If we get ENOSPC half way through setting the ACL, the inode mode
can still be changed even though the ACL does not exist. Reorder the
operation to only change the mode of the inode if the ACL is set
correctly.
Whilst this does not fix the problem with crash consistency (that requires
attribute addition to be a deferred op) it does prevent ENOSPC and other
non-fatal errors setting an xattr to be handled sanely.
This fixes xfstests generic/449.
Signed-Off-By: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
When new directory 'DIR1' is created in a directory 'DIR0' with SGID bit
set, DIR1 is expected to have SGID bit set (and owning group equal to
the owning group of 'DIR0'). However when 'DIR0' also has some default
ACLs that 'DIR1' inherits, setting these ACLs will result in SGID bit on
'DIR1' to get cleared if user is not member of the owning group.
Fix the problem by calling __xfs_set_acl() instead of xfs_set_acl() when
setting up inode in xfs_generic_create(). That prevents SGID bit
clearing and mode is properly set by posix_acl_create() anyway. We also
reorder arguments of __xfs_set_acl() to match the ordering of
xfs_set_acl() to make things consistent.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
CC: stable@vger.kernel.org
CC: Darrick J. Wong <darrick.wong@oracle.com>
CC: linux-xfs@vger.kernel.org
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
Instead of adding the synthesized POSIX ACL attribute names after listing all
non-synthesized attributes, generate them immediately when listing the
non-synthesized attributes.
In addition, merge xfs_xattr_put_listent and xfs_xattr_put_listent_sizes to
ensure that the list size is computed correctly; the split version was
overestimating the list size for non-root users.
Cc: xfs@oss.sgi.com
Error codes from xfs_attr_get other than -ENOATTR were not properly
reported. Fix that.
In addition, the declaration of struct xfs_inode in xfs_acl.h isn't needed.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
In xfs_acl_from_disk, instead of trusting that xfs_acl.acl_cnt is correct,
make sure that the length of the attributes is correct as well. Also, turn
the aclp parameter into a const pointer.
More on-disk format consolidation.
More on-disk format consolidation. A few declarations that weren't on-disk
format related move into better suitable spots.
Convert all the errors the core XFs code to negative error signs
like the rest of the kernel and remove all the sign conversion we
do in the interface layers.
Errors for conversion (and comparison) found via searches like:
$ git grep " E" fs/xfs
$ git grep "return E" fs/xfs
$ git grep " E[A-Z].*;$" fs/xfs
Negation points found via searches like:
$ git grep "= -[a-z,A-Z]" fs/xfs
$ git grep "return -[a-z,A-D,F-Z]" fs/xfs
$ git grep " -[a-z].*;" fs/xfs
[ with some bits I missed from Brian Foster ]
Signed-off-by: Dave Chinner <dchinner@redhat.com>
We should return -E2BIG rather than -EINVAL if hit the maximum size
limits of ACLS, as the former is consistent with VFS xattr syscalls.
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux,
and create inodes with the proper mode instead of fixing it up later.
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
Currently the xfs_inode.h header has a dependency on the definition
of the BMAP btree records as the inode fork includes an array of
xfs_bmbt_rec_host_t objects in it's definition.
Move all the btree format definitions from xfs_btree.h,
xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to
xfs_format.h to continue the process of centralising the on-disk
format definitions. With this done, the xfs inode definitions are no
longer dependent on btree header files.
The enables a massive culling of unnecessary includes, with close to
200 #include directives removed from the XFS kernel code base.
Reviewed-by: Ben Myers <bpm@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
We have quite a few places now where we do:
x = kmem_zalloc(large size)
if (!x)
x = kmem_zalloc_large(large size)
and do a similar dance when freeing the memory. kmem_free() already
does the correct freeing dance, and kmem_zalloc_large() is only ever
called in these constructs, so just factor it all into
kmem_zalloc_large() and kmem_free().
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Ever since increasing the number of supported ACLs from 25 to as
many as can fit in an xattr, there have been reports of order 4
memory allocations failing in the ACL code. Fix it in the same way
we've fixed all the xattr read/write code that has the same problem.
Change permission check for setting ACL to use inode_owner_or_capable()
which will additionally allow a CAP_FOWNER user in a user namespace to
be able to set an ACL on an inode covered by the user namespace mapping.
Reviewed-by: Gao feng <gaofeng@cn.fujitsu.com>
Signed-off-by: Dwight Engen <dwight.engen@oracle.com>
The struct xfs_perag has many kernel-only definitions in it,
requiring a __KERNEL__ guard so userspace can use it to. Move it to
xfs_mount.h so that it it kernel-only, and let userspace redefine
it's own version of the structure containing only what it needs.
This gets rid of another __KERNEL__ check in the XFS header files.
Now we have xfs_inode.c for holding kernel-only XFS inode
operations, move all the inode operations from xfs_vnodeops.c to
this new file as it holds another set of kernel-only inode
operations. The name of this file traces back to the days of Irix
and it's vnodes which we don't have anymore.
Essentially this move consolidates the inode locking functions
and a bunch of XFS inode operations into the one file. Eventually
the high level functions will be merged into the VFS interface
functions in xfs_iops.c.
This leaves only internal preallocation, EOF block manipulation and
hole punching functions in vnodeops.c. Move these to xfs_bmap_util.c
where we are already consolidating various in-kernel physical extent
manipulation and querying functions.
The transaction reservation size calculations is used by both kernel
and userspace, but most of the transaction code in xfs_trans.c is
kernel specific. Split all the transaction reservation code out into
it's own files to make sharing with userspace simpler. This just
leaves kernel-only definitions in xfs_trans.h, so it doesn't need to
be shared with userspace anymore, either.
The log item format definitions are shared with userspace. Split
them out of header files that contain kernel only defintions to make
it simple to shared them.
The limit of 25 ACL entries is arbitrary, but baked into the on-disk
format. For version 5 superblocks, increase it to the maximum nuber
of ACLs that can fit into a single xattr.
Reviewed-by: Mark Tinguely <tinuguely@sgi.com>
(cherry picked from commit 5c87d4bc1a86bd6e6754ac3d6e111d776ddcfe57)
- Pass the user namespace the uid and gid values in the xattr are stored
in into posix_acl_from_xattr.
- Pass the user namespace kuid and kgid values should be converted into
when storing uid and gid values in an xattr in posix_acl_to_xattr.
- Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to
pass in &init_user_ns.
In the short term this change is not strictly needed but it makes the
code clearer. In the longer term this change is necessary to be able to
mount filesystems outside of the initial user namespace that natively
store posix acls in the linux xattr format.
Cc: Theodore Tso <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.cz>
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
This prevents in-memory corruption and possible panics if the on-disk
ACL is badly corrupted.
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
Signed-off-by: Alex Elder <aelder@sgi.com>
This patch rips out the XFS ACL handling code and uses the generic
fs/posix_acl.c code instead. The ondisk format is of course left
unchanged.
This also introduces the same ACL caching all other Linux filesystems do
by adding pointers to the acl and default acl in struct xfs_inode.
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
capable_cred has been unused for a while so we can kill it and sys_cred.
That also means the cred argument to xfs_setattr and xfs_change_file_space
can be removed now.
SGI-PV: 988918
SGI-Modid: xfs-linux-melb:xfs-kern:32412a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Signed-off-by: David Chinner <david@fromorbit.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
All remaining bhv_vnode_t instance are in code that's more or less Linux
specific. (Well, for xfs_acl.c that could be argued, but that code is on
the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the
whole tree. We can clean up variable naming and some useless helpers
later.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31781a
All the ACL routines are called from inode operations which are guaranteed
to have a referenced inode by the VFS, so there's no need for the ACL code
to grab another temporary one.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31763a
xfs_vtoi() is redundant and only unsed in small sections of code.
Replace them with widely used XFS_I() inline and kill xfs_vtoi().
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31725a
Signed-off-by: Niv Sardi <xaiki@sgi.com>
it can be switched to take struct iattr directly and thus simplify the
implementation greatly. Also rename the ATTR_ flags to XFS_ATTR_ to not
conflict with the ATTR_ flags used by the VFS.
SGI-PV: 984565
SGI-Modid: xfs-linux-melb:xfs-kern:31678a
and not go through xfs_attr_list.
SGI-PV: 983395
SGI-Modid: xfs-linux-melb:xfs-kern:31324a
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30913a
Signed-off-by: Barry Naujok <bnaujok@sgi.com>
It's currently used by the ACL code to read di_mode/di_uid, but these are
simple 32bit scalar values we can just read directly without locking.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30897a
We can just check i_mode / di_mode directly.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30896a
Removing an ACL can return an error. Propagate it.
SGI-PV: 980084
SGI-Modid: xfs-linux-melb:xfs-kern:30793a
Signed-off-by: David Chinner <dgc@sgi.com>
Propagate the error status from xfs_acl_setmode() so that callers know if
the ACl was set correctly or not.
SGI-PV: 980084
SGI-Modid: xfs-linux-melb:xfs-kern:30792a
Now that all direct caller of xfs_iaccess are gone we can kill xfs_iaccess
and xfs_access and just use generic_permission with a check_acl callback.
This is required for the per-mount read-only patchset in -mm to work
properly with XFS.
SGI-PV: 971186
SGI-Modid: xfs-linux-melb:xfs-kern:30370a
Simplify the prototype for xfs_create/xfs_mkdir/xfs_symlink by not passing
down a bhv_vattr_t that just hogs stack space. Instead pass down the mode
in a mode_t and in case of xfs_create the rdev as a scalar type as well.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29794a
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t
as a typedef for struct inode for the time being until all the fallout is
cleaned up.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29500a
We can easily get at the vfsp through the super_block but it will soon be
gone anyway.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29494a
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29493a
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used
anywhere in XFS at all. They are left-overs from "to be implement at some
point in the future" functionality that Irix XFS has. If this
functionality ever goes into Linux, it will be provided at a different
layer, most likely through the security hooks in the kernel so we will
never need this functionality in XFS.
Patch provided by Eric Sandeen (sandeen@sandeen.net).
SGI-PV: 960895
SGI-Modid: xfs-linux-melb:xfs-kern:28036a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
pure bloat.
SGI-PV: 952969
SGI-Modid: xfs-linux-melb:xfs-kern:26251a
Signed-off-by: Nathan Scott <nathans@sgi.com>
porters.
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26108a
