path: root/fs/xfs/xfs_dmapi.h
2007-10-16[XFS] kill the vfs_flags member in struct bhv_vfsChristoph Hellwig
All flags are added to xfs_mount's m_flag instead. Note that the 32bit inode flag was duplicated in both of them, but only cleared in the mount when it was not nessecary due to the filesystem beeing small enough. Two flags are still required here - one to indicate the mount option setting, and one to indicate if it applies or not. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29507a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] remove dependency of the dmapi module on behaviorsChristoph Hellwig
Mount options are now parsed by the main XFS module and rejected if dmapi support is not available, and there is a new dm operation to send the mount event. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29502a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] optimize dmapi event tests w/o dmapi configEric Sandeen
SGI-PV: 969372 SGI-Modid: xfs-linux-melb:xfs-kern:29444a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] remove unessecary vfs argument to DM_EVENT_ENABLEDChristoph Hellwig
SGI-PV: 968690 SGI-Modid: xfs-linux-melb:xfs-kern:29340a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] Remove KERNEL_VERSION macros from xfs_dmapi.hDavid Chinner
SGI-PV: 957005 SGI-Modid: xfs-linux-melb:xfs-kern:27398a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-22[XFS] Sync up one/two other minor changes missed in previous merges.Nathan Scott
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] Update copyrightsDean Roehrich
SGI-PV: 933551 SGI-Modid: xfs-linux:xfs-kern:190625a Signed-off-by: Dean Roehrich <roehrich@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-22[XFS] Handle inode semaphores properly for dmapi queuesDean Roehrich
SGI-PV: 931572 SGI-Modid: xfs-linux-melb:xfs-kern:189560a Signed-off-by: Dean Roehrich <roehrich@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] coordinate mmap calls with xfs_dm_punch_holeDean Roehrich
SGI-PV: 933551 SGI-Modid: xfs-linux:xfs-kern:190622a Signed-off-by: Dean Roehrich <roehrich@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
