commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream.
The callback must not return -1 when nr_to_scan is zero. Fix the bug in
fs/super.c and add this requirement to the callback specification.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit bc5b8a9003132ae44559edd63a1623b7b99dfb68 upstream.
On a corrupted file system the ->len field could be wrong leading to
a buffer overflow.
Reported-and-acked-by: Clement LECIGNE <clement.lecigne@netasq.com>
commit a3fbbde70a0cec017f2431e8f8de208708c76acc upstream.
Mountpoint crossing is similar to following procfs symlinks - we do
not get ->d_revalidate() called for dentry we have arrived at, with
unpleasant consequences for NFS4.
Simple way to reproduce the problem in mainline:
cat >/tmp/a.c <<'EOF'
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
main()
struct flock fl = {.l_type = F_RDLCK, .l_whence = SEEK_SET, .l_len = 1};
if (fcntl(0, F_SETLK, &fl))
perror("setlk");
EOF
cc /tmp/a.c -o /tmp/test
then on nfs4:
mount --bind file1 file2
/tmp/test < file1 # ok
/tmp/test < file2 # spews "setlk: No locks available"...
What happens is the missing call of ->d_revalidate() after mountpoint
crossing and that's where NFS4 would issue OPEN request to server.
The fix is simple - treat mountpoint crossing the same way we deal with
following procfs-style symlinks. I.e. set LOOKUP_JUMPED...
commit 5c8a0fbba543d9428a486f0d1282bbcf3cf1d95a upstream.
No one in their right mind would expect statfs() to not work on a
automounter managed mount point. Fix it.
[ I'm not sure about the "no one in their right mind" part. It's not
mounted, and you didn't ask for it to be mounted. But nobody will
really care, and this probably makes it match previous semantics, so..
- Linus ]
This mirrors the fix made to the quota code in 815d405ceff0d69646.
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit f992ae801a7dec34a4ed99a6598bbbbfb82af4fb upstream.
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
commit 6d6a435190bdf2e04c9465cde5bdc3ac68cf11a4 upstream.
Ceph users reported that when using Ceph on ext4, the filesystem
would often become corrupted, containing inodes with incorrect
i_blocks counters.
I managed to reproduce this with a very hacked-up "streamtest"
binary from the Ceph tree.
Ceph is doing a lot of xattr writes, to out-of-inode blocks.
There is also another thread which does sync_file_range and close,
of the same files. The problem appears to happen due to this race:
sync/flush thread xattr-set thread
do_writepages ext4_xattr_set
ext4_da_writepages ext4_xattr_set_handle
mpage_da_map_blocks ext4_xattr_block_set
set DELALLOC_RESERVE
ext4_new_meta_blocks
ext4_mb_new_blocks
if (!i_delalloc_reserved_flag)
vfs_dq_alloc_block
ext4_get_blocks
down_write(i_data_sem)
set i_delalloc_reserved_flag
up_write(i_data_sem)
if (i_delalloc_reserved_flag)
vfs_dq_alloc_block_nofail
In other words, the sync/flush thread pops in and sets
i_delalloc_reserved_flag on the inode, which makes the xattr thread
think that it's in a delalloc path in ext4_new_meta_blocks(),
and add the block for a second time, after already having added
it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks
The real problem is that we shouldn't be using the DELALLOC_RESERVED
state flag, and instead we should be passing
EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of
using an inode state flag. We'll fix this for now with using
i_data_sem to prevent this race, but this is really not the right way
to fix things.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit fcbb5515825f1bb20b7a6f75ec48bee61416f879 upstream.
The started journal handle should be stopped in failure case.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Acked-by: Jan Kara <jack@suse.cz>
commit 5930ea643805feb50a2f8383ae12eb6f10935e49 upstream.
ext4_dx_add_entry manipulates bh2 and frames[0].bh, which are two buffer_heads
that point to directory blocks assigned to the directory inode. However, the
function calls ext4_handle_dirty_metadata with the inode of the file that's
being added to the directory, not the directory inode itself. Therefore,
correct the code to dirty the directory buffers with the directory inode, not
the file inode.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
commit f9287c1f2d329f4d78a3bbc9cf0db0ebae6f146a upstream.
ext4_mkdir calls ext4_handle_dirty_metadata with dir_block and the inode "dir".
Unfortunately, dir_block belongs to the newly created directory (which is
"inode"), not the parent directory (which is "dir"). Fix the incorrect
association.
commit bcaa992975041e40449be8c010c26192b8c8b409 upstream.
When ext4_rename performs a directory rename (move), dir_bh is a
buffer that is modified to update the '..' link in the directory being
moved (old_inode). However, ext4_handle_dirty_metadata is called with
the old parent directory inode (old_dir) and dir_bh, which is
incorrect because dir_bh does not belong to the parent inode. Fix
this error.
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
commit a3defbe5c337dbc6da911f8cc49ae3cc3b49b453 upstream.
The case of address space randomization being disabled in runtime through
randomize_va_space sysctl is not treated properly in load_elf_binary(),
resulting in SIGKILL coming at exec() time for certain PIE-linked binaries
in case the randomization has been disabled at runtime prior to calling
exec().
Handle the randomize_va_space == 0 case the same way as if we were not
supporting .text randomization at all.
Based on original patch by H.J. Lu and Josh Boyer.
Cc: H.J. Lu <hongjiu.lu@intel.com>
Cc: <stable@kernel.org>
Tested-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
commit 1fa1e7f615f4d3ae436fa319af6e4eebdd4026a8 upstream.
Since the commit below which added O_PATH support to the *at() calls, the
error return for readlink/readlinkat for the empty pathname has switched
from ENOENT to EINVAL:
commit 65cfc6722361570bfe255698d9cd4dccaf47570d
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Mar 13 15:56:26 2011 -0400
readlinkat(), fchownat() and fstatat() with empty relative pathnames
This is both unexpected for userspace and makes readlink/readlinkat
inconsistant with all other interfaces; and inconsistant with our stated
return for these pathnames.
As the readlinkat call does not have a flags parameter we cannot use the
AT_EMPTY_PATH approach used in the other calls. Therefore expose whether
the original path is infact entry via a new user_path_at_empty() path
lookup function. Use this to determine whether to default to EINVAL or
ENOENT for failures.
Addresses http://bugs.launchpad.net/bugs/817187
[akpm@linux-foundation.org: remove unused getname_flags()]
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit fc360bd9cdcf875639a77f07fafec26699c546f3 upstream.
The display of the "huge" tag was accidentally removed in 29ea2f698 ("mm:
use walk_page_range() instead of custom page table walking code").
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Stephen Wilson <wilsons@start.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit a877ee03ac010ded434b77f7831f43cbb1fcc60f upstream.
nfsiostat was failing to find mounted filesystems on kernels after
2.6.38 because of changes to show_vfsstat() by commit
c7f404b40a3665d9f4e9a927cc5c1ee0479ed8f9. This patch adds back the
"device" tag before the nfs server entry so scripts can parse the
mountstats file correctly.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
commit c30e92df30d7d5fe65262fbce5d1b7de675fe34e upstream.
We don't use WANT bits yet--and sending them can probably trigger a
BUG() further down.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 3d02fa29dec920c597dd7b7db608a4bc71f088ce upstream.
Yet another open-management regression:
- nfs4_file_downgrade() doesn't remove the BOTH access bit on
downgrade, so the server's idea of the stateid's access gets
out of sync with the client's. If we want to keep an O_RDWR
open in this case, we should do that in the file_put_access
logic rather than here.
- We forgot to convert v4 access to an open mode here.
This logic has proven too hard to get right. In the future we may
consider:
- reexamining the lock/openowner relationship (locks probably
don't really need to take their own references here).
- adding open upgrade/downgrade support to the vfs.
- removing the atomic operations. They're redundant as long as
this is all under some other lock.
Also, maybe some kind of additional static checking would help catch
O_/NFS4_SHARE_ACCESS confusion.
commit a043226bc140a2c1dde162246d68a67e5043e6b2 upstream.
A client that wants to execute a file must be able to read it. Read
opens over nfs are therefore implicitly allowed for executable files
even when those files are not readable.
NFSv2/v3 get this right by using a passed-in NFSD_MAY_OWNER_OVERRIDE on
read requests, but NFSv4 has gotten this wrong ever since
dc730e173785e29b297aa605786c94adaffe2544 "nfsd4: fix owner-override on
open", when we realized that the file owner shouldn't override
permissions on non-reclaim NFSv4 opens.
So we can't use NFSD_MAY_OWNER_OVERRIDE to tell nfsd_permission to allow
reads of executable files.
So, do the same thing we do whenever we encounter another weird NFS
permission nit: define yet another NFSD_MAY_* flag.
The industry's future standardization on 128-bit processors will be
motivated primarily by the need for integers with enough bits for all
the NFSD_MAY_* flags.
Reported-by: Leonardo Borda <leonardoborda@gmail.com>
commit 576163005de286bbd418fcb99cfd0971523a0c6d upstream.
The set of errors here does *not* agree with the set of errors specified
in the rfc!
While we're there, turn this macros into a function, for the usual
reasons, and move it to the one place where it's actually used.
commit 3e77246393c0a433247631a1f0e9ec98d3d78a1c upstream.
The server is returning nfserr_resource for both permanent errors and
for errors (like allocation failures) that might be resolved by retrying
later. Save nfserr_resource for the former and use delay/jukebox for
the latter.
commit 832023bffb4b493f230be901f681020caf3ed1f8 upstream.
Fan Yong <yong.fan@whamcloud.com> noticed setting
FMODE_32bithash wouldn't work with nfsd v4, as
nfsd4_readdir() checks for 32 bit cookies. However, according to RFC 3530
cookies have a 64 bit type and cookies are also defined as u64 in
'struct nfsd4_readdir'. So remove the test for >32-bit values.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit 2da956523526e440ef4f4dd174e26f5ac06fe011 upstream.
nfs_find_and_lock_request will take a reference to the nfs_page and
will then put it if the req is already locked. It's possible though
that the reference will be the last one. That put then can kick off
a whole series of reference puts:
nfs_page
nfs_open_context
dentry
inode
If the inode ends up being deleted, then the VFS will call
truncate_inode_pages. That function will try to take the page lock, but
it was already locked when migrate_page was called. The code
deadlocks.
Fix this by simply refusing the migration request if PagePrivate is
already set, indicating that the page is already associated with an
active read or write request.
We've had a customer test a backported version of this patch and
the preliminary results seem good.
Reported-by: Harshula Jayasuriya <harshula@redhat.com>
commit 3236c3e1adc0c7ec83eaff1de2d06746b7c5bb28 upstream.
commit 420e3646 allowed the kernel to reduce the number of unnecessary
commit calls by skipping the commit when there are a large number of
outstanding pages.
However, the current test in nfs_commit_unstable_pages does not handle
the edge condition properly. When ncommit == 0, then that means that the
kernel doesn't need to do anything more for the inode. The current test
though in the WB_SYNC_NONE case will return true, and the inode will end
up being marked dirty. Once that happens the inode will never be clean
until there's a WB_SYNC_ALL flush.
Fix this by immediately returning from nfs_commit_unstable_pages when
ncommit == 0.
Mike noticed this problem initially in RHEL5 (2.6.18-based kernel) which
has a backported version of 420e3646. The inode cache there was growing
very large. The inode cache was unable to be shrunk since the inodes
were all marked dirty. Calling sync() would essentially "fix" the
problem -- the WB_SYNC_ALL flush would result in the inodes all being
marked clean.
What I'm not clear on is how big a problem this is in mainline kernels
as the writeback code there is very different. Either way, it seems
incorrect to re-mark the inode dirty in this case.
Reported-by: Mike McLean <mikem@redhat.com>
commit c1225158a8dad9e9d5eee8a17dbbd9c7cda05ab9 upstream.
The same function is used by idmap, gss and blocklayout code. Make it
generic.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
syncing"
commit 59b7c05fffba030e5d9e72324691e2f99aa69b79 upstream.
This reverts commit b80c3cb628f0ebc241b02e38dd028969fb8026a2.
The reverted commit was rendered obsolete by a VFS fix: commit
5547e8aac6f71505d621a612de2fca0dd988b439 (writeback: Update dirty flags in
two steps). We now no longer need to worry about writeback_single_inode()
missing our marking the inode for COMMIT in 'do_writepages()' call.
Reverting this patch, fixes a performance regression in which the inode
would continuously get queued to the dirty list, causing the writeback
code to unnecessarily try to send a COMMIT.
Tested-by: Simon Kirby <sim@hostway.ca>
commit 7542274519b3ba87555410c66e8356ac1e3bc9b3 upstream.
We should check if the sector is already initialized before
trying to grab the page from page cache. Otherwise when two
pages of the same block are written back by two threads each
calling from writepage_locked, it can cause deadlock like bellow.
[ 1080.972099] INFO: task kswapd0:25 blocked for more than 120 seconds.
[ 1080.972377] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1080.972812] kswapd0 D ffff88000c4926c0 0 25 2 0x00000000
[ 1080.972816] ffff88000df276b0 0000000000000046 ffff88000df27640 ffffffff81013ba7
[ 1080.972821] ffff88000c492310 ffff88000df27fd8 ffff88000df27fd8 00000000001d3440
[ 1080.972824] ffff88000c378000 ffff88000c492310 ffff8800175d3d40 ffff880017fc75a8
[ 1080.972828] Call Trace:
[ 1080.972860] [<ffffffff81013ba7>] ? read_tsc+0x9/0x19
[ 1080.972877] [<ffffffff810e0b23>] ? lock_page+0x2b/0x2b
[ 1080.972899] [<ffffffff81475a1d>] io_schedule+0x63/0x7e
[ 1080.972902] [<ffffffff810e0b31>] sleep_on_page+0xe/0x12
[ 1080.972905] [<ffffffff81475fe8>] __wait_on_bit_lock+0x46/0x8f
[ 1080.972916] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.972919] [<ffffffff810e0af6>] __lock_page+0x66/0x68
[ 1080.972928] [<ffffffff81072705>] ? autoremove_wake_function+0x3d/0x3d
[ 1080.972932] [<ffffffff810e0b1f>] lock_page+0x27/0x2b
[ 1080.972934] [<ffffffff810e0bcf>] find_lock_page+0x34/0x57
[ 1080.972937] [<ffffffff810e1738>] find_or_create_page+0x34/0x8a
[ 1080.972947] [<ffffffffa034245b>] bl_write_pagelist+0x205/0x6da [blocklayoutdriver]
[ 1080.972951] [<ffffffffa034145d>] ? bl_free_lseg+0x38/0x38 [blocklayoutdriver]
[ 1080.972995] [<ffffffffa02e27b9>] ? nfs_write_rpcsetup+0x118/0x123 [nfs]
[ 1080.973033] [<ffffffffa030246b>] pnfs_generic_pg_writepages+0x10b/0x1f4 [nfs]
[ 1080.973089] [<ffffffffa02deaae>] nfs_pageio_doio+0x1a/0x43 [nfs]
[ 1080.973098] [<ffffffffa02df035>] nfs_pageio_complete+0x16/0x2d [nfs]
[ 1080.973108] [<ffffffffa02e2d8f>] nfs_writepage_locked+0xa0/0xbf [nfs]
[ 1080.973119] [<ffffffffa02e36a1>] nfs_writepage+0x16/0x2b [nfs]
[ 1080.973122] [<ffffffff810e8762>] ? clear_page_dirty_for_io+0x87/0x9a
[ 1080.973133] [<ffffffff810efc5b>] shrink_page_list+0x39b/0x6c8
[ 1080.973139] [<ffffffff810f03bb>] shrink_inactive_list+0x22c/0x39e
[ 1080.973144] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.973148] [<ffffffff810f0c33>] shrink_zone+0x445/0x588
[ 1080.973152] [<ffffffff810f1a11>] balance_pgdat+0x2c2/0x56b
[ 1080.973170] [<ffffffff81254208>] ? __bitmap_weight+0x34/0x80
[ 1080.973175] [<ffffffff810f1f78>] kswapd+0x2be/0x2fa
[ 1080.973179] [<ffffffff810726c8>] ? __init_waitqueue_head+0x4b/0x4b
[ 1080.973183] [<ffffffff810f1cba>] ? balance_pgdat+0x56b/0x56b
[ 1080.973187] [<ffffffff81071f69>] kthread+0xa8/0xb0
[ 1080.973200] [<ffffffff814806b4>] kernel_thread_helper+0x4/0x10
[ 1080.973205] [<ffffffff81071ec1>] ? __init_kthread_worker+0x5a/0x5a
[ 1080.973210] [<ffffffff814806b0>] ? gs_change+0x13/0x13
[ 1080.973213] no locks held by kswapd0/25.
commit e6d05a757c314ad88d0649d3835a8a1daa964236 upstream.
bl_add_page_to_bio returns error pointer. bio should be reset to
NULL in failure cases as the out path always calls bl_submit_bio.
commit 9b7eecdcfeb943f130d86bbc249fde4994b6fe30 upstream.
For pnfs pagelist read failure, we need to pg_recoalesce and resend IO to
mds.
commit 8ce160c5ef06cc89c2b6b26bfa5ef7a5ce2c93e0 upstream.
For pnfs pagelist write failure, we need to pg_recoalesce and resend IO to
mds.
commit 1b0ae068779874f54b55aac3a2a992bcf3f2c3c4 upstream.
file layout and block layout both use it to set mark layout io failure
bit. So make it generic.
commit 760383f1ee4d14b0e0bdf0cddee648d9b8633429 upstream.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
commit fdc17abbc4b6094b34ee8ff5d91eaba8637594a2 upstream.
Make the status field explicitly 32 bits. "...it's unlikely that the kernel
and userspace would differ on the size of an int here, but it might be a
good idea to go ahead and make that explicitly 32 bits in case we end up
dealing with more exotic arches at some point in the future."
Suggested-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Benny Halevy <bhalevy@tonian.com>
commit 516f2e24faa7548a61d9ba790958528469c2e284 upstream.
Always return PTR_ERR, not NULL, from nfs4_blk_get_deviceinfo and
nfs4_blk_decode_device.
Check for IS_ERR, not NULL, in bl_set_layoutdriver when calling
nfs4_blk_get_deviceinfo.
commit d8805e633e054c816c47cb6e727c81f156d9253d upstream.
epoll can acquire recursively acquire ep->mtx on multiple "struct
eventpoll"s at once in the case where one epoll fd is monitoring another
epoll fd. This is perfectly OK, since we're careful about the lock
ordering, but it causes spurious lockdep warnings. Annotate the recursion
using mutex_lock_nested, and add a comment explaining the nesting rules
for good measure.
Recent versions of systemd are triggering this, and it can also be
demonstrated with the following trivial test program:
--------------------8<--------------------
int main(void) {
int e1, e2;
struct epoll_event evt = {
.events = EPOLLIN
e1 = epoll_create1(0);
e2 = epoll_create1(0);
epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt);
return 0;
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Tested-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Nelson Elhage <nelhage@nelhage.com>
Acked-by: Jason Baron <jbaron@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
commit 42274bb22afc3e877ae5abed787b0b09d7dede52 upstream.
We should call cifs_all_info_to_fattr in rc == 0 case only.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 94443f43404239c2a6dc4252a7cb9e77f5b1eb6e upstream.
..the length field has only 17 bits.
Acked-by: Jeff Layton <jlayton@samba.org>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: revert to using a kthread for AIL pushing
xfs: force the log if we encounter pinned buffers in .iop_pushbuf
xfs: do not update xa_last_pushed_lsn for locked items
* 'btrfs-3.0' of git://github.com/chrismason/linux:
Btrfs: make sure not to defrag extents past i_size
Btrfs: fix recursive auto-defrag
Currently we have a few issues with the way the workqueue code is used to
implement AIL pushing:
- it accidentally uses the same workqueue as the syncer action, and thus
can be prevented from running if there are enough sync actions active
in the system.
- it doesn't use the HIGHPRI flag to queue at the head of the queue of
work items
At this point I'm not confident enough in getting all the workqueue flags and
tweaks right to provide a perfectly reliable execution context for AIL
pushing, which is the most important piece in XFS to make forward progress
when the log fills.
Revert back to use a kthread per filesystem which fixes all the above issues
at the cost of having a task struct and stack around for each mounted
filesystem. In addition this also gives us much better ways to diagnose
any issues involving hung AIL pushing and removes a small amount of code.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
If an item was locked we should not update xa_last_pushed_lsn and thus skip
it when restarting the AIL scan as we need to be able to lock and write it
out as soon as possible. Otherwise heavy lock contention might starve AIL
pushing too easily, especially given the larger backoff once we moved
xa_last_pushed_lsn all the way to the target lsn.
The btrfs file defrag code will loop through the extents and
force COW on them. But there is a concurrent truncate in the middle of
the defrag, it might end up defragging the same range over and over
again.
The problem is that writepage won't go through and do anything on pages
past i_size, so the cow won't happen, so the file will appear to still
be fragmented. defrag will end up hitting the same extents again and
again.
In the worst case, the truncate can actually live lock with the defrag
because the defrag keeps creating new ordered extents which the truncate
code keeps waiting on.
The fix here is to make defrag check for i_size inside the main loop,
instead of just once before the looping starts.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Follow those steps:
# mount -o autodefrag /dev/sda7 /mnt
# dd if=/dev/urandom of=/mnt/tmp bs=200K count=1
# sync
# dd if=/dev/urandom of=/mnt/tmp bs=8K count=1 conv=notrunc
and then it'll go into a loop: writeback -> defrag -> writeback ...
It's because writeback writes [8K, 200K] and then writes [0, 8K].
I tried to make writeback know if the pages are dirtied by defrag,
but the patch was a bit intrusive. Here I simply set writeback_index
when we defrag a file.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
* git://git.samba.org/sfrench/cifs-2.6:
[CIFS] Fix first time message on mount, ntlmv2 upgrade delayed to 3.2
Microsoft has a bug with ntlmv2 that requires use of ntlmssp, but
we didn't get the required information on when/how to use ntlmssp to
old (but once very popular) legacy servers (various NT4 fixpacks
for example) until too late to merge for 3.1. Will upgrade
to NTLMv2 in NTLMSSP in 3.2
Btrfs: force a page fault if we have a shorty copy on a page boundary
A user reported a problem where ceph was getting into 100% cpu usage while doing
some writing. It turns out it's because we were doing a short write on a not
uptodate page, which means we'd fall back at one page at a time and fault the
page in. The problem is our position is on the page boundary, so our fault in
logic wasn't actually reading the page, so we'd just spin forever or until the
page got read in by somebody else. This will force a readpage if we end up
doing a short copy. Alexandre could reproduce this easily with ceph and reports
it fixes his problem. I also wrote a reproducer that no longer hangs my box
with this patch. Thanks,
Reported-and-tested-by: Alexandre Oliva <aoliva@redhat.com>
Signed-off-by: Josef Bacik <josef@redhat.com>
That flag no longer makes sense, since we don't look up automount points
as eagerly any more. Additionally, it turns out that the NO_AUTOMOUNT
handling was buggy to begin with: it would avoid automounting even for
cases where we really *needed* to do the automount handling, and could
return ENOENT for autofs entries that hadn't been instantiated yet.
With our new non-eager automount semantics, one discussion has been
about adding a AT_AUTOMOUNT flag to vfs_fstatat (and thus the
newfstatat() and fstatat64() system calls), but it's probably not worth
it: you can always force at least directory automounting by simply
adding the final '/' to the filename, which works for *all* of the stat
family system calls, old and new.
So AT_NO_AUTOMOUNT (and thus LOOKUP_NO_AUTOMOUNT) really were just a
result of our bad default behavior.
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
The concensus seems to be that system calls such as stat() etc should
not trigger an automount. Neither should the l* versions.
This patch therefore adds a LOOKUP_AUTOMOUNT flag to tag those lookups
that _should_ trigger an automount on the last path element.
[ Edited to leave out the cases that are already covered by LOOKUP_OPEN,
LOOKUP_DIRECTORY and LOOKUP_CREATE - all of which also fundamentally
force automounting for their own reasons - Linus ]
