path: root/fs
2014-04-26jffs2: remove from wait queue after schedule()Li Zefan
commit 3ead9578443b66ddb3d50ed4f53af8a0c0298ec5 upstream. @wait is a local variable, so if we don't remove it from the wait queue list, later wake_up() may end up accessing invalid memory. This was spotted by eyes. Signed-off-by: Li Zefan <lizefan@huawei.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26jffs2: avoid soft-lockup in jffs2_reserve_space_gc()Li Zefan
commit 13b546d96207c131eeae15dc7b26c6e7d0f1cad7 upstream. We triggered soft-lockup under stress test on 2.6.34 kernel. BUG: soft lockup - CPU#1 stuck for 60009ms! [lockf2.test:14488] ... [<bf09a4d4>] (jffs2_do_reserve_space+0x420/0x440 [jffs2]) [<bf09a528>] (jffs2_reserve_space_gc+0x34/0x78 [jffs2]) [<bf0a1350>] (jffs2_garbage_collect_dnode.isra.3+0x264/0x478 [jffs2]) [<bf0a2078>] (jffs2_garbage_collect_pass+0x9c0/0xe4c [jffs2]) [<bf09a670>] (jffs2_reserve_space+0x104/0x2a8 [jffs2]) [<bf09dc48>] (jffs2_write_inode_range+0x5c/0x4d4 [jffs2]) [<bf097d8c>] (jffs2_write_end+0x198/0x2c0 [jffs2]) [<c00e00a4>] (generic_file_buffered_write+0x158/0x200) [<c00e14f4>] (__generic_file_aio_write+0x3a4/0x414) [<c00e15c0>] (generic_file_aio_write+0x5c/0xbc) [<c012334c>] (do_sync_write+0x98/0xd4) [<c0123a84>] (vfs_write+0xa8/0x150) [<c0123d74>] (sys_write+0x3c/0xc0)] Fix this by adding a cond_resched() in the while loop. [akpm@linux-foundation.org: don't initialize `ret'] Signed-off-by: Li Zefan <lizefan@huawei.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26jffs2: Fix crash due to truncation of csizeAjesh Kunhipurayil Vijayan
commit 41bf1a24c1001f4d0d41a78e1ac575d2f14789d7 upstream. mounting JFFS2 partition sometimes crashes with this call trace: [ 1322.240000] Kernel bug detected[#1]: [ 1322.244000] Cpu 2 [ 1322.244000] $ 0 : 0000000000000000 0000000000000018 000000003ff00070 0000000000000001 [ 1322.252000] $ 4 : 0000000000000000 c0000000f3980150 0000000000000000 0000000000010000 [ 1322.260000] $ 8 : ffffffffc09cd5f8 0000000000000001 0000000000000088 c0000000ed300de8 [ 1322.268000] $12 : e5e19d9c5f613a45 ffffffffc046d464 0000000000000000 66227ba5ea67b74e [ 1322.276000] $16 : c0000000f1769c00 c0000000ed1e0200 c0000000f3980150 0000000000000000 [ 1322.284000] $20 : c0000000f3a80000 00000000fffffffc c0000000ed2cfbd8 c0000000f39818f0 [ 1322.292000] $24 : 0000000000000004 0000000000000000 [ 1322.300000] $28 : c0000000ed2c0000 c0000000ed2cfab8 0000000000010000 ffffffffc039c0b0 [ 1322.308000] Hi : 000000000000023c [ 1322.312000] Lo : 000000000003f802 [ 1322.316000] epc : ffffffffc039a9f8 check_tn_node+0x88/0x3b0 [ 1322.320000] Not tainted [ 1322.324000] ra : ffffffffc039c0b0 jffs2_do_read_inode_internal+0x1250/0x1e48 [ 1322.332000] Status: 5400f8e3 KX SX UX KERNEL EXL IE [ 1322.336000] Cause : 00800034 [ 1322.340000] PrId : 000c1004 (Netlogic XLP) [ 1322.344000] Modules linked in: [ 1322.348000] Process jffs2_gcd_mtd7 (pid: 264, threadinfo=c0000000ed2c0000, task=c0000000f0e68dd8, tls=0000000000000000) [ 1322.356000] Stack : c0000000f1769e30 c0000000ed010780 c0000000ed010780 c0000000ed300000 c0000000f1769c00 c0000000f3980150 c0000000f3a80000 00000000fffffffc c0000000ed2cfbd8 ffffffffc039c0b0 ffffffffc09c6340 0000000000001000 0000000000000dec ffffffffc016c9d8 c0000000f39805a0 c0000000f3980180 0000008600000000 0000000000000000 0000000000000000 0000000000000000 0001000000000dec c0000000f1769d98 c0000000ed2cfb18 0000000000010000 0000000000010000 0000000000000044 c0000000f3a80000 c0000000f1769c00 c0000000f3d207a8 c0000000f1769d98 c0000000f1769de0 ffffffffc076f9c0 0000000000000009 0000000000000000 0000000000000000 ffffffffc039cf90 0000000000000017 ffffffffc013fbdc 0000000000000001 000000010003e61c ... [ 1322.424000] Call Trace: [ 1322.428000] [<ffffffffc039a9f8>] check_tn_node+0x88/0x3b0 [ 1322.432000] [<ffffffffc039c0b0>] jffs2_do_read_inode_internal+0x1250/0x1e48 [ 1322.440000] [<ffffffffc039cf90>] jffs2_do_crccheck_inode+0x70/0xd0 [ 1322.448000] [<ffffffffc03a1b80>] jffs2_garbage_collect_pass+0x160/0x870 [ 1322.452000] [<ffffffffc03a392c>] jffs2_garbage_collect_thread+0xdc/0x1f0 [ 1322.460000] [<ffffffffc01541c8>] kthread+0xb8/0xc0 [ 1322.464000] [<ffffffffc0106d18>] kernel_thread_helper+0x10/0x18 [ 1322.472000] [ 1322.472000] Code: 67bd0050 94a4002c 2c830001 <00038036> de050218 2403fffc 0080a82d 00431824 24630044 [ 1322.480000] ---[ end trace b052bb90e97dfbf5 ]--- The variable csize in structure jffs2_tmp_dnode_info is of type uint16_t, but it is used to hold the compressed data length(csize) which is declared as uint32_t. So, when the value of csize exceeds 16bits, it gets truncated when assigned to tn->csize. This is causing a kernel BUG. Changing the definition of csize in jffs2_tmp_dnode_info to uint32_t fixes the issue. Signed-off-by: Ajesh Kunhipurayil Vijayan <ajesh@broadcom.com> Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26jffs2: Fix segmentation fault found in stress testKamlakant Patel
commit 3367da5610c50e6b83f86d366d72b41b350b06a2 upstream. Creating a large file on a JFFS2 partition sometimes crashes with this call trace: [ 306.476000] CPU 13 Unable to handle kernel paging request at virtual address c0000000dfff8002, epc == ffffffffc03a80a8, ra == ffffffffc03a8044 [ 306.488000] Oops[#1]: [ 306.488000] Cpu 13 [ 306.492000] $ 0 : 0000000000000000 0000000000000000 0000000000008008 0000000000008007 [ 306.500000] $ 4 : c0000000dfff8002 000000000000009f c0000000e0007cde c0000000ee95fa58 [ 306.508000] $ 8 : 0000000000000001 0000000000008008 0000000000010000 ffffffffffff8002 [ 306.516000] $12 : 0000000000007fa9 000000000000ff0e 000000000000ff0f 80e55930aebb92bb [ 306.524000] $16 : c0000000e0000000 c0000000ee95fa5c c0000000efc80000 ffffffffc09edd70 [ 306.532000] $20 : ffffffffc2b60000 c0000000ee95fa58 0000000000000000 c0000000efc80000 [ 306.540000] $24 : 0000000000000000 0000000000000004 [ 306.548000] $28 : c0000000ee950000 c0000000ee95f738 0000000000000000 ffffffffc03a8044 [ 306.556000] Hi : 00000000000574a5 [ 306.560000] Lo : 6193b7a7e903d8c9 [ 306.564000] epc : ffffffffc03a80a8 jffs2_rtime_compress+0x98/0x198 [ 306.568000] Tainted: G W [ 306.572000] ra : ffffffffc03a8044 jffs2_rtime_compress+0x34/0x198 [ 306.580000] Status: 5000f8e3 KX SX UX KERNEL EXL IE [ 306.584000] Cause : 00800008 [ 306.588000] BadVA : c0000000dfff8002 [ 306.592000] PrId : 000c1100 (Netlogic XLP) [ 306.596000] Modules linked in: [ 306.596000] Process dd (pid: 170, threadinfo=c0000000ee950000, task=c0000000ee6e0858, tls=0000000000c47490) [ 306.608000] Stack : 7c547f377ddc7ee4 7ffc7f967f5d7fae 7f617f507fc37ff4 7e7d7f817f487f5f 7d8e7fec7ee87eb3 7e977ff27eec7f9e 7d677ec67f917f67 7f3d7e457f017ed7 7fd37f517f867eb2 7fed7fd17ca57e1d 7e5f7fe87f257f77 7fd77f0d7ede7fdb 7fba7fef7e197f99 7fde7fe07ee37eb5 7f5c7f8c7fc67f65 7f457fb87f847e93 7f737f3e7d137cd9 7f8e7e9c7fc47d25 7dbb7fac7fb67e52 7ff17f627da97f64 7f6b7df77ffa7ec5 80057ef17f357fb3 7f767fa27dfc7fd5 7fe37e8e7fd07e53 7e227fcf7efb7fa1 7f547e787fa87fcc 7fcb7fc57f5a7ffb 7fc07f6c7ea97e80 7e2d7ed17e587ee0 7fb17f9d7feb7f31 7f607e797e887faa 7f757fdd7c607ff3 7e877e657ef37fbd 7ec17fd67fe67ff7 7ff67f797ff87dc4 7eef7f3a7c337fa6 7fe57fc97ed87f4b 7ebe7f097f0b8003 7fe97e2a7d997cba 7f587f987f3c7fa9 ... [ 306.676000] Call Trace: [ 306.680000] [<ffffffffc03a80a8>] jffs2_rtime_compress+0x98/0x198 [ 306.684000] [<ffffffffc0394f10>] jffs2_selected_compress+0x110/0x230 [ 306.692000] [<ffffffffc039508c>] jffs2_compress+0x5c/0x388 [ 306.696000] [<ffffffffc039dc58>] jffs2_write_inode_range+0xd8/0x388 [ 306.704000] [<ffffffffc03971bc>] jffs2_write_end+0x16c/0x2d0 [ 306.708000] [<ffffffffc01d3d90>] generic_file_buffered_write+0xf8/0x2b8 [ 306.716000] [<ffffffffc01d4e7c>] __generic_file_aio_write+0x1ac/0x350 [ 306.720000] [<ffffffffc01d50a0>] generic_file_aio_write+0x80/0x168 [ 306.728000] [<ffffffffc021f7dc>] do_sync_write+0x94/0xf8 [ 306.732000] [<ffffffffc021ff6c>] vfs_write+0xa4/0x1a0 [ 306.736000] [<ffffffffc02202e8>] SyS_write+0x50/0x90 [ 306.744000] [<ffffffffc0116cc0>] handle_sys+0x180/0x1a0 [ 306.748000] [ 306.748000] Code: 020b202d 0205282d 90a50000 <90840000> 14a40038 00000000 0060602d 0000282d 016c5823 [ 306.760000] ---[ end trace 79dd088435be02d0 ]--- Segmentation fault This crash is caused because the 'positions' is declared as an array of signed short. The value of position is in the range 0..65535, and will be converted to a negative number when the position is greater than 32767 and causes a corruption and crash. Changing the definition to 'unsigned short' fixes this issue Signed-off-by: Jayachandran C <jchandra@broadcom.com> Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26fs: NULL dereference in posix_acl_to_xattr()Dan Carpenter
commit 47ba9734403770a4c5e685b01f0a72b835dd4fff upstream. This patch moves the dereference of "buffer" after the check for NULL. The only place which passes a NULL parameter is gfs2_set_acl(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26ext4: fix premature freeing of partial clusters split across leaf blocksEric Whitney
commit ad6599ab3ac98a4474544086e048ce86ec15a4d1 upstream. Xfstests generic/311 and shared/298 fail when run on a bigalloc file system. Kernel error messages produced during the tests report that blocks to be freed are already on the to-be-freed list. When e2fsck is run at the end of the tests, it typically reports bad i_blocks and bad free blocks counts. The bug that causes these failures is located in ext4_ext_rm_leaf(). Code at the end of the function frees a partial cluster if it's not shared with an extent remaining in the leaf. However, if all the extents in the leaf have been removed, the code dereferences an invalid extent pointer (off the front of the leaf) when the check for sharing is made. This generally has the effect of unconditionally freeing the partial cluster, which leads to the observed failures when the partial cluster is shared with the last extent in the next leaf. Fix this by attempting to free the cluster only if extents remain in the leaf. Any remaining partial cluster will be freed if possible when the next leaf is processed or when leaf removal is complete. Signed-off-by: Eric Whitney <enwlinux@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26ext4: fix partial cluster handling for bigalloc file systemsEric Whitney
commit c06344939422bbd032ac967223a7863de57496b5 upstream. Commit 9cb00419fa, which enables hole punching for bigalloc file systems, exposed a bug introduced by commit 6ae06ff51e in an earlier release. When run on a bigalloc file system, xfstests generic/013, 068, 075, 083, 091, 100, 112, 127, 263, 269, and 270 fail with e2fsck errors or cause kernel error messages indicating that previously freed blocks are being freed again. The latter commit optimizes the selection of the starting extent in ext4_ext_rm_leaf() when hole punching by beginning with the extent supplied in the path argument rather than with the last extent in the leaf node (as is still done when truncating). However, the code in rm_leaf that initially sets partial_cluster to track cluster sharing on extent boundaries is only guaranteed to run if rm_leaf starts with the last node in the leaf. Consequently, partial_cluster is not correctly initialized when hole punching, and a cluster on the boundary of a punched region that should be retained may instead be deallocated. Signed-off-by: Eric Whitney <enwlinux@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26ext4: fix error return from ext4_ext_handle_uninitialized_extents()Eric Whitney
commit ce37c42919608e96ade3748fe23c3062a0a966c5 upstream. Commit 3779473246 breaks the return of error codes from ext4_ext_handle_uninitialized_extents() in ext4_ext_map_blocks(). A portion of the patch assigns that function's signed integer return value to an unsigned int. Consequently, negatively valued error codes are lost and can be treated as a bogus allocated block count. Signed-off-by: Eric Whitney <enwlinux@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26Btrfs: check for an extent_op on the locked refJosef Bacik
commit 573a075567f0174551e2fad2a3164afd2af788f2 upstream. We could have possibly added an extent_op to the locked_ref while we dropped locked_ref->lock, so check for this case as well and loop around. Otherwise we could lose flag updates which would lead to extent tree corruption. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26Btrfs: fix deadlock with nested trans handlesJosef Bacik
commit 3bbb24b20a8800158c33eca8564f432dd14d0bf3 upstream. Zach found this deadlock that would happen like this btrfs_end_transaction <- reduce trans->use_count to 0 btrfs_run_delayed_refs btrfs_cow_block find_free_extent btrfs_start_transaction <- increase trans->use_count to 1 allocate chunk btrfs_end_transaction <- decrease trans->use_count to 0 btrfs_run_delayed_refs lock tree block we are cowing above ^^ We need to only decrease trans->use_count if it is above 1, otherwise leave it alone. This will make nested trans be the only ones who decrease their added ref, and will let us get rid of the trans->use_count++ hack if we have to commit the transaction. Thanks, Reported-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Tested-by: Zach Brown <zab@redhat.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26Btrfs: skip submitting barrier for missing deviceHidetoshi Seto
commit f88ba6a2a44ee98e8d59654463dc157bb6d13c43 upstream. I got an error on v3.13: BTRFS error (device sdf1) in write_all_supers:3378: errno=-5 IO failure (errors while submitting device barriers.) how to reproduce: > mkfs.btrfs -f -d raid1 /dev/sdf1 /dev/sdf2 > wipefs -a /dev/sdf2 > mount -o degraded /dev/sdf1 /mnt > btrfs balance start -f -sconvert=single -mconvert=single -dconvert=single /mnt The reason of the error is that barrier_all_devices() failed to submit barrier to the missing device. However it is clear that we cannot do anything on missing device, and also it is not necessary to care chunks on the missing device. This patch stops sending/waiting barrier if device is missing. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26xfs: fix directory hash ordering bugMark Tinguely
commit c88547a8119e3b581318ab65e9b72f27f23e641d upstream. Commit f5ea1100 ("xfs: add CRCs to dir2/da node blocks") introduced in 3.10 incorrectly converted the btree hash index array pointer in xfs_da3_fixhashpath(). It resulted in the the current hash always being compared against the first entry in the btree rather than the current block index into the btree block's hash entry array. As a result, it was comparing the wrong hashes, and so could misorder the entries in the btree. For most cases, this doesn't cause any problems as it requires hash collisions to expose the ordering problem. However, when there are hash collisions within a directory there is a very good probability that the entries will be ordered incorrectly and that actually matters when duplicate hashes are placed into or removed from the btree block hash entry array. This bug results in an on-disk directory corruption and that results in directory verifier functions throwing corruption warnings into the logs. While no data or directory entries are lost, access to them may be compromised, and attempts to remove entries from a directory that has suffered from this corruption may result in a filesystem shutdown. xfs_repair will fix the directory hash ordering without data loss occuring. [dchinner: wrote useful a commit message] Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26bdi: avoid oops on device removalJan Kara
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream. After commit 839a8e8660b6 ("writeback: replace custom worker pool implementation with unbound workqueue") when device is removed while we are writing to it we crash in bdi_writeback_workfn() -> set_worker_desc() because bdi->dev is NULL. This can happen because even though bdi_unregister() cancels all pending flushing work, nothing really prevents new ones from being queued from balance_dirty_pages() or other places. Fix the problem by clearing BDI_registered bit in bdi_unregister() and checking it before scheduling of any flushing work. Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977 Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Derek Basehore <dbasehore@chromium.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26backing_dev: fix hung task on syncDerek Basehore
commit 6ca738d60c563d5c6cf6253ee4b8e76fa77b2b9e upstream. bdi_wakeup_thread_delayed() used the mod_delayed_work() function to schedule work to writeback dirty inodes. The problem with this is that it can delay work that is scheduled for immediate execution, such as the work from sync_inodes_sb(). This can happen since mod_delayed_work() can now steal work from a work_queue. This fixes the problem by using queue_delayed_work() instead. This is a regression caused by commit 839a8e8660b6 ("writeback: replace custom worker pool implementation with unbound workqueue"). The reason that this causes a problem is that laptop-mode will change the delay, dirty_writeback_centisecs, to 60000 (10 minutes) by default. In the case that bdi_wakeup_thread_delayed() races with sync_inodes_sb(), sync will be stopped for 10 minutes and trigger a hung task. Even if dirty_writeback_centisecs is not long enough to cause a hung task, we still don't want to delay sync for that long. We fix the problem by using queue_delayed_work() when we want to schedule writeback sometime in future. This function doesn't change the timer if it is already armed. For the same reason, we also change bdi_writeback_workfn() to immediately queue the work again in the case that the work_list is not empty. The same problem can happen if the sync work is run on the rescue worker. [jack@suse.cz: update changelog, add comment, use bdi_wakeup_thread_delayed()] Signed-off-by: Derek Basehore <dbasehore@chromium.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Alexander Viro <viro@zento.linux.org.uk> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Derek Basehore <dbasehore@chromium.org> Cc: Kees Cook <keescook@chromium.org> Cc: Benson Leung <bleung@chromium.org> Cc: Sonny Rao <sonnyrao@chromium.org> Cc: Luigi Semenzato <semenzato@chromium.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26kernfs: protect lazy kernfs_iattrs allocation with mutexTejun Heo
commit 4afddd60a770560d370d6f85c5aef57c16bf7502 upstream. kernfs_iattrs is allocated lazily when operations which require it take place; unfortunately, the lazy allocation and returning weren't properly synchronized and when there are multiple concurrent operations, it might end up returning kernfs_iattrs which hasn't finished initialization yet or different copies to different callers. Fix it by synchronizing with a mutex. This can be smarter with memory barriers but let's go there if it actually turns out to be necessary. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/g/533ABA32.9080602@oracle.com Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26kernfs: fix off by one error.Richard Cochran
commit 88391d49abb7d8dee91d405f96bd9e003cb6798d upstream. The hash values 0 and 1 are reserved for magic directory entries, but the code only prevents names hashing to 0. This patch fixes the test to also prevent hash value 1. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-30Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Switch mnt_hash to hlist, turning the races between __lookup_mnt() and hash modifications into false negatives from __lookup_mnt() (instead of hangs)" On the false negatives from __lookup_mnt(): "The *only* thing we care about is not getting stuck in __lookup_mnt(). If it misses an entry because something in front of it just got moved around, etc, we are fine. We'll notice that mount_lock mismatch and that'll be it" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch mnt_hash to hlist don't bother with propagate_mnt() unless the target is shared keep shadowed vfsmounts together resizable namespace.c hashes
2014-03-30ext4: atomically set inode->i_flags in ext4_set_inode_flags()Theodore Ts'o
Use cmpxchg() to atomically set i_flags instead of clearing out the S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race where an immutable file has the immutable flag cleared for a brief window of time. Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-30switch mnt_hash to hlistAl Viro
fixes RCU bug - walking through hlist is safe in face of element moves, since it's self-terminating. Cyclic lists are not - if we end up jumping to another hash chain, we'll loop infinitely without ever hitting the original list head. [fix for dumb braino folded] Spotted by: Max Kellermann <mk@cm4all.com> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30don't bother with propagate_mnt() unless the target is sharedAl Viro
If the dest_mnt is not shared, propagate_mnt() does nothing - there's no mounts to propagate to and thus no copies to create. Might as well don't bother calling it in that case. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30keep shadowed vfsmounts togetherAl Viro
preparation to switching mnt_hash to hlist Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30resizable namespace.c hashesAl Viro
* switch allocation to alloc_large_system_hash() * make sizes overridable by boot parameters (mhash_entries=, mphash_entries=) * switch mountpoint_hashtable from list_head to hlist_head Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-28ocfs2: check if cluster name exists before derefSasha Levin
Commit c74a3bdd9b52 ("ocfs2: add clustername to cluster connection") is trying to strlcpy a string which was explicitly passed as NULL in the very same patch, triggering a NULL ptr deref. BUG: unable to handle kernel NULL pointer dereference at (null) IP: strlcpy (lib/string.c:388 lib/string.c:151) CPU: 19 PID: 19426 Comm: trinity-c19 Tainted: G W 3.14.0-rc7-next-20140325-sasha-00014-g9476368-dirty #274 RIP: strlcpy (lib/string.c:388 lib/string.c:151) Call Trace: ocfs2_cluster_connect (fs/ocfs2/stackglue.c:350) ocfs2_cluster_connect_agnostic (fs/ocfs2/stackglue.c:396) user_dlm_register (fs/ocfs2/dlmfs/userdlm.c:679) dlmfs_mkdir (fs/ocfs2/dlmfs/dlmfs.c:503) vfs_mkdir (fs/namei.c:3467) SyS_mkdirat (fs/namei.c:3488 fs/namei.c:3472) tracesys (arch/x86/kernel/entry_64.S:749) akpm: this patch probably disables the feature. A temporary thing to avoid triviel oopses. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-27vfs: Allocate anon_inode_inode in anon_inode_init()Jan Kara
Currently we allocated anon_inode_inode in anon_inodefs_mount. This is somewhat fragile as if that function ever gets called again, it will overwrite anon_inode_inode pointer. So move the initialization of anon_inode_inode to anon_inode_init(). Signed-off-by: Jan Kara <jack@suse.cz> [ Further simplified on suggestion from Dave Jones ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-25fs: remove now stale label in anon_inode_init()Linus Torvalds
The previous commit removed the register_filesystem() call and the associated error handling, but left the label for the error path that no longer exists. Remove that too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-25fs: Avoid userspace mounting anon_inodefs filesystemJan Kara
anon_inodefs filesystem is a kernel internal filesystem userspace shouldn't mess with. Remove registration of it so userspace cannot even try to mount it (which would fail anyway because the filesystem is MS_NOUSER). This fixes an oops triggered by trinity when it tried mounting anon_inodefs which overwrote anon_inode_inode pointer while other CPU has been in anon_inode_getfile() between ihold() and d_instantiate(). Thus effectively creating dentry pointing to an inode without holding a reference to it. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-25Merge branch 'nfsd-next' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fix frm Bruce Fields: "J R Okajima sent this early and I was just slow to pass it along, apologies. Fortunately it's a simple fix" * 'nfsd-next' of git://linux-nfs.org/~bfields/linux: nfsd: fix lost nfserrno() call in nfsd_setattr()
2014-03-23rcuwalk: recheck mount_lock after mountpoint crossing attemptsAl Viro
We can get false negative from __lookup_mnt() if an unrelated vfsmount gets moved. In that case legitimize_mnt() is guaranteed to fail, and we will fall back to non-RCU walk... unless we end up running into a hard error on a filesystem object we wouldn't have reached if not for that false negative. IOW, delaying that check until the end of pathname resolution is wrong - we should recheck right after we attempt to cross the mountpoint. We don't need to recheck unless we see d_mountpoint() being true - in that case even if we have just raced with mount/umount, we can simply go on as if we'd come at the moment when the sucker wasn't a mountpoint; if we run into a hard error as the result, it was a legitimate outcome. __lookup_mnt() returning NULL is different in that respect, since it might've happened due to operation on completely unrelated mountpoint. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-23make prepend_name() work correctly when called with negative *buflenAl Viro
In all callchains leading to prepend_name(), the value left in *buflen is eventually discarded unused if prepend_name() has returned a negative. So we are free to do what prepend() does, and subtract from *buflen *before* checking for underflow (which turns into checking the sign of subtraction result, of course). Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-23vfs: Don't let __fdget_pos() get FMODE_PATH filesEric Biggers
Commit bd2a31d522344 ("get rid of fget_light()") introduced the __fdget_pos() function, which returns the resulting file pointer and fdput flags combined in an 'unsigned long'. However, it also changed the behavior to return files with FMODE_PATH set, which shouldn't happen because read(), write(), lseek(), etc. aren't allowed on such files. This commit restores the old behavior. This regression actually had no effect on read() and write() since FMODE_READ and FMODE_WRITE are not set on file descriptors opened with O_PATH, but it did cause lseek() on a file descriptor opened with O_PATH to fail with ESPIPE rather than EBADF. Signed-off-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-23vfs: atomic f_pos access in llseek()Eric Biggers
Commit 9c225f2655e36a4 ("vfs: atomic f_pos accesses as per POSIX") changed several system calls to use fdget_pos() instead of fdget(), but missed sys_llseek(). Fix it. Signed-off-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-11Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "A fix for the problem which Al spotted in cifs_writev and a followup (noticed when fixing CVE-2014-0069) patch to ensure that cifs never sends more than the smb frame length over the socket (as we saw with that cifs_iovec_write problem that Jeff fixed last month)" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: mask off top byte in get_rfc1002_length() cifs: sanity check length of data to send before sending CIFS: Fix wrong pos argument of cifs_find_lock_conflict
2014-03-10Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "Nine fixes" * emailed patches from Andrew Morton akpm@linux-foundation.org>: cris: convert ffs from an object-like macro to a function-like macro hfsplus: add HFSX subfolder count support tools/testing/selftests/ipc/msgque.c: handle msgget failure return correctly MAINTAINERS: blackfin: add git repository revert "kallsyms: fix absolute addresses for kASLR" mm/Kconfig: fix URL for zsmalloc benchmark fs/proc/base.c: fix GPF in /proc/$PID/map_files mm/compaction: break out of loop on !PageBuddy in isolate_freepages_block mm: fix GFP_THISNODE callers and clarify
2014-03-10hfsplus: add HFSX subfolder count supportSergei Antonov
Adds support for HFSX 'HasFolderCount' flag and a corresponding 'folderCount' field in folder records. (For reference see HFS_FOLDERCOUNT and kHFSHasFolderCountBit/kHFSHasFolderCountMask in Apple's source code.) Ignoring subfolder count leads to fs errors found by Mac: ... Checking catalog hierarchy. HasFolderCount flag needs to be set (id = 105) (It should be 0x10 instead of 0) Incorrect folder count in a directory (id = 2) (It should be 7 instead of 6) ... Steps to reproduce: Format with "newfs_hfs -s /dev/diskXXX". Mount in Linux. Create a new directory in root. Unmount. Run "fsck_hfs /dev/diskXXX". The patch handles directory creation, deletion, and rename. Signed-off-by: Sergei Antonov <saproj@gmail.com> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-10fs/proc/base.c: fix GPF in /proc/$PID/map_filesArtem Fetishev
The expected logic of proc_map_files_get_link() is either to return 0 and initialize 'path' or return an error and leave 'path' uninitialized. By the time dname_to_vma_addr() returns 0 the corresponding vma may have already be gone. In this case the path is not initialized but the return value is still 0. This results in 'general protection fault' inside d_path(). Steps to reproduce: CONFIG_CHECKPOINT_RESTORE=y fd = open(...); while (1) { mmap(fd, ...); munmap(fd, ...); } ls -la /proc/$PID/map_files Addresses https://bugzilla.kernel.org/show_bug.cgi?id=68991 Signed-off-by: Artem Fetishev <artem_fetishev@epam.com> Signed-off-by: Aleksandr Terekhov <aleksandr_terekhov@epam.com> Reported-by: <wiebittewas@gmail.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro. Clean up file table accesses (get rid of fget_light() in favor of the fdget() interface), add proper file position locking. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: get rid of fget_light() sockfd_lookup_light(): switch to fdget^W^Waway from fget_light vfs: atomic f_pos accesses as per POSIX ocfs2 syncs the wrong range...
2014-03-10get rid of fget_light()Al Viro
instead of returning the flags by reference, we can just have the low-level primitive return those in lower bits of unsigned long, with struct file * derived from the rest. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-10vfs: atomic f_pos accesses as per POSIXLinus Torvalds
Our write() system call has always been atomic in the sense that you get the expected thread-safe contiguous write, but we haven't actually guaranteed that concurrent writes are serialized wrt f_pos accesses, so threads (or processes) that share a file descriptor and use "write()" concurrently would quite likely overwrite each others data. This violates POSIX.1-2008/SUSv4 Section XSI 2.9.7 that says: "2.9.7 Thread Interactions with Regular File Operations All of the following functions shall be atomic with respect to each other in the effects specified in POSIX.1-2008 when they operate on regular files or symbolic links: [...]" and one of the effects is the file position update. This unprotected file position behavior is not new behavior, and nobody has ever cared. Until now. Yongzhi Pan reported unexpected behavior to Michael Kerrisk that was due to this. This resolves the issue with a f_pos-specific lock that is taken by read/write/lseek on file descriptors that may be shared across threads or processes. Reported-by: Yongzhi Pan <panyongzhi@gmail.com> Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-10ocfs2 syncs the wrong range...Al Viro
2014-03-09Merge tag 'nfs-for-3.14-5' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: - Fix another nfs4_sequence corruptor in RELEASE_LOCKOWNER - Fix an Oopsable delegation callback race - Fix another bad stateid infinite loop - Fail the data server I/O is the stateid represents a lost lock - Fix an Oopsable sunrpc trace event" * tag 'nfs-for-3.14-5' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: Fix oops when trace sunrpc_task events in nfs client NFSv4: Fail the truncate() if the lock/open stateid is invalid NFSv4.1 Fail data server I/O if stateid represents a lost lock NFSv4: Fix the return value of nfs4_select_rw_stateid NFSv4: nfs4_stateid_is_current should return 'true' for an invalid stateid NFS: Fix a delegation callback race NFSv4: Fix another nfs4_sequence corruptor
2014-03-07Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "Small collection of fixes for 3.14-rc. It contains: - Three minor update to blk-mq from Christoph. - Reduce number of unaligned (< 4kb) in-flight writes on mtip32xx to two. From Micron. - Make the blk-mq CPU notify spinlock raw, since it can't be a sleeper spinlock on RT. From Mike Galbraith. - Drop now bogus BUG_ON() for bio iteration with blk integrity. From Nic Bellinger. - Properly propagate the SYNC flag on requests. From Shaohua" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: add REQ_SYNC early rt,blk,mq: Make blk_mq_cpu_notify_lock a raw spinlock bio-integrity: Drop bio_integrity_verify BUG_ON in post bip->bip_iter world blk-mq: support partial I/O completions blk-mq: merge blk_mq_insert_request and blk_mq_run_request blk-mq: remove blk_mq_alloc_rq mtip32xx: Reduce the number of unaligned writes to 2
2014-03-05NFSv4: Fail the truncate() if the lock/open stateid is invalidTrond Myklebust
If the open stateid could not be recovered, or the file locks were lost, then we should fail the truncate() operation altogether. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-05NFSv4.1 Fail data server I/O if stateid represents a lost lockAndy Adamson
Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-05NFSv4: Fix the return value of nfs4_select_rw_stateidTrond Myklebust
In commit 5521abfdcf4d6 (NFSv4: Resend the READ/WRITE RPC call if a stateid change causes an error), we overloaded the return value of nfs4_select_rw_stateid() to cause it to return -EWOULDBLOCK if an RPC call is outstanding that would cause the NFSv4 lock or open stateid to change. That is all redundant when we actually copy the stateid used in the read/write RPC call that failed, and check that against the current stateid. It is doubly so, when we consider that in the NFSv4.1 case, we also set the stateid's seqid to the special value '0', which means 'match the current valid stateid'. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-05NFSv4: nfs4_stateid_is_current should return 'true' for an invalid stateidTrond Myklebust
When nfs4_set_rw_stateid() can fails by returning EIO to indicate that the stateid is completely invalid, then it makes no sense to have it trigger a retry of the READ or WRITE operation. Instead, we should just have it fall through and attempt a recovery. This fixes an infinite loop in which the client keeps replaying the same bad stateid back to the server. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-04hfsplus: fix remount issueVyacheslav Dubeyko
Current implementation of HFS+ driver has small issue with remount option. Namely, for example, you are unable to remount from RO mode into RW mode by means of command "mount -o remount,rw /dev/loop0 /mnt/hfsplus". Trying to execute sequence of commands results in an error message: mount /dev/loop0 /mnt/hfsplus mount -o remount,ro /dev/loop0 /mnt/hfsplus mount -o remount,rw /dev/loop0 /mnt/hfsplus mount: you must specify the filesystem type mount -t hfsplus -o remount,rw /dev/loop0 /mnt/hfsplus mount: /mnt/hfsplus not mounted or bad option The reason of such issue is failure of mount syscall: mount("/dev/loop0", "/mnt/hfsplus", 0x2282a60, MS_MGC_VAL|MS_REMOUNT, NULL) = -1 EINVAL (Invalid argument) Namely, hfsplus_parse_options_remount() method receives empty "input" argument and return false in such case. As a result, hfsplus_remount() returns -EINVAL error code. This patch fixes the issue by means of return true for the case of empty "input" argument in hfsplus_parse_options_remount() method. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04ocfs2: fix quota file corruptionJan Kara
Global quota files are accessed from different nodes. Thus we cannot cache offset of quota structure in the quota file after we drop our node reference count to it because after that moment quota structure may be freed and reallocated elsewhere by a different node resulting in corruption of quota file. Fix the problem by clearing dq_off when we are releasing dquot structure. We also remove the DB_READ_B handling because it is useless - DQ_ACTIVE_B is set iff DQ_READ_B is set. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Goldwyn Rodrigues <rgoldwyn@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04mm: close PageTail raceDavid Rientjes
Commit bf6bddf1924e ("mm: introduce compaction and migration for ballooned pages") introduces page_count(page) into memory compaction which dereferences page->first_page if PageTail(page). This results in a very rare NULL pointer dereference on the aforementioned page_count(page). Indeed, anything that does compound_head(), including page_count() is susceptible to racing with prep_compound_page() and seeing a NULL or dangling page->first_page pointer. This patch uses Andrea's implementation of compound_trans_head() that deals with such a race and makes it the default compound_head() implementation. This includes a read memory barrier that ensures that if PageTail(head) is true that we return a head page that is neither NULL nor dangling. The patch then adds a store memory barrier to prep_compound_page() to ensure page->first_page is set. This is the safest way to ensure we see the head page that we are expecting, PageTail(page) is already in the unlikely() path and the memory barriers are unfortunately required. Hugetlbfs is the exception, we don't enforce a store memory barrier during init since no race is possible. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Holger Kiehl <Holger.Kiehl@dwd.de> Cc: Christoph Lameter <cl@linux.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-02NFS: Fix a delegation callback raceTrond Myklebust
The clean-up in commit 36281caa839f ended up removing a NULL pointer check that is needed in order to prevent an Oops in nfs_async_inode_return_delegation(). Reported-by: "Yan, Zheng" <zheng.z.yan@intel.com> Link: http://lkml.kernel.org/r/5313E9F6.2020405@intel.com Fixes: 36281caa839f (NFSv4: Further clean-ups of delegation stateid validation) Cc: stable@vger.kernel.org # 3.4+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-02Merge tag 'driver-core-3.14-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull sysfs fix from Greg KH: "Here is a single sysfs fix for 3.14-rc5. It fixes a reported problem with the namespace code in sysfs" * tag 'driver-core-3.14-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: sysfs: fix namespace refcnt leak
