commit b1c770c273a4787069306fc82aab245e9ac72e9d upstream
When finding the longest extent in an AG, we read the value directly
out of the AGF buffer without endian conversion. This will give an
incorrect length, resulting in FITRIM operations potentially not
trimming everything that it should.
Note, for 3.0-stable this has been modified to apply to
fs/xfs/linux-2.6/xfs_discard.c instead of fs/xfs/xfs_discard.c. -bpm
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 9b025eb3a89e041bab6698e3858706be2385d692 upstream.
Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted
symplink and bailed out. Fix it by jumping to 'out' instead of doing return.
CC: Carlos Maiolino <cmaiolino@redhat.com>
Reviewed-by: Alex Elder <elder@kernel.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream.
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Commit be4f1ac828776bbc7868a68b465cd8eedb733cfd upstream.
Since Linux 2.6.36 the writeback code has introduces various measures for
live lock prevention during sync(). Unfortunately some of these are
actively harmful for the XFS model, where the inode gets marked dirty for
metadata from the data I/O handler.
The older_than_this checks that are now more strictly enforced since
writeback: avoid livelocking WB_SYNC_ALL writeback
by only calling into __writeback_inodes_sb and thus only sampling the
current cut off time once. But on a slow enough devices the previous
asynchronous sync pass might not have fully completed yet, and thus XFS
might mark metadata dirty only after that sampling of the cut off time for
the blocking pass already happened. I have not myself reproduced this
myself on a real system, but by introducing artificial delay into the
XFS I/O completion workqueues it can be reproduced easily.
Fix this by iterating over all XFS inodes in ->sync_fs and log all that
are dirty. This might log inode that only got redirtied after the
previous pass, but given how cheap delayed logging of inodes is it
isn't a major concern for performance.
Tested-by: Mark Tinguely <tinguely@sgi.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Commit 0b8fd3033c308e4088760aa1d38ce77197b4e074 upstream.
If the writeback code writes back an inode because it has expired we currently
use the non-blockin ->write_inode path. This means any inode that is pinned
is skipped. With delayed logging and a workload that has very little log
traffic otherwise it is very likely that an inode that gets constantly
written to is always pinned, and thus we keep refusing to write it. The VM
writeback code at that point redirties it and doesn't try to write it again
for another 30 seconds. This means under certain scenarious time based
metadata writeback never happens.
Fix this by calling into xfs_log_inode for kupdate in addition to data
integrity syncs, and thus transfer the inode to the log ASAP.
commit 859f57ca00805e6c482eef1a7ab073097d02c8ca upstream.
[slightly different from the upstream version because of a previous cleanup]
Currently xfs_attr_inactive causes a synchronous transactions if we are
removing a file that has any extents allocated to the attribute fork, and
thus makes XFS extremely slow at removing files with out of line extended
attributes. The code looks a like a relict from the days before the busy
extent list, but with the busy extent list we avoid reusing data and attr
extents that have been freed but not commited yet, so this code is just
as superflous as the synchronous transactions for data blocks.
Reported-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Signed-off-by: Alex Elder <aelder@sgi.com>
commit c29f7d457ac63311feb11928a866efd2fe153d74 upstream.
The i_ino field in the VFS inode is of type unsigned long and thus can't
hold the full 64-bit inode number on 32-bit kernels. We have the full
inode number in the XFS inode, so use that one for nfs exports. Note
that I've also switched the 32-bit file handles types to it, just to make
the code more consistent and copy & paste errors less likely to happen.
Reported-by: Guoquan Yang <ygq51@hotmail.com>
Reported-by: Hank Peng <pengxihan@gmail.com>
commit 4c393a6059f8442a70512a48ce4639b882b6f6ad upstream.
With Dmitry fsstress updates I've seen very reproducible crashes in
xfs_attr_shortform_remove because xfs_attr_shortform_bytesfit claims that
the attributes would not fit inline into the inode after removing an
attribute. It turns out that we were operating on an inode with lots
of delalloc extents, and thus an if_bytes values for the data fork that
is larger than biggest possible on-disk storage for it which utterly
confuses the code near the end of xfs_attr_shortform_bytesfit.
Fix this by always allowing the current attribute fork, like we already
do for the attr1 format, given that delalloc conversion will take care
for moving either the data or attribute area out of line if it doesn't
fit at that point - or making the point moot by merging extents at this
point.
Also document the function better, and clean up some loose bits.
Acked-by: Dave Chinner <dchinner@redhat.com>
commit 4dd2cb4a28b7ab1f37163a4eba280926a13a8749 upstream.
If we are doing synchronous inode reclaim we block the VM from making
progress in memory reclaim. So if we encouter a flush locked inode
promote it in the delwri list and wake up xfsbufd to write it out now.
Without this we can get hangs of up to 30 seconds during workloads hitting
synchronous inode reclaim.
The scheme is copied from what we do for dquot reclaims.
Reported-by: Simon Kirby <sim@hostway.ca>
Tested-by: Simon Kirby <sim@hostway.ca>
commit fa8b18edd752a8b4e9d1ee2cd615b82c93cf8bba upstream.
This prevents in-memory corruption and possible panics if the on-disk
ACL is badly corrupted.
patch 58d84c4ee0389ddeb86238d5d8359a982c9f7a5b upstream.
Currently we always redirty an inode that was attempted to be written out
synchronously but has been cleaned by an AIL pushed internall, which is
rather bogus. Fix that by doing the i_update_core check early on and
return 0 for it. Also include async calls for it, as doing any work for
those is just as pointless. While we're at it also fix the sign for the
EIO return in case of a filesystem shutdown, and fix the completely
non-sensical locking around xfs_log_inode.
commit db3e74b582915d66e10b0c73a62763418f54c340 upstream
The doalloc arg in xfs_qm_dqattach_one() is a flag that indicates
whether a new area to handle quota information will be allocated
if needed. Originally, it was passed to xfs_qm_dqget(), but has
been removed by the following commit (probably by mistake):
commit 8e9b6e7fa4544ea8a0e030c8987b918509c8ff47
Author: Christoph Hellwig <hch@lst.de>
Date: Sun Feb 8 21:51:42 2009 +0100
xfs: remove the unused XFS_QMOPT_DQLOCK flag
As the result, xfs_qm_dqget() called from xfs_qm_dqattach_one()
never allocates the new area even if it is needed.
This patch gives the doalloc arg to xfs_qm_dqget() in
xfs_qm_dqattach_one() to fix this problem.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Alex Elder <aelder@sgi.com>
commit b52a360b2aa1c59ba9970fb0f52bbb093fcc7a24 upstream.
Fixes a possible memory corruption when the link is larger than
MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the
S_ISLNK assert, since the inode mode is checked previously in
xfs_readlink_by_handle() and via VFS.
Updated to address concerns raised by Ben Hutchings about the loose
attention paid to 32- vs 64-bit values, and the lack of handling a
potentially negative pathlen value:
- Changed type of "pathlen" to be xfs_fsize_t, to match that of
ip->i_d.di_size
- Added checking for a negative pathlen to the too-long pathlen
test, and generalized the message that gets reported in that case
to reflect the change
As a result, if a negative pathlen were encountered, this function
would return EFSCORRUPTED (and would fail an assertion for a debug
build)--just as would a too-long pathlen.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
commit ed32201e65e15f3e6955cb84cbb544b08f81e5a5 upstream.
An attribute of inode can be fetched via xfs_vn_getattr() in XFS.
Currently it returns EIO, not negative value, when it failed. As a
result, the system call returns not negative value even though an
error occured. The stat(2), ls and mv commands cannot handle this
error and do not work correctly.
This patch fixes this bug, and returns -EIO, not EIO when an error
is detected in xfs_vn_getattr().
commit c58cb165bd44de8aaee9755a144136ae743be116 upstream.
Currently a buffered reader or writer can add pages to the pagecache
while we are waiting for the iolock in xfs_file_dio_aio_write. Prevent
this by re-checking mapping->nrpages after we got the iolock, and if
nessecary upgrade the lock to exclusive mode. To simplify this a bit
only take the ilock inside of xfs_file_aio_write_checks.
commit 0c38a2512df272b14ef4238b476a2e4f70da1479 upstream.
There is no need to grab the i_mutex of the IO lock in exclusive
mode if we don't need to invalidate the page cache. Taking these
locks on every direct IO effective serialises them as taking the IO
lock in exclusive mode has to wait for all shared holders to drop
the lock. That only happens when IO is complete, so effective it
prevents dispatch of concurrent direct IO reads to the same inode.
Fix this by taking the IO lock shared to check the page cache state,
and only then drop it and take the IO lock exclusively if there is
work to be done. Hence for the normal direct IO case, no exclusive
locking will occur.
Tested-by: Joern Engel <joern@logfs.org>
commit 866e4ed77448a0c311e1b055eb72ea05423fd799 upstream.
During umount we do not add a dirty inode to the lru and wait for it to
become clean first, but force writeback of data and metadata with
I_WILL_FREE set. Currently there is no way for XFS to detect that the
inode has been redirtied for metadata operations, as we skip the
mark_inode_dirty call during teardown. Fix this by setting i_update_core
nanually in that case, so that the inode gets flushed during inode reclaim.
Alternatively we could enable calling mark_inode_dirty for inodes in
I_WILL_FREE state, and let the VFS dirty tracking handle this. I decided
against this as we will get better I/O patterns from reclaim compared to
the synchronous writeout in write_inode_now, and always marking the inode
dirty in some way from xfs_mark_inode_dirty is a better safetly net in
either case.
If removed storage while synchronous buffer write underway,
"xfslogd" hangs.
Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html
Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81
"xfs: fix error handling for synchronous writes"
Given that xfs_bwrite actually does the shutdown already after
waiting for the b_iodone completion and given that we actually
found that calling xfs_force_shutdown from inside
xfs_buf_iodone_callbacks was a major contributor the problem
it better to drop this call.
Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com>
commit 0030807c66f058230bcb20d2573bcaf28852e804 upstream
Currently we have a few issues with the way the workqueue code is used to
implement AIL pushing:
- it accidentally uses the same workqueue as the syncer action, and thus
can be prevented from running if there are enough sync actions active
in the system.
- it doesn't use the HIGHPRI flag to queue at the head of the queue of
work items
At this point I'm not confident enough in getting all the workqueue flags and
tweaks right to provide a perfectly reliable execution context for AIL
pushing, which is the most important piece in XFS to make forward progress
when the log fills.
Revert back to use a kthread per filesystem which fixes all the above issues
at the cost of having a task struct and stack around for each mounted
filesystem. In addition this also gives us much better ways to diagnose
any issues involving hung AIL pushing and removes a small amount of code.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
commit 17b38471c3c07a49f0bbc2ecc2e92050c164e226 upstream
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
commit bc6e588a8971aa74c02e42db4d6e0248679f3738 upstream
If an item was locked we should not update xa_last_pushed_lsn and thus skip
it when restarting the AIL scan as we need to be able to lock and write it
out as soon as possible. Otherwise heavy lock contention might starve AIL
pushing too easily, especially given the larger backoff once we moved
xa_last_pushed_lsn all the way to the target lsn.
commit 1d8c95a363bf8cd4d4182dd19c01693b635311c2 upstream
xfs: use a cursor for bulk AIL insertion
Delayed logging can insert tens of thousands of log items into the
AIL at the same LSN. When the committing of log commit records
occur, we can get insertions occurring at an LSN that is not at the
end of the AIL. If there are thousands of items in the AIL on the
tail LSN, each insertion has to walk the AIL to find the correct
place to insert the new item into the AIL. This can consume large
amounts of CPU time and block other operations from occurring while
the traversals are in progress.
To avoid this repeated walk, use a AIL cursor to record
where we should be inserting the new items into the AIL without
having to repeat the walk. The cursor infrastructure already
provides this functionality for push walks, so is a simple extension
of existing code. While this will not avoid the initial walk, it
will avoid repeating it tens of thousands of times during a single
checkpoint commit.
This version includes logic improvements from Christoph Hellwig.
commit 2bcf6e970f5a88fa05dced5eeb0326e13d93c4a1 upstream
Start the periodic sync workers only after we have finished xfs_mountfs
and thus fully set up the filesystem structures. Without this we can
call into xfs_qm_sync before the quotainfo strucute is set up if the
mount takes unusually long, and probably hit other incomplete states
as well.
Also clean up the xfs_fs_fill_super error path by using consistent
label names, and removing an impossible to reach case.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Reviewed-by: Alex Elder <aelder@sgi.com>
When inodes are marked stale in a transaction, they are treated
specially when the inode log item is being inserted into the AIL.
It tries to avoid moving the log item forward in the AIL due to a
race condition with the writing the underlying buffer back to disk.
The was "fixed" in commit de25c18 ("xfs: avoid moving stale inodes
in the AIL").
To avoid moving the item forward, we return a LSN smaller than the
commit_lsn of the completing transaction, thereby trying to trick
the commit code into not moving the inode forward at all. I'm not
sure this ever worked as intended - it assumes the inode is already
in the AIL, but I don't think the returned LSN would have been small
enough to prevent moving the inode. It appears that the reason it
worked is that the lower LSN of the inodes meant they were inserted
into the AIL and flushed before the inode buffer (which was moved to
the commit_lsn of the transaction).
The big problem is that with delayed logging, the returning of the
different LSN means insertion takes the slow, non-bulk path. Worse
yet is that insertion is to a position -before- the commit_lsn so it
is doing a AIL traversal on every insertion, and has to walk over
all the items that have already been inserted into the AIL. It's
expensive.
To compound the matter further, with delayed logging inodes are
likely to go from clean to stale in a single checkpoint, which means
they aren't even in the AIL at all when we come across them at AIL
insertion time. Hence these were all getting inserted into the AIL
when they simply do not need to be as inodes marked XFS_ISTALE are
never written back.
Transactional/recovery integrity is maintained in this case by the
other items in the unlink transaction that were modified (e.g. the
AGI btree blocks) and committed in the same checkpoint.
So to fix this, simply unpin the stale inodes directly in
xfs_inode_item_committed() and return -1 to indicate that the AIL
insertion code does not need to do any further processing of these
inodes.
If the attribute fork on an inode is in btree format and has
multiple levels (i.e node format rather than leaf format), then a
lookup failure will trigger an assert failure in xfs_da_path_shift
if the flag XFS_DA_OP_OKNOENT is not set. This flag is used to
indicate to the directory btree code that not finding an entry is
not a fatal error. In the case of doing a lookup for a directory
name removal, this is valid as a user cannot insert an arbitrary
name to remove from the directory btree.
However, in the case of the attribute tree, a user has direct
control over the attribute name and can ask for any random name to
be removed without any validation. In this case, fsstress is asking
for a non-existent user.selinux attribute to be removed, and that is
causing xfs_da_path_shift() to fall off the bottom of the tree where
it asserts that a lookup failure is allowed. Because the flag is not
set, we die a horrible death on a debug enable kernel.
Prevent this assert from firing on attribute removes by adding the
op_flag XFS_DA_OP_OKNOENT to atribute removal operations.
Discovered when testing on a SELinux enabled system by fsstress in
test 070 by trying to remove a non-existent user.selinux attribute.
When an inode is truncated down, speculative preallocation is
removed from the inode. This should also reset the state bits for
controlling whether preallocation is subsequently removed when the
file is next closed. The flag is not being cleared, so repeated
operations on a file that first involve a truncate (e.g. multiple
repeated dd invocations on a file) give different file layouts for
the second and subsequent invocations.
Fix this by clearing the XFS_IDIRTY_RELEASE state bit when the
XFS_ITRUNCATED bit is detected in xfs_release() and hence ensure
that speculative delalloc is removed on files that have been
truncated down.
XFS inodes has several per-lifetime state fields that determine the
behaviour of the inode. These state fields are not all reset when an
inode is reused from the reclaimable state.
This can lead to unexpected behaviour of the new inode such as
speculative preallocation not being truncated away in the expected
manner for local files until the inode is subsequently truncated,
freed or cycles out of the cache. It can also lead to an inode being
considered to be a filestream inode or having been truncated when
that is not the case.
Rework the reinitialisation of the inode when it is recycled to
ensure that it is pristine before it is reused. While there, also
fix the resetting of state flags in the recycling error paths so the
inode does not become unreclaimable.
There's no reason not to support cache flushing on external log devices.
The only thing this really requires is flushing the data device first
both in fsync and log commits. A side effect is that we also have to
remove the barrier write test during mount, which has been superflous
since the new FLUSH+FUA code anyway. Also use the chance to flush the
RT subvolume write cache before the fsync commit, which is required
for correct semantics.
->mknod() should return negative on errors and PTR_ERR() gives
already negative value...
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or
anything else, so that the filesystem can track internally if it
needs to push out a transaction for fdatasync or not.
This is just the prototype change with no user for it yet. I plan
to push large XFS changes for the next merge window, and getting
this trivial infrastructure in this window would help a lot to avoid
tree interdependencies.
Also remove incorrect comments that ->dirty_inode can't block. That
has been changed a long time ago, and many implementations rely on it.
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: correctly decrement the extent buffer index in xfs_bmap_del_extent
xfs: check for valid indices in xfs_iext_get_ext and xfs_iext_idx_to_irec
xfs: fix up asserts in xfs_iflush_fork
xfs: do not do pointer arithmetic on extent records
xfs: do not use unchecked extent indices in xfs_bunmapi
xfs: do not use unchecked extent indices in xfs_bmapi
xfs: do not use unchecked extent indices in xfs_bmap_add_extent_*
xfs: remove if_lastex
xfs: remove the unused XFS_BMAPI_RSVBLOCKS flag
xfs: do not discard alloc btree blocks
xfs: add online discard support
The code in xfs_bmap_del_extent does not correctly decrement the
extent buffer index when deleting a whole extent. Most of the time
this gets caught by checks in xfs_bmapi that work around it and
decrement it manually and thus wasn't noticed so far.
Based on an earlier patch from Lachlan McIlroy.
Reviewed-by: Lachlan McIlroy <lmcilroy@redhat.com>
Remove asserts in xfs_iflush_fork that would call xfs_iext_get_ext
with a potentially invalid extent buffer index.
We need to call xfs_iext_get_ext for the previous extent to get a
valid pointer, and can't just do pointer arithmetics as they might
be in different pages.
Make sure to only call xfs_iext_get_ext after we've validate the
extent index when moving on to the next index in xfs_bunmapi. Also
remove the old workaround for too large indices that has been
superceeded by the proper fix in xfs_bmap_del_extent.
extent index when moving on to the next index in xfs_bmapi.
extent index in the various xfs_bmap_add_extent_* helpers.
The if_lastex field in struct xfs_ifork is only used as a temporary
index during xfs_bmapi and xfs_bunmapi. Instead of using the inode
fork to store it keep it local in the callchain. Fortunately this
is very easy as we already pass a stack copy of it down the whole
chain which can simplify be changed to be passed by reference.
The XFS_BMAPI_RSVBLOCKS is unused, and as far as I can see has
always been. Remove it to simplify the bmapi implementation and
conserve stack space.
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Blocks for the allocation btree are allocated from and released to
the AGFL, and thus frequently reused. Even worse we do not have an
easy way to avoid using an AGFL block when it is discarded due to
the simple FILO list of free blocks, and thus can frequently stall
on blocks that are currently undergoing a discard.
Add a flag to the busy extent tracking structure to skip the discard
for allocation btree blocks. In normal operation these blocks are
reused frequently enough that there is no need to discard them
anyway, but if they spill over to the allocation btree as part of a
balance we "leak" blocks that we would otherwise discard. We could
fix this by adding another flag and keeping these block in the
rbtree even after they aren't busy any more so that we could discard
them when they migrate out of the AGFL. Given that this would cause
significant overhead I don't think it's worthwile for now.
Now that we have reliably tracking of deleted extents in a
transaction we can easily implement "online" discard support
which calls blkdev_issue_discard once a transaction commits.
The actual discard is a two stage operation as we first have
to mark the busy extent as not available for reuse before we
can start the actual discard. Note that we don't bother
supporting discard for the non-delaylog mode.
xfs: obey minleft values during extent allocation correctly
xfs: reset buffer pointers before freeing them
xfs: avoid getting stuck during async inode flushes
xfs: fix xfs_itruncate_start tracing
xfs: fix duplicate workqueue initialisation
xfs: kill off xfs_printk()
xfs: fix race condition in AIL push trigger
xfs: make AIL target updates and compares 32bit safe.
xfs: always push the AIL to the target
xfs: exit AIL push work correctly when AIL is empty
xfs: ensure reclaim cursor is reset correctly at end of AG
xfs: add an x86 compat handler for XFS_IOC_ZERO_RANGE
xfs: fix compiler warning in xfs_trace.h
xfs: cleanup duplicate initializations
xfs: reduce the number of pagb_lock roundtrips in xfs_alloc_clear_busy
xfs: exact busy extent tracking
xfs: do not immediately reuse busy extent ranges
xfs: optimize AGFL refills
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
When allocating an extent that is long enough to consume the
remaining free space in an AG, we need to ensure that the allocation
leaves enough space in the AG for any subsequent bmap btree blocks
that are needed to track the new extent. These have to be allocated
in the same AG as we only reserve enough blocks in an allocation
transaction for modification of the freespace trees in a single AG.
xfs_alloc_fix_minleft() has been considering blocks on the AGFL as
free blocks available for extent and bmbt block allocation, which is
not correct - blocks on the AGFL are there exclusively for the use
of the free space btrees. As a result, when minleft is less than the
number of blocks on the AGFL, xfs_alloc_fix_minleft() does not trim
the given extent to leave minleft blocks available for bmbt
allocation, and hence we can fail allocation during bmbt record
insertion.
When we free a vmapped buffer, we need to ensure the vmap address
and length we free is the same as when it was allocated. In various
places in the log code we change the memory the buffer is pointing
to before issuing IO, but we never reset the buffer to point back to
it's original memory (or no memory, if that is the case for the
buffer).
As a result, when we free the buffer it points to memory that is
owned by something else and attempts to unmap and free it. Because
the range does not match any known mapped range, it can trigger
BUG_ON() traps in the vmap code, and potentially corrupt the vmap
area tracking.
Fix this by always resetting these buffers to their original state
before freeing them.
When the underlying inode buffer is locked and xfs_sync_inode_attr()
is doing a non-blocking flush, xfs_iflush() can return EAGAIN. When
this happens, clear the error rather than returning it to
xfs_inode_ag_walk(), as returning EAGAIN will result in the AG walk
delaying for a short while and trying again. This can result in
background walks getting stuck on the one AG until inode buffer is
unlocked by some other means.
This behaviour was noticed when analysing event traces followed by
code inspection and verification of the fix via further traces.
Variables are ordered incorrectly in trace call.
