path: root/fs/xfs/xfs_itable.h
2014-11-07xfs: bulkstat chunk formatting cursor is brokenDave Chinner
The xfs_bulkstat_agichunk formatting cursor takes buffer values from the main loop and passes them via the structure to the chunk formatter, and the writes the changed values back into the main loop local variables. Unfortunately, this complex dance is full of corner cases that aren't handled correctly. The biggest problem is that it is double handling the information in both the main loop and the chunk formatting function, leading to inconsistent updates and endless loops where progress is not made. To fix this, push the struct xfs_bulkstat_agichunk outwards to be the primary holder of user buffer information. this removes the double handling in the main loop. Also, pass the last inode processed by the chunk formatter as a separate parameter as it purely an output variable and is not related to the user buffer consumption cursor. Finally, the chunk formatting code is not shared by anyone, so make it local to xfs_itable.c. cc: <stable@vger.kernel.org> # 3.17 Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-08-04xfs: introduce xfs_bulkstat_ag_ichunkJie Liu
Introduce xfs_bulkstat_ag_ichunk() to process inodes in chunk with a pointer to a formatter function that will iget the inode and fill in the appropriate structure. Refactor xfs_bulkstat() with it. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-07-24xfs: remove xfs_bulkstat_singleChristoph Hellwig
From: Christoph Hellwig <hch@lst.de> xfs_bukstat_one doesn't have any failure case that would go away when called through xfs_bulkstat, so remove the fallback and the now unessecary xfs_bulkstat_single function. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2010-06-24xfs: remove block number from inode lookup codeDave Chinner
The block number comes from bulkstat based inode lookups to shortcut the mapping calculations. We ar enot able to trust anything from bulkstat, so drop the block number as well so that the correct lookups and mappings are always done. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-06-23xfs: always use iget in bulkstatChristoph Hellwig
The non-coherent bulkstat versionsthat look directly at the inode buffers causes various problems with performance optimizations that make increased use of just logging inodes. This patch makes bulkstat always use iget, which should be fast enough for normal use with the radix-tree based inode cache introduced a while ago. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2009-08-31xfs: add more statics & drop some unused functionsEric Sandeen
A lot more functions could be made static, but they need forward declarations; this does some easy ones, and also found a few unused functions in the process. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2008-12-02[XFS] Fix xfs_bulkstat_one size checks & error handlingsandeen@sandeen.net
The 32-bit xfs_blkstat_one handler was failing because a size check checked whether the remaining (32-bit) user buffer was less than the (64-bit) bulkstat buffer, and failed with ENOMEM if so. Move this check into the respective handlers so that they check the correct sizes. Also, the formatters were returning negative errors or positive bytes copied; this was odd in the positive error value world of xfs, and handled wrong by at least some of the callers, which treated the bytes returned as an error value. Move the bytes-used assignment into the formatters. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-02[XFS] Make the bulkstat_one compat ioctl handling more sanesandeen@sandeen.net
Currently the compat formatter was handled by passing in "private_data" for the xfs_bulkstat_one formatter, which was really just another formatter... IMHO this got confusing. Instead, just make a new xfs_bulkstat_one_compat formatter for xfs_bulkstat, and call it via a wrapper. Also, don't translate the ioctl nrs into their native counterparts, that just clouds the issue; we're in a compat handler anyway, just switch on the 32-bit cmds. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-07-14[XFS] Fix XFS_IOC_FSBULKSTAT{,_SINGLE} & XFS_IOC_FSINUMBERS in compat modeMichal Marek
* 32bit struct xfs_fsop_bulkreq has different size and layout of members, no matter the alignment. Move the code out of the #else branch (why was it there in the first place?). Define _32 variants of the ioctl constants. * 32bit struct xfs_bstat is different because of time_t and on i386 because of different padding. Make xfs_bulkstat_one() accept a custom "output formatter" in the private_data argument which takes care of the xfs_bulkstat_one_compat() that takes care of the different layout in the compat case. * i386 struct xfs_inogrp has different padding. Add a similar "output formatter" mecanism to xfs_inumbers(). SGI-PV: 967354 SGI-Modid: xfs-linux-melb:xfs-kern:29102a Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] pv 956241, author: nathans, rv: vapo - make ino validation checksVlad Apostolov
consistent in bulkstat SGI-PV: 956241 SGI-Modid: xfs-linux-melb:xfs-kern:26984a Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Rework DMAPI bulkstat calls in such a way that we can directlyNathan Scott
extract inline attributes out of the bulkstat buffer (for that case), rather than using an (extremely expensive for large icount filesystems) iget for fetching attrs. SGI-PV: 944409 SGI-Modid: xfs-linux-melb:xfs-kern:26602a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-09[XFS] Remove dead code from come bulkstat paths.Nathan Scott
SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26102a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
