path: root/fs
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: use alloc_workqueue function dlm: increase default hash table sizes dlm: record full callback state
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: call security_d_instantiate in d_obtain_alias V2 lose 'mounting_here' argument in ->d_manage() don't pass 'mounting_here' flag to follow_down() change the locking order for namespace_sem fix deadlock in pivot_root() vfs: split off vfsmount-related parts of vfs_kern_mount() Some fixes for pstore kill simple_set_mnt()
git://git.kernel.org/pub/scm/linux/kernel/git/bcopeland/omfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bcopeland/omfs: omfs: make readdir stop when filldir says so omfs: merge unlink() and rmdir(), close leak in rename() omfs: stop playing silly buggers with omfs_unlink() in ->rename() omfs: rename() needs to mark old_inode dirty after ctime update
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (25 commits) UBIFS: clean-up commentaries UBIFS: save 128KiB or more RAM UBIFS: allocate orphans scan buffer on demand UBIFS: allocate lpt dump buffer on demand UBIFS: allocate ltab checking buffer on demand UBIFS: allocate scanning buffer on demand UBIFS: allocate dump buffer on demand UBIFS: do not check data crc by default UBIFS: simplify UBIFS Kconfig menu UBIFS: print max. index node size UBIFS: handle allocation failures in UBIFS write path UBIFS: use max_write_size during recovery UBIFS: use max_write_size for write-buffers UBIFS: introduce write-buffer size field UBI: incorporate LEB offset information UBIFS: incorporate maximum write size UBI: provide LEB offset information UBI: incorporate maximum write size UBIFS: fix LEB number in printk UBIFS: restrict world-writable debugfs files ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18fs: call security_d_instantiate in d_obtain_alias V2Josef Bacik
While trying to track down some NFS problems with BTRFS, I kept noticing I was getting -EACCESS for no apparent reason. Eric Paris and printk() helped me figure out that it was SELinux that was giving me grief, with the following denial type=AVC msg=audit(1290013638.413:95): avc: denied { 0x800000 } for pid=1772 comm="nfsd" name="" dev=sda1 ino=256 scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=file Turns out this is because in d_obtain_alias if we can't find an alias we create one and do all the normal instantiation stuff, but we don't do the security_d_instantiate. Usually we are protected from getting a hashed dentry that hasn't yet run security_d_instantiate() by the parent's i_mutex, but obviously this isn't an option there, so in order to deal with the case that a second thread comes in and finds our new dentry before we get to run security_d_instantiate(), we go ahead and call it if we find a dentry already. Eric assures me that this is ok as the code checks to see if the dentry has been initialized already so calling security_d_instantiate() against the same dentry multiple times is ok. With this patch I'm no longer getting errant -EACCESS values. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18lose 'mounting_here' argument in ->d_manage()Al Viro
it's always false... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18don't pass 'mounting_here' flag to follow_down()Al Viro
it's always false now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18change the locking order for namespace_semAl Viro
Have it nested inside ->i_mutex. Instead of using follow_down() under namespace_sem, followed by grabbing i_mutex and checking that mountpoint to be is not dead, do the following: grab i_mutex check that it's not dead grab namespace_sem see if anything is mounted there if not, we've won otherwise drop locks put_path on what we had replace with what's mounted retry everything with new mountpoint to be New helper (lock_mount()) does that. do_add_mount(), do_move_mount(), do_loopback() and pivot_root() switched to it; in case of the last two that eliminates a race we used to have - original code didn't do follow_down(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18fix deadlock in pivot_root()Al Viro
Don't hold vfsmount_lock over the loop traversing ->mnt_parent; do check_mnt(new.mnt) under namespace_sem instead; combined with namespace_sem held over all that code it'll guarantee the stability of ->mnt_parent chain all the way to the root. Doing check_mnt() outside of namespace_sem in case of pivot_root() is wrong anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17vfs: split off vfsmount-related parts of vfs_kern_mount()Al Viro
new function: mount_fs(). Does all work done by vfs_kern_mount() except the allocation and filling of vfsmount; returns root dentry or ERR_PTR(). vfs_kern_mount() switched to using it and taken to fs/namespace.c, along with its wrappers. alloc_vfsmnt()/free_vfsmnt() made static. functions in namespace.c slightly reordered. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17Some fixes for pstoreTony Luck
1) Change from ->get_sb() to ->mount() 2) Use mount_single() instead of mount_nodev() 3) Pulled in ramfs_get_inode() & trimmed to what I need for pstore 4) Drop the ugly pstore_writefile() Just save data using kmalloc() and provide a pstore_file_read() that uses simple_read_from_buffer(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17kill simple_set_mnt()Al Viro
not needed anymore, since all users (->get_sb() instances) are gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Always set dx_node's fake_dirent explicitly. ext3: Fix an overflow in ext3_trim_fs. jbd: Remove one to many n's in a word. ext3: skip orphan cleanup on rocompat fs ext2: Fix link count corruption under heavy link+rename load ext3: speed up group trim with the right free block count. ext3: Adjust trim start with first_data_block. quota: return -ENOMEM when memory allocation fails
2011-03-17Merge branch 'nfs-for-2.6.39' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (54 commits) RPC: killing RPC tasks races fixed xprt: remove redundant check SUNRPC: Convert struct rpc_xprt to use atomic_t counters SUNRPC: Ensure we always run the tk_callback before tk_action sunrpc: fix printk format warning xprt: remove redundant null check nfs: BKL is no longer needed, so remove the include NFS: Fix a warning in fs/nfs/idmap.c Cleanup: Factor out some cut-and-paste code. cleanup: save 60 lines/100 bytes by combining two mostly duplicate functions. NFS: account direct-io into task io accounting gss:krb5 only include enctype numbers in gm_upcall_enctypes RPCRDMA: Fix FRMR registration/invalidate handling. RPCRDMA: Fix to XDR page base interpretation in marshalling logic. NFSv4: Send unmapped uid/gids to the server when using auth_sys NFSv4: Propagate the error NFS4ERR_BADOWNER to nfs4_do_setattr NFSv4: cleanup idmapper functions to take an nfs_server argument NFSv4: Send unmapped uid/gids to the server if the idmapper fails NFSv4: If the server sends us a numeric uid/gid then accept it NFSv4.1: reject zero layout with zeroed stripe unit ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: UDF: Fix compiler warning udf: Convert UDF to new truncate calling sequence
2011-03-17Merge branch 'for_next' into for_linusJan Kara
2011-03-16Merge branch 'mnt_devname' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'mnt_devname' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: vfs: bury ->get_sb() nfs: switch NFS from ->get_sb() to ->mount() nfs: stop mangling ->mnt_devname on NFS vfs: new superblock methods to override /proc/*/mount{s,info} nfs: nfs_do_{ref,sub}mount() superblock argument is redundant nfs: make nfs_path() work without vfsmount nfs: store devname at disconnected NFS roots nfs: propagate devname to nfs{,4}_get_root()
2011-03-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] tioca: Fix assignment from incompatible pointer warnings [IA64] mca.c: Fix cast from integer to pointer warning [IA64] setup.c Typo fix "Architechtuallly" [IA64] Add CONFIG_MISC_DEVICES=y to configs that need it. [IA64] disable interrupts at end of ia64_mca_cpe_int_handler() [IA64] Add DMA_ERROR_CODE define. pstore: fix build warning for unused return value from sysfs_create_file pstore: X86 platform interface using ACPI/APEI/ERST pstore: new filesystem interface to platform persistent storage
2011-03-16Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: That's all, folks fs/locks.c: Remove stale FIXME left over from BKL conversion ipx: remove the BKL appletalk: remove the BKL x25: remove the BKL ufs: remove the BKL hpfs: remove the BKL drivers: remove extraneous includes of smp_lock.h tracing: don't trace the BKL adfs: remove the big kernel lock
2011-03-16Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits) printk: do not mangle valid userspace syslog prefixes efivars: Add Documentation efivars: Expose efivars functionality to external drivers. efivars: Parameterize operations. efivars: Split out variable registration efivars: parameterize efivars efivars: Make efivars bin_attributes dynamic efivars: move efivars globals into struct efivars drivers:misc: ti-st: fix debugging code kref: Fix typo in kref documentation UIO: add PRUSS UIO driver support Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches firmware: Fix unaligned memory accesses in dmi-sysfs firmware: Add documentation for /sys/firmware/dmi firmware: Expose DMI type 15 System Event Log firmware: Break out system_event_log in dmi-sysfs firmware: Basic dmi-sysfs support firmware: Add DMI entry types to the headers Driver core: convert platform_{get,set}_drvdata to static inline functions Translate linux-2.6/Documentation/magic-number.txt into Chinese ...
2011-03-16vfs: bury ->get_sb()Al Viro
This is an ex-parrot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: switch NFS from ->get_sb() to ->mount()Al Viro
The last remaining instances of ->get_sb() can be converted ->mount() now - nothing in them uses new vfsmount anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: stop mangling ->mnt_devname on NFSAl Viro
now we can do that - nobody cares about its value anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16vfs: new superblock methods to override /proc/*/mount{s,info}Al Viro
a) ->show_devname(m, mnt) - what to put into devname columns in mounts, mountinfo and mountstats b) ->show_path(m, mnt) - what to put into relative path column in mountinfo Leaving those NULL gives old behaviour. NFS switched to using those. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: nfs_do_{ref,sub}mount() superblock argument is redundantAl Viro
It's always equal to dentry->d_sb Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: make nfs_path() work without vfsmountAl Viro
part 3: now we have everything to get nfs_path() just by dentry - just follow to (disconnected) root and pick the rest of the thing there. Start killing propagation of struct vfsmount * on the paths that used to bring it to nfs_path(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: store devname at disconnected NFS rootsAl Viro
part 2: make sure that disconnected roots have corresponding mnt_devname values stashed into them. Have nfs*_get_root() stuff a copy of devname into ->d_fsdata of the found root, provided that it is disconnected. Have ->d_release() free it when dentry goes away. Have the places where NFS uses ->d_fsdata for sillyrename (and that can *never* happen to a disconnected root - dentry will be attached to its parent) free old devname copies if they find those. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16nfs: propagate devname to nfs{,4}_get_root()Al Viro
step 1 of ->mnt_devname fixes: make sure we have the value of devname available in ..._get_root(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fix cdev leak on O_PATH final fput()
2011-03-16fix cdev leak on O_PATH final fput()Miklos Szeredi
__fput doesn't need a cdev_put() for O_PATH handles. Signed-off-by: mszeredi@suse.cz Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16Pull pstorev4 into release branchTony Luck
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: GFS2: Don't use _raw version of RCU dereference GFS2: Adding missing unlock_page() GFS2: Update to AIL list locking GFS2: introduce AIL lock GFS2: fix block allocation check for fallocate GFS2: Optimize glock multiple-dequeue code GFS2: Remove potential race in flock code GFS2: Fix glock deallocation race GFS2: quota allows exceeding hard limit GFS2: deallocation performance patch GFS2: panics on quotacheck update GFS2: Improve cluster mmap scalability GFS2: Fix glock queue trace point GFS2: Post-VFS scale update for RCU path walk GFS2: Use RCU for glock hash table
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: (46 commits) fs/9p: Make the writeback_fid owned by root fs/9p: Writeback dirty data before setattr fs/9p: call vmtruncate before setattr 9p opeation fs/9p: Properly update inode attributes on link fs/9p: Prevent multiple inclusion of same header fs/9p: Workaround vfs rename rehash bug fs/9p: Mark directory inode invalid for many directory inode operations fs/9p: Add . and .. dentry revalidation flag fs/9p: mark inode attribute invalid on rename, unlink and setattr fs/9p: Add support for marking inode attribute invalid fs/9p: Initialize root inode number for dotl fs/9p: Update link count correctly on different file system operations fs/9p: Add drop_inode 9p callback fs/9p: Add direct IO support in cached mode fs/9p: Fix inode i_size update in file_write fs/9p: set default readahead pages in cached mode fs/9p: Move writeback fid to v9fs_inode fs/9p: Add v9fs_inode fs/9p: Don't set stat.st_blocks based on nrpages fs/9p: Add inode hashing ...
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-16Increase OSF partition limit from 8 to 18Linus Torvalds
It turns out that while a maximum of 8 partitions may be what people "should" have had, you can actually fit up to 18 entries(*) in a sector. And some people clearly were taking advantage of that, like Michael Cree, who had ten partitions on one of his OSF disks. (*) The OSF partition data starts at byte offset 64 in the first sector, and the array of 16-byte partition entries start at offset 148 in the on-disk partition structure. Reported-by: Michael Cree <mcree@orcon.net.nz> Cc: stable@kernel.org (v2.6.38) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16prune back iprune_semChristoph Hellwig
iprune_sem is continously giving us lockdep warnings because we do take it in read mode in the reclaim path, but we're also doing non-NOFS allocations under it taken in write mode. Taking a bit deeper look at it I think it's fixable quite trivially: - for invalidate_inodes we do not need iprune_sem at all. We have an active reference on the superblock, so the filesystem is not going away until it has finished. - for evict_inodes we do need it, to make sure prune_icache has done it's work before we tear down the superblock. But there is no reason to hold it over the actual reclaim operation - it's enough to cycle through it after the actual reclaim to make sure we wait for any pending prune_icache to complete. We just have to remove the WARN_ON for otherwise busy inodes as they can actually happen now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16UBIFS: clean-up commentariesArtem Bityutskiy
Clean-up commentaries in debug.h and remove references to non-existing symblols. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: save 128KiB or more RAMArtem Bityutskiy
When debugging is enabled, we allocate a buffer of PEB size for various debugging purposes. However, now all users of this buffer are gone and we can safely remove it and save 128KiB or more RAM. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate orphans scan buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dbg_scan_orphans()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate lpt dump buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dump_lpt_leb()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate ltab checking buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dbg_check_ltab_lnum()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate scanning buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'scan_check_cb()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate dump buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dbg_dump_leb()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16fix follow_link() breakageAl Viro
commit 574197e0de46a8a4db5c54ef7b65e43ffa8873a7 had a missing piece, breaking the loop detection ;-/ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (57 commits) tidy the trailing symlinks traversal up Turn resolution of trailing symlinks iterative everywhere simplify link_path_walk() tail Make trailing symlink resolution in path_lookupat() iterative update nd->inode in __do_follow_link() instead of after do_follow_link() pull handling of one pathname component into a helper fs: allow AT_EMPTY_PATH in linkat(), limit that to CAP_DAC_READ_SEARCH Allow passing O_PATH descriptors via SCM_RIGHTS datagrams readlinkat(), fchownat() and fstatat() with empty relative pathnames Allow O_PATH for symlinks New kind of open files - "location only". ext4: Copy fs UUID to superblock ext3: Copy fs UUID to superblock. vfs: Export file system uuid via /proc/<pid>/mountinfo unistd.h: Add new syscalls numbers to asm-generic x86: Add new syscalls for x86_64 x86: Add new syscalls for x86_32 fs: Remove i_nlink check from file system link callback fs: Don't allow to create hardlink for deleted file vfs: Add open by file handle support ...
2011-03-15VFS: Fix the nfs sillyrename regression in kernel 2.6.38Trond Myklebust
The new vfs locking scheme introduced in 2.6.38 breaks NFS sillyrename because the latter relies on being able to determine the parent directory of the dentry in the ->iput() callback in order to send the appropriate unlink rpc call. Looking at the code that cares about races with dput(), there doesn't seem to be anything that specifically uses d_parent as a test for whether or not there is a race: - __d_lookup_rcu(), __d_lookup() all test for d_hashed() after d_parent - shrink_dcache_for_umount() is safe since nothing else can rearrange the dentries in that super block. - have_submount(), select_parent() and d_genocide() can test for a deletion if we set the DCACHE_DISCONNECTED flag when the dentry is removed from the parent's d_subdirs list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org (2.6.38, needs commit c826cb7dfce8 "dcache.c: create helper function for duplicated functionality" ) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'next' into for-linusJames Morris
2011-03-15dcache.c: create helper function for duplicated functionalityLinus Torvalds
This creates a helper function for he "try to ascend into the parent directory" case, which was written out in triplicate before. With all the locking and subtle sequence number stuff, we really don't want to duplicate that kind of code. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
