[ Upstream commit 98cf21c61a7f5419d82f847c4d77bf6e96a76f5f ]
Fix B-tree corruption when a new record is inserted at position 0 in the
node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is
called to update the parent index node (if exists) and it is passed
hfs_find_data with a search_key containing a newly inserted key instead
of the key to be updated. This results in an inconsistent index node.
The bug reproduces on my machine after an extents overflow record for
the catalog file (CNID=4) is inserted into the extents overflow B-tree.
Because of a low (reserved) value of CNID=4, it has to become the first
record in the first leaf node.
The resulting first leaf node is correct:
| key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... |
But the parent index key0 still contains the previous key CNID=123:
| key0.CNID=123 | ... |
A change in hfs_brec_insert() makes hfs_brec_update_parent() work
correctly by preventing it from getting fd->record=-1 value from
__hfs_brec_find().
Along the way, I removed duplicate code with unification of the if
condition. The resulting code is equivalent to the original code
because node is never 0.
Also hfs_brec_update_parent() will now return an error after getting a
negative fd->record value. However, the return value of
hfs_brec_update_parent() is not checked anywhere in the file and I'm
leaving it unchanged by this patch. brec.c lacks error checking after
some other calls too, but this issue is of less importance than the one
being fixed by this patch.
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Anton Altaparmakov <aia21@cam.ac.uk>
Cc: <stable@vger.kernel.org>
[ Upstream commit ab676b7d6fbf4b294bf198fb27ade5b0e865c7ce ]
As pointed by recent post[1] on exploiting DRAM physical imperfection,
/proc/PID/pagemap exposes sensitive information which can be used to do
attacks.
This disallows anybody without CAP_SYS_ADMIN to read the pagemap.
[1] http://googleprojectzero.blogspot.com/2015/03/exploiting-dram-rowhammer-bug-to-gain.html
[ Eventually we might want to do anything more finegrained, but for now
this is the simple model. - Linus ]
Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Mark Seaborn <mseaborn@chromium.org>
Cc: stable@vger.kernel.org
[ Upstream commit 283ee1482f349d6c0c09dfb725db5880afc56813 ]
According to a report from Yuxuan Shui, nilfs2 in kernel 3.19 got stuck
during recovery at mount time. The code path that caused the deadlock was
as follows:
nilfs_fill_super()
load_nilfs()
nilfs_salvage_orphan_logs()
* Do roll-forwarding, attach segment constructor for recovery,
and kick it.
nilfs_segctor_thread()
nilfs_segctor_thread_construct()
* A lock is held with nilfs_transaction_lock()
nilfs_segctor_do_construct()
nilfs_segctor_drop_written_files()
iput()
iput_final()
write_inode_now()
writeback_single_inode()
__writeback_single_inode()
do_writepages()
nilfs_writepage()
nilfs_construct_dsync_segment()
nilfs_transaction_lock() --> deadlock
This can happen if commit 7ef3ff2fea8b ("nilfs2: fix deadlock of segment
constructor over I_SYNC flag") is applied and roll-forward recovery was
performed at mount time. The roll-forward recovery can happen if datasync
write is done and the file system crashes immediately after that. For
instance, we can reproduce the issue with the following steps:
< nilfs2 is mounted on /nilfs (device: /dev/sdb1) >
# dd if=/dev/zero of=/nilfs/test bs=4k count=1 && sync
# dd if=/dev/zero of=/nilfs/test conv=notrunc oflag=dsync bs=4k
count=1 && reboot -nfh
< the system will immediately reboot >
# mount -t nilfs2 /dev/sdb1 /nilfs
The deadlock occurs because iput() can run segment constructor through
writeback_single_inode() if MS_ACTIVE flag is not set on sb->s_flags. The
above commit changed segment constructor so that it calls iput()
asynchronously for inodes with i_nlink == 0, but that change was
imperfect.
This fixes the another deadlock by deferring iput() in segment constructor
even for the case that mount is not finished, that is, for the case that
MS_ACTIVE flag is not set.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reported-by: Yuxuan Shui <yshuiv7@gmail.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
[ Upstream commit 0d2783626a53d4c922f82d51fa675cb5d13f0d36 ]
fuse_try_move_page() is not prepared for replacing pages that have already
been read.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
[ Upstream commit aa991b3b267e24f578bac7b09cc57579b660304b ]
Regular pipe buffers' ->steal method (generic_pipe_buf_steal()) doesn't set
PG_uptodate.
Don't warn on this condition, just set the uptodate flag.
commit 278702074ff77b1a3fa2061267997095959f5e2c upstream.
Fixes: e01580bf9e ("gfs2: use generic posix ACL infrastructure")
Reported-by: Eric Meddaugh <etmsys@rit.edu>
Tested-by: Eric Meddaugh <etmsys@rit.edu>
Signed-off-by: Andrew Elble <aweits@rit.edu>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 7c0af9ffb7bb4e5355470fa60b3eb711ddf226fa upstream.
put_rpccred() can sleep.
Fixes: 8f649c3762547 ("NFSv4: Fix the locking in nfs_inode_reclaim_delegation()")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 6c441c254eea2354d686be7f5544bcd79fb6a61f upstream.
If we're traversing a directory which contains a submounted filesystem,
or one that has a referral, the NFS server that is processing the READDIR
request will often return information for the underlying (mounted-on)
directory. It may, or may not, also return filehandle information.
If this happens, and the lookup in nfs_prime_dcache() returns the
dentry for the submounted directory, the filehandle comparison will
fail, and we call d_invalidate(). Post-commit 8ed936b5671bf
("vfs: Lazily remove mounts on unlinked files and directories."), this
means the entire subtree is unmounted.
The following minimal patch addresses this problem by punting on
the invalidation if there is a submount.
Kudos to Neil Brown <neilb@suse.de> for having tracked down this
issue (see link).
Reported-by: Nix <nix@esperi.org.uk>
Link: http://lkml.kernel.org/r/87iofju9ht.fsf@spindle.srvr.nix
commit 6d65261a09adaa374c05de807f73a144d783669e upstream.
eCryptfs can't be aware of what to expect when after passing an
arbitrary ioctl command through to the lower filesystem. The ioctl
command may trigger an action in the lower filesystem that is
incompatible with eCryptfs.
One specific example is when one attempts to use the Btrfs clone
ioctl command when the source file is in the Btrfs filesystem that
eCryptfs is mounted on top of and the destination fd is from a new file
created in the eCryptfs mount. The ioctl syscall incorrectly returns
success because the command is passed down to Btrfs which thinks that it
was able to do the clone operation. However, the result is an empty
eCryptfs file.
This patch allows the trim, {g,s}etflags, and {g,s}etversion ioctl
commands through and then copies up the inode metadata from the lower
inode to the eCryptfs inode to catch any changes made to the lower
inode's metadata. Those five ioctl commands are mostly common across all
filesystems but the whitelist may need to be further pruned in the
future.
https://bugzilla.kernel.org/show_bug.cgi?id=93691
https://launchpad.net/bugs/1305335
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Cc: Rocko <rockorequin@hotmail.com>
Cc: Colin Ian King <colin.king@canonical.com>
commit c876486be17aeefe0da569f3d111cbd8de6f675d upstream.
commit 2d4a532d385f ("nfsd: ensure that clp->cl_revoked list is
protected by clp->cl_lock") removed the use of the reaplist to
clean out clp->cl_revoked. It failed to change list_entry() to
walk clp->cl_revoked.next instead of reaplist.next
Fixes: 2d4a532d385f ("nfsd: ensure that clp->cl_revoked list is protected by clp->cl_lock")
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 957ed60b53b519064a54988c4e31e0087e47d091 upstream.
Each inode of nilfs2 stores a root node of a b-tree, and it turned out to
have a memory overrun issue:
Each b-tree node of nilfs2 stores a set of key-value pairs and the number
of them (in "bn_nchildren" member of nilfs_btree_node struct), as well as
a few other "bn_*" members.
Since the value of "bn_nchildren" is used for operations on the key-values
within the b-tree node, it can cause memory access overrun if a large
number is incorrectly set to "bn_nchildren".
For instance, nilfs_btree_node_lookup() function determines the range of
binary search with it, and too large "bn_nchildren" leads
nilfs_btree_node_get_key() in that function to overrun.
As for intermediate b-tree nodes, this is prevented by a sanity check
performed when each node is read from a drive, however, no sanity check
has been done for root nodes stored in inodes.
This patch fixes the issue by adding missing sanity check against b-tree
root nodes so that it's called when on-memory inodes are read from ifile,
inode metadata file.
commit 7e0e953bb0cf649f93277ac8fb67ecbb7f7b04a9 upstream.
use_pde()/unuse_pde() in ->follow_link()/->put_link() resp.
commit 0db59e59299f0b67450c5db21f7f316c8fb04e84 upstream.
As it is, we have debugfs_remove() racing with symlink traversals.
Supply ->evict_inode() and do freeing there - inode will remain
pinned until we are done with the symlink body.
And rip the idiocy with checking if dentry is positive right after
we'd verified debugfs_positive(), which is a stronger check...
commit 0a280962dc6e117e0e4baa668453f753579265d9 upstream.
X-Coverup: just ask spender
commit dd9ef135e3542ffc621c4eb7f0091870ec7a1504 upstream.
Improper arithmetics when calculting the address of the extended ref could
lead to an out of bounds memory read and kernel panic.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Reviewed-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Mason <clm@fb.com>
commit 3a8b36f378060d20062a0918e99fae39ff077bf0 upstream.
When using the fast file fsync code path we can miss the fact that new
writes happened since the last file fsync and therefore return without
waiting for the IO to finish and write the new extents to the fsync log.
Here's an example scenario where the fsync will miss the fact that new
file data exists that wasn't yet durably persisted:
1. fs_info->last_trans_committed == N - 1 and current transaction is
transaction N (fs_info->generation == N);
2. do a buffered write;
3. fsync our inode, this clears our inode's full sync flag, starts
an ordered extent and waits for it to complete - when it completes
at btrfs_finish_ordered_io(), the inode's last_trans is set to the
value N (via btrfs_update_inode_fallback -> btrfs_update_inode ->
btrfs_set_inode_last_trans);
4. transaction N is committed, so fs_info->last_trans_committed is now
set to the value N and fs_info->generation remains with the value N;
5. do another buffered write, when this happens btrfs_file_write_iter
sets our inode's last_trans to the value N + 1 (that is
fs_info->generation + 1 == N + 1);
6. transaction N + 1 is started and fs_info->generation now has the
value N + 1;
7. transaction N + 1 is committed, so fs_info->last_trans_committed
is set to the value N + 1;
8. fsync our inode - because it doesn't have the full sync flag set,
we only start the ordered extent, we don't wait for it to complete
(only in a later phase) therefore its last_trans field has the
value N + 1 set previously by btrfs_file_write_iter(), and so we
have:
inode->last_trans <= fs_info->last_trans_committed
(N + 1) (N + 1)
Which made us not log the last buffered write and exit the fsync
handler immediately, returning success (0) to user space and resulting
in data loss after a crash.
This can actually be triggered deterministically and the following excerpt
from a testcase I made for xfstests triggers the issue. It moves a dummy
file across directories and then fsyncs the old parent directory - this
is just to trigger a transaction commit, so moving files around isn't
directly related to the issue but it was chosen because running 'sync' for
example does more than just committing the current transaction, as it
flushes/waits for all file data to be persisted. The issue can also happen
at random periods, since the transaction kthread periodicaly commits the
current transaction (about every 30 seconds by default).
The body of the test is:
_scratch_mkfs >> $seqres.full 2>&1
_init_flakey
_mount_flakey
# Create our main test file 'foo', the one we check for data loss.
# By doing an fsync against our file, it makes btrfs clear the 'needs_full_sync'
# bit from its flags (btrfs inode specific flags).
$XFS_IO_PROG -f -c "pwrite -S 0xaa 0 8K" \
-c "fsync" $SCRATCH_MNT/foo | _filter_xfs_io
# Now create one other file and 2 directories. We will move this second file
# from one directory to the other later because it forces btrfs to commit its
# currently open transaction if we fsync the old parent directory. This is
# necessary to trigger the data loss bug that affected btrfs.
mkdir $SCRATCH_MNT/testdir_1
touch $SCRATCH_MNT/testdir_1/bar
mkdir $SCRATCH_MNT/testdir_2
# Make sure everything is durably persisted.
sync
# Write more 8Kb of data to our file.
$XFS_IO_PROG -c "pwrite -S 0xbb 8K 8K" $SCRATCH_MNT/foo | _filter_xfs_io
# Move our 'bar' file into a new directory.
mv $SCRATCH_MNT/testdir_1/bar $SCRATCH_MNT/testdir_2/bar
# Fsync our first directory. Because it had a file moved into some other
# directory, this made btrfs commit the currently open transaction. This is
# a condition necessary to trigger the data loss bug.
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/testdir_1
# Now fsync our main test file. If the fsync succeeds, we expect the 8Kb of
# data we wrote previously to be persisted and available if a crash happens.
# This did not happen with btrfs, because of the transaction commit that
# happened when we fsynced the parent directory.
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foo
# Simulate a crash/power loss.
_load_flakey_table $FLAKEY_DROP_WRITES
_unmount_flakey
_load_flakey_table $FLAKEY_ALLOW_WRITES
_mount_flakey
# Now check that all data we wrote before are available.
echo "File content after log replay:"
od -t x1 $SCRATCH_MNT/foo
status=0
exit
The expected golden output for the test, which is what we get with this
fix applied (or when running against ext3/4 and xfs), is:
wrote 8192/8192 bytes at offset 0
XXX Bytes, X ops; XX:XX:XX.X (XXX YYY/sec and XXX ops/sec)
wrote 8192/8192 bytes at offset 8192
0000000 aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa aa
0020000 bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb
0040000
Without this fix applied, the output shows the test file does not have
the second 8Kb extent that we successfully fsynced:
0020000
So fix this by skipping the fsync only if we're doing a full sync and
if the inode's last_trans is <= fs_info->last_trans_committed, or if
the inode is already in the log. Also remove setting the inode's
last_trans in btrfs_file_write_iter since it's useless/unreliable.
Also because btrfs_file_write_iter no longer sets inode->last_trans to
fs_info->generation + 1, don't set last_trans to 0 if we bail out and don't
bail out if last_trans is 0, otherwise something as simple as the following
example wouldn't log the second write on the last fsync:
1. write to file
2. fsync file
3. fsync file
|--> btrfs_inode_in_log() returns true and it set last_trans to 0
4. write to file
|--> btrfs_file_write_iter() no longers sets last_trans, so it
remained with a value of 0
5. fsync
|--> inode->last_trans == 0, so it bails out without logging the
second write
A test case for xfstests will be sent soon.
Signed-off-by: Filipe Manana <fdmanana@suse.com>
commit 1932b7be973b554ffe20a5bba6ffaed6fa995cdc upstream.
A block-local variable stores error code but btrfs_get_blocks_direct may
not return it in the end as there's a ret defined in the function scope.
Fixes: d187663ef24c ("Btrfs: lock extents as we map them in DIO")
Signed-off-by: David Sterba <dsterba@suse.cz>
commit 4d884fceaa2c838abb598778813e93f6d9fea723 upstream.
We can have multiple fsync operations against the same file during the
same transaction and they can collect the same ordered extents while they
don't complete (still accessible from the inode's ordered tree). If this
happens, those ordered extents will never get their reference counts
decremented to 0, leading to memory leaks and inode leaks (an iput for an
ordered extent's inode is scheduled only when the ordered extent's refcount
drops to 0). The following sequence diagram explains this race:
CPU 1 CPU 2
btrfs_sync_file()
btrfs_sync_file()
mutex_lock(inode->i_mutex)
btrfs_log_inode()
btrfs_get_logged_extents()
--> collects ordered extent X
--> increments ordered
extent X's refcount
btrfs_submit_logged_extents()
mutex_unlock(inode->i_mutex)
btrfs_sync_log()
btrfs_wait_logged_extents()
--> list_del_init(&ordered->log_list)
btrfs_log_inode()
--> Adds ordered extent X
to logged_list because
at this point:
list_empty(&ordered->log_list)
&& test_bit(BTRFS_ORDERED_LOGGED,
&ordered->flags) == 0
--> Increments ordered extent
X's refcount
--> check if ordered extent's io is
finished or not, start it if
necessary and wait for it to finish
--> sets bit BTRFS_ORDERED_LOGGED
on ordered extent X's flags
and adds it to trans->ordered
btrfs_sync_log() finishes
btrfs_log_inode() finishes
btrfs_sync_file() finishes
btrfs_sync_log()
--> Sees ordered extent X has the
bit BTRFS_ORDERED_LOGGED set in
its flags
--> X's refcount is untouched
btrfs_commit_transaction()
--> called by transaction kthread for e.g.
btrfs_wait_pending_ordered()
--> waits for ordered extent X to
complete
--> decrements ordered extent X's
refcount by 1 only, corresponding
to the increment done by the fsync
task ran by CPU 1
In the scenario of the above diagram, after the transaction commit,
the ordered extent will remain with a refcount of 1 forever, leaking
the ordered extent structure and preventing the i_count of its inode
from ever decreasing to 0, since the delayed iput is scheduled only
when the ordered extent's refcount drops to 0, preventing the inode
from ever being evicted by the VFS.
Fix this by using the flag BTRFS_ORDERED_LOGGED differently. Use it to
mean that an ordered extent is already being processed by an fsync call,
which will attach it to the current transaction, preventing it from being
collected by subsequent fsync operations against the same inode.
This race was introduced with the following change (added in 3.19 and
backported to stable 3.18 and 3.17):
Btrfs: make sure logged extents complete in the current transaction V3
commit 50d9aa99bd35c77200e0e3dd7a72274f8304701f
I ran into this issue while running xfstests/generic/113 in a loop, which
failed about 1 out of 10 runs with the following warning in dmesg:
[ 2612.440038] WARNING: CPU: 4 PID: 22057 at fs/btrfs/disk-io.c:3558 free_fs_root+0x36/0x133 [btrfs]()
[ 2612.442810] Modules linked in: btrfs crc32c_generic xor raid6_pq nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc loop processor parport_pc parport psmouse therma
l_sys i2c_piix4 serio_raw pcspkr evdev microcode button i2c_core ext4 crc16 jbd2 mbcache sd_mod sg sr_mod cdrom virtio_scsi ata_generic virtio_pci ata_piix virtio_ring libata virtio flo
ppy e1000 scsi_mod [last unloaded: btrfs]
[ 2612.452711] CPU: 4 PID: 22057 Comm: umount Tainted: G W 3.19.0-rc5-btrfs-next-4+ #1
[ 2612.454921] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014
[ 2612.457709] 0000000000000009 ffff8801342c3c78 ffffffff8142425e ffff88023ec8f2d8
[ 2612.459829] 0000000000000000 ffff8801342c3cb8 ffffffff81045308 ffff880046460000
[ 2612.461564] ffffffffa036da56 ffff88003d07b000 ffff880046460000 ffff880046460068
[ 2612.463163] Call Trace:
[ 2612.463719] [<ffffffff8142425e>] dump_stack+0x4c/0x65
[ 2612.464789] [<ffffffff81045308>] warn_slowpath_common+0xa1/0xbb
[ 2612.466026] [<ffffffffa036da56>] ? free_fs_root+0x36/0x133 [btrfs]
[ 2612.467247] [<ffffffff810453c5>] warn_slowpath_null+0x1a/0x1c
[ 2612.468416] [<ffffffffa036da56>] free_fs_root+0x36/0x133 [btrfs]
[ 2612.469625] [<ffffffffa036f2a7>] btrfs_drop_and_free_fs_root+0x93/0x9b [btrfs]
[ 2612.471251] [<ffffffffa036f353>] btrfs_free_fs_roots+0xa4/0xd6 [btrfs]
[ 2612.472536] [<ffffffff8142612e>] ? wait_for_completion+0x24/0x26
[ 2612.473742] [<ffffffffa0370bbc>] close_ctree+0x1f3/0x33c [btrfs]
[ 2612.475477] [<ffffffff81059d1d>] ? destroy_workqueue+0x148/0x1ba
[ 2612.476695] [<ffffffffa034e3da>] btrfs_put_super+0x19/0x1b [btrfs]
[ 2612.477911] [<ffffffff81153e53>] generic_shutdown_super+0x73/0xef
[ 2612.479106] [<ffffffff811540e2>] kill_anon_super+0x13/0x1e
[ 2612.480226] [<ffffffffa034e1e3>] btrfs_kill_super+0x17/0x23 [btrfs]
[ 2612.481471] [<ffffffff81154307>] deactivate_locked_super+0x3b/0x50
[ 2612.482686] [<ffffffff811547a7>] deactivate_super+0x3f/0x43
[ 2612.483791] [<ffffffff8116b3ed>] cleanup_mnt+0x59/0x78
[ 2612.484842] [<ffffffff8116b44c>] __cleanup_mnt+0x12/0x14
[ 2612.485900] [<ffffffff8105d019>] task_work_run+0x8f/0xbc
[ 2612.486960] [<ffffffff810028d8>] do_notify_resume+0x5a/0x6b
[ 2612.488083] [<ffffffff81236e5b>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 2612.489333] [<ffffffff8142a17f>] int_signal+0x12/0x17
[ 2612.490353] ---[ end trace 54a960a6bdcb8d93 ]---
[ 2612.557253] VFS: Busy inodes after unmount of sdb. Self-destruct in 5 seconds. Have a nice day...
Kmemleak confirmed the ordered extent leak (and btrfs inode specific
structures such as delayed nodes):
$ cat /sys/kernel/debug/kmemleak
unreferenced object 0xffff880154290db0 (size 576):
comm "btrfsck", pid 21980, jiffies 4295542503 (age 1273.412s)
hex dump (first 32 bytes):
01 40 00 00 01 00 00 00 b0 1d f1 4e 01 88 ff ff .@.........N....
00 00 00 00 00 00 00 00 c8 0d 29 54 01 88 ff ff ..........)T....
backtrace:
[<ffffffff8141d74d>] kmemleak_update_trace+0x4c/0x6a
[<ffffffff8122f2c0>] radix_tree_node_alloc+0x6d/0x83
[<ffffffff8122fb26>] __radix_tree_create+0x109/0x190
[<ffffffff8122fbdd>] radix_tree_insert+0x30/0xac
[<ffffffffa03b9bde>] btrfs_get_or_create_delayed_node+0x130/0x187 [btrfs]
[<ffffffffa03bb82d>] btrfs_delayed_delete_inode_ref+0x32/0xac [btrfs]
[<ffffffffa0379dae>] __btrfs_unlink_inode+0xee/0x288 [btrfs]
[<ffffffffa037c715>] btrfs_unlink_inode+0x1e/0x40 [btrfs]
[<ffffffffa037c797>] btrfs_unlink+0x60/0x9b [btrfs]
[<ffffffff8115d7f0>] vfs_unlink+0x9c/0xed
[<ffffffff8115f5de>] do_unlinkat+0x12c/0x1fa
[<ffffffff811601a7>] SyS_unlinkat+0x29/0x2b
[<ffffffff81429e92>] system_call_fastpath+0x12/0x17
[<ffffffffffffffff>] 0xffffffffffffffff
unreferenced object 0xffff88014ef11db0 (size 576):
comm "rm", pid 22009, jiffies 4295542593 (age 1273.052s)
02 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 c8 1d f1 4e 01 88 ff ff ...........N....
backtrace:
unreferenced object 0xffff8800336feda8 (size 584):
comm "aio-stress", pid 22031, jiffies 4295543006 (age 1271.400s)
00 40 3e 00 00 00 00 00 00 00 8f 42 00 00 00 00 .@>........B....
00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 ................
backtrace:
[<ffffffff8114eb34>] create_object+0x172/0x29a
[<ffffffff8141d790>] kmemleak_alloc+0x25/0x41
[<ffffffff81141ae6>] kmemleak_alloc_recursive.constprop.52+0x16/0x18
[<ffffffff81145288>] kmem_cache_alloc+0xf7/0x198
[<ffffffffa0389243>] __btrfs_add_ordered_extent+0x43/0x309 [btrfs]
[<ffffffffa038968b>] btrfs_add_ordered_extent_dio+0x12/0x14 [btrfs]
[<ffffffffa03810e2>] btrfs_get_blocks_direct+0x3ef/0x571 [btrfs]
[<ffffffff81181349>] do_blockdev_direct_IO+0x62a/0xb47
[<ffffffff8118189a>] __blockdev_direct_IO+0x34/0x36
[<ffffffffa03776e5>] btrfs_direct_IO+0x16a/0x1e8 [btrfs]
[<ffffffff81100373>] generic_file_direct_write+0xb8/0x12d
[<ffffffffa038615c>] btrfs_file_write_iter+0x24b/0x42f [btrfs]
[<ffffffff8118bb0d>] aio_run_iocb+0x2b7/0x32e
[<ffffffff8118c99a>] do_io_submit+0x26e/0x2ff
[<ffffffff8118ca3b>] SyS_io_submit+0x10/0x12
commit b10a08194c2b615955dfab2300331a90ae9344c7 upstream.
Currently maximum space limit quota format supports is in blocks however
since we store space limits in bytes, this is somewhat confusing. So
store the maximum limit in bytes as well. Also rename the field to match
the new unit and related inode field to match the new naming scheme.
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream.
The issue is that the stack for processes is not properly randomized on
64 bit architectures due to an integer overflow.
The affected function is randomize_stack_top() in file
"fs/binfmt_elf.c":
static unsigned long randomize_stack_top(unsigned long stack_top)
unsigned int random_variable = 0;
if ((current->flags & PF_RANDOMIZE) &&
!(current->personality & ADDR_NO_RANDOMIZE)) {
random_variable = get_random_int() & STACK_RND_MASK;
random_variable <<= PAGE_SHIFT;
return PAGE_ALIGN(stack_top) + random_variable;
return PAGE_ALIGN(stack_top) - random_variable;
Note that, it declares the "random_variable" variable as "unsigned int".
Since the result of the shifting operation between STACK_RND_MASK (which
is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64):
then the two leftmost bits are dropped when storing the result in the
"random_variable". This variable shall be at least 34 bits long to hold
the (22+12) result.
These two dropped bits have an impact on the entropy of process stack.
Concretely, the total stack entropy is reduced by four: from 2^28 to
2^30 (One fourth of expected entropy).
This patch restores back the entropy by correcting the types involved
in the operations in the functions randomize_stack_top() and
stack_maxrandom_size().
The successful fix can be tested with:
$ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done
7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack]
7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack]
7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack]
7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack]
Once corrected, the leading bytes should be between 7ffc and 7fff,
rather than always being 7fff.
Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es>
Signed-off-by: Ismael Ripoll <iripoll@upv.es>
[ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ]
Fixes: CVE-2015-1593
Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net
commit 1a4bcf470c886b955adf36486f4c86f2441d85cb upstream.
We have a scenario where after the fsync log replay we can lose file data
that had been previously fsync'ed if we added an hard link for our inode
and after that we sync'ed the fsync log (for example by fsync'ing some
other file or directory).
This is because when adding an hard link we updated the inode item in the
log tree with an i_size value of 0. At that point the new inode item was
in memory only and a subsequent fsync log replay would not make us lose
the file data. However if after adding the hard link we sync the log tree
to disk, by fsync'ing some other file or directory for example, we ended
up losing the file data after log replay, because the inode item in the
persisted log tree had an an i_size of zero.
This is easy to reproduce, and the following excerpt from my test for
xfstests shows this:
_init_flakey
_mount_flakey
# Create one file with data and fsync it.
# This made the btrfs fsync log persist the data and the inode metadata with
# a correct inode->i_size (4096 bytes).
$XFS_IO_PROG -f -c "pwrite -S 0xaa -b 4K 0 4K" -c "fsync" \
# Now add one hard link to our file. This made the btrfs code update the fsync
# log, in memory only, with an inode metadata having a size of 0.
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link
# Now force persistence of the fsync log to disk, for example, by fsyncing some
# other file.
touch $SCRATCH_MNT/bar
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/bar
# Before a power loss or crash, we could read the 4Kb of data from our file as
# expected.
echo "File content before:"
_unmount_flakey
_mount_flakey
# After the fsync log replay, because the fsync log had a value of 0 for our
# inode's i_size, we couldn't read anymore the 4Kb of data that we previously
# wrote and fsync'ed. The size of the file became 0 after the fsync log replay.
echo "File content after:"
Another alternative test, that doesn't need to fsync an inode in the same
transaction it was created, is:
_init_flakey
_mount_flakey
# Create our test file with some data.
$XFS_IO_PROG -f -c "pwrite -S 0xaa -b 8K 0 8K" \
# Make sure the file is durably persisted.
sync
# Append some data to our file, to increase its size.
$XFS_IO_PROG -f -c "pwrite -S 0xcc -b 4K 8K 4K" \
# Fsync the file, so from this point on if a crash/power failure happens, our
# new data is guaranteed to be there next time the fs is mounted.
# Add one hard link to our file. This made btrfs write into the in memory fsync
# log a special inode with generation 0 and an i_size of 0 too. Note that this
# didn't update the inode in the fsync log on disk.
# Now make sure the in memory fsync log is durably persisted.
# Creating and fsync'ing another file will do it.
# As expected, before the crash/power failure, we should be able to read the
# 12Kb of file data.
_unmount_flakey
_mount_flakey
# After mounting the fs again, the fsync log was replayed.
# The btrfs fsync log replay code didn't update the i_size of the persisted
# inode because the inode item in the log had a special generation with a
# value of 0 (and it couldn't know the correct i_size, since that inode item
# had a 0 i_size too). This made the last 4Kb of file data inaccessible and
# effectively lost.
This isn't a new issue/regression. This problem has been around since the
log tree code was added in 2008:
Btrfs: Add a write ahead tree log to optimize synchronous operations
(commit e02119d5a7b4396c5a872582fddc8bd6d305a70a)
Test cases for xfstests follow soon.
commit 381cf6587f8a8a8e981bc0c1aaaa8859b51dc756 upstream.
If btrfs_find_item is called with NULL path it allocates one locally but
does not free it. Affected paths are inserting an orphan item for a file
and for a subvol root.
Move the path allocation to the callers.
Fixes: 3f870c289900 ("btrfs: expand btrfs_find_item() to include find_orphan_item functionality")
commit 5efa0490cc94aee06cd8d282683e22a8ce0a0026 upstream.
This has been confusing people for too long, the message is really just
informative.
commit 164c24063a3eadee11b46575c5482b2f1417be49 upstream.
sm->offset maybe wrong but magic maybe right, the offset do not have CRC.
Badness at c00c7580 [verbose debug info unavailable]
NIP: c00c7580 LR: c00c718c CTR: 00000014
REGS: df07bb40 TRAP: 0700 Not tainted (2.6.34.13-WR4.3.0.0_standard)
MSR: 00029000 <EE,ME,CE> CR: 22084f84 XER: 00000000
TASK = df84d6e0[908] 'mount' THREAD: df07a000
GPR00: 00000001 df07bbf0 df84d6e0 00000000 00000001 00000000 df07bb58 00000041
GPR08: 00000041 c0638860 00000000 00000010 22084f88 100636c8 df814ff8 00000000
GPR16: df84d6e0 dfa558cc c05adb90 00000048 c0452d30 00000000 000240d0 000040d0
GPR24: 00000014 c05ae734 c05be2e0 00000000 00000001 00000000 00000000 c05ae730
NIP [c00c7580] __alloc_pages_nodemask+0x4d0/0x638
LR [c00c718c] __alloc_pages_nodemask+0xdc/0x638
Call Trace:
[df07bbf0] [c00c718c] __alloc_pages_nodemask+0xdc/0x638 (unreliable)
[df07bc90] [c00c7708] __get_free_pages+0x20/0x48
[df07bca0] [c00f4a40] __kmalloc+0x15c/0x1ec
[df07bcd0] [c01fc880] jffs2_scan_medium+0xa58/0x14d0
[df07bd70] [c01ff38c] jffs2_do_mount_fs+0x1f4/0x6b4
[df07bdb0] [c020144c] jffs2_do_fill_super+0xa8/0x260
[df07bdd0] [c020230c] jffs2_fill_super+0x104/0x184
[df07be00] [c0335814] get_sb_mtd_aux+0x9c/0xec
[df07be20] [c033596c] get_sb_mtd+0x84/0x1e8
[df07be60] [c0201ed0] jffs2_get_sb+0x1c/0x2c
[df07be70] [c0103898] vfs_kern_mount+0x78/0x1e8
[df07bea0] [c0103a58] do_kern_mount+0x40/0x100
[df07bec0] [c011fe90] do_mount+0x240/0x890
[df07bf10] [c0120570] sys_mount+0x90/0xd8
[df07bf40] [c00110d8] ret_from_syscall+0x0/0x4
=== Exception: c01 at 0xff61a34
LR = 0x100135f0
Instruction dump:
38800005 38600000 48010f41 4bfffe1c 4bfc2d15 4bfffe8c 72e90200 4082fc28
3d20c064 39298860 8809000d 68000001 <0f000000> 2f800000 419efc0c 38000001
mount: mounting /dev/mtdblock3 on /common failed: Input/output error
Signed-off-by: Chen Jie <chenjie6@huawei.com>
commit dfcc70a8c868fe03276fa59864149708fb41930b upstream.
For filesystems without separate project quota inode field in the
superblock we just reuse project quota file for group quotas (and vice
versa) if project quota file is allocated and we need group quota file.
When we reuse the file, quota structures on disk suddenly have wrong
type stored in d_flags though. Nobody really cares about this (although
structure type reported to userspace was wrong as well) except
that after commit 14bf61ffe6ac (quota: Switch ->get_dqblk() and
->set_dqblk() to use bytes as space units) assertion in
xfs_qm_scall_getquota() started to trigger on xfs/106 test (apparently I
was testing without XFS_DEBUG so I didn't notice when submitting the
above commit).
Fix the problem by properly resetting ddq->d_flags when running quotacheck
for a quota file.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 23b133bdc452aa441fcb9b82cbf6dd05cfd342d0 upstream.
Check length of extended attributes and allocation descriptors when
loading inodes from disk. Otherwise corrupted filesystems could confuse
the code and make the kernel oops.
Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no>
commit 79144954278d4bb5989f8b903adcac7a20ff2a5a upstream.
Store blocksize in a local variable in udf_fill_inode() since it is used
a lot of times.
commit d8ba1f971497c19cf80da1ea5391a46a5f9fbd41 upstream.
If the call to decode_rc_list() fails due to a memory allocation error,
then we need to truncate the array size to ensure that we only call
kfree() on those pointer that were allocated.
Reported-by: David Ramos <daramos@stanford.edu>
Fixes: 4aece6a19cf7f ("nfs41: cb_sequence xdr implementation")
commit ea7c38fef0b774a5dc16fb0ca5935f0ae8568176 upstream.
If we have to do a return-on-close in the delegreturn code, then
we must ensure that the inode and super block remain referenced.
Cc: Peng Tao <tao.peng@primarydata.com>
Reviewed-by: Peng Tao <tao.peng@primarydata.com>
commit 03a9a42a1a7e5b3e7919ddfacc1d1cc81882a955 upstream.
Fix an Oopsable condition when nsm_mon_unmon is called as part of the
namespace cleanup, which now apparently happens after the utsname
has been freed.
Link: http://lkml.kernel.org/r/20150125220604.090121ae@neptune.home
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
commit cb5d04bc39e914124e811ea55f3034d2379a5f6c upstream.
With pgio refactoring in v3.15, .init_read and .init_write can be
called with valid pgio->pg_lseg. file layout was fixed at that time
by commit c6194271f (pnfs: filelayout: support non page aligned
layouts). But the generic helper still needs to be fixed.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
commit f4086a3d789dbe18949862276d83b8f49fce6d2f upstream.
Commit 411a99adffb4f (nfs: clear_request_commit while holding i_lock)
assumes that the nfs_commit_info always points to the inode->i_lock.
For historical reasons, that is not the case for O_DIRECT writes.
Cc: Weston Andros Adamson <dros@primarydata.com>
Fixes: 411a99adffb4f ("nfs: clear_request_commit while holding i_lock")
commit 6ffa30d3f734d4f6b478081dfc09592021028f90 upstream.
Bruce reported seeing this warning pop when mounting using v4.1:
WARNING: CPU: 1 PID: 1121 at kernel/sched/core.c:7300 __might_sleep+0xbd/0xd0()
do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffff810ff58f>] prepare_to_wait+0x2f/0x90
Modules linked in: rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace sunrpc fscache ip6t_rpfilter ip6t_REJECT nf_reject_ipv6 xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw snd_hda_codec_generic snd_hda_intel snd_hda_controller snd_hda_codec snd_hwdep snd_pcm snd_timer ppdev joydev snd virtio_console virtio_balloon pcspkr serio_raw parport_pc parport pvpanic floppy soundcore i2c_piix4 virtio_blk virtio_net qxl drm_kms_helper ttm drm virtio_pci virtio_ring ata_generic virtio pata_acpi
CPU: 1 PID: 1121 Comm: nfsv4.1-svc Not tainted 3.19.0-rc4+ #25
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153950- 04/01/2014
0000000000000000 000000004e5e3f73 ffff8800b998fb48 ffffffff8186ac78
0000000000000000 ffff8800b998fba0 ffff8800b998fb88 ffffffff810ac9da
ffff8800b998fb68 ffffffff81c923e7 00000000000004d9 0000000000000000
Call Trace:
[<ffffffff8186ac78>] dump_stack+0x4c/0x65
[<ffffffff810ac9da>] warn_slowpath_common+0x8a/0xc0
[<ffffffff810aca65>] warn_slowpath_fmt+0x55/0x70
[<ffffffff810ff58f>] ? prepare_to_wait+0x2f/0x90
[<ffffffff810dd2ad>] __might_sleep+0xbd/0xd0
[<ffffffff8124c973>] kmem_cache_alloc_trace+0x243/0x430
[<ffffffff810d941e>] ? groups_alloc+0x3e/0x130
[<ffffffff810d941e>] groups_alloc+0x3e/0x130
[<ffffffffa0301b1e>] svcauth_unix_accept+0x16e/0x290 [sunrpc]
[<ffffffffa0300571>] svc_authenticate+0xe1/0xf0 [sunrpc]
[<ffffffffa02fc564>] svc_process_common+0x244/0x6a0 [sunrpc]
[<ffffffffa02fd044>] bc_svc_process+0x1c4/0x260 [sunrpc]
[<ffffffffa03d5478>] nfs41_callback_svc+0x128/0x1f0 [nfsv4]
[<ffffffff810ff970>] ? wait_woken+0xc0/0xc0
[<ffffffffa03d5350>] ? nfs4_callback_svc+0x60/0x60 [nfsv4]
[<ffffffff810d45bf>] kthread+0x11f/0x140
[<ffffffff810ea815>] ? local_clock+0x15/0x30
[<ffffffff810d44a0>] ? kthread_create_on_node+0x250/0x250
[<ffffffff81874bfc>] ret_from_fork+0x7c/0xb0
---[ end trace 675220a11e30f4f2 ]---
nfs41_callback_svc does most of its work while in TASK_INTERRUPTIBLE,
which is just wrong. Fix that by finishing the wait immediately if we've
found that the list has something on it.
Also, we don't expect this kthread to accept signals, so we should be
using a TASK_UNINTERRUPTIBLE sleep instead. That however, opens us up
hung task warnings from the watchdog, so have the schedule_timeout
wake up every 60s if there's no callback activity.
Reported-by: "J. Bruce Fields" <bfields@fieldses.org>
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
commit 05fbf357d94152171bc50f8a369390f1f16efd89 upstream.
Lockless access to pte in pagemap_pte_range() might race with page
migration and trigger BUG_ON(!PageLocked()) in migration_entry_to_page():
CPU A (pagemap) CPU B (migration)
lock_page()
try_to_unmap(page, TTU_MIGRATION...)
make_migration_entry()
set_pte_at()
<read *pte>
pte_to_pagemap_entry()
remove_migration_ptes()
unlock_page()
if(is_migration_entry())
BUG_ON(!PageLocked(page))
Also lockless read might be non-atomic if pte is larger than wordsize.
Other pte walkers (smaps, numa_maps, clear_refs) already lock ptes.
Fixes: 052fb0d635df ("proc: report file/anon bit in /proc/pid/pagemap")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 3443a3bca54588f43286b725d8648d33a38c86f1 upstream.
When the superblock is modified in a transaction, the commonly
modified fields are not actually copied to the superblock buffer to
avoid the buffer lock becoming a serialisation point. However, there
are some other operations that modify the superblock fields within
the transaction that don't directly log to the superblock but rely
on the changes to be applied during the transaction commit (to
minimise the buffer lock hold time).
When we do this, we fail to mark the buffer log item as being a
superblock buffer and that can lead to the buffer not being marked
with the corect type in the log and hence causing recovery issues.
Fix it by setting the type correctly, similar to xfs_mod_sb()...
Tested-by: Jan Kara <jack@suse.cz>
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
commit fe22d552b82d7cc7de1851233ae8bef579198637 upstream.
Conversion from local to extent format does not set the buffer type
correctly on the new extent buffer when a symlink data is moved out
of line.
Fix the symlink code and leave a comment in the generic bmap code
reminding us that the format-specific data copy needs to set the
destination buffer type appropriately.
commit f19b872b086711bb4b22c3a0f52f16aa920bcc61 upstream.
This leads to log recovery throwing errors like:
XFS (md0): Mounting V5 Filesystem
XFS (md0): Starting recovery (logdev: internal)
XFS (md0): Unknown buffer type 0!
XFS (md0): _xfs_buf_ioapply: no ops on block 0xaea8802/0x1
ffff8800ffc53800: 58 41 47 49 .....
Which is the AGI buffer magic number.
Ensure that we set the type appropriately in both unlink list
addition and removal.
commit 0d612fb570b71ea2e49554a770cff4c489018b2c upstream.
Jan Kara reported that log recovery was finding buffers with invalid
types in them. This should not happen, and indicates a bug in the
logging of buffers. To catch this, add asserts to the buffer
formatting code to ensure that the buffer type is in range when the
transaction is committed.
We don't set a type on buffers being marked stale - they are not
going to get replayed, the format item exists only for recovery to
be able to prevent replay of the buffer, so the type does not
matter. Hence that needs special casing here.
Reported-by: Jan Kara <jack@suse.cz>
commit 2d5b86e048780c5efa7f7d9708815555919e7b05 upstream.
As of v3.18, ext4 started rejecting a remount which changes the
journal_checksum option.
Prior to that, it was simply ignored; the problem here is that
if someone has this in their fstab for the root fs, now the box
fails to boot properly, because remount of root with the new options
will fail, and the box proceeds with a readonly root.
I think it is a little nicer behavior to accept the option, but
warn that it's being ignored, rather than failing the mount,
but that might be a subjective matter...
Reported-by: Cónräd <conradsand.arma@gmail.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit 7ef3ff2fea8bf5e4a21cef47ad87710a3d0fdb52 upstream.
Nilfs2 eventually hangs in a stress test with fsstress program. This
issue was caused by the following deadlock over I_SYNC flag between
nilfs_segctor_thread() and writeback_sb_inodes():
nilfs_segctor_unlock()
nilfs_dispose_list()
iput()
iput_final()
evict()
inode_wait_for_writeback() * wait for I_SYNC flag
* set I_SYNC flag on inode->i_state
do_writepages()
nilfs_writepages()
nilfs_segctor_sync()
* wait for completion of segment constructor
inode_sync_complete()
* clear I_SYNC flag after __writeback_single_inode() completed
writeback_sb_inodes() calls do_writepages() for dirty inodes after
setting I_SYNC flag on inode->i_state. do_writepages() in turn calls
nilfs_writepages(), which can run segment constructor and wait for its
completion. On the other hand, segment constructor calls iput(), which
can call evict() and wait for the I_SYNC flag on
inode_wait_for_writeback().
Since segment constructor doesn't know when I_SYNC will be set, it
cannot know whether iput() will block or not unless inode->i_nlink has a
non-zero count. We can prevent evict() from being called in iput() by
implementing sop->drop_inode(), but it's not preferable to leave inodes
with i_nlink == 0 for long periods because it even defers file
truncation and inode deallocation. So, this instead resolves the
deadlock by calling iput() asynchronously with a workqueue for inodes
with i_nlink == 0.
commit ca7df8e0bb2a5ec79691de8a1a4c0e611fe04e60 upstream.
Commit
c11f1df5003d534fd067f0168bfad7befffb3b5c
requires writers to wait for any pending oplock break handler to
complete before proceeding to write. This is done by waiting on bit
CIFS_INODE_PENDING_OPLOCK_BREAK in cifsFileInfo->flags. This bit is
cleared by the oplock break handler job queued on the workqueue once it
has completed handling the oplock break allowing writers to proceed with
writing to the file.
While testing, it was noticed that the filehandle could be closed while
there is a pending oplock break which results in the oplock break
handler on the cifsiod workqueue being cancelled before it has had a
chance to execute and clear the CIFS_INODE_PENDING_OPLOCK_BREAK bit.
Any subsequent attempt to write to this file hangs waiting for the
CIFS_INODE_PENDING_OPLOCK_BREAK bit to be cleared.
We fix this by ensuring that we also clear the bit
CIFS_INODE_PENDING_OPLOCK_BREAK when we remove the oplock break handler
from the workqueue.
The bug was found by Red Hat QA while testing using ltp's fsstress
command.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Acked-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Signed-off-by: Jeff Layton <jlayton@samba.org>
Signed-off-by: Steve French <steve.french@primarydata.com>
commit 14bf61ffe6ac54afcd1e888a4407fe16054483db upstream.
Currently ->get_dqblk() and ->set_dqblk() use struct fs_disk_quota which
tracks space limits and usage in 512-byte blocks. However VFS quotas
track usage in bytes (as some filesystems require that) and we need to
somehow pass this information. Upto now it wasn't a problem because we
didn't do any unit conversion (thus VFS quota routines happily stuck
number of bytes into d_bcount field of struct fd_disk_quota). Only if
you tried to use Q_XGETQUOTA or Q_XSETQLIM for VFS quotas (or Q_GETQUOTA
/ Q_SETQUOTA for XFS quotas), you got bogus results. Hardly anyone
tried this but reportedly some Samba users hit the problem in practice.
So when we want interfaces compatible we need to fix this.
We bite the bullet and define another quota structure used for passing
information from/to ->get_dqblk()/->set_dqblk. It's somewhat sad we have
to have more conversion routines in fs/quota/quota.c and another copying
of quota structure slows down getting of quota information by about 2%
but it seems cleaner than overloading e.g. units of d_bcount to bytes.
commit 3175e1dcec40fab1a444c010087f2068b6b04732 upstream.
If we start state recovery on a client that failed to initialise correctly,
then we are very likely to Oops.
Reported-by: "Mkrtchyan, Tigran" <tigran.mkrtchyan@desy.de>
Link: http://lkml.kernel.org/r/130621862.279655.1421851650684.JavaMail.zimbra@desy.de
commit ee8a1a8b160a87dc3a9c81a86796aa4db85ea815 upstream.
We only support swap file calling nfs_direct_IO. However, application
might be able to get to nfs_direct_IO if it toggles O_DIRECT flag
during IO and it can deadlock because we grab inode->i_mutex in
nfs_file_direct_write(). So return 0 for such case. Then the generic
layer will fall back to buffer IO.
commit b07ef35244424cbeda9844198607c7077099c82c upstream.
Commit 6fb1ca92a640 "udf: Fix race between write(2) and close(2)"
changed the condition when preallocation is released. The idea was that
we don't want to release the preallocation for an inode on close when
there are other writeable file descriptors for the inode. However the
condition was written in the opposite way so we released preallocation
only if there were other writeable file descriptors. Fix the problem by
changing the condition properly.
Fixes: 6fb1ca92a6409a9d5b0696447cd4997bc9aaf5a2
Reported-by: Fabian Frederick <fabf@skynet.be>
commit 378ff1a53b5724f3ac97b0aba3c9ecac072f6fcd upstream.
It really needs to check that src is non-directory *and* use
{un,}lock_two_nodirectories(). As it is, it's trivial to cause
double-lock (ioctl(fd, CIFS_IOC_COPYCHUNK_FILE, fd)) and if the
last argument is an fd of directory, we are asking for trouble
by violating the locking order - all directories go before all
non-directories. If the last argument is an fd of parent
directory, it has 50% odds of locking child before parent,
which will cause AB-BA deadlock if we race with unlink().
commit 06bed7d18c2c07b3e3eeadf4bd357f6e806618cc upstream.
This commit fixes a race whereby nlmclnt_init() first starts the lockd
daemon, and then calls nlm_bind_host() with the expectation that
nlmsvc_timeout has already been initialised. Unfortunately, there is no
no synchronisation between lockd() and lockd_up() to guarantee that this
is the case.
Fix is to move the initialisation of nlmsvc_timeout into lockd_create_svc
Fixes: 9a1b6bf818e74 ("LOCKD: Don't call utsname()->nodename...")
Cc: Bruce Fields <bfields@fieldses.org>
Cc: stable@vger.kernel.org # 3.10.x
commit 1fc0703af3143914a389bfa081c7acb09502ed5d upstream.
Currently, our trunking code will check for session trunking, but will
fail to detect client id trunking. This is a problem, because it means
that the client will fail to recognise that the two connections represent
shared state, even if they do not permit a shared session.
By removing the check for the server minor id, and only checking the
major id, we will end up doing the right thing in both cases: we close
down the new nfs_client and fall back to using the existing one.
Fixes: 05f4c350ee02e ("NFS: Discover NFSv4 server trunking when mounting")
Cc: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
commit 52d304eb4eaced9ad04b64ba7cd6ceb5153bbf18 upstream.
commit 0efaa7e82f02fe69c05ad28e905f31fc86e6f08e
locks: generic_delete_lease doesn't need a file_lock at all
moves the call to fl->fl_lmops->lm_change() to a place in the
code where fl might be a non-lease lock.
When that happens, fl_lmops is NULL and an Oops ensures.
So add an extra test to restore correct functioning.
Reported-by: Linda Walsh <suse@tlinx.org>
Link: https://bugzilla.suse.com/show_bug.cgi?id=912569
Fixes: 0efaa7e82f02fe69c05ad28e905f31fc86e6f08e
Signed-off-by: NeilBrown <neilb@suse.de>
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
