drivers/mtd/ubi/ubi.h
drivers/mtd/ubi/wl.c
While in list_for_each_entry() of yaffs_flush_inodes, the fs code
can delete inodes. This leads to an endless loop which causes a
softlockup. Typically this happend in sync_supers when creating
and deleting files while under CPU load.
This fix checks whether we get twice the same inode. If this is
true, we just retry again.
This is an alternative fix to the proposed fix Jisheng Zhang:
yaffs: fix softlockup cauesed by inode deleted when scanning s_inodes list
http://www.aleph1.co.uk/lurker/message/20110831.075307.3cfeacdf.fr.html
The fsync function in the fs.h header file in our kernel version has
two additional function introduced by this commit:
02c24a82187d5a628c68edfe71ae60dc135cd178
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
Update the function prototype for YAFFS2 too to avoid missinterpreted
datasync parameter and to avoid warnings.
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no
mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are
in the middle of 'ubifs_readdir()'.
This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses
it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage,
but this may corrupt memory and lead to all kinds of problems like crashes an
security holes.
This patch fixes the problem by using the 'file->f_version' field, which
'->llseek()' always unconditionally sets to zero. We set it to 1 in
'ubifs_readdir()' and whenever we detect that it became 0, we know there was a
seek and it is time to clear the state saved in 'file->private_data'.
I tested this patch by writing a user-space program which runds readdir and
seek in parallell. I could easily crash the kernel without these patches, but
could not crash it with these patches.
Cc: stable@vger.kernel.org
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
First of all, this means that 'file->private_data' can be freed while
'ubifs_readdir()' uses it. But this particular patch does not fix the problem.
This patch is only a preparation, and the fix will follow next.
In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly,
because 'file->f_pos' can be changed by '->llseek()' at any point. This may
lead 'ubifs_readdir()' to returning inconsistent data: directory entry names
may correspond to incorrect file positions.
So here we introduce a local variable 'pos', read 'file->f_pose' once at very
the beginning, and then stick to 'pos'. The result of this is that when
'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of
'ubifs_readdir()', the latter "wins".
When mounting an UBIFS R/W volume, we have the message:
UBIFS: mounted UBI device 0, volume 1, name "rootfs"(null)
With this patch, we'll have:
Which is, I think, what was intended.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Cc: stable@vger.kernel.org [v3.7+]
The UBIFS space fixup is a useful feature which allows to fixup the "broken"
flash space at the time of the first mount. The "broken" space is usually the
result of using a "dumb" industrial flasher which is not able to skip empty
NAND pages and just writes all 0xFFs to the empty space, which has grave
side-effects for UBIFS when UBIFS trise to write useful data to those empty
pages.
The fix-up feature works roughly like this:
1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image
(see -F option)
2. when the file-system is mounted for the first time, UBIFS notices the fixup
flag and re-writes the entire media atomically, which may take really a lot
of time.
3. UBIFS clears the fixup flag in the superblock.
This works fine when the file system is mounted R/W for the very first time.
But it did not really work in the case when we first mount the file-system R/O,
and then re-mount R/W. The reason was that we started the fixup procedure too
late, which we cannot really do because we have to fixup the space before it
starts being used.
Reported-by: Mark Jackson <mpfj-list@mimc.co.uk>
Cc: stable@vger.kernel.org # 3.0+
The last orphan in the dnext list has its dnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the dnext list
and frees it immediately instead ignoring it as a second delete. The
orphan is later freed again by erase_deleted.
This change adds an explicit flag to ubifs_orphan indicating whether
it is pending delete.
Signed-off-by: Adam Thomas <adamthomas1111@gmail.com>
The last orphan in the cnext list has its cnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the cnext list
and frees it immediately instead of adding it to the dnext list. The
freed orphan is later modified by write_orph_node.
This can cause various inconsistencies including directory entries
that cannot be removed and this error:
UBIFS error (pid 20685): layout_cnodes: LPT out of space at LEB 14:129009 needing 17, done_ltab 1, done_lsave 1
This is a regression introduced by
"7074e5eb UBIFS: remove invalid reference to list iterator variable".
it is pending commit.
Reviewed-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: stable@vger.kernel.org # v3.6+
Use more preferable function name which implies using a pseudo-random
number generator.
This also converts filling memory loop to use memset.
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: David Laight <david.laight@aculab.com>
Cc: Eilon Greenstein <eilong@broadcom.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Robert Love <robert.w.love@intel.com>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
This is a bugfix for a problem with the following symptoms:
1. A power cut happens
2. After reboot, we try to mount UBIFS
3. Mount fails with "No space left on device" error message
UBIFS complains like this:
UBIFS error (pid 28225): grab_empty_leb: could not find an empty LEB
The root cause of this problem is that when we mount, not all LEBs are
categorized. Only those which were read are. However, the
'ubifs_find_free_leb_for_idx()' function assumes that all LEBs were
categorized and 'c->freeable_cnt' is valid, which is a false assumption.
This patch fixes the problem by teaching 'ubifs_find_free_leb_for_idx()'
to always fall back to LPT scanning if no freeable LEBs were found.
This problem was reported by few people in the past, but Brent Taylor
was able to reproduce it and send me a flash image which cannot be mounted,
which made it easy to hunt the bug. Kudos to Brent.
Reported-by: Brent Taylor <motobud@gmail.com>
This commit is a preparation for a subsequent bugfix. We introduce a
counter for categorized lprops.
UBIFS currently prints a lot of information when it mounts a volume, which
bothers some people. Make it less chatty - print only important information
by default.
Get rid of 'dbg_msg()' macro completely.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Use 'pr_err()' instead of 'printk(KERN_ERR', etc.
Join all the split printk lines in order to stop checkpatch complaining.
.. instead of __attribute__((aligned())).
This tag is useless and it breaks automatic builds. It causes rebuilds
for packages that depend on kernel for no real reason.
Further, quoting Michal, who removed most of the users already:
The kernel already prints its build timestamp during boot, no need to
repeat it in random drivers and produce different object files each
time.
The power cut emulation did not work correctly because we corrupted more than
one max. I/O unit in the buffer and then wrote the entire buffer. This lead to
recovery errors because UBIFS complained about corrupted free space. And this
was easily reproducible on mtdram because max. write size is very small there
(64 bytes), and we could easily have a 1KiB buffer, corrupt 128 bytes there,
and then write the entire buffer.
The fix is to corrupt max. write size bytes at most, and write only up to the
last corrupted max. write size chunk, not the entire buffer.
Include LEB number and offset in scanning debugging output.
Even when we are emulating power cuts, otherwise it is difficult to investigate
failures during emulated power cuts testing.
Corruptio -> corruption.
When debugging is enabled, we use a temporary on-stack buffer for formatting
the key strings like "(11368871, direntry, 0xcd0750)". The buffer size is
32 bytes and sometimes it is not enough to fit the key string - e.g., when
inode numbers are high. This is not fatal, but the key strings are incomplete
and UBIFS complains like this:
UBIFS assert failed in dbg_snprintf_key at 137 (pid 1)
This is a regression caused by "515315a UBIFS: fix key printing".
Fix the issue by increasing the buffer to 48 bytes.
Reported-by: Michael Hench <michaelhench@gmail.com>
Tested-by: Michael Hench <michaelhench@gmail.com>
Cc: stable@vger.kernel.org [v3.3+]
Commit "d51f17e UBIFS: simplify reply code a bit" introduces a bug with the
following symptoms:
UBIFS error (pid 1): replay_log_leb: first CS node at LEB 3:0 has wrong commit number 0 expected 1
The issue is that we start replaying the log from UBIFS_LOG_LNUM instead
of c->lhead_lnum. This patch fixes that.
This patch fixes a regression introduced by
"4994297 UBIFS: make ubifs_lpt_init clean-up in case of failure" which
I've hit while running the 'integck -p' test. When remount the file-system
from R/O mode to R/W mode and 'lpt_init_wr()' fails, we free _all_ LPT
resources by calling 'ubifs_lpt_free(c, 0)', even those needed for R/O
mode. This leads to subsequent crashes, e.g., if we try to unmount
the file-system.
Cc: stable@vger.kernel.org [v3.5+]
If list_for_each_entry, etc complete a traversal of the list, the iterator
variable ends up pointing to an address at an offset from the list head,
and not a meaningful structure. Thus this value should not be used after
the end of the iterator. Replace a field access from orphan by NULL in two
places.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier c;
expression E;
iterator name list_for_each_entry;
statement S;
list_for_each_entry(c,...) { ... when != break;
when forall
when strict
c = E
*c
// </smpl>
Artem: fortunately, this did not cause any issues because we iterate the orphan
list using the elements count, so we never dereferenced the corrupted pointer.
This is why I do not send this patch to -stable. But otherwise - well spotted!
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
In the log reply code we assume that 'c->lhead_offs' is known and may be
non-zero, which is not the case because we do not store it in the master
node and have to find out by scanning on every mount. Knowing this fact
allows us to simplify the log scanning loop a bit and remove a couple
of unneeded local variables.
This patch adds another debugfs knob which switches UBIFS to R/O mode.
I needed it while trying to reproduce the 'first log node is not CS node'
bug. Without this debugfs knob you have to perform a power cut to repruduce
the bug. The knob is named 'ro_error' and all it does is it sets the
'ro_error' UBIFS flag which makes UBIFS disallow any further writes - even
write-back will fail with -EROFS. Useful for debugging.
UBIFS has a feature called "empty space fix-up" which is a quirk to work-around
limitations of dumb flasher programs. Namely, of those flashers that are unable
to skip NAND pages full of 0xFFs while flashing, resulting in empty space at
the end of half-filled eraseblocks to be unusable for UBIFS. This feature is
relatively new (introduced in v3.0).
The fix-up routine (fixup_free_space()) is executed only once at the very first
mount if the superblock has the 'space_fixup' flag set (can be done with -F
option of mkfs.ubifs). It basically reads all the UBIFS data and metadata and
writes it back to the same LEB. The routine assumes the image is pristine and
does not have anything in the journal.
There was a bug in 'fixup_free_space()' where it fixed up the log incorrectly.
All but one LEB of the log of a pristine file-system are empty. And one
contains just a commit start node. And 'fixup_free_space()' just unmapped this
LEB, which resulted in wiping the commit start node. As a result, some users
were unable to mount the file-system next time with the following symptom:
UBIFS error (pid 1): replay_log_leb: first log node at LEB 3:0 is not CS node
UBIFS error (pid 1): replay_log_leb: log error detected while replaying the log at LEB 3:0
The root-cause of this bug was that 'fixup_free_space()' wrongly assumed
that the beginning of empty space in the log head (c->lhead_offs) was known
on mount. However, it is not the case - it was always 0. UBIFS does not store
in it the master node and finds out by scanning the log on every mount.
The fix is simple - just pass commit start node size instead of 0 to
'fixup_leb()'.
Cc: stable@vger.kernel.org [v3.0+]
Reported-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Tested-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Reported-by: James Nute <newten82@gmail.com>
Add time-average nr_running to loadavg printout
Bug 958978
Change-Id: I5c6904efb52a86f4964eb66c1576fc91f60f5b1d
Signed-off-by: Alex Frid <afrid@nvidia.com>
(cherry picked from commit 86f3642cc44a69d1e4798719bd9182cd6923f526)
Reviewed-on: http://git-master/r/111636
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Commit "818039c UBIFS: fix debugfs-less systems support" fixed one
regression but introduced a different regression - the debugfs is now always
compiled out. Root cause: IS_ENABLED() arguments should be used with the
CONFIG_* prefix.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
The asserts here never check anything because it uses '|' instead of
'&'. Now if the flags are not set it prints a warning a a stack trace.
Remove FAT Directory Bread message which is
causing timing issues.
Bug 992496
Change-Id: Ieb58e38bf8ac81f6c0558361f9f296a8e9071b33
Signed-off-by: venkata jagadish <vjagadish@nvidia.com>
Reviewed-on: http://git-master/r/105354
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Commit "f70b7e5 UBIFS: remove Kconfig debugging option" broke UBIFS and it
refuses to initialize if debugfs (CONFIG_DEBUG_FS) is disabled. I incorrectly
assumed that debugfs files creation function will return success if debugfs
is disabled, but they actually return -ENODEV. This patch fixes the issue.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Richard removed the "dtype" hint, but few commentaries were left and this patch
removes them. I've also added a better description about the "dtype" field in
the ubi-user.h for people who may ever wonder what was that dtype thing about.
This patch also adds an important note that it is better to use value "3" for
the "dtype" field.
We do not need this feature and to our shame it even was not working
and there was a bug found very recently.
-- Artem Bityutskiy
Without the data type hint UBI2 (fastmap) will be easier to implement.
Signed-off-by: Richard Weinberger <richard@nod.at>
UBIFS leaks memory on error path in 'mount_ubifs()'. In case of failure in
'ubifs_fixup_free_space()', it does not call 'ubifs_lpt_free()' whereas LPT
data structures can potentially be allocated. The amount of memory leaked can
be quite high -- see 'ubifs_lpt_init()'.
The bug was introduced when moving the LPT initialisation earlier in the
mount process (commit '781c5717a95a74b294beb38b8276943b0f8b5bb4').
Signed-off-by: Sidney Amani <seed95@gmail.com>
Most functions in UBIFS follow the following designn pattern: if the function
allocates multiple resources, and failss at some point, it frees what it has
allocated and returns an error. So the caller can rely on the fact that the
callee has cleaned up everything after own failure.
Acked-by: Sidney Amani <seed95@gmail.com>
This patch removes the 'dbg_err()' macro and we now use 'ubifs_err()' instead.
The idea of 'dbg_err()' was to compile out some error message to make the
binary a bit smaller - but I think it was a bad idea.
Have the debugging stuff always compiled-in instead. It simplifies maintanance
a lot.
This commit re-names all functions which dump something from "dbg_dump_*()" to
"ubifs_dump_*()". This is done for consistency with UBI and because this way it
will be more logical once we remove the debugging sompilation option.
In case of errors we almost always need the stack dump - it makes no sense
to compile it out. Remove the 'dbg_dump_stack()' function completely.
Remove CONFIG_UBIFS_FS_XATTR configuration option and associated
UBIFS_FS_XATTR ifdefs.
Testing:
Tested using integck while using nandsim on x86 & MX28 based
platform with Micron MT29F2G08ABAEAH4 nand.
Signed-off-by: Subodh Nijsure <snijsure@grid-net.com>
"heap" is initialized twice. I removed the first one, because it makes
Smatch complain that we use "new_cat" as an offset before checking it.
This doesn't change how the code works, it's just a cleanup.
Ricard complaints that the following error message is odd:
"UBIFS error (pid 1578): validate_sb: bad superblock, error 8"
and he is right. This patch improves the error messages a bit and makes
them more user-friendly.
Reported-by: Ricard Wanderlof <ricard.wanderlof@axis.com>
It is useless and confusing and may make people believe they may just
change it, which is not true, because this will also change the on-flash
format.
commit b1c770c273a4787069306fc82aab245e9ac72e9d upstream
When finding the longest extent in an AG, we read the value directly
out of the AGF buffer without endian conversion. This will give an
incorrect length, resulting in FITRIM operations potentially not
trimming everything that it should.
Note, for 3.0-stable this has been modified to apply to
fs/xfs/linux-2.6/xfs_discard.c instead of fs/xfs/xfs_discard.c. -bpm
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
Change-Id: Iad84b2bb82ee0d410cdb64eeea3a8431c5a0a7ad
Reviewed-on: http://git-master/r/79660
