path: root/fs/xfs/xfs_attr_leaf.h
2009-01-09[XFS] Remove macro-to-function indirections in attr codeEric Sandeen
Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Move xfs_attr_rolltrans to xfs_trans_rollNiv Sardi
Move it from the attr code to the transaction code and make the attr code call the new function. We rolltrans is really usefull whenever we want to use rolling transaction, should be generic, it isn't dependent on any part of the attr code anyway. We use this excuse to change all the: if ((error = xfs_attr_rolltrans())) calls into: error = xfs_trans_roll(); if (error) SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31729a Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Switches xfs_vn_listxattr to set it's put_listent callback directlyChristoph Hellwig
and not go through xfs_attr_list. SGI-PV: 983395 SGI-Modid: xfs-linux-melb:xfs-kern:31324a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2006-09-28[XFS] Add EA list callbacks for xfs kernel use. Cleanup some namespaceTim Shimmin
code. SGI-PV: 954372 SGI-Modid: xfs-linux-melb:xfs-kern:26583a Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_name_remote_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25500a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_name_local_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25499a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25498a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25497a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-12[XFS] Merge in trivial changes, sync up headers with userspaceNathan Scott
equivalents. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Move some code around to prepare for the upcoming extendedNathan Scott
attributes format change (attr2). SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23833a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
