Make the workqueues used by XFS freezeable, so their worker threads don't
submit any I/O after the suspend image has been created.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Nigel Cunningham <nigel@suspend2.net>
Cc: David Chinner <dgc@sgi.com>
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
CONFIG_XFS_TRACE is on
SGI-PV: 956618
SGI-Modid: xfs-linux-melb:xfs-kern:27196a
Signed-off-by: Vlad Apostolov <vapo@sgi.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Separate out the concept of "queue congestion" from "backing-dev congestion".
Congestion is a backing-dev concept, not a queue concept.
The blk_* congestion functions are retained, as wrappers around the core
backing-dev congestion functions.
This proper layering is needed so that NFS can cleanly use the congestion
functions, and so that CONFIG_BLOCK=n actually links.
Cc: "Thomas Maier" <balagi@justmail.de>
Cc: "Jens Axboe" <jens.axboe@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Peter Osterlund <petero2@telia.com>
buffers.
SGI-PV: 955302
SGI-Modid: xfs-linux-melb:xfs-kern:26801a
Signed-off-by: Nathan Scott <nathans@sgi.com>
one page.
SGI-PV: 955302
SGI-Modid: xfs-linux-melb:xfs-kern:26800a
SGI-PV: 944409
SGI-Modid: xfs-linux-melb:xfs-kern:26603a
analysis.
Under a sequential create+allocate workload, blktrace reported backward
writes being issued by xfsbufd, and frequent inappropriate queue unplugs.
We now insert at the tail when moving from the delwri lists to the temp
lists, which maintains correct ordering, and we avoid unplugging queues
deep in the submit paths when we'd shortly do it at a higher level anyway.
blktrace now reports much healthier write patterns from xfsbufd for this
workload (and likely many others).
SGI-PV: 954310
SGI-Modid: xfs-linux-melb:xfs-kern:26396a
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
Introduce GFP_NOWAIT, as an alias for GFP_ATOMIC & ~__GFP_HIGH.
This also changes XFS, which is the only in-tree user of this idiom that I
could find. The XFS piece is compile-tested only.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Acked-by: Nathan Scott <nathans@sgi.com>
* git://oss.sgi.com:8090/oss/git/xfs-2.6: (71 commits)
[XFS] Sync up one/two other minor changes missed in previous merges.
[XFS] Reenable the noikeep (delete inode cluster space) option by default.
[XFS] Check that a page has dirty buffers before finding it acceptable for
[XFS] Fixup naming inconsistencies found by Pekka Enberg and one from Jan
[XFS] Explain the race closed by the addition of vn_iowait() to the start
[XFS] Fixing the error caused by the conflict between DIO Write's
[XFS] Fixing KDB's xrwtrc command, also added the current process id into
[XFS] Fix compiler warning from xfs_file_compat_invis_ioctl prototype.
[XFS] remove bogus INT_GET for u8 variables in xfs_dir_leaf.c
[XFS] endianess annotations for xfs_da_node_hdr_t
[XFS] endianess annotations for xfs_da_node_entry_t
[XFS] store xfs_attr_inactive_list_t in native endian
[XFS] store xfs_attr_sf_sort in native endian
[XFS] endianess annotations for xfs_attr_shortform_t
[XFS] endianess annotations for xfs_attr_leaf_name_remote_t
[XFS] endianess annotations for xfs_attr_leaf_name_local_t
[XFS] endianess annotations for xfs_attr_leaf_entry_t
[XFS] endianess annotations for xfs_attr_leaf_hdr_t
[XFS] remove bogus INT_GET on u8 variables in xfs_dir2_block.c
[XFS] endianess annotations for xfs_da_blkinfo_t
Centralize the page migration functions in anticipation of additional
tinkering. Creates a new file mm/migrate.c
1. Extract buffer_migrate_page() from fs/buffer.c
2. Extract central migration code from vmscan.c
3. Extract some components from mempolicy.c
4. Export pageout() and remove_from_swap() from vmscan.c
5. Make it possible to configure NUMA systems without page migration
and non-NUMA systems with page migration.
I had to so some #ifdeffing in mempolicy.c that may need a cleanup.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
be passed.
SGI-PV: 949073
SGI-Modid: xfs-linux-melb:xfs-kern:25122a
Migrate a page with buffers without requiring writeback
This introduces a new address space operation migratepage() that may be used
by a filesystem to implement its own version of page migration.
A version is provided that migrates buffers attached to pages. Some
filesystems (ext2, ext3, xfs) are modified to utilize this feature.
The swapper address space operation are modified so that a regular
migrate_page() will occur for anonymous pages without writeback (migrate_pages
forces every anonymous page to have a swap entry).
Signed-off-by: Mike Kravetz <kravetz@us.ibm.com>
occur during log replay. Novell bug 145204, Fedora bug 177848.
SGI-PV: 948860
SGI-Modid: xfs-linux-melb:xfs-kern:25064a
changes.
SGI-PV: 947038
SGI-Modid: xfs-linux-melb:xfs-kern:24875a
SGI-PV: 947098
SGI-Modid: xfs-linux-melb:xfs-kern:203831a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
finally.
SGI-PV: 947038
SGI-Modid: xfs-linux-melb:xfs-kern:24866a
contention between filesystems and prevent deadlocks between filesystems
when a flush dependency exists between them.
SGI-PV: 947098
SGI-Modid: xfs-linux-melb:xfs-kern:24844a
Signed-off-by: David Chinner <dgc@sgi.com>
anymore and simplify the final put path a little
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:200790a
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23903a
replace PBF_NONE with an inverted PBF_DONE, so it's like all the other
flags.
SGI-PV: 942609
SGI-Modid: xfs-linux:xfs-kern:199136a
writes. In addition flush the disk cache on fsync if the sync cached
operation didn't sync the log to disk (this requires some additional
bookeping in the transaction and log code). If the device doesn't claim to
support barriers, the filesystem has an extern log volume or the trial
superblock write with barriers enabled failed we disable barriers and
print a warning. We should probably fail the mount completely, but that
could lead to nasty boot failures for the root filesystem. Not enabled by
default yet, needs more destructive testing first.
SGI-PV: 912426
SGI-Modid: xfs-linux:xfs-kern:198723a
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:198669a
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:198656a
reverse startup order
SGI-PV: 942063
SGI-Modid: xfs-linux:xfs-kern:198651a
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with
a many-threaded application which concurrently initializes different parts of
a large anonymous area.
This patch corrects that, by using a separate spinlock per page table page, to
guard the page table entries in that page, instead of using the mm's single
page_table_lock. (But even then, page_table_lock is still used to guard page
table allocation, and anon_vma allocation.)
In this implementation, the spinlock is tucked inside the struct page of the
page table page: with a BUILD_BUG_ON in case it overflows - which it would in
the case of 32-bit PA-RISC with spinlock debugging enabled.
Splitting the lock is not quite for free: another cacheline access. Ideally,
I suppose we would use split ptlock only for multi-threaded processes on
multi-cpu machines; but deciding that dynamically would have its own costs.
So for now enable it by config, at some number of cpus - since the Kconfig
language doesn't support inequalities, let preprocessor compare that with
NR_CPUS. But I don't think it's worth being user-configurable: for good
testing of both split and unsplit configs, split now at 4 cpus, and perhaps
change that to 8 later.
There is a benefit even for singly threaded processes: kswapd can be attacking
one part of the mm while another part is busy faulting.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
- ->releasepage() annotated (s/int/gfp_t), instances updated
- missing gfp_t in fs/* added
- fixed misannotation from the original sweep caught by bitwise checks:
XFS used __nocast both for gfp_t and for flags used by XFS allocator.
The latter left with unsigned int __nocast; we might want to add a
different type for those but for now let's leave them alone. That,
BTW, is a case when __nocast use had been actively confusing - it had
been used in the same code for two different and similar types, with
no way to catch misuses. Switch of gfp_t to bitwise had caught that
immediately...
One tricky bit is left alone to be dealt with later - mapping->flags is
a mix of gfp_t and error indications. Left alone for now.
Use schedule_timeout_{,un}interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size. Also use helper
functions to convert between human time units and jiffies rather than constant
HZ division to avoid rounding errors.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
SGI-PV: 942063
SGI-Modid: xfs-linux:xfs-kern:198388a
the pagebuf had been unlocked if the buffer was delwri. At high load, this
could result in a race when the superblock was being synced that would
result the flags being incorrect and the iodone functions being executed
incorrectly. This then leads to iclog callback failures or AIL list
corruptions resulting in filesystem shutdowns.
SGI-PV: 923981
SGI-Modid: xfs-linux:xfs-kern:23616a
SGI-PV: 934766
SGI-Modid: xfs-linux:xfs-kern:197783a
SGI-PV: 934766
SGI-Modid: xfs-linux:xfs-kern:196856a
handlers.
SGI-PV: 938409
SGI-Modid: xfs-linux:xfs-kern:22965a
1. Establish a simple API for process freezing defined in linux/include/sched.h:
frozen(process) Check for frozen process
freezing(process) Check if a process is being frozen
freeze(process) Tell a process to freeze (go to refrigerator)
thaw_process(process) Restart process
frozen_process(process) Process is frozen now
2. Remove all references to PF_FREEZE and PF_FROZEN from all
kernel sources except sched.h
3. Fix numerous locations where try_to_freeze is manually done by a driver
4. Remove the argument that is no longer necessary from two function calls.
5. Some whitespace cleanup
6. Clear potential race in refrigerator (provides an open window of PF_FREEZE
cleared before setting PF_FROZEN, recalc_sigpending does not check
PF_FROZEN).
This patch does not address the problem of freeze_processes() violating the rule
that a task may only modify its own flags by setting PF_FREEZE. This is not clean
in an SMP environment. freeze(process) is therefore not SMP safe!
Signed-off-by: Christoph Lameter <christoph@lameter.com>
SGI-PV: 936977
SGI-Modid: xfs-linux:xfs-kern:193409a
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:192756a
SGI-PV: 908809
SGI-Modid: xfs-linux:xfs-kern:192348a
SGI Modid: xfs-linux:xfs-kern:22342a
infrastructure for it.
Let it rip!
