path: root/fs/xfs/xfs_extfree_item.h
2013-08-12xfs: split out EFI/EFD log item format definitionDave Chinner
The EFI/EFD item format definitions are shared with userspace. Split the out of header files that contain kernel only defintions to make it simple to shared them. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-05xfs: don't free EFIs before the EFDs are committedDave Chinner
Filesystems are occasionally being shut down with this error: xfs_trans_ail_delete_bulk: attempting to delete a log item that is not in the AIL. It was diagnosed to be related to the EFI/EFD commit order when the EFI and EFD are in different checkpoints and the EFD is committed before the EFI here: http://oss.sgi.com/archives/xfs/2013-01/msg00082.html The real problem is that a single bit cannot fully describe the states that the EFI/EFD processing can be in. These completion states are: EFI EFI in AIL EFD Result committed/unpinned Yes committed OK committed/pinned No committed Shutdown uncommitted No committed Shutdown Note that the "result" field is what should happen, not what does happen. The current logic is broken and handles the first two cases correctly by luck. That is, the code will free the EFI if the XFS_EFI_COMMITTED bit is *not* set, rather than if it is set. The inverted logic "works" because if both EFI and EFD are committed, then the first __xfs_efi_release() call clears the XFS_EFI_COMMITTED bit, and the second frees the EFI item. Hence as long as xfs_efi_item_committed() has been called, everything appears to be fine. It is the third case where the logic fails - where xfs_efd_item_committed() is called before xfs_efi_item_committed(), and that results in the EFI being freed before it has been committed. That is the bug that triggered the shutdown, and hence keeping track of whether the EFI has been committed or not is insufficient to correctly order the EFI/EFD operations w.r.t. the AIL. What we really want is this: the EFI is always placed into the AIL before the last reference goes away. The only way to guarantee that is that the EFI is not freed until after it has been unpinned *and* the EFD has been committed. That is, restructure the logic so that the only case that can occur is the first case. This can be done easily by replacing the XFS_EFI_COMMITTED with an EFI reference count. The EFI is initialised with it's own count, and that is not released until it is unpinned. However, there is a complication to this method - the high level EFI/EFD code in xfs_bmap_finish() does not hold direct references to the EFI structure, and runs a transaction commit between the EFI and EFD processing. Hence the EFI can be freed even before the EFD is created using such a method. Further, log recovery uses the AIL for tracking EFI/EFDs that need to be recovered, but it uses the AIL *differently* to the EFI transaction commit. Hence log recovery never pins or unpins EFIs, so we can't drop the EFI reference count indirectly to free the EFI. However, this doesn't prevent us from using a reference count here. There is a 1:1 relationship between EFIs and EFDs, so when we initialise the EFI we can take a reference count for the EFD as well. This solves the xfs_bmap_finish() issue - the EFI will never be freed until the EFD is processed. In terms of log recovery, during the committing of the EFD we can look for the XFS_EFI_RECOVERED bit being set and drop the EFI reference as well, thereby ensuring everything works correctly there as well. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2010-12-20xfs: Pull EFI/EFD handling out from under the AIL lockDave Chinner
EFI/EFD interactions are protected from races by the AIL lock. They are the only type of log items that require the the AIL lock to serialise internal state, so they need to be separated from the AIL lock before we can do bulk insert operations on the AIL. To acheive this, convert the counter of the number of extents in the EFI to an atomic so it can be safely manipulated by EFD processing without locks. Also, convert the EFI state flag manipulations to use atomic bit operations so no locks are needed to record state changes. Finally, use the state bits to determine when it is safe to free the EFI and clean up the code to do this neatly. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-12-20xfs: fix EFI transaction cancellation.Dave Chinner
XFS_EFI_CANCELED has not been set in the code base since xfs_efi_cancel() was removed back in 2006 by commit 065d312e15902976d256ddaf396a7950ec0350a8 ("[XFS] Remove unused iop_abort log item operation), and even then xfs_efi_cancel() was never called. I haven't tracked it back further than that (beyond git history), but it indicates that the handling of EFIs in cancelled transactions has been broken for a long time. Basically, when we get an IOP_UNPIN(lip, 1); call from xfs_trans_uncommit() (i.e. remove == 1), if we don't free the log item descriptor we leak it. Fix the behviour to be correct and kill the XFS_EFI_CANCELED flag. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-01-22[XFS] remove always-true #ifndef HAVE_FORMAT32 testsEric Sandeen
There are several tests for #ifndef HAVE_FORMAT32, but this is never defined anywhere so it is always the default behavior; just remove the ifndef goop. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2006-09-28[XFS] cleanup the field types of some item format structuresTim Shimmin
SGI-PV: 954365 SGI-Modid: xfs-linux-melb:xfs-kern:26406a Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-09[XFS] inode items and EFI/EFDs have different ondisk format for 32bit andTim Shimmin
64bit kernels allow recovery to handle both versions and do the necessary decoding SGI-PV: 952214 SGI-Modid: xfs-linux-melb:xfs-kern:26011a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] consolidate extent item freeingChristoph Hellwig
SGI-PV: 938062 SGI-Modid: xfs-linux:xfs-kern:194415a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
