path: root/fs
2013-08-28Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge fixes from Andrew Morton: "Five fixes. err, make that six. let me try again" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: fs/ocfs2/super.c: Use bigger nodestr to accomodate 32-bit node numbers memcg: check that kmem_cache has memcg_params before accessing it drivers/base/memory.c: fix show_mem_removable() to handle missing sections IPC: bugfix for msgrcv with msgtyp < 0 Omnikey Cardman 4000: pull in ioctl.h in user header timer_list: correct the iterator for timer_list
2013-08-28fs/ocfs2/super.c: Use bigger nodestr to accomodate 32-bit node numbersGoldwyn Rodrigues
While using pacemaker/corosync, the node numbers are generated using IP address as opposed to serial node number generation. This may not fit in a 8-byte string. Use a bigger string to print the complete node number. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-28vfs: make the dentry cache use the lockref infrastructureWaiman Long
This just replaces the dentry count/lock combination with the lockref structure that contains both a count and a spinlock, and does the mechanical conversion to use the lockref infrastructure. There are no semantic changes here, it's purely syntactic. The reference lockref implementation uses the spinlock exactly the same way that the old dcache code did, and the bulk of this patch is just expanding the internal "d_count" use in the dcache code to use "d_lockref.count" instead. This is purely preparation for the real change to make the reference count updates be lockless during the 3.12 merge window. [ As with the previous commit, this is a rewritten version of a concept originally from Waiman, so credit goes to him, blame for any errors goes to me. Waiman's patch had some semantic differences for taking advantage of the lockless update in dget_parent(), while this patch is intentionally a pure search-and-replace change with no semantic changes. - Linus ] Signed-off-by: Waiman Long <Waiman.Long@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-28Revert "fs: Allow unprivileged linkat(..., AT_EMPTY_PATH) aka flink"Linus Torvalds
This reverts commit bb2314b47996491bbc5add73633905c3120b6268. It wasn't necessarily wrong per se, but we're still busily discussing the exact details of this all, so I'm going to revert it for now. It's true that you can already do flink() through /proc and that flink() isn't new. But as Brad Spengler points out, some secure environments do not mount proc, and flink adds a new interface that can avoid path lookup of the source for those kinds of environments. We may re-do this (and even mark it for stable backporting back in 3.11 and possibly earlier) once the whole discussion about the interface is done. Cc: Andy Lutomirski <luto@amacapital.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Brad Spengler <spender@grsecurity.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-26Merge tag 'jfs-3.11-rc8' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from Dave Kleikamp: "One JFS patch to fix an incompatibility with NFSv4 resulting in the nfs client reporting a readdir loop" * tag 'jfs-3.11-rc8' of git://github.com/kleikamp/linux-shaggy: jfs: fix readdir cookie incompatibility with NFSv4
2013-08-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Assorted fixes from the last week or so" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: VFS: collect_mounts() should return an ERR_PTR bfs: iget_locked() doesn't return an ERR_PTR efs: iget_locked() doesn't return an ERR_PTR() proc: kill the extra proc_readfd_common()->dir_emit_dots() cope with potentially long ->d_dname() output for shmem/hugetlb
2013-08-24Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of small bug fixes for lpfc and zfcp and a fix for a fairly nasty bug in sg where a process which cancels I/O completes in a kernel thread which would then try to write back to the now gone userspace and end up writing to a random kernel address instead" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: [SCSI] zfcp: remove access control tables interface (keep sysfs files) [SCSI] zfcp: fix schedule-inside-lock in scsi_device list loops [SCSI] zfcp: fix lock imbalance by reworking request queue locking [SCSI] sg: Fix user memory corruption when SG_IO is interrupted by a signal [SCSI] lpfc: Don't force CONFIG_GENERIC_CSUM on
2013-08-24VFS: collect_mounts() should return an ERR_PTRDan Carpenter
This should actually be returning an ERR_PTR on error instead of NULL. That was how it was designed and all the callers expect it. [AV: actually, that's what "VFS: Make clone_mnt()/copy_tree()/collect_mounts() return errors" missed - originally collect_mounts() was expected to return NULL on failure] Cc: <stable@vger.kernel.org> # 3.10+ Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-24bfs: iget_locked() doesn't return an ERR_PTRDan Carpenter
iget_locked() returns a NULL on error, it doesn't return an ERR_PTR. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-24efs: iget_locked() doesn't return an ERR_PTR()Dan Carpenter
The iget_locked() function returns NULL on error and never an ERR_PTR. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-24proc: kill the extra proc_readfd_common()->dir_emit_dots()Oleg Nesterov
proc_readfd_common() does dir_emit_dots() twice in a row, we need to do this only once. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-24cope with potentially long ->d_dname() output for shmem/hugetlbAl Viro
dynamic_dname() is both too much and too little for those - the output may be well in excess of 64 bytes dynamic_dname() assumes to be enough (thanks to ashmem feeding really long names to shmem_file_setup()) and vsnprintf() is an overkill for those guys. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-23nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error detection Fix the issue with improper counting number of flying bio requests for BIO_EOPNOTSUPP error detection case. The sb_nbio must be incremented exactly the same number of times as complete() function was called (or will be called) because nilfs_segbuf_wait() will call wail_for_completion() for the number of times set to sb_nbio: do { wait_for_completion(&segbuf->sb_bio_event); } while (--segbuf->sb_nbio > 0); Two functions complete() and wait_for_completion() must be called the same number of times for the same sb_bio_event. Otherwise, wait_for_completion() will hang or leak. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-23nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error Remove double call of bio_put() in nilfs_end_bio_write() for the case of BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter and he suggests first version of the fix too. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-21[SCSI] sg: Fix user memory corruption when SG_IO is interrupted by a signalRoland Dreier
There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances leads to one process writing data into the address space of some other random unrelated process if the ioctl is interrupted by a signal. What happens is the following: - A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the underlying SCSI command will transfer data from the SCSI device to the buffer provided in the ioctl) - Before the command finishes, a signal is sent to the process waiting in the ioctl. This will end up waking up the sg_ioctl() code: result = wait_event_interruptible(sfp->read_wait, (srp_done(sfp, srp) || sdp->detached)); but neither srp_done() nor sdp->detached is true, so we end up just setting srp->orphan and returning to userspace: srp->orphan = 1; write_unlock_irq(&sfp->rq_list_lock); return result; /* -ERESTARTSYS because signal hit process */ At this point the original process is done with the ioctl and blithely goes ahead handling the signal, reissuing the ioctl, etc. - Eventually, the SCSI command issued by the first ioctl finishes and ends up in sg_rq_end_io(). At the end of that function, we run through: write_lock_irqsave(&sfp->rq_list_lock, iflags); if (unlikely(srp->orphan)) { if (sfp->keep_orphan) srp->sg_io_owned = 0; else done = 0; } srp->done = done; write_unlock_irqrestore(&sfp->rq_list_lock, iflags); if (likely(done)) { /* Now wake up any sg_read() that is waiting for this * packet. */ wake_up_interruptible(&sfp->read_wait); kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN); kref_put(&sfp->f_ref, sg_remove_sfp); } else { INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext); schedule_work(&srp->ew.work); } Since srp->orphan *is* set, we set done to 0 (assuming the userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext() to run in a workqueue. - In workqueue context we go through sg_rq_end_io_usercontext() -> sg_finish_rem_req() -> blk_rq_unmap_user() -> ... -> bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user(). The key point here is that we are doing copy_to_user() on a workqueue -- that is, we're on a kernel thread with current->mm equal to whatever random previous user process was scheduled before this kernel thread. So we end up copying whatever data the SCSI command returned to the virtual address of the buffer passed into the original ioctl, but it's quite likely we do this copying into a different address space! As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>, add a check for current->mm (which is NULL if we're on a kernel thread without a real userspace address space) in bio_uncopy_user(), and skip the copy if we're on a kernel thread. There's no reason that I can think of for any caller of bio_uncopy_user() to want to do copying on a kernel thread with a random active userspace address space. Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the original pointer to this bug in the sg code. Signed-off-by: Roland Dreier <roland@purestorage.com> Tested-by: David Milburn <dmilburn@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: <stable@vger.kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-08-19proc: more readdir conversion bug-fixesLinus Torvalds
In the previous commit, Richard Genoud fixed proc_root_readdir(), which had lost the check for whether all of the non-process /proc entries had been returned or not. But that in turn exposed _another_ bug, namely that the original readdir conversion patch had yet another problem: it had lost the return value of proc_readdir_de(), so now checking whether it had completed successfully or not didn't actually work right anyway. This reinstates the non-zero return for the "end of base entries" that had also gotten lost in commit f0c3b5093add ("[readdir] convert procfs"). So now you get all the base entries *and* you get all the process entries, regardless of getdents buffer size. (Side note: the Linux "getdents" manual page actually has a nice example application for testing getdents, which can be easily modified to use different buffers. Who knew? Man-pages can be useful) Reported-by: Emmanuel Benisty <benisty.e@gmail.com> Reported-by: Marc Dionne <marc.c.dionne@gmail.com> Cc: Richard Genoud <richard.genoud@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-19proc: return on proc_readdir errorRichard Genoud
Commit f0c3b5093add ("[readdir] convert procfs") introduced a bug on the listing of the proc file-system. The return value of proc_readdir() isn't tested anymore in the proc_root_readdir function. This lead to an "interesting" behaviour when we are using the getdents() system call with a buffer too small: instead of failing, it returns the first entries of /proc (enough to fill the given buffer), plus the PID directories. This is not triggered on glibc (as getdents is called with a 32KB buffer), but on uclibc, the buffer size is only 1KB, thus some proc entries are missing. See https://lkml.org/lkml/2013/8/12/288 for more background. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
Pull gfs2 fixes from Steven Whitehouse: "Out of these five patches, the one for ensuring that the number of revokes is not exceeded, and the one for checking the glock is not already held in gfs2_getxattr are the two most important. The latter can be triggered by selinux. The other three patches are very small and fix mostly fairly trivial issues" * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: Check for glock already held in gfs2_getxattr GFS2: alloc_workqueue() doesn't return an ERR_PTR GFS2: don't overrun reserved revokes GFS2: WQ_NON_REENTRANT is meaningless and going away GFS2: Fix typo in gfs2_create_inode()
2013-08-19GFS2: Check for glock already held in gfs2_getxattrSteven Whitehouse
Since the introduction of atomic_open, gfs2_getxattr can be called with the glock already held, so we need to allow for this. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reported-by: David Teigland <teigland@redhat.com> Tested-by: David Teigland <teigland@redhat.com>
2013-08-19GFS2: alloc_workqueue() doesn't return an ERR_PTRDan Carpenter
alloc_workqueue() returns a NULL on error, it doesn't return an ERR_PTR. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-08-19GFS2: don't overrun reserved revokesBenjamin Marzinski
When run during fsync, a gfs2_log_flush could happen between the time when gfs2_ail_flush checked the number of blocks to revoke, and when it actually started the transaction to do those revokes. This occassionally caused it to need more revokes than it reserved, causing gfs2 to crash. Instead of just reserving enough revokes to handle the blocks that currently need them, this patch makes gfs2_ail_flush reserve the maximum number of revokes it can, without increasing the total number of reserved log blocks. This patch also passes the number of reserved revokes to __gfs2_ail_flush() so that it doesn't go over its limit and cause a crash like we're seeing. Non-fsync calls to __gfs2_ail_flush will still cause a BUG() necessary revokes are skipped. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-08-19GFS2: WQ_NON_REENTRANT is meaningless and going awayTejun Heo
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made WQ_NON_REENTRANT no-op and the flag is going away. Remove its usages. This patch doesn't introduce any behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: cluster-devel@redhat.com
2013-08-19GFS2: Fix typo in gfs2_create_inode()Steven Whitehouse
PTR_RET should be PTR_ERR Reported-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-08-17Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull jbd2 bug fixes from Ted Ts'o: "Two jbd2 bug fixes, one of which is a regression fix" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd2: Fix oops in jbd2_journal_file_inode() jbd2: Fix use after free after error in jbd2_journal_dirty_metadata()
2013-08-16jbd2: Fix oops in jbd2_journal_file_inode()Jan Kara
Commit 0713ed0cde76438d05849f1537d3aab46e099475 added jbd2_journal_file_inode() call into ext4_block_zero_page_range(). However that function gets called from truncate path and thus inode needn't have jinode attached - that happens in ext4_file_open() but the file needn't be ever open since mount. Calling jbd2_journal_file_inode() without jinode attached results in the oops. We fix the problem by attaching jinode to inode also in ext4_truncate() and ext4_punch_hole() when we are going to zero out partial blocks. Reported-by: majianpeng <majianpeng@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-08-16Fix TLB gather virtual address range invalidation corner casesLinus Torvalds
Ben Tebulin reported: "Since v3.7.2 on two independent machines a very specific Git repository fails in 9/10 cases on git-fsck due to an SHA1/memory failures. This only occurs on a very specific repository and can be reproduced stably on two independent laptops. Git mailing list ran out of ideas and for me this looks like some very exotic kernel issue" and bisected the failure to the backport of commit 53a59fc67f97 ("mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT"). That commit itself is not actually buggy, but what it does is to make it much more likely to hit the partial TLB invalidation case, since it introduces a new case in tlb_next_batch() that previously only ever happened when running out of memory. The real bug is that the TLB gather virtual memory range setup is subtly buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather: enable tlb flush range in generic mmu_gather"), and the range handling was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB range flushed when __tlb_remove_page() runs out of slots"), but that fix was not complete. The problem with the TLB gather virtual address range is that it isn't set up by the initial tlb_gather_mmu() initialization (which didn't get the TLB range information), but it is set up ad-hoc later by the functions that actually flush the TLB. And so any such case that forgot to update the TLB range entries would potentially miss TLB invalidates. Rather than try to figure out exactly which particular ad-hoc range setup was missing (I personally suspect it's the hugetlb case in zap_huge_pmd(), which didn't have the same logic as zap_pte_range() did), this patch just gets rid of the problem at the source: make the TLB range information available to tlb_gather_mmu(), and initialize it when initializing all the other tlb gather fields. This makes the patch larger, but conceptually much simpler. And the end result is much more understandable; even if you want to play games with partial ranges when invalidating the TLB contents in chunks, now the range information is always there, and anybody who doesn't want to bother with it won't introduce subtle bugs. Ben verified that this fixes his problem. Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com> Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au> Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-15jfs: fix readdir cookie incompatibility with NFSv4Dave Kleikamp
NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..), but jfs allows a value of 2 for a non-special entry. This incompatibility can result in the nfs client reporting a readdir loop. This patch doesn't change the value stored internally, but adds one to the value exposed to the iterate method. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Tested-by: Christian Kujau <lists@nerdbynature.de>
2013-08-13fs/proc/task_mmu.c: fix buffer overflow in add_page_map()yonghua zheng
Recently we met quite a lot of random kernel panic issues after enabling CONFIG_PROC_PAGE_MONITOR. After debuggind we found this has something to do with following bug in pagemap: In struct pagemapread: struct pagemapread { int pos, len; pagemap_entry_t *buffer; bool v2; }; pos is number of PM_ENTRY_BYTES in buffer, but len is the size of buffer, it is a mistake to compare pos and len in add_page_map() for checking buffer is full or not, and this can lead to buffer overflow and random kernel panic issue. Correct len to be total number of PM_ENTRY_BYTES in buffer. [akpm@linux-foundation.org: document pagemapread.pos and .len units, fix PM_ENTRY_BYTES definition] Signed-off-by: Yonghua Zheng <younghua.zheng@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13ocfs2: fix null pointer dereference in ocfs2_dir_foreach_blk_id()Jeff Liu
Fix a NULL pointer deference while removing an empty directory, which was introduced by commit 3704412bdbf3 ("[readdir] convert ocfs2"). BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<(null)>] (null) PGD 6da85067 PUD 6da89067 PMD 0 Oops: 0010 [#1] SMP CPU: 0 PID: 6564 Comm: rmdir Tainted: G O 3.11.0-rc1 #4 RIP: 0010:[<0000000000000000>] [< (null)>] (null) Call Trace: ocfs2_dir_foreach+0x49/0x50 [ocfs2] ocfs2_empty_dir+0x12c/0x3e0 [ocfs2] ocfs2_unlink+0x56e/0xc10 [ocfs2] vfs_rmdir+0xd5/0x140 do_rmdir+0x1cb/0x1e0 SyS_rmdir+0x16/0x20 system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [< (null)>] (null) RSP <ffff88006daddc10> CR2: 0000000000000000 [dan.carpenter@oracle.com: fix pointer math] Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reported-by: David Weber <wb@munzinger.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13ocfs2: fix NULL pointer dereference in ocfs2_duplicate_clusters_by_pageTiger Yang
Since ocfs2_cow_file_pos will invoke ocfs2_refcount_icow with a NULL as the struct file pointer, it finally result in a null pointer dereference in ocfs2_duplicate_clusters_by_page. This patch replace file pointer with inode pointer in cow_duplicate_clusters to fix this issue. [jeff.liu@oracle.com: rebased patch against linux-next tree] Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Jie Liu <jeff.liu@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Acked-by: Tao Ma <tm@tao.ma> Tested-by: David Weber <wb@munzinger.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13ocfs2: Revert 40bd62e to avoid regression in extended allocationJie Liu
Revert commit 40bd62eb7fb8 ("fs/ocfs2/journal.h: add bits_wanted while calculating credits in ocfs2_calc_extend_credits"). Unfortunately this change broke fallocate even if there is insufficient disk space for the preallocation, which is a serious problem. # df -h /dev/sda8 22G 1.2G 21G 6% /ocfs2 # fallocate -o 0 -l 200M /ocfs2/testfile fallocate: /ocfs2/test: fallocate failed: No space left on device and a kernel warning: CPU: 3 PID: 3656 Comm: fallocate Tainted: G W O 3.11.0-rc3 #2 Call Trace: dump_stack+0x77/0x9e warn_slowpath_common+0xc4/0x110 warn_slowpath_null+0x2a/0x40 start_this_handle+0x6c/0x640 [jbd2] jbd2__journal_start+0x138/0x300 [jbd2] jbd2_journal_start+0x23/0x30 [jbd2] ocfs2_start_trans+0x166/0x300 [ocfs2] __ocfs2_extend_allocation+0x38f/0xdb0 [ocfs2] ocfs2_allocate_unwritten_extents+0x3c9/0x520 __ocfs2_change_file_space+0x5e0/0xa60 [ocfs2] ocfs2_fallocate+0xb1/0xe0 [ocfs2] do_fallocate+0x1cb/0x220 SyS_fallocate+0x6f/0xb0 system_call_fastpath+0x16/0x1b JBD2: fallocate wants too many credits (51216 > 4381) Signed-off-by: Jie Liu <jeff.liu@oracle.com> Cc: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13hugetlb: fix lockdep splat caused by pmd sharingMichal Hocko
Dave has reported the following lockdep splat: ================================= [ INFO: inconsistent lock state ] 3.11.0-rc1+ #9 Not tainted --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd0/49 [HC0[0]:SC0[0]:HE1:SE1] takes: (&mapping->i_mmap_mutex){+.+.?.}, at: [<c114971b>] page_referenced+0x87/0x5e3 {RECLAIM_FS-ON-W} state was registered at: mark_held_locks+0x81/0xe7 lockdep_trace_alloc+0x5e/0xbc __alloc_pages_nodemask+0x8b/0x9b6 __get_free_pages+0x20/0x31 get_zeroed_page+0x12/0x14 __pmd_alloc+0x1c/0x6b huge_pmd_share+0x265/0x283 huge_pte_alloc+0x5d/0x71 hugetlb_fault+0x7c/0x64a handle_mm_fault+0x255/0x299 __do_page_fault+0x142/0x55c do_page_fault+0xd/0x16 error_code+0x6c/0x74 irq event stamp: 3136917 hardirqs last enabled at (3136917): _raw_spin_unlock_irq+0x27/0x50 hardirqs last disabled at (3136916): _raw_spin_lock_irq+0x15/0x78 softirqs last enabled at (3136180): __do_softirq+0x137/0x30f softirqs last disabled at (3136175): irq_exit+0xa8/0xaa other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&mapping->i_mmap_mutex); <Interrupt> lock(&mapping->i_mmap_mutex); *** DEADLOCK *** no locks held by kswapd0/49. stack backtrace: CPU: 1 PID: 49 Comm: kswapd0 Not tainted 3.11.0-rc1+ #9 Hardware name: Dell Inc. Precision WorkStation 490 /0DT031, BIOS A08 04/25/2008 Call Trace: dump_stack+0x4b/0x79 print_usage_bug+0x1d9/0x1e3 mark_lock+0x1e0/0x261 __lock_acquire+0x623/0x17f2 lock_acquire+0x7d/0x195 mutex_lock_nested+0x6c/0x3a7 page_referenced+0x87/0x5e3 shrink_page_list+0x3d9/0x947 shrink_inactive_list+0x155/0x4cb shrink_lruvec+0x300/0x5ce shrink_zone+0x53/0x14e kswapd+0x517/0xa75 kthread+0xa8/0xaa ret_from_kernel_thread+0x1b/0x28 which is a false positive caused by hugetlb pmd sharing code which allocates a new pmd from withing mapping->i_mmap_mutex. If this allocation causes reclaim then the lockdep detector complains that we might self-deadlock. This is not correct though, because hugetlb pages are not reclaimable so their mapping will be never touched from the reclaim path. The patch tells lockup detector that hugetlb i_mmap_mutex is special by assigning it a separate lockdep class so it won't report possible deadlocks on unrelated mappings. [peterz@infradead.org: comment for annotation] Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13mm: save soft-dirty bits on file pagesCyrill Gorcunov
Andy reported that if file page get reclaimed we lose the soft-dirty bit if it was there, so save _PAGE_BIT_SOFT_DIRTY bit when page address get encoded into pte entry. Thus when #pf happens on such non-present pte we can restore it back. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13mm: save soft-dirty bits on swapped pagesCyrill Gorcunov
Andy Lutomirski reported that if a page with _PAGE_SOFT_DIRTY bit set get swapped out, the bit is getting lost and no longer available when pte read back. To resolve this we introduce _PTE_SWP_SOFT_DIRTY bit which is saved in pte entry for the page being swapped out. When such page is to be read back from a swap cache we check for bit presence and if it's there we clear it and restore the former _PAGE_SOFT_DIRTY bit back. One of the problem was to find a place in pte entry where we can save the _PTE_SWP_SOFT_DIRTY bit while page is in swap. The _PAGE_PSE was chosen for that, it doesn't intersect with swap entry format stored in pte. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-12Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "A set of small cifs fixes, including 3 relating to symlink handling" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: don't instantiate new dentries in readdir for inodes that need to be revalidated immediately cifs: set sb->s_d_op before calling d_make_root() cifs: fix bad error handling in crypto code cifs: file: initialize oparms.reconnect before using it Do not attempt to do cifs operations reading symlinks with SMB2 cifs: extend the buffer length enought for sprintf() using
2013-08-12Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull more ext4 bugfixes from Ted Ts'o: "A number of miscellaneous ext4 bugs fixes for v3.11, including a fix so that if ext4 is built as a module, to allow it to be unloaded" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: flush the extent status cache during EXT4_IOC_SWAP_BOOT ext4: fix mount/remount error messages for incompatible mount options ext4: allow the mount options nodelalloc and data=journal
2013-08-12jbd2: Fix use after free after error in jbd2_journal_dirty_metadata()Jan Kara
When jbd2_journal_dirty_metadata() returns error, __ext4_handle_dirty_metadata() stops the handle. However callers of this function do not count with that fact and still happily used now freed handle. This use after free can result in various issues but very likely we oops soon. The motivation of adding __ext4_journal_stop() into __ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to improve error reporting. So replace __ext4_journal_stop() with ext4_journal_abort_handle() which was there before that commit and add WARN_ON_ONCE() to dump stack to provide useful information. Reported-by: Sage Weil <sage@inktank.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org # 3.2+
2013-08-12ext4: flush the extent status cache during EXT4_IOC_SWAP_BOOTTheodore Ts'o
Previously we weren't swapping only some of the extent_status LRU fields during the processing of the EXT4_IOC_SWAP_BOOT ioctl. The much safer thing to do is to just completely flush the extent status tree when doing the swap. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Zheng Liu <gnehzuil.liu@gmail.com> Cc: stable@vger.kernel.org
2013-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "These are assorted fixes, mostly from Josef nailing down xfstests runs. Zach also has a long standing fix for problems with readdir wrapping f_pos (or ctx->pos) These patches were spread out over different bases, so I rebased things on top of rc4 and retested overnight" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: don't loop on large offsets in readdir Btrfs: check to see if root_list is empty before adding it to dead roots Btrfs: release both paths before logging dir/changed extents Btrfs: allow splitting of hole em's when dropping extent cache Btrfs: make sure the backref walker catches all refs to our extent Btrfs: fix backref walking when we hit a compressed extent Btrfs: do not offset physical if we're compressed Btrfs: fix extent buffer leak after backref walking Btrfs: fix a bug of snapshot-aware defrag to make it work on partial extents btrfs: fix file truncation if FALLOC_FL_KEEP_SIZE is specified
2013-08-10Merge tag 'nfs-for-3.11-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Stable patch for lockd to fix Oopses due to inappropriate calls to utsname()->nodename - Stable patches for sunrpc to fix Oopses on shutdown when using AF_LOCAL sockets with rpcbind - Fix memory leak and error checking issues in nfs4_proc_lookup_mountpoint - Fix a regression with the sync mount option failing to work for nfs4 mounts - Fix a writeback performance issue when doing cache invalidation - Remove an incorrect call to nfs_setsecurity in nfs_fhget * tag 'nfs-for-3.11-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Fix up nfs4_proc_lookup_mountpoint NFS: Remove unnecessary call to nfs_setsecurity in nfs_fhget() NFSv4: Fix the sync mount option for nfs4 mounts NFS: Fix writeback performance issue on cache invalidation SUNRPC: If the rpcbind channel is disconnected, fail the call to unregister SUNRPC: Don't auto-disconnect from the local rpcbind socket LOCKD: Don't call utsname()->nodename from nlmclnt_setlockargs
2013-08-10Merge branch 'for-3.11' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "Some fixes for a 4.1 feature that in retrospect probably should have waited for 3.12.... But it appears to be working now" * 'for-3.11' of git://linux-nfs.org/~bfields/linux: nfsd: Fix SP4_MACH_CRED negotiation in EXCHANGE_ID nfsd4: Fix MACH_CRED NULL dereference
2013-08-09btrfs: don't loop on large offsets in readdirZach Brown
When btrfs readdir() hits the last entry it sets the readdir offset to a huge value to stop buggy apps from breaking when the same name is returned by readdir() with concurrent rename()s. But unconditionally setting the offset to INT_MAX causes readdir() to loop returning any entries with offsets past INT_MAX. It only takes a few hours of constant file creation and removal to create entries past INT_MAX. So let's set the huge offset to LLONG_MAX if the last entry has already overflowed 32bit loff_t. Without large offsets behaviour is identical. With large offsets 64bit apps will work and 32bit apps will be no more broken than they currently are if they see large offsets. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: check to see if root_list is empty before adding it to dead rootsJosef Bacik
A user reported a panic when running with autodefrag and deleting snapshots. This is because we could end up trying to add the root to the dead roots list twice. To fix this check to see if we are empty before adding ourselves to the dead roots list. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: release both paths before logging dir/changed extentsJosef Bacik
The ceph guys tripped over this bug where we were still holding onto the original path that we used to copy the inode with when logging. This is based on Chris's fix which was reported to fix the problem. We need to drop the paths in two cases anyway so just move the drop up so that we don't have duplicate code. Thanks, Cc: stable@vger.kernel.org Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: allow splitting of hole em's when dropping extent cacheJosef Bacik
I noticed while running multi-threaded fsync tests that sometimes fsck would complain about an improper gap. This happens because we fail to add a hole extent to the file, which was happening when we'd split a hole EM because btrfs_drop_extent_cache was just discarding the whole em instead of splitting it. So this patch fixes this by allowing us to split a hole em properly, which means that added holes actually get logged properly and we no longer see this fsck error. Thankfully we're tolerant of these sort of problems so a user would not see any adverse effects of this bug, other than fsck complaining. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: make sure the backref walker catches all refs to our extentJosef Bacik
Because we don't mess with the offset into the extent for compressed we will properly find both extents for this case [extent a][extent b][rest of extent a] but because we already added a ref for the front half we won't add the inode information for the second half. This causes us to leak that memory and not print out the other offset when we do logical-resolve. So fix this by calling ulist_add_merge and then add our eie to the existing entry if there is one. With this patch we get both offsets out of logical-resolve. With this and the other 2 patches I've sent we now pass btrfs/276 on my vm with compress-force=lzo set. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: fix backref walking when we hit a compressed extentJosef Bacik
If you do btrfs inspect-internal logical-resolve on a compressed extent that has been partly overwritten it won't find anything. This is because we try and match the extent offset we've searched for based on the extent offset in the data extent entry. However this doesn't work for compressed extents because the offsets are for the uncompressed size, not the compressed size. So instead only do this check if we are not compressed, that way we can get an actual entry for the physical offset rather than nothing for compressed. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: do not offset physical if we're compressedJosef Bacik
xfstest btrfs/276 was freaking out on slower boxes partly because fiemap was offsetting the physical based on the extent offset. This is perfectly fine with uncompressed extents, however the extent offset is into the uncompressed area, not the compressed. So we can return a physical value that isn't at all within the area we have allocated on disk. Fix this by returning the start of the extent if it is compressed no matter what the offset. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: fix extent buffer leak after backref walkingLiu Bo
commit 47fb091fb787420cd195e66f162737401cce023f(Btrfs: fix unlock after free on rewinded tree blocks) takes an extra increment on the reference of allocated dummy extent buffer, so now we cannot free this dummy one, and end up with extent buffer leak. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Reviewed-by: Jan Schmidt <list.btrfs@jan-o-sch.net> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-08-09Btrfs: fix a bug of snapshot-aware defrag to make it work on partial extentsLiu Bo
For partial extents, snapshot-aware defrag does not work as expected, since a) we use the wrong logical offset to search for parents, which should be disk_bytenr + extent_offset, not just disk_bytenr, b) 'offset' returned by the backref walking just refers to key.offset, not the 'offset' stored in btrfs_extent_data_ref which is (key.offset - extent_offset). The reproducer: $ mkfs.btrfs sda $ mount sda /mnt $ btrfs sub create /mnt/sub $ for i in `seq 5 -1 1`; do dd if=/dev/zero of=/mnt/sub/foo bs=5k count=1 seek=$i conv=notrunc oflag=sync; done $ btrfs sub snap /mnt/sub /mnt/snap1 $ btrfs sub snap /mnt/sub /mnt/snap2 $ sync; btrfs filesystem defrag /mnt/sub/foo; $ umount /mnt $ btrfs-debug-tree sda (Here we can check whether the defrag operation is snapshot-awared. This addresses the above two problems. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
