path: root/fs/xfs/xfs_da_btree.h
2009-03-29xfs: fix various typosMalcolm Parsons
Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-03-06xfs: move declaration to header fileHannes Eder
Fix this sparse warning: fs/xfs/xfs_da_btree.c:1550:26: warning: symbol 'xfs_default_nameops' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-02-09xfs: remove uchar_t/ushort_t/uint_t/ulong_t typesChristoph Hellwig
Just another set of types obsfucating the code, remove them. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2008-10-30[XFS] Sync up kernel and user-space headersBarry Naujok
SGI-PV: 986558 SGI-Modid: xfs-linux-melb:xfs-kern:32231a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Remove final remnants of dirv1 macros and other stuffBarry Naujok
SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:32002a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Return case-insensitive match for dentry cacheBarry Naujok
This implements the code to store the actual filename found during a lookup in the dentry cache and to avoid multiple entries in the dcache pointing to the same inode. To avoid polluting the dcache, we implement a new directory inode operations for lookup. xfs_vn_ci_lookup() stores the correct case name in the dcache. The "actual name" is only allocated and returned for a case- insensitive match and not an actual match. Another unusual interaction with the dcache is not storing negative dentries like other filesystems doing a d_add(dentry, NULL) when an ENOENT is returned. During the VFS lookup, if a dentry returned has no inode, dput is called and ENOENT is returned. By not doing a d_add, this actually removes it completely from the dcache to be reused. create/rename have to be modified to support unhashed dentries being passed in. SGI-PV: 981521 SGI-Modid: xfs-linux-melb:xfs-kern:31208a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Add op_flags field and helpers to xfs_da_argsBarry Naujok
The end of the xfs_da_args structure has 4 unsigned char fields for true/false information on directory and attr operations using the xfs_da_args structure. The following converts these 4 into a op_flags field that uses the first 4 bits for these fields and allows expansion for future operation information (eg. case-insensitive lookup request). SGI-PV: 981520 SGI-Modid: xfs-linux-melb:xfs-kern:31206a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Name operation vector for hash and compareBarry Naujok
Adds two pieces of functionality for the basis of case-insensitive support in XFS: 1. A comparison result enumerated type: xfs_dacmp. It represents an exact match, case-insensitive match or no match at all. This patch only implements different and exact results. 2. xfs_nameops vector for specifying how to perform the hash generation of filenames and comparision methods. In this patch the hash vector points to the existing xfs_da_hashname function and the comparison method does a length compare, and if the same, does a memcmp and return the xfs_dacmp result. All filename functions that use the hash (create, lookup remove, rename, etc) now use the xfs_nameops.hashname function and all directory lookup functions also use the xfs_nameops.compname function. The lookup functions also handle case-insensitive results even though the default comparison function cannot return that. And important aspect of the lookup functions is that an exact match always has precedence over a case-insensitive. So while a case-insensitive match is found, we have to keep looking just in case there is an exact match. In the meantime, the info for the first case-insensitive match is retained if no exact match is found. SGI-PV: 981519 SGI-Modid: xfs-linux-melb:xfs-kern:31205a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-02-07[XFS] Fix up sparse warnings.David Chinner
These are mostly locking annotations, marking things static, casts where needed and declaring stuff in header files. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30002a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25505a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25504a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Make some extended attributes routines take const parameters, forNathan Scott
the FreeBSD porters. SGI-PV: 942906 SGI-Modid: xfs-linux:xfs-kern:23845a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
