commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 0143fc5e9f6f5aad4764801015bc8d4b4a278200 upstream.
For type 0x51 the udf.parent_partref member in struct fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit fe685aabf7c8c9f138e5ea900954d295bf229175 upstream.
For type 1 the parent_offset member in struct isofs_fid gets copied
commit 89b1f39eb4189de745fae554b0d614d87c8d5c63 upstream.
For large UDF filesystems with 512-byte blocks the number of necessary
bitmap blocks is larger than 2^16 so s_nr_groups in udf_bitmap overflows
(the number will overflow for filesystems larger than 128 GB with
512-byte blocks). That results in ENOSPC errors despite the filesystem
has plenty of free space.
Fix the problem by changing s_nr_groups' type to 'int'. That is enough
even for filesystems 2^32 blocks (UDF maximum) and 512-byte blocksize.
Reported-and-tested-by: v10lator@myway.de
Cc: Jim Trigg <jtrigg@spamcop.net>
commit 2b405bfa84063bfa35621d2d6879f52693c614b0 upstream.
In data=journal mode, if we unmount the file system before a
transaction has a chance to complete, when the journal inode is being
evicted, we can end up calling into jbd2_log_wait_commit() for the
last transaction, after the journalling machinery has been shut down.
Arguably we should adjust ext4_should_journal_data() to return FALSE
for the journal inode, but the only place it matters is
ext4_evict_inode(), and so to save a bit of CPU time, and to make the
patch much more obviously correct by inspection(tm), we'll fix it by
explicitly not trying to waiting for a journal commit when we are
evicting the journal inode, since it's guaranteed to never succeed in
this case.
This can be easily replicated via:
mount -t ext4 -o data=journal /dev/vdb /vdb ; umount /vdb
WARNING: at /usr/projects/linux/ext4/fs/jbd2/journal.c:542 __jbd2_log_start_commit+0xba/0xcd()
Hardware name: Bochs
JBD2: bad log_start_commit: 3005630206 3005630206 0 0
Modules linked in:
Pid: 2909, comm: umount Not tainted 3.8.0-rc3 #1020
Call Trace:
[<c015c0ef>] warn_slowpath_common+0x68/0x7d
[<c02b7e7d>] ? __jbd2_log_start_commit+0xba/0xcd
[<c015c177>] warn_slowpath_fmt+0x2b/0x2f
[<c02b7e7d>] __jbd2_log_start_commit+0xba/0xcd
[<c02b8075>] jbd2_log_start_commit+0x24/0x34
[<c0279ed5>] ext4_evict_inode+0x71/0x2e3
[<c021f0ec>] evict+0x94/0x135
[<c021f9aa>] iput+0x10a/0x110
[<c02b7836>] jbd2_journal_destroy+0x190/0x1ce
[<c0175284>] ? bit_waitqueue+0x50/0x50
[<c028d23f>] ext4_put_super+0x52/0x294
[<c020efe3>] generic_shutdown_super+0x48/0xb4
[<c020f071>] kill_block_super+0x22/0x60
[<c020f3e0>] deactivate_locked_super+0x22/0x49
[<c020f5d6>] deactivate_super+0x30/0x33
[<c0222795>] mntput_no_expire+0x107/0x10c
[<c02233a7>] sys_umount+0x2cf/0x2e0
[<c02233ca>] sys_oldumount+0x12/0x14
[<c08096b8>] syscall_call+0x7/0xb
---[ end trace 6a954cc790501c1f ]---
jbd2_log_wait_commit: error: j_commit_request=-1289337090, tid=0
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 3a2256702e47f68f921dfad41b1764d05c572329 upstream.
This commit fixes a wrong return value of the number of the allocated
blocks in ext4_split_extent. When the length of blocks we want to
allocate is greater than the length of the current extent, we return a
wrong number. Let's see what happens in the following case when we
call ext4_split_extent().
map: [48, 72]
ex: [32, 64, u]
'ex' will be split into two parts:
ex1: [32, 47, u]
ex2: [48, 64, w]
'map->m_len' is returned from this function, and the value is 24. But
the real length is 16. So it should be fixed.
Meanwhile in this commit we use right length of the allocated blocks
when get_reserved_cluster_alloc in ext4_ext_handle_uninitialized_extents
is called.
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
Cc: Dmitry Monakhov <dmonakhov@openvz.org>
commit ad56edad089b56300fd13bb9eeb7d0424d978239 upstream.
jbd2_journal_dirty_metadata() didn't get a reference to journal_head it
was working with. This is OK in most of the cases since the journal head
should be attached to a transaction but in rare occasions when we are
journalling data, __ext4_journalled_writepage() can race with
jbd2_journal_invalidatepage() stripping buffers from a page and thus
journal head can be freed under hands of jbd2_journal_dirty_metadata().
Fix the problem by getting own journal head reference in
jbd2_journal_dirty_metadata() (and also in jbd2_journal_set_triggers()
which can possibly have the same issue).
Reported-by: Zheng Liu <gnehzuil.liu@gmail.com>
commit f853c616883a8de966873a1dab283f1369e275a1 upstream.
We've had several reports of people attempting to mount Windows 8 shares
and getting failures with a return code of -EINVAL. The default sec=
mode changed recently to sec=ntlmssp. With that, we expect and parse a
SPNEGO blob from the server in the NEGOTIATE reply.
The current decode_negTokenInit function first parses all of the
mechTypes and then tries to parse the rest of the negTokenInit reply.
The parser however currently expects a mechListMIC or nothing to follow the
mechTypes, but Windows 8 puts a mechToken field there instead to carry
some info for the new NegoEx stuff.
In practice, we don't do anything with the fields after the mechTypes
anyway so I don't see any real benefit in continuing to parse them.
This patch just has the kernel ignore the fields after the mechTypes.
We'll probably need to reinstate some of this if we ever want to support
NegoEx.
Reported-by: Jason Burgess <jason@jacknife2.dns2go.com>
Reported-by: Yan Li <elliot.li.tech@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit d646a02a9d44d1421f273ae3923d97b47b918176 upstream.
blkdev_ioctl(GETBLKSIZE) uses i_size_read() to read size of block device.
If we update block size directly, reader may see intermediate result in
some machines and configurations. Use i_size_write() instead.
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: M. Hindess <hindessm@uk.ibm.com>
Cc: Nikanth Karthikesan <knikanth@suse.de>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit bc178622d40d87e75abc131007342429c9b03351 upstream.
Doing this would reliably fail with -EBUSY for me:
# mount /dev/sdb2 /mnt/scratch; umount /mnt/scratch; mkfs.btrfs -f /dev/sdb2
unable to open /dev/sdb2: Device or resource busy
because mkfs.btrfs tries to open the device O_EXCL, and somebody still has it.
Using systemtap to track bdev gets & puts shows a kworker thread doing a
blkdev put after mkfs attempts a get; this is left over from the unmount
path:
btrfs_close_devices
__btrfs_close_devices
call_rcu(&device->rcu, free_device);
free_device
INIT_WORK(&device->rcu_work, __free_device);
schedule_work(&device->rcu_work);
so unmount might complete before __free_device fires & does its blkdev_put.
Adding an rcu_barrier() to btrfs_close_devices() causes unmount to wait
until all blkdev_put()s are done, and the device is truly free once
unmount completes.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit 8d0c2d10dd72c5292eda7a06231056a4c972e4cc upstream.
ext3_msg() takes the printk prefix as the second parameter and the
format string as the third parameter. Two callers of ext3_msg omit the
prefix and pass the format string as the second parameter and the first
parameter to the format string as the third parameter. In both cases
this string comes from an arbitrary source. Which means the string may
contain format string characters, which will
lead to undefined and potentially harmful behavior.
The issue was introduced in commit 4cf46b67eb("ext3: Unify log messages
in ext3") and is fixed by this patch.
commit a930d8790552658140d7d0d2e316af4f0d76a512 upstream.
If you open a pipe for neither read nor write, the pipe code will not
add any usage counters to the pipe, causing the 'struct pipe_inode_info"
to be potentially released early.
That doesn't normally matter, since you cannot actually use the pipe,
but the pipe release code - particularly fasync handling - still expects
the actual pipe infrastructure to all be there. And rather than adding
NULL pointer checks, let's just disallow this case, the same way we
already do for the named pipe ("fifo") case.
This is ancient going back to pre-2.4 days, and until trinity, nobody
naver noticed.
Reported-by: Dave Jones <davej@redhat.com>
security keys
commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream.
Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to
compat_process_vm_rw() shows that the compatibility code requires an
explicit "access_ok()" check before calling
compat_rw_copy_check_uvector(). The same difference seems to appear when
we compare fs/read_write.c:do_readv_writev() to
fs/compat.c:compat_do_readv_writev().
This subtle difference between the compat and non-compat requirements
should probably be debated, as it seems to be error-prone. In fact,
there are two others sites that use this function in the Linux kernel,
and they both seem to get it wrong:
Now shifting our attention to fs/aio.c, we see that aio_setup_iocb()
also ends up calling compat_rw_copy_check_uvector() through
aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to
be missing. Same situation for
security/keys/compat.c:compat_keyctl_instantiate_key_iov().
I propose that we add the access_ok() check directly into
compat_rw_copy_check_uvector(), so callers don't have to worry about it,
and it therefore makes the compat call code similar to its non-compat
counterpart. Place the access_ok() check in the same location where
copy_from_user() can trigger a -EFAULT error in the non-compat code, so
the ABI behaviors are alike on both compat and non-compat.
While we are here, fix compat_do_readv_writev() so it checks for
compat_rw_copy_check_uvector() negative return values.
And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error
handling.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit 5a7a613a47a715711b3f2d3322a0eac21d459166 upstream.
Commit 73ca100 broke the code that prevents the client from deleting
a silly renamed dentry. This affected "delete on last close"
semantics as after that commit, nothing prevented removal of
silly-renamed files. As a result, a process holding a file open
could easily get an ESTALE on the file in a directory where some
other process issued 'rm -rf some_dir_containing_the_file' twice.
Before the commit, any attempt at unlinking silly renamed files would
fail inside may_delete() with -EBUSY because of the
DCACHE_NFSFS_RENAMED flag. The following testcase demonstrates
the problem:
tail -f /nfsmnt/dir/file &
rm -rf /nfsmnt/dir
rm -rf /nfsmnt/dir
# second removal does not fail, 'tail' process receives ESTALE
The problem with the above commit is that it unhashes the old and
new dentries from the lookup path, even in the normal case when
a signal is not encountered and it would have been safe to call
d_move. Unfortunately the old dentry has the special
DCACHE_NFSFS_RENAMED flag set on it. Unhashing has the
side-effect that future lookups call d_alloc(), allocating a new
dentry without the special flag for any silly-renamed files. As a
result, subsequent calls to unlink silly renamed files do not fail
but allow the removal to go through. This will result in ESTALE
errors for any other process doing operations on the file.
To fix this, go back to using d_move on success.
For the signal case, it's unclear what we may safely do beyond d_drop.
Reported-by: Dave Wysochanski <dwysocha@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
commit ce2ac52105aa663056dfc17966ebed1bf93e6e64 upstream.
Kjell Braden reported this oops:
[ 833.211970] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 833.212816] IP: [< (null)>] (null)
[ 833.213280] PGD 1b9b2067 PUD e9f7067 PMD 0
[ 833.213874] Oops: 0010 [#1] SMP
[ 833.214344] CPU 0
[ 833.214458] Modules linked in: des_generic md4 nls_utf8 cifs vboxvideo drm snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq bnep rfcomm snd_timer bluetooth snd_seq_device ppdev snd vboxguest parport_pc joydev mac_hid soundcore snd_page_alloc psmouse i2c_piix4 serio_raw lp parport usbhid hid e1000
[ 833.215629]
[ 833.215629] Pid: 1752, comm: mount.cifs Not tainted 3.0.0-rc7-bisectcifs-fec11dd9a0+ #18 innotek GmbH VirtualBox/VirtualBox
[ 833.215629] RIP: 0010:[<0000000000000000>] [< (null)>] (null)
[ 833.215629] RSP: 0018:ffff8800119c9c50 EFLAGS: 00010282
[ 833.215629] RAX: ffffffffa02186c0 RBX: ffff88000c427780 RCX: 0000000000000000
[ 833.215629] RDX: 0000000000000000 RSI: ffff88000c427780 RDI: ffff88000c4362e8
[ 833.215629] RBP: ffff8800119c9c88 R08: ffff88001fc15e30 R09: 00000000d69515c7
[ 833.215629] R10: ffffffffa0201972 R11: ffff88000e8f6a28 R12: ffff88000c4362e8
[ 833.215629] R13: 0000000000000000 R14: 0000000000000000 R15: ffff88001181aaa6
[ 833.215629] FS: 00007f2986171700(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
[ 833.215629] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 833.215629] CR2: 0000000000000000 CR3: 000000001b982000 CR4: 00000000000006f0
[ 833.215629] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 833.215629] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 833.215629] Process mount.cifs (pid: 1752, threadinfo ffff8800119c8000, task ffff88001c1c16f0)
[ 833.215629] Stack:
[ 833.215629] ffffffff8116a9b5 ffff8800119c9c88 ffffffff81178075 0000000000000286
[ 833.215629] 0000000000000000 ffff88000c4276c0 ffff8800119c9ce8 ffff8800119c9cc8
[ 833.215629] ffffffff8116b06e ffff88001bc6fc00 ffff88000c4276c0 ffff88000c4276c0
[ 833.215629] Call Trace:
[ 833.215629] [<ffffffff8116a9b5>] ? d_alloc_and_lookup+0x45/0x90
[ 833.215629] [<ffffffff81178075>] ? d_lookup+0x35/0x60
[ 833.215629] [<ffffffff8116b06e>] __lookup_hash.part.14+0x9e/0xc0
[ 833.215629] [<ffffffff8116b1d6>] lookup_one_len+0x146/0x1e0
[ 833.215629] [<ffffffff815e4f7e>] ? _raw_spin_lock+0xe/0x20
[ 833.215629] [<ffffffffa01eef0d>] cifs_do_mount+0x26d/0x500 [cifs]
[ 833.215629] [<ffffffff81163bd3>] mount_fs+0x43/0x1b0
[ 833.215629] [<ffffffff8117d41a>] vfs_kern_mount+0x6a/0xd0
[ 833.215629] [<ffffffff8117e584>] do_kern_mount+0x54/0x110
[ 833.215629] [<ffffffff8117fdc2>] do_mount+0x262/0x840
[ 833.215629] [<ffffffff81108a0e>] ? __get_free_pages+0xe/0x50
[ 833.215629] [<ffffffff8117f9ca>] ? copy_mount_options+0x3a/0x180
[ 833.215629] [<ffffffff8118075d>] sys_mount+0x8d/0xe0
[ 833.215629] [<ffffffff815ece82>] system_call_fastpath+0x16/0x1b
[ 833.215629] Code: Bad RIP value.
[ 833.215629] RIP [< (null)>] (null)
[ 833.215629] RSP <ffff8800119c9c50>
[ 833.238525] ---[ end trace ec00758b8d44f529 ]---
When walking down the path on the server, it's possible to hit a
symlink. The path walking code assumes that the caller will handle that
situation properly, but cifs_get_root() isn't set up for it. This patch
prevents the oops by simply returning an error.
A better solution would be to try and chase the symlinks here, but that's
fairly complicated to handle.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=53221
Reported-and-tested-by: Kjell Braden <afflux@pentabarf.de>
commit 1cba0cdf5e4dbcd9e5fa5b54d7a028e55e2ca057 upstream.
__btrfs_close_devices() clones btrfs device structs with
memcpy(). Some of the fields in the clone are reinitialized, but it's
missing to init io_lock. In mainline this goes unnoticed, but on RT it
leaves the plist pointing to the original about to be freed lock
struct.
Initialize io_lock after cloning, so no references to the original
struct are left.
Reported-and-tested-by: Mike Galbraith <efault@gmx.de>
commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream.
[Issue]
When pstore is in panic and emergency-restart paths, it may be blocked
in those paths because it simply takes spin_lock.
This is an example scenario which pstore may hang up in a panic path:
- cpuA grabs psinfo->buf_lock
- cpuB panics and calls smp_send_stop
- smp_send_stop sends IRQ to cpuA
- after 1 second, cpuB gives up on cpuA and sends an NMI instead
- cpuA is now in an NMI handler while still holding buf_lock
- cpuB is deadlocked
This case may happen if a firmware has a bug and
cpuA is stuck talking with it more than one second.
Also, this is a similar scenario in an emergency-restart path:
- cpuA grabs psinfo->buf_lock and stucks in a firmware
- cpuB kicks emergency-restart via either sysrq-b or hangcheck timer.
And then, cpuB is deadlocked by taking psinfo->buf_lock again.
[Solution]
This patch avoids the deadlocking issues in both panic and emergency_restart
paths by introducing a function, is_non_blocking_path(), to check if a cpu
can be blocked in current path.
With this patch, pstore is not blocked even if another cpu has
taken a spin_lock, in those paths by changing from spin_lock_irqsave
to spin_trylock_irqsave.
In addition, according to a comment of emergency_restart() in kernel/sys.c,
spin_lock shouldn't be taken in an emergency_restart path to avoid
deadlock. This patch fits the comment below.
<snip>
* emergency_restart - reboot the system
* Without shutting down any hardware or taking any locks
* reboot the system. This is called when we know we are in
* trouble so this is our best effort to reboot. This is
* safe to call in interrupt context.
void emergency_restart(void)
<snip>
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: CAI Qian <caiqian@redhat.com>
commit dfca7cebc2679f3d129f8e680a8f199a7ad16e38 upstream.
drop_nlink() warns if nlink is already zero. This is triggerable by a buggy
userspace filesystem. The cure, I think, is worse than the disease so disable
the warning.
Reported-by: Tero Roponen <tero.roponen@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 2d32b29a1c2830f7c42caa8258c714acd983961f upstream.
When free nfs-client, it must free the ->cl_stateids.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 304e220f0879198b1f5309ad6f0be862b4009491 upstream.
ext4_has_free_clusters() should tell us whether there is enough free
clusters to allocate, however number of free clusters in the file system
is converted to blocks using EXT4_C2B() which is not only wrong use of
the macro (we should have used EXT4_NUM_B2C) but it's also completely
wrong concept since everything else is in cluster units.
Moreover when calculating number of root clusters we should be using
macro EXT4_NUM_B2C() instead of EXT4_B2C() otherwise the result might be
off by one. However r_blocks_count should always be a multiple of the
cluster ratio so doing a plain bit shift should be enough here. We
avoid using EXT4_B2C() because it's confusing.
As a result of the first problem number of free clusters is much bigger
than it should have been and ext4_has_free_clusters() would return 1 even
if there is really not enough free clusters available.
Fix this by removing the EXT4_C2B() conversion of free clusters and
using bit shift when calculating number of root clusters. This bug
affects number of xfstests tests covering file system ENOSPC situation
handling. With this patch most of the ENOSPC problems with bigalloc file
system disappear, especially the errors caused by delayed allocation not
having enough space when the actual allocation is finally requested.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 1231b3a1eb5740192aeebf5344dd6d6da000febf upstream.
Currently when new xattr block is created or released we we would call
dquot_free_block() or dquot_alloc_block() respectively, among the else
decrementing or incrementing the number of blocks assigned to the
inode by one block.
This however does not work for bigalloc file system because we always
allocate/free the whole cluster so we have to count with that in
dquot_free_block() and dquot_alloc_block() as well.
Use the clusters-to-blocks conversion EXT4_C2B() when passing number of
blocks to the dquot_alloc/free functions to fix the problem.
The problem has been revealed by xfstests #117 (and possibly others).
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit f1167009711032b0d747ec89a632a626c901a1ad upstream.
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
commit 15b49132fc972c63894592f218ea5a9a61b1a18f upstream.
Validate the bh pointer before using it, since
ext4_read_block_bitmap_nowait() might return NULL.
I've seen this in fsfuzz testing.
EXT4-fs error (device loop0): ext4_read_block_bitmap_nowait:385: comm touch: Cannot get buffer for block bitmap - block_group = 0, block_bitmap = 3925999616
IP: [<ffffffff8121de25>] ext4_wait_block_bitmap+0x25/0xe0
Call Trace:
[<ffffffff8121e1e5>] ext4_read_block_bitmap+0x35/0x60
[<ffffffff8125e9c6>] ext4_free_blocks+0x236/0xb80
[<ffffffff811d0d36>] ? __getblk+0x36/0x70
[<ffffffff811d0a5f>] ? __find_get_block+0x8f/0x210
[<ffffffff81191ef3>] ? kmem_cache_free+0x33/0x140
[<ffffffff812678e5>] ext4_xattr_release_block+0x1b5/0x1d0
[<ffffffff812679be>] ext4_xattr_delete_inode+0xbe/0x100
[<ffffffff81222a7c>] ext4_free_inode+0x7c/0x4d0
[<ffffffff812277b8>] ? ext4_mark_inode_dirty+0x88/0x230
[<ffffffff8122993c>] ext4_evict_inode+0x32c/0x490
[<ffffffff811b8cd7>] evict+0xa7/0x1c0
[<ffffffff811b8ed3>] iput_final+0xe3/0x170
[<ffffffff811b8f9e>] iput+0x3e/0x50
[<ffffffff812316fd>] ext4_add_nondir+0x4d/0x90
[<ffffffff81231d0b>] ext4_create+0xeb/0x170
[<ffffffff811aae9c>] vfs_create+0xac/0xd0
[<ffffffff811ac845>] lookup_open+0x185/0x1c0
[<ffffffff8129e3b9>] ? selinux_inode_permission+0xa9/0x170
[<ffffffff811acb54>] do_last+0x2d4/0x7a0
[<ffffffff811af743>] path_openat+0xb3/0x480
[<ffffffff8116a8a1>] ? handle_mm_fault+0x251/0x3b0
[<ffffffff811afc49>] do_filp_open+0x49/0xa0
[<ffffffff811bbaad>] ? __alloc_fd+0xdd/0x150
[<ffffffff8119da28>] do_sys_open+0x108/0x1f0
[<ffffffff8119db51>] sys_open+0x21/0x30
[<ffffffff81618959>] system_call_fastpath+0x16/0x1b
Also fix comment for ext4_read_block_bitmap_nowait()
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 54c807e71d5ac59dee56c685f2b66e27cd54c475 upstream.
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
CC: Christoph Hellwig <hch@infradead.org>
CC: Jens Axboe <axboe@kernel.dk>
CC: Jeff Moyer <jmoyer@redhat.com>
commit 309a85b6861fedbb48a22d45e0e079d1be993b3a upstream.
ocfs2_block_group_alloc_discontig() disables chain relink by setting
ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple
cluster groups.
It doesn't keep the credits for all chain relink,but
ocfs2_claim_suballoc_bits overrides this in this call trace:
ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()->
__ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits()
ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call
ocfs2_search_chain() one time and disable it again, and then we run out
of credits.
Fix is to allow relink by default and disable it in
ocfs2_block_group_alloc_discontig.
Without this patch, End-users will run into a crash due to run out of
credits, backtrace like this:
RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>]
jbd2_journal_dirty_metadata+0x164/0x170 [jbd2]
RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0
RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8
RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0
R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800
FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000
CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0
Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0)
Call Trace:
ocfs2_journal_dirty+0x2f/0x70 [ocfs2]
ocfs2_relink_block_group+0x111/0x480 [ocfs2]
ocfs2_search_chain+0x455/0x9a0 [ocfs2]
Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 32918dd9f19e5960af4cdfa41190bb843fb2247b upstream.
We need to re-initialize the security for a new reflinked inode with its
parent dirs if it isn't specified to be preserved for ocfs2_reflink().
However, the code logic is broken at ocfs2_init_security_and_acl()
although ocfs2_init_security_get() succeed. As a result,
ocfs2_acl_init() does not involked and therefore the default ACL of
parent dir was missing on the new inode.
Note this was introduced by 9d8f13ba3 ("security: new
security_inode_init_security API adds function callback")
To reproduce:
set default ACL for the parent dir(ocfs2 in this case):
$ setfacl -m default:user:jeff:rwx ../ocfs2/
$ getfacl ../ocfs2/
# file: ../ocfs2/
# owner: jeff
# group: jeff
user::rwx
group::r-x
other::r-x
default:user::rwx
default:group::r-x
default:mask::rwx
default:other::r-x
$ touch a
$ getfacl a
# file: a
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
Before patching, create reflink file b from a, the user
default ACL entry(user:jeff:rwx)was missing:
$ ./ocfs2_reflink a b
$ getfacl b
# file: b
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
In this case, the end user can also observed an error message at syslog:
(ocfs2_reflink,3229,2):ocfs2_init_security_and_acl:7193 ERROR: status = 0
After applying this patch, create reflink file c from a:
$ ./ocfs2_reflink a c
$ getfacl c
# file: c
# owner: jeff
# group: jeff
user::rw-
user:jeff:rwx #effective:rw-
group::r-x #effective:r--
mask::rw-
other::r--
Test program:
/* Usage: reflink <source> <dest> */
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <errno.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
static int
reflink_file(char const *src_name, char const *dst_name,
bool preserve_attrs)
int fd;
#ifndef REFLINK_ATTR_NONE
# define REFLINK_ATTR_NONE 0
#endif
#ifndef REFLINK_ATTR_PRESERVE
# define REFLINK_ATTR_PRESERVE 1
#endif
#ifndef OCFS2_IOC_REFLINK
struct reflink_arguments {
uint64_t old_path;
uint64_t new_path;
uint64_t preserve;
# define OCFS2_IOC_REFLINK _IOW ('o', 4, struct reflink_arguments)
#endif
struct reflink_arguments args = {
.old_path = (unsigned long) src_name,
.new_path = (unsigned long) dst_name,
.preserve = preserve_attrs ? REFLINK_ATTR_PRESERVE :
REFLINK_ATTR_NONE,
fd = open(src_name, O_RDONLY);
if (fd < 0) {
fprintf(stderr, "Failed to open %s: %s\n",
src_name, strerror(errno));
return -1;
if (ioctl(fd, OCFS2_IOC_REFLINK, &args) < 0) {
fprintf(stderr, "Failed to reflink %s to %s: %s\n",
src_name, dst_name, strerror(errno));
return -1;
int
main(int argc, char *argv[])
if (argc != 3) {
fprintf(stdout, "Usage: %s source dest\n", argv[0]);
return 1;
return reflink_file(argv[1], argv[2], 0);
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reviewed-by: Tao Ma <boyu.mt@taobao.com>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 9b171e0c74ca0549d0610990a862dd895870f04a upstream.
Acked-by: Joel Becker <jlbec@evilplan.org>
commit 666b3d803a511fbc9bc5e5ea8ce66010cf03ea13 upstream.
Currently, nlmclnt_lock will break out of the for(;;) loop when
the reclaimer wakes up the blocking lock thread by setting
nlm_lck_denied_grace_period. This causes the lock request to fail
with an ENOLCK error.
The intention was always to ensure that we resend the lock request
after the grace period has expired.
Reported-by: Wangyuan Zhang <Wangyuan.Zhang@netapp.com>
commit 5a12cca697aca5dfba42a7d4c3356acc0445a2b0 upstream.
now pnfs client uses block layout, maybe we can remove
blocklayoutdriver first. if we umount later,
it can cause oops in unset_pnfs_layoutdriver.
because nfss->pnfs_curr_ld->clear_layoutdriver is invalid.
reproduce it:
modprobe blocklayoutdriver
mount -t nfs4 -o minorversion=1 pnfsip:/ /mnt/
rmmod blocklayoutdriver
umount /mnt
then you can see following
CPU 0
Pid: 17023, comm: umount.nfs4 Tainted: GF O 3.7.0-rc6-pnfs #1 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform
RIP: 0010:[<ffffffffa04cfe6d>] [<ffffffffa04cfe6d>] unset_pnfs_layoutdriver+0x1d/0x70 [nfsv4]
RSP: 0018:ffff8800022d9e48 EFLAGS: 00010286
RAX: ffffffffa04a1b00 RBX: ffff88000b013800 RCX: 0000000000000001
RDX: ffffffff81ae8ee0 RSI: ffff880001ee94b8 RDI: ffff88000b013800
RBP: ffff8800022d9e58 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880001ee9400
R13: ffff8800105978c0 R14: 00007fff25846c08 R15: 0000000001bba550
FS: 00007f45ae7f0700(0000) GS:ffff880012c00000(0000) knlGS:0000000000000000
CR2: ffffffffa04a1b38 CR3: 0000000002c0c000 CR4: 00000000000006f0
Process umount.nfs4 (pid: 17023, threadinfo ffff8800022d8000, task ffff880006e48aa0)
Stack:
ffff8800105978c0 ffff88000b013800 ffff8800022d9e78 ffffffffa04cd0ce
ffff8800022d9e78 ffff88000b013800 ffff8800022d9ea8 ffffffffa04755a7
ffff8800022d9ea8 ffff880002f96400 ffff88000b013800 ffff880002f96400
Call Trace:
[<ffffffffa04cd0ce>] nfs4_destroy_server+0x1e/0x30 [nfsv4]
[<ffffffffa04755a7>] nfs_free_server+0xb7/0x150 [nfs]
[<ffffffffa047d4d5>] nfs_kill_super+0x35/0x40 [nfs]
[<ffffffff81178d35>] deactivate_locked_super+0x45/0x70
[<ffffffff8117986a>] deactivate_super+0x4a/0x70
[<ffffffff81193ee2>] mntput_no_expire+0xd2/0x130
[<ffffffff81194d62>] sys_umount+0x72/0xe0
[<ffffffff8154af59>] system_call_fastpath+0x16/0x1b
Code: 06 e1 b8 ea ff ff ff eb 9e 0f 1f 44 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 48 8b 87 80 03 00 00 48 89 fb 48 85 c0 74 29 <48> 8b 40 38 48 85 c0 74 02 ff d0 48 8b 03 3e ff 48 04 0f 94 c2
RIP [<ffffffffa04cfe6d>] unset_pnfs_layoutdriver+0x1d/0x70 [nfsv4]
RSP <ffff8800022d9e48>
---[ end trace 29f75aaedda058bf ]---
Signed-off-by: fanchaoting<fanchaoting@cn.fujitsu.com>
commit 3278bb748d2437eb1464765f36429e5d6aa91c38 upstream.
If lockres refresh failed, the super lock will never be released which
will cause some processes on other cluster nodes hung forever.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
commit 7630b661da330b35dd57b6f5d6d62b386f2dd751 upstream.
We found that bdev->bd_invalidated was left set once revalidate_disk()
is called, which results in page cache flush every time that device is
open.
Specifically, we found this problem in MD block device. Once we resize
a MD device, mdadm --monitor periodically flush all page cache for that
device every 60 or 1000 seconds when it opens the device.
This bug lies since at least 3.2.0 till the latest kernel(3.6.2). Patch
is attached.
The following steps will reproduce the problem.
1. prepair a block device (eg /dev/sdb).
2. create two partitions:
sudo parted /dev/sdb
mklabel gpt
mkpart primary 0% 50%
mkpart primary 50% 100%
3. create a md device.
sudo mdadm -C /dev/md/hoge -l 1 -n 2 -e 1.2 --assume-clean --auto=md --symlink=no /dev/sdb1 /dev/sdb2
4. create file system and mount it
sudo mkfs.ext3 /dev/md/hoge
sudo mkdir /mnt/test
sudo mount /dev/md/hoge /mnt/test
5. try to resize the device
sudo mdadm -G /dev/md/hoge --size=max
6. create a file to fill file cache.
sudo dd if=/dev/urandom of=/mnt/test/data bs=1M count=10
and verify the current status of file by free command.
7. mdadm monitor will open the md device every 1000 seconds and you
will find all file cache on the device are cleared.
The timing can be reduced by the following steps.
a) kill mdadm and restart it with --delay option
/sbin/mdadm --monitor --delay=30 --pid-file /var/run/mdadm/monitor.pid --daemonise --scan --syslog
or open the md device directly.
sudo dd if=/dev/md/hoge of=/dev/null bs=4096 count=1
Signed-off-by: MITSUNARI Shigeo <herumi@nifty.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
commit 676a0675cf9200ac047fb50825f80867b3bb733b upstream.
Running the command:
inotifywait -e unmount /mnt/disk
immediately aborts with a -EINVAL return code. This is however a valid
parameter. This abort occurs only if unmount is the sole event
parameter. If other event parameters are supplied, then the unmount
event wait will work.
The problem was introduced by commit 44b350fc23e ("inotify: Fix mask
checks"). In that commit, it states:
The mask checks in inotify_update_existing_watch() and
inotify_new_watch() are useless because inotify_arg_to_mask()
sets FS_IN_IGNORED and FS_EVENT_ON_CHILD bits anyway.
But instead of removing the useless checks, it did this:
mask = inotify_arg_to_mask(arg);
- if (unlikely(!mask))
+ if (unlikely(!(mask & IN_ALL_EVENTS)))
return -EINVAL;
The problem is that IN_ALL_EVENTS doesn't include IN_UNMOUNT, and other
parts of the code keep IN_UNMOUNT separate from IN_ALL_EVENTS. So the
check should be:
if (unlikely(!(mask & (IN_ALL_EVENTS | IN_UNMOUNT))))
But inotify_arg_to_mask(arg) always sets the IN_UNMOUNT bit in the mask
anyway, so the check is always going to pass and thus should simply be
removed. Also note that inotify_arg_to_mask completely controls what
mask bits get set from arg, there's no way for invalid bits to get
enabled there.
Lets fix it by simply removing the useless broken checks.
Signed-off-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: John McCutchan <john@johnmccutchan.com>
Cc: Robert Love <rlove@rlove.org>
Cc: Eric Paris <eparis@parisplace.org>
commit a9bae189542e71f91e61a4428adf6e5a7dfe8063 upstream.
There exists a situation when GC can work in background alone without
any other filesystem activity during significant time.
The nilfs_clean_segments() method calls nilfs_segctor_construct() that
updates superblocks in the case of NILFS_SC_SUPER_ROOT and
THE_NILFS_DISCONTINUED flags are set. But when GC is working alone the
nilfs_clean_segments() is called with unset THE_NILFS_DISCONTINUED flag.
As a result, the update of superblocks doesn't occurred all this time
and in the case of SPOR superblocks keep very old values of last super
root placement.
SYMPTOMS:
Trying to mount a NILFS2 volume after SPOR in such environment ends with
very long mounting time (it can achieve about several hours in some
cases).
REPRODUCING PATH:
1. It needs to use external USB HDD, disable automount and doesn't
make any additional filesystem activity on the NILFS2 volume.
2. Generate temporary file with size about 100 - 500 GB (for example,
dd if=/dev/zero of=<file_name> bs=1073741824 count=200). The size of
file defines duration of GC working.
3. Then it needs to delete file.
4. Start GC manually by means of command "nilfs-clean -p 0". When you
start GC by means of such way then, at the end, superblocks is updated
by once. So, for simulation of SPOR, it needs to wait sometime (15 -
40 minutes) and simply switch off USB HDD manually.
5. Switch on USB HDD again and try to mount NILFS2 volume. As a
result, NILFS2 volume will mount during very long time.
REPRODUCIBILITY: 100%
FIX:
This patch adds checking that superblocks need to update and set
THE_NILFS_DISCONTINUED flag before nilfs_clean_segments() call.
Reported-by: Sergey Alexandrov <splavgm@gmail.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit ab225417825963b6dc66be7ea80f94ac1378dfdf upstream.
Ensure that any setattr and getattr requests for junctions and/or
mountpoints are sent to the server. Ever since commit
0ec26fd0698 (vfs: automount should ignore LOOKUP_FOLLOW), we have
silently dropped any setattr requests to a server-side mountpoint.
For referrals, we have silently dropped both getattr and setattr
requests.
This patch restores the original behaviour for setattr on mountpoints,
and tries to do the same for referrals, provided that we have a
filehandle...
commit 4b05d09c18d9aa62d2e7fb4b057f54e5a38963f5 upstream.
CC: xfs@oss.sgi.com
CC: Ben Myers <bpm@sgi.com>
Reviewed-by: Ben Myers <bpm@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 10b8c7dff5d3633b69e77f57d404dab54ead3787 upstream.
When it goes to error through line 144, the memory allocated to *devname is
not freed, and the caller doesn't free it either in line 250. So we free the
memroy of *devname in function cifs_compose_mount_options() when it goes to
error.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 66bea92c69477a75a5d37b9bfed5773c92a3c4b4 upstream.
ext4_da_block_invalidatepages is missing a pagevec_init(),
which means that pvec->cold contains random garbage.
This affects whether the page goes to the front or
back of the LRU when ->cold makes it to
free_hot_cold_page()
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Signed-off-by: CAI Qian <caiqian@redhat.com>
Function start_read() can get an error before processing all pages.
It must not only release the remaining pages, but unlock them too.
This fixes http://tracker.newdream.net/issues/3370
Signed-off-by: David Zafman <david.zafman@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
(cherry picked from commit 8884d53dd63b1d9315b343564fcbe1ede004a99e)
If client sends cap message that requests new max size during
exporting caps, the exporting MDS will drop the message quietly.
So the client may wait for the reply that updates the max size
forever. call handle_cap_grant() for cap import message can
avoid this issue.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Signed-off-by: Sage Weil <sage@inktank.com>
(cherry picked from commit 0e5e1774a92e6fe9c511585de8f078b4c4c68dbb)
we should set i_truncate_pending to 0 after page cache is truncated
to i_truncate_size
(cherry picked from commit a85f50b6ef93fbbb2ae932ce9b2376509d172796)
Add dirty inode to cap_dirty_migrating list instead, this can avoid
ceph_flush_dirty_caps() entering infinite loop.
(cherry picked from commit 0685235ffd9dbdb9ccbda587f8a3c83ad1d5a921)
__wake_requests() will enter infinite loop if we use it to wake
requests in the session->s_waiting list. __wake_requests() deletes
requests from the list and __do_request() adds requests back to
the list.
(cherry picked from commit ed75ec2cd19b47efcd292b6e23f58e56f4c5bc34)
The cap from non-auth mds doesn't have a meaningful max_size value.
(cherry picked from commit 5e62ad30157d0da04cf40c6d1a2f4bc840948b9c)
This would reset a connection with any OSD that had an outstanding
request that was taking more than N seconds. The idea was that if the
OSD was buggy, the client could compensate by resending the request.
In reality, this only served to hide server bugs, and we haven't
actually seen such a bug in quite a while. Moreover, the userspace
client code never did this.
More importantly, often the request is taking a long time because the
OSD is trying to recover, or overloaded, and killing the connection
and retrying would only make the situation worse by giving the OSD
more work to do.
(cherry picked from commit 83aff95eb9d60aff5497e9f44a2ae906b86d8e88)
If we are creating an osd request and get an invalid layout, return
an EINVAL to the caller. We switch up the return to have an error
code instead of NULL implying -ENOMEM.
(cherry picked from commit 6816282dab3a72efe8c0d182c1bc2960d87f4322)
If the MDS gives us a dentry and we weren't prepared to handle it,
WARN_ON_ONCE instead of crashing.
Reported-by: Yan, Zheng <zheng.z.yan@intel.com>
(cherry picked from commit 6c5e50fa614fea5325a2973be06f7ec6f1055316)
When we detect a mds session reset, close the old ceph_connection before
reopening it. This ensures we clean up the old socket properly and keep
the ceph_connection state correct.
Reviewed-by: Yehuda Sadeh <yehuda@inktank.com>
(cherry picked from commit a53aab645c82f0146e35684b34692c69b5118121)
commit 96e5d1d3adf56f1c7eeb07258f6a1a0a7ae9c489 upstream.
In gfs2_trans_add_bh(), gfs2 was testing if a there was a bd attached to the
buffer without having the gfs2_log_lock held. It was then assuming it would
stay attached for the rest of the function. However, without either the log
lock being held of the buffer locked, __gfs2_ail_flush() could detach bd at any
time. This patch moves the locking before the test. If there isn't a bd
already attached, gfs2 can safely allocate one and attach it before locking.
There is no way that the newly allocated bd could be on the ail list,
and thus no way for __gfs2_ail_flush() to detach it.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
[bwh: Backported to 3.2: adjust context]
commit 128dd1759d96ad36c379240f8b9463e8acfd37a1 upstream.
EPOLL_CTL_MOD sets the interest mask before calling f_op->poll() to
ensure events are not missed. Since the modifications to the interest
mask are not protected by the same lock as ep_poll_callback, we need to
ensure the change is visible to other CPUs calling ep_poll_callback.
We also need to ensure f_op->poll() has an up-to-date view of past
events which occured before we modified the interest mask. So this
barrier also pairs with the barrier in wq_has_sleeper().
This should guarantee either ep_poll_callback or f_op->poll() (or both)
will notice the readiness of a recently-ready/modified item.
This issue was encountered by Andreas Voellmy and Junchang(Jason) Wang in:
http://thread.gmane.org/gmane.linux.kernel/1408782/
Signed-off-by: Eric Wong <normalperson@yhbt.net>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Andreas Voellmy <andreas.voellmy@yale.edu>
Tested-by: "Junchang(Jason) Wang" <junchang.wang@yale.edu>
Cc: netdev@vger.kernel.org
Cc: linux-fsdevel@vger.kernel.org
commit fb719c59bdb4fca86ee1fd1f42ab3735ca12b6b2 upstream.
Incrementing lenExtents even while writing to a hole is bad
for performance as calls to udf_discard_prealloc and
udf_truncate_tail_extent would not return from start if
isize != lenExtents
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
