commit c9fbd7bbc23dbdd73364be4d045e5d3612cf6e82 upstream.
We recently had an oops reported on a 4.14 kernel in
xfs_reclaim_inodes_count() where sb->s_fs_info pointed to garbage
and so the m_perag_tree lookup walked into lala land.
Essentially, the machine was under memory pressure when the mount
was being run, xfs_fs_fill_super() failed after allocating the
xfs_mount and attaching it to sb->s_fs_info. It then cleaned up and
freed the xfs_mount, but the sb->s_fs_info field still pointed to
the freed memory. Hence when the superblock shrinker then ran
it fell off the bad pointer.
With the superblock shrinker problem fixed at teh VFS level, this
stale s_fs_info pointer is still a problem - we use it
unconditionally in ->put_super when the superblock is being torn
down, and hence we can still trip over it after a ->fill_super
call failure. Hence we need to clear s_fs_info if
xfs-fs_fill_super() fails, and we need to check if it's valid in
the places it can potentially be dereferenced after a ->fill_super
failure.
Signed-Off-By: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Ajay Kaher <akaher@vmware.com>
commit 80660f20252d6f76c9f203874ad7c7a4a8508cf8 upstream.
The function return values are confusing with the way the function is
named. We expect a true or false return value but it actually returns
0/-errno. This makes the code very confusing. Changing the return values
to return a bool where if DAX is supported then return true and no DAX
support returns false.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
commit ba23cba9b3bdc967aabdc6ff1e3e9b11ce05bb4f upstream.
Change bdev_dax_supported so it takes a bdev parameter. This enables
multi-device filesystems like xfs to check that a dax device can work for
the particular filesystem. Once that's in place, actually fix all the
parts of XFS where we need to be able to distinguish between datadev and
rtdev.
This patch fixes the problem where we screw up the dax support checking
in xfs if the datadev and rtdev have different dax capabilities.
[rez: Re-added __bdev_dax_supported() for !CONFIG_FS_DAX cases]
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
[AV: in addition to the fix in previous commit]
Signed-off-by: Matthew Garrett <mjg59@google.com>
Reviewed-by: David Howells <dhowells@redhat.com>
device does not support discard
In order to using discard function, it is necessary that not only xfs
is mounted with discard option, but also the discard function is
supported by the device. Current code doesn't output any message when
users mount with discard option on unsupported device, so it is
difficult to notice that it was not enabled actually.
This patch adds the warning message to notice that discard option is
not enabled due to unsupported device when the filesystem is mounted.
Changes in v2 (Suggested by Brian Foster):
- Move the unsupported device check into xfs_fs_fill_super().
- Clear the discard flag when device is unsupported.
Signed-off-by: Kenjiro Nakayama <nakayamakenjiro@gmail.com>
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm from Dan Williams:
"A rework of media error handling in the BTT driver and other updates.
It has appeared in a few -next releases and collected some late-
breaking build-error and warning fixups as a result.
Summary:
- Media error handling support in the Block Translation Table (BTT)
driver is reworked to address sleeping-while-atomic locking and
memory-allocation-context conflicts.
- The dax_device lookup overhead for xfs and ext4 is moved out of the
iomap hot-path to a mount-time lookup.
- A new 'ecc_unit_size' sysfs attribute is added to advertise the
read-modify-write boundary property of a persistent memory range.
- Preparatory fix-ups for arm and powerpc pmem support are included
along with other miscellaneous fixes"
* tag 'libnvdimm-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (26 commits)
libnvdimm, btt: fix format string warnings
libnvdimm, btt: clean up warning and error messages
ext4: fix null pointer dereference on sbi
libnvdimm, nfit: move the check on nd_reserved2 to the endpoint
dax: fix FS_DAX=n BLOCK=y compilation
libnvdimm: fix integer overflow static analysis warning
libnvdimm, nd_blk: remove mmio_flush_range()
libnvdimm, btt: rework error clearing
libnvdimm: fix potential deadlock while clearing errors
libnvdimm, btt: cache sector_size in arena_info
libnvdimm, btt: ensure that flags were also unchanged during a map_read
libnvdimm, btt: refactor map entry operations with macros
libnvdimm, btt: fix a missed NVDIMM_IO_ATOMIC case in the write path
libnvdimm, nfit: export an 'ecc_unit_size' sysfs attribute
ext4: perform dax_device lookup at mount
ext2: perform dax_device lookup at mount
xfs: perform dax_device lookup at mount
dax: introduce a fs_dax_get_by_bdev() helper
libnvdimm, btt: check memory allocation failure
libnvdimm, label: fix index block size calculation
In function xfs_test_remount_options(), kfree() is used to free memory
allocated by kmem_zalloc(). But it is better to use kmem_free().
Signed-off-by: Pan Bian <bianpan2016@163.com>
The ->iomap_begin() operation is a hot path, so cache the
fs_dax_get_by_host() result at mount time to avoid the incurring the
hash lookup overhead on a per-i/o basis.
Reported-by: Christoph Hellwig <hch@lst.de>
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
Pull XFS updates from Darrick Wong:
"Here are some changes for you for 4.13. For the most part it's fixes
for bugs and deadlock problems, and preparation for online fsck in
some future merge window.
- Avoid quotacheck deadlocks
- Fix transaction overflows when bunmapping fragmented files
- Refactor directory readahead
- Allow admin to configure if ASSERT is fatal
- Improve transaction usage detail logging during overflows
- Minor cleanups
- Don't leak log items when the log shuts down
- Remove double-underscore typedefs
- Various preparation for online scrubbing
- Introduce new error injection configuration sysfs knobs
- Refactor dq_get_next to use extent map directly
- Fix problems with iterating the page cache for unwritten data
- Implement SEEK_{HOLE,DATA} via iomap
- Refactor XFS to use iomap SEEK_HOLE and SEEK_DATA
- Don't use MAXPATHLEN to check on-disk symlink target lengths"
* tag 'xfs-4.13-merge-5' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linux: (48 commits)
xfs: don't crash on unexpected holes in dir/attr btrees
xfs: rename MAXPATHLEN to XFS_SYMLINK_MAXLEN
xfs: fix contiguous dquot chunk iteration livelock
xfs: Switch to iomap for SEEK_HOLE / SEEK_DATA
vfs: Add iomap_seek_hole and iomap_seek_data helpers
vfs: Add page_cache_seek_hole_data helper
xfs: remove a whitespace-only line from xfs_fs_get_nextdqblk
xfs: rewrite xfs_dq_get_next_id using xfs_iext_lookup_extent
xfs: Check for m_errortag initialization in xfs_errortag_test
xfs: grab dquots without taking the ilock
xfs: fix semicolon.cocci warnings
xfs: Don't clear SGID when inheriting ACLs
xfs: free cowblocks and retry on buffered write ENOSPC
xfs: replace log_badcrc_factor knob with error injection tag
xfs: convert drop_writes to use the errortag mechanism
xfs: remove unneeded parameter from XFS_TEST_ERROR
xfs: expose errortag knobs via sysfs
xfs: make errortag a per-mountpoint structure
xfs: free uncommitted transactions during log recovery
xfs: don't allow bmap on rt files
This is a purely mechanical patch that removes the private
__{u,}int{8,16,32,64}_t typedefs in favor of using the system
{u,}int{8,16,32,64}_t typedefs. This is the sed script used to perform
the transformation and fix the resulting whitespace and indentation
errors:
s/typedef\t__uint8_t/typedef __uint8_t\t/g
s/typedef\t__uint/typedef __uint/g
s/typedef\t__int\([0-9]*\)_t/typedef int\1_t\t/g
s/__uint8_t\t/__uint8_t\t\t/g
s/__uint/uint/g
s/__int\([0-9]*\)_t\t/__int\1_t\t\t/g
s/__int/int/g
/^typedef.*int[0-9]*_t;$/d
"flags" arguments are often seen as good API design as they allow
easy extensibility.
bioset_create_nobvec() is implemented internally as a variation in
flags passed to __bioset_create().
To support future extension, make the internal structure part of the
API.
i.e. add a 'flags' argument to bioset_create() and discard
bioset_create_nobvec().
Note that the bio_split allocations in drivers/md/raid* do not need
the bvec mempool - they should have used bioset_create_nobvec().
Suggested-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.com>
Pull libnvdimm fixes from Dan Williams:
"Incremental fixes and a small feature addition on top of the main
libnvdimm 4.12 pull request:
- Geert noticed that tinyconfig was bloated by BLOCK selecting DAX.
The size regression is fixed by moving all dax helpers into the
dax-core and only specifying "select DAX" for FS_DAX and
dax-capable drivers. He also asked for clarification of the
NR_DEV_DAX config option which, on closer look, does not need to be
a config option at all. Mike also throws in a DEV_DAX_PMEM fixup
for good measure.
- Ben's attention to detail on -stable patch submissions caught a
case where the recent fixes to arch_copy_from_iter_pmem() missed a
condition where we strand dirty data in the cache. This is tagged
for -stable and will also be included in the rework of the pmem api
to a proposed {memcpy,copy_user}_flushcache() interface for 4.13.
- Vishal adds a feature that missed the initial pull due to pending
review feedback. It allows the kernel to clear media errors when
initializing a BTT (atomic sector update driver) instance on a pmem
namespace.
- Ross noticed that the dax_device + dax_operations conversion broke
__dax_zero_page_range(). The nvdimm unit tests fail to check this
path, but xfstests immediately trips over it. No excuse for missing
this before submitting the 4.12 pull request.
These all pass the nvdimm unit tests and an xfstests spot check. The
set has received a build success notification from the kbuild robot"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
filesystem-dax: fix broken __dax_zero_page_range() conversion
libnvdimm, btt: ensure that initializing metadata clears poison
libnvdimm: add an atomic vs process context flag to rw_bytes
x86, pmem: Fix cache flushing for iovec write < 8 bytes
device-dax: kill NR_DEV_DAX
block, dax: move "select DAX" from BLOCK to FS_DAX
device-dax: Tell kbuild DEV_DAX_PMEM depends on DEV_DAX
For configurations that do not enable DAX filesystems or drivers, do not
require the DAX core to be built.
Given that the 'direct_access' method has been removed from
'block_device_operations', we can also go ahead and remove the
block-related dax helper functions from fs/block_dev.c to
drivers/dax/super.c. This keeps dax details out of the block layer and
lets the DAX core be built as a module in the FS_DAX=n case.
Filesystems need to include dax.h to call bdev_dax_supported().
Cc: linux-xfs@vger.kernel.org
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Jan Kara <jack@suse.com>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
The log covering background task used to be part of the xfssyncd
workqueue. That workqueue was removed as of commit 5889608df ("xfs:
syncd workqueue is no more") and the associated work item scheduled
to the xfs-log wq. The latter is used for log buffer I/O completion.
Since xfs_log_worker() can invoke a log flush, a deadlock is
possible between the xfs-log and xfs-cil workqueues. Consider the
following codepath from xfs_log_worker():
xfs_log_worker()
xfs_log_force()
_xfs_log_force()
xlog_cil_force()
xlog_cil_force_lsn()
xlog_cil_push_now()
flush_work()
The above is in xfs-log wq context and blocked waiting on the
completion of an xfs-cil work item. Concurrently, the cil push in
progress can end up blocked here:
xlog_cil_push_work()
xlog_cil_push()
xlog_write()
xlog_state_get_iclog_space()
xlog_wait(&log->l_flush_wait, ...)
The above is in xfs-cil context waiting on log buffer I/O
completion, which executes in xfs-log wq context. In this scenario
both workqueues are deadlocked waiting on eachother.
Add a new workqueue specifically for the high level log covering and
ail pushing worker, as was the case prior to commit 5889608df.
Diagnosed-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: Brian Foster <bfoster@redhat.com>
We only want to reclaim preallocations from our periodic work item.
Currently this is archived by looking for a dirty inode, but that check
is rather fragile. Instead add a flag to xfs_reflink_cancel_cow_* so
that the caller can ask for just cancelling unwritten extents in the COW
fork.
[darrick: fix typos in commit message]
Instead we submit the discard requests and use another workqueue to
release the extents from the extent busy list.
We always perform integrity operations now, so these mount options
don't do anything. Deprecate them and mark them for removal in
in a year.
Signed-off-by: Dave Chinner <david@fromorbit.com>
This patch drops the XFS-own i_iolock and uses the VFS i_rwsem which
recently replaced i_mutex instead. This means we only have to take
one lock instead of two in many fast path operations, and we can
also shrink the xfs_inode structure. Thanks to the xfs_ilock family
there is very little churn, the only thing of note is that we need
to switch to use the lock_two_directory helper for taking the i_rwsem
on two inodes in a few places to make sure our lock order matches
the one used in the VFS.
Tested-by: Jens Axboe <axboe@fb.com>
There are a couple of places where we don't check the inode's
reflink flag before calling into the reflink code. Fix those,
and add some asserts so we don't make this mistake again.
Reported-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Add the reflink feature flag to the set of recognized feature flags.
This enables users to write to reflink filesystems.
Trim CoW reservations made on behalf of a cowextsz hint if they get too
old or we run low on quota, so long as we don't have dirty data awaiting
writeback or directio operations in progress.
Garbage collection of the cowextsize extents are kept separate from
prealloc extent reaping because setting the CoW prealloc lifetime to a
(much) higher value than the regular prealloc extent lifetime has been
useful for combatting CoW fragmentation on VM hosts where the VMs
experience bursty write behaviors and we can keep the utilization ratios
low enough that we don't start to run out of space. IOWs, it benefits
us to keep the CoW fork reservations around for as long as we can unless
we run out of blocks or hit inode reclaim.
To gracefully handle the situation where a CoW operation turns a
single refcount extent into a lot of tiny ones and then run out of
space when a tree split has to happen, use the per-AG reserved block
pool to pre-allocate all the space we'll ever need for a maximal
btree. For a 4K block size, this only costs an overhead of 0.3% of
available disk space.
When reflink is enabled, we have an unfortunate problem with rmap --
since we can share a block billions of times, this means that the
reverse mapping btree can expand basically infinitely. When an AG is
so full that there are no free blocks with which to expand the rmapbt,
the filesystem will shut down hard.
This is rather annoying to the user, so use the AG reservation code to
reserve a "reasonable" amount of space for rmap. We'll prevent
reflinks and CoW operations if we think we're getting close to
exhausting an AG's free space rather than shutting down, but this
permanent reservation should be enough for "most" users. Hopefully.
[hch@lst.de: ensure that we invalidate the freed btree buffer]
Due to the way the CoW algorithm in XFS works, there's an interval
during which blocks allocated to handle a CoW can be lost -- if the FS
goes down after the blocks are allocated but before the block
remapping takes place. This is exacerbated by the cowextsz hint --
allocated reservations can sit around for a while, waiting to get
used.
Since the refcount btree doesn't normally store records with refcount
of 1, we can use it to record these in-progress extents. In-progress
blocks cannot be shared because they're not user-visible, so there
shouldn't be any conflicts with other programs. This is a better
solution than holding EFIs during writeback because (a) EFIs can't be
relogged currently, (b) even if they could, EFIs are bound by
available log space, which puts an unnecessary upper bound on how much
CoW we can have in flight, and (c) we already have a mechanism to
track blocks.
At mount time, read the refcount records and free anything we find
with a refcount of 1 because those were in-progress when the FS went
down.
When destroying the inode, cancel all pending reservations in the CoW
fork so that all the reserved blocks go back to the free pile. In
theory this sort of cleanup is only needed to clean up after write
errors.
Log recovery will iget an inode to replay BUI items and iput the inode
when it's done. Unfortunately, if the inode was unlinked, the iput
will see that i_nlink == 0 and decide to truncate & free the inode,
which prevents us from replaying subsequent BUIs. We can't skip the
BUIs because we have to replay all the redo items to ensure that
atomic operations complete.
Since unlinked inode recovery will reap the inode anyway, we can
safely introduce a new inode flag to indicate that an inode is in this
'unlinked recovery' state and should not be auto-reaped in the
drop_inode path.
Implement deferred versions of the inode block map/unmap functions.
These will be used in subsequent patches to make reflink operations
atomic.
Create bmbt update intent/done log items to record redo information in
the log. Because we roll transactions multiple times for reflink
operations, we also have to track the status of the metadata updates
that will be recorded in the post-roll transactions in case we crash
before committing the final transaction. This mechanism enables log
recovery to finish what was already started.
Plumb in the upper level interface to schedule and finish deferred
refcount operations via the deferred ops mechanism.
Create refcount update intent/done log items to record redo
information in the log. Because we need to roll transactions between
updating the bmbt mapping and updating the reverse mapping, we also
have to track the status of the metadata updates that will be recorded
in the post-roll transactions, just in case we crash before committing
the final transaction. This mechanism enables log recovery to finish
Recently we've had a number of reports where log recovery on a v5
filesystem has reported corruptions that looked to be caused by
recovery being re-run over the top of an already-recovered
metadata. This has uncovered a bug in recovery (fixed elsewhere)
but the vector that caused this was largely unknown.
A kdump test started tripping over this problem - the system
would be crashed, the kdump kernel and environment would boot and
dump the kernel core image, and then the system would reboot. After
reboot, the root filesystem was triggering log recovery and
corruptions were being detected. The metadumps indicated the above
log recovery issue.
What is happening is that the kdump kernel and environment is
mounting the root device read-only to find the binaries needed to do
it's work. The result of this is that it is running log recovery.
However, because there were unlinked files and EFIs to be processed
by recovery, the completion of phase 1 of log recovery could not
mark the log clean. And because it's a read-only mount, the unmount
process does not write records to the log to mark it clean, either.
Hence on the next mount of the filesystem, log recovery was run
again across all the metadata that had already been recovered and
this is what triggered corruption warnings.
To avoid this problem, we need to ensure that a read-only mount
always updates the log when it completes the second phase of
recovery. We already handle this sort of issue with rw->ro remount
transitions, so the solution is as simple as quiescing the
filesystem at the appropriate time during the mount process. This
results in the log being marked clean so the mount behaviour
recorded in the logs on repeated RO mounts will change (i.e. log
recovery will no longer be run on every mount until a RW mount is
done). This is a user visible change in behaviour, but it is
harmless.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Use variable length array declarations for RUI log items,
and replace the open coded sizeof formulae with a single function.
Since the kernel doesn't currently support the realtime rmapbt,
don't allow such filesystems to be mounted. Support will appear
in a future release.
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Nothing ever uses the extent array in the rmap update done redo
item, so remove it before it is fixed in the on-disk log format.
Originally-From: Dave Chinner <dchinner@redhat.com>
Add the feature flag to the supported matrix so that the kernel can
mount and use rmap btree enabled filesystems
[darrick.wong@oracle.com: move the experimental tag]
Reviewed-by: Brian Foster <bfoster@redhat.com>
Connect the xfs_defer mechanism with the pieces that we'll need to
handle deferred rmap updates. We'll wire up the existing code to
our new deferred mechanism later.
Create rmap update intent/done log items to record redo information in
the log. Because we need to roll transactions between updating the
bmbt mapping and updating the reverse mapping, we also have to track
the status of the metadata updates that will be recorded in the
post-roll transactions, just in case we crash before committing the
final transaction. This mechanism enables log recovery to finish what
The rmap btree is allocated from the AGFL, which means we have to
ensure ENOSPC is reported to userspace before we run out of free
space in each AG. The last allocation in an AG can cause a full
height rmap btree split, and that means we have to reserve at least
this many blocks *in each AG* to be placed on the AGFL at ENOSPC.
Update the various space calculation functions to handle this.
Also, because the macros are now executing conditional code and are
called quite frequently, convert them to functions that initialise
variables in the struct xfs_mount, use the new variables everywhere
and document the calculations better.
[darrick.wong@oracle.com: don't reserve blocks if !rmap]
[dchinner@redhat.com: update m_ag_max_usable after growfs]
Drop the compatibility shims that we were using to integrate the new
deferred operation mechanism into the existing code. No new code.
handle deferred extent freeing. We'll wire up the existing code to
Been around for long enough now, hasn't caused any regression test
failures in the past 3 months, so it's time to make it a fully
supported feature.
In struct xfs_bmap_free, convert the open-coded free extent list to
a regular list, then use list_sort to sort it prior to processing.
The filesystem quiesce sequence performs the operations necessary to
drain all background work, push pending transactions through the log
infrastructure and wait on I/O resulting from the final AIL push. We
have had reports of remount,ro hangs in xfs_log_quiesce() ->
xfs_wait_buftarg(), however, and some instrumentation code to detect
transaction commits at this point in the quiesce sequence has inculpated
the eofblocks background scanner as a cause.
While higher level remount code generally prevents user modifications by
the time the filesystem has made it to xfs_log_quiesce(), the background
scanner may still be alive and can perform pending work at any time. If
this occurs between the xfs_log_force() and xfs_wait_buftarg() calls
within xfs_log_quiesce(), this can lead to an indefinite lockup in
xfs_wait_buftarg().
To prevent this problem, cancel the background eofblocks scan worker
during the remount read-only quiesce sequence. This suspends background
trimming when a filesystem is remounted read-only. This is only done in
the remount path because the freeze codepath has already locked out new
transactions by the time the filesystem attempts to quiesce (and thus
waiting on an active work item could deadlock). Kick the eofblocks
worker to pick up where it left off once an fs is remounted back to
read-write.
Al Viro noticed that xfs_lock_inodes should be static, and
that led to ... a few more.
These are just the easy ones, others require moving functions
higher in source files, so that's not done here to keep
this review simple.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Pull misc DAX updates from Vishal Verma:
"DAX error handling for 4.7
- Until now, dax has been disabled if media errors were found on any
device. This enables the use of DAX in the presence of these
errors by making all sector-aligned zeroing go through the driver.
- The driver (already) has the ability to clear errors on writes that
are sent through the block layer using 'DSMs' defined in ACPI 6.1.
Other misc changes:
- When mounting DAX filesystems, check to make sure the partition is
page aligned. This is a requirement for DAX, and previously, we
allowed such unaligned mounts to succeed, but subsequent
reads/writes would fail.
- Misc/cleanup fixes from Jan that remove unused code from DAX
related to zeroing, writeback, and some size checks"
* tag 'dax-misc-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
dax: fix a comment in dax_zero_page_range and dax_truncate_page
dax: for truncate/hole-punch, do zeroing through the driver if possible
dax: export a low-level __dax_zero_page_range helper
dax: use sb_issue_zerout instead of calling dax_clear_sectors
dax: enable dax in the presence of known media errors (badblocks)
dax: fallback from pmd to pte on error
block: Update blkdev_dax_capable() for consistency
xfs: Add alignment check for DAX mount
ext2: Add alignment check for DAX mount
ext4: Add alignment check for DAX mount
block: Add bdev_dax_supported() for dax mount checks
block: Add vfs_msg() interface
dax: Remove redundant inode size checks
dax: Remove pointless writeback from dax_do_io()
dax: Remove zeroing from dax_io()
dax: Remove dead zeroing code from fault handlers
ext2: Avoid DAX zeroing to corrupt data
ext2: Fix block zeroing in ext2_get_blocks() for DAX
dax: Remove complete_unwritten argument
DAX: move RADIX_DAX_ definitions to dax.c
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs updates from Dave Chinner:
"A pretty average collection of fixes, cleanups and improvements in
this request.
Summary:
- fixes for mount line parsing, sparse warnings, read-only compat
feature remount behaviour
- allow fast path symlink lookups for inline symlinks.
- attribute listing cleanups
- writeback goes direct to bios rather than indirecting through
bufferheads
- transaction allocation cleanup
- optimised kmem_realloc
- added configurable error handling for metadata write errors,
changed default error handling behaviour from "retry forever" to
"retry until unmount then fail"
- fixed several inode cluster writeback lookup vs reclaim race
conditions
- fixed inode cluster writeback checking wrong inode after lookup
- fixed bugs where struct xfs_inode freeing wasn't actually RCU safe
- cleaned up inode reclaim tagging"
* tag 'xfs-for-linus-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (39 commits)
xfs: fix warning in xfs_finish_page_writeback for non-debug builds
xfs: move reclaim tagging functions
xfs: simplify inode reclaim tagging interfaces
xfs: rename variables in xfs_iflush_cluster for clarity
xfs: xfs_iflush_cluster has range issues
xfs: mark reclaimed inodes invalid earlier
xfs: xfs_inode_free() isn't RCU safe
xfs: optimise xfs_iext_destroy
xfs: skip stale inodes in xfs_iflush_cluster
xfs: fix inode validity check in xfs_iflush_cluster
xfs: xfs_iflush_cluster fails to abort on error
xfs: remove xfs_fs_evict_inode()
xfs: add "fail at unmount" error handling configuration
xfs: add configuration handlers for specific errors
xfs: add configuration of error failure speed
xfs: introduce table-based init for error behaviors
xfs: add configurable error support to metadata buffers
xfs: introduce metadata IO error class
xfs: configurable error behavior via sysfs
xfs: buffer ->bi_end_io function requires irq-safe lock
