commit a41537e69b4aa43f0fea02498c2595a81267383b upstream.
O_DIRECT flags can be toggeled via fcntl(F_SETFL). But this value checked
twice inside ext4_file_write_iter() and __generic_file_write() which
result in BUG_ON inside ext4_direct_IO.
Let's initialize iocb->private unconditionally.
TESTCASE: xfstest:generic/036 https://patchwork.ozlabs.org/patch/402445/
#TYPICAL STACK TRACE:
kernel BUG at fs/ext4/inode.c:2960!
invalid opcode: 0000 [#1] SMP
Modules linked in: brd iTCO_wdt lpc_ich mfd_core igb ptp dm_mirror dm_region_hash dm_log dm_mod
CPU: 6 PID: 5505 Comm: aio-dio-fcntl-r Not tainted 3.17.0-rc2-00176-gff5c017 #161
Hardware name: Intel Corporation W2600CR/W2600CR, BIOS SE5C600.86B.99.99.x028.061320111235 06/13/2011
task: ffff88080e95a7c0 ti: ffff88080f908000 task.ti: ffff88080f908000
RIP: 0010:[<ffffffff811fabf2>] [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP: 0018:ffff88080f90bb58 EFLAGS: 00010246
RAX: 0000000000000400 RBX: ffff88080fdb2a28 RCX: 00000000a802c818
RDX: 0000040000080000 RSI: ffff88080d8aeb80 RDI: 0000000000000001
RBP: ffff88080f90bbc8 R08: 0000000000000000 R09: 0000000000001581
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88080d8aeb80
R13: ffff88080f90bbf8 R14: ffff88080fdb28c8 R15: ffff88080fdb2a28
FS: 00007f23b2055700(0000) GS:ffff880818400000(0000) knlGS:0000000000000000
CR2: 00007f23b2045000 CR3: 000000080cedf000 CR4: 00000000000407e0
Stack:
ffff88080f90bb98 0000000000000000 7ffffffffffffffe ffff88080fdb2c30
0000000000000200 0000000000000200 0000000000000001 0000000000000200
ffff88080f90bbc8 ffff88080fdb2c30 ffff88080f90be08 0000000000000200
Call Trace:
[<ffffffff8112ca9d>] generic_file_direct_write+0xed/0x180
[<ffffffff8112f2b2>] __generic_file_write_iter+0x222/0x370
[<ffffffff811f495b>] ext4_file_write_iter+0x34b/0x400
[<ffffffff811bd709>] ? aio_run_iocb+0x239/0x410
[<ffffffff810990e5>] ? local_clock+0x25/0x30
[<ffffffff810abd94>] ? __lock_acquire+0x274/0x700
[<ffffffff811f4610>] ? ext4_unwritten_wait+0xb0/0xb0
[<ffffffff811bd756>] aio_run_iocb+0x286/0x410
[<ffffffff810ac359>] ? lock_release_holdtime+0x29/0x190
[<ffffffff811bc05b>] ? lookup_ioctx+0x4b/0xf0
[<ffffffff811bde3b>] do_io_submit+0x55b/0x740
[<ffffffff811bdcaa>] ? do_io_submit+0x3ca/0x740
[<ffffffff811be030>] SyS_io_submit+0x10/0x20
[<ffffffff815ce192>] system_call_fastpath+0x16/0x1b
Code: 01 48 8b 80 f0 01 00 00 48 8b 18 49 8b 45 10 0f 85 f1 01 00 00 48 03 45 c8 48 3b 43 48 0f 8f e3 01 00 00 49 83 7c
24 18 00 75 04 <0f> 0b eb fe f0 ff 83 ec 01 00 00 49 8b 44 24 18 8b 00 85 c0 89
RIP [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP <ffff88080f90bb58>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
[hujianyang: Backported to 3.10
- Move initialization of iocb->private to ext4_file_write() as we don't
have ext4_file_write_iter(), which is introduced by commit 9b884164.
- Adjust context to make 'overwrite' changes apply to ext4_file_dio_write()
as ext4_file_dio_write() is not move into ext4_file_write()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 7ef3ff2fea8bf5e4a21cef47ad87710a3d0fdb52 upstream.
Nilfs2 eventually hangs in a stress test with fsstress program. This
issue was caused by the following deadlock over I_SYNC flag between
nilfs_segctor_thread() and writeback_sb_inodes():
nilfs_segctor_thread_construct()
nilfs_segctor_unlock()
nilfs_dispose_list()
iput()
iput_final()
evict()
inode_wait_for_writeback() * wait for I_SYNC flag
* set I_SYNC flag on inode->i_state
__writeback_single_inode()
do_writepages()
nilfs_writepages()
nilfs_construct_dsync_segment()
nilfs_segctor_sync()
* wait for completion of segment constructor
inode_sync_complete()
* clear I_SYNC flag after __writeback_single_inode() completed
writeback_sb_inodes() calls do_writepages() for dirty inodes after
setting I_SYNC flag on inode->i_state. do_writepages() in turn calls
nilfs_writepages(), which can run segment constructor and wait for its
completion. On the other hand, segment constructor calls iput(), which
can call evict() and wait for the I_SYNC flag on
inode_wait_for_writeback().
Since segment constructor doesn't know when I_SYNC will be set, it
cannot know whether iput() will block or not unless inode->i_nlink has a
non-zero count. We can prevent evict() from being called in iput() by
implementing sop->drop_inode(), but it's not preferable to leave inodes
with i_nlink == 0 for long periods because it even defers file
truncation and inode deallocation. So, this instead resolves the
deadlock by calling iput() asynchronously with a workqueue for inodes
with i_nlink == 0.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 0405a5cec3406f19e69da07c8111a6bf1088ac29 upstream.
For persistent RAM outside of main memory, the memory may have limitations
on supported accesses. For internal RAM on highbank platform exclusive
accesses are not supported and will hang the system. So atomic_cmpxchg
cannot be used. This commit uses spinlock protection for buffer size and
start updates on ioremapped regions instead.
Acked-by: Anton Vorontsov <anton@enomsg.org>
Signed-off-by: Tony Luck <tony.luck@intel.com>
[hkp: Backported to 3.10: adjust context]
Signed-off-by: HuKeping <hukeping@huawei.com>
commit b0aa931fb84431394d995472d0af2a6c2b61064d upstream.
ramoops_get_next_prz get the prz according the paramters. If it get a
uninitialized prz, access its members by following persistent_ram_old_size(prz)
will cause a NULL pointer crash.
Ex: if ftrace_size is 0, fprz will be NULL.
Fix it by return NULL in advance.
Signed-off-by: Liu ShuoX <shuox.liu@intel.com>
Cc: HuKeping <hukeping@huawei.com>
commit aa9a4a1edfbd3d223af01db833da2f07850bc655 upstream.
In ramoops_pstore_read, a valid prz pointer with zero size buffer will
break traverse of all persistent ram buffers. The latter buffer might be
lost.
Cc: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
Cc: Colin Cross <ccross@android.com>
commit 57fd835385a043577457a385f28c08be693991bf upstream.
*_read_cnt in ramoops_context need to be cleared during pstore ->open to
support mutli times getting the records. The patch added missed
ftrace_read_cnt clearing and removed duplicate clearing in ramoops_probe.
commit c39524e6744284452ef45480d3153bec28960c32 upstream.
d_alloc_name() returns NULL on error. Also I changed the error code
from -ENOSPC to -ENOMEM to reflect that we were short on RAM not disk
space.
commit bf2883339a33b7544b92ea465b90c3de55082032 upstream.
pstore_erase is used to erase the record from the persistent store.
So if a driver has not defined pstore_erase callback return
-EPERM instead of unlinking a file as deleting the file without
erasing its record in persistent store will give a wrong impression
to customers.
Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com>
commit 3175e1dcec40fab1a444c010087f2068b6b04732 upstream.
If we start state recovery on a client that failed to initialise correctly,
then we are very likely to Oops.
Reported-by: "Mkrtchyan, Tigran" <tigran.mkrtchyan@desy.de>
Link: http://lkml.kernel.org/r/130621862.279655.1421851650684.JavaMail.zimbra@desy.de
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit ee8a1a8b160a87dc3a9c81a86796aa4db85ea815 upstream.
We only support swap file calling nfs_direct_IO. However, application
might be able to get to nfs_direct_IO if it toggles O_DIRECT flag
during IO and it can deadlock because we grab inode->i_mutex in
nfs_file_direct_write(). So return 0 for such case. Then the generic
layer will fall back to buffer IO.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
commit 7d7345322d60edb0fa49a64a89b31360f01d09cb upstream.
reaim workfile.dbase test easily triggers warning in
ext4_da_update_reserve_space():
EXT4-fs warning (device ram0): ext4_da_update_reserve_space:365:
ino 12, allocated 1 with only 0 reserved metadata blocks (releasing 1
blocks with reserved 9 data blocks)
The problem is that (one of) tests creates file and then randomly writes
to it with O_SYNC. That results in writing back pages of the file in
random order so we create extents for written blocks say 0, 2, 4, 6, 8
- this last allocation also allocates new block for extents. Then we
writeout block 1 so we have extents 0-2, 4, 6, 8 and we release
indirect extent block because extents fit in the inode again. Then we
writeout block 10 and we need to allocate indirect extent block again
which triggers the warning because we don't have the reservation
anymore.
Fix the problem by giving back freed metadata blocks resulting from
extent merging into inode's reservation pool.
Cc: Josh Hunt <johunt@akamai.com>
commit 1c8924eb106c1ac755d5d35ce9b3ff42e89e2511 upstream.
ext4 needs to convert allocated (metadata) blocks back into blocks
reserved for delayed allocation. Add functions into quota code for
supporting such operation.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 6424babfd68dd8a83d9c60a5242d27038856599f upstream.
During file system stress testing on 3.10 and 3.12 based kernels, the
umount command occasionally hung in fsnotify_unmount_inodes in the
section of code:
spin_lock(&inode->i_lock);
if (inode->i_state & (I_FREEING|I_WILL_FREE|I_NEW)) {
spin_unlock(&inode->i_lock);
continue;
As this section of code holds the global inode_sb_list_lock, eventually
the system hangs trying to acquire the lock.
Multiple crash dumps showed:
The inode->i_state == 0x60 and i_count == 0 and i_sb_list would point
back at itself. As this is not the value of list upon entry to the
function, the kernel never exits the loop.
To help narrow down problem, the call to list_del_init in
inode_sb_list_del was changed to list_del. This poisons the pointers in
the i_sb_list and causes a kernel to panic if it transverse a freed
inode.
Subsequent stress testing paniced in fsnotify_unmount_inodes at the
bottom of the list_for_each_entry_safe loop showing next_i had become
free.
We believe the root cause of the problem is that next_i is being freed
during the window of time that the list_for_each_entry_safe loop
temporarily releases inode_sb_list_lock to call fsnotify and
fsnotify_inode_delete.
The code in fsnotify_unmount_inodes attempts to prevent the freeing of
inode and next_i by calling __iget. However, the code doesn't do the
__iget call on next_i
if i_count == 0 or
if i_state & (I_FREEING | I_WILL_FREE)
The patch addresses this issue by advancing next_i in the above two cases
until we either find a next_i which we can __iget or we reach the end of
the list. This makes the handling of next_i more closely match the
handling of the variable "inode."
The time to reproduce the hang is highly variable (from hours to days.) We
ran the stress test on a 3.10 kernel with the proposed patch for a week
without failure.
During list_for_each_entry_safe, next_i is becoming free causing
the loop to never terminate. Advance next_i in those cases where
__iget is not done.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hp.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Ken Helias <kenhelias@firemail.de>
Cc: Jan Kara <jack@suse.cz>
commit 06bed7d18c2c07b3e3eeadf4bd357f6e806618cc upstream.
This commit fixes a race whereby nlmclnt_init() first starts the lockd
daemon, and then calls nlm_bind_host() with the expectation that
nlmsvc_timeout has already been initialised. Unfortunately, there is no
no synchronisation between lockd() and lockd_up() to guarantee that this
is the case.
Fix is to move the initialisation of nlmsvc_timeout into lockd_create_svc
Fixes: 9a1b6bf818e74 ("LOCKD: Don't call utsname()->nodename...")
Cc: Bruce Fields <bfields@fieldses.org>
Cc: stable@vger.kernel.org # 3.10.x
commit 1fc0703af3143914a389bfa081c7acb09502ed5d upstream.
Currently, our trunking code will check for session trunking, but will
fail to detect client id trunking. This is a problem, because it means
that the client will fail to recognise that the two connections represent
shared state, even if they do not permit a shared session.
By removing the check for the server minor id, and only checking the
major id, we will end up doing the right thing in both cases: we close
down the new nfs_client and fall back to using the existing one.
Fixes: 05f4c350ee02e ("NFS: Discover NFSv4 server trunking when mounting")
Cc: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
commit 6f8960541b1eb6054a642da48daae2320fddba93 upstream.
Commit 1d52c78afbb (Btrfs: try not to ENOSPC on log replay) added a
check to skip delayed inode updates during log replay because it
confuses the enospc code. But the delayed processing will end up
ignoring delayed refs from log replay because the inode itself wasn't
put through the delayed code.
This can end up triggering a warning at commit time:
WARNING: CPU: 2 PID: 778 at fs/btrfs/delayed-inode.c:1410 btrfs_assert_delayed_root_empty+0x32/0x34()
Which is repeated for each commit because we never process the delayed
inode ref update.
The fix used here is to change btrfs_delayed_delete_inode_ref to return
an error if we're currently in log replay. The caller will do the ref
deletion immediately and everything will work properly.
Signed-off-by: Chris Mason <clm@fb.com>
commit 705304a863cc41585508c0f476f6d3ec28cf7e00 upstream.
Same story as in commit 41080b5a2401 ("nfsd race fixes: ext2") (similar
ext2 fix) except that nilfs2 needs to use insert_inode_locked4() instead
of insert_inode_locked() and a bug of a check for dead inodes needs to
be fixed.
If nilfs_iget() is called from nfsd after nilfs_new_inode() calls
insert_inode_locked4(), nilfs_iget() will wait for unlock_new_inode() at
the end of nilfs_mkdir()/nilfs_create()/etc to unlock the inode.
If nilfs_iget() is called before nilfs_new_inode() calls
insert_inode_locked4(), it will create an in-core inode and read its
data from the on-disk inode. But, nilfs_iget() will find i_nlink equals
zero and fail at nilfs_read_inode_common(), which will lead it to call
iget_failed() and cleanly fail.
However, this sanity check doesn't work as expected for reused on-disk
inodes because they leave a non-zero value in i_mode field and it
hinders the test of i_nlink. This patch also fixes the issue by
removing the test on i_mode that nilfs2 doesn't need.
commit 5a64e56976f1ba98743e1678c0029a98e9034c81 upstream.
Fix a bug where nfsd4_encode_components_esc() includes the esc_end char as
an additional string encoding.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Fixes: e7a0444aef4a "nfsd: add IPv6 addr escaping to fs_location hosts"
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit ef17af2a817db97d42dd2ec0a425231748e23dbc upstream.
Bugs similar to the one in acbbe6fbb240 (kcmp: fix standard comparison
bug) are in rich supply.
In this variant, the problem is that struct xdr_netobj::len has type
unsigned int, so the expression o1->len - o2->len _also_ has type
unsigned int; it has completely well-defined semantics, and the result
is some non-negative integer, which is always representable in a long
long. But this means that if the conditional triggers, we are
guaranteed to return a positive value from compare_blob.
In this case it could be fixed by
- res = o1->len - o2->len;
+ res = (long long)o1->len - (long long)o2->len;
but I'd rather eliminate the usually broken 'return a - b;' idiom.
Reviewed-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit 9c6ac78eb3521c5937b2dd8a7d1b300f41092f45 upstream.
After invoking ->dirty_inode(), __mark_inode_dirty() does smp_mb() and
tests inode->i_state locklessly to see whether it already has all the
necessary I_DIRTY bits set. The comment above the barrier doesn't
contain any useful information - memory barriers can't ensure "changes
are seen by all cpus" by itself.
And it sure enough was broken. Please consider the following
scenario.
CPU 0 CPU 1
enters __writeback_single_inode()
grabs inode->i_lock
tests PAGECACHE_TAG_DIRTY which is clear
enters __set_page_dirty()
grabs mapping->tree_lock
sets PAGECACHE_TAG_DIRTY
releases mapping->tree_lock
leaves __set_page_dirty()
enters __mark_inode_dirty()
smp_mb()
sees I_DIRTY_PAGES set
leaves __mark_inode_dirty()
clears I_DIRTY_PAGES
releases inode->i_lock
Now @inode has dirty pages w/ I_DIRTY_PAGES clear. This doesn't seem
to lead to an immediately critical problem because requeue_inode()
later checks PAGECACHE_TAG_DIRTY instead of I_DIRTY_PAGES when
deciding whether the inode needs to be requeued for IO and there are
enough unintentional memory barriers inbetween, so while the inode
ends up with inconsistent I_DIRTY_PAGES flag, it doesn't fall off the
IO list.
The lack of explicit barrier may also theoretically affect the other
I_DIRTY bits which deal with metadata dirtiness. There is no
guarantee that a strong enough barrier exists between
I_DIRTY_[DATA]SYNC clearing and write_inode() writing out the dirtied
inode. Filesystem inode writeout path likely has enough stuff which
can behave as full barrier but it's theoretically possible that the
writeout may not see all the updates from ->dirty_inode().
Fix it by adding an explicit smp_mb() after I_DIRTY clearing. Note
that I_DIRTY_PAGES needs a special treatment as it always needs to be
cleared to be interlocked with the lockless test on
__mark_inode_dirty() side. It's cleared unconditionally and
reinstated after smp_mb() if the mapping still has dirty pages.
Also add comments explaining how and why the barriers are paired.
Lightly tested.
Cc: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Olof Johansson <olof@lixom.net>
commit 7ae9cb81933515dc7db1aa3c47ef7653717e3090 upstream.
Currently trying to use pstore on at least ARMs can hang as we're
mapping the peristent RAM with pgprot_noncached().
On ARMs, pgprot_noncached() will actually make the memory strongly
ordered, and as the atomic operations pstore uses are implementation
defined for strongly ordered memory, they may not work. So basically
atomic operations have undefined behavior on ARM for device or strongly
ordered memory types.
Let's fix the issue by using write-combine variants for mappings. This
corresponds to normal, non-cacheable memory on ARM. For many other
architectures, this change does not change the mapping type as by
default we have:
#define pgprot_writecombine pgprot_noncached
The reason why pgprot_noncached() was originaly used for pstore
is because Colin Cross <ccross@android.com> had observed lost
debug prints right before a device hanging write operation on some
systems. For the platforms supporting pgprot_noncached(), we can
add a an optional configuration option to support that. But let's
get pstore working first before adding new features.
Cc: Anton Vorontsov <cbouatmailru@gmail.com>
[tony@atomide.com: updated description]
commit 136f49b9171074872f2a14ad0ab10486d1ba13ca upstream.
For buffer write, page lock will be got in write_begin and released in
write_end, in ocfs2_write_end_nolock(), before it unlock the page in
ocfs2_free_write_ctxt(), it calls ocfs2_run_deallocs(), this will ask
for the read lock of journal->j_trans_barrier. Holding page lock and
ask for journal->j_trans_barrier breaks the locking order.
This will cause a deadlock with journal commit threads, ocfs2cmt will
get write lock of journal->j_trans_barrier first, then it wakes up
kjournald2 to do the commit work, at last it waits until done. To
commit journal, kjournald2 needs flushing data first, it needs get the
cache page lock.
Since some ocfs2 cluster locks are holding by write process, this
deadlock may hung the whole cluster.
unlock pages before ocfs2_run_deallocs() can fix the locking order, also
put unlock before ocfs2_commit_trans() to make page lock is unlocked
before j_trans_barrier to preserve unlocking order.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit 678886bdc6378c1cbd5072da2c5a3035000214e3 upstream.
When we abort a transaction we iterate over all the ranges marked as dirty
in fs_info->freed_extents[0] and fs_info->freed_extents[1], clear them
from those trees, add them back (unpin) to the free space caches and, if
the fs was mounted with "-o discard", perform a discard on those regions.
Also, after adding the regions to the free space caches, a fitrim ioctl call
can see those ranges in a block group's free space cache and perform a discard
on the ranges, so the same issue can happen without "-o discard" as well.
This causes corruption, affecting one or multiple btree nodes (in the worst
case leaving the fs unmountable) because some of those ranges (the ones in
the fs_info->pinned_extents tree) correspond to btree nodes/leafs that are
referred by the last committed super block - breaking the rule that anything
that was committed by a transaction is untouched until the next transaction
commits successfully.
I ran into this while running in a loop (for several hours) the fstest that
I recently submitted:
[PATCH] fstests: add btrfs test to stress chunk allocation/removal and fstrim
The corruption always happened when a transaction aborted and then fsck complained
like this:
_check_btrfs_filesystem: filesystem on /dev/sdc is inconsistent
*** fsck.btrfs output ***
Check tree block failed, want=94945280, have=0
read block failed check_tree_block
Couldn't open file system
In this case 94945280 corresponded to the root of a tree.
Using frace what I observed was the following sequence of steps happened:
1) transaction N started, fs_info->pinned_extents pointed to
fs_info->freed_extents[0];
2) node/eb 94945280 is created;
3) eb is persisted to disk;
4) transaction N commit starts, fs_info->pinned_extents now points to
fs_info->freed_extents[1], and transaction N completes;
5) transaction N + 1 starts;
6) eb is COWed, and btrfs_free_tree_block() called for this eb;
7) eb range (94945280 to 94945280 + 16Kb) is added to
fs_info->pinned_extents (fs_info->freed_extents[1]);
8) Something goes wrong in transaction N + 1, like hitting ENOSPC
for example, and the transaction is aborted, turning the fs into
readonly mode. The stack trace I got for example:
[112065.253935] [<ffffffff8140c7b6>] dump_stack+0x4d/0x66
[112065.254271] [<ffffffff81042984>] warn_slowpath_common+0x7f/0x98
[112065.254567] [<ffffffffa0325990>] ? __btrfs_abort_transaction+0x50/0x10b [btrfs]
[112065.261674] [<ffffffff810429e5>] warn_slowpath_fmt+0x48/0x50
[112065.261922] [<ffffffffa032949e>] ? btrfs_free_path+0x26/0x29 [btrfs]
[112065.262211] [<ffffffffa0325990>] __btrfs_abort_transaction+0x50/0x10b [btrfs]
[112065.262545] [<ffffffffa036b1d6>] btrfs_remove_chunk+0x537/0x58b [btrfs]
[112065.262771] [<ffffffffa033840f>] btrfs_delete_unused_bgs+0x1de/0x21b [btrfs]
[112065.263105] [<ffffffffa0343106>] cleaner_kthread+0x100/0x12f [btrfs]
[112065.264493] ---[ end trace dd7903a975a31a08 ]---
[112065.264673] BTRFS: error (device sdc) in btrfs_remove_chunk:2625: errno=-28 No space left
[112065.264997] BTRFS info (device sdc): forced readonly
9) The clear kthread sees that the BTRFS_FS_STATE_ERROR bit is set in
fs_info->fs_state and calls btrfs_cleanup_transaction(), which in
turn calls btrfs_destroy_pinned_extent();
10) Then btrfs_destroy_pinned_extent() iterates over all the ranges
marked as dirty in fs_info->freed_extents[], and for each one
it calls discard, if the fs was mounted with "-o discard", and
adds the range to the free space cache of the respective block
group;
11) btrfs_trim_block_group(), invoked from the fitrim ioctl code path,
sees the free space entries and performs a discard;
12) After an umount and mount (or fsck), our eb's location on disk was full
of zeroes, and it should have been untouched, because it was marked as
dirty in the fs_info->pinned_extents tree, and therefore used by the
trees that the last committed superblock points to.
Fix this by not performing a discard and not adding the ranges to the free space
caches - it's useless from this point since the fs is now in readonly mode and
we won't write free space caches to disk anymore (otherwise we would leak space)
nor any new superblock. By not adding the ranges to the free space caches, it
prevents other code paths from allocating that space and write to it as well,
therefore being safer and simpler.
This isn't a new problem, as it's been present since 2011 (git commit
acce952b0263825da32cf10489413dec78053347).
Signed-off-by: Filipe Manana <fdmanana@suse.com>
commit a28046956c71985046474283fa3bcd256915fb72 upstream.
We use the modified list to keep track of which extents have been modified so we
know which ones are candidates for logging at fsync() time. Newly modified
extents are added to the list at modification time, around the same time the
ordered extent is created. We do this so that we don't have to wait for ordered
extents to complete before we know what we need to log. The problem is when
something like this happens
log extent 0-4k on inode 1
copy csum for 0-4k from ordered extent into log
sync log
commit transaction
log some other extent on inode 1
ordered extent for 0-4k completes and adds itself onto modified list again
log changed extents
see ordered extent for 0-4k has already been logged
at this point we assume the csum has been copied
sync log
crash
On replay we will see the extent 0-4k in the log, drop the original 0-4k extent
which is the same one that we are replaying which also drops the csum, and then
we won't find the csum in the log for that bytenr. This of course causes us to
have errors about not having csums for certain ranges of our inode. So remove
the modified list manipulation in unpin_extent_cache, any modified extents
should have been added well before now, and we don't want them re-logged. This
fixes my test that I could reliably reproduce this problem with. Thanks,
Signed-off-by: Josef Bacik <jbacik@fb.com>
commit 942080643bce061c3dd9d5718d3b745dcb39a8bc upstream.
Dmitry Chernenkov used KASAN to discover that eCryptfs writes past the
end of the allocated buffer during encrypted filename decoding. This
fix corrects the issue by getting rid of the unnecessary 0 write when
the current bit offset is 2.
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
Reported-by: Dmitry Chernenkov <dmitryc@google.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit 332b122d39c9cbff8b799007a825d94b2e7c12f2 upstream.
The ecryptfs_encrypted_view mount option greatly changes the
functionality of an eCryptfs mount. Instead of encrypting and decrypting
lower files, it provides a unified view of the encrypted files in the
lower filesystem. The presence of the ecryptfs_encrypted_view mount
option is intended to force a read-only mount and modifying files is not
supported when the feature is in use. See the following commit for more
information:
e77a56d [PATCH] eCryptfs: Encrypted passthrough
This patch forces the mount to be read-only when the
ecryptfs_encrypted_view mount option is specified by setting the
MS_RDONLY flag on the superblock. Additionally, this patch removes some
broken logic in ecryptfs_open() that attempted to prevent modifications
of files when the encrypted view feature was in use. The check in
ecryptfs_open() was not sufficient to prevent file modifications using
system calls that do not operate on a file descriptor.
Reported-by: Priya Bansal <p.bansal@samsung.com>
commit a1d47b262952a45aae62bd49cfaf33dd76c11a2c upstream.
UDF specification allows arbitrarily large symlinks. However we support
only symlinks at most one block large. Check the length of the symlink
so that we don't access memory beyond end of the symlink block.
Reported-by: Carl Henrik Lunde <chlunde@gmail.com>
commit a682e9c28cac152e6e54c39efcf046e0c8cfcf63 upstream.
If some error happens in NCP_IOC_SETROOT ioctl, the appropriate error
return value is then (in most cases) just overwritten before we return.
This can result in reporting success to userspace although error happened.
This bug was introduced by commit 2e54eb96e2c8 ("BKL: Remove BKL from
ncpfs"). Propagate the errors correctly.
Coverity id: 1226925.
Fixes: 2e54eb96e2c80 ("BKL: Remove BKL from ncpfs")
Cc: Petr Vandrovec <petr@vandrovec.name>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit b2f5d4dc38e034eecb7987e513255265ff9aa1cf upstream.
Forced unmount affects not just the mount namespace but the underlying
superblock as well. Restrict forced unmount to the global root user
for now. Otherwise it becomes possible a user in a less privileged
mount namespace to force the shutdown of a superblock of a filesystem
in a more privileged mount namespace, allowing a DOS attack on root.
commit 3e1866410f11356a9fd869beb3e95983dc79c067 upstream.
Now that remount is properly enforcing the rule that you can't remove
nodev at least sandstorm.io is breaking when performing a remount.
It turns out that there is an easy intuitive solution implicitly
add nodev on remount when nodev was implicitly added on mount.
Tested-by: Cedric Bosdonnat <cbosdonnat@suse.com>
Tested-by: Richard Weinberger <richard@nod.at>
commit 4e2024624e678f0ebb916e6192bd23c1f9fdf696 upstream.
We didn't check length of rock ridge ER records before printing them.
Thus corrupted isofs image can cause us to access and print some memory
behind the buffer with obvious consequences.
Reported-and-tested-by: Carl Henrik Lunde <chlunde@ping.uio.no>
commit 4bd5a980de87d2b5af417485bde97b8eb3d6cf6a upstream.
nfs4_layoutget_release() drops layout hdr refcnt. Grab the refcnt
early so that it is safe to call .release in case nfs4_alloc_pages
fails.
Fixes: a47970ff78147 ("NFSv4.1: Hold reference to layout hdr in layoutget")
commit f54e18f1b831c92f6512d2eedb224cd63d607d3d upstream.
Rock Ridge extensions define so called Continuation Entries (CE) which
define where is further space with Rock Ridge data. Corrupted isofs
image can contain arbitrarily long chain of these, including a one
containing loop and thus causing kernel to end in an infinite loop when
traversing these entries.
Limit the traversal to 32 entries which should be more than enough space
to store all the Rock Ridge data.
Reported-by: P J P <ppandit@redhat.com>
commit df4e7ac0bb70abc97fbfd9ef09671fc084b3f9db upstream.
ext2_quota_write() doesn't properly setup bh it passes to
ext2_get_block() and thus we hit assertion BUG_ON(maxblocks == 0) in
ext2_get_blocks() (or we could actually ask for mapping arbitrary number
of blocks depending on whatever value was on stack).
Fix ext2_quota_write() to properly fill in number of blocks to map.
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Christoph Hellwig <hch@infradead.org>
BugLink: http://bugs.launchpad.net/bugs/1348670
Fix regression introduced in pre-3.14 kernels by cherry-picking
aa07c713ecfc0522916f3cd57ac628ea6127c0ec
(NFSD: Call ->set_acl with a NULL ACL structure if no entries).
The affected code was removed in 3.14 by commit
4ac7249ea5a0ceef9f8269f63f33cc873c3fac61
(nfsd: use get_acl and ->set_acl).
The ->set_acl methods are already able to cope with a NULL argument.
Signed-off-by: Sergio Gelato <Sergio.Gelato@astro.su.se>
[bwh: Rewrite the subject]
Cc: Moritz Mühlenhoff <muehlenhoff@univention.de>
commit bf7bd3e98be5c74813bee6ad496139fb0a011b3b upstream.
This fixes a regression from 68a3396178e6688ad7367202cdf0af8ed03c8727
"nfsd4: shut down more of delegation earlier".
After that commit, nfs4_set_delegation() failures result in
nfs4_put_delegation being called, but nfs4_put_delegation doesn't free
the nfs4_file that has already been set by alloc_init_deleg().
This can result in an oops on later unmounting the exported filesystem.
Note also delaying the fi_had_conflict check we're able to return a
better error (hence give 4.1 clients a better idea why the delegation
failed; though note CONFLICT isn't an exact match here, as that's
supposed to indicate a current conflict, but all we know here is that
there was one recently).
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
[tuomasjjrasanen: backported to 3.10
Conflicts fs/nfsd/nfs4state.c:
Delegation type flags have been removed from upstream code. In 3.10-series,
they still exists and therefore the commit caused few conflicts in function
signatures.
Signed-off-by: Tuomas Räsänen <tuomasjjrasanen@opinsys.fi>
commit c6c15e1ed303ffc47e696ea1c9a9df1761c1f603 upstream.
The currect code for nfsd41_cb_get_slot() and nfsd4_cb_done() has no
locking in order to guarantee atomicity, and so allows for races of
the form.
Task 1 Task 2
if (test_and_set_bit(0) != 0) {
clear_bit(0)
rpc_wake_up_next(queue)
rpc_sleep_on(queue)
return false;
This patch breaks the race condition by adding a retest of the bit
after the call to rpc_sleep_on().
commit 869f9dfa4d6d57b79e0afc3af14772c2a023eeb1 upstream.
Any attempt to call nfs_remove_bad_delegation() while a delegation is being
returned is currently a no-op. This means that we can end up looping
forever in nfs_end_delegation_return() if something causes the delegation
to be revoked.
This patch adds a mechanism whereby the state recovery code can communicate
to the delegation return code that the delegation is no longer valid and
that it should not be used when reclaiming state.
It also changes the return value for nfs4_handle_delegation_recall_error()
to ensure that nfs_end_delegation_return() does not reattempt the lock
reclaim before state recovery is done.
http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com
commit 16caf5b6101d03335b386e77e9e14136f989be87 upstream.
Variable 'err' needn't be initialized when nfs_getattr() uses it to
check whether it should call generic_fillattr() or not. That can result
in spurious error returns. Initialize 'err' properly.
commit f8ebf7a8ca35dde321f0cd385fee6f1950609367 upstream.
If state recovery failed, then we should not attempt to reclaim delegated
state.
commit 4dfd4f7af0afd201706ad186352ca423b0f17d4b upstream.
NFSv4.0 does not have TEST_STATEID/FREE_STATEID functionality, so
unlike NFSv4.1, the recovery procedure when stateids have expired or
have been revoked requires us to just forget the delegation.
commit ece9c72accdc45c3a9484dacb1125ce572647288 upstream.
Priority of a merged request is computed by ioprio_best(). If one of the
requests has undefined priority (IOPRIO_CLASS_NONE) and another request
has priority from IOPRIO_CLASS_BE, the function will return the
undefined priority which is wrong. Fix the function to properly return
priority of a request with the defined priority.
Fixes: d58cdfb89ce0c6bd5f81ae931a984ef298dbda20
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit 8c393f9a721c30a030049a680e1bf896669bb279 upstream.
For pNFS direct writes, layout driver may dynamically allocate ds_cinfo.buckets.
So we need to take care to free them when freeing dreq.
Ideally this needs to be done inside layout driver where ds_cinfo.buckets
are allocated. But buckets are attached to dreq and reused across LD IO iterations.
So I feel it's OK to free them in the generic layer.
commit 6e5aafb27419f32575b27ef9d6a31e5d54661aca upstream.
If we hit any errors in btrfs_lookup_csums_range, we'll loop through all
the csums we allocate and free them. But the code was using list_entry
incorrectly, and ended up trying to free the on-stack list_head instead.
This bug came from commit 0678b6185
btrfs: Don't BUG_ON kzalloc error in btrfs_lookup_csums_range()
Reported-by: Erik Berg <btrfs@slipsprogrammoer.no>
commit 474d2605d119479e5aa050f738632e63589d4bb5 upstream.
Due to a switched left and right side of an assignment,
dquot_writeback_dquots() never returned error. This could result in
errors during quota writeback to not be reported to userspace properly.
Fix it.
Coverity-id: 1226884
commit 7938db449bbc55bbeb164bec7af406212e7e98f1 upstream.
The check whether quota format is set even though there are no
quota files with journalled quota is pointless and it actually
makes it impossible to turn off journalled quotas (as there's
no way to unset journalled quota format). Just remove the check.
commit 51904b08072a8bf2b9ed74d1bd7a5300a614471d upstream.
Unknown operation numbers are caught in nfsd4_decode_compound() which
sets op->opnum to OP_ILLEGAL and op->status to nfserr_op_illegal. The
error causes the main loop in nfsd4_proc_compound() to skip most
processing. But nfsd4_proc_compound also peeks ahead at the next
operation in one case and doesn't take similar precautions there.
commit 599a9b77ab289d85c2d5c8607624efbe1f552b0f upstream.
When we fail to load block bitmap in __ext4_new_inode() we will
dereference NULL pointer in ext4_journal_get_write_access(). So check
for error from ext4_read_block_bitmap().
Coverity-id: 989065
