path: root/fs/xfs/xfs_iget.c
2008-08-13[XFS] replace inode flush semaphore with a completionDavid Chinner
Use the new completion flush code to implement the inode flush lock. Removes one of the final users of semaphores in the XFS code base. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31817a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] sanitize xfs_initialize_vnodeChristoph Hellwig
Sanitize setting up the Linux indode. Setting up the xfs_inode <-> inode link is opencoded in xfs_iget_core now because that's the only place it needs to be done, xfs_initialize_vnode is renamed to xfs_setup_inode and loses all superflous paramaters. The check for I_NEW is removed because it always is true and the di_mode check moves into xfs_iget_core because it's only needed there. xfs_set_inodeops and xfs_revalidate_inode are merged into xfs_setup_inode and the whole things is moved into xfs_iops.c where it belongs. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31782a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Avoid directly referencing the VFS inode.David Chinner
In several places we directly convert from the XFS inode to the linux (VFS) inode by a simple deference of ip->i_vnode. We should not do this - a helper function should be used to extract the VFS inode from the XFS inode. Introduce the function VFS_I() to extract the VFS inode from the XFS inode. The name was chosen to match XFS_I() which is used to extract the XFS inode from the VFS inode. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31720a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] shrink mrlock_tChristoph Hellwig
The writer field is not needed for non_DEBU builds so remove it. While we're at i also clean up the interface for is locked asserts to go through and xfs_iget.c helper with an interface like the xfs_ilock routines to isolated the XFS codebase from mrlock internals. That way we can kill mrlock_t entirely once rw_semaphores grow an islocked facility. Also remove unused flags to the ilock family of functions. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30902a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Remove the xfs_icluster structureDavid Chinner
Remove the xfs_icluster structure and replace with a radix tree lookup. We don't need to keep a list of inodes in each cluster around anymore as we can look them up quickly when we need to. The only time we need to do this now is during inode writeback. Factor the inode cluster writeback code out of xfs_iflush and convert it to use radix_tree_gang_lookup() instead of walking a list of inodes built when we first read in the inodes. This remove 3 pointers from each xfs_inode structure and the xfs_icluster structure per inode cluster. Hence we reduce the cache footprint of the xfs_inodes by between 5-10% depending on cluster sparseness. To be truly efficient we need a radix_tree_gang_lookup_range() call to stop searching once we are past the end of the cluster instead of trying to find a full cluster's worth of inodes. Before (ia64): $ cat /sys/slab/xfs_inode/object_size 536 After: $ cat /sys/slab/xfs_inode/object_size 512 SGI-PV: 977460 SGI-Modid: xfs-linux-melb:xfs-kern:30502a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-03-06[XFS] fix inode leak in xfs_iget_core()David Chinner
If the radix_tree_preload() fails, we need to destroy the inode we just read in before trying again. This could leak xfs_vnode structures when there is memory pressure. Noticed by Christoph Hellwig. SGI-PV: 977823 SGI-Modid: xfs-linux-melb:xfs-kern:30606a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-02-07[XFS] Fix inode allocation latencyDavid Chinner
The log force added in xfs_iget_core() has been a performance issue since it was introduced for tight loops that allocate then unlink a single file. under heavy writeback, this can introduce unnecessary latency due tothe log I/o getting stuck behind bulk data writes. Fix this latency problem by avoinding the need for the log force by moving the place we mark linux inode dirty to the transaction commit rather than on transaction completion. This also closes a potential hole in the sync code where a linux inode is not dirty between the time it is modified and the time the log buffer has been written to disk. SGI-PV: 972753 SGI-Modid: xfs-linux-melb:xfs-kern:30007a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] cleanup vnode useage in xfs_iget.cChristoph Hellwig
Get rid of vnode useage in xfs_iget.c and pass Linux inode / xfs_inode where apropinquate. And kill some useless helpers while we're at it. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29808a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] kill xfs_iocore_tChristoph Hellwig
xfs_iocore_t is a structure embedded in xfs_inode. Except for one field it just duplicates fields already in xfs_inode, and there is nothing this abstraction buys us on XFS/Linux. This patch removes it and shrinks source and binary size of xfs aswell as shrinking the size of xfs_inode by 60/44 bytes in debug/non-debug builds. SGI-PV: 970852 SGI-Modid: xfs-linux-melb:xfs-kern:29754a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] more vnode/inode tracing fixesLachlan McIlroy
SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29697a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] clean up vnode/inode tracingLachlan McIlroy
Simplify vnode tracing calls by embedding function name & return addr in the calling macro. Also do a lot of vnode->inode renaming for consistency, while we're at it. SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29650a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-12-10[XFS] Fix broken inode cluster setup.David Chinner
The radix tree based inode caches did away with the inode cluster hashes, replacing them with a bunch of masking and gang lookups on the radix tree. This masking got broken when moving the code to per-ag radix trees and indexing by agino # rather than straight inode number. The result is clustered inode writeback does not cluster and things can go extremely slowly when there are lots of inodes to write. Fix it up by comparing the agino # of the inode we just looked up to the index of the cluster we are looking for. Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com> SGI-PV: 972915 SGI-Modid: xfs-linux-melb:xfs-kern:30033a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-16[XFS] kill struct bhv_vfsChristoph Hellwig
Now that struct bhv_vfs doesn't have any members left we can kill it and go directly from the super_block to the xfs_mount everywhere. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29509a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vfs-level helpers directly and remove vfs operationsChristoph Hellwig
Also remove the now dead behavior code. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29505a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the v_number member in struct bhv_vnodeChristoph Hellwig
It's entirely unused except for ignored arguments in the mrlock initialization, so remove it. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29499a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_trace from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the trace buffer to the XFS inode. Note that this makes the tracing macros rather misnamed, but this kind of fallout will be fixed up incrementally later on. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29498a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the v_flag member in struct bhv_vnodeChristoph Hellwig
All flags previously handled at the vnode level are not in the xfs_inode where we already have a flags mechanisms and free bits for flags previously in the vnode. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29495a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] Radix tree based inode cachingDavid Chinner
One of the perpetual scaling problems XFS has is indexing it's incore inodes. We currently uses hashes and the default hash sizes chosen can only ever be a tradeoff between memory consumption and the maximum realistic size of the cache. As a result, anyone who has millions of inodes cached on a filesystem needs to tunes the size of the cache via the ihashsize mount option to allow decent scalability with inode cache operations. A further problem is the separate inode cluster hash, whose size is based on the ihashsize but is smaller, and so under certain conditions (sparse cluster cache population) this can become a limitation long before the inode hash is causing issues. The following patchset removes the inode hash and cluster hash and replaces them with radix trees to avoid the scalability limitations of the hashes. It also reduces the size of the inodes by 3 pointers.... SGI-PV: 969561 SGI-Modid: xfs-linux-melb:xfs-kern:29481a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Add lockdep support for XFSLachlan McIlroy
SGI-PV: 963965 SGI-Modid: xfs-linux-melb:xfs-kern:28485a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] Prevent a deadlock when xfslogd unpins inodes.David Chinner
The previous fixes for the use after free in xfs_iunpin left a nasty log deadlock when xfslogd unpinned the inode and dropped the last reference to the inode. the ->clear_inode() method can issue transactions, and if the log was full, the transaction could push on the log and get stuck trying to push the inode it was currently unpinning. To fix this, we provide xfs_iunpin a guarantee that it will always have a valid xfs_inode <-> linux inode link or a particular flag will be set on the inode. We then use log forces during lookup to ensure transactions are completed before we recycle the inode. This ensures that xfs_iunpin will never use the linux inode after it is being freed, and any lookup on an inode on the reclaim list will wait until it is safe to attach a new linux inode to the xfs inode. SGI-PV: 956832 SGI-Modid: xfs-linux-melb:xfs-kern:27359a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Shailendra Tripathi <stripathi@agami.com> Signed-off-by: Takenori Nagano <t-nagano@ah.jp.nec.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] Clean up i_flags and i_flags_lock handling.David Chinner
SGI-PV: 956832 SGI-Modid: xfs-linux-melb:xfs-kern:27358a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nscott@aconex.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] Keep lockdep happy.Tim Shimmin
SGI-PV: 956964 SGI-Modid: xfs-linux-melb:xfs-kern:27200a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
2006-09-28[XFS] Really fix use after free in xfs_iunpin.David Chinner
The previous attempts to fix the linux inode use-after-free in xfs_iunpin simply made the problem harder to hit. We actually need complete exclusion between xfs_reclaim and xfs_iunpin, as well as ensuring that the i_flags are consistent during both of these functions. Introduce a new spinlock for exclusion and the i_flags, and fix up xfs_iunpin to use igrab before marking the inode dirty. SGI-PV: 952967 SGI-Modid: xfs-linux-melb:xfs-kern:26964a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] standardize on one sema init macroEric Sandeen
One sema to rule them all, one sema to find them... SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:26911a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add a greedy allocation interface, allocating within a min/max sizeNathan Scott
range. SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26803a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add a debug flag for allocations which are known to be larger thanNathan Scott
one page. SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26800a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Remove last bulkstat false-positives with debug kernels.Nathan Scott
SGI-PV: 953819 SGI-Modid: xfs-linux-melb:xfs-kern:26628a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-19[XFS] Kill direct access to ->count in valusema(); all we ever use it forAl Viro
is check if semaphore is actually locked, which can be trivially done in portable way. Code gets more reabable, while we are at it... SGI-PV: 953915 SGI-Modid: xfs-linux-melb:xfs-kern:26274a Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-04-11[XFS] Fix inode reclaim scalability regression. When a filesystem hasDavid Chinner
millions of inodes cached and has sparse cluster population, removing inodes from the cluster hash consumes excessive amounts of CPU time. Reduce the CPU cost by making removal O(1) via use of a double linked list for the hash chains. SGI-PV: 951551 SGI-Modid: xfs-linux-melb:xfs-kern:25683a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Complete transition away from linvfs naming convention, finally.Nathan Scott
SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:25474a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] add helper to get xfs_inode from vnodeChristoph Hellwig
SGI-PV: 947206 SGI-Modid: xfs-linux-melb:xfs-kern:203960a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-05[XFS] Retry linux inode cacech lookup if we found a stale inode. ThisChristoph Hellwig
fixes crashes under high nfs load SGI-PV: 941429 SGI-Modid: xfs-linux:xfs-kern:197929a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] remove unessecary vnode flagsChristoph Hellwig
SGI-PV: 934766 SGI-Modid: xfs-linux:xfs-kern:196852a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-05-05[XFS] Move the XFS inode to the front of its hash list on a cache hitNathan Scott
SGI Modid: xfs-linux:xfs-kern:21915a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Christoph Hellwig <hch@sgi.com>
