path: root/fs/xfs/linux-2.6/xfs_super.h
2008-04-18[XFS] Remove CONFIG_XFS_SECURITY.Eric Sandeen
There is no point to the CONFIG_XFS_SECURITY option; it disables the ability to set security attributes at runtime, but it does not actually slim down or remove any code for runtime. Just remove it and always allow security attributes to be set. SGI-PV: 980310 SGI-Modid: xfs-linux-melb:xfs-kern:30877a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[XFS] kill struct bhv_vfsChristoph Hellwig
Now that struct bhv_vfs doesn't have any members left we can kill it and go directly from the super_block to the xfs_mount everywhere. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29509a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vfs-level helpers directly and remove vfs operationsChristoph Hellwig
Also remove the now dead behavior code. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29505a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] decontaminate vfs operations from behavior detailsChristoph Hellwig
All vfs ops now take struct xfs_mount pointers and the behaviour related glue is split out into methods of its own. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29504a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] remove dependency of the quota module on behaviorsChristoph Hellwig
Mount options are now parsed by the main XFS module and rejected if quota support is not available, and there are some new quota operation for the quotactl syscall and calls to quote in the mount, unmount and sync callchains. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29503a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Complete transition away from linvfs naming convention, finally.Nathan Scott
SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:25474a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Switch over from linvfs names for sb/quotactl operations forNathan Scott
consistent naming. SGI-PV: 950556 SGI-Modid: xfs-linux-melb:xfs-kern:25382a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] write barrier support Issue all log sync operations as orderedChristoph Hellwig
writes. In addition flush the disk cache on fsync if the sync cached operation didn't sync the log to disk (this requires some additional bookeping in the transaction and log code). If the device doesn't claim to support barriers, the filesystem has an extern log volume or the trial superblock write with barriers enabled failed we disable barriers and print a warning. We should probably fail the mount completely, but that could lead to nasty boot failures for the root filesystem. Not enabled by default yet, needs more destructive testing first. SGI-PV: 912426 SGI-Modid: xfs-linux:xfs-kern:198723a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
