path: root/fs/xfs/linux-2.6/xfs_vnode.h
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: remove IO_ISAIOChristoph Hellwig
We set the IO_ISAIO flag for all read/write I/O since early Linux 2.6.x. Remove it as it has lost it's purpose long ago. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-03-16xfs: kill VN_BADChristoph Hellwig
Remove this rather pointless wrapper and use is_bad_inode directly. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2009-03-16xfs: kill vn_atime_* helpers.Christoph Hellwig
Two out of three are unused already, and the third is better done open-coded with a comment describing what's going on here. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2009-02-04xfs: merge xfs_inode_flush into xfs_fs_write_inodeChristoph Hellwig
Splitting the task for a VFS-induced inode flush into two functions doesn't make any sense, so merge the two functions dealing with it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Reviewed-by: Dave Chinner <david@fromorbit.com>
2008-12-04move inode tracing out of xfs_vnode.Christoph Hellwig
Move the inode tracing into xfs_iget.c / xfs_inode.h and kill xfs_vnode.c now that it's empty. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04move vn_iowait / vn_iowake into xfs_aops.cChristoph Hellwig
The whole machinery to wait on I/O completion is related to the I/O path and should be there instead of in xfs_vnode.c. Also give the functions more descriptive names. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04kill vn_ioerrorChristoph Hellwig
There's just one caller of this helper, and it's much cleaner to just merge the xfs_do_force_shutdown call into it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04no explicit xfs_iflush for special inodes during unmountChristoph Hellwig
Currently we explicitly call xfs_iflush on the quota, real-time and root inodes from xfs_unmount_flush. But we just called xfs_sync_inodes with SYNC_ATTR and do an XFS_bflush aka xfs_flush_buftarg to make sure all inodes are on disk already, so there is no need for these special cases. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] remove xfs_vfs.hChristoph Hellwig
The only thing left are the forced shutdown flags and freeze macros which fit into xfs_mount.h much better. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-10-30[XFS] Use struct inodes instead of vnodes to kill vn_grabDavid Chinner
With the sync code relocated to the linux-2.6 directory we can use struct inodes directly. If we do the same thing for the quota release code, we can remove vn_grab altogether. While here, convert the VN_BAD() checks to is_bad_inode() so we can remove vnodes entirely from this code. SGI-PV: 988140 SGI-Modid: xfs-linux-melb:xfs-kern:32304a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-08-13[XFS] kill bhv_vnode_tChristoph Hellwig
All remaining bhv_vnode_t instance are in code that's more or less Linux specific. (Well, for xfs_acl.c that could be argued, but that code is on the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the whole tree. We can clean up variable naming and some useless helpers later. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31781a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] implement IHOLD/IRELE directlyChristoph Hellwig
Now that all direct calls to VN_HOLD/VN_RELE are gone we can implement IHOLD/IRELE directly. For the IHOLD case also replace igrab with a direct increment of i_count because we are guaranteed to already have a live and referenced inode by the VFS. Also remove the vn_hold statistic because it's been rather meaningless for some time with most references done by other callers. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31764a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill vn_to_inodeChristoph Hellwig
bhv_vnode_t is just a typedef for struct inode, so there's no need for a helper to convert between the two. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31761a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Remove vn_from_inode()Christoph Hellwig
bhv_vnode_t is just a typedef for struct inode, so there's no need for a helper to convert between the two. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31760a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] XFS: Kill xfs_vtoi()David Chinner
xfs_vtoi() is redundant and only unsed in small sections of code. Replace them with widely used XFS_I() inline and kill xfs_vtoi(). SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31725a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Remove vn_revalidate calls in xfs.Christoph Hellwig
These days most of the attributes in struct inode are properly kept in sync by XFS. This patch removes the need for vn_revalidate completely by: - keeping inode.i_flags uptodate after any flags are updated in xfs_ioctl_setattr - keeping i_mode, i_uid and i_gid uptodate in xfs_setattr SGI-PV: 984566 SGI-Modid: xfs-linux-melb:xfs-kern:31679a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Now that xfs_setattr is only used for attributes set from ->setattrChristoph Hellwig
it can be switched to take struct iattr directly and thus simplify the implementation greatly. Also rename the ATTR_ flags to XFS_ATTR_ to not conflict with the ATTR_ flags used by the VFS. SGI-PV: 984565 SGI-Modid: xfs-linux-melb:xfs-kern:31678a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] xfs_setattr currently doesn't just handle the attributes set throughChristoph Hellwig
->setattr but also addition XFS-specific attributes: project id, inode flags and extent size hint. Having these in a single function makes it more complicated and forces to have us a bhv_vattr intermediate structure eating up stackspace. This patch adds a new xfs_ioctl_setattr helper for the XFS ioctls that set these attributes and remove the code to set them through xfs_setattr. SGI-PV: 984564 SGI-Modid: xfs-linux-melb:xfs-kern:31677a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-05-23[XFS] Fix fsync() b0rkage.David Chinner
xfs_fsync() fails to wait for data I/O completion before checking if the inode is dirty or clean to decide whether to log the inode or not. This misses inode size updates when the data flushed by the fsync() is extending the file. Hence, like fdatasync(), we need to wait for I/o completion first, then check the inode for cleanliness. Doing so makes the behaviour of xfs_fsync() identical for fsync and fdatasync and we *always* use synchronous semantics if the inode is dirty. Therefore also kill the differences and remove the unused flags from the xfs_fsync function and callers. SGI-PV: 981296 SGI-Modid: xfs-linux-melb:xfs-kern:31033a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] Remove VN_IS* macros and related cruft.Christoph Hellwig
We can just check i_mode / di_mode directly. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30896a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] remove bhv_vname_t and xfs_rename codeBarry Naujok
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30804a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30775a Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] kill xfs_rwlock/xfs_rwunlockChristoph Hellwig
We can just use xfs_ilock/xfs_iunlock instead and get rid of the ugly bhv_vrwlock_t. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30533a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] kill xfs_get_dir_entryChristoph Hellwig
Instead of of xfs_get_dir_entry use a macro to get the xfs_inode from the dentry in the callers and grab the reference manually. Only grab the reference once as it's fine to keep it over the dmapi calls. (And even that reference is actually superflous in Linux but I'll leave that for another patch) SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30531a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Don't block pdflush when writing back inodesDavid Chinner
When pdflush is writing back inodes, it can get stuck on inode cluster buffers that are currently under I/O. This occurs when we write data to multiple inodes in the same inode cluster at the same time. Effectively, delayed allocation marks the inode dirty during the data writeback. Hence if the inode cluster was flushed during the writeback of the first inode, the writeback of the second inode will block waiting for the inode cluster write to complete before writing it again for the newly dirtied inode. Basically, we want to avoid this from happening so we don't block pdflush and slow down all of writeback. Hence we introduce a non-blocking async inode flush flag that pdflush uses. If this flag is set, we use non-blocking operations (e.g. try locks) whereever we can to avoid blocking or extra I/O being issued. SGI-PV: 970925 SGI-Modid: xfs-linux-melb:xfs-kern:30501a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] cleanup vnode useage in xfs_iget.cChristoph Hellwig
Get rid of vnode useage in xfs_iget.c and pass Linux inode / xfs_inode where apropinquate. And kill some useless helpers while we're at it. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29808a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] simplify vn_revalidateChristoph Hellwig
No need to allocate a bhv_vattr_t on stack and call xfs_getattr to update a few fields in the Linux inode from the XFS inode, just do it directly. And yes, this function is in dire need of a better name and prototype, I'll do in a separate patch, though. SGI-PV: 970705 SGI-Modid: xfs-linux-melb:xfs-kern:29713a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] more vnode/inode tracing fixesLachlan McIlroy
SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29697a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] clean up vnode/inode tracingLachlan McIlroy
Simplify vnode tracing calls by embedding function name & return addr in the calling macro. Also do a lot of vnode->inode renaming for consistency, while we're at it. SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29650a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill struct bhv_vfsChristoph Hellwig
Now that struct bhv_vfs doesn't have any members left we can kill it and go directly from the super_block to the xfs_mount everywhere. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29509a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill struct bhv_vnodeChristoph Hellwig
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t as a typedef for struct inode for the time being until all the fallout is cleaned up. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29500a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the v_number member in struct bhv_vnodeChristoph Hellwig
It's entirely unused except for ignored arguments in the mrlock initialization, so remove it. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29499a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_trace from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the trace buffer to the XFS inode. Note that this makes the tracing macros rather misnamed, but this kind of fallout will be fixed up incrementally later on. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29498a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_iocount from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the I/O count to the XFS inode. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29497a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the v_flag member in struct bhv_vnodeChristoph Hellwig
All flags previously handled at the vnode level are not in the xfs_inode where we already have a flags mechanisms and free bits for flags previously in the vnode. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29495a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill v_vfsp member from struct bhv_vnodeChristoph Hellwig
We can easily get at the vfsp through the super_block but it will soon be gone anyway. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29494a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] stop using uio in the readlink codeChristoph Hellwig
Simplify the readlink code to get rid of the last user of uio. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29479a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] use filldir internallyChristoph Hellwig
Currently xfs has a rather complicated internal scheme to allow for different directory formats in IRIX. This patch rips all code related to this out and pushes useage of the Linux filldir callback into the lowlevel directory code. This does not make the code any less portable because filldir can be used to create dirents of all possible variations (including the IRIX ones as proved by the IRIX binary emulation code under arch/mips/). This patch get rid of an unessecary copy in the readdir path, about 400 lines of code and one of the last two users of the uio structure. This version is updated to deal with dmapi aswell which greatly simplifies the get_dirattrs code. The dmapi part has been tested using the get_dirattrs tools from the xfstest dmapi suite1 with various small and large directories. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29478a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] XFS should not be looking at filp reference countsChristoph Hellwig
A check for file_count is always a bad idea. Linux has the ->release method to deal with cleanups on last close and ->flush is only for the very rare case where we want to perform an operation on every drop of a reference to a file struct. This patch gets rid of vop_close and surrounding code in favour of simply doing the page flushing from ->release. SGI-PV: 966562 SGI-Modid: xfs-linux-melb:xfs-kern:28952a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08[XFS] propogate return codes from flush routinesLachlan McIlroy
This patch handles error return values in fs_flush_pages and fs_flushinval_pages. It changes the prototype of fs_flushinval_pages so we can propogate the errors and handle them at higher layers. I also modified xfs_itruncate_start so that it could propogate the error further. SGI-PV: 961990 SGI-Modid: xfs-linux-melb:xfs-kern:28231a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Stewart Smith <stewart@flamingspork.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Keep stack usage down for 4k stacks by using noinline.David Chinner
gcc-4.1 and more recent aggressively inline static functions which increases XFS stack usage by ~15% in critical paths. Prevent this from occurring by adding noinline to the STATIC definition. Also uninline some functions that are too large to be inlined and were causing problems with CONFIG_FORCED_INLINING=y. Finally, clean up all the different users of inline, __inline and __inline__ and put them under one STATIC_INLINE macro. For debug kernels the STATIC_INLINE macro uninlines those functions. SGI-PV: 957159 SGI-Modid: xfs-linux-melb:xfs-kern:27585a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] remove bhv_lookup, _range version works aswell and has more usefulChristoph Hellwig
semantics. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26563a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-27[XFS] * There is trivial "inode => vnode => inode" conversion, but onlyAlexey Dobriyan
flags and mode of final inode are looked at. Pass original inode instead. * Two occurences of bhv_vnode_t go out. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26298a Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on remaining vtypes for FreeBSDNathan Scott
porters. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26108a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
