Retry loops on RT might loop forever when the modifying side was
preempted. Use cpu_chill() instead of cpu_relax() to let the system
make progress.
Cc: stable-rt@vger.kernel.org
On Sat, 2007-10-27 at 11:44 +0200, Ingo Molnar wrote:
> * Nick Piggin <nickpiggin@yahoo.com.au> wrote:
> > > [10138.175796] [<c0105de3>] show_trace+0x12/0x14
> > > [10138.180291] [<c0105dfb>] dump_stack+0x16/0x18
> > > [10138.184769] [<c011609f>] native_smp_call_function_mask+0x138/0x13d
> > > [10138.191117] [<c0117606>] smp_call_function+0x1e/0x24
> > > [10138.196210] [<c012f85c>] on_each_cpu+0x25/0x50
> > > [10138.200807] [<c0115c74>] flush_tlb_all+0x1e/0x20
> > > [10138.205553] [<c016caaf>] kmap_high+0x1b6/0x417
> > > [10138.210118] [<c011ec88>] kmap+0x4d/0x4f
> > > [10138.214102] [<c026a9d8>] ntfs_end_buffer_async_read+0x228/0x2f9
> > > [10138.220163] [<c01a0e9e>] end_bio_bh_io_sync+0x26/0x3f
> > > [10138.225352] [<c01a2b09>] bio_endio+0x42/0x6d
> > > [10138.229769] [<c02c2a08>] __end_that_request_first+0x115/0x4ac
> > > [10138.235682] [<c02c2da7>] end_that_request_chunk+0x8/0xa
> > > [10138.241052] [<c0365943>] ide_end_request+0x55/0x10a
> > > [10138.246058] [<c036dae3>] ide_dma_intr+0x6f/0xac
> > > [10138.250727] [<c0366d83>] ide_intr+0x93/0x1e0
> > > [10138.255125] [<c015afb4>] handle_IRQ_event+0x5c/0xc9
> > Looks like ntfs is kmap()ing from interrupt context. Should be using
> > kmap_atomic instead, I think.
> it's not atomic interrupt context but irq thread context - and -rt
> remaps kmap_atomic() to kmap() internally.
Hm. Looking at the change to mm/bounce.c, perhaps I should do this
instead?
On RT we cannot loop with preemption disabled here as
mnt_make_readonly() might have been preempted. We can safely enable
preemption while waiting for MNT_WRITE_HOLD to be cleared. Safe on !RT
as well.
If hrtimer_try_to_cancel() requires a retry, then depending on the
priority setting te retry loop might prevent timer callback completion
on RT. Prevent that by waiting for completion on RT, no change for a
non RT kernel.
Reported-by: Sankara Muthukrishnan <sankara.m@gmail.com>
Wrap the bit_spin_lock calls into a separate inline and add the RT
replacements with a real spinlock.
RT cannot disable preemption in the seqcount write sections due to
functions called which take "sleeping" spinlocks.
Move the code out of those sections. It does not need to be there.
commit de5b8e8e047534aac6bc9803f96e7257436aef9c upstream.
If you try to set grace_period or timeout via a module parameter
to lockd, and do this on a big-endian machine where
sizeof(int) != sizeof(unsigned long)
it won't work. This number given will be effectively shifted right
by the difference in those two sizes.
So cast kp->arg properly to get correct result.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit e59d27e05a6435f8c04d5ad843f37fa795f2eaaa upstream.
Firstly, task->tk_status will always return negative error values,
so the current tests for 'NFS4ERR_DELEG_REVOKED' etc. are all being
ignored.
Secondly, clean up the code so that we only need to test
task->tk_status once!
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 05e9cfb408b24debb3a85fd98edbfd09dd148881 upstream.
We can currently loop forever in nfs4_lookup_root() and in
nfs41_proc_secinfo_no_name(), if the first iteration returns a
NFS4ERR_DELAY or something else that causes exception.retry to get
set.
Reported-by: Weston Andros Adamson <dros@netapp.com>
commit d97d32edcd732110758799ae60af725e5110b3dc upstream.
When an IO error happens during inode deletion run from
xlog_recover_process_iunlinks() filesystem gets shutdown. Thus any subsequent
attempt to read buffers fails. Code in xlog_recover_process_iunlinks() does not
count with the fact that read of a buffer which was read a while ago can
really fail which results in the oops on
agi = XFS_BUF_TO_AGI(agibp);
Fix the problem by cleaning up the buffer handling in
xlog_recover_process_iunlinks() as suggested by Dave Chinner. We release buffer
lock but keep buffer reference to AG buffer. That is enough for buffer to stay
pinned in memory and we don't have to call xfs_read_agi() all the time.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit a0391a3ae91d301c0e59368531a4de5f0b122bcf upstream.
udf_release_file() can be called from munmap() path with mmap_sem held. Thus
we cannot take i_mutex there because that ranks above mmap_sem. Luckily,
i_mutex is not needed in udf_release_file() anymore since protection by
i_data_sem is enough to protect from races with write and truncate.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
commit b18dafc86bb879d2f38a1743985d7ceb283c2f4d upstream.
In d_materialise_unique() there are 3 subcases to the 'aliased dentry'
case; in two subcases the inode i_lock is properly released but this
does not occur in the -ELOOP subcase.
This seems to have been introduced by commit 1836750115f2 ("fix loop
checks in d_materialise_unique()").
Signed-off-by: Michel Lespinasse <walken@google.com>
[ Added a comment, and moved the unlock to where we generate the -ELOOP,
which seems to be more natural.
You probably can't actually trigger this without a buggy network file
server - d_materialize_unique() is for finding aliases on non-local
filesystems, and the d_ancestor() case is for a hardlinked directory
loop.
But we should be robust in the case of such buggy servers anyway. ]
commit 31d4f3a2f3c73f279ff96a7135d7202ef6833f12 upstream.
Explicitly test for an extent whose length is zero, and flag that as a
corrupted extent.
This avoids a kernel BUG_ON assertion failure.
Tested: Without this patch, the file system image found in
tests/f_ext_zero_len/image.gz in the latest e2fsprogs sources causes a
kernel panic. With this patch, an ext4 file system error is noted
instead, and the file system is marked as being corrupted.
https://bugzilla.kernel.org/show_bug.cgi?id=42859
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 491caa43639abcffaa645fbab372a7ef4ce2975c upstream.
The following command line will leave the aio-stress process unkillable
on an ext4 file system (in my case, mounted on /mnt/test):
aio-stress -t 20 -s 10 -O -S -o 2 -I 1000 /mnt/test/aiostress.3561.4 /mnt/test/aiostress.3561.4.20 /mnt/test/aiostress.3561.4.19 /mnt/test/aiostress.3561.4.18 /mnt/test/aiostress.3561.4.17 /mnt/test/aiostress.3561.4.16 /mnt/test/aiostress.3561.4.15 /mnt/test/aiostress.3561.4.14 /mnt/test/aiostress.3561.4.13 /mnt/test/aiostress.3561.4.12 /mnt/test/aiostress.3561.4.11 /mnt/test/aiostress.3561.4.10 /mnt/test/aiostress.3561.4.9 /mnt/test/aiostress.3561.4.8 /mnt/test/aiostress.3561.4.7 /mnt/test/aiostress.3561.4.6 /mnt/test/aiostress.3561.4.5 /mnt/test/aiostress.3561.4.4 /mnt/test/aiostress.3561.4.3 /mnt/test/aiostress.3561.4.2
This is using the aio-stress program from the xfstests test suite.
That particular command line tells aio-stress to do random writes to
20 files from 20 threads (one thread per file). The files are NOT
preallocated, so you will get writes to random offsets within the
file, thus creating holes and extending i_size. It also opens the
file with O_DIRECT and O_SYNC.
On to the problem. When an I/O requires unwritten extent conversion,
it is queued onto the completed_io_list for the ext4 inode. Two code
paths will pull work items from this list. The first is the
ext4_end_io_work routine, and the second is ext4_flush_completed_IO,
which is called via the fsync path (and O_SYNC handling, as well).
There are two issues I've found in these code paths. First, if the
fsync path beats the work routine to a particular I/O, the work
routine will free the io_end structure! It does not take into account
the fact that the io_end may still be in use by the fsync path. I've
fixed this issue by adding yet another IO_END flag, indicating that
the io_end is being processed by the fsync path.
The second problem is that the work routine will make an assignment to
io->flag outside of the lock. I have witnessed this result in a hang
at umount. Moving the flag setting inside the lock resolved that
problem.
The problem was introduced by commit b82e384c7b ("ext4: optimize
locking for end_io extent conversion"), which first appeared in 3.2.
As such, the fix should be backported to that release (probably along
with the unwritten extent conversion race fix).
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
commit 266991b13890049ee1a6bb95b9817f06339ee3d7 upstream.
The following comment in ext4_end_io_dio caught my attention:
/* XXX: probably should move into the real I/O completion handler */
inode_dio_done(inode);
The truncate code takes i_mutex, then calls inode_dio_wait. Because the
ext4 code path above will end up dropping the mutex before it is
reacquired by the worker thread that does the extent conversion, it
seems to me that the truncate can happen out of order. Jan Kara
mentioned that this might result in error messages in the system logs,
but that should be the extent of the "damage."
The fix is pretty straight-forward: don't call inode_dio_done until the
extent conversion is complete.
commit 3d2b158262826e8b75bbbfb7b97010838dd92ac7 upstream.
Ext4 does not support data journalling with delayed allocation enabled.
We even do not allow to mount the file system with delayed allocation
and data journalling enabled, however it can be set via FS_IOC_SETFLAGS
so we can hit the inode with EXT4_INODE_JOURNAL_DATA set even on file
system mounted with delayed allocation (default) and that's where
problem arises. The easies way to reproduce this problem is with the
following set of commands:
mkfs.ext4 /dev/sdd
mount /dev/sdd /mnt/test1
dd if=/dev/zero of=/mnt/test1/file bs=1M count=4
chattr +j /mnt/test1/file
dd if=/dev/zero of=/mnt/test1/file bs=1M count=4 conv=notrunc
chattr -j /mnt/test1/file
Additionally it can be reproduced quite reliably with xfstests 272 and
269. In fact the above reproducer is a part of test 272.
To fix this we should ignore the EXT4_INODE_JOURNAL_DATA inode flag if
the file system is mounted with delayed allocation. This can be easily
done by fixing ext4_should_*_data() functions do ignore data journal
flag when delalloc is set (suggested by Ted). We also have to set the
appropriate address space operations for the inode (again, ignoring data
journal flag if delalloc enabled).
Additionally this commit introduces ext4_inode_journal_mode() function
because ext4_should_*_data() has already had a lot of common code and
this change is putting it all into one function so it is easier to
read.
Successfully tested with xfstests in following configurations:
delalloc + data=ordered
delalloc + data=writeback
data=journal
nodelalloc + data=ordered
nodelalloc + data=writeback
nodelalloc + data=journal
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 15291164b22a357cb211b618adfef4fa82fc0de3 upstream.
journal_unmap_buffer()'s zap_buffer: code clears a lot of buffer head
state ala discard_buffer(), but does not touch _Delay or _Unwritten as
discard_buffer() does.
This can be problematic in some areas of the ext4 code which assume
that if they have found a buffer marked unwritten or delay, then it's
a live one. Perhaps those spots should check whether it is mapped
as well, but if jbd2 is going to tear down a buffer, let's really
tear it down completely.
Without this I get some fsx failures on sub-page-block filesystems
up until v3.2, at which point 4e96b2dbbf1d7e81f22047a50f862555a6cb87cb
and 189e868fa8fdca702eb9db9d8afc46b5cb9144c9 make the failures go
away, because buried within that large change is some more flag
clearing. I still think it's worth doing in jbd2, since
->invalidatepage leads here directly, and it's the right place
to clear away these flags.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit 9a3ba432330e504ac61ff0043dbdaba7cea0e35a upstream.
Prevent the state manager from filling up system logs when recovery
fails on the server.
commit 4e474a00d7ff746ed177ddae14fa8b2d4bad7a00 upstream.
Protect code accessing ctl_table by grabbing the header with grab_header()
and after releasing with sysctl_head_finish(). This is needed if poll()
is called in entries created by modules: currently only hostname and
domainname support poll(), but this bug may be triggered when/if modules
use it and if user called poll() in a file that doesn't support it.
Dave Jones reported the following when using a syscall fuzzer while
hibernating/resuming:
RIP: 0010:[<ffffffff81233e3e>] [<ffffffff81233e3e>] proc_sys_poll+0x4e/0x90
RAX: 0000000000000145 RBX: ffff88020cab6940 RCX: 0000000000000000
RDX: ffffffff81233df0 RSI: 6b6b6b6b6b6b6b6b RDI: ffff88020cab6940
Code: 00 48 89 fb 48 89 f1 48 8b 40 30 4c 8b 60 e8 b8 45 01 00 00 49 83
7c 24 28 00 74 2e 49 8b 74 24 30 48 85 f6 74 24 48 85 c9 75 32 <8b> 16
b8 45 01 00 00 48 63 d2 49 39 d5 74 10 8b 06 48 98 48 89
If an entry goes away while we are polling() it, ctl_table may not exist
anymore.
Reported-by: Dave Jones <davej@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 1b26c9b334044cff6d1d2698f2be41bc7d9a0864 upstream.
The namespace cleanup path leaks a dentry which holds a reference count
on a network namespace. Keeping that network namespace from being freed
when the last user goes away. Leaving things like vlan devices in the
leaked network namespace.
If you use ip netns add for much real work this problem becomes apparent
pretty quickly. It light testing the problem hides because frequently
you simply don't notice the leak.
Use d_set_d_op() so that DCACHE_OP_* flags are set correctly.
This issue exists back to 3.0.
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Reported-by: Justin Pettit <jpettit@nicira.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
commit ce85852b90a214cf577fc1b4f49d99fd7e98784a upstream.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Steve French <sfrench@us.ibm.com>
controller to the next
commit 1daaae8fa4afe3df78ca34e724ed7e8187e4eb32 upstream.
This patch fixes an issue when cifs_mount receives a
STATUS_BAD_NETWORK_NAME error during cifs_get_tcon but is able to
continue after an DFS ROOT referral. In this case, the return code
variable is not reset prior to trying to mount from the system referred
to. Thus, is_path_accessible is not executed and the final DFS referral
is not performed causing a mount error.
Use case: In DNS, example.com resolves to the secondary AD server
ad2.example.com Our primary domain controller is ad1.example.com and has
a DFS redirection set up from \\ad1\share\Users to \\files\share\Users.
Mounting \\example.com\share\Users fails.
Regression introduced by commit 724d9f1.
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru
Signed-off-by: Thomas Hadig <thomas@intapp.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 10b9b98e41ba248a899f6175ce96ee91431b6194 upstream.
Some servers sets this value less than 50 that was hardcoded and
we lost the connection if when we exceed this limit. Fix this by
respecting this value - not sending more than the server allows.
Reviewed-by: Jeff Layton <jlayton@samba.org>
commit f30d500f809eca67a21704347ab14bb35877b5ee upstream.
When we get concurrent lookups of the same inode that is not in the
per-AG inode cache, there is a race condition that triggers warnings
in unlock_new_inode() indicating that we are initialising an inode
that isn't in a the correct state for a new inode.
When we do an inode lookup via a file handle or a bulkstat, we don't
serialise lookups at a higher level through the dentry cache (i.e.
pathless lookup), and so we can get concurrent lookups of the same
inode.
The race condition is between the insertion of the inode into the
cache in the case of a cache miss and a concurrently lookup:
Thread 1 Thread 2
xfs_iget()
xfs_iget_cache_miss()
xfs_iread()
lock radix tree
radix_tree_insert()
rcu_read_lock
radix_tree_lookup
lock inode flags
XFS_INEW not set
igrab()
unlock inode flags
rcu_read_unlock
use uninitialised inode
lock inode flags
set XFS_INEW
unlock inode flags
unlock radix tree
xfs_setup_inode()
inode flags = I_NEW
unlock_new_inode()
WARNING as inode flags != I_NEW
This can lead to inode corruption, inode list corruption, etc, and
is generally a bad thing to occur.
Fix this by setting XFS_INEW before inserting the inode into the
radix tree. This will ensure any concurrent lookup will find the new
inode with XFS_INEW set and that forces the lookup to wait until the
XFS_INEW flag is removed before allowing the lookup to succeed.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
commit 3114ea7a24d3264c090556a2444fc6d2c06176d4 upstream.
If a setattr() fails because of an NFS4ERR_OPENMODE error, it is
probably due to us holding a read delegation. Ensure that the
recovery routines return that delegation in this case.
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
commit a1d0b5eebc4fd6e0edb02688b35f17f67f42aea5 upstream.
If we know that the delegation stateid is bad or revoked, we need to
remove that delegation as soon as possible, and then mark all the
stateids that relied on that delegation for recovery. We cannot use
the delegation as part of the recovery process.
Also note that NFSv4.1 uses a different error code (NFS4ERR_DELEG_REVOKED)
to indicate that the delegation was revoked.
Finally, ensure that setlk() and setattr() can both recover safely from
a revoked delegation.
commit a05b0855fd15504972dba2358e5faa172a1e50ba upstream.
Taking i_mutex in hugetlbfs_read() can result in deadlock with mmap as
explained below
Thread A:
read() on hugetlbfs
hugetlbfs_read() called
i_mutex grabbed
hugetlbfs_read_actor() called
__copy_to_user() called
page fault is triggered
Thread B, sharing address space with A:
mmap() the same file
->mmap_sem is grabbed on task_B->mm->mmap_sem
hugetlbfs_file_mmap() is called
attempt to grab ->i_mutex and block waiting for A to give it up
Thread A:
pagefault handled blocked on attempt to grab task_A->mm->mmap_sem,
which happens to be the same thing as task_B->mm->mmap_sem. Block waiting
for B to give it up.
AFAIU the i_mutex locking was added to hugetlbfs_read() as per
http://lkml.indiana.edu/hypermail/linux/kernel/0707.2/3066.html to take
care of the race between truncate and read. This patch fixes this by
looking at page->mapping under lock_page() (find_lock_page()) to ensure
that the inode didn't get truncated in the range during a parallel read.
Ideally we can extend the patch to make sure we don't increase i_size in
mmap. But that will break userspace, because applications will now have
to use truncate(2) to increase i_size in hugetlbfs.
Based on the original patch from Hillf Danton.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Mark Salter <msalter@redhat.com>
commit 93518dd2ebafcc761a8637b2877008cfd748c202 upstream.
This patch fixies follwing two memory leak patterns that reported by kmemleak.
sysfs_sd_setsecdata() is called during sys_lsetxattr() operation.
It checks sd->s_iattr is NULL or not. Then if it is NULL, it calls
sysfs_init_inode_attrs() to allocate memory.
That code is this.
iattrs = sd->s_iattr;
if (!iattrs)
iattrs = sysfs_init_inode_attrs(sd);
The iattrs recieves sysfs_init_inode_attrs()'s result, but sd->s_iattr
doesn't know the address. so it needs to set correct address to
sd->s_iattr to free memory in other function.
unreferenced object 0xffff880250b73e60 (size 32):
comm "systemd", pid 1, jiffies 4294683888 (age 94.553s)
hex dump (first 32 bytes):
73 79 73 74 65 6d 5f 75 3a 6f 62 6a 65 63 74 5f system_u:object_
72 3a 73 79 73 66 73 5f 74 3a 73 30 00 00 00 00 r:sysfs_t:s0....
backtrace:
[<ffffffff814cb1d0>] kmemleak_alloc+0x73/0x98
[<ffffffff811270ab>] __kmalloc+0x100/0x12c
[<ffffffff8120775a>] context_struct_to_string+0x106/0x210
[<ffffffff81207cc1>] security_sid_to_context_core+0x10b/0x129
[<ffffffff812090ef>] security_sid_to_context+0x10/0x12
[<ffffffff811fb0da>] selinux_inode_getsecurity+0x7d/0xa8
[<ffffffff811fb127>] selinux_inode_getsecctx+0x22/0x2e
[<ffffffff811f4d62>] security_inode_getsecctx+0x16/0x18
[<ffffffff81191dad>] sysfs_setxattr+0x96/0x117
[<ffffffff811542f0>] __vfs_setxattr_noperm+0x73/0xd9
[<ffffffff811543d9>] vfs_setxattr+0x83/0xa1
[<ffffffff811544c6>] setxattr+0xcf/0x101
[<ffffffff81154745>] sys_lsetxattr+0x6a/0x8f
[<ffffffff814efda9>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
unreferenced object 0xffff88024163c5a0 (size 96):
00 00 00 00 ed 41 00 00 00 00 00 00 00 00 00 00 .....A..........
00 00 00 00 00 00 00 00 0c 64 42 4f 00 00 00 00 .........dBO....
backtrace:
[<ffffffff81127402>] kmem_cache_alloc_trace+0xc4/0xee
[<ffffffff81191cbe>] sysfs_init_inode_attrs+0x2a/0x83
[<ffffffff81191dd6>] sysfs_setxattr+0xbf/0x117
Signed-off-by: Masami Ichikawa <masami256@gmail.com>
commit c0173863528a8c9212c53e080d63a1aaae5ef4f4 upstream.
When writing files to afs I sometimes hit a BUG:
kernel BUG at fs/afs/rxrpc.c:179!
With a backtrace of:
afs_free_call
afs_make_call
afs_fs_store_data
afs_vnode_store_data
afs_write_back_from_locked_page
afs_writepages_region
afs_writepages
The cause is:
ASSERT(skb_queue_empty(&call->rx_queue));
Looking at a tcpdump of the session the abort happens because we
are exceeding our disk quota:
rx abort fs reply store-data error diskquota exceeded (32)
So the abort error is valid. We hit the BUG because we haven't
freed all the resources for the call.
By freeing any skbs in call->rx_queue before calling afs_free_call
we avoid hitting leaking memory and avoid hitting the BUG.
commit 2c724fb92732c0b2a5629eb8af74e82eb62ac947 upstream.
A read of a large file on an afs mount failed:
# cat junk.file > /dev/null
cat: junk.file: Bad message
Looking at the trace, call->offset wrapped since it is only an
unsigned short. In afs_extract_data:
_enter("{%u},{%zu},%d,,%zu", call->offset, len, last, count);
if (call->offset < count) {
if (last) {
_leave(" = -EBADMSG [%d < %zu]", call->offset, count);
return -EBADMSG;
Which matches the trace:
[cat ] ==> afs_extract_data({65132},{524},1,,65536)
[cat ] <== afs_extract_data() = -EBADMSG [0 < 65536]
call->offset went from 65132 to 0. Fix this by making call->offset an
unsigned int.
commit d7178c79d9b7c5518f9943188091a75fc6ce0675 upstream.
According to the report from Slicky Devil, nilfs caused kernel oops at
nilfs_load_super_block function during mount after he shrank the
partition without resizing the filesystem:
BUG: unable to handle kernel NULL pointer dereference at 00000048
IP: [<d0d7a08e>] nilfs_load_super_block+0x17e/0x280 [nilfs2]
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
Call Trace:
[<d0d7a87b>] init_nilfs+0x4b/0x2e0 [nilfs2]
[<d0d6f707>] nilfs_mount+0x447/0x5b0 [nilfs2]
[<c0226636>] mount_fs+0x36/0x180
[<c023d961>] vfs_kern_mount+0x51/0xa0
[<c023ddae>] do_kern_mount+0x3e/0xe0
[<c023f189>] do_mount+0x169/0x700
[<c023fa9b>] sys_mount+0x6b/0xa0
[<c04abd1f>] sysenter_do_call+0x12/0x28
Code: 53 18 8b 43 20 89 4b 18 8b 4b 24 89 53 1c 89 43 24 89 4b 20 8b 43
20 c7 43 2c 00 00 00 00 23 75 e8 8b 50 68 89 53 28 8b 54 b3 20 <8b> 72
48 8b 7a 4c 8b 55 08 89 b3 84 00 00 00 89 bb 88 00 00 00
EIP: [<d0d7a08e>] nilfs_load_super_block+0x17e/0x280 [nilfs2] SS:ESP 0068:ca9bbdcc
CR2: 0000000000000048
This turned out due to a defect in an error path which runs if the
calculated location of the secondary super block was invalid.
This patch fixes it and eliminates the reported oops.
Reported-by: Slicky Devil <slicky.dvl@gmail.com>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Slicky Devil <slicky.dvl@gmail.com>
commit fe316bf2d5847bc5dd975668671a7b1067603bc7 upstream.
Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(),
__blkdev_get() calls rescan_partitions() to remove
in-kernel partition structures and raise KOBJ_CHANGE uevent.
However it ends up calling driver's revalidate_disk without open
and could cause oops.
In the case of SCSI:
process A process B
sys_open
__blkdev_get
sd_open
returns -ENOMEDIUM
scsi_remove_device
<scsi_device torn down>
rescan_partitions
sd_revalidate_disk
<oops>
Oopses are reported here:
http://marc.info/?l=linux-scsi&m=132388619710052
This patch separates the partition invalidation from rescan_partitions()
and use it for -ENOMEDIUM case.
Reported-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 097b180ca09b581ef0dc24fbcfc1b227de3875df upstream.
complete_walk() already puts nd->path, no need to do it again at cleanup time.
This would result in Oopses if triggered, apparently the codepath is not too
well exercised.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 7f6c7e62fcc123e6bd9206da99a2163fe3facc31 upstream.
complete_walk() returns either ECHILD or ESTALE. do_last() turns this into
ECHILD unconditionally. If not in RCU mode, this error will reach userspace
which is complete nonsense.
commit d5751469f210d2149cc2159ffff66cbeef6da3f2 upstream.
Reorganize the code to make the memory already allocated before
spinlock'ed loop.
commit c7b285550544c22bc005ec20978472c9ac7138c6 upstream.
Current code has put_ioctx() called asynchronously from aio_fput_routine();
that's done *after* we have killed the request that used to pin ioctx,
so there's nothing to stop io_destroy() waiting in wait_for_all_aios()
from progressing. As the result, we can end up with async call of
put_ioctx() being the last one and possibly happening during exit_mmap()
or elf_core_dump(), neither of which expects stray munmap() being done
to them...
We do need to prevent _freeing_ ioctx until aio_fput_routine() is done
with that, but that's all we care about - neither io_destroy() nor
exit_aio() will progress past wait_for_all_aios() until aio_fput_routine()
does really_put_req(), so the ioctx teardown won't be done until then
and we don't care about the contents of ioctx past that point.
Since actual freeing of these suckers is RCU-delayed, we don't need to
bump ioctx refcount when request goes into list for async removal.
All we need is rcu_read_lock held just over the ->ctx_lock-protected
area in aio_fput_routine().
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
commit 86b62a2cb4fc09037bbce2959d2992962396fd7f upstream.
Have ioctx_alloc() return an extra reference, so that caller would drop it
on success and not bother with re-grabbing it on failure exit. The current
code is obviously broken - io_destroy() from another thread that managed
to guess the address io_setup() would've returned would free ioctx right
under us; gets especially interesting if aio_context_t * we pass to
io_setup() points to PROT_READ mapping, so put_user() fails and we end
up doing io_destroy() on kioctx another thread has just got freed...
commit 5bccda0ebc7c0331b81ac47d39e4b920b198b2cd upstream.
The cifs code will attempt to open files on lookup under certain
circumstances. What happens though if we find that the file we opened
was actually a FIFO or other special file?
Currently, the open filehandle just ends up being leaked leading to
a dentry refcount mismatch and oops on umount. Fix this by having the
code close the filehandle on the server if it turns out not to be a
regular file. While we're at it, change this spaghetti if statement
into a switch too.
Reported-by: CAI Qian <caiqian@redhat.com>
Tested-by: CAI Qian <caiqian@redhat.com>
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 880641bb9da2473e9ecf6c708d993b29928c1b3c upstream.
Bart Van Assche reported a hung fio process when either hot-removing
storage or when interrupting the fio process itself. The (pruned) call
trace for the latter looks like so:
fio D 0000000000000001 0 6849 6848 0x00000004
ffff880092541b88 0000000000000046 ffff880000000000 ffff88012fa11dc0
ffff88012404be70 ffff880092541fd8 ffff880092541fd8 ffff880092541fd8
ffff880128b894d0 ffff88012404be70 ffff880092541b88 000000018106f24d
Call Trace:
schedule+0x3f/0x60
io_schedule+0x8f/0xd0
wait_for_all_aios+0xc0/0x100
exit_aio+0x55/0xc0
mmput+0x2d/0x110
exit_mm+0x10d/0x130
do_exit+0x671/0x860
do_group_exit+0x44/0xb0
get_signal_to_deliver+0x218/0x5a0
do_signal+0x65/0x700
do_notify_resume+0x65/0x80
int_signal+0x12/0x17
The problem lies with the allocation batching code. It will
opportunistically allocate kiocbs, and then trim back the list of iocbs
when there is not enough room in the completion ring to hold all of the
events.
In the case above, what happens is that the pruning back of events ends
up freeing up the last active request and the context is marked as dead,
so it is thus responsible for waking up waiters. Unfortunately, the
code does not check for this condition, so we end up with a hung task.
Reported-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Bart Van Assche <bvanassche@acm.org>
commit c8e252586f8d5de906385d8cf6385fee289a825e upstream.
The regset common infrastructure assumed that regsets would always
have .get and .set methods, but not necessarily .active methods.
Unfortunately people have since written regsets without .set methods.
Rather than putting in stub functions everywhere, handle regsets with
null .get or .set methods explicitly.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Roland McGrath <roland@hack.frob.com>
commit a32744d4abae24572eff7269bc17895c41bd0085 upstream.
When the autofs protocol version 5 packet type was added in commit
5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it
obvously tried quite hard to be word-size agnostic, and uses explicitly
sized fields that are all correctly aligned.
However, with the final "char name[NAME_MAX+1]" array at the end, the
actual size of the structure ends up being not very well defined:
because the struct isn't marked 'packed', doing a "sizeof()" on it will
align the size of the struct up to the biggest alignment of the members
it has.
And despite all the members being the same, the alignment of them is
different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte
alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round
number (256), the name[] array starts out a 4-byte aligned.
End result: the "packed" size of the structure is 300 bytes: 4-byte, but
not 8-byte aligned.
As a result, despite all the fields being in the same place on all
architectures, sizeof() will round up that size to 304 bytes on
architectures that have 8-byte alignment for u64.
Note that this is *not* a problem for 32-bit compat mode on POWER, since
there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit
and 64-bit alignment is different for 64-bit entities, and as a result
the structure that has exactly the same layout has different sizes.
So on x86-64, but no other architecture, we will just subtract 4 from
the size of the structure when running in a compat task. That way we
will write the properly sized packet that user mode expects.
Not pretty. Sadly, this very subtle, and unnecessary, size difference
has been encoded in user space that wants to read packets of *exactly*
the right size, and will refuse to touch anything else.
Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ian Kent <raven@themaw.net>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream.
The current epoll code can be tickled to run basically indefinitely in
both loop detection path check (on ep_insert()), and in the wakeup paths.
The programs that tickle this behavior set up deeply linked networks of
epoll file descriptors that cause the epoll algorithms to traverse them
indefinitely. A couple of these sample programs have been previously
posted in this thread: https://lkml.org/lkml/2011/2/25/297.
To fix the loop detection path check algorithms, I simply keep track of
the epoll nodes that have been already visited. Thus, the loop detection
becomes proportional to the number of epoll file descriptor and links.
This dramatically decreases the run-time of the loop check algorithm. In
one diabolical case I tried it reduced the run-time from 15 mintues (all
in kernel time) to .3 seconds.
Fixing the wakeup paths could be done at wakeup time in a similar manner
by keeping track of nodes that have already been visited, but the
complexity is harder, since there can be multiple wakeups on different
cpus...Thus, I've opted to limit the number of possible wakeup paths when
the paths are created.
This is accomplished, by noting that the end file descriptor points that
are found during the loop detection pass (from the newly added link), are
actually the sources for wakeup events. I keep a list of these file
descriptors and limit the number and length of these paths that emanate
from these 'source file descriptors'. In the current implemetation I
allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of
length 4 and 10 of length 5. Note that it is sufficient to check the
'source file descriptors' reachable from the newly added link, since no
other 'source file descriptors' will have newly added links. This allows
us to check only the wakeup paths that may have gotten too long, and not
re-check all possible wakeup paths on the system.
In terms of the path limit selection, I think its first worth noting that
the most common case for epoll, is probably the model where you have 1
epoll file descriptor that is monitoring n number of 'source file
descriptors'. In this case, each 'source file descriptor' has a 1 path of
length 1. Thus, I believe that the limits I'm proposing are quite
reasonable and in fact may be too generous. Thus, I'm hoping that the
proposed limits will not prevent any workloads that currently work to
fail.
In terms of locking, I have extended the use of the 'epmutex' to all
epoll_ctl add and remove operations. Currently its only used in a subset
of the add paths. I need to hold the epmutex, so that we can correctly
traverse a coherent graph, to check the number of paths. I believe that
this additional locking is probably ok, since its in the setup/teardown
paths, and doesn't affect the running paths, but it certainly is going to
add some extra overhead. Also, worth noting is that the epmuex was
recently added to the ep_ctl add operations in the initial path loop
detection code using the argument that it was not on a critical path.
Another thing to note here, is the length of epoll chains that is allowed.
Currently, eventpoll.c defines:
/* Maximum number of nesting allowed inside epoll sets */
#define EP_MAX_NESTS 4
This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS
+ 1). However, this limit is currently only enforced during the loop
check detection code, and only when the epoll file descriptors are added
in a certain order. Thus, this limit is currently easily bypassed. The
newly added check for wakeup paths, stricly limits the wakeup paths to a
length of 5, regardless of the order in which ep's are linked together.
Thus, a side-effect of the new code is a more consistent enforcement of
the graph depth.
Thus far, I've tested this, using the sample programs previously
mentioned, which now either return quickly or return -EINVAL. I've also
testing using the piptest.c epoll tester, which showed no difference in
performance. I've also created a number of different epoll networks and
tested that they behave as expectded.
I believe this solves the original diabolical test cases, while still
preserving the sane epoll nesting.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Cc: Nelson Elhage <nelhage@ksplice.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
commit 971316f0503a5c50633d07b83b6db2f15a3a5b00 upstream.
signalfd_cleanup() ensures that ->signalfd_wqh is not used, but
this is not enough. eppoll_entry->whead still points to the memory
we are going to free, ep_unregister_pollwait()->remove_wait_queue()
is obviously unsafe.
Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL,
change ep_unregister_pollwait() to check pwq->whead != NULL under
rcu_read_lock() before remove_wait_queue(). We add the new helper,
ep_remove_wait_queue(), for this.
This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because
->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand.
ep_unregister_pollwait()->remove_wait_queue() can play with already
freed and potentially reused ->sighand, but this is fine. This memory
must have the valid ->signalfd_wqh until rcu_read_unlock().
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
commit abe9a6d57b4544ac208401f9c0a4262814db2be4 upstream.
server_scope would never be freed if nfs4_check_cl_exchange_flags() returned
non-zero
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
