path: root/fs/xfs/quota
2008-08-13[XFS] Use KM_NOFS for debug trace buffersLachlan McIlroy
Use KM_NOFS to prevent recursion back into the filesystem which can cause deadlocks. In the case of xfs_iread() we hold the lock on the inode cluster buffer while allocating memory for the trace buffers. If we recurse back into XFS to flush data that may require a transaction to allocate extents which needs log space. This can deadlock with the xfsaild thread which can't push the tail of the log because it is trying to get the inode cluster buffer lock. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31838a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-08-13[XFS] cleanup xfs_mountfsChristoph Hellwig
Remove all the useless flags and code keyed off it in xfs_mountfs. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31831a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] replace dquot flush semaphore with a completionDavid Chinner
Use the new completion flush code to implement the dquot flush lock. Removes one of the final users of semaphores in the XFS code base. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31822a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill bhv_vnode_tChristoph Hellwig
All remaining bhv_vnode_t instance are in code that's more or less Linux specific. (Well, for xfs_acl.c that could be argued, but that code is on the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the whole tree. We can clean up variable naming and some useless helpers later. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31781a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] remove remaining VN_HOLD callsChristoph Hellwig
Use IHOLD(ip) instead of VN_HOLD(VFS_I(ip)). SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31765a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Kill shouty XFS_ITOV() macroDavid Chinner
Replace XFS_ITOV() with the new VFS_I() inline. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31724a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill shouty XFS_ITOV_NULL macroDavid Chinner
Replace XFS_ITOV_NULL() with the new VFS_I() inline. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31722a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] s/XFS_PURGE_INODE/IRELE/g s/VN_HOLD(XFS_ITOV())/IHOLD()/Christoph Hellwig
SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31405a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Remove unused Falgs parameter from xfs_qm_dqpurge()Denys Vlasenko
SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31056a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] shrink mrlock_tChristoph Hellwig
The writer field is not needed for non_DEBU builds so remove it. While we're at i also clean up the interface for is locked asserts to go through and xfs_iget.c helper with an interface like the xfs_ilock routines to isolated the XFS codebase from mrlock internals. That way we can kill mrlock_t entirely once rw_semaphores grow an islocked facility. Also remove unused flags to the ilock family of functions. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30902a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] kill di_mode checks after xfs_igetChristoph Hellwig
Unless XFS_IGET_CREATE is passed xfs_iget will return ENOENT if it encounters an inode with di_mode == 0. Remove the duplicated checks in the callers. (the log recovery case is not touched for now) SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30898a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Ensure xfs_bawrite() errors are checked.David Chinner
xfs_bawrite() can return immediate error status on async writes. Unlike xfsbdstrat() we don't ever check the error on the buffer after the call, so we currently do not catch errors at all here. Ensure we catch and propagate or warn to the syslog about up-front async write errors. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30824a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Propagate errors from xfs_trans_commit().David Chinner
xfs_trans_commit() can return errors when there are problems in the transaction subsystem. They are indicative that the entire transaction may be incomplete, and hence the error should be propagated as there is a good possibility that there is something fatally wrong in the filesystem. Catch and propagate or warn about commit errors in the places where they are currently ignored. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30795a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Propagate quota file truncation errors.David Chinner
Truncating the quota files can silently fail. Ensure that truncation errors are propagated to the callers. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30791a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Catch errors when turning off quotas.David Chinner
When turning off quota, we need to write various transactions to the log to ensure that they are cleanly removed in the case of a crash. We need to check that the transactions hit the disk correctly. If we fail to write the final quota off transaction, we are corrupt in memory and so the only option is to shut the filesystem down at this point. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30790a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Catch errors resetting quota flags.David Chinner
Warn to the syslog if we fail to reset the quota flags in the superblock when a quota check fails. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30789a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Clean up quotamount error handling.David Chinner
xfs_qm_mount_quotas() returns an error status that is ignored. If we fail to mount quotas, we continue with quota's turned off, which is all handled inside xfs_qm_mount_quotas(). Mark it as void to indicate that errors need not be returned to the callers. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30788a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Check for dquot flush errorsDavid Chinner
xfs_qm_dqflush() can fail, but the return is not checked anywhere. Hence we never know if we've failed to flush a dquot to disk. Propagate the error and warn to the syslog if a flush ever fails. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30787a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Propagate xfs_qm_dqflush_all() errors.David Chinner
xfs_qm_dqflush_all() can return flush errors. Ensure they are propagated into the quotacheck code to determine if the quotacheck succeeded or not. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30786a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] xfs_qm_reset_dqcounts() does not return errors.David Chinner
Declare it void. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30785a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Replace __inline with inlineHarvey Harrison
Remove the remaining uses of __inline in the XFS code base. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30774a Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] remove most calls to VN_RELEChristoph Hellwig
Most VN_RELE calls either directly contain a XFS_ITOV or have the corresponding xfs_inode already in scope. Use the IRELE helper instead of VN_RELE to clarify the code. With a little more work we can kill VN_RELE altogether and define IRELE in terms of iput directly. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30710a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[XFS] Remove the BPCSHIFT and NB* based macros from XFS.Tim Shimmin
The BPCSHIFT based macros, btoc*, ctob*, offtoc* and ctooff are either not used or don't need to be used. The NDPP, NDPP, NBBY macros don't need to be used but instead are replaced directly by PAGE_SIZE and PAGE_CACHE_SIZE where appropriate. Initial patch and motivation from Nicolas Kaiser. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30096a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Remove spin.hEric Sandeen
remove spinlock init abstraction macro in spin.h, remove the callers, and remove the file. Move no-op spinlock_destroy to xfs_linux.h Cleanup spinlock locals in xfs_mount.c SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29751a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] Unwrap XFS_SB_LOCK.Eric Sandeen
Un-obfuscate XFS_SB_LOCK, remove XFS_SB_LOCK->mutex_lock->spin_lock macros, call spin_lock directly, remove extraneous cookie holdover from old xfs code, and change lock type to spinlock_t. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29746a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] Unwrap XFS_DQ_PINUNLOCK.Eric Sandeen
Un-obfuscate DQ_PINLOCK, remove DQ_PINLOCK->mutex_lock->spin_lock macros, call spin_lock directly, remove extraneous cookie holdover from old xfs code, and change lock type to spinlock_t. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29742a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] Unwrap AIL_LOCKDonald Douwsma
SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29739a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-12-10[XFS] Fix dbflush panic in xfs_qm_sync.Donald Douwsma
The recent behaviour layer removal dropped the check for quotas that have been requested at mount time but have subsequently been turned off. This results in a panic when accessing m_quotainfo which has been freed. This patch adds the check originally made by xfs_qm_syncall() to xfs_qm_sync(). SGI-PV: 969769 SGI-Modid: xfs-linux-melb:xfs-kern:29908a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-16[XFS] kill the vfs_flags member in struct bhv_vfsChristoph Hellwig
All flags are added to xfs_mount's m_flag instead. Note that the 32bit inode flag was duplicated in both of them, but only cleared in the mount when it was not nessecary due to the filesystem beeing small enough. Two flags are still required here - one to indicate the mount option setting, and one to indicate if it applies or not. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29507a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] remove dependency of the quota module on behaviorsChristoph Hellwig
Mount options are now parsed by the main XFS module and rejected if quota support is not available, and there are some new quota operation for the quotactl syscall and calls to quote in the mount, unmount and sync callchains. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29503a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill struct bhv_vnodeChristoph Hellwig
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t as a typedef for struct inode for the time being until all the fallout is cleaned up. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29500a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] split ondisk vs incore versions of xfs_bmbt_rec_tChristoph Hellwig
currently xfs_bmbt_rec_t is used both for ondisk extents as well as host-endian ones. This patch adds a new xfs_bmbt_rec_host_t for the native endian ones and cleans up the fallout. There have been various endianess issues in the tracing / debug printf code that are fixed by this patch. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29318a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-09-05[XFS] fix nasty quota hashtable allocation bugEric Sandeen
This git mod: 77e4635ae191774526ed695482a151ac986f3806 converted to a "greedy" allocation interface, but for the quota hashtables it switched from allocating XFS_QM_HASHSIZE (nr of elements) xfs_dqhash_t's to allocating only XFS_QM_HASHSIZE *bytes* - quite a lot smaller! Then when we converted hsize "back" to nr of elements (the division line) hsize went to 0. This was leading to oopses when running any quota tests on the Fedora 8 test kernel, but the problem has been there for almost a year. SGI-PV: 968837 SGI-Modid: xfs-linux-melb:xfs-kern:29354a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-17mm: clean up and kernelify shrinker registrationRusty Russell
I can never remember what the function to register to receive VM pressure is called. I have to trace down from __alloc_pages() to find it. It's called "set_shrinker()", and it needs Your Help. 1) Don't hide struct shrinker. It contains no magic. 2) Don't allocate "struct shrinker". It's not helpful. 3) Call them "register_shrinker" and "unregister_shrinker". 4) Call the function "shrink" not "shrinker". 5) Reduce the 17 lines of waffly comments to 13, but document it properly. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: David Chinner <dgc@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-14[XFS] Quota inode has no parent.David Chinner
Avoid using a special "zero inode" as the parent of the quota inode as this can confuse the filestreams code into thinking the quota inode has a parent. We do not want the quota inode to follow filestreams allocation rules, so pass a NULL as the parent inode and detect this condition when doing stream associations. SGI-PV: 964469 SGI-Modid: xfs-linux-melb:xfs-kern:29098a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Use generic shrinker interfaces in XFS.Andrew Morton
SGI-PV: 964986 SGI-Modid: xfs-linux-melb:xfs-kern:28642a Signed-Off-By: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Fix uquota and oquota enforcement problems.Kouta Ooizumi
When uquota and oquota (gquota/pquota) are enabled for accounting both are enforced if ether has enforcement active. Conditions: - Both XFS_UQUOTA_ACCT and XFS_GQUOTA_ACCT are enabled. - Either XFS_UQUOTA_ENFD or XFS_OQUOTA_ENFD is enabled. - The usage without enforce is reached at the soft limit. Problems: 1. "repquota" shows all grace time even if no enforcement. 2. we cannot make a file over a hard limits even if no enforcement. SGI-PV: 962291 SGI-Modid: xfs-linux-melb:xfs-kern:28272a Signed-off-by: Kouta Ooizumi <k-ooizumi@tnes.nec.co.jp> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Fix quotaon syscall failures for group enforcement requests.Donald Douwsma
xfs_qm_scall_quotaon was incorrectly failing requests to enable group quota enforcement. Fixes logic error in OQUOTA handling. SGI-PV: 961964 SGI-Modid: xfs-linux-melb:xfs-kern:28227a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Invalidate quotacheck when mounting without a quota type.Donald Douwsma
When quotas are mounted or remounted without a particular quota type the quota accounting for that type becomes invalid. Previously we were ignoring this leading to accounting errors. SGI-PV: 961964 SGI-Modid: xfs-linux-melb:xfs-kern:28225a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Utako Kusaka <utako@tnes.nec.co.jp> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused header files for MAC and CAP checking functionality.Eric Sandeen
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used anywhere in XFS at all. They are left-overs from "to be implement at some point in the future" functionality that Irix XFS has. If this functionality ever goes into Linux, it will be provided at a different layer, most likely through the security hooks in the kernel so we will never need this functionality in XFS. Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960895 SGI-Modid: xfs-linux-melb:xfs-kern:28036a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused argument to xfs_bmap_finishEric Sandeen
The firstblock argument to xfs_bmap_finish is not used by that function. Remove it and cleanup the code a bit. Patch provided by Eric Sandeen. SGI-PV: 960196 SGI-Modid: xfs-linux-melb:xfs-kern:28034a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] remove unused xflags parameter from sync routinesLachlan McIlroy
SGI-PV: 959137 SGI-Modid: xfs-linux-melb:xfs-kern:27710a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Keep stack usage down for 4k stacks by using noinline.David Chinner
gcc-4.1 and more recent aggressively inline static functions which increases XFS stack usage by ~15% in critical paths. Prevent this from occurring by adding noinline to the STATIC definition. Also uninline some functions that are too large to be inlined and were causing problems with CONFIG_FORCED_INLINING=y. Finally, clean up all the different users of inline, __inline and __inline__ and put them under one STATIC_INLINE macro. For debug kernels the STATIC_INLINE macro uninlines those functions. SGI-PV: 957159 SGI-Modid: xfs-linux-melb:xfs-kern:27585a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Fix kmem_zalloc_greedy warnings on 64 bit platforms.Nathan Scott
SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26907a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add a greedy allocation interface, allocating within a min/max sizeNathan Scott
range. SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26803a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add a debug flag for allocations which are known to be larger thanNathan Scott
one page. SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26800a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
