndb.de: fix nommu build]
Link: http://lkml.kernel.org/r/20170203165141.3665284-1-arnd@arndb.de
[mhocko@suse.com: fix nommu build]
Link: http://lkml.kernel.org/r/20170202091503.GA22823@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/1485542673-24387-3-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Michal Hocko <mhocko@suse.com>
Patch series "userfaultfd: non-cooperative: add madvise() event for
MADV_REMOVE request".
These patches add notification of madvise(MADV_REMOVE) event to
non-cooperative userfaultfd monitor.
The first pacth renames EVENT_MADVDONTNEED to EVENT_REMOVE along with
relevant functions and structures. Using _REMOVE instead of
_MADVDONTNEED describes the event semantics more clearly and I hope it's
not too late for such change in the ABI.
This patch (of 3):
The UFFD_EVENT_MADVDONTNEED purpose is to notify uffd monitor about
removal of certain range from address space tracked by userfaultfd.
Hence, UFFD_EVENT_REMOVE seems to better reflect the operation
semantics. Respectively, 'madv_dn' field of uffd_msg is renamed to
'remove' and the madvise_userfault_dontneed callback is renamed to
userfaultfd_remove.
Link: http://lkml.kernel.org/r/1484814154-1557-2-git-send-email-rppt@linux.vnet.ibm.com
Expand the userfaultfd_register/unregister routines to allow shared
memory VMAs.
Currently, there is no UFFDIO_ZEROPAGE and write-protection support for
shared memory VMAs, which is reflected in ioctl methods supported by
uffdio_register.
Link: http://lkml.kernel.org/r/20161216144821.5183-34-aarcange@redhat.com
Cc: Michael Rapoport <RAPOPORT@il.ibm.com>
Check whether a VMA can be used with userfault in more compact way
Link: http://lkml.kernel.org/r/20161216144821.5183-28-aarcange@redhat.com
Add routine userfaultfd_huge_must_wait which has the same functionality
as the existing userfaultfd_must_wait routine. Only difference is that
new routine must handle page table structure for hugepmd vmas.
Link: http://lkml.kernel.org/r/20161216144821.5183-24-aarcange@redhat.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Expand the userfaultfd_register/unregister routines to allow VM_HUGETLB
vmas. huge page alignment checking is performed after a VM_HUGETLB vma
is encountered.
Also, since there is no UFFDIO_ZEROPAGE support for huge pages do not
return that as a valid ioctl method for huge page ranges.
Link: http://lkml.kernel.org/r/20161216144821.5183-22-aarcange@redhat.com
Userfaults may still happen after the userfaultfd monitor thread
received a UFFD_EVENT_MADVDONTNEED until UFFDIO_UNREGISTER is run.
Wake any pending userfault within UFFDIO_UNREGISTER protected by the
mmap_sem for writing, so they will not be reported to userland leading
to UFFDIO_COPY returning -EINVAL (as the range was already unregistered)
and they will not hang permanently either.
Link: http://lkml.kernel.org/r/20161216144821.5183-16-aarcange@redhat.com
If the page is punched out of the address space the uffd reader should
know this and zeromap the respective area in case of the #PF event.
Link: http://lkml.kernel.org/r/20161216144821.5183-14-aarcange@redhat.com
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Optimize the mremap_userfaultfd_complete() interface to pass only the
vm_userfaultfd_ctx pointer through the stack as a microoptimization.
Link: http://lkml.kernel.org/r/20161216144821.5183-13-aarcange@redhat.com
Reported-by: Hillf Danton <hillf.zj@alibaba-inc.com>
The event denotes that an area [start:end] moves to different location.
Length change isn't reported as "new" addresses, if they appear on the
uffd reader side they will not contain any data and the latter can just
zeromap them.
Waiting for the event ACK is also done outside of mmap sem, as for fork
event.
Link: http://lkml.kernel.org/r/20161216144821.5183-12-aarcange@redhat.com
Since commit d2005e3f41d4 ("userfaultfd: don't pin the user memory in
userfaultfd_file_create()") userfaultfd uses mm_count rather than
mm_users to pin mm_struct.
Make dup_userfaultfd consistent with this behaviour
Link: http://lkml.kernel.org/r/20161216144821.5183-11-aarcange@redhat.com
