Access to log items on the AIL is generally protected by m_ail_lock;
this is particularly needed when we're getting or setting the 64-bit
li_lsn on a 32-bit platform. This patch fixes a couple places where we
were accessing the log item after dropping the AIL lock on 32-bit
machines.
This can result in a partially-zeroed log->l_tail_lsn if
xfs_trans_ail_delete is racing with xfs_trans_ail_update, and in at
least some cases, this can leave the l_tail_lsn with a zero cycle
number, which means xlog_space_left will think the log is full (unless
CONFIG_XFS_DEBUG is set, in which case we'll trip an ASSERT), leading to
processes stuck forever in xlog_grant_log_space.
Thanks to Adrian VanderSpek for first spotting the race potential and to
Dave Chinner for debug assistance.
Signed-off-by: Nathaniel W. Turner <nate@houseofnate.net>
Signed-off-by: Alex Elder <aelder@sgi.com>
I was hit by a bug in linux 2.6.31 when XFS is not able to recover the
log after a crash if fs was mounted with quotas. Gory details in XFS
bugzilla: http://oss.sgi.com/bugzilla/show_bug.cgi?id=855.
It looks like wrong struct is used in buffer length check, and the following
patch should fix the problem.
xfs_dqblk_t has a size of 104+32 bytes, while xfs_disk_dquot_t is 104 bytes
long, and this is exactly what I see in system logs - "XFS: dquot too small
(104) in xlog_recover_do_dquot_trans."
Signed-off-by: Jan Rekorajski <baggins@sith.mimuw.edu.pl>
* 'for-linus' of git://git.kernel.org/pub/scm/fs/xfs/xfs:
xfs: fix xfs_quota remove error
xfs: free temporary cursor in xfs_dialloc
The xfs_quota returns ENOSYS when remove command is executed.
Reproducable with following steps.
# mount -t xfs -o uquota /dev/sda7 /mnt/mp1
# xfs_quota -x -c off -c remove
XFS_QUOTARM: Function not implemented.
The remove command is allowed during quotaoff, but xfs_fs_set_xstate()
checks whether quota is running, and it leads to ENOSYS.
To solve this problem, add a check for X_QUOTARM.
Signed-off-by: Ryota Yamauchi <r-yamauchi@vf.jp.nec.com>
Signed-off-by: Utako Kusaka <u-kusaka@wm.jp.nec.com>
Commit bd169565993b39b9b4b102cdac8b13e0a259ce2f seems
to have a slight regression where this code path:
if (!--searchdistance) {
* Not in range - save last search
* location and allocate a new inode
goto newino;
doesn't free the temporary cursor (tcur) that got dup'd in
this function.
This leaks an item in the xfs_btree_cur zone, and it's caught
on module unload:
BUG xfs_btree_cur: Objects remaining on kmem_cache_close()
It seems like maybe a single free at the end of the function might
be cleaner, but for now put a del_cursor right in this code block
similar to the handling in the rest of the function.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: fix double IRELE in xfs_dqrele_inode
xfs_dqrele_inode calls xfs_iput to release the ilock and a reference
and then also calls IRELE which does a second decrement of the reference
count. This leads to a premature freeing of inodes when quotas were turned
off while the filesystem was mounted.
Thanks to Utako Kusaka for reporting the bug and provinding a good testcase.
Reported-by: Utako Kusaka <u-kusaka@wm.jp.nec.com>
Reviewed-by: Alex Elder <aelder@sgi.com>
xfs: stop calling filemap_fdatawait inside ->fsync
fix readahead calculations in xfs_dir2_leaf_getdents()
xfs: make sure xfs_sync_fsdata covers the log
xfs: mark inodes dirty before issuing I/O
xfs: cleanup ->sync_fs
xfs: fix xfs_quiesce_data
xfs: implement ->dirty_inode to fix timestamp handling
Now that the VFS actually waits for the data I/O to complete before
calling into ->fsync we can stop doing it ourselves.
This is for bug #850,
http://oss.sgi.com/bugzilla/show_bug.cgi?id=850
XFS file system segfaults , repeatedly and 100% reproducable in 2.6.30 , 2.6.31
The above only showed up on a CONFIG_XFS_DEBUG=y kernel, because
xfs_bmapi() ASSERTs that it has been asked for at least one map,
and it was getting 0.
The root cause is that our guesstimated "bufsize" from xfs_file_readdir
was fairly small, and the
bufsize -= length;
in the loop was going negative - except bufsize is a size_t, so it
was wrapping to a very large number.
Then when we did
ra_want = howmany(bufsize + mp->m_dirblksize,
mp->m_sb.sb_blocksize) - 1;
with that very large number, the (int) ra_want was coming out
negative, and a subsequent compare:
if (1 + ra_want > map_blocks ...
was coming out -true- (negative int compare w/ uint) and we went
back to xfs_bmapi() for more, even though we did not need more,
and asked for 0 maps, and hit the ASSERT.
We have kind of a type mess here, but just keeping bufsize from
going negative is probably sufficient to avoid the problem.
We want to always cover the log after writing out the superblock, and
in case of a synchronous writeout make sure we actually wait for the
log to be covered. That way a filesystem that has been sync()ed can
be considered clean by log recovery.
Signed-off-by: Dave Chinner <david@fromorbit.com>
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
To make sure they get properly waited on in sync when I/O is in flight and
we latter need to update the inode size. Requires a new helper to check if an
ioend structure is beyond the current EOF.
Sort out ->sync_fs to not perform a superblock writeback for the wait = 0 case
as that is just an optional first pass and the superblock will be written back
properly in the next call with wait = 1. Instead perform an opportunistic
quota writeback to have less work later. Also remove the freeze special case
as we do a proper wait = 1 call in the freeze code anyway.
Also rename the function to xfs_fs_sync_fs to match the normal naming
convention, update comments and avoid calling into the laptop_mode logic on
an error.
We need to do a synchronous xfs_sync_fsdata to make sure the superblock
actually is on disk when we return.
Also remove SYNC_BDFLUSH flag to xfs_sync_inodes because that particular
flag is never checked.
Move xfs_filestream_flush call later to only release inodes after they
have been written out.
This is picking up on Felix's repost of Dave's patch to implement a
.dirty_inode method. We really need this notification because
the VFS keeps writing directly into the inode structure instead
of going through methods to update this state. In addition to
the long-known atime issue we now also have a caller in VM code
that updates c/mtime that way for shared writeable mmaps. And
I found another one that no one has noticed in practice in the FIFO
code.
So implement ->dirty_inode to set i_update_core whenever the
inode gets externally dirtied, and switch the c/mtime handling to
the same scheme we already use for atime (always picking up
the value from the Linux inode).
Note that this patch also removes the xfs_synchronize_atime call
in xfs_reclaim it was superflous as we already synchronize the time
when writing the inode via the log (xfs_inode_item_format) or the
normal buffers (xfs_iflush_int).
In addition also remove the I_CLEAR check before copying the Linux
timestamps - now that we always have the Linux inode available
we can always use the timestamps in it.
Also switch to just using file_update_time for regular reads/writes -
that will get us all optimization done to it for free and make
sure we notice early when it breaks.
Reviewed-by: Felix Blyakher <felixb@sgi.com>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits)
HWPOISON: Enable error_remove_page on btrfs
HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs
HWPOISON: Add madvise() based injector for hardware poisoned pages v4
HWPOISON: Enable error_remove_page for NFS
HWPOISON: Enable .remove_error_page for migration aware file systems
HWPOISON: The high level memory error handler in the VM v7
HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process
HWPOISON: shmem: call set_page_dirty() with locked page
HWPOISON: Define a new error_remove_page address space op for async truncation
HWPOISON: Add invalidate_inode_page
HWPOISON: Refactor truncate to allow direct truncating of page v2
HWPOISON: check and isolate corrupted free pages v2
HWPOISON: Handle hardware poisoned pages in try_to_unmap
HWPOISON: Use bitmask/action code for try_to_unmap behaviour
HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2
HWPOISON: Add poison check to page fault handling
HWPOISON: Add basic support for poisoned pages in fault handler v3
HWPOISON: Add new SIGBUS error codes for hardware poison signals
HWPOISON: Add support for poison swap entries v2
HWPOISON: Export some rmap vma locking to outside world
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
trivial: fix typo "for for" in multiple files
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Enable removing of corrupted pages through truncation
for a bunch of file systems: ext*, xfs, gfs2, ocfs2, ntfs
These should cover most server needs.
I chose the set of migration aware file systems for this
for now, assuming they have been especially audited.
But in general it should be safe for all file systems
on the data area that support read/write and truncate.
Caveat: the hardware error handler does not take i_mutex
for now before calling the truncate function. Is that ok?
Cc: tytso@mit.edu
Cc: hch@infradead.org
Cc: mfasheh@suse.com
Cc: aia21@cantab.net
Cc: hugh.dickins@tiscali.co.uk
Cc: swhiteho@redhat.com
fs/xfs/linux-2.6/xfs_lrw.c
fix the following 'make includecheck' warning:
fs/xfs/linux-2.6/xfs_iops.c: xfs_acl.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
create_proc_read_entry() is getting deprecated.
Christoph Hellwig says that it is enough for XFS to call
filemap_write_and_wait_range() instead of sync_page_range() because we do
all the metadata syncing when forcing the log.
CC: Felix Blyakher <felixb@sgi.com>
CC: xfs@oss.sgi.com
CC: Christoph Hellwig <hch@lst.de>
We added the ENOSPC handling patch in xfs_create just after it got mered
with xfs_mkdir. Change the log reservation to the variable for either
the create or mkdir value so it does the right thing if get here for creating
a directory.
This avoids an indirect call in the VFS for each path component lookup.
Well, at least as long as you own the directory in question, and the ACL
check is unnecessary.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
If you enable group or project quotas on an XFS file system, then the
mount table presented through /proc/self/mounts erroneously shows
that both options are in effect for the file system. The root of
the problem is some bad logic in the xfs_showargs() function, which
is used to format the file system type-specific options in effect
for a file system.
The problem originated in this GIT commit:
Move platform specific mount option parse out of core XFS code
Date: 11/22/07
Author: Dave Chinner
SHA1 ID: a67d7c5f5d25d0b13a4dfb182697135b014fa478
For XFS quotas, project and group quota management are mutually
exclusive--only one can be in effect at a time. There are two
parts to managing quotas: aggregating usage information; and
enforcing limits. It is possible to have a quota in effect
(aggregating usage) but not enforced.
These features are recorded on an XFS mount point using these flags:
XFS_PQUOTA_ACCT - Project quotas are aggregated
XFS_GQUOTA_ACCT - Group quotas are aggregated
XFS_OQUOTA_ENFD - Project/group quotas are enforced
The code in error is in fs/xfs/linux-2.6/xfs_super.c:
if (mp->m_qflags & (XFS_PQUOTA_ACCT|XFS_OQUOTA_ENFD))
seq_puts(m, "," MNTOPT_PRJQUOTA);
else if (mp->m_qflags & XFS_PQUOTA_ACCT)
seq_puts(m, "," MNTOPT_PQUOTANOENF);
if (mp->m_qflags & (XFS_GQUOTA_ACCT|XFS_OQUOTA_ENFD))
seq_puts(m, "," MNTOPT_GRPQUOTA);
else if (mp->m_qflags & XFS_GQUOTA_ACCT)
seq_puts(m, "," MNTOPT_GQUOTANOENF);
The problem is that XFS_OQUOTA_ENFD will be set in mp->m_qflags
if either group or project quotas are enforced, and as a result
both MNTOPT_PRJQUOTA and MNTOPT_GRPQUOTA will be shown as mount
options.
xfs_inobt_lookup is also used in xfs_itable.c, remove the STATIC modifier
from it's declaration to fix non-debug builds.
Signed-off-by: Felix Blyakher <felixb@sgi.com>
Fix a small typo in the compat ioctl handler that cause the swapext
compat handler to never be called.
Reviewed-by: Torsten Kaiser <just.for.lkml@googlemail.com>
Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com>
xfs_trans_iget is a wrapper for xfs_iget that adds the inode to the
transaction after it is read. Except when the inode already is in the
inode cache, in which case it returns the existing locked inode with
increment lock recursion counts.
Now, no one in the tree every decrements these lock recursion counts,
so any user of this gets a potential double unlock when both the original
owner of the inode and the xfs_trans_iget caller unlock it. When looking
back in a git bisect in the historic XFS tree there was only one place
that decremented these counts, xfs_trans_iput. Introduced in commit
ca25df7a840f426eb566d52667b6950b92bb84b5 by Adam Sweeney in 1993,
and removed in commit 19f899a3ab155ff6a49c0c79b06f2f61059afaf3 by
Steve Lord in 2003. And as long as it didn't slip through git bisects
cracks never actually used in that time frame.
A quick audit of the callers of xfs_trans_iget shows that no caller
really relies on this behaviour fortunately - xfs_ialloc allows this
inode from disk so it must not be there before, and all the RT allocator
routines only every add each RT bitmap inode once.
In addition to removing lots of code and reducing the size of the inode
item this patch also avoids the double inode cache lookup in each
create/mkdir/mknod transaction.
The guarantees for O_SYNC are exactly the same as the ones we need to
make for an fsync call (and given that Linux O_SYNC is O_DSYNC the
equivalent is fdadatasync, but we treat both the same in XFS), except
with a range data writeout. Jan Kara has started unifying these two
path for filesystems using the generic helpers, and I've started to
look at XFS.
The actual transaction commited by xfs_fsync and xfs_write_sync_logforce
has a different transaction number, but actually is exactly the same.
We'll only use the fsync transaction going forward. One major difference
is that xfs_write_sync_logforce never issues a cache flush unless we
commit a transaction causing that as a side-effect, which is an obvious
bug in the O_SYNC handling. Second all the locking and i_update_size
vs i_update_core changes from 978b7237123d007b9fa983af6e0e2fa8f97f9934
never made it to xfs_write_sync_logforce, so we add them back.
To make xfs_fsync easily usable from the O_SYNC path, the filemap_fdatawait
call is moved up to xfs_file_fsync, so that we don't wait on the whole
file after we already waited for our portion in xfs_write.
We'll also use a plain call to filemap_write_and_wait_range instead
of the previous sync_page_rang which did it in two steps including
an half-hearted inode write out that doesn't help us.
Once we're done with this also remove the now useless i_update_size
tracking.
Don't search too far - abort if it is outside a certain radius and simply do
a linear search for the first free inode. In AGs with a million inodes this
can speed up allocation speed by 3-4x.
[hch: ported to the new xfs_ialloc.c world order]
Signed-off-by: Dave Chinner <dgc@sgi.com>
Currenly we have a xfs_inobt_lookup* variant for each comparism direction,
and all these get all three fields of the inobt records passed, while the
common case is just looking for the inode number and we have only marginally
more callers than xfs_inobt_lookup* variants.
So opencode a direct call to xfs_btree_lookup for the single case where we
need all fields, and replace xfs_inobt_lookup* with a xfs_inobt_looku that
just takes the inode number and the direction for all other callers.
Clarify the control flow in xfs_dialloc. Factor out a helper to go to the
next node from the current one and improve the control flow by expanding
composite if statements and using gotos.
The xfs_ialloc_next_rec helper is borrowed from Dave Chinners dynamic
allocation policy patches.
Factor out a common helper from repeated debug checks in xfs_dialloc and
xfs_difree.
[hch: split out from Dave's dynamic allocation policy patches]
Both callers of xfs_inobt_update have the record in form of a
xfs_inobt_rec_incore_t, so just pass a pointer to it instead of the
individual variables.
Most callers of xfs_inobt_get_rec need to fill a xfs_inobt_rec_incore_t, and
those who don't yet are fine with a xfs_inobt_rec_incore_t, instead of the
three individual variables, too. So just change xfs_inobt_get_rec to write
the output into a xfs_inobt_rec_incore_t directly.
Factor out code to initialize new inode clusters into a function of it's own.
This keeps xfs_ialloc_ag_alloc smaller and better structured and enables a
future inode cluster initialization transaction. Also initialize the agno
variable earlier in xfs_ialloc_ag_alloc to avoid repeated byte swaps.
[hch: The original patch is from Dave from his unpublished inode create
transaction patch series, with some modifcations by me to apply stand-alone]
bp was tested for NULL a few lines before, followed by a return, and there
is no intervening modification of its value.
A simplified version of the semantic match that finds this problem is as
follows: (http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x == NULL || ...) { ... when forall
return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
*x == NULL
*x != NULL
// </smpl>
Acked-by: Felix Blyakher <felixb@sgi.com>
Commit a19d9f887d81106d52cacbc9930207b487e07e0e removed the
ino64 option but left the XFS_INO64_OFFSET define it used
in place - just remove it.
CONFIG_XFS_DEBUG builds still need xfs_read_agf to be
non-static, oops.
A lot more functions could be made static, but they need
forward declarations; this does some easy ones, and also
found a few unused functions in the process.
The locking in xfs_iget_cache_hit currently has numerous problems:
- we clear the reclaim tag without i_flags_lock which protects
modifications to it
- we call inode_init_always which can sleep with pag_ici_lock
held (this is oss.sgi.com BZ #819)
- we acquire and drop i_flags_lock a lot and thus provide no
consistency between the various flags we set/clear under it
This patch fixes all that with a major revamp of the locking in
the function. The new version acquires i_flags_lock early and
only drops it once we need to call into inode_init_always or before
calling xfs_ilock.
This patch fixes a bug seen in the wild where we race modifying the
reclaim tag.
