path: root/fs
2012-03-12cifs: fix dentry refcount leak when opening a FIFO on lookupJeff Layton
commit 5bccda0ebc7c0331b81ac47d39e4b920b198b2cd upstream. The cifs code will attempt to open files on lookup under certain circumstances. What happens though if we find that the file we opened was actually a FIFO or other special file? Currently, the open filehandle just ends up being leaked leading to a dentry refcount mismatch and oops on umount. Fix this by having the code close the filehandle on the server if it turns out not to be a regular file. While we're at it, change this spaghetti if statement into a switch too. Reported-by: CAI Qian <caiqian@redhat.com> Tested-by: CAI Qian <caiqian@redhat.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12aio: wake up waiters when freeing unused kiocbsJeff Moyer
commit 880641bb9da2473e9ecf6c708d993b29928c1b3c upstream. Bart Van Assche reported a hung fio process when either hot-removing storage or when interrupting the fio process itself. The (pruned) call trace for the latter looks like so: fio D 0000000000000001 0 6849 6848 0x00000004 ffff880092541b88 0000000000000046 ffff880000000000 ffff88012fa11dc0 ffff88012404be70 ffff880092541fd8 ffff880092541fd8 ffff880092541fd8 ffff880128b894d0 ffff88012404be70 ffff880092541b88 000000018106f24d Call Trace: schedule+0x3f/0x60 io_schedule+0x8f/0xd0 wait_for_all_aios+0xc0/0x100 exit_aio+0x55/0xc0 mmput+0x2d/0x110 exit_mm+0x10d/0x130 do_exit+0x671/0x860 do_group_exit+0x44/0xb0 get_signal_to_deliver+0x218/0x5a0 do_signal+0x65/0x700 do_notify_resume+0x65/0x80 int_signal+0x12/0x17 The problem lies with the allocation batching code. It will opportunistically allocate kiocbs, and then trim back the list of iocbs when there is not enough room in the completion ring to hold all of the events. In the case above, what happens is that the pruning back of events ends up freeing up the last active request and the context is marked as dead, so it is thus responsible for waking up waiters. Unfortunately, the code does not check for this condition, so we end up with a hung task. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12regset: Prevent null pointer reference on readonly regsetsH. Peter Anvin
commit c8e252586f8d5de906385d8cf6385fee289a825e upstream. The regset common infrastructure assumed that regsets would always have .get and .set methods, but not necessarily .active methods. Unfortunately people have since written regsets without .set methods. Rather than putting in stub functions everywhere, handle regsets with null .get or .set methods explicitly. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12autofs: work around unhappy compat problem on x86-64Ian Kent
commit a32744d4abae24572eff7269bc17895c41bd0085 upstream. When the autofs protocol version 5 packet type was added in commit 5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it obvously tried quite hard to be word-size agnostic, and uses explicitly sized fields that are all correctly aligned. However, with the final "char name[NAME_MAX+1]" array at the end, the actual size of the structure ends up being not very well defined: because the struct isn't marked 'packed', doing a "sizeof()" on it will align the size of the struct up to the biggest alignment of the members it has. And despite all the members being the same, the alignment of them is different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round number (256), the name[] array starts out a 4-byte aligned. End result: the "packed" size of the structure is 300 bytes: 4-byte, but not 8-byte aligned. As a result, despite all the fields being in the same place on all architectures, sizeof() will round up that size to 304 bytes on architectures that have 8-byte alignment for u64. Note that this is *not* a problem for 32-bit compat mode on POWER, since there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit and 64-bit alignment is different for 64-bit entities, and as a result the structure that has exactly the same layout has different sizes. So on x86-64, but no other architecture, we will just subtract 4 from the size of the structure when running in a compat task. That way we will write the properly sized packet that user mode expects. Not pretty. Sadly, this very subtle, and unnecessary, size difference has been encoded in user space that wants to read packets of *exactly* the right size, and will refuse to touch anything else. Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: limit pathsJason Baron
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream. The current epoll code can be tickled to run basically indefinitely in both loop detection path check (on ep_insert()), and in the wakeup paths. The programs that tickle this behavior set up deeply linked networks of epoll file descriptors that cause the epoll algorithms to traverse them indefinitely. A couple of these sample programs have been previously posted in this thread: https://lkml.org/lkml/2011/2/25/297. To fix the loop detection path check algorithms, I simply keep track of the epoll nodes that have been already visited. Thus, the loop detection becomes proportional to the number of epoll file descriptor and links. This dramatically decreases the run-time of the loop check algorithm. In one diabolical case I tried it reduced the run-time from 15 mintues (all in kernel time) to .3 seconds. Fixing the wakeup paths could be done at wakeup time in a similar manner by keeping track of nodes that have already been visited, but the complexity is harder, since there can be multiple wakeups on different cpus...Thus, I've opted to limit the number of possible wakeup paths when the paths are created. This is accomplished, by noting that the end file descriptor points that are found during the loop detection pass (from the newly added link), are actually the sources for wakeup events. I keep a list of these file descriptors and limit the number and length of these paths that emanate from these 'source file descriptors'. In the current implemetation I allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of length 4 and 10 of length 5. Note that it is sufficient to check the 'source file descriptors' reachable from the newly added link, since no other 'source file descriptors' will have newly added links. This allows us to check only the wakeup paths that may have gotten too long, and not re-check all possible wakeup paths on the system. In terms of the path limit selection, I think its first worth noting that the most common case for epoll, is probably the model where you have 1 epoll file descriptor that is monitoring n number of 'source file descriptors'. In this case, each 'source file descriptor' has a 1 path of length 1. Thus, I believe that the limits I'm proposing are quite reasonable and in fact may be too generous. Thus, I'm hoping that the proposed limits will not prevent any workloads that currently work to fail. In terms of locking, I have extended the use of the 'epmutex' to all epoll_ctl add and remove operations. Currently its only used in a subset of the add paths. I need to hold the epmutex, so that we can correctly traverse a coherent graph, to check the number of paths. I believe that this additional locking is probably ok, since its in the setup/teardown paths, and doesn't affect the running paths, but it certainly is going to add some extra overhead. Also, worth noting is that the epmuex was recently added to the ep_ctl add operations in the initial path loop detection code using the argument that it was not on a critical path. Another thing to note here, is the length of epoll chains that is allowed. Currently, eventpoll.c defines: /* Maximum number of nesting allowed inside epoll sets */ #define EP_MAX_NESTS 4 This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS + 1). However, this limit is currently only enforced during the loop check detection code, and only when the epoll file descriptors are added in a certain order. Thus, this limit is currently easily bypassed. The newly added check for wakeup paths, stricly limits the wakeup paths to a length of 5, regardless of the order in which ep's are linked together. Thus, a side-effect of the new code is a more consistent enforcement of the graph depth. Thus far, I've tested this, using the sample programs previously mentioned, which now either return quickly or return -EINVAL. I've also testing using the piptest.c epoll tester, which showed no difference in performance. I've also created a number of different epoll networks and tested that they behave as expectded. I believe this solves the original diabolical test cases, while still preserving the sane epoll nesting. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Nelson Elhage <nelhage@ksplice.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: ep_unregister_pollwait() can use the freed pwq->wheadOleg Nesterov
commit 971316f0503a5c50633d07b83b6db2f15a3a5b00 upstream. signalfd_cleanup() ensures that ->signalfd_wqh is not used, but this is not enough. eppoll_entry->whead still points to the memory we are going to free, ep_unregister_pollwait()->remove_wait_queue() is obviously unsafe. Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL, change ep_unregister_pollwait() to check pwq->whead != NULL under rcu_read_lock() before remove_wait_queue(). We add the new helper, ep_remove_wait_queue(), for this. This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because ->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand. ep_unregister_pollwait()->remove_wait_queue() can play with already freed and potentially reused ->sighand, but this is fine. This memory must have the valid ->signalfd_wqh until rcu_read_unlock(). Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: introduce POLLFREE to flush ->signalfd_wqh before kfree()Oleg Nesterov
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream. This patch is intentionally incomplete to simplify the review. It ignores ep_unregister_pollwait() which plays with the same wqh. See the next change. epoll assumes that the EPOLL_CTL_ADD'ed file controls everything f_op->poll() needs. In particular it assumes that the wait queue can't go away until eventpoll_release(). This is not true in case of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand which is not connected to the file. This patch adds the special event, POLLFREE, currently only for epoll. It expects that init_poll_funcptr()'ed hook should do the necessary cleanup. Perhaps it should be defined as EPOLLFREE in eventpoll. __cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if ->signalfd_wqh is not empty, we add the new signalfd_cleanup() helper. ep_poll_callback(POLLFREE) simply does list_del_init(task_list). This make this poll entry inconsistent, but we don't care. If you share epoll fd which contains our sigfd with another process you should blame yourself. signalfd is "really special". I simply do not know how we can define the "right" semantics if it used with epoll. The main problem is, epoll calls signalfd_poll() once to establish the connection with the wait queue, after that signalfd_poll(NULL) returns the different/inconsistent results depending on who does EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd has nothing to do with the file, it works with the current thread. In short: this patch is the hack which tries to fix the symptoms. It also assumes that nobody can take tasklist_lock under epoll locks, this seems to be true. Note: - we do not have wake_up_all_poll() but wake_up_poll() is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE. - signalfd_cleanup() uses POLLHUP along with POLLFREE, we need a couple of simple changes in eventpoll.c to make sure it can't be "lost". Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29NFSv4: fix server_scope memory leakWeston Andros Adamson
commit abe9a6d57b4544ac208401f9c0a4262814db2be4 upstream. server_scope would never be freed if nfs4_check_cl_exchange_flags() returned non-zero Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29NFSv4: Ensure we throw out bad delegation stateids on NFS4ERR_BAD_STATEIDTrond Myklebust
commit b9f9a03150969e4bd9967c20bce67c4de769058f upstream. To ensure that we don't just reuse the bad delegation when we attempt to recover the nfs4_state that received the bad stateid error. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29NFSv4: Fix an Oops in the NFSv4 getacl codeTrond Myklebust
commit 331818f1c468a24e581aedcbe52af799366a9dfe upstream. Commit bf118a342f10dafe44b14451a1392c3254629a1f (NFSv4: include bitmap in nfsv4 get acl data) introduces the 'acl_scratch' page for the case where we may need to decode multi-page data. However it fails to take into account the fact that the variable may be NULL (for the case where we're not doing multi-page decode), and it also attaches it to the encoding xdr_stream rather than the decoding one. The immediate result is an Oops in nfs4_xdr_enc_getacl due to the call to page_address() with a NULL page pointer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Andy Adamson <andros@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29vfs: fix d_inode_lookup() dentry ref leakMiklos Szeredi
commit e188dc02d3a9c911be56eca5aa114fe7e9822d53 upstream. d_inode_lookup() leaks a dentry reference on IS_DEADDIR(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29eCryptfs: Copy up lower inode attrs after setting lower xattrTyler Hicks
commit 545d680938be1e86a6c5250701ce9abaf360c495 upstream. After passing through a ->setxattr() call, eCryptfs needs to copy the inode attributes from the lower inode to the eCryptfs inode, as they may have changed in the lower filesystem's ->setxattr() path. One example is if an extended attribute containing a POSIX Access Control List is being set. The new ACL may cause the lower filesystem to modify the mode of the lower inode and the eCryptfs inode would need to be updated to reflect the new mode. https://launchpad.net/bugs/926292 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Sebastien Bacher <seb128@ubuntu.com> Cc: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20cifs: don't return error from standard_receive3 after marking response malformedJeff Layton
commit ff4fa4a25a33f92b5653bb43add0c63bea98d464 upstream. standard_receive3 will check the validity of the response from the server (via checkSMB). It'll pass the result of that check to handle_mid which will dequeue it and mark it with a status of MID_RESPONSE_MALFORMED if checkSMB returned an error. At that point, standard_receive3 will also return an error, which will make the demultiplex thread skip doing the callback for the mid. This is wrong -- if we were able to identify the request and the response is marked malformed, then we want the demultiplex thread to do the callback. Fix this by making standard_receive3 return 0 in this situation. Reported-and-Tested-by: Mark Moseley <moseleymark@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20cifs: request oplock when doing open on lookupJeff Layton
commit 8b0192a5f478da1c1ae906bf3ffff53f26204f56 upstream. Currently, it's always set to 0 (no oplock requested). Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20writeback: fix NULL bdi->dev in trace writeback_single_inodeWu Fengguang
commit 15eb77a07c714ac80201abd0a9568888bcee6276 upstream. bdi_prune_sb() resets sb->s_bdi to default_backing_dev_info when the tearing down the original bdi. Fix trace_writeback_single_inode to use sb->s_bdi=default_backing_dev_info rather than bdi->dev=NULL for a teared down bdi. Reported-by: Rabin Vincent <rabin@rab.in> Tested-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13cifs: Fix oops in session setup code for null user mountsShirish Pargaonkar
commit de47a4176c532ef5961b8a46a2d541a3517412d3 upstream. For null user mounts, do not invoke string length function during session setup. Reported-and-Tested-by: Chris Clayton <chris2553@googlemail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13eCryptfs: Infinite loop due to overflow in ecryptfs_write()Li Wang
commit 684a3ff7e69acc7c678d1a1394fe9e757993fd34 upstream. ecryptfs_write() can enter an infinite loop when truncating a file to a size larger than 4G. This only happens on architectures where size_t is represented by 32 bits. This was caused by a size_t overflow due to it incorrectly being used to store the result of a calculation which uses potentially large values of type loff_t. [tyhicks@canonical.com: rewrite subject and commit message] Signed-off-by: Li Wang <liwang@nudt.edu.cn> Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn> Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13udf: Mark LVID buffer as uptodate before marking it dirtyJan Kara
commit 853a0c25baf96b028de1654bea1e0c8857eadf3d upstream. When we hit EIO while writing LVID, the buffer uptodate bit is cleared. This then results in an anoying warning from mark_buffer_dirty() when we write the buffer again. So just set uptodate flag unconditionally. Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13proc: make sure mem_open() doesn't pin the target's memoryOleg Nesterov
commit 6d08f2c7139790c268820a2e590795cb8333181a upstream. Once /proc/pid/mem is opened, the memory can't be released until mem_release() even if its owner exits. Change mem_open() to do atomic_inc(mm_count) + mmput(), this only pins mm_struct. Change mem_rw() to do atomic_inc_not_zero(mm_count) before access_remote_vm(), this verifies that this mm is still alive. I am not sure what should mem_rw() return if atomic_inc_not_zero() fails. With this patch it returns zero to match the "mm == NULL" case, may be it should return -EINVAL like it did before e268337d. Perhaps it makes sense to add the additional fatal_signal_pending() check into the main loop, to ensure we do not hold this memory if the target task was oom-killed. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13proc: unify mem_read() and mem_write()Oleg Nesterov
commit 572d34b946bae070debd42db1143034d9687e13f upstream. No functional changes, cleanup and preparation. mem_read() and mem_write() are very similar. Move this code into the new common helper, mem_rw(), which takes the additional "int write" argument. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13proc: mem_release() should check mm != NULLOleg Nesterov
commit 71879d3cb3dd8f2dfdefb252775c1b3ea04a3dd4 upstream. mem_release() can hit mm == NULL, add the necessary check. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03sysfs: Complain bitterly about attempts to remove files from nonexistent ↵Eric W. Biederman
directories. commit ce597919361dcec97341151690e780eade2a9cf4 upstream. Recently an OOPS was observed from the usb serial io_ti driver when it tried to remove sysfs directories. Upon investigation it turns out this driver was always buggy and that a recent sysfs change had stopped guarding itself against removing attributes from sysfs directories that had already been removed. :( Historically we have been silent about attempting to files from nonexistent sysfs directories and have politely returned error codes. That has resulted in people writing broken code that ignores the error codes. Issue a kernel WARNING and a stack backtrace to make it clear in no uncertain terms that abusing sysfs is not ok, and the callers need to fix their code. This change transforms the io_ti OOPS into a more comprehensible error message and stack backtrace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Wolfgang Frisch <wfpub@roembden.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03jbd: Issue cache flush after checkpointingJan Kara
commit 353b67d8ced4dc53281c88150ad295e24bc4b4c5 upstream. When we reach cleanup_journal_tail(), there is no guarantee that checkpointed buffers are on a stable storage - especially if buffers were written out by log_do_checkpoint(), they are likely to be only in disk's caches. Thus when we update journal superblock, effectively removing old transaction from journal, this write of superblock can get to stable storage before those checkpointed buffers which can result in filesystem corruption after a crash. A similar problem can happen if we replay the journal and wipe it before flushing disk's caches. Thus we must unconditionally issue a cache flush before we update journal superblock in these cases. The fix is slightly complicated by the fact that we have to get log tail before we issue cache flush but we can store it in the journal superblock only after the cache flush. Otherwise we risk races where new tail is written before appropriate cache flush is finished. I managed to reproduce the corruption using somewhat tweaked Chris Mason's barrier-test scheduler. Also this should fix occasional reports of 'Bit already freed' filesystem errors which are totally unreproducible but inspection of several fs images I've gathered over time points to a problem like this. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03xfs: Fix missing xfs_iunlock() on error recovery path in xfs_readlink()Jan Kara
commit 9b025eb3a89e041bab6698e3858706be2385d692 upstream. Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted symplink and bailed out. Fix it by jumping to 'out' instead of doing return. CC: Carlos Maiolino <cmaiolino@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Alex Elder <elder@kernel.org> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03eCryptfs: Fix oops when printing debug info in extent crypto functionsTyler Hicks
commit 58ded24f0fcb85bddb665baba75892f6ad0f4b8a upstream. If pages passed to the eCryptfs extent-based crypto functions are not mapped and the module parameter ecryptfs_verbosity=1 was specified at loading time, a NULL pointer dereference will occur. Note that this wouldn't happen on a production system, as you wouldn't pass ecryptfs_verbosity=1 on a production system. It leaks private information to the system logs and is for debugging only. The debugging info printed in these messages is no longer very useful and rather than doing a kmap() in these debugging paths, it will be better to simply remove the debugging paths completely. https://launchpad.net/bugs/913651 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03eCryptfs: Check inode changes in setattrTyler Hicks
commit a261a03904849c3df50bd0300efb7fb3f865137d upstream. Most filesystems call inode_change_ok() very early in ->setattr(), but eCryptfs didn't call it at all. It allowed the lower filesystem to make the call in its ->setattr() function. Then, eCryptfs would copy the appropriate inode attributes from the lower inode to the eCryptfs inode. This patch changes that and actually calls inode_change_ok() on the eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call would happen earlier in ecryptfs_setattr(), but there are some possible inode initialization steps that must happen first. Since the call was already being made on the lower inode, the change in functionality should be minimal, except for the case of a file extending truncate call. In that case, inode_newsize_ok() was never being called on the eCryptfs inode. Rather than inode_newsize_ok() catching maximum file size errors early on, eCryptfs would encrypt zeroed pages and write them to the lower filesystem until the lower filesystem's write path caught the error in generic_write_checks(). This patch introduces a new function, called ecryptfs_inode_newsize_ok(), which checks if the new lower file size is within the appropriate limits when the truncate operation will be growing the lower file. In summary this change prevents eCryptfs truncate operations (and the resulting page encryptions), which would exceed the lower filesystem limits or FSIZE rlimits, from ever starting. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reviewed-by: Li Wang <liwang@nudt.edu.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03eCryptfs: Make truncate path killableTyler Hicks
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream. ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a page, zeroes out the appropriate portions, and then encrypts the page before writing it to the lower filesystem. It was unkillable and due to the lack of sparse file support could result in tying up a large portion of system resources, while encrypting pages of zeros, with no way for the truncate operation to be stopped from userspace. This patch adds the ability for ecryptfs_write() to detect a pending fatal signal and return as gracefully as possible. The intent is to leave the lower file in a useable state, while still allowing a user to break out of the encryption loop. If a pending fatal signal is detected, the eCryptfs inode size is updated to reflect the modified inode size and then -EINTR is returned. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03ecryptfs: Improve metadata read failure loggingTim Gardner
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream. Print inode on metadata read failure. The only real way of dealing with metadata read failures is to delete the underlying file system file. Having the inode allows one to 'find . -inum INODE`. [tyhicks@canonical.com: Removed some minor not-for-stable parts] Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03eCryptfs: Sanitize write counts of /dev/ecryptfsTyler Hicks
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream. A malicious count value specified when writing to /dev/ecryptfs may result in a a very large kernel memory allocation. This patch peeks at the specified packet payload size, adds that to the size of the packet headers and compares the result with the write count value. The resulting maximum memory allocation size is approximately 532 bytes. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25proc: clear_refs: do not clear reserved pagesWill Deacon
commit 85e72aa5384b1a614563ad63257ded0e91d1a620 upstream. /proc/pid/clear_refs is used to clear the Referenced and YOUNG bits for pages and corresponding page table entries of the task with PID pid, which includes any special mappings inserted into the page tables in order to provide things like vDSOs and user helper functions. On ARM this causes a problem because the vectors page is mapped as a global mapping and since ec706dab ("ARM: add a vma entry for the user accessible vector page"), a VMA is also inserted into each task for this page to aid unwinding through signals and syscall restarts. Since the vectors page is required for handling faults, clearing the YOUNG bit (and subsequently writing a faulting pte) means that we lose the vectors page *globally* and cannot fault it back in. This results in a system deadlock on the next exception. To see this problem in action, just run: $ echo 1 > /proc/self/clear_refs on an ARM platform (as any user) and watch your system hang. I think this has been the case since 2.6.37 This patch avoids clearing the aforementioned bits for reserved pages, therefore leaving the vectors page intact on ARM. Since reserved pages are not candidates for swap, this change should not have any impact on the usefulness of clear_refs. Signed-off-by: Will Deacon <will.deacon@arm.com> Reported-by: Moussa Ba <moussaba@micron.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25cifs: lower default wsize when unix extensions are not usedJeff Layton
commit ce91acb3acae26f4163c5a6f1f695d1a1e8d9009 upstream. We've had some reports of servers (namely, the Solaris in-kernel CIFS server) that don't deal properly with writes that are "too large" even though they set CAP_LARGE_WRITE_ANDX. Change the default to better mirror what windows clients do. Cc: Pavel Shilovsky <piastry@etersoft.ru> Reported-by: Nick Davis <phireph0x@yahoo.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25xfs: fix endian conversion issue in discard codeDave Chinner
commit b1c770c273a4787069306fc82aab245e9ac72e9d upstream When finding the longest extent in an AG, we read the value directly out of the AGF buffer without endian conversion. This will give an incorrect length, resulting in FITRIM operations potentially not trimming everything that it should. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25proc: clean up and fix /proc/<pid>/mem handlingLinus Torvalds
commit e268337dfe26dfc7efd422a804dbb27977a3cccc upstream. Jüri Aedla reported that the /proc/<pid>/mem handling really isn't very robust, and it also doesn't match the permission checking of any of the other related files. This changes it to do the permission checks at open time, and instead of tracking the process, it tracks the VM at the time of the open. That simplifies the code a lot, but does mean that if you hold the file descriptor open over an execve(), you'll continue to read from the _old_ VM. That is different from our previous behavior, but much simpler. If somebody actually finds a load where this matters, we'll need to revert this commit. I suspect that nobody will ever notice - because the process mapping addresses will also have changed as part of the execve. So you cannot actually usefully access the fd across a VM change simply because all the offsets for IO would have changed too. Reported-by: Jüri Aedla <asd@ut.ee> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25fix cputime overflow in uptime_proc_showMartin Schwidefsky
commit c3e0ef9a298e028a82ada28101ccd5cf64d209ee upstream. For 32-bit architectures using standard jiffies the idletime calculation in uptime_proc_show will quickly overflow. It takes (2^32 / HZ) seconds of idle-time, or e.g. 12.45 days with no load on a quad-core with HZ=1000. Switch to 64-bit calculations. Cc: Michael Abbott <michael.abbott@diamond.ac.uk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25pnfsblock: limit bio page countPeng Tao
commit 74a6eeb44ca6174d9cc93b9b8b4d58211c57bc80 upstream. One bio can have at most BIO_MAX_PAGES pages. We should limit it bec otherwise bio_alloc will fail when there are many pages in one read/write_pagelist. Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25pnfsblock: don't spinlock when freeing block_devPeng Tao
commit 93a3844ee0f843b05a1df4b52e1a19ff26b98d24 upstream. bl_free_block_dev() may sleep. We can not call it with spinlock held. Besides, there is no need to take bm_lock as we are last user freeing bm_devlist. Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25pnfsblock: acquire im_lock in _preload_rangePeng Tao
commit 39e567ae36fe03c2b446e1b83ee3d39bea08f90b upstream. When calling _add_entry, we should take the im_lock to protect agains other modifiers. Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25fix shrink_dcache_parent() livelockMiklos Szeredi
commit eaf5f9073533cde21c7121c136f1c3f072d9cf59 upstream. Two (or more) concurrent calls of shrink_dcache_parent() on the same dentry may cause shrink_dcache_parent() to loop forever. Here's what appears to happen: 1 - CPU0: select_parent(P) finds C and puts it on dispose list, returns 1 2 - CPU1: select_parent(P) locks P->d_lock 3 - CPU0: shrink_dentry_list() locks C->d_lock dentry_kill(C) tries to lock P->d_lock but fails, unlocks C->d_lock 4 - CPU1: select_parent(P) locks C->d_lock, moves C from dispose list being processed on CPU0 to the new dispose list, returns 1 5 - CPU0: shrink_dentry_list() finds dispose list empty, returns 6 - Goto 2 with CPU0 and CPU1 switched Basically select_parent() steals the dentry from shrink_dentry_list() and thinks it found a new one, causing shrink_dentry_list() to think it's making progress and loop over and over. One way to trigger this is to make udev calls stat() on the sysfs file while it is going away. Having a file in /lib/udev/rules.d/ with only this one rule seems to the trick: ATTR{vendor}=="0x8086", ATTR{device}=="0x10ca", ENV{PCI_SLOT_NAME}="%k", ENV{MATCHADDR}="$attr{address}", RUN+="/bin/true" Then execute the following loop: while true; do echo -bond0 > /sys/class/net/bonding_masters echo +bond0 > /sys/class/net/bonding_masters echo -bond1 > /sys/class/net/bonding_masters echo +bond1 > /sys/class/net/bonding_masters done One fix would be to check all callers and prevent concurrent calls to shrink_dcache_parent(). But I think a better solution is to stop the stealing behavior. This patch adds a new dentry flag that is set when the dentry is added to the dispose list. The flag is cleared in dentry_lru_del() in case the dentry gets a new reference just before being pruned. If the dentry has this flag, select_parent() will skip it and let shrink_dentry_list() retry pruning it. With select_parent() skipping those dentries there will not be the appearance of progress (new dentries found) when there is none, hence shrink_dcache_parent() will not loop forever. Set the flag is also set in prune_dcache_sb() for consistency as suggested by Linus. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25dcache: use a dispose list in select_parentDave Chinner
commit b48f03b319ba78f3abf9a7044d1f436d8d90f4f9 upstream. select_parent currently abuses the dentry cache LRU to provide cleanup features for child dentries that need to be freed. It moves them to the tail of the LRU, then tells shrink_dcache_parent() to calls __shrink_dcache_sb to unconditionally move them to a dispose list (as DCACHE_REFERENCED is ignored). __shrink_dcache_sb() has to relock the dentries to move them off the LRU onto the dispose list, but otherwise does not touch the dentries that select_parent() moved to the tail of the LRU. It then passses the dispose list to shrink_dentry_list() which tries to free the dentries. IOWs, the use of __shrink_dcache_sb() is superfluous - we can build exactly the same list of dentries for disposal directly in select_parent() and call shrink_dentry_list() instead of calling __shrink_dcache_sb() to do that. This means that we avoid long holds on the lru lock walking the LRU moving dentries to the dispose list We also avoid the need to relock each dentry just to move it off the LRU, reducing the numebr of times we lock each dentry to dispose of them in shrink_dcache_parent() from 3 to 2 times. Further, we remove one of the two callers of __shrink_dcache_sb(). This also means that __shrink_dcache_sb can be moved into back into prune_dcache_sb() and we no longer have to handle referenced dentries conditionally, simplifying the code. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25fsnotify: don't BUG in fsnotify_destroy_mark()Miklos Szeredi
commit fed474857efbed79cd390d0aee224231ca718f63 upstream. Removing the parent of a watched file results in "kernel BUG at fs/notify/mark.c:139". To reproduce add "-w /tmp/audit/dir/watched_file" to audit.rules rm -rf /tmp/audit/dir This is caused by fsnotify_destroy_mark() being called without an extra reference taken by the caller. Reported by Francesco Cosoleto here: https://bugzilla.novell.com/show_bug.cgi?id=689860 Fix by removing the BUG_ON and adding a comment about not accessing mark after the iput. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25nfsd: Fix oops when parsing a 0 length exportSasha Levin
commit b2ea70afade7080360ac55c4e64ff7a5fafdb67b upstream. expkey_parse() oopses when handling a 0 length export. This is easily triggerable from usermode by writing 0 bytes into '/proc/[proc id]/net/rpc/nfsd.fh/channel'. Below is the log: [ 1402.286893] BUG: unable to handle kernel paging request at ffff880077c49fff [ 1402.287632] IP: [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1 [ 1402.287632] PGD 2206063 PUD 1fdfd067 PMD 1ffbc067 PTE 8000000077c49160 [ 1402.287632] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [ 1402.287632] CPU 1 [ 1402.287632] Pid: 20198, comm: trinity Not tainted 3.2.0-rc2-sasha-00058-gc65cd37 #6 [ 1402.287632] RIP: 0010:[<ffffffff812b4b99>] [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1 [ 1402.287632] RSP: 0018:ffff880077f0fd68 EFLAGS: 00010292 [ 1402.287632] RAX: ffff880077c49fff RBX: 00000000ffffffea RCX: 0000000001043400 [ 1402.287632] RDX: 0000000000000000 RSI: ffff880077c4a000 RDI: ffffffff82283de0 [ 1402.287632] RBP: ffff880077f0fe18 R08: 0000000000000001 R09: ffff880000000000 [ 1402.287632] R10: 0000000000000000 R11: 0000000000000001 R12: ffff880077c4a000 [ 1402.287632] R13: ffffffff82283de0 R14: 0000000001043400 R15: ffffffff82283de0 [ 1402.287632] FS: 00007f25fec3f700(0000) GS:ffff88007d400000(0000) knlGS:0000000000000000 [ 1402.287632] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1402.287632] CR2: ffff880077c49fff CR3: 0000000077e1d000 CR4: 00000000000406e0 [ 1402.287632] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 1402.287632] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 1402.287632] Process trinity (pid: 20198, threadinfo ffff880077f0e000, task ffff880077db17b0) [ 1402.287632] Stack: [ 1402.287632] ffff880077db17b0 ffff880077c4a000 ffff880077f0fdb8 ffffffff810b411e [ 1402.287632] ffff880000000000 ffff880077db17b0 ffff880077c4a000 ffffffff82283de0 [ 1402.287632] 0000000001043400 ffffffff82283de0 ffff880077f0fde8 ffffffff81111f63 [ 1402.287632] Call Trace: [ 1402.287632] [<ffffffff810b411e>] ? lock_release+0x1af/0x1bc [ 1402.287632] [<ffffffff81111f63>] ? might_fault+0x97/0x9e [ 1402.287632] [<ffffffff81111f1a>] ? might_fault+0x4e/0x9e [ 1402.287632] [<ffffffff81a8bcf2>] cache_do_downcall+0x3e/0x4f [ 1402.287632] [<ffffffff81a8c950>] cache_write.clone.16+0xbb/0x130 [ 1402.287632] [<ffffffff81a8c9df>] ? cache_write_pipefs+0x1a/0x1a [ 1402.287632] [<ffffffff81a8c9f8>] cache_write_procfs+0x19/0x1b [ 1402.287632] [<ffffffff8118dc54>] proc_reg_write+0x8e/0xad [ 1402.287632] [<ffffffff8113fe81>] vfs_write+0xaa/0xfd [ 1402.287632] [<ffffffff8114142d>] ? fget_light+0x35/0x9e [ 1402.287632] [<ffffffff8113ff8b>] sys_write+0x48/0x6f [ 1402.287632] [<ffffffff81bbdb92>] system_call_fastpath+0x16/0x1b [ 1402.287632] Code: c0 c9 c3 55 48 63 d2 48 89 e5 48 8d 44 32 ff 41 57 41 56 41 55 41 54 53 bb ea ff ff ff 48 81 ec 88 00 00 00 48 89 b5 58 ff ff ff [ 1402.287632] 38 0a 0f 85 89 02 00 00 c6 00 00 48 8b 3d 44 4a e5 01 48 85 [ 1402.287632] RIP [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1 [ 1402.287632] RSP <ffff880077f0fd68> [ 1402.287632] CR2: ffff880077c49fff [ 1402.287632] ---[ end trace 368ef53ff773a5e3 ]--- Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-nfs@vger.kernel.org Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25nfsd4: fix lockowner matchingJ. Bruce Fields
commit b93d87c19821ba7d3ee11557403d782e541071ad upstream. Lockowners are looked up by file as well as by owner, but we were forgetting to do a comparison on the file. This could cause an incorrect result from lockt. (Note looking up the inode from the lockowner is pretty awkward here. The data structures need fixing.) Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25Unused iocbs in a batch should not be accounted as active.Gleb Natapov
commit 69e4747ee9727d660b88d7e1efe0f4afcb35db1b upstream. Since commit 080d676de095 ("aio: allocate kiocbs in batches") iocbs are allocated in a batch during processing of first iocbs. All iocbs in a batch are automatically added to ctx->active_reqs list and accounted in ctx->reqs_active. If one (not the last one) of iocbs submitted by an user fails, further iocbs are not processed, but they are still present in ctx->active_reqs and accounted in ctx->reqs_active. This causes process to stuck in a D state in wait_for_all_aios() on exit since ctx->reqs_active will never go down to zero. Furthermore since kiocb_batch_free() frees iocb without removing it from active_reqs list the list become corrupted which may cause oops. Fix this by removing iocb from ctx->active_reqs and updating ctx->reqs_active in kiocb_batch_free(). Signed-off-by: Gleb Natapov <gleb@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25UBIFS: make debugging messages light againArtem Bityutskiy
commit 1f5d78dc4823a85f112aaa2d0f17624f8c2a6c52 upstream. We switch to dynamic debugging in commit 56e46742e846e4de167dde0e1e1071ace1c882a5 but did not take into account that now we do not control anymore whether a specific message is enabled or not. So now we lock the "dbg_lock" and release it in every debugging macro, which make them not so light-weight. This commit removes the "dbg_lock" protection from the debugging macros to fix the issue. The downside is that now our DBGKEY() stuff is broken, but this is not critical at all and will be fixed later. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25UBIFS: fix debugging messagesArtem Bityutskiy
commit d34315da9146253351146140ea4b277193ee5e5f upstream. Patch 56e46742e846e4de167dde0e1e1071ace1c882a5 broke UBIFS debugging messages: before that commit when UBIFS debugging was enabled, users saw few useful debugging messages after mount. However, that patch turned 'dbg_msg()' into 'pr_debug()', so to enable the debugging messages users have to enable them first via /sys/kernel/debug/dynamic_debug/control, which is very impractical. This commit makes 'dbg_msg()' to use 'printk()' instead of 'pr_debug()', just as it was before the breakage. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25nfs: fix regression in handling of context= option in NFSv4Jeff Layton
commit 8a0d551a59ac92d8ff048d6cb29d3a02073e81e8 upstream. Setting the security context of a NFSv4 mount via the context= mount option is currently broken. The NFSv4 codepath allocates a parsed options struct, and then parses the mount options to fill it. It eventually calls nfs4_remote_mount which calls security_init_mnt_opts. That clobbers the lsm_opts struct that was populated earlier. This bug also looks like it causes a small memory leak on each v4 mount where context= is used. Fix this by moving the initialization of the lsm_opts into nfs_alloc_parsed_mount_data. Also, add a destructor for nfs_parsed_mount_data to make it easier to free all of the allocations hanging off of it, and to ensure that the security_free_mnt_opts is called whenever security_init_mnt_opts is. I believe this regression was introduced quite some time ago, probably by commit c02d7adf. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25NFSv4: include bitmap in nfsv4 get acl dataAndy Adamson
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream. The NFSv4 bitmap size is unbounded: a server can return an arbitrary sized bitmap in an FATTR4_WORD0_ACL request. Replace using the nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data xdr length to the (cached) acl page data. This is a general solution to commit e5012d1f "NFSv4.1: update nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead when getting ACLs. Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25NFS - fix recent breakage to NFS error handling.NeilBrown
commit 2edb6bc3852c681c0d948245bd55108dc6407604 upstream. From c6d615d2b97fe305cbf123a8751ced859dca1d5e Mon Sep 17 00:00:00 2001 From: NeilBrown <neilb@suse.de> Date: Wed, 16 Nov 2011 09:39:05 +1100 Subject: NFS - fix recent breakage to NFS error handling. commit 02c24a82187d5a628c68edfe71ae60dc135cd178 made a small and presumably unintended change to write error handling in NFS. Previously an error from filemap_write_and_wait_range would only be of interest if nfs_file_fsync did not return an error. After this commit, an error from filemap_write_and_wait_range would mean that (the rest of) nfs_file_fsync would not even be called. This means that: 1/ you are more likely to see EIO than e.g. EDQUOT or ENOSPC. 2/ NFS_CONTEXT_ERROR_WRITE remains set for longer so more writes are synchronous. This patch restores previous behaviour. Cc: Josef Bacik <josef@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25NFSv4.1: fix backchannel slotid off-by-one bugAndy Adamson
commit 61f2e5106582d02f30b6807e3f9c07463c572ccb upstream. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25pnfs-obj: Must return layout on IO errorBoaz Harrosh
commit fe0fe83585f88346557868a803a479dfaaa0688a upstream. As mandated by the standard. In case of an IO error, a pNFS objects layout driver must return it's layout. This is because all device errors are reported to the server as part of the layout return buffer. This is implemented the same way PNFS_LAYOUTRET_ON_SETATTR is done, through a bit flag on the pnfs_layoutdriver_type->flags member. The flag is set by the layout driver that wants a layout_return preformed at pnfs_ld_{write,read}_done in case of an error. (Though I have not defined a wrapper like pnfs_ld_layoutret_on_setattr because this code is never called outside of pnfs.c and pnfs IO paths) Without this patch 3.[0-2] Kernels leak memory and have an annoying WARN_ON after every IO error utilizing the pnfs-obj driver. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
