path: root/fs/xfs/xfs_rw.c
2008-04-18[XFS] Sanitise xfs_log_force error checking.David Chinner
xfs_log_force() is declared to return an error, but we almost never check it. We don't need to check it in most cases; if there's a log I/O error then we'll be shutting down the filesystem anyway and that means we'll catch the error somewhere else. However, on certain calls we should be returning an error - sync transactions, fsync, sync writes, etc. so this isn't a pure black and white distinction. Hence make xfs_log_force() a void function that issues a warning to the syslog on error, and call _xfs_log_force() in all the places where we actually care about the error status returned. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30832a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-16[XFS] decontaminate vfs operations from behavior detailsChristoph Hellwig
All vfs ops now take struct xfs_mount pointers and the behaviour related glue is split out into methods of its own. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29504a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused header files for MAC and CAP checking functionality.Eric Sandeen
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used anywhere in XFS at all. They are left-overs from "to be implement at some point in the future" functionality that Irix XFS has. If this functionality ever goes into Linux, it will be provided at a different layer, most likely through the security hooks in the kernel so we will never need this functionality in XFS. Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960895 SGI-Modid: xfs-linux-melb:xfs-kern:28036a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-19[XFS] Push some common code out of write path into core XFS code forNathan Scott
sharing. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26248a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Complete the pagebuf -> xfs_buf naming convention transition,Nathan Scott
finally. SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:24866a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Add format checking to cmn_err and icmn_errChristoph Hellwig
SGI-PV: 942243 SGI-Modid: xfs-linux:xfs-kern:198658a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
