commit ffc4c92227db5699493e43eb140b4cb5904c30ff upstream.
Commit 786534b92f3c introduced a regression that caused listxattr to
return the POSIX ACL attribute names even though sysfs doesn't support
POSIX ACLs. This happens because simple_xattr_list checks for NULL
i_acl / i_default_acl, but inode_init_always initializes those fields
to ACL_NOT_CACHED ((void *)-1). For example:
$ getfattr -m- -d /sys
/sys: system.posix_acl_access: Operation not supported
/sys: system.posix_acl_default: Operation not supported
Fix this in simple_xattr_list by checking if the filesystem supports POSIX ACLs.
Fixes: 786534b92f3c ("tmpfs: listxattr should include POSIX ACL xattrs")
Reported-by: Marc Aurèle La France <tsi@tuyoix.net>
Tested-by: Marc Aurèle La France <tsi@tuyoix.net>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Cc: stable@vger.kernel.org # v4.5+
commit 82c9a927bc5df6e06b72d206d24a9d10cced4eb5 upstream.
When running in a container with a user namespace, if you call getxattr
with name = "system.posix_acl_access" and size % 8 != 4, then getxattr
silently skips the user namespace fixup that it normally does resulting in
un-fixed-up data being returned.
This is caused by posix_acl_fix_xattr_to_user() being passed the total
buffer size and not the actual size of the xattr as returned by
vfs_getxattr().
This commit passes the actual length of the xattr as returned by
vfs_getxattr() down.
A reproducer for the issue is:
touch acl_posix
setfacl -m user:0:rwx acl_posix
and the compile:
#define _GNU_SOURCE
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <attr/xattr.h>
/* Run in user namespace with nsuid 0 mapped to uid != 0 on the host. */
int main(int argc, void **argv)
ssize_t ret1, ret2;
char buf1[128], buf2[132];
int fret = EXIT_SUCCESS;
char *file;
if (argc < 2) {
fprintf(stderr,
"Please specify a file with "
"\"system.posix_acl_access\" permissions set\n");
_exit(EXIT_FAILURE);
file = argv[1];
ret1 = getxattr(file, "system.posix_acl_access",
buf1, sizeof(buf1));
if (ret1 < 0) {
fprintf(stderr, "%s - Failed to retrieve "
"\"system.posix_acl_access\" "
"from \"%s\"\n", strerror(errno), file);
ret2 = getxattr(file, "system.posix_acl_access",
buf2, sizeof(buf2));
if (ret2 < 0) {
if (ret1 != ret2) {
fprintf(stderr, "The value of \"system.posix_acl_"
"access\" for file \"%s\" changed "
"between two successive calls\n", file);
for (ssize_t i = 0; i < ret2; i++) {
if (buf1[i] == buf2[i])
continue;
fprintf(stderr,
"Unexpected different in byte %zd: "
"%02x != %02x\n", i, buf1[i], buf2[i]);
fret = EXIT_FAILURE;
if (fret == EXIT_SUCCESS)
fprintf(stderr, "Test passed\n");
else
fprintf(stderr, "Test failed\n");
_exit(fret);
and run:
./tester acl_posix
On a non-fixed up kernel this should return something like:
root@c1:/# ./t
Unexpected different in byte 16: ffffffa0 != 00
Unexpected different in byte 17: ffffff86 != 00
Unexpected different in byte 18: 01 != 00
and on a fixed kernel:
root@c1:~# ./t
Test passed
Fixes: 2f6f0654ab61 ("userns: Convert vfs posix_acl support to use kuids and kgids")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=199945
Reported-by: Colin Watson <cjwatson@ubuntu.com>
Signed-off-by: Christian Brauner <christian@brauner.io>
Acked-by: Serge Hallyn <serge@hallyn.com>
commit 57e7ba04d422c3d41c8426380303ec9b7533ded9 upstream.
security_inode_getsecurity() provides the text string value
of a security attribute. It does not provide a "secctx".
The code in xattr_getsecurity() that calls security_inode_getsecurity()
and then calls security_release_secctx() happened to work because
SElinux and Smack treat the attribute and the secctx the same way.
It fails for cap_inode_getsecurity(), because that module has no
secctx that ever needs releasing. It turns out that Smack is the
one that's doing things wrong by not allocating memory when instructed
to do so by the "alloc" parameter.
The fix is simple enough. Change the security_release_secctx() to
kfree() because it isn't a secctx being returned by
security_inode_getsecurity(). Change Smack to allocate the string when
told to do so.
Note: this also fixes memory leaks for LSMs which implement
inode_getsecurity but not release_secctx, such as capabilities.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 81be3dee96346fbe08c31be5ef74f03f6b63cf68 upstream.
getxattr uses vmalloc to allocate memory if kzalloc fails. This is
filled by vfs_getxattr and then copied to the userspace. vmalloc,
however, doesn't zero out the memory so if the specific implementation
of the xattr handler is sloppy we can theoretically expose a kernel
memory. There is no real sign this is really the case but let's make
sure this will not happen and use vzalloc instead.
Fixes: 779302e67835 ("fs/xattr.c:getxattr(): improve handling of allocation failures")
Link: http://lkml.kernel.org/r/20170306103327.2766-1-mhocko@kernel.org
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Michal Hocko <mhocko@suse.com>
The IOP_XATTR flag is set on sockfs because sockfs supports getting the
"system.sockprotoname" xattr. Since commit 6c6ef9f2, this flag is checked for
setxattr support as well. This is wrong on sockfs because security xattr
support there is supposed to be provided by security_inode_setsecurity. The
smack security module relies on socket labels (xattrs).
Fix this by adding a security xattr handler on sockfs that returns
-EAGAIN, and by checking for -EAGAIN in setxattr.
We cannot simply check for -EOPNOTSUPP in setxattr because there are
filesystems that neither have direct security xattr support nor support
via security_inode_setsecurity. A more proper fix might be to move the
call to security_inode_setsecurity into sockfs, but it's not clear to me
if that is safe: we would end up calling security_inode_post_setxattr after
that as well.
These inode operations are no longer used; remove them.
All filesystems that support xattrs by now do so via xattr handlers.
They all define sb->s_xattr, and their getxattr, setxattr, and
removexattr inode operations use the generic inode operations. On
filesystems that don't support xattrs, the xattr inode operations are
all NULL, and sb->s_xattr is also NULL.
This means that we can remove the getxattr, setxattr, and removexattr
inode operations and directly call the generic handlers, or better,
inline expand those handlers into fs/xattr.c.
Filesystems that do not support xattrs on some inodes should clear the
IOP_XATTR i_opflags flag in those inodes. (Right now, some filesystems
have checks to disable xattrs on some inodes in the ->list, ->get, and
->set xattr handler operations instead.) The IOP_XATTR flag is
automatically cleared in inodes of filesystems that don't have xattr
support.
In orangefs, symlinks do have a setxattr iop but no getxattr iop. Add a
check for symlinks to orangefs_inode_getxattr to preserve the current,
weird behavior; that check may not be necessary though.
When an inode doesn't support xattrs, turn listxattr off as well.
(When xattrs are "turned off", the VFS still passes security xattr
operations through to security modules, which can still expose inode
security labels that way.)
Right now, various places in the kernel check for the existence of
getxattr, setxattr, and removexattr inode operations and directly call
those operations. Switch to helper functions and test for the IOP_XATTR
flag instead.
Acked-by: James Morris <james.l.morris@oracle.com>
With this change, all the xattr handler based operations will produce an
-EIO result for bad inodes, and we no longer only depend on inode->i_op
to be set to bad_inode_ops.
The IOP_XATTR inode operations flag in inode->i_opflags indicates that
the inode has xattr support. The flag is automatically set by
new_inode() on filesystems with xattr support (where sb->s_xattr is
defined), and cleared otherwise. Filesystems can explicitly clear it
for inodes that should not have xattr support.
When NULL is passed to one of the xattr system calls as the attribute
name, copying that name from user space already fails with -EFAULT;
xattr_resolve_name is never called with a NULL attribute name.
When a filesystem outside of init_user_ns is mounted it could have
uids and gids stored in it that do not map to init_user_ns.
The plan is to allow those filesystems to set i_uid to INVALID_UID and
i_gid to INVALID_GID for unmapped uids and gids and then to handle
that strange case in the vfs to ensure there is consistent robust
handling of the weirdness.
Upon a careful review of the vfs and filesystems about the only case
where there is any possibility of confusion or trouble is when the
inode is written back to disk. In that case filesystems typically
read the inode->i_uid and inode->i_gid and write them to disk even
when just an inode timestamp is being updated.
Which leads to a rule that is very simple to implement and understand
inodes whose i_uid or i_gid is not valid may not be written.
In dealing with access times this means treat those inodes as if the
inode flag S_NOATIME was set. Reads of the inodes appear safe and
useful, but any write or modification is disallowed. The only inode
write that is allowed is a chown that sets the uid and gid on the
inode to valid values. After such a chown the inode is normal and may
be treated as such.
Denying all writes to inodes with uids or gids unknown to the vfs also
prevents several oddball cases where corruption would have occurred
because the vfs does not have complete information.
One problem case that is prevented is attempting to use the gid of a
directory for new inodes where the directories sgid bit is set but the
directories gid is not mapped.
Another problem case avoided is attempting to update the evm hash
after setxattr, removexattr, and setattr. As the evm hash includeds
the inode->i_uid or inode->i_gid not knowning the uid or gid prevents
a correct evm hash from being computed. evm hash verification also
fails when i_uid or i_gid is unknown but that is essentially harmless
as it does not cause filesystem corruption.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
smack ->d_instantiate() uses ->setxattr(), so to be able to call it before
we'd hashed the new dentry and attached it to inode, we need ->setxattr()
instances getting the inode as an explicit argument rather than obtaining
it from dentry.
Similar change for ->getxattr() had been done in commit ce23e64. Unlike
->getxattr() (which is used by both selinux and smack instances of
->d_instantiate()) ->setxattr() is used only by smack one and unfortunately
it got missed back then.
Reported-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
preparation for similar switch in ->setxattr() (see the next commit for
rationale).
Commit 98e9cb57 improved the xattr name checks in xattr_resolve_name but
didn't update the NULL attribute name check appropriately, so NULL
attribute names lead to NULL pointer dereferences. Turn that into
-EINVAL results instead.
fs/xattr.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
... and do not assume they are already attached to each other
The code could leak xattrs->lock on error.
Problem introduced with 786534b92f3ce68f4 "tmpfs: listxattr should
include POSIX ACL xattrs".
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
... instead of open coding it.
Signed-off-by: Richard Weinberger <richard@nod.at>
Change the list operation to only return whether or not an attribute
should be listed. Copying the attribute names into the buffer is moved
to the callers.
Since the result only depends on the dentry and not on the attribute
name, we do not pass the attribute name to list operations.
Add a nfs_listxattr operation. Move the call to security_inode_listsecurity
from list operation of the "security.*" xattr handler to nfs_listxattr.
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Cc: linux-nfs@vger.kernel.org
When a file on tmpfs has an ACL or a Default ACL, listxattr should include the
corresponding xattr name.
Reviewed-by: James Morris <james.l.morris@oracle.com>
Cc: linux-mm@kvack.org
Use the VFS xattr handler infrastructure and get rid of similar code in
the filesystem. For implementing shmem_xattr_handler_set, we need a
version of simple_xattr_set which removes the attribute when value is
NULL. Use this to implement kernfs_iop_removexattr as well.
Add an additional "name" field to struct xattr_handler. When the name
is set, the handler matches attributes with exactly that name. When the
prefix is set instead, the handler matches attributes with the given
prefix and with a non-empty suffix.
This patch should avoid bugs like the one fixed in commit c361016a in
the future.
This function was only briefly used in security/integrity/evm, between
commits 66dbc325 and 15647eb3.
Now that the xattr handler is passed to the xattr handler operations, we
can use the same get and set operations for the user, trusted, and security
xattr namespaces. In those namespaces, we can access the full attribute
name by "reattaching" the name prefix the vfs has skipped for us. Add a
xattr_full_name helper to make this obvious in the code.
For the "system.posix_acl_access" and "system.posix_acl_default"
attributes, handler->prefix is the full attribute name; the suffix is the
empty string.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: v9fs-developer@lists.sourceforge.net
The xattr_handler operations are currently all passed a file system
specific flags value which the operations can use to disambiguate between
different handlers; some file systems use that to distinguish the xattr
namespace, for example. In some oprations, it would be useful to also have
access to the handler prefix. To allow that, pass a pointer to the handler
to operations instead of the flags value alone.
EVM needs to be atomically updated when removing xattrs.
Otherwise concurrent EVM verification may fail in between.
This patch fixes by moving i_mutex unlocking after calling
EVM hook. fsnotify_xattr() is also now called while locked
the same way as it is done in __vfs_setxattr_noperm.
Changelog:
- remove unused 'inode' variable.
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
... for situations when we don't have any candidate in pathnames - basically,
in descriptor-based syscalls.
[Folded the build fix for !CONFIG_AUDITSYSCALL configs from Chen Gang]
The following pairs of system calls dealing with extended attributes only
differ in their behavior on whether the symbolic link is followed (when
the named file is a symbolic link):
- setxattr() and lsetxattr()
- getxattr() and lgetxattr()
- listxattr() and llistxattr()
- removexattr() and lremovexattr()
Despite this, the implementations all had duplicated code, so this commit
redirects each of the above pairs of system calls to a corresponding
function to which different lookup flags (LOOKUP_FOLLOW or 0) are passed.
For me this reduced the stripped size of xattr.o from 8824 to 8248 bytes.
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
If a filesystem uses simple_xattr to support user extended attributes,
LTP setxattr01 and xfstests generic/062 fail with "Cannot allocate
memory": simple_xattr_alloc()'s wrap-around test mistakenly excludes
values of zero size. Fix that off-by-one (but apparently no filesystem
needs them yet).
Cc: Jeff Layton <jlayton@poochiereds.net>
Cc: Aristeu Rozanski <aris@redhat.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Commit 38f38657444d ("xattr: extract simple_xattr code from tmpfs") moved
some code from tmpfs but introduced a subtle bug along the way.
If the name passed to simple_xattr_remove() does not exist in the list of
xattrs, then it is possible to call kfree(new_xattr) when new_xattr is
actually initialized to itself on the stack via uninitialized_var().
This causes a BUG() since the memory was not allocated via the slab
allocator and was not bypassed through to the page allocator because it
was too large.
Initialize the local variable to NULL so the kfree() never takes place.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Aristeu Rozanski <aris@redhat.com>
Currently, this gets set mostly by happenstance when we call into
audit_inode_child. While that might be a little more efficient, it seems
wrong. If the syscall ends up failing before audit_inode_child ever gets
called, then you'll have an audit_names record that shows the full path
but has the parent inode info attached.
Fix this by passing in a parent flag when we call audit_inode that gets
set to the value of LOOKUP_PARENT. We can then fix up the pathname for
the audit entry correctly from the get-go.
While we're at it, clean up the no-op macro for audit_inode in the
!CONFIG_AUDITSYSCALL case.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- Integrity: add local fs integrity verification to detect offline
attacks
- Integrity: add digital signature verification
- Simple stacking of Yama with other LSMs (per LSS discussions)
- IBM vTPM support on ppc64
- Add new driver for Infineon I2C TIS TPM
- Smack: add rule revocation for subject labels"
Fixed conflicts with the user namespace support in kernel/auditsc.c and
security/integrity/ima/ima_policy.c.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits)
Documentation: Update git repository URL for Smack userland tools
ima: change flags container data type
Smack: setprocattr memory leak fix
Smack: implement revoking all rules for a subject label
Smack: remove task_wait() hook.
ima: audit log hashes
ima: generic IMA action flag handling
ima: rename ima_must_appraise_or_measure
audit: export audit_log_task_info
tpm: fix tpm_acpi sparse warning on different address spaces
samples/seccomp: fix 31 bit build on s390
ima: digital signature verification support
ima: add support for different security.ima data types
ima: add ima_inode_setxattr/removexattr function and calls
ima: add inode_post_setattr call
ima: replace iint spinblock with rwlock/read_lock
ima: allocating iint improvements
ima: add appraise action keywords and default rules
ima: integrity appraisal extension
vfs: move ima_file_free before releasing the file
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
