[ Upstream commit 31051c85b5e2aaaf6315f74c72a732673632a905 ]
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
References: CVE-2015-1350
Signed-off-by: Philipp Hahn <hahn@univention.de>
NFSv4 uses leases to guarantee that clients can cache metadata as well
as data.
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Dustin Kirkland <dustin.kirkland@gazzang.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Clearly, we can't handle the NULL filename case, but we can deal with
the case where there's a real pathname.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
* do not pass nameidata; struct path is all the callers want.
* switch to new helpers:
user_path_at(dfd, pathname, flags, &path)
user_path(pathname, &path)
user_lpath(pathname, &path)
user_path_dir(pathname, &path) (fail if not a directory)
The last 3 are trivial macro wrappers for the first one.
* remove nameidata in callers.
Incidentally, the name that gives hundreds of false positives on grep
is not a good idea...
Move the immutable and append-only checks from chmod, chown and utimes
into notify_change(). Checks for immutable and append-only files are
always performed by the VFS and not by the filesystem (see
permission() and may_...() in namei.c), so these belong in
notify_change(), and not in inode_change_ok().
This should be completely equivalent.
CC: Ulrich Drepper <drepper@redhat.com>
CC: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Untange the mess that is do_utimes(). Add kerneldoc comment to
do_utimes().
Add a new ia_valid flag: ATTR_TIMES_SET, to handle the
UTIMES_OMIT/UTIMES_NOW and UTIMES_NOW/UTIMES_OMIT cases. In these
cases neither ATTR_MTIME_SET nor ATTR_ATIME_SET is in the flags, yet
the POSIX draft specifies that permission checking is performed the
same way as if one or both of the times was explicitly set to a
timestamp.
See the path "vfs: utimensat(): fix error checking for
{UTIME_NOW,UTIME_OMIT} case" by Michael Kerrisk for the patch
introducing this behavior.
This is a cleanup, as well as allowing filesystems (NFS/fuse/...) to
perform their own permission checking instead of the default.
The POSIX.1 draft spec for futimens()/utimensat() says:
Only a process with the effective user ID equal to the
user ID of the file, *or with write access to the file*,
or with appropriate privileges may use futimens() or
utimensat() with a null pointer as the times argument
or with both tv_nsec fields set to the special value
UTIME_NOW.
The important piece here is "with write access to the file", and
this matters for futimens(), which deals with an argument that
is a file descriptor referring to the file whose timestamps are
being updated, The standard is saying that the "writability"
check is based on the file permissions, not the access mode with
which the file is opened. (This behavior is consistent with the
semantics of FreeBSD's futimes().) However, Linux is currently
doing the latter -- futimens(fd, times) is a library
function implemented as
utimensat(fd, NULL, times, 0)
and within the utimensat() implementation we have the code:
f = fget(dfd); // dfd is 'fd'
if (f) {
if (!(f->f_mode & FMODE_WRITE))
goto mnt_drop_write_and_out;
The check should instead be based on the file permissions.
Thanks to Miklos for pointing out how to do this check.
Miklos also pointed out a simplification that could be
made to my first version of this patch, since the checks
for the pathname and file descriptor cases can now be
conflated.
Acked-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: Ulrich Drepper <drepper@redhat.com>
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
The POSIX.1 draft spec for utimensat() says:
user ID of the file or with appropriate privileges may use
futimens() or utimensat() with a non-null times argument
that does not have both tv_nsec fields set to UTIME_NOW
and does not have both tv_nsec fields set to UTIME_OMIT.
If this condition is violated, then the error EPERM should result.
However, the current implementation does not generate EPERM if
one tv_nsec field is UTIME_NOW while the other is UTIME_OMIT.
It should give this error for that case.
This patch:
a) Repairs that problem.
b) Removes the now unneeded nsec_special() helper function.
c) Adds some comments to explain the checks that are being
performed.
Thanks to Miklos, who provided comments on the previous iteration
of this patch. As a result, this version is a little simpler and
and its logic is better structured.
Miklos suggested an alternative idea, migrating the
is_owner_or_cap() checks into fs/attr.c:inode_change_ok() via
the use of an ATTR_OWNER_CHECK flag. Maybe we could do that
later, but for now I've gone with this version, which is
IMO simpler, and can be more easily read as being correct.
UTIME_OMIT or UTIME_NOW
The POSIX.1 draft spec for utimensat() says that if a times[n].tv_nsec
field is UTIME_OMIT or UTIME_NOW, then the value in the corresponding
tv_sec field is ignored. See the last sentence of this para, from
the spec:
If the tv_nsec field of a timespec structure has
the special value UTIME_NOW, the file's relevant
timestamp shall be set to the greatest value
supported by the file system that is not greater than
the current time. If the tv_nsec field has the
special value UTIME_OMIT, the file's relevant
timestamp shall not be changed. In either case,
the tv_sec field shall be ignored.
However the current Linux implementation requires the tv_sec value to be
zero (or the EINVAL error results). This requirement should be removed.
This patch fixes utimensat() to make its behavior consistent
with that of utime()/utimes() when dealing with files marked
immutable and append-only.
The current utimensat() implementation also returns EPERM if
'times' is non-NULL and the tv_nsec fields are both UTIME_NOW.
For consistency, the
(times != NULL && times[0].tv_nsec == UTIME_NOW &&
times[1].tv_nsec == UTIME_NOW)
case should be treated like the traditional utimes() case where
'times' is NULL. That is, the call should succeed for a file
marked append-only and should give the error EACCES if the file
is marked as immutable.
The simple way to do this is to set 'times' to NULL
if (times[0].tv_nsec == UTIME_NOW && times[1].tv_nsec == UTIME_NOW).
This is also the natural approach, since POSIX.1 semantics consider the
times == {{x, UTIME_NOW}, {y, UTIME_NOW}}
to be exactly equivalent to the case for
times == NULL.
(Thanks to Miklos for pointing this out.)
Patch 3 in this series relies on the simplification provided
by this patch.
If utimensat() is called with both times set to UTIME_NOW or one of them to
UTIME_NOW and the other to UTIME_OMIT, then it will update the file time
without any permission checking.
I don't think this can be used for anything other than a local DoS, but could
be quite bewildering at that (e.g. "Why was that large source tree rebuilt
when I didn't modify anything???")
This affects all kernels from 2.6.22, when the utimensat() syscall was
introduced.
Fix by doing the same permission checking as for the "times == NULL" case.
Thanks to Michael Kerrisk, whose utimensat-non-conformances-and-fixes.patch in
-mm also fixes this (and breaks other stuff), only he didn't realize the
security implications of this bug.
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: <stable@kernel.org>
Now includes fix for oops seen by akpm.
"never let a libc developer write your kernel code" - hch
"nor, apparently, a kernel developer" - akpm
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Balbir Singh <balbir@in.ibm.com>
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
* Add path_put() functions for releasing a reference to the dentry and
vfsmount of a struct path in the right order
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
Every file should include the headers containing the prototypes for its global
functions.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
utimensat() (and possibly other callers of do_utimes()) didn't check if the
nanosecond value was within the allowed range.
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant
users to it. This is done because we want to avoid bugs in the future
where we check for only effective fsuid of the current task against a
file's owning uid, without simultaneously checking for CAP_FOWNER as
well, thus violating its semantics.
[ XFS uses special macros and structures, and in general looked ...
untouchable, so we leave it alone -- but it has been looked over. ]
The (current->fsuid != inode->i_uid) check in generic_permission() and
exec_permission_lite() is left alone, because those operations are
covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations
falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone.
Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
do_utimes() does not honour CAP_FOWNER when times==NULL.
Trivial and obvious one-line fix.
Commit 1c710c896eb461895d3c399e15bb5f20b39c9073 added the utimensat()
system call, but didn't handle the case of checking for the writability
of the target right, when the target was a file descriptor, not a
filename.
We cannot use vfs_permission(MAY_WRITE) for that case, and need to
simply check whether the file descriptor is writable. The oops from
using the wrong function was noticed and narrowed down by Markus
Trippelsdorf.
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Acked-by: Al Viro <viro@ftp.linux.org.uk>
Implement utimensat(2) which is an extension to futimesat(2) in that it
a) supports nano-second resolution for the timestamps
b) allows to selectively ignore the atime/mtime value
c) allows to selectively use the current time for either atime or mtime
d) supports changing the atime/mtime of a symlink itself along the lines
of the BSD lutimes(3) functions
For this change the internally used do_utimes() functions was changed to
accept a timespec time value and an additional flags parameter.
Additionally the sys_utime function was changed to match compat_sys_utime
which already use do_utimes instead of duplicating the work.
Also, the completely missing futimensat() functionality is added. We have
such a function in glibc but we have to resort to using /proc/self/fd/* which
not everybody likes (chroot etc).
Test application (the syscall number will need per-arch editing):
#include <errno.h>
#include <fcntl.h>
#include <time.h>
#include <sys/time.h>
#include <stddef.h>
#include <syscall.h>
#define __NR_utimensat 280
#define UTIME_NOW ((1l << 30) - 1l)
#define UTIME_OMIT ((1l << 30) - 2l)
int
main(void)
int status = 0;
int fd = open("ttt", O_RDWR|O_CREAT|O_EXCL, 0666);
if (fd == -1)
error (1, errno, "failed to create test file \"ttt\"");
struct stat64 st1;
if (fstat64 (fd, &st1) != 0)
error (1, errno, "fstat failed");
struct timespec t[2];
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0)
error (1, errno, "utimensat failed");
struct stat64 st2;
if (fstat64 (fd, &st2) != 0)
if (st2.st_atim.tv_sec != 0 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to zero");
status = 1;
if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0] = st1.st_atim;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_OMIT;
if (st2.st_atim.tv_sec != st1.st_atim.tv_sec
|| st2.st_atim.tv_nsec != st1.st_atim.tv_nsec)
puts ("atim not set");
status = 1;
puts ("mtim changed from zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_OMIT;
t[1] = st1.st_mtim;
puts ("mtim changed from original time");
status = 1;
if (st2.st_mtim.tv_sec != st1.st_mtim.tv_sec
|| st2.st_mtim.tv_nsec != st1.st_mtim.tv_nsec)
puts ("mtim not set");
status = 1;
if (status != 0)
goto out;
sleep (2);
t[0].tv_sec = 0;
t[0].tv_nsec = UTIME_NOW;
t[1].tv_sec = 0;
t[1].tv_nsec = UTIME_NOW;
struct timeval tv;
gettimeofday(&tv,NULL);
if (st2.st_atim.tv_sec <= st1.st_atim.tv_sec
|| st2.st_atim.tv_sec > tv.tv_sec)
puts ("atim not set to NOW");
status = 1;
if (st2.st_mtim.tv_sec <= st1.st_mtim.tv_sec
|| st2.st_mtim.tv_sec > tv.tv_sec)
puts ("mtim not set to NOW");
status = 1;
if (symlink ("ttt", "tttsym") != 0)
error (1, errno, "cannot create symlink");
t[0].tv_sec = 0;
t[0].tv_nsec = 0;
t[1].tv_sec = 0;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, AT_FDCWD, "tttsym", t, AT_SYMLINK_NOFOLLOW) != 0)
if (lstat64 ("tttsym", &st2) != 0)
error (1, errno, "lstat failed");
puts ("symlink atim not reset to zero");
status = 1;
puts ("symlink mtim not reset to zero");
status = 1;
if (status != 0)
goto out;
t[0].tv_sec = 1;
t[0].tv_nsec = 0;
t[1].tv_sec = 1;
t[1].tv_nsec = 0;
if (syscall(__NR_utimensat, fd, NULL, t, 0) != 0)
if (st2.st_atim.tv_sec != 1 || st2.st_atim.tv_nsec != 0)
puts ("atim not reset to one");
status = 1;
if (st2.st_mtim.tv_sec != 1 || st2.st_mtim.tv_nsec != 0)
puts ("mtim not reset to one");
status = 1;
if (status == 0)
puts ("all OK");
out:
close (fd);
unlink ("ttt");
unlink ("tttsym");
return status;
[akpm@linux-foundation.org: add missing i386 syscall table entry]
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: Alexey Dobriyan <adobriyan@openvz.org>
Cc: <linux-arch@vger.kernel.org>
* fs/open.c is getting bit crowdy
* preparation to lutimes(2)
