path: root/fs/xfs/xfs_ialloc.c
2008-04-29[XFS] Don't initialise new inode generation numbers to zeroDavid Chinner
When we allocation new inode chunks, we initialise the generation numbers to zero. This works fine until we delete a chunk and then reallocate it, resulting in the same inode numbers but with a reset generation count. This can result in inode/generation pairs of different inodes occurring relatively close together. Given that the inode/gen pair makes up the "unique" portion of an NFS filehandle on XFS, this can result in file handles cached on clients being seen on the wire from the server but refer to a different file. This causes .... issues for NFS clients. Hence we need a unique generation number initialisation for each inode to prevent reuse of a small portion of the generation number space. Use a random number to initialise the generation number so we don't need to keep any new state on disk whilst making the new number difficult to guess from previous allocations. SGI-PV: 979416 SGI-Modid: xfs-linux-melb:xfs-kern:31001a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Account for inode cluster alignment in all allocationsDavid Chinner
At ENOSPC, we can get a filesystem shutdown due to a cancelling a dirty transaction in xfs_mkdir or xfs_create. This is due to the initial allocation attempt not taking into account inode alignment and hence we can prepare the AGF freelist for allocation when it's not actually possible to do an allocation. This results in inode allocation returning ENOSPC with a dirty transaction, and hence we shut down the filesystem. Because the first allocation is an exact allocation attempt, we must tell the allocator that the alignment does not affect the allocation attempt. i.e. we will accept any extent alignment as long as the extent starts at the block we want. Unfortunately, this means that if the longest free extent is less than the length + alignment necessary for fallback allocation attempts but is long enough to attempt a non-aligned allocation, we will modify the free list. If we then have the exact allocation fail, all other allocation attempts will also fail due to the alignment constraint being taken into account. Hence the initial attempt needs to set the "alignment slop" field so that alignment, while not required, must be taken into account when determining if there is enough space left in the AG to do the allocation. That means if the exact allocation fails, we will not dirty the freelist if there is not enough space available fo a subsequent allocation to succeed. Hence we get an ENOSPC error back to userspace without shutting down the filesystem. SGI-PV: 978886 SGI-Modid: xfs-linux-melb:xfs-kern:30699a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-28[XFS] If you mount an XFS filesystem with no mount options at all, thenJosef Jeff Sipek
the "ikeep" option is set rather than "noikeep". This regression was introduced in 970451. With no mount options specified, xfs_parseargs() does the following: int ikeep = 0; args->flags |= XFSMNT_BARRIER; args->flags2 |= XFSMNT2_COMPAT_IOSIZE; if (!options) goto done; It only sets the above two options by default and before, it also used to set XFSMNT_IDELETE by default. If options are specified, then if (!(args->flags & XFSMNT_DMAPI) && !ikeep) args->flags |= XFSMNT_IDELETE; is executed later on which is skipped by the "goto done;" above. The solution is to invert the logic. SGI-PV: 977771 SGI-Modid: xfs-linux-melb:xfs-kern:30590a Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Josef 'Jeff' Sipek <jeffpc@josefsipek.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15[XFS] dinode endianess annotationsChristoph Hellwig
Biggest bit is duplicating the dinode structure so we have one annotated for native endianess and one for disk endianess. The other significant change is that xfs_xlate_dinode_core is split into one helper per direction to allow for proper annotations, everything else is trivial. As a sidenode splitting out the incore dinode means we can move it into xfs_inode.h in a later patch and severely improving on the include hell in xfs. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29476a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Lazy Superblock CountersDavid Chinner
When we have a couple of hundred transactions on the fly at once, they all typically modify the on disk superblock in some way. create/unclink/mkdir/rmdir modify inode counts, allocation/freeing modify free block counts. When these counts are modified in a transaction, they must eventually lock the superblock buffer and apply the mods. The buffer then remains locked until the transaction is committed into the incore log buffer. The result of this is that with enough transactions on the fly the incore superblock buffer becomes a bottleneck. The result of contention on the incore superblock buffer is that transaction rates fall - the more pressure that is put on the superblock buffer, the slower things go. The key to removing the contention is to not require the superblock fields in question to be locked. We do that by not marking the superblock dirty in the transaction. IOWs, we modify the incore superblock but do not modify the cached superblock buffer. In short, we do not log superblock modifications to critical fields in the superblock on every transaction. In fact we only do it just before we write the superblock to disk every sync period or just before unmount. This creates an interesting problem - if we don't log or write out the fields in every transaction, then how do the values get recovered after a crash? the answer is simple - we keep enough duplicate, logged information in other structures that we can reconstruct the correct count after log recovery has been performed. It is the AGF and AGI structures that contain the duplicate information; after recovery, we walk every AGI and AGF and sum their individual counters to get the correct value, and we do a transaction into the log to correct them. An optimisation of this is that if we have a clean unmount record, we know the value in the superblock is correct, so we can avoid the summation walk under normal conditions and so mount/recovery times do not change under normal operation. One wrinkle that was discovered during development was that the blocks used in the freespace btrees are never accounted for in the AGF counters. This was once a valid optimisation to make; when the filesystem is full, the free space btrees are empty and consume no space. Hence when it matters, the "accounting" is correct. But that means the when we do the AGF summations, we would not have a correct count and xfs_check would complain. Hence a new counter was added to track the number of blocks used by the free space btrees. This is an *on-disk format change*. As a result of this, lazy superblock counters are a mkfs option and at the moment on linux there is no way to convert an old filesystem. This is possible - xfs_db can be used to twiddle the right bits and then xfs_repair will do the format conversion for you. Similarly, you can convert backwards as well. At some point we'll add functionality to xfs_admin to do the bit twiddling easily.... SGI-PV: 964999 SGI-Modid: xfs-linux-melb:xfs-kern:28652a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Keep stack usage down for 4k stacks by using noinline.David Chinner
gcc-4.1 and more recent aggressively inline static functions which increases XFS stack usage by ~15% in critical paths. Prevent this from occurring by adding noinline to the STATIC definition. Also uninline some functions that are too large to be inlined and were causing problems with CONFIG_FORCED_INLINING=y. Finally, clean up all the different users of inline, __inline and __inline__ and put them under one STATIC_INLINE macro. For debug kernels the STATIC_INLINE macro uninlines those functions. SGI-PV: 957159 SGI-Modid: xfs-linux-melb:xfs-kern:27585a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Remove last bulkstat false-positives with debug kernels.Nathan Scott
SGI-PV: 953819 SGI-Modid: xfs-linux-melb:xfs-kern:26628a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] use NULL for pointer initialisation instead of zero-cast-to-ptrNathan Scott
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26562a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] endianess annotations for xfs_inobt_rec_t / xfs_inobt_key_tChristoph Hellwig
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26556a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Fix up debug code so that bulkstat wont generate thousands ofNathan Scott
fsstress warnings. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26111a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-04-11[XFS] Fix a problem in aligning inode allocations to stripe unitNathan Scott
boundaries. SGI-PV: 951862 SGI-Modid: xfs-linux-melb:xfs-kern:25726a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] A change to inode chunk allocation to try allocating the new chunkGlen Overby
contiguous with the most recently allocated chunk. On a striped filesystem, this will fill a stripe unit with inodes before allocating new inodes in another stripe unit. SGI-PV: 951416 SGI-Modid: xfs-linux-melb:xfs-kern:208488a Signed-off-by: Glen Overby <overby@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Dynamically allocate the xfs_dinode_core_t structure to reduce ourNathan Scott
stack footprint in xfs_ialloc_ag_alloc. SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:25420a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Endianess annotations for various allocator data structuresChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux:xfs-kern:201006a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Add format checking to cmn_err and icmn_errChristoph Hellwig
SGI-PV: 942243 SGI-Modid: xfs-linux:xfs-kern:198658a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
