path: root/fs/xfs/xfs_trans_buf.c
2008-04-18[XFS] Ensure errors from xfs_bdstrat() are correctly checked.David Chinner
xfsbdstrat() is declared to return an error. That is never checked because the error is propagated by the xfs_buf_t that is passed through the function. Mark xfsbdstrat() as returning void and comment the prototype on the methods needed for error checking. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30823a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Don't block pdflush when writing back inodesDavid Chinner
When pdflush is writing back inodes, it can get stuck on inode cluster buffers that are currently under I/O. This occurs when we write data to multiple inodes in the same inode cluster at the same time. Effectively, delayed allocation marks the inode dirty during the data writeback. Hence if the inode cluster was flushed during the writeback of the first inode, the writeback of the second inode will block waiting for the inode cluster write to complete before writing it again for the newly dirtied inode. Basically, we want to avoid this from happening so we don't block pdflush and slow down all of writeback. Hence we introduce a non-blocking async inode flush flag that pdflush uses. If this flag is set, we use non-blocking operations (e.g. try locks) whereever we can to avoid blocking or extra I/O being issued. SGI-PV: 970925 SGI-Modid: xfs-linux-melb:xfs-kern:30501a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-01Revert "[XFS] Avoid replaying inode buffer initialisation log items if ↵Tim Shimmin
on-disk version is newer." This reverts commit b394e43e995d08821588a22561c6a71a63b4ff27. Lachlan McIlroy says: It tried to fix an issue where log replay is replaying an inode cluster initialisation transaction that should not be replayed because the inode cluster on disk is more up to date. Since we don't log file sizes (we rely on inode flushing to get them to disk) then we can't just replay all the transations in the log and expect the inode to be completely restored. We lose file size updates. Unfortunately this fix is causing more (serious) problems than it is fixing. SGI-PV: 969656 SGI-Modid: xfs-linux-melb:xfs-kern:29804a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-09-18[XFS] Avoid replaying inode buffer initialisation log items if on-disk ↵Lachlan McIlroy
version is newer. SGI-PV: 969656 SGI-Modid: xfs-linux-melb:xfs-kern:29676a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Portability changes: remove prdev, stick to one diagnosticNathan Scott
interface. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26103a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-05[XFS] Fixes a bug in the quota code when allocating a new dquot recordTim Shimmin
which can cause an extent hole to be filled and a free extent to be processed. In this case, we make a few mistakes: forget to pass back the transaction, forget to put a hold on the buffer and forget to add the buf to the new transaction. SGI-PV: 940366 SGI-Modid: xfs-linux:xfs-kern:23594a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] Add support for project quota, based on Dan Knappes earlier work.Nathan Scott
SGI-PV: 932952 SGI-Modid: xfs-linux:xfs-kern:22805a Signed-off-by: Nathan Scott <nathans@sgi.com>
