commit f01d1d546abb2f4028b5299092f529eefb01253a upstream.
lseek() further than length of the file will leave stale ->index
(second-to-last during iteration). Next seq_read() will not notice
that ->f_pos is big enough to return 0, but will print last item
as if ->f_pos is pointing to it.
Introduced in commit cb510b8172602a66467f3551b4be1911f5a7c8c2
aka "seq_file: more atomicity in traverse()".
commit 33da8892a2f9e7d4b2d9a35fc80833ba2d2b1aa6 upstream.
In 2.6.25 some /proc files were converted to use the seq_file
infrastructure. But seq_files do not correctly support pread(), which
broke some usersapce applications.
To handle pread correctly we can't assume that f_pos is where we left it
in seq_read. So move traverse() so that we can eventually use it in
seq_read and do thus some day support pread().
Signed-off-by: Eric Biederman <ebiederm@xmission.com>
Cc: Paul Turner <pjt@google.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 20d5a39929232a715f29e6cb7e3f0d0c790f41eb upstream.
dlm_posix_get fills out the relevant fields in the file_lock before
returning when there is a lock conflict, but doesn't clean out any of
the other fields in the file_lock.
When nfsd does a NFSv4 lockt call, it sets the fl_lmops to
nfsd_posix_mng_ops before calling the lower fs. When the lock comes back
after testing a lock on GFS2, it still has that field set. This confuses
nfsd into thinking that the file_lock is a nfsd4 lock.
Fix this by making DLM reinitialize the file_lock before copying the
fields from the conflicting lock.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: David Teigland <teigland@redhat.com>
commit 55ef1274dddd4de387c54d110e354ffbb6cdc706 upstream.
Since nfsv4 allows LOCKT without an open, but the ->lock() method is a
file method, we fake up a struct file in the nfsv4 code with just the
fields we need initialized. But we forgot to initialize the file
operations, with the result that LOCKT never results in a call to the
filesystem's ->lock() method (if it exists).
We could just add that one more initialization. But this hack of faking
up a struct file with only some fields initialized seems the kind of
thing that might cause more problems in the future. We should either do
an open and get a real struct file, or make lock-testing an inode (not a
file) method.
This patch does the former.
Reported-by: Marc Eshel <eshel@almaden.ibm.com>
Tested-by: Marc Eshel <eshel@almaden.ibm.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit fa82a491275a613b15489aab4b99acecb00958d3 upstream.
nfsd4_lockt does a search for a lockstateowner when building the lock
struct to test. If one is found, it'll set fl_owner to it. Regardless of
whether that happens, it'll also set fl_lmops. Given that this lock is
basically a "lightweight" lock that's just used for checking conflicts,
setting fl_lmops is probably not appropriate for it.
This behavior exposed a bug in DLM's GETLK implementation where it
wasn't clearing out the fields in the file_lock before filling in
conflicting lock info. While we were able to fix this in DLM, it
still seems pointless and dangerous to set the fl_lmops this way
when we may have a NULL lockstateowner.
Signed-off-by: J. Bruce Fields <bfields@pig.fieldses.org>
commit a9ac49d303f967be0dabd97cb722c4a13109c6c2 upstream.
cifs_mount declares a struct sockaddr on the stack and then casts it
to the proper address type. The storage allocated is fine for ipv4,
but is too small for ipv6 addresses. Declare it as
"struct sockaddr_storage" instead of struct sockaddr".
This bug was manifesting itself as oopses and address corruption when
mounting IPv6 addresses.
Tested-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 9df04e1f25effde823a600e755b51475d438f56b upstream.
Linus suggested to put limits where the money is, and max_user_watches
already does that w/out the need of max_user_instances. That has the
advantage to mitigate the potential DoS while allowing pretty generous
default behavior.
Allowing top 4% of low memory (per user) to be allocated in epoll watches,
we have:
LOMEM MAX_WATCHES (per user)
512MB ~178000
1GB ~356000
2GB ~712000
A box with 512MB of lomem, will meet some challenge in hitting 180K
watches, socket buffers math teaches us. No more max_user_instances
limits then.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Bron Gondwana <brong@fastmail.fm>
commit a21102b55c4f8dfd3adb4a15a34cd62237b46039 upstream.
Make sure the rec_len field in the '..' entry is sane, lest we overrun
the directory block and cause a kernel oops on a purposefully
corrupted filesystem.
This fixes a bug related to a bug originally reported by Sami Liedes
for ext4 at:
http://bugzilla.kernel.org/show_bug.cgi?id=12430
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 4503efd0891c40e30928afb4b23dc3f99c62a6b2 upstream.
Some sysfs binary files don't like having 0 passed to them as a size.
Fix this up at the root by just returning to the vfs if userspace asks
us for a zero sized buffer.
Thanks to Pavel Roskin for pointing this out.
Reported-by: Pavel Roskin <proski@gnu.org>
commit bb875b38dc5e343bdb696b2eab8233e4d195e208 upstream.
ff is set to NULL and then dereferenced on line 65. Compile tested only.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 3ddf1e7f57237ac7c5d5bfb7058f1ea4f970b661 upstream.
Fix the leaking file reference if allocation or initialization of
fuse_conn failed.
commit 26c3679101dbccc054dcf370143941844ba70531 upstream.
If a fuse filesystem is unmounted but the device file descriptor
remains open and a new mount reuses the old device number, then the
mount fails with EEXIST and the following warning is printed in the
kernel log:
WARNING: at fs/sysfs/dir.c:462 sysfs_add_one+0x35/0x3d()
sysfs: duplicate filename '0:15' can not be created
The cause is that the bdi belonging to the fuse filesystem was
destoryed only after the device file was released. Fix this by
calling bdi_destroy() from fuse_put_super() instead.
commit 3632dee2f8b8a9720329f29eeaa4ec4669a3aff8 upstream.
If userspace supplies an invalid pointer to a read() of an inotify
instance, the inotify device's event list mutex is unlocked twice.
This causes an unbalance which effectively leaves the data structure
unprotected, and we can trigger oopses by accessing the inotify
instance from different tasks concurrently.
The best fix (contributed largely by Linus) is a total rewrite
of the function in question:
On Thu, Jan 22, 2009 at 7:05 AM, Linus Torvalds wrote:
> The thing to notice is that:
> - locking is done in just one place, and there is no question about it
> not having an unlock.
> - that whole double-while(1)-loop thing is gone.
> - use multiple functions to make nesting and error handling sane
> - do error testing after doing the things you always need to do, ie do
> this:
> mutex_lock(..)
> ret = function_call();
> mutex_unlock(..)
> .. test ret here ..
> instead of doing conditional exits with unlocking or freeing.
> So if the code is written in this way, it may still be buggy, but at least
> it's not buggy because of subtle "forgot to unlock" or "forgot to free"
> issues.
> This _always_ unlocks if it locked, and it always frees if it got a
> non-error kevent.
Cc: John McCutchan <ttb@tentacle.dhs.org>
Cc: Robert Love <rlove@google.com>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
commit 856bf4d717feb8c55d4e2f817b71ebb70cfbc67b upstream.
s_syncing livelock avoidance was breaking data integrity guarantee of
sys_sync, by allowing sys_sync to skip writing or waiting for superblocks
if there is a concurrent sys_sync happening.
This livelock avoidance is much less important now that we don't have the
get_super_to_sync() call after every sb that we sync. This was replaced
by __put_super_and_need_restart.
Signed-off-by: Nick Piggin <npiggin@suse.de>
commit 38f21977663126fef53f5585e7f1653d8ebe55c4 upstream.
Fix data integrity semantics required by sys_sync, by iterating over all
inodes and waiting for any writeback pages after the initial writeout.
Comments explain the exact problem.
commit 4f5a99d64c17470a784a6c68064207d82e3e74a5 upstream.
Remove WB_SYNC_HOLD. The primary motiviation is the design of my
anti-starvation code for fsync. It requires taking an inode lock over the
sync operation, so we could run into lock ordering problems with multiple
inodes. It is possible to take a single global lock to solve the ordering
problem, but then that would prevent a future nice implementation of "sync
multiple inodes" based on lock order via inode address.
Seems like a backward step to remove this, but actually it is busted
anyway: we can't use the inode lists for data integrity wait: an inode can
be taken off the dirty lists but still be under writeback. In order to
satisfy data integrity semantics, we should wait for it to finish
writeback, but if we only search the dirty lists, we'll miss it.
It would be possible to have a "writeback" list, for sys_sync, I suppose.
But why complicate things by prematurely optimise? For unmounting, we
could avoid the "livelock avoidance" code, which would be easier, but
again premature IMO.
Fixing the existing data integrity problem will come next.
commit ee53a891f47444c53318b98dac947ede963db400 upstream.
Chris Mason notices do_sync_mapping_range didn't actually ask for data
integrity writeout. Unfortunately, it is advertised as being usable for
data integrity operations.
This is a data integrity bug.
Cc: Chris Mason <chris.mason@oracle.com>
commit 15440319767942a363f282d6585303d3d75088ba upstream.
John Stanley reported EOVERFLOW errors in readdir from his self-build
glibc. I traced this down to glibc enabling d_off overflow checks
in one of the about five million different getdents implementations.
In 2.6.28 Dave Woodhouse moved our readdir double buffering required
for NFS4 readdirplus into nfsd and at that point we lost the capping
of the directory offsets to 32 bit signed values. Johns glibc used
getdents64 to even implement readdir for normal 32 bit offset dirents,
and failed with EOVERFLOW only if this happens on the first dirent in
a getdents call. I managed to come up with a testcase that uses
raw getdents and does the EOVERFLOW check manually. We always hit
it with our last entry due to the special end of directory marker.
The patch below is a dumb version of just putting back the masking,
to make sure we have the same behavior as in 2.6.27 and earlier.
I will work on a better and cleaner fix for 2.6.30.
Reported-by: John Stanley <jpsinthemix@verizon.net>
Tested-by: John Stanley <jpsinthemix@verizon.net>
Reviewed-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
commit a17d5232de7b53d34229de79ec22f4bb04adb7e4 upstream.
The result from readlink is being used to index into the link name
buffer without checking whether it is a valid length. If readlink
returns an error this will fault or cause memory corruption.
Cc: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
Cc: Dustin Kirkland <kirkland@canonical.com>
Cc: ecryptfs-devel@lists.launchpad.net
Signed-off-by: Duane Griffin <duaneg@dghda.com>
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 136221fc3219b3805c48db5da065e8e3467175d4 upstream.
aops->readpages() and its NFS helper readpage_async_filler() will only
be called to do readahead I/O for newly allocated pages. So it's not
necessary to test for the always 0 dirty/uptodate page flags.
The removal of nfs_wb_page() call also fixes a readahead bug: the NFS
readahead has been synchronous since 2.6.23, because that call will
clear PG_readahead, which is the reminder for asynchronous readahead.
More background: the PG_readahead page flag is shared with PG_reclaim,
one for read path and the other for write path. clear_page_dirty_for_io()
unconditionally clears PG_readahead to prevent possible readahead residuals,
assuming itself to be always called in the write path. However, NFS is one
and the only exception in that it _always_ calls clear_page_dirty_for_io()
in the read path, i.e. for readpages()/readpage().
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit dc711ca35f9d95a1eec02118e0c298b5e3068315 upstream.
We want ->name.len to match the resulting name on *both*
source and target
commit 62568510b8e2679cbc331d7de10ea9ba81ae8b3d upstream.
Since we (Analog Devices) updated our Blackfin kernel to 2.6.28, we've
seen occasional 5-second hangs from telnet. telnetd calls select with a
NULL timeout, but with the new kernel, the system call occasionally
returns 0, which causes telnet to call sleep (5). This did not happen
with earlier kernels.
The code in sys_pselect7 looks a bit strange, in particular the variable
"to" is initialized to NULL, then changed if a non-null timeout was
passed in, but not used further. It needs to be passed to
core_sys_select instead of &end_time.
This bug was introduced by 8ff3e8e85fa6c312051134b3953e397feb639f51
("select: switch select() and poll() over to hrtimers").
Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com>
Reviewed-by: Ulrich Drepper <drepper@redhat.com>
Tested-by: Robin Getz <rgetz@blackfin.uclinux.org>
commit 2b66421995d2e93c9d1a0111acf2581f8529c6e5 upstream.
commit d4e82042c4cfa87a7d51710b71f568fe80132551 upstream.
commit 836f92adf121f806e9beb5b6b88bd5c9c4ea3f24 upstream.
commit 6559eed8ca7db0531a207cd80be5e28cd6f213c5 upstream.
commit 2e4d0924eb0c403ce4014fa139d1d61bf2c44fee upstream.
commit 938bb9f5e840eddbf54e4f62f6c5ba9b3ae12c9d upstream.
commit 1e7bfb2134dfec37ce04fb3a4ca89299e892d10c upstream.
commit 5a8a82b1d306a325d899b67715618413657efda4 upstream.
commit 20f37034fb966a1c35894f9fe529fda0b6440101 upstream.
commit 3cdad42884bbd95d5aa01297e8236ea1bad70053 upstream.
commit 003d7ab479168132a2b2c6700fe682b08f08ab0c upstream.
commit ca013e945b1ba5828b151ee646946f1297b67a4c upstream.
commit 002c8976ee537724b20a5e179d9b349309438836 upstream.
commit a26eab2400f0477bfac0255600552394855016f7 upstream.
commit 3480b25743cb7404928d57efeaa3d085708b04c2 upstream.
commit 6a6160a7b5c27b3c38651baef92a14fa7072b3c1 upstream.
commit 64fd1de3d821659ac0a3004fd5ee1de59e64af30 upstream.
commit 257ac264d69017270fbc3cf5536953525db4076c upstream.
commit bdc480e3bef6eb0e7071770834cbdda7e30a5436 upstream.
commit a5f8fa9e9ba5ef3305e147f41ad6e1e84ac1f0bd upstream.
commit 6673e0c3fbeaed2cd08e2fd4a4aa97382d6fedb0 upstream.
System calls with an unsigned long long argument can't be converted with
the standard wrappers since that would include a cast to long, which in
turn means that we would lose the upper 32 bit on 32 bit architectures.
Also semctl can't use the standard wrapper since it has a 'union'
parameter.
So we handle them as special case and add some extra wrappers instead.
commit c9da9f2129d6a421c32e334a83770a9e67f7feac upstream.
Not a single architecture has wired up sys_pselect7 plus it is the
only system call with seven parameters. Just make it static and
rename it to do_pselect which will do the work for sys_pselect6.
commit 1134723e96f6e2abcf8bfd7a2d1c96fcc323ef35 upstream.
Remove __attribute__((weak)) from common code sys_pipe implemantation.
IA64, ALPHA, SUPERH (32bit) and SPARC (32bit) have own implemantations
with the same name. Just rename them.
For sys_pipe2 there is no architecture specific implementation.
Cc: Richard Henderson <rth@twiddle.net>
commit e55380edf68796d75bf41391a781c68ee678587d upstream.
This way it matches the generic system call name convention.
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
commit 4ae8978cf92a96257cd8998a49e781be83571d64 upstream.
The problems lie in the types used for some inotify interfaces, both at the kernel level and at the glibc level. This mail addresses the kernel problem. I will follow up with some suggestions for glibc changes.
For the sys_inotify_rm_watch() interface, the type of the 'wd' argument is
currently 'u32', it should be '__s32' . That is Robert's suggestion, and
is consistent with the other declarations of watch descriptors in the
kernel source, in particular, the inotify_event structure in
include/linux/inotify.h:
struct inotify_event {
__s32 wd; /* watch descriptor */
__u32 mask; /* watch mask */
__u32 cookie; /* cookie to synchronize two events */
__u32 len; /* length (including nulls) of name */
char name[0]; /* stub for possible name */
The patch makes the changes needed for inotify_rm_watch().
Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Ulrich Drepper <drepper@redhat.com>
commit d6b54841f4ddd836c886d1e6ac381cf309ee98a3 upstream.
Fix the add link method. The oosition in the directory was calculated in
wrong way - it had the incorrect shift direction.
Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream.
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
