path: root/fs
2014-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes, both -stable fodder. The O_SYNC bug is fairly old..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fix a kmap leak in virtio_console fix O_SYNC|O_APPEND syncing the wrong range on write()
2014-02-09fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix data corruption when reading/updating compressed extents Btrfs: don't loop forever if we can't run because of the tree mod log btrfs: reserve no transaction units in btrfs_ioctl_set_features btrfs: commit transaction after setting label and features Btrfs: fix assert screwup for the pending move stuff
2014-02-08Btrfs: fix data corruption when reading/updating compressed extentsFilipe David Borba Manana
When using a mix of compressed file extents and prealloc extents, it is possible to fill a page of a file with random, garbage data from some unrelated previous use of the page, instead of a sequence of zeroes. A simple sequence of steps to get into such case, taken from the test case I made for xfstests, is: _scratch_mkfs _scratch_mount "-o compress-force=lzo" $XFS_IO_PROG -f -c "pwrite -S 0x06 -b 18670 266978 18670" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "falloc 26450 665194" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "truncate 542872" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foobar This results in the following file items in the fs tree: item 4 key (257 INODE_ITEM 0) itemoff 15879 itemsize 160 inode generation 6 transid 6 size 542872 block group 0 mode 100600 item 5 key (257 INODE_REF 256) itemoff 15863 itemsize 16 inode ref index 2 namelen 6 name: foobar item 6 key (257 EXTENT_DATA 0) itemoff 15810 itemsize 53 extent data disk byte 0 nr 0 gen 6 extent data offset 0 nr 24576 ram 266240 extent compression 0 item 7 key (257 EXTENT_DATA 24576) itemoff 15757 itemsize 53 prealloc data disk byte 12849152 nr 241664 gen 6 prealloc data offset 0 nr 241664 item 8 key (257 EXTENT_DATA 266240) itemoff 15704 itemsize 53 extent data disk byte 12845056 nr 4096 gen 6 extent data offset 0 nr 20480 ram 20480 extent compression 2 item 9 key (257 EXTENT_DATA 286720) itemoff 15651 itemsize 53 prealloc data disk byte 13090816 nr 405504 gen 6 prealloc data offset 0 nr 258048 The on disk extent at offset 266240 (which corresponds to 1 single disk block), contains 5 compressed chunks of file data. Each of the first 4 compress 4096 bytes of file data, while the last one only compresses 3024 bytes of file data. Therefore a read into the file region [285648 ; 286720[ (length = 4096 - 3024 = 1072 bytes) should always return zeroes (our next extent is a prealloc one). The solution here is the compression code path to zero the remaining (untouched) bytes of the last page it uncompressed data into, as the information about how much space the file data consumes in the last page is not known in the upper layer fs/btrfs/extent_io.c:__do_readpage(). In __do_readpage we were correctly zeroing the remainder of the page but only if it corresponds to the last page of the inode and if the inode's size is not a multiple of the page size. This would cause not only returning random data on reads, but also permanently storing random data when updating parts of the region that should be zeroed. For the example above, it means updating a single byte in the region [285648 ; 286720[ would store that byte correctly but also store random data on disk. A test case for xfstests follows soon. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Btrfs: don't loop forever if we can't run because of the tree mod logJosef Bacik
A user reported a 100% cpu hang with my new delayed ref code. Turns out I forgot to increase the count check when we can't run a delayed ref because of the tree mod log. If we can't run any delayed refs during this there is no point in continuing to look, and we need to break out. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08btrfs: reserve no transaction units in btrfs_ioctl_set_featuresDavid Sterba
Added in patch "btrfs: add ioctls to query/change feature bits online" modifications to superblock don't need to reserve metadata blocks when starting a transaction. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08btrfs: commit transaction after setting label and featuresJeff Mahoney
The set_fslabel ioctl uses btrfs_end_transaction, which means it's possible that the change will be lost if the system crashes, same for the newly set features. Let's use btrfs_commit_transaction instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Btrfs: fix assert screwup for the pending move stuffJosef Bacik
Wang noticed that he was failing btrfs/030 even though me and Filipe couldn't reproduce. Turns out this is because Wang didn't have CONFIG_BTRFS_ASSERT set, which meant that a key part of Filipe's original patch was not being built in. This appears to be a mess up with merging Filipe's patch as it does not exist in his original patch. Fix this by changing how we make sure del_waiting_dir_move asserts that it did not error and take the function out of the ifdef check. This makes btrfs/030 pass with the assert on or off. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Reviewed-by: Filipe Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Merge tag 'jfs-3.14-rc2' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Fix regression" * tag 'jfs-3.14-rc2' of git://github.com/kleikamp/linux-shaggy: jfs: fix generic posix ACL regression
2014-02-08jfs: fix generic posix ACL regressionDave Kleikamp
I missed a couple errors in reviewing the patches converting jfs to use the generic posix ACL function. Setting ACL's currently fails with -EOPNOTSUPP. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Reported-by: Michael L. Semon <mlsemon35@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2014-02-07Merge tag 'driver-core-3.14-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fix from Greg KH: "Here is a single kernfs fix to resolve a much-reported lockdep issue with the removal of entries in sysfs" * tag 'driver-core-3.14-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: kernfs: make kernfs_deactivate() honor KERNFS_LOCKDEP flag
2014-02-06mm: __set_page_dirty uses spin_lock_irqsave instead of spin_lock_irqKOSAKI Motohiro
To use spin_{un}lock_irq is dangerous if caller disabled interrupt. During aio buffer migration, we have a possibility to see the following call stack. aio_migratepage [disable interrupt] migrate_page_copy clear_page_dirty_for_io set_page_dirty __set_page_dirty_buffers __set_page_dirty spin_lock_irq This mean, current aio migration is a deadlockable. spin_lock_irqsave is a safer alternative and we should use it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: David Rientjes rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-06ocfs2: free allocated clusters if error occurs after ocfs2_claim_clustersZongxun Wang
Even if using the same jbd2 handle, we cannot rollback a transaction. So once some error occurs after successfully allocating clusters, the allocated clusters will never be used and it means they are lost. For example, call ocfs2_claim_clusters successfully when expanding a file, but failed in ocfs2_insert_extent. So we need free the allocated clusters if they are not used indeed. Signed-off-by: Zongxun Wang <wangzongxun@huawei.com> Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-05execve: use 'struct filename *' for executable name passingLinus Torvalds
This changes 'do_execve()' to get the executable name as a 'struct filename', and to free it when it is done. This is what the normal users want, and it simplifies and streamlines their error handling. The controlled lifetime of the executable name also fixes a use-after-free problem with the trace_sched_process_exec tracepoint: the lifetime of the passed-in string for kernel users was not at all obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize the pathname allocation lifetime with the execve() having finished, which in turn meant that the trace point that happened after mm_release() of the old process VM ended up using already free'd memory. To solve the kernel string lifetime issue, this simply introduces "getname_kernel()" that works like the normal user-space getname() function, except with the source coming from kernel memory. As Oleg points out, this also means that we could drop the tcomm[] array from 'struct linux_binprm', since the pathname lifetime now covers setup_new_exec(). That would be a separate cleanup. Reported-by: Igor Zhbanov <i.zhbanov@samsung.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-05kernfs: make kernfs_deactivate() honor KERNFS_LOCKDEP flagTejun Heo
kernfs_deactivate() forgot to check whether KERNFS_LOCKDEP is set before performing lockdep annotations and ends up feeding uninitialized lockdep_map to lockdep triggering warning like the following on USB stick hotunplug. usb 1-2: USB disconnect, device number 2 INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. CPU: 1 PID: 62 Comm: khubd Not tainted 3.13.0-work+ #82 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 ffff880065ca7f60 ffff88013a4ffa08 ffffffff81cfb6bd 0000000000000002 ffff88013a4ffac8 ffffffff810f8530 ffff88013a4fc710 0000000000000002 ffff880100000000 ffffffff82a3db50 0000000000000001 ffff88013a4fc710 Call Trace: [<ffffffff81cfb6bd>] dump_stack+0x4e/0x7a [<ffffffff810f8530>] __lock_acquire+0x1910/0x1e70 [<ffffffff810f931a>] lock_acquire+0x9a/0x1d0 [<ffffffff8127c75e>] kernfs_deactivate+0xee/0x130 [<ffffffff8127d4c8>] kernfs_addrm_finish+0x38/0x60 [<ffffffff8127d701>] kernfs_remove_by_name_ns+0x51/0xa0 [<ffffffff8127b4f1>] remove_files.isra.1+0x41/0x80 [<ffffffff8127b7e7>] sysfs_remove_group+0x47/0xa0 [<ffffffff8127b873>] sysfs_remove_groups+0x33/0x50 [<ffffffff8177d66d>] device_remove_attrs+0x4d/0x80 [<ffffffff8177e25e>] device_del+0x12e/0x1d0 [<ffffffff819722c2>] usb_disconnect+0x122/0x1a0 [<ffffffff819749b5>] hub_thread+0x3c5/0x1290 [<ffffffff810c6a6d>] kthread+0xed/0x110 [<ffffffff81d0a56c>] ret_from_fork+0x7c/0xb0 Fix it by making kernfs_deactivate() perform lockdep annotations only if KERNFS_LOCKDEP is set. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Fabio Estevam <festevam@gmail.com> Reported-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Jiri Kosina <jkosina@suse.cz> Reported-by: Dave Jones <davej@redhat.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is fixing compile and boot problems with our crc32c rework, and Josef has disabled snapshot aware defrag for now. As the number of snapshots increases, we're hitting OOM. For the short term we're disabling things until a bigger fix is ready" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use late_initcall instead of module_init Btrfs: use btrfs_crc32c everywhere instead of libcrc32c Btrfs: disable snapshot aware defrag for now
2014-02-04Merge tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix NFSv3 acl regressions - Fix NFSv4 memory corruption due to slot table abuse in nfs4_proc_open_confirm - nfs4_destroy_session must call rpc_destroy_waitqueue" * tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: fs: get_acl() must be allowed to return EOPNOTSUPP NFSv3: Fix return value of nfs3_proc_setacls NFSv3: Remove unused function nfs3_proc_set_default_acl NFSv4.1: nfs4_destroy_session must call rpc_destroy_waitqueue NFSv4: Fix memory corruption in nfs4_proc_open_confirm nfs: fix setting of ACLs on file creation.
2014-02-03Merge branch 'acl_fixes' into linux-nextTrond Myklebust
2014-02-03fs: get_acl() must be allowed to return EOPNOTSUPPTrond Myklebust
posix_acl_xattr_get requires get_acl() to return EOPNOTSUPP if the filesystem cannot support acls. This is needed for NFS, which can't know whether or not the server supports acls until it tries to get/set one. This patch converts posix_acl_chmod and posix_acl_create to deal with EOPNOTSUPP return values from get_acl(). Reported-by: Russell King <linux@arm.linux.org.uk> Link: http://lkml.kernel.org/r/20140130140834.GW15937@n2100.arm.linux.org.uk Cc: Al Viro viro@zeniv.linux.org.uk> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03NFSv3: Fix return value of nfs3_proc_setaclsTrond Myklebust
nfs3_proc_setacls is used internally by the NFSv3 create operations to set the acl after the file has been created. If the operation fails because the server doesn't support acls, then it must return '0', not -EOPNOTSUPP. Reported-by: Russell King <linux@arm.linux.org.uk> Link: http://lkml.kernel.org/r/20140201010328.GI15937@n2100.arm.linux.org.uk Cc: Christoph Hellwig <hch@lst.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03NFSv3: Remove unused function nfs3_proc_set_default_aclTrond Myklebust
Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03Btrfs: use late_initcall instead of module_initFilipe David Borba Manana
It seems that when init_btrfs_fs() is called, crc32c/crc32c-intel might not always be already initialized, which results in the call to crypto_alloc_shash() returning -ENOENT, as experienced by Ahmet who reported this. Therefore make sure init_btrfs_fs() is called after crc32c is initialized (which is at initialization level 6, module_init), by using late_initcall (which is at initialization level 7) instead of module_init for btrfs. Reported-and-Tested-by: Ahmet Inan <ainan@mathematik.uni-freiburg.de> Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-03Btrfs: use btrfs_crc32c everywhere instead of libcrc32cFilipe David Borba Manana
After the commit titled "Btrfs: fix btrfs boot when compiled as built-in", LIBCRC32C requirement was removed from btrfs' Kconfig. This made it not possible to build a kernel with btrfs enabled (either as module or built-in) if libcrc32c is not enabled as well. So just replace all uses of libcrc32c with the equivalent function in btrfs hash.h - btrfs_crc32c. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-03Btrfs: disable snapshot aware defrag for nowJosef Bacik
It's just broken and it's taking a lot of effort to fix it, so for now just disable it so people can defrag in peace. Thanks, Cc: stable@vger.kernel.org Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-02hpfs: optimize quad buffer loadingMikulas Patocka
HPFS needs to load 4 consecutive 512-byte sectors when accessing the directory nodes or bitmaps. We can't switch to 2048-byte block size because files are allocated in the units of 512-byte sectors. Previously, the driver would allocate a 2048-byte area using kmalloc, copy the data from four buffers to this area and eventually copy them back if they were modified. In the current implementation of the buffer cache, buffers are allocated in the pagecache. That means that 4 consecutive 512-byte buffers are stored in consecutive areas in the kernel address space. So, we don't need to allocate extra memory and copy the content of the buffers there. This patch optimizes the code to avoid copying the buffers. It checks if the four buffers are stored in contiguous memory - if they are not, it falls back to allocating a 2048-byte area and copying data there. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-02hpfs: remember free spaceMikulas Patocka
Previously, hpfs scanned all bitmaps each time the user asked for free space using statfs. This patch changes it so that hpfs scans the bitmaps only once, remembes the free space and on next invocation of statfs it returns the value instantly. New versions of wine are hammering on the statfs syscall very heavily, making some games unplayable when they're stored on hpfs, with load times in minutes. This should be backported to the stable kernels because it fixes user-visible problem (excessive level load times in wine). Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-01NFSv4.1: nfs4_destroy_session must call rpc_destroy_waitqueueTrond Myklebust
There may still be timers active on the session waitqueues. Make sure that we kill them before freeing the memory. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-01NFSv4: Fix memory corruption in nfs4_proc_open_confirmTrond Myklebust
nfs41_wake_and_assign_slot() relies on the task->tk_msg.rpc_argp and task->tk_msg.rpc_resp always pointing to the session sequence arguments. nfs4_proc_open_confirm tries to pull a fast one by reusing the open sequence structure, thus causing corruption of the NFSv4 slot table. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-01afs: proc cells and rootcell are writeablePali Rohár
Both proc files are writeable and used for configuring cells. But there is missing correct mode flag for writeable files. Without this patch both proc files are read only. [ It turns out they aren't really read-only, since root can write to them even if the write bit isn't set due to CAP_DAC_OVERRIDE ] Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-01Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "A set of cifs fixes (mostly for symlinks, and SMB2 xattrs) and cleanups" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: cifs: Fix check for regular file in couldbe_mf_symlink() [CIFS] Fix SMB2 mounts so they don't try to set or get xattrs via cifs CIFS: Cleanup cifs open codepath CIFS: Remove extra indentation in cifs_sfu_type CIFS: Cleanup cifs_mknod CIFS: Cleanup CIFSSMBOpen cifs: Add support for follow_link on dfs shares under posix extensions cifs: move unix extension call to cifs_query_symlink() cifs: Re-order M-F Symlink code cifs: Add create MFSymlinks to protocol ops struct cifs: use protocol specific call for query_mf_symlink() cifs: Rename MF symlink function names cifs: Rename and cleanup open_query_close_cifs_symlink() cifs: Fix memory leak in cifs_hardlink()
2014-02-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Several obvious fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Fix mountpoint reference leakage in linkat hfsplus: use xattr handlers for removexattr Typo in compat_sys_lseek() declaration fs/super.c: sync ro remount after blocking writers vfs: unexport the getname() symbol
2014-01-31nfs: fix setting of ACLs on file creation.Noah Massey
nfs3_get_acl() tries to skip posix equivalent ACLs, but misinterprets the return value of posix_acl_equiv_mode(). Fix it. This is a regression introduced by "nfs: use generic posix ACL infrastructure for v3 Posix ACLs" CC: Christoph Hellwig <hch@infradead.org> CC: linux-nfs@vger.kernel.org CC: linux-fsdevel@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-31Merge tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix several races in nfs_revalidate_mapping - NFSv4.1 slot leakage in the pNFS files driver - Stable fix for a slot leak in nfs40_sequence_done - Don't reject NFSv4 servers that support ACLs with only ALLOW aces" * tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: initialize the ACL support bits to zero. NFSv4.1: Cleanup NFSv4.1: Clean up nfs41_sequence_done NFSv4: Fix a slot leak in nfs40_sequence_done NFSv4.1 free slot before resending I/O to MDS nfs: add memory barriers around NFS_INO_INVALID_DATA and NFS_INO_INVALIDATING NFS: Fix races in nfs_revalidate_mapping sunrpc: turn warn_gssd() log message into a dprintk() NFS: fix the handling of NFS_INO_INVALID_DATA flag in nfs_revalidate_mapping nfs: handle servers that support only ALLOW ACE type.
2014-01-31Fix mountpoint reference leakage in linkatOleg Drokin
Recent changes to retry on ESTALE in linkat (commit 442e31ca5a49e398351b2954b51f578353fdf210) introduced a mountpoint reference leak and a small memory leak in case a filesystem link operation returns ESTALE which is pretty normal for distributed filesystems like lustre, nfs and so on. Free old_path in such a case. [AV: there was another missing path_put() nearby - on the previous goto retry] Signed-off-by: Oleg Drokin: <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31hfsplus: use xattr handlers for removexattrChristoph Hellwig
hfsplus was already using the handlers for get and set operations, and with the removal of can_set_xattr we've now allow operations that wouldn't otherwise be allowed. With this we can also centralize the special-casing of the osx. attrs that don't have prefixes on disk in the osx xattr handlers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31fs/super.c: sync ro remount after blocking writersAndrew Ruder
Move sync_filesystem() after sb_prepare_remount_readonly(). If writers sneak in anywhere from sync_filesystem() to sb_prepare_remount_readonly() it can cause inodes to be dirtied and writeback to occur well after sys_mount() has completely successfully. This was spotted by corrupted ubifs filesystems on reboot, but appears that it can cause issues with any filesystem using writeback. Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> CC: Richard Weinberger <richard@nod.at> Co-authored-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31vfs: unexport the getname() symbolJeff Layton
Leaving getname() exported when putname() isn't is a bad idea. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31Merge tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Minor bug fix for linux-3.14" * tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggy: jfs: fix xattr value size overflow in __jfs_setxattr
2014-01-31ceph: fix missing dput in ceph_set_aclSage Weil
Add matching dput() for d_find_alias(). Move d_find_alias() down a bit at Julia's suggestion. [ Introduced by commit 72466d0b92e0: "ceph: fix posix ACL hooks" ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-31cifs: Fix check for regular file in couldbe_mf_symlink()Sachin Prabhu
MF Symlinks are regular files containing content in a specified format. The function couldbe_mf_symlink() checks the mode for a set S_IFREG bit as a test to confirm that it is a regular file. This bit is also set for other filetypes and simply checking for this bit being set may return false positives. We ensure that we are actually checking for a regular file by using the S_ISREG macro to test instead. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reported-by: Neil Brown <neilb@suse.de> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-01-31nfs: initialize the ACL support bits to zero.Malahal Naineni
Avoid returning incorrect acl mask attributes when the server doesn't support ACLs. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull some further ceph acl cleanups from Sage Weil: "I do have a couple patches on top of what's in your tree, though, that clean up a couple duplicated lines in your fix and apply Christoph's cleanup" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: simplify ceph_{get,init}_acl ceph: remove duplicate declaration of ceph_setattr
2014-01-30ceph: simplify ceph_{get,init}_aclChristoph Hellwig
- ->get_acl only gets called after we checked for a cached ACL, so no need to call get_cached_acl again. - no need to check IS_POSIXACL in ->get_acl, without that it should never get set as all the callers that set it already have the check. - you should be able to use the full posix_acl_create in CEPH Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Sage Weil <sage@inktank.com>
2014-01-30Merge branch 'for-3.14/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver changes from Jens Axboe: - bcache update from Kent Overstreet. - two bcache fixes from Nicholas Swenson. - cciss pci init error fix from Andrew. - underflow fix in the parallel IDE pg_write code from Dan Carpenter. I'm sure the 1 (or 0) users of that are now happy. - two PCI related fixes for sx8 from Jingoo Han. - floppy init fix for first block read from Jiri Kosina. - pktcdvd error return miss fix from Julia Lawall. - removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from Michael Opdenacker. - comment typo fix for the loop driver from Olaf Hering. - potential oops fix for null_blk from Raghavendra K T. - two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing an OOM problem and a problem with handling security locked conditions * 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits) mg_disk: Spelling s/finised/finished/ null_blk: Null pointer deference problem in alloc_page_buffers mtip32xx: Correctly handle security locked condition mtip32xx: Make SGL container per-command to eliminate high order dma allocation drivers/block/loop.c: fix comment typo in loop_config_discard drivers/block/cciss.c:cciss_init_one(): use proper errnos drivers/block/paride/pg.c: underflow bug in pg_write() drivers/block/sx8.c: remove unnecessary pci_set_drvdata() drivers/block/sx8.c: use module_pci_driver() floppy: bail out in open() if drive is not responding to block0 read bcache: Fix auxiliary search trees for key size > cacheline size bcache: Don't return -EINTR when insert finished bcache: Improve bucket_prio() calculation bcache: Add bch_bkey_equal_header() bcache: update bch_bkey_try_merge bcache: Move insert_fixup() to btree_keys_ops bcache: Convert sorting to btree_keys bcache: Convert debug code to btree_keys bcache: Convert btree_iter to struct btree_keys bcache: Refactor bset_tree sysfs stats ...
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-30Merge branch 'for-3.14' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: - Handle some loose ends from the vfs read delegation support. (For example nfsd can stop breaking leases on its own in a fewer places where it can now depend on the vfs to.) - Make life a little easier for NFSv4-only configurations (thanks to Kinglong Mee). - Fix some gss-proxy problems (thanks Jeff Layton). - miscellaneous bug fixes and cleanup * 'for-3.14' of git://linux-nfs.org/~bfields/linux: (38 commits) nfsd: consider CLAIM_FH when handing out delegation nfsd4: fix delegation-unlink/rename race nfsd4: delay setting current_fh in open nfsd4: minor nfs4_setlease cleanup gss_krb5: use lcm from kernel lib nfsd4: decrease nfsd4_encode_fattr stack usage nfsd: fix encode_entryplus_baggage stack usage nfsd4: simplify xdr encoding of nfsv4 names nfsd4: encode_rdattr_error cleanup nfsd4: nfsd4_encode_fattr cleanup minor svcauth_gss.c cleanup nfsd4: better VERIFY comment nfsd4: break only delegations when appropriate NFSD: Fix a memory leak in nfsd4_create_session sunrpc: get rid of use_gssp_lock sunrpc: fix potential race between setting use_gss_proxy and the upcall rpc_clnt sunrpc: don't wait for write before allowing reads from use-gss-proxy file nfsd: get rid of unused function definition Define op_iattr for nfsd4_open instead using macro NFSD: fix compile warning without CONFIG_NFSD_V3 ...
2014-01-30nfs: fix xattr inode op pointers when disabledChristoph Hellwig
Chris Mason reported a NULL pointer derefernence in generic_getxattr() that was due to sb->s_xattr being NULL. The reason is that the nfs #ifdef's for ACL support were misplaced, and the nfs3 inode operations had the xattr operation pointers set up, even though xattrs were not actually supported. As a result, the xattr code was being called without the infrastructure having been set up. Move the #ifdef's appropriately. Reported-and-tested-by: Chris Mason <clm@fb.com> Acked-by: Al Viro viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30ceph: remove duplicate declaration of ceph_setattrPeter Rosin
Signed-off-by: Peter Rosin <peda@lysator.liu.se> Signed-off-by: Sage Weil <sage@inktank.com>
2014-01-29Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge random fixes from Andrew Morton: "Random fixes. I have one batch remaining for -rc1, mainly zram changes which await a merge of Jens's trees" * emailed patches fron Andrew Morton akpm@linux-foundation.org>: MAINTAINERS: ADI Linux development mailing lists: change to the new server Documentation: fix multiple typo occurences s/KenelVersion/KernelVersion/ dma-debug: fix overlap detection memblock: add limit checking to memblock_virt_alloc mm/readahead.c: fix do_readahead() for no readpage(s) mm/slub.c: do not VM_BUG_ON_PAGE() for temporary on-stack pages slab: fix wrong retval on kmem_cache_create_memcg error path s390/compat: change parameter types from unsigned long to compat_ulong_t fs/compat: fix lookup_dcookie() parameter handling fs/compat: fix parameter handling for compat readv/writev syscalls mm/mempolicy.c: convert to pr_foo() mm: numa: initialise numa balancing after jump label initialisation mm/page-writeback.c: do not count anon pages as dirtyable memory mm/page-writeback.c: fix dirty_balance_reserve subtraction from dirtyable memory mm: document improved handling of swappiness==0 lib/genalloc.c: add check gen_pool_dma_alloc() if dma pointer is not NULL
