path: root/fs/xfs/xfs_qm_bhv.c
2017-06-19xfs: remove double-underscore integer typesDarrick J. Wong
This is a purely mechanical patch that removes the private __{u,}int{8,16,32,64}_t typedefs in favor of using the system {u,}int{8,16,32,64}_t typedefs. This is the sed script used to perform the transformation and fix the resulting whitespace and indentation errors: s/typedef\t__uint8_t/typedef __uint8_t\t/g s/typedef\t__uint/typedef __uint/g s/typedef\t__int\([0-9]*\)_t/typedef int\1_t\t/g s/__uint8_t\t/__uint8_t\t\t/g s/__uint/uint/g s/__int\([0-9]*\)_t\t/__int\1_t\t\t/g s/__int/int/g /^typedef.*int[0-9]*_t;$/d Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2014-11-28xfs: move most of xfs_sb.h to xfs_format.hChristoph Hellwig
More on-disk format consolidation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-28xfs: merge xfs_ag.h into xfs_format.hChristoph Hellwig
More on-disk format consolidation. A few declarations that weren't on-disk format related move into better suitable spots. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-25xfs: global error sign conversionDave Chinner
Convert all the errors the core XFs code to negative error signs like the rest of the kernel and remove all the sign conversion we do in the interface layers. Errors for conversion (and comparison) found via searches like: $ git grep " E" fs/xfs $ git grep "return E" fs/xfs $ git grep " E[A-Z].*;$" fs/xfs Negation points found via searches like: $ git grep "= -[a-z,A-Z]" fs/xfs $ git grep "return -[a-z,A-D,F-Z]" fs/xfs $ git grep " -[a-z].*;" fs/xfs [ with some bits I missed from Brian Foster ] Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-06-22xfs: Nuke XFS_ERROR macroEric Sandeen
XFS_ERROR was designed long ago to trap return values, but it's not runtime configurable, it's not consistently used, and we can do similar error trapping with ftrace scripts and triggers from userspace. Just nuke XFS_ERROR and associated bits. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-10-23xfs: decouple inode and bmap btree header filesDave Chinner
Currently the xfs_inode.h header has a dependency on the definition of the BMAP btree records as the inode fork includes an array of xfs_bmbt_rec_host_t objects in it's definition. Move all the btree format definitions from xfs_btree.h, xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to xfs_format.h to continue the process of centralising the on-disk format definitions. With this done, the xfs inode definitions are no longer dependent on btree header files. The enables a massive culling of unnecessary includes, with close to 200 #include directives removed from the XFS kernel code base. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: decouple log and transaction headersDave Chinner
xfs_trans.h has a dependency on xfs_log.h for a couple of structures. Most code that does transactions doesn't need to know anything about the log, but this dependency means that they have to include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header files and clean up the includes to be in dependency order. In doing this, remove the direct include of xfs_trans_reserve.h from xfs_trans.h so that we remove the dependency between xfs_trans.h and xfs_mount.h. Hence the xfs_trans.h include can be moved to the indicate the actual dependencies other header files have on it. Note that these are kernel only header files, so this does not translate to any userspace changes at all. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: separate dquot on disk format definitions out of xfs_quota.hDave Chinner
The on disk format definitions of the on-disk dquot, log formats and quota off log formats are all intertwined with other definitions for quotas. Separate them out into their own header file so they can easily be shared with userspace. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-07-11xfs: Add pquota fields where gquota is used.Chandra Seetharaman
Add project quota changes to all the places where group quota field is used: * add separate project quota members into various structures * split project quota and group quotas so that instead of overriding the group quota members incore, the new project quota members are used instead * get rid of usage of the OQUOTA flag incore, in favor of separate group and project quota flags. * add a project dquot argument to various functions. Not using the pquotino field from superblock yet. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-17xfs: Remove boolean_t typedef completely.Thiago Farina
Since we are using C99 we have one builtin defined in include/linux/types.h, use that instead. v2: you missed one in fs/xfs/xfs_qm_bhv.c, cleaned up. -bpm Signed-off-by: Thiago Farina <tfarina@chromium.org> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: clean up xfs_bit.h includesDave Chinner
With the removal of xfs_rw.h and other changes over time, xfs_bit.h is being included in many files that don't actually need it. Clean up the includes as necessary. Also move the only-used-once xfs_ialloc_find_free() static inline function out of a header file that is widely included to reduce the number of needless dependencies on xfs_bit.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: move xfsagino_t to xfs_types.hDave Chinner
Untangle the header file includes a bit by moving the definition of xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include xfs_ag.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-03-14xfs: remove the global xfs_Gqm structureChristoph Hellwig
If we initialize the slab caches for the quota code when XFS is loaded there is no need for a global and reference counted quota manager structure. Drop all this overhead and also fix the error handling during quota initialization. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-03-14xfs: use common code for quota statisticsChristoph Hellwig
Switch the quota code over to use the generic XFS statistics infrastructure. While the legacy /proc/fs/xfs/xqm and /proc/fs/xfs/xqmstats interfaces are preserved for now the statistics that still have a meaning with the current code are now also available from /proc/fs/xfs/stats. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-02-29xfs: include reservations in quota reportingChristoph Hellwig
Report all quota usage including the currently pending reservations. This avoids the need to flush delalloc space before gathering quota information, and matches quota enforcement, which already takes the reservations into account. This fixes xfstests 270. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
