commit a9cfcd63e8d206ce4235c355d857c4fbdf0f4587 upstream.
Thanks to Dan Carpenter for extending smatch to find bugs like this.
(This was found using a development version of smatch.)
Fixes: 36de928641ee48b2078d3fe9514242aaa2f92013
Reported-by: Dan Carpenter <dan.carpenter@oracle.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 36de928641ee48b2078d3fe9514242aaa2f92013 upstream.
If we run into some kind of error, such as ENOMEM, while calling
ext4_getblk() or ext4_dx_find_entry(), we need to make sure this error
gets propagated up to ext4_find_entry() and then to its callers. This
way, transient errors such as ENOMEM can get propagated to the VFS.
This is important so that the system calls return the appropriate
error, and also so that in the case of ext4_lookup(), we return an
error instead of a NULL inode, since that will result in a negative
dentry cache entry that will stick around long past the OOM condition
which caused a transient ENOMEM error.
Google-Bug-Id: #17142205
commit 6098b45b32e6baeacc04790773ced9340601d511 upstream.
It seems that exit_aio() also needs to wait for all iocbs to complete (like
io_destroy), but we missed the wait step in current implemention, so fix
it in the same way as we did in io_destroy.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
[bwh: Backported to 3.16: adjust context]
commit f2d5a94436cc7cc0221b9a81bba2276a25187dd3 upstream.
On 32-bit architectures, the legacy buffer_head functions are not always
handling the sector number with the proper 64-bit types, and will thus
fail on 4TB+ disks.
Any code that uses __getblk() (and thus bread(), breadahead(),
sb_bread(), sb_breadahead(), sb_getblk()), and calls it using a 64-bit
block on a 32-bit arch (where "long" is 32-bit) causes an inifinite loop
in __getblk_slow() with an infinite stream of errors logged to dmesg
like this:
__find_get_block_slow() failed. block=6740375944, b_blocknr=2445408648
b_state=0x00000020, b_size=512
device sda1 blocksize: 512
Note how in hex block is 0x191C1F988 and b_blocknr is 0x91C1F988 i.e. the
top 32-bits are missing (in this case the 0x1 at the top).
This is because grow_dev_page() is broken and has a 32-bit overflow due
to shifting the page index value (a pgoff_t - which is just 32 bits on
32-bit architectures) left-shifted as the block number. But the top
bits to get lost as the pgoff_t is not type cast to sector_t / 64-bit
before the shift.
This patch fixes this issue by type casting "index" to sector_t before
doing the left shift.
Note this is not a theoretical bug but has been seen in the field on a
4TiB hard drive with logical sector size 512 bytes.
This patch has been verified to fix the infinite loop problem on 3.17-rc5
kernel using a 4TB disk image mounted using "-o loop". Without this patch
doing a "find /nt" where /nt is an NTFS volume causes the inifinite loop
100% reproducibly whilst with the patch it works fine as expected.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
commit cfb2f9d5c921e38b0f12bb26fed10b877664444d upstream.
Callers of d_splice_alias(dentry, inode) don't need iput(), neither
on success nor on failure. Either the reference to inode is stored
in a previously negative dentry, or it's dropped. In either case
inode reference the caller used to hold is consumed.
__gfs2_lookup() does iput() in case when d_splice_alias() has failed.
Double iput() if we ever hit that. And gfs2_create_inode() ends up
not only with double iput(), but with link count dropped to zero - on
an inode it has just found in directory.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 7bd88377d482e1eae3c5329b12e33cfd664fa6a9 upstream.
return the value instead, and have path_init() do the assignment. Broken by
"vfs: Fix absolute RCU path walk failures due to uninitialized seq number",
which was Cc-stable with 2.6.38+ as destination. This one should go where
it went.
To avoid dummy value returned in case when root is already set (it would do
no harm, actually, since the only caller that doesn't ignore the return value
is guaranteed to have nd->root *not* set, but it's more obvious that way),
lift the check into callers. And do the same to set_root(), to keep them
in sync.
commit 6ff66ac77aeaa9c13db28784e1c50c027a1f487b upstream.
Commit 0227d6abb378 ("fs/cachefiles: replace kerror by pr_err") didn't
include newline featuring in original kerror definition
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Reported-by: David Howells <dhowells@redhat.com>
commit 5760a97c7143c208fa3a8f8cad0ed7dd672ebd28 upstream.
There is a deadlock case which reported by Guozhonghua:
https://oss.oracle.com/pipermail/ocfs2-devel/2014-September/010079.html
This case is caused by &res->spinlock and &dlm->master_lock
misordering in different threads.
It was introduced by commit 8d400b81cc83 ("ocfs2/dlm: Clean up refmap
helpers"). Since lockres is new, it doesn't not require the
&res->spinlock. So remove it.
Fixes: 8d400b81cc83 ("ocfs2/dlm: Clean up refmap helpers")
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: joyce.xue <xuejiufei@huawei.com>
Reported-by: Guozhonghua <guozhonghua@h3c.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 56d7acc792c0d98f38f22058671ee715ff197023 upstream.
This bug leads to reproducible silent data loss, despite the use of
msync(), sync() and a clean unmount of the file system. It is easily
reproducible with the following script:
----------------[BEGIN SCRIPT]--------------------
mkfs.nilfs2 -f /dev/sdb
mount /dev/sdb /mnt
dd if=/dev/zero bs=1M count=30 of=/mnt/testfile
umount /mnt
mount /dev/sdb /mnt
CHECKSUM_BEFORE="$(md5sum /mnt/testfile)"
/root/mmaptest/mmaptest /mnt/testfile 30 10 5
sync
CHECKSUM_AFTER="$(md5sum /mnt/testfile)"
umount /mnt
mount /dev/sdb /mnt
CHECKSUM_AFTER_REMOUNT="$(md5sum /mnt/testfile)"
umount /mnt
echo "BEFORE MMAP:\t$CHECKSUM_BEFORE"
echo "AFTER MMAP:\t$CHECKSUM_AFTER"
echo "AFTER REMOUNT:\t$CHECKSUM_AFTER_REMOUNT"
----------------[END SCRIPT]--------------------
The mmaptest tool looks something like this (very simplified, with
error checking removed):
----------------[BEGIN mmaptest]--------------------
data = mmap(NULL, file_size - file_offset, PROT_READ | PROT_WRITE,
MAP_SHARED, fd, file_offset);
for (i = 0; i < write_count; ++i) {
memcpy(data + i * 4096, buf, sizeof(buf));
msync(data, file_size - file_offset, MS_SYNC))
----------------[END mmaptest]--------------------
The output of the script looks something like this:
BEFORE MMAP: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile
AFTER MMAP: 6604a1c31f10780331a6850371b3a313 /mnt/testfile
AFTER REMOUNT: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile
So it is clear, that the changes done using mmap() do not survive a
remount. This can be reproduced a 100% of the time. The problem was
introduced in commit 136e8770cd5d ("nilfs2: fix issue of
nilfs_set_page_dirty() for page at EOF boundary").
If the page was read with mpage_readpage() or mpage_readpages() for
example, then it has no buffers attached to it. In that case
page_has_buffers(page) in nilfs_set_page_dirty() will be false.
Therefore nilfs_set_file_dirty() is never called and the pages are never
collected and never written to disk.
This patch fixes the problem by also calling nilfs_set_file_dirty() if the
page has no buffers attached to it.
[akpm@linux-foundation.org: s/PAGE_SHIFT/PAGE_CACHE_SHIFT/]
Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net>
Tested-by: Andreas Rohner <andreas.rohner@gmx.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 7e8824816bda16bb11ff5ff1e1212d642e57b0b3 upstream.
Currently we handle only ENOSPC. In case of other errors the file_handle
variable isn't filled properly and we will show a part of stack.
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
commit 1fc98d11cac6dd66342e5580cb2687e5b1e9a613 upstream.
MAX_HANDLE_SZ is equal to 128, but currently the size of pad is only 64
bytes, so exportfs_encode_inode_fh can return an error.
commit c680e41b3a2e944185c74bf60531e3d316d3ecc4 upstream.
When calling epoll_ctl with operation EPOLL_CTL_DEL, structure epds is
not initialized but ep_take_care_of_epollwakeup reads its event field.
When this unintialized field has EPOLLWAKEUP bit set, a capability check
is done for CAP_BLOCK_SUSPEND in ep_take_care_of_epollwakeup. This
produces unexpected messages in the audit log, such as (on a system
running SELinux):
type=AVC msg=audit(1408212798.866:410): avc: denied
{ block_suspend } for pid=7754 comm="dbus-daemon" capability=36
scontext=unconfined_u:unconfined_r:unconfined_t
tcontext=unconfined_u:unconfined_r:unconfined_t
tclass=capability2 permissive=1
type=SYSCALL msg=audit(1408212798.866:410): arch=c000003e syscall=233
success=yes exit=0 a0=3 a1=2 a2=9 a3=7fffd4d66ec0 items=0 ppid=1
pid=7754 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0
fsgid=0 tty=(none) ses=3 comm="dbus-daemon"
exe="/usr/bin/dbus-daemon"
subj=unconfined_u:unconfined_r:unconfined_t key=(null)
("arch=c000003e syscall=233 a1=2" means "epoll_ctl(op=EPOLL_CTL_DEL)")
Remove use of epds in epoll_ctl when op == EPOLL_CTL_DEL.
Fixes: 4d7e30d98939 ("epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are ready")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Cc: Arve Hjønnevåg <arve@android.com>
commit 7c17705e77b12b20fb8afb7c1b15dcdb126c0c12 upstream.
Nikita Yuschenko reported that booting a kernel with init=/bin/sh and
then nfs mounting without portmap or rpcbind running using a busybox
mount resulted in:
# mount -t nfs 10.30.130.21:/opt /mnt
svc: failed to register lockdv1 RPC service (errno 111).
lockd_up: makesock failed, error=-111
Unable to handle kernel paging request for data at address 0x00000030
Faulting instruction address: 0xc055e65c
Oops: Kernel access of bad area, sig: 11 [#1]
MPC85xx CDS
Modules linked in:
CPU: 0 PID: 1338 Comm: mount Not tainted 3.10.44.cge #117
task: cf29cea0 ti: cf35c000 task.ti: cf35c000
NIP: c055e65c LR: c0566490 CTR: c055e648
REGS: cf35dad0 TRAP: 0300 Not tainted (3.10.44.cge)
MSR: 00029000 <CE,EE,ME> CR: 22442488 XER: 20000000
DEAR: 00000030, ESR: 00000000
GPR00: c05606f4 cf35db80 cf29cea0 cf0ded80 cf0dedb8 00000001 1dec3086
00000000
GPR08: 00000000 c07b1640 00000007 1dec3086 22442482 100b9758 00000000
10090ae8
GPR16: 00000000 000186a5 00000000 00000000 100c3018 bfa46edc 100b0000
bfa46ef0
GPR24: cf386ae0 c07834f0 00000000 c0565f88 00000001 cf0dedb8 00000000
cf0ded80
NIP [c055e65c] call_start+0x14/0x34
LR [c0566490] __rpc_execute+0x70/0x250
Call Trace:
[cf35db80] [00000080] 0x80 (unreliable)
[cf35dbb0] [c05606f4] rpc_run_task+0x9c/0xc4
[cf35dbc0] [c0560840] rpc_call_sync+0x50/0xb8
[cf35dbf0] [c056ee90] rpcb_register_call+0x54/0x84
[cf35dc10] [c056f24c] rpcb_register+0xf8/0x10c
[cf35dc70] [c0569e18] svc_unregister.isra.23+0x100/0x108
[cf35dc90] [c0569e38] svc_rpcb_cleanup+0x18/0x30
[cf35dca0] [c0198c5c] lockd_up+0x1dc/0x2e0
[cf35dcd0] [c0195348] nlmclnt_init+0x2c/0xc8
[cf35dcf0] [c015bb5c] nfs_start_lockd+0x98/0xec
[cf35dd20] [c015ce6c] nfs_create_server+0x1e8/0x3f4
[cf35dd90] [c0171590] nfs3_create_server+0x10/0x44
[cf35dda0] [c016528c] nfs_try_mount+0x158/0x1e4
[cf35de20] [c01670d0] nfs_fs_mount+0x434/0x8c8
[cf35de70] [c00cd3bc] mount_fs+0x20/0xbc
[cf35de90] [c00e4f88] vfs_kern_mount+0x50/0x104
[cf35dec0] [c00e6e0c] do_mount+0x1d0/0x8e0
[cf35df10] [c00e75ac] SyS_mount+0x90/0xd0
[cf35df40] [c000ccf4] ret_from_syscall+0x0/0x3c
The addition of svc_shutdown_net() resulted in two calls to
svc_rpcb_cleanup(); the second is no longer necessary and crashes when
it calls rpcb_register_call with clnt=NULL.
Reported-by: Nikita Yushchenko <nyushchenko@dev.rtsoft.ru>
Fixes: 679b033df484 "lockd: ensure we tear down any live sockets when socket creation fails during lockd_up"
Acked-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit da80659d4aa758dc6935b10ec64513f0b67bc969 upstream.
We were not checking for symlink support properly for SMB2/SMB3
mounts so could oops when mounted with mfsymlinks when try
to create symlink when mfsymlinks on smb2/smb3 mounts
Signed-off-by: Steve French <smfrench@gmail.com>
CC: Sachin Prabhu <sprabhu@redhat.com>
commit 78270e8fbc2916bfc8305b8f58f33474cce1ec0e upstream.
Commit 6094f83864c1d1296566a282cba05ba613f151ee
"nfs: allow coalescing of subpage requests" got rid of the requirement
that requests cover whole pages, but it made some incorrect assumptions.
It turns out that callers of this interface can map adjacent requests
(by file position as seen by req_offset + req->wb_bytes) to different pages,
even when they could share a page. An example is the direct I/O interface -
iov_iter_get_pages_alloc may return one segment with a partial page filled
and the next segment (which is adjacent in the file position) starts with a
new page.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit bba5c1887a925a9945d22217d38d58d8b3ba1043 upstream.
Adjacent requests that share the same page are allowed, but should only
use one entry in the page vector. This avoids overruning the page
vector - it is sized based on how many bytes there are, not by
request count.
This fixes issues that manifest as "Redzone overwritten" bugs (the
vector overrun) and hangs waiting on page read / write, as it waits on
the same page more than once.
This also adds bounds checking to the page vector with a graceful failure
(WARN_ON_ONCE and pgio error returned to application).
commit 7c3af975257383ece54b83c0505d3e0656cb7daf upstream.
This handles the 'nonblock=false' case in nfs_lock_and_join_requests.
If the group is already locked and blocking is allowed, drop the inode lock
and wait for the group lock to be cleared before trying it all again.
This should fix warnings found in peterz's tree (sched/wait branch), where
might_sleep() checks are added to wait.[ch].
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reviewed-by: Peng Tao <tao.peng@primarydata.com>
commit 94970014c46223cbcdfbfc67b89596a412f9e3dd upstream.
This fixes handling of errors from nfs_page_group_lock in
nfs_lock_and_join_requests. It now releases the inode lock and the
reference to the head request.
Reported-by: Peng Tao <tao.peng@primarydata.com>
commit bfd484a5606d6a0379a0a2f04251b1e5c1f8995c upstream.
__nfs_pageio_add_request was calling nfs_page_group_lock nonblocking, but
this can return -EAGAIN which would end up passing -EIO to the application.
There is no reason not to block in this path, so change the two calls to
do so. Also, there is no need to check the return value of
nfs_page_group_lock when nonblock=false, so remove the error handling code.
commit bc8a309e88a86205fc3e17f06e42a2e56fc6f807 upstream.
nfs_page_group_lock was calling wait_on_bit_lock even when told not to
block. Fix by first trying test_and_set_bit, followed by wait_on_bit_lock
if and only if blocking is allowed. Return -EAGAIN if nonblocking and the
test_and_set of the bit was already locked.
commit fd2f3a06d30c85a17cf035ebc60c88c2a13a8ece upstream.
Flip the meaning of the second argument from 'wait' to 'nonblock' to
match related functions. Update all five calls to reflect this change.
commit 411a99adffb4f993eee29759f744de01487044ac upstream.
commit e6cf82d1830f5e16a10d566f58db70f297ba5da8 upstream.
This is useful when lsegs need to be released while holding locks.
commit e7029206ff43f6cf7d6fcb741adb126f47200516 upstream.
Return errors from wait_on_bit_lock from nfs_page_group_lock.
Add a bool argument @wait to nfs_page_group_lock. If true, loop over
wait_on_bit_lock until it returns cleanly. If false, return the error
from wait_on_bit_lock.
commit 4714fb51fd03a14d8c73001438283e7f7b752f1e upstream.
The refcounting on nfs_pgio_header was related to there being (possibly)
more than one nfs_pgio_data. Now that nfs_pgio_data has been merged into
nfs_pgio_header, there is no reason to do this ref counting. Just call
the completion callback on nfs_pgio_release/nfs_pgio_error.
commit d45f60c67848b9f19160692581d78e5b4757a000 upstream.
struct nfs_pgio_data only exists as a member of nfs_pgio_header, but is
passed around everywhere, because there used to be multiple _data structs
per _header. Many of these functions then use the _data to find a pointer
to the _header. This patch cleans this up by merging the nfs_pgio_data
structure into nfs_pgio_header and passing nfs_pgio_header around instead.
commit 823b0c9d9800e712374cda89ac3565bd29f6701b upstream.
Rename "verf" to "writeverf" and "pages" to "page_array" to prepare for
merge of nfs_pgio_data and nfs_pgio_header.
commit 1e7f3a485922211b6e4a082ebc6bf05810b0b6ea upstream.
nfs_rw_header was used to allocate an nfs_pgio_header along with an
nfs_pgio_data, because a _header would need at least one _data.
Now there is only ever one nfs_pgio_data for each nfs_pgio_header -- move
it to nfs_pgio_header and get rid of nfs_rw_header.
commit 15b23ef5d348ea51c5e7573e2ef4116fbc7cb099 upstream.
The calculation of page_ptr here is wrong in the case the read doesn't
start at an offset that is a multiple of a page.
The result is that nfs4svc_encode_compoundres sets rq_next_page to a
value one too small, and then the loop in svc_free_res_pages may
incorrectly fail to clear a page pointer in rq_respages[].
Pages left in rq_respages[] are available for the next rpc request to
use, so xdr data may be written to that page, which may hold data still
waiting to be transmitted to the client or data in the page cache.
The observed result was silent data corruption seen on an NFSv4 client.
We tag this as "fixing" 05638dc73af2 because that commit exposed this
bug, though the incorrect calculation predates it.
Particular thanks to Andrea Arcangeli and David Gilbert for analysis and
testing.
Fixes: 05638dc73af2 "nfsd4: simplify server xdr->next_page use"
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
commit cd9288ffaea4359d5cfe2b8d264911506aed26a4 upstream.
James Drew reports another bug whereby the NFS client is now sending
an OPEN_DOWNGRADE in a situation where it should really have sent a
CLOSE: the client is opening the file for O_RDWR, but then trying to
do a downgrade to O_RDONLY, which is not allowed by the NFSv4 spec.
Reported-by: James Drews <drews@engr.wisc.edu>
Link: http://lkml.kernel.org/r/541AD7E5.8020409@engr.wisc.edu
Fixes: aee7af356e15 (NFSv4: Fix problems with close in the presence...)
commit 080af20cc945d110f9912d01cf6b66f94a375b8d upstream.
There is a race between nfs4_state_manager() and
nfs_server_remove_lists() that happens during a nfsv3 mount.
The v3 mount notices there is already a supper block so
nfs_server_remove_lists() called which uses the nfs_client_lock
spin lock to synchronize access to the client list.
At the same time nfs4_state_manager() is running through
the client list looking for work to do, using the same
lock. When nfs4_state_manager() wins the race to the
list, a v3 client pointer is found and not ignored
properly which causes the panic.
Moving some protocol checks before the state checking
avoids the panic.
Signed-off-by: Steve Dickson <steved@redhat.com>
commit aee3776441461c14ba6d8ed9e2149933e65abb6e upstream.
Commit 3b299709091b "nfsd4: enforce rd_dircount" totally misunderstood
rd_dircount; it refers to total non-attribute bytes returned, not number
of directory entries returned.
Bring the code into agreement with RFC 3530 section 14.2.24.
Fixes: 3b299709091b "nfsd4: enforce rd_dircount"
commit 9ef7db7f38d0472dd9c444e42d5c5175ccbe5451 upstream.
Commit 0244756edc4b ("ufs: sb mutex merge + mutex_destroy") introduces
deadlocks in ufs_new_inode() and ufs_free_inode().
Most callers of that functions acqure the mutex by themselves and
ufs_{new,free}_inode() do that via lock_ufs(),
i.e we have an unavoidable double lock.
The patch proposes to resolve the issue by making sure that
ufs_{new,free}_inode() are not called with the mutex held.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
commit e0b760ff71be168d4e623f7c3612e98902ab93e9 upstream.
The argument to locks_unlink_lock can't be just any pointer to a
pointer. It must be a pointer to the fl_next field in the previous
lock in the list.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
commit 2ff396be602f10b5eab8e73b24f20348fa2de159 upstream.
We ran into a case on ppc64 running mariadb where io_getevents would
return zeroed out I/O events. After adding instrumentation, it became
clear that there was some missing synchronization between reading the
tail pointer and the events themselves. This small patch fixes the
problem in testing.
Thanks to Zach for helping to look into this, and suggesting the fix.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
commit d856f32a86b2b015ab180ab7a55e455ed8d3ccc5 upstream.
As reported by Dan Aloni, commit f8567a3845ac ("aio: fix aio request
leak when events are reaped by userspace") introduces a regression when
user code attempts to perform io_submit() with more events than are
available in the ring buffer. Reverting that commit would reintroduce a
regression when user space event reaping is used.
Fixing this bug is a bit more involved than the previous attempts to fix
this regression. Since we do not have a single point at which we can
count events as being reaped by user space and io_getevents(), we have
to track event completion by looking at the number of events left in the
event ring. So long as there are as many events in the ring buffer as
there have been completion events generate, we cannot call
put_reqs_available(). The code to check for this is now placed in
refill_reqs_available().
A test program from Dan and modified by me for verifying this bug is available
at http://www.kvack.org/~bcrl/20140824-aio_bug.c .
Reported-by: Dan Aloni <dan@kernelim.com>
Acked-by: Dan Aloni <dan@kernelim.com>
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
commit 52755808d4525f4d5b86d112d36ffc7a46f3fb48 upstream.
SMB2 servers indicates the end of a directory search with
STATUS_NO_MORE_FILE error code that is not processed now.
This causes generic/257 xfstest to fail. Fix this by triggering
the end of search by this error code in SMB2_query_directory.
Also when negotiating CIFS protocol we tell the server to close
the search automatically at the end and there is no need to do
it itself. In the case of SMB2 protocol, we need to close it
explicitly - separate close directory checks for different
protocols.
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
commit 99d263d4c5b2f541dfacb5391e22e8c91ea982a6 upstream.
Josef Bacik found a performance regression between 3.2 and 3.10 and
narrowed it down to commit bfcfaa77bdf0 ("vfs: use 'unsigned long'
accesses for dcache name comparison and hashing"). He reports:
"The test case is essentially
for (i = 0; i < 1000000; i++)
mkdir("a$i");
On xfs on a fio card this goes at about 20k dir/sec with 3.2, and 12k
dir/sec with 3.10. This is because we spend waaaaay more time in
__d_lookup on 3.10 than in 3.2.
The new hashing function for strings is suboptimal for <
sizeof(unsigned long) string names (and hell even > sizeof(unsigned
long) string names that I've tested). I broke out the old hashing
function and the new one into a userspace helper to get real numbers
and this is what I'm getting:
Old hash table had 1000000 entries, 0 dupes, 0 max dupes
New hash table had 12628 entries, 987372 dupes, 900 max dupes
We had 11400 buckets with a p50 of 30 dupes, p90 of 240 dupes, p99 of 567 dupes for the new hash
My test does the hash, and then does the d_hash into a integer pointer
array the same size as the dentry hash table on my system, and then
just increments the value at the address we got to see how many
entries we overlap with.
As you can see the old hash function ended up with all 1 million
entries in their own bucket, whereas the new one they are only
distributed among ~12.5k buckets, which is why we're using so much
more CPU in __d_lookup".
The reason for this hash regression is two-fold:
- On 64-bit architectures the down-mixing of the original 64-bit
word-at-a-time hash into the final 32-bit hash value is very
simplistic and suboptimal, and just adds the two 32-bit parts
together.
In particular, because there is no bit shuffling and the mixing
boundary is also a byte boundary, similar character patterns in the
low and high word easily end up just canceling each other out.
- the old byte-at-a-time hash mixed each byte into the final hash as it
hashed the path component name, resulting in the low bits of the hash
generally being a good source of hash data. That is not true for the
word-at-a-time case, and the hash data is distributed among all the
bits.
The fix is the same in both cases: do a better job of mixing the bits up
and using as much of the hash data as possible. We already have the
"hash_32|64()" functions to do that.
Reported-by: Josef Bacik <jbacik@fb.com>
Cc: Chris Mason <clm@fb.com>
Cc: linux-fsdevel@vger.kernel.org
commit f736906a7669a77cf8cabdcbcf1dc8cb694e12ef upstream.
The existing code calls server->ops->close() that is not
right. This causes XFS test generic/310 to fail. Fix this
by using server->ops->closedir() function.
commit 1bbe4997b13de903c421c1cc78440e544b5f9064 upstream.
The existing code uses the old MAX_NAME constant. This causes
XFS test generic/013 to fail. Fix it by replacing MAX_NAME with
PATH_MAX that SMB1 uses. Also remove an unused MAX_NAME constant
definition.
commit a07d322059db66b84c9eb4f98959df468e88b34b upstream.
CIFS servers process nlink counts differently for files and directories.
In cifs_rename() if we the request fails on the existing target, we
try to remove it through cifs_unlink() but this is not what we want
to do for directories. As the result the following sequence of commands
mkdir {1,2}; mv -T 1 2; rmdir {1,2}; mkdir {1,2}; echo foo > 2/bar
and XFS test generic/023 fail with -ENOENT error. That's why the second
mkdir reuses the existing inode (target inode of the mv -T command) with
S_DEAD flag.
Fix this by checking whether the target is directory or not and
calling cifs_rmdir() rather than cifs_unlink() for directories.
commit b46799a8f28c43c5264ac8d8ffa28b311b557e03 upstream.
When we requests rename we also need to update attributes
of both source and target parent directories. Not doing it
causes generic/309 xfstest to fail on SMB2 mounts. Fix this
by marking these directories for force revalidating.
commit 18f39e7be0121317550d03e267e3ebd4dbfbb3ce upstream.
As Raphael Geissert pointed out, tcon_error_exit can dereference tcon
and there is one path in which tcon can be null.
Reported-by: Raphael Geissert <geissert@debian.org>
commit 038bc961c31b070269ecd07349a7ee2e839d4fec upstream.
If we get into read_into_pages() from cifs_readv_receive() and then
loose a network, we issue cifs_reconnect that moves all mids to
a private list and issue their callbacks. The callback of the async
read request sets a mid to retry, frees it and wakes up a process
that waits on the rdata completion.
After the connection is established we return from read_into_pages()
with a short read, use the mid that was freed before and try to read
the remaining data from the a newly created socket. Both actions are
not what we want to do. In reconnect cases (-EAGAIN) we should not
mask off the error with a short read but should return the error
code instead.
Acked-by: Jeff Layton <jlayton@samba.org>
commit 21496687a79424572f46a84c690d331055f4866f upstream.
The existing mapping causes unlink() call to return error after delete
operation. Changing the mapping to -EACCES makes the client process
the call like CIFS protocol does - reset dos attributes with ATTR_READONLY
flag masked off and retry the operation.
commit 85e584da3212140ee80fd047f9058bbee0bc00d5 upstream.
xfs is using truncate_pagecache_range to invalidate the page cache
during DIO reads. This is different from the other filesystems who
only invalidate pages during DIO writes.
truncate_pagecache_range is meant to be used when we are freeing the
underlying data structs from disk, so it will zero any partial
ranges in the page. This means a DIO read can zero out part of the
page cache page, and it is possible the page will stay in cache.
buffered reads will find an up to date page with zeros instead of
the data actually on disk.
This patch fixes things by using invalidate_inode_pages2_range
instead. It preserves the page cache invalidation, but won't zero
any pages.
[dchinner: catch error and warn if it fails. Comment.]
Signed-off-by: Chris Mason <clm@fb.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 834ffca6f7e345a79f6f2e2d131b0dfba8a4b67a upstream.
Similar to direct IO reads, direct IO writes are using
truncate_pagecache_range to invalidate the page cache. This is
incorrect due to the sub-block zeroing in the page cache that
truncate_pagecache_range() triggers.
any pages.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
commit 22e757a49cf010703fcb9c9b4ef793248c39b0c2 upstream.
generic/263 is failing fsx at this point with a page spanning
EOF that cannot be invalidated. The operations are:
1190 mapwrite 0x52c00 thru 0x5e569 (0xb96a bytes)
1191 mapread 0x5c000 thru 0x5d636 (0x1637 bytes)
1192 write 0x5b600 thru 0x771ff (0x1bc00 bytes)
where 1190 extents EOF from 0x54000 to 0x5e569. When the direct IO
write attempts to invalidate the cached page over this range, it
fails with -EBUSY and so any attempt to do page invalidation fails.
The real question is this: Why can't that page be invalidated after
it has been written to disk and cleaned?
Well, there's data on the first two buffers in the page (1k block
size, 4k page), but the third buffer on the page (i.e. beyond EOF)
is failing drop_buffers because it's bh->b_state == 0x3, which is
BH_Uptodate | BH_Dirty. IOWs, there's dirty buffers beyond EOF. Say
what?
OK, set_buffer_dirty() is called on all buffers from
__set_page_buffers_dirty(), regardless of whether the buffer is
beyond EOF or not, which means that when we get to ->writepage,
we have buffers marked dirty beyond EOF that we need to clean.
So, we need to implement our own .set_page_dirty method that
doesn't dirty buffers beyond EOF.
This is messy because the buffer code is not meant to be shared
and it has interesting locking issues on the buffer dirty bits.
So just copy and paste it and then modify it to suit what we need.
Note: the solutions the other filesystems and generic block code use
of marking the buffers clean in ->writepage does not work for XFS.
It still leaves dirty buffers beyond EOF and invalidations still
fail. Hence rather than play whack-a-mole, this patch simply
prevents those buffers from being dirtied in the first place.
commit 5fd364fee81a7888af806e42ed8a91c845894f2d upstream.
When running xfs/305, I noticed that quotacheck was flushing dquot
buffers that did not have the xfs_dquot_buf_ops verifiers attached:
XFS (vdb): _xfs_buf_ioapply: no ops on block 0x1dc8/0x1dc8
ffff880052489000: 44 51 01 04 00 00 65 b8 00 00 00 00 00 00 00 00 DQ....e.........
ffff880052489010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
ffff880052489020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
ffff880052489030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
CPU: 1 PID: 2376 Comm: mount Not tainted 3.16.0-rc2-dgc+ #306
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
ffff88006fe38000 ffff88004a0ffae8 ffffffff81cf1cca 0000000000000001
ffff88004a0ffb88 ffffffff814d50ca 000010004a0ffc70 0000000000000000
ffff88006be56dc4 0000000000000021 0000000000001dc8 ffff88007c773d80
Call Trace:
[<ffffffff81cf1cca>] dump_stack+0x45/0x56
[<ffffffff814d50ca>] _xfs_buf_ioapply+0x3ca/0x3d0
[<ffffffff810db520>] ? wake_up_state+0x20/0x20
[<ffffffff814d51f5>] ? xfs_bdstrat_cb+0x55/0xb0
[<ffffffff814d513b>] xfs_buf_iorequest+0x6b/0xd0
[<ffffffff814d51f5>] xfs_bdstrat_cb+0x55/0xb0
[<ffffffff814d53ab>] __xfs_buf_delwri_submit+0x15b/0x220
[<ffffffff814d6040>] ? xfs_buf_delwri_submit+0x30/0x90
[<ffffffff814d6040>] xfs_buf_delwri_submit+0x30/0x90
[<ffffffff8150f89d>] xfs_qm_quotacheck+0x17d/0x3c0
[<ffffffff81510591>] xfs_qm_mount_quotas+0x151/0x1e0
[<ffffffff814ed01c>] xfs_mountfs+0x56c/0x7d0
[<ffffffff814f0f12>] xfs_fs_fill_super+0x2c2/0x340
[<ffffffff811c9fe4>] mount_bdev+0x194/0x1d0
[<ffffffff814f0c50>] ? xfs_finish_flags+0x170/0x170
[<ffffffff814ef0f5>] xfs_fs_mount+0x15/0x20
[<ffffffff811ca8c9>] mount_fs+0x39/0x1b0
[<ffffffff811e4d67>] vfs_kern_mount+0x67/0x120
[<ffffffff811e757e>] do_mount+0x23e/0xad0
[<ffffffff8117abde>] ? __get_free_pages+0xe/0x50
[<ffffffff811e71e6>] ? copy_mount_options+0x36/0x150
[<ffffffff811e8103>] SyS_mount+0x83/0xc0
[<ffffffff81cfd40b>] tracesys+0xdd/0xe2
This was caused by dquot buffer readahead not attaching a verifier
structure to the buffer when readahead was issued, resulting in the
followup read of the buffer finding a valid buffer and so not
attaching new verifiers to the buffer as part of the read.
Also, when a verifier failure occurs, we then read the buffer
without verifiers. Attach the verifiers manually after this read so
that if the buffer is then written it will be verified that the
corruption has been repaired.
Further, when flushing a dquot we don't ask for a verifier when
reading in the dquot buffer the dquot belongs to. Most of the time
this isn't an issue because the buffer is still cached, but when it
is not cached it will result in writing the dquot buffer without
having the verfier attached.
commit 67dc288c21064b31a98a53dc64f6b9714b819fd6 upstream.
Crash testing of CRC enabled filesystems has resulted in a number of
reports of bad CRCs being detected after the filesystem was mounted.
Errors such as the following were being seen:
XFS (sdb3): Mounting V5 Filesystem
XFS (sdb3): Starting recovery (logdev: internal)
XFS (sdb3): Metadata CRC error detected at xfs_agf_read_verify+0x5a/0x100 [xfs], block 0x1
XFS (sdb3): Unmount and run xfs_repair
XFS (sdb3): First 64 bytes of corrupted metadata buffer:
ffff880136ffd600: 58 41 47 46 00 00 00 01 00 00 00 00 00 0f aa 40 XAGF...........@
ffff880136ffd610: 00 02 6d 53 00 02 77 f8 00 00 00 00 00 00 00 01 ..mS..w.........
ffff880136ffd620: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 03 ................
ffff880136ffd630: 00 00 00 04 00 08 81 d0 00 08 81 a7 00 00 00 00 ................
XFS (sdb3): metadata I/O error: block 0x1 ("xfs_trans_read_buf_map") error 74 numblks 1
The errors were typically being seen in AGF, AGI and their related
btree block buffers some time after log recovery had run. Often it
wasn't until later subsequent mounts that the problem was
discovered. The common symptom was a buffer with the correct
contents, but a CRC and an LSN that matched an older version of the
contents.
Some debug added to _xfs_buf_ioapply() indicated that buffers were
being written without verifiers attached to them from log recovery,
and Jan Kara isolated the cause to log recovery readahead an dit's
interactions with buffers that had a more recent LSN on disk than
the transaction being recovered. In this case, the buffer did not
get a verifier attached, and os when the second phase of log
recovery ran and recovered EFIs and unlinked inodes, the buffers
were modified and written without the verifier running. Hence they
had up to date contents, but stale LSNs and CRCs.
Fix it by attaching verifiers to buffers we skip due to future LSN
values so they don't escape into the buffer cache without the
correct verifier attached.
This patch is based on analysis and a patch from Jan Kara.
Reported-by: Jan Kara <jack@suse.cz>
Reported-by: Fanael Linithien <fanael4@gmail.com>
Reported-by: Grozdan <neutrino8@gmail.com>
