path: root/fs
2011-05-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix FS_IOC_SETFLAGS ioctl Btrfs: fix FS_IOC_GETFLAGS ioctl fs: remove FS_COW_FL Btrfs: fix easily get into ENOSPC in mixed case Prevent oopsing in posix_acl_valid()
2011-05-14Btrfs: fix FS_IOC_SETFLAGS ioctlLi Zefan
Steps to reproduce the bug: - Call FS_IOC_SETLFAGS ioctl with flags=FS_COMPR_FL - Call FS_IOC_SETFLAGS ioctl with flags=0 - Call FS_IOC_GETFLAGS ioctl, and you'll see FS_COMPR_FL is still set! Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Btrfs: fix FS_IOC_GETFLAGS ioctlLi Zefan
As we've added per file compression/cow support. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14fs: remove FS_COW_FLLi Zefan
FS_COW_FL and FS_NOCOW_FL were newly introduced to control per file COW in btrfs, but FS_NOCOW_FL is sufficient. The fact is we don't have corresponding BTRFS_INODE_COW flag. COW is default, and FS_NOCOW_FL can be used to switch off COW for a single file. If we mount btrfs with nodatacow, a newly created file will be set with the FS_NOCOW_FL flag. So to turn on COW for it, we can just clear the FS_NOCOW_FL flag. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Btrfs: fix easily get into ENOSPC in mixed caseliubo
When a btrfs disk is created by mixed data & metadata option, it will have no pure data or pure metadata space info. In btrfs's for-linus branch, commit 78b1ea13838039cd88afdd62519b40b344d6c920 (Btrfs: fix OOPS of empty filesystem after balance) initializes space infos at the very beginning. The problem is this initialization does not take the mixed case into account, which will cause btrfs will easily get into ENOSPC in mixed case. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Prevent oopsing in posix_acl_valid()Daniel J Blueman
If posix_acl_from_xattr() returns an error code, a negative address is dereferenced causing an oops; fix by checking for error code first. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-13Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFSv4.1: Ensure that layoutget uses the correct gfp modes NFSv4.1: remove pnfs_layout_hdr from pnfs_destroy_all_layouts tmp_list NFSv41: Resend on NFS4ERR_RETRY_UNCACHED_REP
2011-05-13vfs: micro-optimize acl_permission_check()Linus Torvalds
It's a hot function, and we're better off not mixing types in the mask calculations. The compiler just ends up mixing 16-bit and 32-bit operations, for no good reason. So do everything in 'unsigned int' rather than mixing 'unsigned int' masking with a 'umode_t' (16-bit) mode variable. This, together with the parent commit (47a150edc2ae: "Cache user_ns in struct cred") makes acl_permission_check() much nicer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix oops in revalidate when called with NULL nameidata
2011-05-11NFSv4.1: Ensure that layoutget uses the correct gfp modesTrond Myklebust
Currently, writebacks may end up recursing back into the filesystem due to GFP_KERNEL direct reclaims in the pnfs subsystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: do not use i_wrbuffer_ref as refcount for Fb cap ceph: fix list_add in ceph_put_snap_realm ceph: print debug message before put mds session
2011-05-11NFSv4.1: remove pnfs_layout_hdr from pnfs_destroy_all_layouts tmp_listAndy Adamson
Prevents an infinite loop as list was never emptied. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-11NFSv41: Resend on NFS4ERR_RETRY_UNCACHED_REPAndy Adamson
Free the slot and resend the RPC with new session <slot#,seq#>. For nfs4_async_handle_error, return -EAGAIN and set the task->tk_status to 0 to restart the async rpc in the rpc_restart_call_prepare state which resets the slot. For nfs4_handle_exception, retrying a call that uses nfs4_call_sync will reset the slot via nfs41_call_sync_prepare. For open/close/lock/locku/delegreturn/layoutcommit/unlink/rename/write cachethis is true, so these operations will not trigger an NFS4ERR_RETRY_UNCACHED_REP. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-11ceph: do not use i_wrbuffer_ref as refcount for Fb capHenry C Chang
We increments i_wrbuffer_ref when taking the Fb cap. This breaks the dirty page accounting and causes looping in __ceph_do_pending_vmtruncate, and ceph client hangs. This bug can be reproduced occasionally by running blogbench. Add a new field i_wb_ref to inode and dedicate it to Fb reference counting. Signed-off-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-11ceph: fix list_add in ceph_put_snap_realmHenry C Chang
2011-05-11ceph: print debug message before put mds sessionHenry C Chang
The mds session, s, could be freed during ceph_put_mds_session. Move dout before ceph_put_mds_session. Signed-off-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-10Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix race condition in AIL push trigger xfs: make AIL target updates and compares 32bit safe. xfs: always push the AIL to the target xfs: exit AIL push work correctly when AIL is empty xfs: ensure reclaim cursor is reset correctly at end of AG
2011-05-10fuse: fix oops in revalidate when called with NULL nameidataMiklos Szeredi
Some cases (e.g. ecryptfs) can call ->dentry_revalidate with NULL nameidata. https://bugzilla.kernel.org/show_bug.cgi?id=34732 Tyler Hicks pointed out that this bug was introduced by commit e7c0a16786 "fuse: make fuse_dentry_revalidate() RCU aware" Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-05-10nilfs2: fix infinite loop in nilfs_palloc_freev functionRyusuke Konishi
After having applied commit 9954e7af14868b8b ("nilfs2: add free entries count only if clear bit operation succeeded"), a free routine of nilfs came to fall into an infinite loop, outputting the same message endlessly: nilfs_palloc_freev: entry number 29497 already freed nilfs_palloc_freev: entry number 29497 already freed nilfs_palloc_freev: entry number 29497 already freed nilfs_palloc_freev: entry number 29497 already freed nilfs_palloc_freev: entry number 29497 already freed ... That patch broke the routine so that a loop counter is never updated in an abnormal state. This fixes the regression. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-09xfs: fix race condition in AIL push triggerDave Chinner
The recent conversion of the xfsaild functionality to a work queue introduced a hard-to-hit log space grant hang. One is caused by a race condition in determining whether there is a psh in progress or not. The XFS_AIL_PUSHING_BIT is used to determine whether a push is currently in progress. When the AIL push work completes, it checked whether the target changed and cleared the PUSHING bit to allow a new push to be requeued. The race condition is as follows: Thread 1 push work smp_wmb() smp_rmb() check ailp->xa_target unchanged update ailp->xa_target test/set PUSHING bit does not queue clear PUSHING bit does not requeue Now that the push target is updated, new attempts to push the AIL will not trigger as the push target will be the same, and hence despite trying to push the AIL we won't ever wake it again. The fix is to ensure that the AIL push work clears the PUSHING bit before it checks if the target is unchanged. As a result, both push triggers operate on the same test/set bit criteria, so even if we race in the push work and miss the target update, the thread requesting the push will still set the PUSHING bit and queue the push work to occur. For safety sake, the same queue check is done if the push work detects the target change, though only one of the two will will queue new work due to the use of test_and_set_bit() checks. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> (cherry picked from commit e4d3c4a43b595d5124ae824d300626e6489ae857)
2011-05-09xfs: make AIL target updates and compares 32bit safe.Dave Chinner
The recent conversion of the xfsaild functionality to a work queue introduced a hard-to-hit log space grant hang. One of the problems noticed was that updates of the push target are not 32 bit safe as the target is a 64 bit value. We cannot copy a 64 bit LSN without the possibility of corrupting the result when racing with another updating thread. We have function to do this update safely without needing to care about 32/64 bit issues - xfs_trans_ail_copy_lsn() - so use that when updating the AIL push target. Also move the reading of the target in the push work inside the AIL lock, and use XFS_LSN_CMP() for the unlocked comparison during work termination to close read holes as well. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> (cherry picked from commit fd5670f22fce247754243cf2ed41941e5762d990)
2011-05-09xfs: always push the AIL to the targetDave Chinner
The recent conversion of the xfsaild functionality to a work queue introduced a hard-to-hit log space grant hang. One of the problems discovered is a target mismatch between the item pushing loop and the target itself. The push trigger checks for the target increasing (i.e. new target > current) while the push loop only pushes items that have a LSN < current. As a result, we can get the situation where the push target is X, the items at the tail of the AIL have LSN X and they don't get pushed. The push work then completes thinking it is done, and cannot be restarted until the push target increases to >= X + 1. If the push target then never increases (because the tail is not moving), then we never run the push work again and we stall. Fix it by making sure log items with a LSN that matches the target exactly are pushed during the loop. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> (cherry picked from commit cb64026b6e8af50db598ec7c3f59d504259b00bb)
2011-05-09xfs: exit AIL push work correctly when AIL is emptyDave Chinner
The recent conversion of the xfsaild functionality to a work queue introduced a hard-to-hit log space grant hang. The main cause is a regression where a work exit path fails to clear the PUSHING state and recheck the target correctly. Make both exit paths do the same PUSHING bit clearing and target checking when the "no more work to be done" condition is hit. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> (cherry picked from commit ea35a20021f8497390d05b93271b4d675516c654)
2011-05-09xfs: ensure reclaim cursor is reset correctly at end of AGDave Chinner
On a 32 bit highmem PowerPC machine, the XFS inode cache was growing without bound and exhausting low memory causing the OOM killer to be triggered. After some effort, the problem was reproduced on a 32 bit x86 highmem machine. The problem is that the per-ag inode reclaim index cursor was not getting reset to the start of the AG if the radix tree tag lookup found no more reclaimable inodes. Hence every further reclaim attempt started at the same index beyond where any reclaimable inodes lay, and no further background reclaim ever occurred from the AG. Without background inode reclaim the VM driven cache shrinker simply cannot keep up with cache growth, and OOM is the result. While the change that exposed the problem was the conversion of the inode reclaim to use work queues for background reclaim, it was not the cause of the bug. The bug was introduced when the cursor code was added, just waiting for some weird configuration to strike.... Signed-off-by: Dave Chinner <dchinner@redhat.com> Tested-By: Christian Kujau <lists@nerdbynature.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> (cherry picked from commit b223221956675ce8a7b436d198ced974bb388571)
2011-05-09Don't lock guardpage if the stack is growing upMikulas Patocka
Linux kernel excludes guard page when performing mlock on a VMA with down-growing stack. However, some architectures have up-growing stack and locking the guard page should be excluded in this case too. This patch fixes lvm2 on PA-RISC (and possibly other architectures with up-growing stack). lvm2 calculates number of used pages when locking and when unlocking and reports an internal error if the numbers mismatch. [ Patch changed fairly extensively to also fix /proc/<pid>/maps for the grows-up case, and to move things around a bit to clean it all up and share the infrstructure with the /proc bits. Tested on ia64 that has both grow-up and grow-down segments - Linus ] Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Tested-by: Tony Luck <tony.luck@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09Merge branch 'hpfs'Linus Torvalds
* hpfs: HPFS: Remove unused variable HPFS: Move declaration up, so that there are no out-of-scope pointers HPFS: Fix some unaligned accesses HPFS: Fix endianity. Make hpfs work on big-endian machines HPFS: Implement fsync for hpfs HPFS: Fix a bug that filesystem was not marked dirty when remounting it HPFS: Restrict uid and gid to 16-bit values HPFS: When marking or clearing the dirty bit, sync the filesystem HPFS: Use types with defined width HPFS: Remove mark_inode_dirty HPFS: Remove CR/LF conversion option HPFS: Remove remaining locks HPFS: Introduce a global mutex and lock it on every callback from VFS. HPFS: Make HPFS compile on preempt and SMP
2011-05-09HPFS: Remove unused variableMikulas Patocka
Remove unused variable Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Move declaration up, so that there are no out-of-scope pointersMikulas Patocka
Move declaration up, so that there are no out-of-scope pointers Reported-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Fix some unaligned accessesMikulas Patocka
Fix some unaligned accesses Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Fix endianity. Make hpfs work on big-endian machinesMikulas Patocka
Fix endianity. Make hpfs work on big-endian machines. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Implement fsync for hpfsMikulas Patocka
Implement fsync for hpfs. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Fix a bug that filesystem was not marked dirty when remounting itMikulas Patocka
Fix a bug that filesystem was not marked dirty when remounting it Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Restrict uid and gid to 16-bit valuesMikulas Patocka
Restrict uid and gid to 16-bit values. HPFS stores only 2 bytes in the EAs. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: When marking or clearing the dirty bit, sync the filesystemMikulas Patocka
When marking or clearing the dirty bit, sync the filesystem Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Use types with defined widthMikulas Patocka
Use types with defined width Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Remove mark_inode_dirtyMikulas Patocka
Remove mark_inode_dirty HPFS doesn't use kernel's dirty inode indicator anyway because writing an inode requires directory's mutex. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Remove CR/LF conversion optionMikulas Patocka
Remove CR/LF conversion option It is unused anyway. It was used on 2.2 kernels or so. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Remove remaining locksMikulas Patocka
Remove remaining locks Because of a new global per-fs lock, no other locks are needed Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Introduce a global mutex and lock it on every callback from VFS.Mikulas Patocka
Introduce a global mutex and lock it on every callback from VFS. Performance doesn't matter, reviewing the whole code for locking correctness would be too complicated, so simply lock it all. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Make HPFS compile on preempt and SMPMikulas Patocka
Make HPFS compile on preempt and SMP Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: handle errors from coalesce_t2 cifs: refactor mid finding loop in cifs_demultiplex_thread cifs: sanitize length checking in coalesce_t2 (try #3) cifs: check for bytes_remaining going to zero in CIFS_SessSetup cifs: change bleft in decode_unicode_ssetup back to signed type
2011-05-06Validate size of EFI GUID partition entries.Timo Warns
Otherwise corrupted EFI partition tables can cause total confusion. Signed-off-by: Timo Warns <warns@pre-sense.de> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: do not call __mark_dirty_inode under i_lock libceph: fix ceph_osdc_alloc_request error checks ceph: handle ceph_osdc_new_request failure in ceph_writepages_start libceph: fix ceph_msg_new error path ceph: use ihold() when i_lock is held
2011-05-04ceph: do not call __mark_dirty_inode under i_lockSage Weil
The __mark_dirty_inode helper now takes i_lock as of 250df6ed. Fix the one ceph callers that held i_lock (__ceph_mark_dirty_caps) to return the flags value so that the callers can do it outside of i_lock. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-03logfs: initialize superblock entries earlierLinus Torvalds
In particular, s_freeing_list needs to be initialized early, since it is used on some of the error paths when mounts fail. The mapping inode, for example, would be initialized and then free'd on an error path before s_freeing_list was initialized, but the inode drop operation needs the s_freeing_list to be set up. Normally you'd never see this, because not only is logfs fairly rare, but a successful mount will never have any issues. Reported-by: werner <w.landgraf@ru.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-03ceph: handle ceph_osdc_new_request failure in ceph_writepages_startHenry C Chang
We should unlock the page and return -ENOMEM if ceph_osdc_new_request failed. Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-03ceph: use ihold() when i_lock is heldSage Weil
See 0444d76ae64fffc7851797fc1b6ebdbb44ac504a. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-03cifs: handle errors from coalesce_t2Jeff Layton
cifs_demultiplex_thread calls coalesce_t2 to try and merge follow-on t2 responses into the original mid buffer. coalesce_t2 however can return errors, but the caller doesn't handle that situation properly. Fix the thread to treat such a case as it would a malformed packet. Mark the mid as being malformed and issue the callback. Cc: stable@kernel.org Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-03cifs: refactor mid finding loop in cifs_demultiplex_threadJeff Layton
...to reduce the extreme indentation. This should introduce no behavioral changes. Cc: stable@kernel.org Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-02Merge branch 'for-linus' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubifs-2.6: UBIFS: seek journal heads to the latest bud in replay UBIFS: do not free write-buffers when in R/O mode
