commit 9bf729c0af67897ea8498ce17c29b0683f7f2028 upstream
On low memory boxes or those with highmem, kernel can OOM before the
background reclaims inodes via xfssyncd. Add a shrinker to run inode
reclaim so that it inode reclaim is expedited when memory is low.
This is more complex than it needs to be because the VM folk don't
want a context added to the shrinker infrastructure. Hence we need
to add a global list of XFS mount structures so the shrinker can
traverse them.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Acked-by: Alex Elder <aelder@sgi.com>
commit 2b0b39517d1af5294128dbc2fd7ed39c8effa540 upstream.
Resizing the filesystem would result in an diAllocExt error in some
instances because changes in bmp->db_agsize would not get noticed if
goto extendBmap was called.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: jfs-discussion@lists.sourceforge.net
commit aca92ff6f57c000d1b4523e383c8bd6b8269b8b1 upstream.
ext4_fiemap() rounds the length of the requested range down to
blocksize, which is is not the true number of blocks that cover the
requested region. This problem is especially impressive if the user
requests only the first byte of a file: not a single extent will be
reported.
We fix this by calculating the last block of the region and then
subtract to find the number of blocks in the extents.
Signed-off-by: Leonard Michlmayr <leonard.michlmayr@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 356e76b855bdbfd8d1c5e75bcf0c6bf0dfe83496 upstream.
NFSv4 mounts ignore the rsize and wsize mount options, and always use
the default transfer size for both. This seems to be because all
NFSv4 mounts are now cloned, and the cloning logic doesn't copy the
rsize and wsize settings from the parent nfs_server.
I tested Fedora's 2.6.32.11-99 and it seems to have this problem as
well, so I'm guessing that .33, .32, and perhaps older kernels have
this issue as well.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit d9e80b7de91db05c1c4d2e5ebbfd70b3b3ba0e0f upstream.
If dentry found stale happens to be a root of disconnected tree, we
can't d_drop() it; its d_hash is actually part of s_anon and d_drop()
would simply hide it from shrink_dcache_for_umount(), leading to
all sorts of fun, including busy inodes on umount and oopsen after
that.
Bug had been there since at least 2006 (commit c636eb already has it),
so it's definitely -stable fodder.
commit a36d515c7a2dfacebcf41729f6812dbc424ebcf0 upstream.
When asked for a partial read of the LVB in a dlmfs file, we can
accidentally calculate a negative count.
Reported-by: Dan Carpenter <error27@gmail.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
commit a42ab8e1a37257da37e0f018e707bf365ac24531 upstream.
Online resize writes out the new superblock and its backups directly.
The metaecc data wasn't being recomputed. Let's do that directly.
Acked-by: Mark Fasheh <mfasheh@suse.com>
commit 0350cb078f5035716ebdad4ad4709d02fe466a8a upstream.
If "handle" is non null at the end of the function then we assume it's a
valid pointer and pass it to ocfs2_commit_trans();
commit c21a534e2f24968cf74976a4e721ac194db30ded upstream.
In reflink we update the id info on the disk but forgot to update
the corresponding information in the VFS inode. Update them
accordingly when we want to preserve the attributes.
Reported-by: Jeff Liu <jeff.liu@oracle.com>
Signed-off-by: Tao Ma <tao.ma@oracle.com>
commit 2bc3c1179c781b359d4f2f3439cb3df72afc17fc upstream.
When read_buf is called to move over to the next page in the pagelist
of an NFSv4 request, it sets argp->end to essentially a random
number, certainly not an address within the page which argp->p now
points to. So subsequent calls to READ_BUF will think there is much
more than a page of spare space (the cast to u32 ensures an unsigned
comparison) so we can expect to fall off the end of the second
page.
We never encountered thsi in testing because typically the only
operations which use more than two pages are write-like operations,
which have their own decoding logic. Something like a getattr after a
write may cross a page boundary, but it would be very unusual for it to
cross another boundary after that.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 3835541dd481091c4dbf5ef83c08aed12e50fd61 upstream.
Correct the file_operations struct in fdinfo entry of tid_base_stuff[].
Presently /proc/*/task/*/fdinfo contains symlinks to opened files like
/proc/*/fd/.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit fb2162df74bb19552db3d988fd11c787cf5fad56 upstream.
Commit 48b32a3553a54740d236b79a90f20147a25875e3 ("reiserfs: use generic
xattr handlers") introduced a problem that causes corruption when extended
attributes are replaced with a smaller value.
The issue is that the reiserfs_setattr to shrink the xattr file was moved
from before the write to after the write.
The root issue has always been in the reiserfs xattr code, but was papered
over by the fact that in the shrink case, the file would just be expanded
again while the xattr was written.
The end result is that the last 8 bytes of xattr data are lost.
This patch fixes it to use new_size.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=14826
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Christian Kujau <lists@nerdbynature.de>
Tested-by: Christian Kujau <lists@nerdbynature.de>
Cc: Edward Shishkin <edward.shishkin@gmail.com>
Cc: Jethro Beekman <kernel@jbeekman.nl>
Cc: Greg Surbey <gregsurbey@hotmail.com>
Cc: Marco Gatti <marco.gatti@gmail.com>
commit cac36f707119b792b2396aed371d6b5cdc194890 upstream.
Commit 677c9b2e393a0cd203bd54e9c18b012b2c73305a ("reiserfs: remove
privroot hiding in lookup") removed the magic from the lookup code to hide
the .reiserfs_priv directory since it was getting loaded at mount-time
instead. The intent was that the entry would be hidden from the user via
a poisoned d_compare, but this was faulty.
This introduced a security issue where unprivileged users could access and
modify extended attributes or ACLs belonging to other users, including
root.
This patch resolves the issue by properly hiding .reiserfs_priv. This was
the intent of the xattr poisoning code, but it appears to have never
worked as expected. This is fixed by using d_revalidate instead of
d_compare.
This patch makes -oexpose_privroot a no-op. I'm fine leaving it this way.
The effort involved in working out the corner cases wrt permissions and
caching outweigh the benefit of the feature.
Acked-by: Edward Shishkin <edward.shishkin@gmail.com>
Reported-by: Matt McCutchen <matt@mattmccutchen.net>
Tested-by: Matt McCutchen <matt@mattmccutchen.net>
commit a1de02dccf906faba2ee2d99cac56799bda3b96a upstream.
The "offset" member in ext4_io_end holds bytes, not blocks, so
ext4_lblk_t is wrong - and too small (u32).
This caused the async i/o writes to sparse files beyond 4GB to fail
when they wrapped around to 0.
Also fix up the type of arguments to ext4_convert_unwritten_extents(),
it gets ssize_t from ext4_end_aio_dio_nolock() and
ext4_ext_direct_IO().
Reported-by: Giel de Nijs <giel@vectorwise.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: maximilian attems <max@stro.at>
commit 20f6b2c785cf187445f126321638ab8ba7aa7494 upstream.
xfssyncd processes a queue of work by detaching the queue and
then iterating over all the work items. It then sleeps for a
time period or until new work comes in. If new work is queued
while xfssyncd is actively processing the detached work queue,
it will not process that new work until after a sleep timeout
or the next work event queued wakes it.
Fix this by checking the work queue again before going to sleep.
Signed-off-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
commit f1f724e4b523d444c5a598d74505aefa3d6844d2 upstream.
The radix-tree code requires it's users to serialize tag updates
against other updates to the tree. While XFS protects tag updates
against each other it does not serialize them against updates of the
tree contents, which can lead to tag corruption. Fix the inode
cache to always take pag_ici_lock in exclusive mode when updating
radix tree tags.
Reported-by: Patrick Schreurs <patrick@news-service.com>
Tested-by: Patrick Schreurs <patrick@news-service.com>
commit 77d7a0c2eeb285c9069e15396703d0cb9690ac50 upstream.
The introduction of barriers to loop devices has created a new IO
order completion dependency that XFS does not handle. The loop
device implements barriers using fsync and so turns a log IO in the
XFS filesystem on the loop device into a data IO in the backing
filesystem. That is, the completion of log IOs in the loop
filesystem are now dependent on completion of data IO in the backing
filesystem.
This can cause deadlocks when a flush daemon issues a log force with
an inode locked because the IO completion of IO on the inode is
blocked by the inode lock. This in turn prevents further data IO
completion from occuring on all XFS filesystems on that CPU (due to
the shared nature of the completion queues). This then prevents the
log IO from completing because the log is waiting for data IO
completion as well.
The fix for this new completion order dependency issue is to make
the IO completion inode locking non-blocking. If the inode lock
can't be grabbed, simply requeue the IO completion back to the work
queue so that it can be processed later. This prevents the
completion queue from being blocked and allows data IO completion on
other inodes to proceed, hence avoiding completion order dependent
deadlocks.
commit cfce08c6bdfb20ade979284e55001ca1f100ed51 upstream.
If the lower file system driver has extended attributes disabled,
ecryptfs' own access functions return -ENOSYS instead of -EOPNOTSUPP.
This breaks execution of programs in the ecryptfs mount, since the
kernel expects the latter error when checking for security
capabilities in xattrs.
Signed-off-by: Christian Pulvermacher <pulvermacher@gmx.de>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 3a60a1686f0d51c99bd0df8ac93050fb6dfce647 upstream.
Create a getattr handler for eCryptfs symlinks that is capable of
reading the lower target and decrypting its path. Prior to this patch,
a stat's st_size field would represent the strlen of the encrypted path,
while readlink() would return the strlen of the decrypted path. This
could lead to confusion in some userspace applications, since the two
values should be equal.
https://bugs.launchpad.net/bugs/524919
Reported-by: Loïc Minier <loic.minier@canonical.com>
commit 133b8f9d632cc23715c6d72d1c5ac449e054a12a upstream.
Since tmpfs has no persistent storage, it pins all its dentries in memory
so they have d_count=1 when other file systems would have d_count=0.
->lookup is only used to create new dentries. If the caller doesn't
instantiate it, it's freed immediately at dput(). ->readdir reads
directly from the dcache and depends on the dentries being hashed.
When an ecryptfs mount is mounted, it associates the lower file and dentry
with the ecryptfs files as they're accessed. When it's umounted and
destroys all the in-memory ecryptfs inodes, it fput's the lower_files and
d_drop's the lower_dentries. Commit 4981e081 added this and a d_delete in
2008 and several months later commit caeeeecf removed the d_delete. I
believe the d_drop() needs to be removed as well.
The d_drop effectively hides any file that has been accessed via ecryptfs
from the underlying tmpfs since it depends on it being hashed for it to
be accessible. I've removed the d_drop on my development node and see no
ill effects with basic testing on both tmpfs and persistent storage.
As a side effect, after ecryptfs d_drops the dentries on tmpfs, tmpfs
BUGs on umount. This is due to the dentries being unhashed.
tmpfs->kill_sb is kill_litter_super which calls d_genocide to drop
the reference pinning the dentry. It skips unhashed and negative dentries,
but shrink_dcache_for_umount_subtree doesn't. Since those dentries
still have an elevated d_count, we get a BUG().
This patch removes the d_drop call and fixes both issues.
This issue was reported at:
https://bugzilla.novell.com/show_bug.cgi?id=567887
Reported-by: Árpád Bíró <biroa@demasz.hu>
Cc: Dustin Kirkland <kirkland@canonical.com>
commit f78233dd44a110c574fe760ad6f9c1e8741a0d00 upstream.
While investigating a bug, I came across a possible bug in v9fs. The
problem is similar to the one reported for NFS by ASANO Masahiro in
http://lkml.org/lkml/2005/12/21/334.
v9fs_file_lock() will skip locks on file which has mode set to 02666.
This is a problem in cases where the mode of the file is changed after
a process has obtained a lock on the file. Such a lock will be skipped
during unlock and the machine will end up with a BUG in
locks_remove_flock().
v9fs_file_lock() should skip the check for mandatory locks when
unlocking a file.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
commit 78c37eb0d5e6a9727b12ea0f1821795ffaa66cfe upstream.
In ocfs2_validate_gd_parent, we check bg_chain against the
cl_next_free_rec of the dinode. Actually in resize, we have
the chance of bg_chain == cl_next_free_rec. So add some
additional condition check for it.
I also rename paramter "clean_error" to "resize", since the
old one is not clearly enough to indicate that we should only
meet with this case in resize.
btw, the correpsonding bug is
http://oss.oracle.com/bugzilla/show_bug.cgi?id=1230.
commit fcefd25ac89239cb57fa198f125a79ff85468c75 upstream.
ocfs2_set_acl() and ocfs2_init_acl() were setting i_mode on the in-memory
inode, but never setting it on the disk copy. Thus, acls were some times not
getting propagated between nodes. This patch fixes the issue by adding a
helper function ocfs2_acl_set_mode() which does this the right way.
ocfs2_set_acl() and ocfs2_init_acl() are then updated to call
ocfs2_acl_set_mode().
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
commit 08261673cb6dc638c39f44d69b76fffb57b92a8b upstream.
dq_flags are modified non-atomically in do_set_dqblk via __set_bit calls and
atomically for example in mark_dquot_dirty or clear_dquot_dirty. Hence a
change done by an atomic operation can be overwritten by a change done by a
non-atomic one. Fix the problem by using atomic bitops even in do_set_dqblk.
Signed-off-by: Andrew Perepechko <andrew.perepechko@sun.com>
commit 462d60577a997aa87c935ae4521bd303733a9f2b upstream.
RFC says we need to follow the chain of mounts if there's more
than one stacked on that point.
commit 0df5dd4aae211edeeeb84f7f84f6d093406d7c22 upstream.
Arnaud Giersch reports that NFSv4 locking is broken when we hold a
delegation since commit 8e469ebd6dc32cbaf620e134d79f740bf0ebab79 (NFSv4:
Don't allow posix locking against servers that don't support it).
According to Arnaud, the lock succeeds the first time he opens the file
(since we cannot do a delegated open) but then fails after we start using
delegated opens.
The following patch fixes it by ensuring that locking behaviour is
governed by a per-filesystem capability flag that is initially set, but
gets cleared if the server ever returns an OPEN without the
NFS4_OPEN_RESULT_LOCKTYPE_POSIX flag being set.
Reported-by: Arnaud Giersch <arnaud.giersch@iut-bm.univ-fcomte.fr>
commit 80e60639f1b7c121a7fea53920c5a4b94009361a upstream.
commit a24e2d7d8f512340991ef0a59cb5d08d491b8e98 upstream.
By doing this we always overwrite nbytes value that is being passed on to
CIFSSMBWrite() and need not rely on the callers to initialize. CIFSSMBWrite2 is
doing this already.
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Reviewed-by: Jeff Layton <jlayton@samba.org>
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 6513a81e9325d712f1bfb9a1d7b750134e49ff18 upstream.
While chasing a bug report involving a OS/2 server, I noticed the server sets
pSMBr->CountHigh to a incorrect value even in case of normal writes. This
results in 'nbytes' being computed wrongly and triggers a kernel BUG at
mm/filemap.c.
void iov_iter_advance(struct iov_iter *i, size_t bytes)
BUG_ON(i->count < bytes); <--- BUG here
Why the server is setting 'CountHigh' is not clear but only does so after
writing 64k bytes. Though this looks like the server bug, the client side
crash may not be acceptable.
The workaround is to mask off high 16 bits if the number of bytes written as
returned by the server is greater than the bytes requested by the client as
suggested by Jeff Layton.
commit 55ab3a1ff843e3f0e24d2da44e71bffa5d853010 upstream.
Commit 148f948ba877f4d3cdef036b1ff6d9f68986706a (vfs: Introduce new
helpers for syncing after writing to O_SYNC file or IS_SYNC inode) broke
the raw driver.
We now call through generic_file_aio_write -> generic_write_sync ->
vfs_fsync_range. vfs_fsync_range has:
if (!fop || !fop->fsync) {
ret = -EINVAL;
goto out;
But drivers/char/raw.c doesn't set an fsync method.
We have two options: fix it or remove the raw driver completely. I'm
happy to do either, the fact this has been broken for so long suggests it
is rarely used.
The patch below adds an fsync method to the raw driver. My knowledge of
the block layer is pretty sketchy so this could do with a once over.
If we instead decide to remove the raw driver, this patch might still be
useful as a backport to 2.6.33 and 2.6.32.
Cc: Jens Axboe <jens.axboe@oracle.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Tested-by: Jeff Moyer <jmoyer@redhat.com>
commit b7b7fa43103a9fb30dbcc60cbd5161fdfc25f904 upstream.
Commit 8ebc423238341b52912c7295b045a32477b33f09 (reiserfs: kill-the-BKL)
introduced a bug in the mount failure case.
The error label releases the lock before calling journal_release_error,
but it requires that the lock be held. do_journal_release unlocks and
retakes it. When it releases it without it held, we trigger a BUG().
The error_alloc label skips the unlock since the lock isn't held yet
but none of the other conditions that are clean up exist yet either.
This patch returns immediately after the kzalloc failure and moves
the reiserfs_write_unlock after the journal_release_error call.
This was reported in https://bugzilla.novell.com/show_bug.cgi?id=591807
Reported-by: Thomas Siedentopf <thomas.siedentopf@novell.com>
Cc: Thomas Siedentopf <thomas.siedentopf@novell.com>
commit b95c35e76b29ba812e5dabdd91592e25ec640e93 upstream.
proc_oom_score(task) has a reference to task_struct, but that is all.
If this task was already released before we take tasklist_lock
- we can't use task->group_leader, it points to nowhere
- it is not safe to call badness() even if this task is
->group_leader, has_intersects_mems_allowed() assumes
it is safe to iterate over ->thread_group list.
- even worse, badness() can hit ->signal == NULL
Add the pid_alive() check to ensure __unhash_process() was not called.
Also, use "task" instead of task->group_leader. badness() should return
the same result for any sub-thread. Currently this is not true, but
this should be changed anyway.
commit 30d1872d9eb3663b4cf7bdebcbf5cd465674cced upstream.
When using the string representation of a random counter as part of the base
name, ensure that it is no longer than 4 bytes.
Since we are repeatedly decrementing the counter in a loop until we have found a
unique base name, the counter may wrap around zero; therefore, it is not enough
to mask its higher bits before entering the loop, this must be done inside the
loop.
[hirofumi@mail.parknet.co.jp: use snprintf()]
Signed-off-by: Nikolaus Schulz <microschulz@web.de>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit 720e7749279bde0d08684b1bb4e7a2eedeec6394 upstream.
gfs2_lock() will skip locks on file which have mode set to 02666. This is a problem in cases where the mode of the file is changed after a process has obtained a lock on the file. Such a lock will be skipped and will result in a BUG in locks_remove_flock().
gfs2_lock() should skip the check for mandatory locks when unlocking a file.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 0a5a9c725512461d19397490f3adf29931dca1f2 upstream.
If a delayed-allocation write happens before quota is enabled, the
kernel spits out a warning:
WARNING: at fs/quota/dquot.c:988 dquot_claim_space+0x77/0x112()
because the fact that user has some delayed allocation is not recorded
in quota structure.
Make dquot_initialize() update amount of reserved space for user if it sees
inode has some space reserved. Also make sure that reserved quota space does
not go negative and we warn about the filesystem bug just once.
commit c469070aea5a0ada45a836937c776fd3083dae2b upstream.
Since we implemented generic reserved space management interface,
then it is possible to account reserved space even when quota
is not active (similar to i_blocks/i_bytes).
Without this patch following testcase result in massive comlain from
WARN_ON in dquot_claim_space()
TEST_CASE:
mount /dev/sdb /mnt -oquota
dd if=/dev/zero of=/mnt/test bs=1M count=1
quotaon /mnt
# fs_reserved_spave == 1Mb
# quota_reserved_space == 0, because quota was disabled
dd if=/dev/zero of=/mnt/test seek=1 bs=1M count=1
# fs_reserved_spave == 2Mb
# quota_reserved_space == 1Mb
sync # ->dquot_claim_space() -> WARN_ON
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 110d735a0ae69bdd11af9acb6ea3b979137eb118 upstream.
According to the report from Andreas Beckmann (Message-ID:
<4BA54677.3090902@abeckmann.de>), nilfs in 2.6.33 kernel got stuck
after a disk full error.
This turned out to be a regression by log writer updates merged at
kernel 2.6.33. nilfs_segctor_abort_construction, which is a cleanup
function for erroneous cases, was skipping writeback completion for
some logs.
This fixes the bug and would resolve the hang issue.
Reported-by: Andreas Beckmann <debian@abeckmann.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 8e0cc811e0f8029a7225372fb0951fab102c012f upstream.
Smaller size than a minimum blocksize can't be used, after all it's
handled like 0 size.
For extended partition itself, this makes sure to use bigger size than one
logical sector size at least.
Cc: Daniel Taylor <Daniel.Taylor@wdc.com>
commit 3fbf586cf7f245392142e5407c2a56f1cff979b6 upstream.
In order to use disks larger than 2TiB on Windows XP, it is necessary to
use 4096-byte logical sectors in an MBR.
Although the kernel storage and functions called from msdos.c used
"sector_t" internally, msdos.c still used u32 variables, which results in
the ability to handle XP-compatible large disks.
This patch changes the internal variables to "sector_t".
Daniel said: "In the near future, WD will be releasing products that need
this patch".
[hirofumi@mail.parknet.co.jp: tweaks and fix]
Signed-off-by: Daniel Taylor <daniel.taylor@wdc.com>
commit d812e575822a2b7ab1a7cadae2571505ec6ec2bd upstream.
We should not attempt to free the page if __GFP_FS is not set. Otherwise we
can deadlock as per
http://bugzilla.kernel.org/show_bug.cgi?id=15578
commit bb6fbc4548b9ae7ebbd06ef72f00229df259d217 upstream.
J.R. Okajima reports the following deadlock:
INFO: task kswapd0:305 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
kswapd0 D 0000000000000001 0 305 2 0x00000000
ffff88001f21d4f0 0000000000000046 ffff88001fdea680 ffff88001f21c000
ffff88001f21dfd8 ffff88001f21c000 ffff88001f21dfd8 ffff88001f21dfd8
ffff88001fdea040 0000000000014c00 0000000000000001 ffff88001fdea040
Call Trace:
[<ffffffff8146155d>] io_schedule+0x4d/0x70
[<ffffffff810d2be5>] sync_page+0x65/0xa0
[<ffffffff81461b12>] __wait_on_bit_lock+0x52/0xb0
[<ffffffff810d2b80>] ? sync_page+0x0/0xa0
[<ffffffff810d2b64>] __lock_page+0x64/0x70
[<ffffffff81070ce0>] ? wake_bit_function+0x0/0x40
[<ffffffff810df1d4>] truncate_inode_pages_range+0x344/0x4a0
[<ffffffff810df340>] truncate_inode_pages+0x10/0x20
[<ffffffff8112cbfe>] generic_delete_inode+0x15e/0x190
[<ffffffff8112cc8d>] generic_drop_inode+0x5d/0x80
[<ffffffff8112bb88>] iput+0x78/0x80
[<ffffffff811bc908>] nfs_dentry_iput+0x38/0x50
[<ffffffff811285f4>] dentry_iput+0x84/0x110
[<ffffffff811286ae>] d_kill+0x2e/0x60
[<ffffffff8112912a>] dput+0x7a/0x170
[<ffffffff8111e925>] path_put+0x15/0x40
[<ffffffff811c3a44>] __put_nfs_open_context+0xa4/0xb0
[<ffffffff811cb5d0>] ? nfs_free_request+0x0/0x50
[<ffffffff811c3b0b>] put_nfs_open_context+0xb/0x10
[<ffffffff811cb5f9>] nfs_free_request+0x29/0x50
[<ffffffff81234b7e>] kref_put+0x8e/0xe0
[<ffffffff811cb594>] nfs_release_request+0x14/0x20
[<ffffffff811cf769>] nfs_find_and_lock_request+0x89/0xa0
[<ffffffff811d1180>] nfs_wb_page+0x80/0x110
[<ffffffff811c0770>] nfs_release_page+0x70/0x90
[<ffffffff810d18ee>] try_to_release_page+0x5e/0x80
[<ffffffff810e1178>] shrink_page_list+0x638/0x860
[<ffffffff810e19de>] shrink_zone+0x63e/0xc40
We can fix this by making the call to put_nfs_open_context() happen when we
actually remove the write request from the inode (which is done by the
nfsiod thread in this case).
commit b4d2314bb88b07e5a04e6c75b442a1dfcd60e340 upstream.
If the NFS_INO_REVAL_FORCED flag is set, that means that we don't yet have
an up to date attribute cache. Even if we hold a delegation, we must
put a GETATTR on the wire.
commit 76595f79d76fbe6267a51b3a866a028d150f06d4 upstream.
Modify uid check in do_coredump so as to not apply it in the case of
pipes.
This just got noticed in testing. The end of do_coredump validates the
uid of the inode for the created file against the uid of the crashing
process to ensure that no one can pre-create a core file with different
ownership and grab the information contained in the core when they
shouldn' tbe able to. This causes failures when using pipes for a core
dumps if the crashing process is not root, which is the uid of the pipe
when it is created.
The fix is simple. Since the check for matching uid's isn't relevant for
pipes (a process can't create a pipe that the uermodehelper code will open
anyway), we can just just skip it in the event ispipe is non-zero
Reverts a pipe-affecting change which was accidentally made in
: commit c46f739dd39db3b07ab5deb4e3ec81e1c04a91af
: Author: Ingo Molnar <mingo@elte.hu>
: AuthorDate: Wed Nov 28 13:59:18 2007 +0100
: Commit: Linus Torvalds <torvalds@woody.linux-foundation.org>
: CommitDate: Wed Nov 28 10:58:01 2007 -0800
: vfs: coredumping fix
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit ebed9203b68a4f333ce5d17e874b26c3afcfeff1 upstream.
sunrpc_cache_update() will always call detail->update() from inside the
detail->hash_lock, so it cannot allocate memory.
commit cbaee472f274ea9a98aabe47025f6e5551acadcb upstream.
In ocfs2_direct_IO_get_blocks, we only need to bug out
in case of we are going to write a recounted extent rec.
What a silly bug introduced by me!
commit 1e5289c97bba2d8ee7239a416bc3f28743362cd9 upstream.
When sysfs_readdir stops short we now cache the next
sysfs_dirent to return to user space in filp->private_data.
There is no impact on the rest of sysfs by doing this and
in the common case it allows us to pick up exactly where
we left off with no seeking.
Additionally I drop and regrab the sysfs_mutex around
filldir to avoid a page fault abritrarily increasing the
hold time on the sysfs_mutex.
v2: Returned to using INT_MAX as the EOF condition.
seekdir is ambiguous unless all directory entries have
a unique f_pos value.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14949
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
commit 42e49608683ab25fbbbf9c40edb944601e543882 upstream.
We'll introduce FMODE_RANDOM which will be runtime modified. So protect
all runtime modification to f_mode with f_lock to avoid races.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
803bf5ec259941936262d10ecc84511b76a20921 ("fs/exec.c: restrict initial
stack space expansion to rlimit") attempts to limit the initial stack to
20*PAGE_SIZE. Unfortunately, in attempting ensure the stack is not
reduced in size, we ended up not changing the stack at all.
This size reduction check is not necessary as the expand_stack call does
this already.
This caused a regression in UML resulting in most guest processes being
killed.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Jouni Malinen <j@w1.fi>
Cc: <stable@kernel.org>
cachefiles_delete_object() can race with rename. It gets the parent directory
of the object it's asked to delete, then locks it - but rename may have changed
the object's parent between the get and the completion of the lock.
However, if such a circumstance is detected, we abandon our attempt to delete
the object - since it's no longer in the index key path, it won't be seen
again by lookups of that key. The assumption is that cachefilesd may have
culled it by renaming it to the graveyard for later destruction.
commit 1e41568d7378d1ba8c64ba137b9ddd00b59f893a ("Take ima_path_check()
in nfsd past dentry_open() in nfsd_open()") moved this code back to its
original location but missed the "else".
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
