path: root/fs/xfs/xfs_export.c
2016-07-15xfs: abstract block export operations from nfsd layoutsBenjamin Coddington
Instead of creeping pnfs layout configuration into filesystems, move the definition of block-based export operations under a more abstract configuration. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Chinner <david@fromorbit.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-03-24Merge tag 'nfsd-4.6-1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull more nfsd updates from Bruce Fields: "Apologies for the previous request, which omitted the top 8 commits from my for-next branch (including the SCSI layout commits). Thanks to Trond for spotting my error!" This actually includes the new layout types, so here's that part of the pull message repeated: "Support for a new pnfs layout type from Christoph Hellwig. The new layout type is a variant of the block layout which uses SCSI features to offer improved fencing and device identification. Note this pull request also includes the client side of SCSI layout, with Trond's permission" * tag 'nfsd-4.6-1' of git://linux-nfs.org/~bfields/linux: nfsd: use short read as well as i_size to set eof nfsd: better layoutupdate bounds-checking nfsd: block and scsi layout drivers need to depend on CONFIG_BLOCK nfsd: add SCSI layout support nfsd: move some blocklayout code nfsd: add a new config option for the block layout driver nfs/blocklayout: add SCSI layout support nfs4.h: add SCSI layout definitions
2016-03-18nfsd: add a new config option for the block layout driverChristoph Hellwig
Split the config symbols into a generic pNFS one, which is invisible and gets selected by the layout drivers, and one for the block layout driver. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-02-09xfs: move inode generation count to VFS inodeDave Chinner
Pull another 4 bytes out of the xfs_icdinode. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-16xfs: implement pNFS export operationsChristoph Hellwig
Add operations to export pNFS block layouts from an XFS filesystem. See the previous commit adding the operations for an explanation of them. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-12-04Merge branch 'xfs-misc-fixes-for-3.19-2' into for-nextDave Chinner
Conflicts: fs/xfs/xfs_iops.c
2014-12-04xfs: move type conversion functions to xfs_dir.hDave Chinner
These are currently considered private to libxfs, but they are widely used by the userspace code to decode, walk and check directory structures. Hence they really form part of the external API and as such need to bemoved to xfs_dir2.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: move most of xfs_sb.h to xfs_format.hChristoph Hellwig
More on-disk format consolidation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: merge xfs_ag.h into xfs_format.hChristoph Hellwig
More on-disk format consolidation. A few declarations that weren't on-disk format related move into better suitable spots. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-25xfs: global error sign conversionDave Chinner
Convert all the errors the core XFs code to negative error signs like the rest of the kernel and remove all the sign conversion we do in the interface layers. Errors for conversion (and comparison) found via searches like: $ git grep " E" fs/xfs $ git grep "return E" fs/xfs $ git grep " E[A-Z].*;$" fs/xfs Negation points found via searches like: $ git grep "= -[a-z,A-Z]" fs/xfs $ git grep "return -[a-z,A-D,F-Z]" fs/xfs $ git grep " -[a-z].*;" fs/xfs [ with some bits I missed from Brian Foster ] Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-05-15xfs: xfs_commit_metadata returns wrong errnoDave Chinner
Invert it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-10-23xfs: decouple inode and bmap btree header filesDave Chinner
Currently the xfs_inode.h header has a dependency on the definition of the BMAP btree records as the inode fork includes an array of xfs_bmbt_rec_host_t objects in it's definition. Move all the btree format definitions from xfs_btree.h, xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to xfs_format.h to continue the process of centralising the on-disk format definitions. With this done, the xfs inode definitions are no longer dependent on btree header files. The enables a massive culling of unnecessary includes, with close to 200 #include directives removed from the XFS kernel code base. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: decouple log and transaction headersDave Chinner
xfs_trans.h has a dependency on xfs_log.h for a couple of structures. Most code that does transactions doesn't need to know anything about the log, but this dependency means that they have to include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header files and clean up the includes to be in dependency order. In doing this, remove the direct include of xfs_trans_reserve.h from xfs_trans.h so that we remove the dependency between xfs_trans.h and xfs_mount.h. Hence the xfs_trans.h include can be moved to the indicate the actual dependencies other header files have on it. Note that these are kernel only header files, so this does not translate to any userspace changes at all. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: unify directory/attribute format definitionsDave Chinner
The on-disk format definitions for the directory and attribute structures are spread across 3 header files right now, only one of which is dedicated to defining on-disk structures and their manipulation (xfs_dir2_format.h). Pull all the format definitions into a single header file - xfs_da_format.h - and switch all the code over to point at that. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: kill xfs_vnodeops.[ch]Dave Chinner
Now we have xfs_inode.c for holding kernel-only XFS inode operations, move all the inode operations from xfs_vnodeops.c to this new file as it holds another set of kernel-only inode operations. The name of this file traces back to the days of Irix and it's vnodes which we don't have anymore. Essentially this move consolidates the inode locking functions and a bunch of XFS inode operations into the one file. Eventually the high level functions will be merged into the VFS interface functions in xfs_iops.c. This leaves only internal preallocation, EOF block manipulation and hole punching functions in vnodeops.c. Move these to xfs_bmap_util.c where we are already consolidating various in-kernel physical extent manipulation and querying functions. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: reshuffle dir2 definitions around for userspaceDave Chinner
Many of the definitions within xfs_dir2_priv.h are needed in userspace outside libxfs. Definitions within xfs_dir2_priv.h are wholly contained within libxfs, so we need to shuffle some of the definitions around to keep consistency across files shared between user and kernel space. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-02-26fs: encode_fh: return FILEID_INVALID if invalid fid_typeNamjae Jeon
This patch is a follow up on below patch: [PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63 Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Vivek Trivedi <t.vivek@samsung.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Sage Weil <sage@inktank.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-17xfs: remove xfs_iget.cDave Chinner
The inode cache functions remaining in xfs_iget.c can be moved to xfs_icache.c along with the other inode cache functions. This removes all functionality from xfs_iget.c, so the file can simply be removed. This move results in various functions now only having the scope of a single file (e.g. xfs_inode_free()), so clean up all the definitions and exported prototypes in xfs_icache.[ch] and xfs_inode.h appropriately. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-10-09tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checkingHugh Dickins
Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(), u64 inum = fid->raw[2]; which is unhelpfully reported as at the end of shmem_alloc_inode(): BUG: unable to handle kernel paging request at ffff880061cd3000 IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Call Trace: [<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0 [<ffffffff812d77c3>] do_handle_open+0x163/0x2c0 [<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10 [<ffffffff83a5f3f8>] tracesys+0xe1/0xe6 Right, tmpfs is being stupid to access fid->raw[2] before validating that fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may fall at the end of a page, and the next page not be present. But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and could oops in the same way: add the missing fh_len checks to those. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sage Weil <sage@inktank.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29->encode_fh() API changeAl Viro
pass inode + parent's inode or NULL instead of dentry + bool saying whether we want the parent or not. NOTE: that needs ceph fix folded in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-14xfs: move xfsagino_t to xfs_types.hDave Chinner
Untangle the header file includes a bit by moving the definition of xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include xfs_ag.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-12-06xfs: fix nfs export of 64-bit inodes numbers on 32-bit kernelsChristoph Hellwig
The i_ino field in the VFS inode is of type unsigned long and thus can't hold the full 64-bit inode number on 32-bit kernels. We have the full inode number in the XFS inode, so use that one for nfs exports. Note that I've also switched the 32-bit file handles types to it, just to make the code more consistent and copy & paste errors less likely to happen. Reported-by: Guoquan Yang <ygq51@hotmail.com> Reported-by: Hank Peng <pengxihan@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-10-11xfs: unlock the inode before log force in xfs_fs_nfs_commit_metadataChristoph Hellwig
Only read the LSN we need to push to with the ilock held, and then release it before we do the log force to improve concurrency. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
