commit 89a4e48f8479f8145eca9698f39fe188c982212f upstream.
Commit 968dee7722: "ext4: fix hole punch failure when depth is greater
than 0" introduced a regression in v3.5.1/v3.6-rc1 which caused kernel
crashes when users ran run "rm -rf" on large directory hierarchy on
ext4 filesystems on RAID devices:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
Process rm (pid: 18229, threadinfo ffff8801276bc000, task ffff880123631710)
Call Trace:
[<ffffffff81236483>] ? __ext4_handle_dirty_metadata+0x83/0x110
[<ffffffff812353d3>] ext4_ext_truncate+0x193/0x1d0
[<ffffffff8120a8cf>] ? ext4_mark_inode_dirty+0x7f/0x1f0
[<ffffffff81207e05>] ext4_truncate+0xf5/0x100
[<ffffffff8120cd51>] ext4_evict_inode+0x461/0x490
[<ffffffff811a1312>] evict+0xa2/0x1a0
[<ffffffff811a1513>] iput+0x103/0x1f0
[<ffffffff81196d84>] do_unlinkat+0x154/0x1c0
[<ffffffff8118cc3a>] ? sys_newfstatat+0x2a/0x40
[<ffffffff81197b0b>] sys_unlinkat+0x1b/0x50
[<ffffffff816135e9>] system_call_fastpath+0x16/0x1b
Code: 8b 4d 20 0f b7 41 02 48 8d 04 40 48 8d 04 81 49 89 45 18 0f b7 49 02 48 83 c1 01 49 89 4d 00 e9 ae f8 ff ff 0f 1f 00 49 8b 45 28 <48> 8b 40 28 49 89 45 20 e9 85 f8 ff ff 0f 1f 80 00 00 00
RIP [<ffffffff81233164>] ext4_ext_remove_space+0xa34/0xdf0
This could be reproduced as follows:
The problem in commit 968dee7722 was that caused the variable 'i' to
be left uninitialized if the truncate required more space than was
available in the journal. This resulted in the function
ext4_ext_truncate_extend_restart() returning -EAGAIN, which caused
ext4_ext_remove_space() to restart the truncate operation after
starting a new jbd2 handle.
Reported-by: Maciej Żenczykowski <maze@google.com>
Reported-by: Marti Raudsepp <marti@juffo.org>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 0548bbb85337e532ca2ed697c3e9b227ff2ed4b4 upstream.
Commit 8aeb00ff85a: "ext4: fix overhead calculation used by
ext4_statfs()" introduced a O(n**2) calculation which makes very large
file systems take forever to mount. Fix this with an optimization for
non-bigalloc file systems. (For bigalloc file systems the overhead
needs to be set in the the superblock.)
commit 7a4c5de27efa4c2ecca87af0a3deea63446367e2 upstream.
While in ext4_validate_block_bitmap(), if an block allocation bitmap
is found to be invalid, we call ext4_error() while the block group is
still locked. This causes ext4_commit_super() to call a function
which might sleep while in an atomic context.
There's no need to keep the block group locked at this point, so hoist
the ext4_error() call up to ext4_validate_block_bitmap() and release
the block group spinlock before calling ext4_error().
The reported stack trace can be found at:
http://article.gmane.org/gmane.comp.file-systems.ext4/33731
Reported-by: Dave Jones <davej@redhat.com>
commit 7e731bc9a12339f344cddf82166b82633d99dd86 upstream.
Commit 03179fe923 introduced a kmemcheck complaint in
ext4_da_get_block_prep() because we save and restore
ei->i_da_metadata_calc_last_lblock even though it is left
uninitialized in the case where i_da_metadata_calc_len is zero.
This doesn't hurt anything, but silencing the kmemcheck complaint
makes it easier for people to find real bugs.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=45631
(which is marked as a regression).
commit d796c52ef0b71a988364f6109aeb63d79c5b116b upstream.
After we transfer set the EXT4_ERROR_FS bit in the file system
superblock, it's not enough to call jbd2_journal_clear_err() to clear
the error indication from journal superblock --- we need to call
jbd2_journal_update_sb_errno() as well. Otherwise, when the root file
system is mounted read-only, the journal is replayed, and the error
indicator is transferred to the superblock --- but the s_errno field
in the jbd2 superblock is left set (since although we cleared it in
memory, we never flushed it out to disk).
This can end up confusing e2fsck. We should make e2fsck more robust
in this case, but the kernel shouldn't be leaving things in this
confused state, either.
commit fb6ccff667712c46b4501b920ea73a326e49626a upstream.
Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that
the total iovec from the client doesn't overflow iov_length() but it
only checked the first element. The iovec could still overflow by
starting with a small element. The obvious fix is to check all the
elements.
The overflow case doesn't look dangerous to the kernel as the copy is
limited by the length after the overflow. This fix restores the
intention of returning an error instead of successfully copying less
than the iovec represented.
I found this by code inspection. I built it but don't have a test case.
I'm cc:ing stable because the initial commit did as well.
Signed-off-by: Zach Brown <zab@redhat.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 9e62bb4458ad2cf28bd701aa5fab380b846db326 upstream.
_ios_obj() is accessed by group_index not device_table index.
The oc->comps array is only a group_full of devices at a time
it is not like ore_comp_dev() which is indexed by a global
device_table index.
This did not BUG until now because exofs only uses a single
COMP for all devices. But with other FSs like PanFS this is
not true.
This bug was only in the write_path, all other users were
using it correctly
[This is a bug since 3.2 Kernel]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 572d8b3945a31bee7c40d21556803e4807fd9141 upstream.
An fs-thaw ioctl causes deadlock with a chcp or mkcp -s command:
chcp D ffff88013870f3d0 0 1325 1324 0x00000004
Call Trace:
nilfs_transaction_begin+0x11c/0x1a0 [nilfs2]
wake_up_bit+0x20/0x20
copy_from_user+0x18/0x30 [nilfs2]
nilfs_ioctl_change_cpmode+0x7d/0xcf [nilfs2]
nilfs_ioctl+0x252/0x61a [nilfs2]
do_page_fault+0x311/0x34c
get_unmapped_area+0x132/0x14e
do_vfs_ioctl+0x44b/0x490
__set_task_blocked+0x5a/0x61
vm_mmap_pgoff+0x76/0x87
__set_current_blocked+0x30/0x4a
sys_ioctl+0x4b/0x6f
thaw D ffff88013870d890 0 1352 1351 0x00000004
Call Trace:
rwsem_down_failed_common+0xdb/0x10f
call_rwsem_down_write_failed+0x13/0x20
down_write+0x25/0x27
thaw_super+0x13/0x9e
do_vfs_ioctl+0x1f5/0x490
sys_ioctl+0x4b/0x6f
filp_close+0x64/0x6c
where the thaw ioctl deadlocked at thaw_super() when called while chcp was
waiting at nilfs_transaction_begin() called from
nilfs_ioctl_change_cpmode(). This deadlock is 100% reproducible.
This is because nilfs_ioctl_change_cpmode() first locks sb->s_umount in
read mode and then waits for unfreezing in nilfs_transaction_begin(),
whereas thaw_super() locks sb->s_umount in write mode. The locking of
sb->s_umount here was intended to make snapshot mounts and the downgrade
of snapshots to checkpoints exclusive.
This fixes the deadlock issue by replacing the sb->s_umount usage in
nilfs_ioctl_change_cpmode() with a dedicated mutex which protects snapshot
mounts.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 41eb70dde42b2360074a559a6f1fc49860a50179 upstream.
In xattr block operation, we use h_refcount to indicate whether the
xattr block is shared among many inodes. And xattr block csum uses
s_csum_seed if it is shared and i_csum_seed if it belongs to
one inode. But this has a problem. So consider the block is shared
first bewteen inode A and B, and B has some xattr update and CoW
the xattr block. When it updates the *old* xattr block(because
of the h_refcount change) and calls ext4_xattr_release_block, we
has no idea that inode A is the real owner of the *old* xattr
block and we can't use the i_csum_seed of inode A either in xattr
block csum calculation. And I don't think we have an easy way to
find inode A.
So this patch just removes the tricky i_csum_seed and we now uses
s_csum_seed every time for the xattr block csum. The corresponding
patch for the e2fsprogs will be sent in another patch.
This is spotted by xfstests 117.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Acked-by: Darrick J. Wong <djwong@us.ibm.com>
commit ef58f69c3c34f6377f1e21d3533c806dbd980ad0 upstream.
In ext4_rename, when the old name is a dir, we need to
change ".." to its new parent and journal the change, so
with metadata_csum enabled, we have to re-calc the csum.
As the first block of the dir can be either a htree root
or a normal directory block and we have different csum
calculation for these 2 types, we have to choose the right
one in ext4_rename.
btw, it is found by xfstests 013.
commit 03179fe92318e7934c180d96f12eff2cb36ef7b6 upstream.
The function ext4_calc_metadata_amount() has side effects, although
it's not obvious from its function name. So if we fail to claim
space, regardless of whether we retry to claim the space again, or
return an error, we need to undo these side effects.
Otherwise we can end up incorrectly calculating the number of metadata
blocks needed for the operation, which was responsible for an xfstests
failure for test #271 when using an ext2 file system with delalloc
enabled.
Reported-by: Brian Foster <bfoster@redhat.com>
commit 97795d2a5b8d3c8dc4365d4bd3404191840453ba upstream.
If we hit a condition where we have allocated metadata blocks that
were not appropriately reserved, we risk underflow of
ei->i_reserved_meta_blocks. In turn, this can throw
sbi->s_dirtyclusters_counter significantly out of whack and undermine
the nondelalloc fallback logic in ext4_nonda_switch(). Warn if this
occurs and set i_allocated_meta_blocks to avoid this problem.
This condition is reproduced by xfstests 270 against ext2 with
delalloc enabled:
Mar 28 08:58:02 localhost kernel: [ 171.526344] EXT4-fs (loop1): delayed block allocation failed for inode 14 at logical offset 64486 with max blocks 64 with error -28
Mar 28 08:58:02 localhost kernel: [ 171.526346] EXT4-fs (loop1): This should not happen!! Data will be lost
270 ultimately fails with an inconsistent filesystem and requires an
fsck to repair. The cause of the error is an underflow in
ext4_da_update_reserve_space() due to an unreserved meta block
allocation.
Signed-off-by: Brian Foster <bfoster@redhat.com>
commit 968dee77220768a5f52cf8b21d0bdb73486febef upstream.
Whether to continue removing extents or not is decided by the return
value of function ext4_ext_more_to_rm() which checks 2 conditions:
a) if there are no more indexes to process.
b) if the number of entries are decreased in the header of "depth -1".
In case of hole punch, if the last block to be removed is not part of
the last extent index than this index will not be deleted, hence the
number of valid entries in the extent header of "depth - 1" will
remain as it is and ext4_ext_more_to_rm will return 0 although the
required blocks are not yet removed.
This patch fixes the above mentioned problem as instead of removing
the extents from the end of file, it starts removing the blocks from
the particular extent from which removing blocks is actually required
and continue backward until done.
Signed-off-by: Ashish Sangwan <ashish.sangwan2@gmail.com>
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit 952fc18ef9ec707ebdc16c0786ec360295e5ff15 upstream.
Commit f975d6bcc7a introduced bug which caused ext4_statfs() to
miscalculate the number of file system overhead blocks. This causes
the f_blocks field in the statfs structure to be larger than it should
be. This would in turn cause the "df" output to show the number of
data blocks in the file system and the number of data blocks used to
be larger than they should be.
commit f6fb99cadcd44660c68e13f6eab28333653621e6 upstream.
Make it possible for ext4_count_free to operate on buffers and not
just data in buffer_heads.
commit a427b9ec4eda8cd6e641ea24541d30b641fc3140 upstream.
Fix a number of bugs in the NFS idmapper code:
(1) Only registered key types can be passed to the core keys code, so
register the legacy idmapper key type.
This is a requirement because the unregister function cleans up keys
belonging to that key type so that there aren't dangling pointers to the
module left behind - including the key->type pointer.
(2) Rename the legacy key type. You can't have two key types with the same
name, and (1) would otherwise require that.
(3) complete_request_key() must be called in the error path of
nfs_idmap_legacy_upcall().
(4) There is one idmap struct for each nfs_client struct. This means that
idmap->idmap_key_cons is shared without the use of a lock. This is a
problem because key_instantiate_and_link() - as called indirectly by
idmap_pipe_downcall() - releases anyone waiting for the key to be
instantiated.
What happens is that idmap_pipe_downcall() running in the rpc.idmapd
thread, releases the NFS filesystem in whatever thread that is running in
to continue. This may then make another idmapper call, overwriting
idmap_key_cons before idmap_pipe_downcall() gets the chance to call
complete_request_key().
I *think* that reading idmap_key_cons only once, before
key_instantiate_and_link() is called, and then caching the result in a
variable is sufficient.
Bug (4) is the cause of:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [< (null)>] (null)
PGD 0
Oops: 0010 [#1] SMP
CPU 1
Modules linked in: ppdev parport_pc lp parport ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack nfs fscache xt_CHECKSUM auth_rpcgss iptable_mangle nfs_acl bridge stp llc lockd be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i libcxgbi cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi snd_hda_codec_realtek snd_usb_audio snd_hda_intel snd_hda_codec snd_seq snd_pcm snd_hwdep snd_usbmidi_lib snd_rawmidi snd_timer uvcvideo videobuf2_core videodev media videobuf2_vmalloc snd_seq_device videobuf2_memops e1000e vhost_net iTCO_wdt joydev coretemp snd soundcore macvtap macvlan i2c_i801 snd_page_alloc tun iTCO_vendor_support microcode kvm_intel kvm sunrpc hid_logitech_dj usb_storage i915 drm_kms_helper drm i2c_algo_bit i2c_core video [last unloaded: scsi_wait_scan]
Pid: 1229, comm: rpc.idmapd Not tainted 3.4.2-1.fc16.x86_64 #1 Gateway DX4710-UB801A/G33M05G1
RIP: 0010:[<0000000000000000>] [< (null)>] (null)
RSP: 0018:ffff8801a3645d40 EFLAGS: 00010246
RAX: ffff880077707e30 RBX: ffff880077707f50 RCX: ffff8801a18ccd80
RDX: 0000000000000006 RSI: ffff8801a3645e75 RDI: ffff880077707f50
RBP: ffff8801a3645d88 R08: ffff8801a430f9c0 R09: ffff8801a3645db0
R10: 000000000000000a R11: 0000000000000246 R12: ffff8801a18ccd80
R13: ffff8801a3645e75 R14: ffff8801a430f9c0 R15: 0000000000000006
FS: 00007fb6fb51a700(0000) GS:ffff8801afc80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001a49b0000 CR4: 00000000000027e0
Process rpc.idmapd (pid: 1229, threadinfo ffff8801a3644000, task ffff8801a3bf9710)
Stack:
ffffffff81260878 ffff8801a3645db0 ffff8801a3645db0 ffff880077707a90
ffff880077707f50 ffff8801a18ccd80 0000000000000006 ffff8801a3645e75
ffff8801a430f9c0 ffff8801a3645dd8 ffffffff81260983 ffff8801a3645de8
Call Trace:
[<ffffffff81260878>] ? __key_instantiate_and_link+0x58/0x100
[<ffffffff81260983>] key_instantiate_and_link+0x63/0xa0
[<ffffffffa057062b>] idmap_pipe_downcall+0x1cb/0x1e0 [nfs]
[<ffffffffa0107f57>] rpc_pipe_write+0x67/0x90 [sunrpc]
[<ffffffff8117f833>] vfs_write+0xb3/0x180
[<ffffffff8117fb5a>] sys_write+0x4a/0x90
[<ffffffff81600329>] system_call_fastpath+0x16/0x1b
Code: Bad RIP value.
RIP [< (null)>] (null)
RSP <ffff8801a3645d40>
Reviewed-by: Steve Dickson <steved@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 5cf02d09b50b1ee1c2d536c9cf64af5a7d433f56 upstream.
We've had some reports of a deadlock where rpciod ends up with a stack
trace like this:
PID: 2507 TASK: ffff88103691ab40 CPU: 14 COMMAND: "rpciod/14"
#0 [ffff8810343bf2f0] schedule at ffffffff814dabd9
#1 [ffff8810343bf3b8] nfs_wait_bit_killable at ffffffffa038fc04 [nfs]
#2 [ffff8810343bf3c8] __wait_on_bit at ffffffff814dbc2f
#3 [ffff8810343bf418] out_of_line_wait_on_bit at ffffffff814dbcd8
#4 [ffff8810343bf488] nfs_commit_inode at ffffffffa039e0c1 [nfs]
#5 [ffff8810343bf4f8] nfs_release_page at ffffffffa038bef6 [nfs]
#6 [ffff8810343bf528] try_to_release_page at ffffffff8110c670
#7 [ffff8810343bf538] shrink_page_list.clone.0 at ffffffff81126271
#8 [ffff8810343bf668] shrink_inactive_list at ffffffff81126638
#9 [ffff8810343bf818] shrink_zone at ffffffff8112788f
#10 [ffff8810343bf8c8] do_try_to_free_pages at ffffffff81127b1e
#11 [ffff8810343bf958] try_to_free_pages at ffffffff8112812f
#12 [ffff8810343bfa08] __alloc_pages_nodemask at ffffffff8111fdad
#13 [ffff8810343bfb28] kmem_getpages at ffffffff81159942
#14 [ffff8810343bfb58] fallback_alloc at ffffffff8115a55a
#15 [ffff8810343bfbd8] ____cache_alloc_node at ffffffff8115a2d9
#16 [ffff8810343bfc38] kmem_cache_alloc at ffffffff8115b09b
#17 [ffff8810343bfc78] sk_prot_alloc at ffffffff81411808
#18 [ffff8810343bfcb8] sk_alloc at ffffffff8141197c
#19 [ffff8810343bfce8] inet_create at ffffffff81483ba6
#20 [ffff8810343bfd38] __sock_create at ffffffff8140b4a7
#21 [ffff8810343bfd98] xs_create_sock at ffffffffa01f649b [sunrpc]
#22 [ffff8810343bfdd8] xs_tcp_setup_socket at ffffffffa01f6965 [sunrpc]
#23 [ffff8810343bfe38] worker_thread at ffffffff810887d0
#24 [ffff8810343bfee8] kthread at ffffffff8108dd96
#25 [ffff8810343bff48] kernel_thread at ffffffff8100c1ca
rpciod is trying to allocate memory for a new socket to talk to the
server. The VM ends up calling ->releasepage to get more memory, and it
tries to do a blocking commit. That commit can't succeed however without
a connected socket, so we deadlock.
Fix this by setting PF_FSTRANS on the workqueue task prior to doing the
socket allocation, and having nfs_release_page check for that flag when
deciding whether to do a commit call. Also, set PF_FSTRANS
unconditionally in rpc_async_schedule since that function can also do
allocations sometimes.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 5559b50acdcdcad7e362882d3261bf934c9436f6 upstream.
This fixes a wrong check for same cr_principal in same_creds
Introduced by 8fbba96e5b327665265ad02b7f331b68536828bf "nfsd4: stricter
cred comparison for setclientid/exchange_id".
Signed-off-by: Vivek Trivedi <vtrivedi018@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 2930d381d22b9c56f40dd4c63a8fa59719ca2c3c upstream.
Actually, xfs and jfs can optionally be case insensitive; we'll handle
that case in later patches.
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream.
Recently, glibc made a change to suppress sign-conversion warnings in
FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the
kernel's definition of __NFDBITS if applications #include
<linux/types.h> after including <sys/select.h>. A build failure would
be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2
flags to gcc.
It was suggested that the kernel should either match the glibc
definition of __NFDBITS or remove that entirely. The current in-kernel
uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no
uses of the related __FDELT and __FDMASK defines. Given that, we'll
continue the cleanup that was started with commit 8b3d1cda4f5f
("posix_types: Remove fd_set macros") and drop the remaining unused
macros.
Additionally, linux/time.h has similar macros defined that expand to
nothing so we'll remove those at the same time.
Reported-by: Jeff Law <law@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ .. and fix up whitespace as per akpm ]
commit 764a1b1acecedfe204cb2e80d8e2cc7c6df1b0b8 upstream.
The readpages bug is a regression that was introduced in 6993f74a5.
This also fixes a couple of similar bugs in the uncached read and write
codepaths.
Also, prevent this sort of thing in the future by having cifsFileInfo_get
take the spinlock itself, and adding a _locked variant for use in places
that are already holding the lock. The _put code has always done that
so this makes for a less confusing interface.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 7659624ffb550d69c87f9af9ae63e717daa874bd upstream.
sec=ntlmv2 as a mount option got dropped in the mount option overhaul.
Cc: Sachin Prabhu <sprabhu@redhat.com>
Reported-by: Günter Kukkukk <linux@kukkukk.com>
commit e9fbcb42201c862fd6ab45c48ead4f47bb2dea9d upstream.
Each ordered operation has a free callback, and this was called with the
worker spinlock held. Josef made the free callback also call iput,
which we can't do with the spinlock.
This drops the spinlock for the free operation and grabs it again before
moving through the rest of the list. We'll circle back around to this
and find a cleaner way that doesn't bounce the lock around so much.
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit 57b9655d01ef057a523e810d29c37ac09b80eead upstream.
When a partition table length is corrupted to be close to 1 << 32, the
check for its length may overflow on 32-bit systems and we will think
the length is valid. Later on the kernel can crash trying to read beyond
end of buffer. Fix the check to avoid possible overflow.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
commit 0ec4f431eb56d633da3a55da67d5c4b88886ccc7 upstream.
The only checks of the long argument passed to fcntl(fd,F_SETLEASE,.)
are done after converting the long to an int. Thus some illegal values
may be let through and cause problems in later code.
[ They actually *don't* cause problems in mainline, as of Dave Jones's
commit 8d657eb3b438 "Remove easily user-triggerable BUG from
generic_setlease", but we should fix this anyway. And this patch will
be necessary to fix real bugs on earlier kernels. ]
Pull pnfs/ore fixes from Boaz Harrosh:
"These are catastrophic fixes to the pnfs objects-layout that were just
discovered. They are also destined for @stable.
I have found these and worked on them at around RC1 time but
unfortunately went to the hospital for kidney stones and had a very
slow recovery. I refrained from sending them as is, before proper
testing, and surly I have found a bug just yesterday.
So now they are all well tested, and have my sign-off. Other then
fixing the problem at hand, and assuming there are no bugs at the new
code, there is low risk to any surrounding code. And in anyway they
affect only these paths that are now broken. That is RAID5 in pnfs
objects-layout code. It does also affect exofs (which was not broken)
but I have tested exofs and it is lower priority then objects-layout
because no one is using exofs, but objects-layout has lots of users."
* 'for-linus' of git://git.open-osd.org/linux-open-osd:
pnfs-obj: Fix __r4w_get_page when offset is beyond i_size
pnfs-obj: don't leak objio_state if ore_write/read fails
ore: Unlock r4w pages in exact reverse order of locking
ore: Remove support of partial IO request (NFS crash)
ore: Fix NFS crash by supporting any unaligned RAID IO
Pull UBIFS free space fix-up bugfix from Artem Bityutskiy:
"It's been reported already twice recently:
http://lists.infradead.org/pipermail/linux-mtd/2012-May/041408.html
http://lists.infradead.org/pipermail/linux-mtd/2012-June/042422.html
and we finally have the fix. I am quite confident the fix is correct
because I could reproduce the problem with nandsim and verify the fix.
It was also verified by Iwo (the reporter).
I am also confident that this is OK to merge the fix so late because
this patch affects only the fixup functionality, which is not used by
most users."
* tag 'upstream-3.5-rc8' of git://git.infradead.org/linux-ubifs:
UBIFS: fix a bug in empty space fix-up
It is very common for the end of the file to be unaligned on
stripe size. But since we know it's beyond file's end then
the XOR should be preformed with all zeros.
Old code used to just read zeros out of the OSD devices, which is a great
waist. But what scares me more about this situation is that, we now have
pages attached to the file's mapping that are beyond i_size. I don't
like the kind of bugs this calls for.
Fix both birds, by returning a global zero_page, if offset is beyond
i_size.
TODO:
Change the API to ->__r4w_get_page() so a NULL can be
returned without being considered as error, since XOR API
treats NULL entries as zero_pages.
[Bug since 3.2. Should apply the same way to all Kernels since]
CC: Stable Tree <stable@kernel.org>
[Bug since 3.2 Kernel]
The read-4-write pages are locked in address ascending order.
But where unlocked in a way easiest for coding. Fix that,
locks should be released in opposite order of locking, .i.e
descending address order.
I have not hit this dead-lock. It was found by inspecting the
dbug print-outs. I suspect there is an higher lock at caller that
protects us, but fix it regardless.
Do to OOM situations the ore might fail to allocate all resources
needed for IO of the full request. If some progress was possible
it would proceed with a partial/short request, for the sake of
forward progress.
Since this crashes NFS-core and exofs is just fine without it just
remove this contraption, and fail.
TODO:
Support real forward progress with some reserved allocations
of resources, such as mem pools and/or bio_sets
CC: Benny Halevy <bhalevy@tonian.com>
In RAID_5/6 We used to not permit an IO that it's end
byte is not stripe_size aligned and spans more than one stripe.
.i.e the caller must check if after submission the actual
transferred bytes is shorter, and would need to resubmit
a new IO with the remainder.
Exofs supports this, and NFS was supposed to support this
as well with it's short write mechanism. But late testing has
exposed a CRASH when this is used with none-RPC layout-drivers.
The change at NFS is deep and risky, in it's place the fix
at ORE to lift the limitation is actually clean and simple.
So here it is below.
The principal here is that in the case of unaligned IO on
both ends, beginning and end, we will send two read requests
one like old code, before the calculation of the first stripe,
and also a new site, before the calculation of the last stripe.
If any "boundary" is aligned or the complete IO is within a single
stripe. we do a single read like before.
The code is clean and simple by splitting the old _read_4_write
into 3 even parts:
1._read_4_write_first_stripe
2. _read_4_write_last_stripe
3. _read_4_write_execute
And calling 1+3 at the same place as before. 2+3 before last
stripe, and in the case of all in a single stripe then 1+2+3
is preformed additively.
Why did I not think of it before. Well I had a strike of
genius because I have stared at this code for 2 years, and did
not find this simple solution, til today. Not that I did not try.
This solution is much better for NFS than the previous supposedly
solution because the short write was dealt with out-of-band after
IO_done, which would cause for a seeky IO pattern where as in here
we execute in order. At both solutions we do 2 separate reads, only
here we do it within a single IO request. (And actually combine two
writes into a single submission)
NFS/exofs code need not change since the ORE API communicates the new
shorter length on return, what will happen is that this case would not
occur anymore.
hurray!!
[Stable this is an NFS bug since 3.2 Kernel should apply cleanly]
UBIFS has a feature called "empty space fix-up" which is a quirk to work-around
limitations of dumb flasher programs. Namely, of those flashers that are unable
to skip NAND pages full of 0xFFs while flashing, resulting in empty space at
the end of half-filled eraseblocks to be unusable for UBIFS. This feature is
relatively new (introduced in v3.0).
The fix-up routine (fixup_free_space()) is executed only once at the very first
mount if the superblock has the 'space_fixup' flag set (can be done with -F
option of mkfs.ubifs). It basically reads all the UBIFS data and metadata and
writes it back to the same LEB. The routine assumes the image is pristine and
does not have anything in the journal.
There was a bug in 'fixup_free_space()' where it fixed up the log incorrectly.
All but one LEB of the log of a pristine file-system are empty. And one
contains just a commit start node. And 'fixup_free_space()' just unmapped this
LEB, which resulted in wiping the commit start node. As a result, some users
were unable to mount the file-system next time with the following symptom:
UBIFS error (pid 1): replay_log_leb: first log node at LEB 3:0 is not CS node
UBIFS error (pid 1): replay_log_leb: log error detected while replaying the log at LEB 3:0
The root-cause of this bug was that 'fixup_free_space()' wrongly assumed
that the beginning of empty space in the log head (c->lhead_offs) was known
on mount. However, it is not the case - it was always 0. UBIFS does not store
in it the master node and finds out by scanning the log on every mount.
The fix is simple - just pass commit start node size instead of 0 to
'fixup_leb()'.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Cc: stable@vger.kernel.org [v3.0+]
Reported-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Tested-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Reported-by: James Nute <newten82@gmail.com>
Pull CIFS fixes from Steve French.
* git://git.samba.org/sfrench/cifs-2.6:
cifs: always update the inode cache with the results from a FIND_*
cifs: when CONFIG_HIGHMEM is set, serialize the read/write kmaps
cifs: on CONFIG_HIGHMEM machines, limit the rsize/wsize to the kmap space
Initialise mid_q_entry before putting it on the pending queue
Caused, AFAICS, by mismerge in commit ff9cb1c4eead ("Merge branch
'for_linus' into for_linus_merged")
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org # 3.3+
Pull a last-minute PM update from Rafael J. Wysocki:
"This renames CAP_EPOLLWAKEUP to CAP_BLOCK_SUSPEND to encourage future
reuse of the capability in question in related cases."
* tag 'pm-post-3.5-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM: Rename CAP_EPOLLWAKEUP to CAP_BLOCK_SUSPEND
As discussed in
http://thread.gmane.org/gmane.linux.kernel/1249726/focus=1288990,
the capability introduced in 4d7e30d98939a0340022ccd49325a3d70f7e0238
to govern EPOLLWAKEUP seems misnamed: this capability is about governing
the ability to suspend the system, not using a particular API flag
(EPOLLWAKEUP). We should make the name of the capability more general
to encourage reuse in related cases. (Whether or not this capability
should also be used to govern the use of /sys/power/wake_lock is a
question that needs to be separately resolved.)
This patch renames the capability to CAP_BLOCK_SUSPEND. In order to ensure
that the old capability name doesn't make it out into the wild, could you
please apply and push up the tree to ensure that it is incorporated
for the 3.5 release.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
When we get back a FIND_FIRST/NEXT result, we have some info about the
dentry that we use to instantiate a new inode. We were ignoring and
discarding that info when we had an existing dentry in the cache.
Fix this by updating the inode in place when we find an existing dentry
and the uniqueid is the same.
Cc: <stable@vger.kernel.org> # .31.x
Reported-and-Tested-by: Andrew Bartlett <abartlet@samba.org>
Reported-by: Bill Robertson <bill_robertson@debortoli.com.au>
Reported-by: Dion Edwards <dion_edwards@debortoli.com.au>
Jian found that when he ran fsx on a 32 bit arch with a large wsize the
process and one of the bdi writeback kthreads would sometimes deadlock
with a stack trace like this:
crash> bt
PID: 2789 TASK: f02edaa0 CPU: 3 COMMAND: "fsx"
#0 [eed63cbc] schedule at c083c5b3
#1 [eed63d80] kmap_high at c0500ec8
#2 [eed63db0] cifs_async_writev at f7fabcd7 [cifs]
#3 [eed63df0] cifs_writepages at f7fb7f5c [cifs]
#4 [eed63e50] do_writepages at c04f3e32
#5 [eed63e54] __filemap_fdatawrite_range at c04e152a
#6 [eed63ea4] filemap_fdatawrite at c04e1b3e
#7 [eed63eb4] cifs_file_aio_write at f7fa111a [cifs]
#8 [eed63ecc] do_sync_write at c052d202
#9 [eed63f74] vfs_write at c052d4ee
#10 [eed63f94] sys_write at c052df4c
#11 [eed63fb0] ia32_sysenter_target at c0409a98
EAX: 00000004 EBX: 00000003 ECX: abd73b73 EDX: 012a65c6
DS: 007b ESI: 012a65c6 ES: 007b EDI: 00000000
SS: 007b ESP: bf8db178 EBP: bf8db1f8 GS: 0033
CS: 0073 EIP: 40000424 ERR: 00000004 EFLAGS: 00000246
Each task would kmap part of its address array before getting stuck, but
not enough to actually issue the write.
This patch fixes this by serializing the marshal_iov operations for
async reads and writes. The idea here is to ensure that cifs
aggressively tries to populate a request before attempting to fulfill
another one. As soon as all of the pages are kmapped for a request, then
we can unlock and allow another one to proceed.
There's no need to do this serialization on non-CONFIG_HIGHMEM arches
however, so optimize all of this out when CONFIG_HIGHMEM isn't set.
Reported-by: Jian Li <jiali@redhat.com>
We currently rely on being able to kmap all of the pages in an async
read or write request. If you're on a machine that has CONFIG_HIGHMEM
set then that kmap space is limited, sometimes to as low as 512 slots.
With 512 slots, we can only support up to a 2M r/wsize, and that's
assuming that we can get our greedy little hands on all of them. There
are other users however, so it's possible we'll end up stuck with a
size that large.
Since we can't handle a rsize or wsize larger than that currently, cap
those options at the number of kmap slots we have. We could consider
capping it even lower, but we currently default to a max of 1M. Might as
well allow those luddites on 32 bit arches enough rope to hang
themselves.
A more robust fix would be to teach the send and receive routines how
to contend with an array of pages so we don't need to marshal up a kvec
array at all. That's a fairly significant overhaul though, so we'll need
this limit in place until that's ready.
A user reported a crash in cifs_demultiplex_thread() caused by an
incorrectly set mid_q_entry->callback() function. It appears that the
callback assignment made in cifs_call_async() was not flushed back to
memory suggesting that a memory barrier was required here. Changing the
code to make sure that the mid_q_entry structure was completely
initialised before it was added to the pending queue fixes the problem.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Pull xfs regression fixes from Ben Myers:
- Really fix a cursor leak in xfs_alloc_ag_vextent_near
- Fix a performance regression related to doing allocation in
workqueues
- Prevent recursion in xfs_buf_iorequest which is causing stack
overflows
- Don't call xfs_bdstrat_cb in xfs_buf_iodone callbacks
* tag 'for-linus-v3.5-rc7' of git://oss.sgi.com/xfs/xfs:
xfs: do not call xfs_bdstrat_cb in xfs_buf_iodone_callbacks
xfs: prevent recursion in xfs_buf_iorequest
xfs: don't defer metadata allocation to the workqueue
xfs: really fix the cursor leak in xfs_alloc_ag_vextent_near
If a parent and child process open the two ends of a fifo, and the
child immediately exits, the parent may receive a SIGCHLD before its
open() returns. In that case, we need to make sure that open() will
return successfully after the SIGCHLD handler returns, instead of
throwing EINTR or being restarted. Otherwise, the restarted open()
would incorrectly wait for a second partner on the other end.
The following test demonstrates the EINTR that was wrongly thrown from
the parent’s open(). Change .sa_flags = 0 to .sa_flags = SA_RESTART
to see a deadlock instead, in which the restarted open() waits for a
second reader that will never come. (On my systems, this happens
pretty reliably within about 5 to 500 iterations. Others report that
it manages to loop ~forever sometimes; YMMV.)
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <fcntl.h>
#include <signal.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#define CHECK(x) do if ((x) == -1) {perror(#x); abort();} while(0)
void handler(int signum) {}
int main()
struct sigaction act = {.sa_handler = handler, .sa_flags = 0};
CHECK(sigaction(SIGCHLD, &act, NULL));
CHECK(mknod("fifo", S_IFIFO | S_IRWXU, 0));
for (;;) {
int fd;
pid_t pid;
putc('.', stderr);
CHECK(pid = fork());
if (pid == 0) {
CHECK(fd = open("fifo", O_RDONLY));
_exit(0);
CHECK(fd = open("fifo", O_WRONLY));
CHECK(close(fd));
CHECK(waitpid(pid, NULL, 0));
This is what I suspect was causing the Git test suite to fail in
t9010-svn-fe.sh:
http://bugs.debian.org/678852
Signed-off-by: Anders Kaseorg <andersk@mit.edu>
Reviewed-by: Jonathan Nieder <jrnieder@gmail.com>
Cc: stable@kernel.org
xfs_bdstrat_cb only adds a check for a shutdown filesystem over
xfs_buf_iorequest, but xfs_buf_iodone_callbacks just checked for a shut down
filesystem a little earlier. In addition the shutdown handling in
xfs_bdstrat_cb is not very suitable for this caller.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
If the b_iodone handler is run in calling context in xfs_buf_iorequest we
can run into a recursion where xfs_buf_iodone_callbacks keeps calling back
into xfs_buf_iorequest because an I/O error happened, which keeps calling
back into xfs_buf_iorequest. This chain will usually not take long
because the filesystem gets shut down because of log I/O errors, but even
over a short time it can cause stack overflows if run on the same context.
As a short term workaround make sure we always call the iodone handler in
workqueue context.
Almost all metadata allocations come from shallow stack usage
situations. Avoid the overhead of switching the allocation to a
workqueue as we are not in danger of running out of stack when
making these allocations. Metadata allocations are already marked
through the args that are passed down, so this is trivial to do.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reported-by: Mel Gorman <mgorman@suse.de>
Tested-by: Mel Gorman <mgorman@suse.de>
The current cursor is reallocated when retrying the allocation, so
the existing cursor needs to be destroyed in both the restart and
the failure cases.
Tested-by: Mike Snitzer <snitzer@redhat.com>
Pull NFS client bugfixes from Trond Myklebust:
- Fix an NFSv4 mount regression
- Fix O_DIRECT list manipulation snafus
* tag 'nfs-for-3.5-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv4: Fix an NFSv4 mount regression
NFS: Fix list manipulation snafus in fs/nfs/direct.c
This can be trivially triggered from userspace by passing in something unexpected.
kernel BUG at fs/locks.c:1468!
invalid opcode: 0000 [#1] SMP
RIP: 0010:generic_setlease+0xc2/0x100
Call Trace:
__vfs_setlease+0x35/0x40
fcntl_setlease+0x76/0x150
sys_fcntl+0x1c6/0x810
system_call_fastpath+0x1a/0x1f
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: stable@kernel.org # 3.2+
Commit 080399aaaf35 ("block: don't mark buffers beyond end of disk as
mapped") exposed a bug in __getblk_slow that causes mount to hang as it
loops infinitely waiting for a buffer that lies beyond the end of the
disk to become uptodate.
The problem was initially reported by Torsten Hilbrich here:
https://lkml.org/lkml/2012/6/18/54
and also reported independently here:
http://www.sysresccd.org/forums/viewtopic.php?f=13&t=4511
and then Richard W.M. Jones and Marcos Mello noted a few separate
bugzillas also associated with the same issue. This patch has been
confirmed to fix:
https://bugzilla.redhat.com/show_bug.cgi?id=835019
The main problem is here, in __getblk_slow:
for (;;) {
struct buffer_head * bh;
int ret;
bh = __find_get_block(bdev, block, size);
if (bh)
return bh;
ret = grow_buffers(bdev, block, size);
if (ret < 0)
return NULL;
if (ret == 0)
free_more_memory();
__find_get_block does not find the block, since it will not be marked as
mapped, and so grow_buffers is called to fill in the buffers for the
associated page. I believe the for (;;) loop is there primarily to
retry in the case of memory pressure keeping grow_buffers from
succeeding. However, we also continue to loop for other cases, like the
block lying beond the end of the disk. So, the fix I came up with is to
only loop when grow_buffers fails due to memory allocation issues
(return value of 0).
The attached patch was tested by myself, Torsten, and Rich, and was
found to resolve the problem in call cases.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reported-and-Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Tested-by: Richard W.M. Jones <rjones@redhat.com>
Reviewed-by: Josh Boyer <jwboyer@redhat.com>
Cc: Stable <stable@vger.kernel.org> # 3.0+
[ Jens is on vacation, taking this directly - Linus ]
Stable Notes: this patch requires backport to 3.0, 3.2 and 3.3.
