path: root/fs/xfs/xfs_error.c
2014-06-25xfs: global error sign conversionDave Chinner
Convert all the errors the core XFs code to negative error signs like the rest of the kernel and remove all the sign conversion we do in the interface layers. Errors for conversion (and comparison) found via searches like: $ git grep " E" fs/xfs $ git grep "return E" fs/xfs $ git grep " E[A-Z].*;$" fs/xfs Negation points found via searches like: $ git grep "= -[a-z,A-Z]" fs/xfs $ git grep "return -[a-z,A-D,F-Z]" fs/xfs $ git grep " -[a-z].*;" fs/xfs [ with some bits I missed from Brian Foster ] Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-22xfs: Nuke XFS_ERROR macroEric Sandeen
XFS_ERROR was designed long ago to trap return values, but it's not runtime configurable, it's not consistently used, and we can do similar error trapping with ftrace scripts and triggers from userspace. Just nuke XFS_ERROR and associated bits. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-02-27xfs: print useful caller information in xfs_error_reportEric Sandeen
xfs_error_report used to just print the hex address of the caller; %pF will give us something more human-readable. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-02-27xfs: add xfs_verifier_error()Eric Sandeen
We want to distinguish between corruption, CRC errors, etc. In addition, the full stack trace on verifier errors seems less than helpful; it looks more like an oops than corruption. Create a new function to specifically alert the user to verifier errors, which can differentiate between EFSCORRUPTED and CRC mismatches. It doesn't dump stack unless the xfs error level is turned up high. Define a new error message (EFSBADCRC) to clearly identify CRC errors. (Defined to EBADMSG, bad message) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-10-23xfs: decouple inode and bmap btree header filesDave Chinner
Currently the xfs_inode.h header has a dependency on the definition of the BMAP btree records as the inode fork includes an array of xfs_bmbt_rec_host_t objects in it's definition. Move all the btree format definitions from xfs_btree.h, xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to xfs_format.h to continue the process of centralising the on-disk format definitions. With this done, the xfs inode definitions are no longer dependent on btree header files. The enables a massive culling of unnecessary includes, with close to 200 #include directives removed from the XFS kernel code base. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: decouple log and transaction headersDave Chinner
xfs_trans.h has a dependency on xfs_log.h for a couple of structures. Most code that does transactions doesn't need to know anything about the log, but this dependency means that they have to include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header files and clean up the includes to be in dependency order. In doing this, remove the direct include of xfs_trans_reserve.h from xfs_trans.h so that we remove the dependency between xfs_trans.h and xfs_mount.h. Hence the xfs_trans.h include can be moved to the indicate the actual dependencies other header files have on it. Note that these are kernel only header files, so this does not translate to any userspace changes at all. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-17xfs: remove newlines from strings passed to __xfs_printkEric Sandeen
__xfs_printk adds its own "\n". Having it in the original string leads to unintentional blank lines from these messages. Most format strings have no newline, but a few do, leading to i.e.: [ 7347.119911] XFS (sdb2): Access to block zero in inode 132 start_block: 0 start_off: 0 blkcnt: 0 extent-state: 0 lastx: 1a05 [ 7347.119911] [ 7347.119919] XFS (sdb2): Access to block zero in inode 132 start_block: 0 start_off: 0 blkcnt: 0 extent-state: 0 lastx: 1a05 [ 7347.119919] Fix them all. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: consolidate xfs_utils.cDave Chinner
There are a few small helper functions in xfs_util, all related to xfs_inode modifications. Move them all to xfs_inode.c so all xfs_inode operations are consiolidated in the one place. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-21xfs: increase hexdump output in xfs_corruption_errorDave Chinner
Currently xfs_corruption_error() dumps the first 16 bytes of the buffer that is passed to it when a corruption occurs. This is not large enough to see the entire state of the header of the block that was determined to be corrupt. increase the output to 64 bytes to capture the majority of all headers in all types of metadata blocks. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-03-07xfs: rename random32() to prandom_u32()Akinobu Mita
Use more preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: <bpm@sgi.com> Cc: Ben Myers <bpm@sgi.com> Cc: Alex Elder <elder@kernel.org> Cc: xfs@oss.sgi.com Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: move xfsagino_t to xfs_types.hDave Chinner
Untangle the header file includes a bit by moving the definition of xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include xfs_ag.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-03-07xfs: Convert remaining cmn_err() callers to new APIDave Chinner
Once converted, kill the remainder of the cmn_err() interface. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-03-07xfs: kill xfs_fs_repair_cmn_err() macroDave Chinner
In certain cases of inode corruption, the xfs_fs_repair_cmn_err() macro is used to output an extra message in the corruption report. That extra message is "unmount and run xfs_repair", which really applies to any corruption report. Each case that this macro is called (except one) a following call to xfs_corruption_error() is made to optionally dump more information about the error. Hence, move the output of "run xfs_repair" to xfs_corruption_error() so that it is output on all corruption reports. Also, convert the callers of the repair macro that don't call xfs_corruption_error() to call it, hence provide consiѕtent error reporting for all cases where xfs_fs_repair_cmn_err() used to be called. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-03-07xfs: convert xfs_cmn_err to xfs_alert_tagDave Chinner
Continue the conversion of the old cmn_err interface be converting all the conditional panic tag errors to xfs_alert_tag() and then removing xfs_cmn_err(). Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-01-12xfs: prevent NMI timeouts in cmn_errDave Chinner
We currently have a global error message buffer in cmn_err that is protected by a spin lock that disables interrupts. Recently there have been reports of NMI timeouts occurring when the console is being flooded by SCSI error reports due to cmn_err() getting stuck trying to print to the console while holding this lock (i.e. with interrupts disabled). The NMI watchdog is seeing this CPU as non-responding and so is triggering a panic. While the trigger for the reported case is SCSI errors, pretty much anything that spams the kernel log could cause this to occur. Realistically the only reason that we have the intemediate message buffer is to prepend the correct kernel log level prefix to the log message. The only reason we have the lock is to protect the global message buffer and the only reason the message buffer is global is to keep it off the stack. Hence if we can avoid needing a global message buffer we avoid needing the lock, and we can do this with a small amount of cleanup and some preprocessor tricks: 1. clean up xfs_cmn_err() panic mask functionality to avoid needing debug code in xfs_cmn_err() 2. remove the couple of "!" message prefixes that still exist that the existing cmn_err() code steps over. 3. redefine CE_* levels directly to KERN_* 4. redefine cmn_err() and friends to use printk() directly via variable argument length macros. By doing this, we can completely remove the cmn_err() code and the lock that is causing the problems, and rely solely on printk() serialisation to ensure that we don't get garbled messages. A series of followup patches is really needed to clean up all the cmn_err() calls and related messages properly, but that results in a series that is not easily back portable to enterprise kernels. Hence this initial fix is only to address the direct problem in the lowest impact way possible. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-12-01xfs: only run xfs_error_test if error injection is activeDave Chinner
Recent tests writing lots of small files showed the flusher thread being CPU bound and taking a long time to do allocations on a debug kernel. perf showed this as the prime reason: samples pcnt function DSO _______ _____ ___________________________ _________________ 224648.00 36.8% xfs_error_test [kernel.kallsyms] 86045.00 14.1% xfs_btree_check_sblock [kernel.kallsyms] 39778.00 6.5% prandom32 [kernel.kallsyms] 37436.00 6.1% xfs_btree_increment [kernel.kallsyms] 29278.00 4.8% xfs_btree_get_rec [kernel.kallsyms] 27717.00 4.5% random32 [kernel.kallsyms] Walking btree blocks during allocation checking them requires each block (a cache hit, so no I/O) call xfs_error_test(), which then does a random32() call as the first operation. IOWs, ~50% of the CPU is being consumed just testing whether we need to inject an error, even though error injection is not active. Kill this overhead when error injection is not active by adding a global counter of active error traps and only calling into xfs_error_test when fault injection is active. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-07-26xfs: remove unneeded #include statementsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: drop dmapi hooksChristoph Hellwig
Dmapi support was never merged upstream, but we still have a lot of hooks bloating XFS for it, all over the fast pathes of the filesystem. This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM support in mainline at least the namespace events can be done much saner in the VFS instead of the individual filesystem, so it's not like this is much help for future work. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-05-24xfs: clean up log ticket overrun debug outputDave Chinner
Push the error message output when a ticket overrun is detected into the ticket printing functions. Also remove the debug version of the code as the production version will still panic just as effectively on a debug kernel via the panic mask being set. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-05-19xfs: add const qualifiers to xfs error function argsAlex Elder
Change the tag and file name arguments to xfs_error_report() and xfs_corruption_error() to use a const qualifier. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com>
2008-12-22[XFS] avoid memory allocations in xfs_fs_vcmn_errChristoph Hellwig
xfs_fs_vcmn_err can be called under a spinlock, but does a sleeping memory allocation to create buffer for it's internal sprintf. Fortunately it's the only caller of icmn_err, so we can merge the two and have one single static buffer and spinlock protecting it. While we're at it make sure we proper __attribute__ format annotations so that the compiler can detect mismatched format strings. Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill INDUCE_IO_ERRORChristoph Hellwig
All the error injection is already enabled through ifdef DEBUG, so kill the never set second cpp symbol to activate it without the rest of the debugging infrastructure. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31771a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] streamline init/exit pathChristoph Hellwig
Currently the xfs module init/exit code is a mess. It's farmed out over a lot of function with very little error checking. This patch makes sure we propagate all initialization failures properly and clean up after them. Various runtime initializations are replaced with compile-time initializations where possible to make this easier. The exit path is similarly consolidated. There's now split out function to create/destroy the kmem zones and alloc/free the trace buffers. I've also changed the ktrace allocations to KM_MAYFAIL and handled errors resulting from that. And yes, we really should replace the XFS_*_TRACE ifdefs with a single XFS_TRACE.. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:31354a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] lose xfs_hex_dump in favor of print_hex_dumpEric Sandeen
No need for xfs to have its own hex dumping routine now that the kernel has one. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29847a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the vfs_fsid and vfs_altfsid members in struct bhv_vfsChristoph Hellwig
vfs_altfsid was just a pointer to mp->m_fixedfsid so we can trivially replace it with the latter. vfs_fsid also was identical to m_fixedfsid through rather obfuscated ways so we can kill it as well and simply its only user. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29506a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] Radix tree based inode cachingDavid Chinner
One of the perpetual scaling problems XFS has is indexing it's incore inodes. We currently uses hashes and the default hash sizes chosen can only ever be a tradeoff between memory consumption and the maximum realistic size of the cache. As a result, anyone who has millions of inodes cached on a filesystem needs to tunes the size of the cache via the ihashsize mount option to allow decent scalability with inode cache operations. A further problem is the separate inode cluster hash, whose size is based on the ihashsize but is smaller, and so under certain conditions (sparse cluster cache population) this can become a limitation long before the inode hash is causing issues. The following patchset removes the inode hash and cluster hash and replaces them with radix trees to avoid the scalability limitations of the hashes. It also reduces the size of the inodes by 3 pointers.... SGI-PV: 969561 SGI-Modid: xfs-linux-melb:xfs-kern:29481a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] reducing the number of random number functions.Joe Perches
Patch provided by Joe Perches SGI-PV: 961696 SGI-Modid: xfs-linux-melb:xfs-kern:28209a Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-12[XFS] Merge in trivial changes, sync up headers with userspaceNathan Scott
equivalents. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
