path: root/fs/xfs/xfs_attr_list.c
2017-07-13xfs: assert locking precondŃ–tion in xfs_attr_list_int_ilockedChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2017-06-20xfs: pass along transaction context when reading xattr block buffersDarrick J. Wong
Teach the extended attribute reading functions to pass along a transaction context if one was supplied. The extended attribute scrub code will use transactions to lock buffers and avoid deadlocking with itself in the case of loops; since it will already have the inode locked, also create xattr get/list helpers that don't take locks. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Brian Foster <bfoster@redhat.com>
2017-06-19xfs: remove double-underscore integer typesDarrick J. Wong
This is a purely mechanical patch that removes the private __{u,}int{8,16,32,64}_t typedefs in favor of using the system {u,}int{8,16,32,64}_t typedefs. This is the sed script used to perform the transformation and fix the resulting whitespace and indentation errors: s/typedef\t__uint8_t/typedef __uint8_t\t/g s/typedef\t__uint/typedef __uint/g s/typedef\t__int\([0-9]*\)_t/typedef int\1_t\t/g s/__uint8_t\t/__uint8_t\t\t/g s/__uint/uint/g s/__int\([0-9]*\)_t\t/__int\1_t\t\t/g s/__int/int/g /^typedef.*int[0-9]*_t;$/d Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2016-12-05xfs: several xattr functions can be voidEric Sandeen
There are a handful of xattr functions which now return nothing but zero. They can be made void, chased through calling functions, and error handling etc can be removed. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-06-01xfs: make several functions staticEric Sandeen
Al Viro noticed that xfs_lock_inodes should be static, and that led to ... a few more. These are just the easy ones, others require moving functions higher in source files, so that's not done here to keep this review simple. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-04-06xfs: collapse cases in xfs_attr3_leaf_list_intEric Sandeen
Consolidate the 2 calls to ->put_listent in xfs_attr3_leaf_list_int(), by setting up name, namelen, and valuelen for the local vs remote cases, then call ->put_listent and do the error handling all in one spot. Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2016-04-06xfs: remove put_value from attr ->put_listent contextEric Sandeen
The put_value context member is never set; remove it and the conditional test in xfs_attr3_leaf_list_int(). Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-04-06xfs: don't pass value into attr ->put_listentEric Sandeen
The value is not used; only names and value lengths are returned. Remove the argument. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-04-06xfs: only return -errno or success from attr ->put_listentEric Sandeen
Today, the put_listent formatters return either 1 or 0; if they return 1, some callers treat this as an error and return it up the stack, despite "1" not being a valid (negative) error code. The intent seems to be that if the input buffer is full, we set seen_enough or set count = -1, and return 1; but some callers check the return before checking the seen_enough or count fields of the context. Fix this by only returning non-zero for actual errors encountered, and rely on the caller to first check the return value, then check the values in the context to decide what to do. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-03-02xfs: fix two memory leaks in xfs_attr_list.c error pathsMateusz Guzik
This plugs 2 trivial leaks in xfs_attr_shortform_list and xfs_attr3_leaf_list_int. Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Cc: <stable@vger.kernel.org> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2015-10-12xfs: per-filesystem stats counter implementationBill O'Donnell
This patch modifies the stats counting macros and the callers to those macros to properly increment, decrement, and add-to the xfs stats counts. The counts for global and per-fs stats are correctly advanced, and cleared by writing a "1" to the corresponding clear file. global counts: /sys/fs/xfs/stats/stats per-fs counts: /sys/fs/xfs/sda*/stats/stats global clear: /sys/fs/xfs/stats/stats_clear per-fs clear: /sys/fs/xfs/sda*/stats/stats_clear [dchinner: cleaned up macro variables, removed CONFIG_FS_PROC around stats structures and macros. ] Signed-off-by: Bill O'Donnell <billodo@redhat.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2015-04-13xfs: pass attr geometry to attr leaf header conversion functionsBrian Foster
The firstused field of the xfs_attr3_leaf_hdr structure is subject to an overflow when fs blocksize is 64k. In preparation to handle this overflow in the header conversion functions, pass the attribute geometry to the functions that convert the in-core structure to and from the on-disk structure. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: move most of xfs_sb.h to xfs_format.hChristoph Hellwig
More on-disk format consolidation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: merge xfs_ag.h into xfs_format.hChristoph Hellwig
More on-disk format consolidation. A few declarations that weren't on-disk format related move into better suitable spots. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: merge xfs_dinode.h into xfs_format.hChristoph Hellwig
More consolidatation for the on-disk format defintions. Note that the XFS_IS_REALTIME_INODE moves to xfs_linux.h instead as it is not related to the on disk format, but depends on a CONFIG_ option. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-25xfs: global error sign conversionDave Chinner
Convert all the errors the core XFs code to negative error signs like the rest of the kernel and remove all the sign conversion we do in the interface layers. Errors for conversion (and comparison) found via searches like: $ git grep " E" fs/xfs $ git grep "return E" fs/xfs $ git grep " E[A-Z].*;$" fs/xfs Negation points found via searches like: $ git grep "= -[a-z,A-Z]" fs/xfs $ git grep "return -[a-z,A-D,F-Z]" fs/xfs $ git grep " -[a-z].*;" fs/xfs [ with some bits I missed from Brian Foster ] Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-22xfs: Nuke XFS_ERROR macroEric Sandeen
XFS_ERROR was designed long ago to trap return values, but it's not runtime configurable, it's not consistently used, and we can do similar error trapping with ftrace scripts and triggers from userspace. Just nuke XFS_ERROR and associated bits. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-22xfs: return is not a functionEric Sandeen
return is not a function. "return(EIO);" is silly; "return (EIO);" moreso. return is not a function. Nuke the pointless parens. [dchinner: catch a couple of extra cases in xfs_attr_list.c, xfs_acl.c and xfs_linux.h.] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-06xfs: introduce directory geometry structureDave Chinner
The directory code has a dependency on the struct xfs_mount to supply the directory block geometry. Block size, block log size, and other parameters are pre-caclulated in the struct xfs_mount or access directly from the superblock embedded in the struct xfs_mount. Extract all of this geometry information out of the struct xfs_mount and superblock and place it into a new struct xfs_da_geometry defined by the directory code. Allocate and initialise it at mount time, and attach it to the struct xfs_mount so it canbe passed back into the directory code appropriately rather than using the struct xfs_mount. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-05-06xfs: remote attribute overwrite causes transaction overrunDave Chinner
Commit e461fcb ("xfs: remote attribute lookups require the value length") passes the remote attribute length in the xfs_da_args structure on lookup so that CRC calculations and validity checking can be performed correctly by related code. This, unfortunately has the side effect of changing the args->valuelen parameter in cases where it shouldn't. That is, when we replace a remote attribute, the incoming replacement stores the value and length in args->value and args->valuelen, but then the lookup which finds the existing remote attribute overwrites args->valuelen with the length of the remote attribute being replaced. Hence when we go to create the new attribute, we create it of the size of the existing remote attribute, not the size it is supposed to be. When the new attribute is much smaller than the old attribute, this results in a transaction overrun and an ASSERT() failure on a debug kernel: XFS: Assertion failed: tp->t_blk_res_used <= tp->t_blk_res, file: fs/xfs/xfs_trans.c, line: 331 Fix this by keeping the remote attribute value length separate to the attribute value length in the xfs_da_args structure. The enables us to pass the length of the remote attribute to be removed without overwriting the new attribute's length. Also, ensure that when we save remote block contexts for a later rename we zero the original state variables so that we don't confuse the state of the attribute to be removes with the state of the new attribute that we just added. [Spotted by Brain Foster.] Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-18xfs: use xfs_ilock_attr_map_shared in xfs_attr_list_intChristoph Hellwig
We might not have read in the extent list at this point, so make sure we take the ilock exclusively if we have to do so. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-30xfs: vectorise encoding/decoding directory headersDave Chinner
Conversion from on-disk structures to in-core header structures currently relies on magic number checks. If the magic number is wrong, but one of the supported values, we do the wrong thing with the encode/decode operation. Split these functions so that there are discrete operations for the specific directory format we are handling. In doing this, move all the header encode/decode functions to xfs_da_format.c as they are directly manipulating the on-disk format. It should be noted that all the growth in binary size is from xfs_da_format.c - the rest of the code actaully shrinks. text data bss dec hex filename 794490 96802 1096 892388 d9de4 fs/xfs/xfs.o.orig 792986 96802 1096 890884 d9804 fs/xfs/xfs.o.p1 792350 96802 1096 890248 d9588 fs/xfs/xfs.o.p2 789293 96802 1096 887191 d8997 fs/xfs/xfs.o.p3 789005 96802 1096 886903 d8997 fs/xfs/xfs.o.p4 789061 96802 1096 886959 d88af fs/xfs/xfs.o.p5 789733 96802 1096 887631 d8b4f fs/xfs/xfs.o.p6 791421 96802 1096 889319 d91e7 fs/xfs/xfs.o.p7 Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-30xfs: vectorise DA btree operationsDave Chinner
The remaining non-vectorised code for the directory structure is the node format blocks. This is shared with the attribute tree, and so is slightly more complex to vectorise. Introduce a "non-directory" directory ops structure that is attached to all non-directory inodes so that attribute operations can be vectorised for all inodes. Once we do this, we can vectorise all the da btree operations. Because this patch adds more infrastructure than it removes the binary size does not decrease: text data bss dec hex filename 794490 96802 1096 892388 d9de4 fs/xfs/xfs.o.orig 792986 96802 1096 890884 d9804 fs/xfs/xfs.o.p1 792350 96802 1096 890248 d9588 fs/xfs/xfs.o.p2 789293 96802 1096 887191 d8997 fs/xfs/xfs.o.p3 789005 96802 1096 886903 d8997 fs/xfs/xfs.o.p4 789061 96802 1096 886959 d88af fs/xfs/xfs.o.p5 789733 96802 1096 887631 d8b4f fs/xfs/xfs.o.p6 Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: decouple inode and bmap btree header filesDave Chinner
Currently the xfs_inode.h header has a dependency on the definition of the BMAP btree records as the inode fork includes an array of xfs_bmbt_rec_host_t objects in it's definition. Move all the btree format definitions from xfs_btree.h, xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to xfs_format.h to continue the process of centralising the on-disk format definitions. With this done, the xfs inode definitions are no longer dependent on btree header files. The enables a massive culling of unnecessary includes, with close to 200 #include directives removed from the XFS kernel code base. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: decouple log and transaction headersDave Chinner
xfs_trans.h has a dependency on xfs_log.h for a couple of structures. Most code that does transactions doesn't need to know anything about the log, but this dependency means that they have to include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header files and clean up the includes to be in dependency order. In doing this, remove the direct include of xfs_trans_reserve.h from xfs_trans.h so that we remove the dependency between xfs_trans.h and xfs_mount.h. Hence the xfs_trans.h include can be moved to the indicate the actual dependencies other header files have on it. Note that these are kernel only header files, so this does not translate to any userspace changes at all. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: unify directory/attribute format definitionsDave Chinner
The on-disk format definitions for the directory and attribute structures are spread across 3 header files right now, only one of which is dedicated to defining on-disk structures and their manipulation (xfs_dir2_format.h). Pull all the format definitions into a single header file - xfs_da_format.h - and switch all the code over to point at that. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: split out attribute listing code into separate fileDave Chinner
The attribute listing code is not used by userspace, so like the directory readdir code, split it out into a separate file to minimise the differences between the filesystem shared with libxfs in userspace. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
