commit b8d0c69b9469ffd33df30fee3e990f2d4aa68a09 upstream.
A user was reporting weird warnings from btrfs_put_delayed_ref() and I noticed
that we were doing this list_del_init() on our head ref outside of
delayed_refs->lock. This is a problem if we have people still on the list, we
could end up modifying old pointers and such. Fix this by removing us from the
list before we do our run_delayed_ref on our head ref. Thanks,
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit a05254143cd183b18002cbba7759a1e4629aa762 upstream.
We have logic to see if we've already created a parent directory by check to see
if an inode inside of that directory has a lower inode number than the one we
are currently processing. The logic is that if there is a lower inode number
then we would have had to made sure the directory was created at that previous
point. The problem is that subvols inode numbers count from the lowest objectid
in the root tree, which may be less than our current progress. So just skip if
our dir item key is a root item. This fixes the original test and the xfstest
version I made that added an extra subvol create. Thanks,
Reported-by: Emil Karlson <jekarlson@gmail.com>
commit b6c60c8018c4e9beb2f83fc82c09f9d033766571 upstream.
Previously we only added blocks to the list to have their backrefs checked if
the level of the block is right above the one we are searching for. This is
because we want to make sure we don't add the entire path up to the root to the
lists to make sure we process things one at a time. This assumes that if any
blocks in the path to the root are going to be not checked (shared in other
words) then they will be in the level right above the current block on up. This
isn't quite right though since we can have blocks higher up the list that are
shared because they are attached to a reloc root. But we won't add this block
to be checked and then later on we will BUG_ON(!upper->checked). So instead
keep track of wether or not we've queued a block to be checked in this current
search, and if we haven't go ahead and queue it to be checked. This patch fixed
the panic I was seeing where we BUG_ON(!upper->checked). Thanks,
commit 997def25e4b9cee3b01609e18a52f926bca8bd2b upstream.
Commit f5ea1100 cleans up the disk to host conversions for
node directory entries, but because a variable is reused in
xfs_node_toosmall() the next node is not correctly found.
If the original node is small enough (<= 3/8 of the node size),
this change may incorrectly cause a node collapse when it should
not. That will cause an assert in xfstest generic/319:
Assertion failed: first <= last && last < BBTOB(bp->b_length),
file: /root/newest/xfs/fs/xfs/xfs_trans_buf.c, line: 569
Keep the original node header to get the correct forward node.
(When a node is considered for a merge with a sibling, it overwrites the
sibling pointers of the original incore nodehdr with the sibling's
pointers. This leads to loop considering the original node as a merge
candidate with itself in the second pass, and so it incorrectly
determines a merge should occur.)
[v3: added Dave Chinner's (slightly modified) suggestion to the commit header,
cleaned up whitespace. -bpm]
Signed-off-by: Mark Tinguely <tinguely@sgi.com>
Reviewed-by: Ben Myers <bpm@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 52b26a3e1bb3e065c32b3febdac1e1f117d88e15 upstream.
- Fix an Oops when nfs4_ds_connect() returns an error.
- Always check the device status after waiting for a connect to complete.
Reported-by: Andy Adamson <andros@netapp.com>
Reported-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
dirty blocks
commit 7f42ec3941560f0902fe3671e36f2c20ffd3af0a upstream.
Many NILFS2 users were reported about strange file system corruption
(for example):
NILFS: bad btree node (blocknr=185027): level = 0, flags = 0x0, nchildren = 768
NILFS error (device sda4): nilfs_bmap_last_key: broken bmap (inode number=11540)
But such error messages are consequence of file system's issue that takes
place more earlier. Fortunately, Jerome Poulin <jeromepoulin@gmail.com>
and Anton Eliasson <devel@antoneliasson.se> were reported about another
issue not so recently. These reports describe the issue with segctor
thread's crash:
BUG: unable to handle kernel paging request at 0000000000004c83
IP: nilfs_end_page_io+0x12/0xd0 [nilfs2]
Call Trace:
nilfs_segctor_do_construct+0xf25/0x1b20 [nilfs2]
nilfs_segctor_construct+0x17b/0x290 [nilfs2]
nilfs_segctor_thread+0x122/0x3b0 [nilfs2]
kthread+0xc0/0xd0
ret_from_fork+0x7c/0xb0
These two issues have one reason. This reason can raise third issue
too. Third issue results in hanging of segctor thread with eating of
100% CPU.
REPRODUCING PATH:
One of the possible way or the issue reproducing was described by
Jermoe me Poulin <jeromepoulin@gmail.com>:
1. init S to get to single user mode.
2. sysrq+E to make sure only my shell is running
3. start network-manager to get my wifi connection up
4. login as root and launch "screen"
5. cd /boot/log/nilfs which is a ext3 mount point and can log when NILFS dies.
6. lscp | xz -9e > lscp.txt.xz
7. mount my snapshot using mount -o cp=3360839,ro /dev/vgUbuntu/root /mnt/nilfs
8. start a screen to dump /proc/kmsg to text file since rsyslog is killed
9. start a screen and launch strace -f -o find-cat.log -t find
/mnt/nilfs -type f -exec cat {} > /dev/null \;
10. start a screen and launch strace -f -o apt-get.log -t apt-get update
11. launch the last command again as it did not crash the first time
12. apt-get crashes
13. ps aux > ps-aux-crashed.log
13. sysrq+W
14. sysrq+E wait for everything to terminate
15. sysrq+SUSB
Simplified way of the issue reproducing is starting kernel compilation
task and "apt-get update" in parallel.
REPRODUCIBILITY:
The issue is reproduced not stable [60% - 80%]. It is very important to
have proper environment for the issue reproducing. The critical
conditions for successful reproducing:
(1) It should have big modified file by mmap() way.
(2) This file should have the count of dirty blocks are greater that
several segments in size (for example, two or three) from time to time
during processing.
(3) It should be intensive background activity of files modification
in another thread.
INVESTIGATION:
First of all, it is possible to see that the reason of crash is not valid
page address:
NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82
NILFS [nilfs_segctor_complete_write]:2101 segbuf->sb_segnum 6783
Moreover, value of b_page (0x1a82) is 6786. This value looks like segment
number. And b_blocknr with b_size values look like block numbers. So,
buffer_head's pointer points on not proper address value.
Detailed investigation of the issue is discovered such picture:
[-----------------------------SEGMENT 6783-------------------------------]
NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction
NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect
NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign
NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage
NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write
NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs
NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111149024, segbuf->sb_segnum 6783
[-----------------------------SEGMENT 6784-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff8802174a6798, bh->b_assoc_buffers.prev ffff880221cffee8
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111150080, segbuf->sb_segnum 6784, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111164416, segbuf->sb_segnum 6784, segbuf->sb_nbio 15
[-----------------------------SEGMENT 6785-------------------------------]
NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff880219277e80, bh->b_assoc_buffers.prev ffff880221cffc88
NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824
NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6785
NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111165440, segbuf->sb_segnum 6785, segbuf->sb_nbio 0
[----------] ditto
NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111177728, segbuf->sb_segnum 6785, segbuf->sb_nbio 12
NILFS [nilfs_segctor_do_construct]:2399 nilfs_segctor_wait
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6783
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6784
NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6785
BUG: unable to handle kernel paging request at 0000000000001a82
IP: [<ffffffffa024d0f2>] nilfs_end_page_io+0x12/0xd0 [nilfs2]
Usually, for every segment we collect dirty files in list. Then, dirty
blocks are gathered for every dirty file, prepared for write and
submitted by means of nilfs_segbuf_submit_bh() call. Finally, it takes
place complete write phase after calling nilfs_end_bio_write() on the
block layer. Buffers/pages are marked as not dirty on final phase and
processed files removed from the list of dirty files.
It is possible to see that we had three prepare_write and submit_bio
phases before segbuf_wait and complete_write phase. Moreover, segments
compete between each other for dirty blocks because on every iteration
of segments processing dirty buffer_heads are added in several lists of
payload_buffers:
[SEGMENT 6784]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50
[SEGMENT 6785]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8
The next pointer is the same but prev pointer has changed. It means
that buffer_head has next pointer from one list but prev pointer from
another. Such modification can be made several times. And, finally, it
can be resulted in various issues: (1) segctor hanging, (2) segctor
crashing, (3) file system metadata corruption.
FIX:
This patch adds:
(1) setting of BH_Async_Write flag in nilfs_segctor_prepare_write()
for every proccessed dirty block;
(2) checking of BH_Async_Write flag in
nilfs_lookup_dirty_data_buffers() and
nilfs_lookup_dirty_node_buffers();
(3) clearing of BH_Async_Write flag in nilfs_segctor_complete_write(),
nilfs_abort_logs(), nilfs_forget_buffer(), nilfs_clear_dirty_page().
Reported-by: Jerome Poulin <jeromepoulin@gmail.com>
Reported-by: Anton Eliasson <devel@antoneliasson.se>
Cc: Paul Fertser <fercerpav@gmail.com>
Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp>
Cc: Piotr Szymaniak <szarpaj@grubelek.pl>
Cc: Juan Barry Manuel Canham <Linux@riotingpacifist.net>
Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com>
Cc: Elmer Zhang <freeboy6716@gmail.com>
Cc: Kenneth Langga <klangga@gmail.com>
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit 0ab08f576b9e6a6b689fc6b4e632079b978e619b upstream.
A former patch introducing FUSE_I_SIZE_UNSTABLE flag provided detailed
description of races between ftruncate and anyone who can extend i_size:
> 1. As in the previous scenario fuse_dentry_revalidate() discovered that i_size
> changed (due to our own fuse_do_setattr()) and is going to call
> truncate_pagecache() for some 'new_size' it believes valid right now. But by
> the time that particular truncate_pagecache() is called ...
> 2. fuse_do_setattr() returns (either having called truncate_pagecache() or
> not -- it doesn't matter).
> 3. The file is extended either by write(2) or ftruncate(2) or fallocate(2).
> 4. mmap-ed write makes a page in the extended region dirty.
This patch adds necessary bits to fuse_file_fallocate() to protect from that
race.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit bde52788bdb755b9e4b75db6c434f30e32a0ca0b upstream.
The patch fixes a race between mmap-ed write and fallocate(PUNCH_HOLE):
1) An user makes a page dirty via mmap-ed write.
2) The user performs fallocate(2) with mode == PUNCH_HOLE|KEEP_SIZE
and <offset, size> covering the page.
3) Before truncate_pagecache_range call from fuse_file_fallocate,
the page goes to write-back. The page is fully processed by fuse_writepage
(including end_page_writeback on the page), but fuse_flush_writepages did
nothing because fi->writectr < 0.
4) truncate_pagecache_range is called and fuse_file_fallocate is finishing
by calling fuse_release_nowrite. The latter triggers processing queued
write-back request which will write stale data to the hole soon.
Changed in v2 (thanks to Brian for suggestion):
- Do not truncate page cache until FUSE_FALLOCATE succeeded. Otherwise,
we can end up in returning -ENOTSUPP while user data is already punched
from page cache. Use filemap_write_and_wait_range() instead.
Changed in v3 (thanks to Miklos for suggestion):
- fuse_wait_on_writeback() is prone to livelocks; use fuse_set_nowrite()
instead. So far as we need a dirty-page barrier only, fuse_sync_writes()
should be enough.
- rebased to for-linus branch of fuse.git
commit 72023656961b8c81a168a7a6762d589339d0d7ec upstream.
A high setting of max_map_count, and a process core-dumping with a large
enough vm_map_count could result in an NT_FILE note not being written,
and the kernel crashing immediately later because it has assumed
otherwise.
Reproduction of the oops-causing bug described here:
https://lkml.org/lkml/2013/8/30/50
Rge ussue originated in commit 2aa362c49c31 ("coredump: extend core dump
note section to contain file names of mapped file") from Oct 4, 2012.
This patch make that section optional in that case. fill_files_note()
should signify the error, and also let the info struct in
elf_core_dump() be zero-initialized so that we can check for the
optionally written note.
[akpm@linux-foundation.org: avoid abusing E2BIG, remove a couple of not-really-needed local variables]
[akpm@linux-foundation.org: fix sparse warning]
Signed-off-by: Dan Aloni <alonid@stratoscale.com>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Reported-by: Martin MOKREJS <mmokrejs@gmail.com>
Tested-by: Martin MOKREJS <mmokrejs@gmail.com>
commit 49475555848d396a0c78fb2f8ecceb3f3f263ef1 upstream.
Superblock lock was replaced with (un)lock_super() removal, but left
uninitialized for Seventh Edition UNIX filesystem in the following commit (3.7):
c07cb01 sysv: drop lock/unlock super
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
commit 2f6cf0de0281d210061ce976f2d42d246adc75bb upstream.
The memcpy() in bio_copy_data() was using the wrong offset vars, leading
to data corruption in weird unusual setups.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
commit adbe6991efd36104ac9eaf751993d35eaa7f493a upstream.
This fixes a copy and paste error introduced by 9f060e2231
("block: Convert integrity to bvec_alloc_bs()").
Found by Coverity (CID 1020654).
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Kent Overstreet <koverstreet@google.com>
Cc: Jonghwan Choi <jhbird.choi@gmail.com>
commit e729eac6f65e11c5f03b09adcc84bd5bcb230467 upstream.
Refuse RW mount of udf filesystem. So far we just silently changed it
to RO mount but when the media is writeable, block layer won't notice
this change and thus will think device is used RW and will block eject
button of the drive. That is unexpected by users because for
non-writeable media eject button works just fine.
Userspace mount(8) command handles this just fine and retries mounting
with MS_RDONLY set so userspace shouldn't see any regression. Plus any
tool mounting udf is likely confronted with the case of read-only
media where block layer already refuses to mount the filesystem without
MS_RDONLY set so our behavior shouldn't be anything new for it.
Reported-by: Hui Wang <hui.wang@canonical.com>
commit d759bfa4e7919b89357de50a2e23817079889195 upstream.
Change all function used in filesystem discovery during mount to user
standard kernel return values - -errno on error, 0 on success instead
of 1 on failure and 0 on success. This allows us to pass error number
(not just failure / success) so we can abort device scanning earlier
in case of errors like EIO or ENOMEM . Also we will be able to return
EROFS in case writeable mount is requested but writing isn't supported.
Cc: Hui Wang <hui.wang@canonical.com>
commit dfb1d61b0e9f9e2c542e9adc8d970689f4114ff6 upstream.
If an error occurs after having called finish_open() then fput() needs to
be called on the already opened file.
Cc: Steve French <sfrench@samba.org>
commit efeb9e60d48f7778fdcad4a0f3ad9ea9b19e5dfd upstream.
Userspace can add names containing a slash character to the directory
listing. Don't allow this as it could cause all sorts of trouble.
commit 06a7c3c2781409af95000c60a5df743fd4e2f8b4 upstream.
The way how fuse calls truncate_pagecache() from fuse_change_attributes()
is completely wrong. Because, w/o i_mutex held, we never sure whether
'oldsize' and 'attr->size' are valid by the time of execution of
truncate_pagecache(inode, oldsize, attr->size). In fact, as soon as we
released fc->lock in the middle of fuse_change_attributes(), we completely
loose control of actions which may happen with given inode until we reach
truncate_pagecache. The list of potentially dangerous actions includes
mmap-ed reads and writes, ftruncate(2) and write(2) extending file size.
The typical outcome of doing truncate_pagecache() with outdated arguments
is data corruption from user point of view. This is (in some sense)
acceptable in cases when the issue is triggered by a change of the file on
the server (i.e. externally wrt fuse operation), but it is absolutely
intolerable in scenarios when a single fuse client modifies a file without
any external intervention. A real life case I discovered by fsx-linux
looked like this:
1. Shrinking ftruncate(2) comes to fuse_do_setattr(). The latter sends
FUSE_SETATTR to the server synchronously, but before getting fc->lock ...
2. fuse_dentry_revalidate() is asynchronously called. It sends FUSE_LOOKUP
to the server synchronously, then calls fuse_change_attributes(). The
latter updates i_size, releases fc->lock, but before comparing oldsize vs
attr->size..
3. fuse_do_setattr() from the first step proceeds by acquiring fc->lock and
updating attributes and i_size, but now oldsize is equal to
outarg.attr.size because i_size has just been updated (step 2). Hence,
fuse_do_setattr() returns w/o calling truncate_pagecache().
4. As soon as ftruncate(2) completes, the user extends file size by
write(2) making a hole in the middle of file, then reads data from the hole
either by read(2) or mmap-ed read. The user expects to get zero data from
the hole, but gets stale data because truncate_pagecache() is not executed
yet.
The scenario above illustrates one side of the problem: not truncating the
page cache even though we should. Another side corresponds to truncating
page cache too late, when the state of inode changed significantly.
Theoretically, the following is possible:
i_size changed (due to our own fuse_do_setattr()) and is going to call
by the time that particular truncate_pagecache() is called ...
The result will be the lost of data user wrote on the fourth step.
The patch is a hotfix resolving the issue in a simplistic way: let's skip
dangerous i_size update and truncate_pagecache if an operation changing
file size is in progress. This simplistic approach looks correct for the
cases w/o external changes. And to handle them properly, more sophisticated
and intrusive techniques (e.g. NFS-like one) would be required. I'd like to
postpone it until the issue is well discussed on the mailing list(s).
Changed in v2:
- improved patch description to cover both sides of the issue.
commit d331a415aef98717393dda0be69b7947da08eba3 upstream.
Calls like setxattr and removexattr result in updation of ctime.
Therefore invalidate inode attributes to force a refresh.
Signed-off-by: Anand Avati <avati@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
commit 4a4ac4eba1010ef9a804569058ab29e3450c0315 upstream.
The patch fixes a race between ftruncate(2), mmap-ed write and write(2):
2) The user performs shrinking truncate(2) intended to purge the page.
3) Before fuse_do_setattr calls truncate_pagecache, the page goes to
writeback. fuse_writepage_locked fills FUSE_WRITE request and releases
the original page by end_page_writeback.
4) fuse_do_setattr() completes and successfully returns. Since now, i_mutex
is free.
5) Ordinary write(2) extends i_size back to cover the page. Note that
fuse_send_write_pages do wait for fuse writeback, but for another
page->index.
6) fuse_writepage_locked proceeds by queueing FUSE_WRITE request.
fuse_send_writepage is supposed to crop inarg->size of the request,
but it doesn't because i_size has already been extended back.
Moving end_page_writeback to the end of fuse_writepage_locked fixes the
race because now the fact that truncate_pagecache is successfully returned
infers that fuse_writepage_locked has already called end_page_writeback.
And this, in turn, infers that fuse_flush_writepages has already called
fuse_send_writepage, and the latter used valid (shrunk) i_size. write(2)
could not extend it because of i_mutex held by ftruncate(2).
commit 494ddd11be3e2621096bb425eed2886f8e8446d4 upstream.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Reviewed-by: Sage Weil <sage@inktank.com>
commit 17b7f7cf58926844e1dd40f5eb5348d481deca6a upstream.
Refuse RW mount of isofs filesystem. So far we just silently changed it
tool mounting isofs is likely confronted with the case of read-only
commit aee1c13dd0f6c2fc56e0e492b349ee8ac655880f upstream.
Don't allow mounting the proc filesystem unless the caller has
CAP_SYS_ADMIN rights over the pid namespace. The principle here is if
you create or have capabilities over it you can mount it, otherwise
you get to live with what other people have mounted.
Andy pointed out that this is needed to prevent users in a user
namespace from remounting proc and specifying different hidepid and gid
options on already existing proc mounts.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream.
Call fiemap ioctl(2) with given start offset as well as an desired mapping
range should show extents if possible. However, we somehow figure out the
end offset of mapping via 'mapping_end -= cpos' before iterating the
extent records which would cause problems if the given fiemap length is
too small to a cluster size, e.g,
Cluster size 4096:
debugfs.ocfs2 1.6.3
Block Size Bits: 12 Cluster Size Bits: 12
The extended fiemap test utility From David:
https://gist.github.com/anonymous/6172331
# dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000
# ./fiemap /ocfs2/test_file 4096 10
start: 4096, length: 10
File /ocfs2/test_file has 0 extents:
# Logical Physical Length Flags
^^^^^ <-- No extent is shown
In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the
loop of searching extent records was not executed at all.
This patch remove the in question 'mapping_end -= cpos', and loops
until the cpos is larger than the mapping_end as usual.
File /ocfs2/test_file has 1 extents:
0: 0000000000000000 0000000056a01000 0000000006a00000 0000
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reported-by: David Weber <wb@munzinger.de>
Tested-by: David Weber <wb@munzinger.de>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Mark Fashen <mfasheh@suse.de>
commit bbb651e469d99f0088e286fdeb54acca7bb4ad4e upstream.
If you start the replace procedure on a read only filesystem, at
the end the procedure fails to write the updated dev_items to the
chunk tree. The problem is that this error is not indicated except
for a WARN_ON(). If the user now thinks that everything was done
as expected and destroys the source device (with mkfs or with a
hammer). The next mount fails with "failed to read chunk root" and
the filesystem is gone.
This commit adds code to fail the attempt to start the replace
procedure if the filesystem is mounted read-only.
Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
commit 5208386c501276df18fee464e21d3c58d2d79517 upstream.
Merge conditions in ext4_setattr() handling inode size changes, also
move ext4_begin_ordered_truncate() call somewhat earlier because it
simplifies error recovery in case of failure. Also add error handling in
case i_disksize update fails.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 933d4b36576c951d0371bbfed05ec0135d516a6e upstream.
If a server sends a lease break to a connection that doesn't have
opens with a lease key specified in the server response, we can't
find an open file to send an ack. Fix this by walking through
all connections we have.
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 1a05096de82f3cd672c76389f63964952678506f upstream.
This happens when we receive a lease break from a server, then
find an appropriate lease key in opened files and schedule the
oplock_break slow work. lw pointer isn't freed in this case.
commit 73e216a8a42c0ef3d08071705c946c38fdbe12b0 upstream.
Oleksii reported that he had seen an oops similar to this:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000088
IP: [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
PGD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: ipt_MASQUERADE xt_REDIRECT xt_tcpudp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables x_tables carl9170 ath usb_storage f2fs nfnetlink_log nfnetlink md4 cifs dns_resolver hid_generic usbhid hid af_packet uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_core videodev rfcomm btusb bnep bluetooth qmi_wwan qcserial cdc_wdm usb_wwan usbnet usbserial mii snd_hda_codec_hdmi snd_hda_codec_realtek iwldvm mac80211 coretemp intel_powerclamp kvm_intel kvm iwlwifi snd_hda_intel cfg80211 snd_hda_codec xhci_hcd e1000e ehci_pci snd_hwdep sdhci_pci snd_pcm ehci_hcd microcode psmouse sdhci thinkpad_acpi mmc_core i2c_i801 pcspkr usbcore hwmon snd_timer snd_page_alloc snd ptp rfkill pps_core soundcore evdev usb_common vboxnetflt(O) vboxdrv(O)Oops#2 Part8
loop tun binfmt_misc fuse msr acpi_call(O) ipv6 autofs4
CPU: 0 PID: 21612 Comm: kworker/0:1 Tainted: G W O 3.10.1SIGN #28
Hardware name: LENOVO 2306CTO/2306CTO, BIOS G2ET92WW (2.52 ) 02/22/2013
Workqueue: cifsiod cifs_echo_request [cifs]
task: ffff8801e1f416f0 ti: ffff880148744000 task.ti: ffff880148744000
RIP: 0010:[<ffffffff814dcc13>] [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
RSP: 0000:ffff880148745b00 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880148745b78 RCX: 0000000000000048
RDX: ffff880148745c90 RSI: ffff880181864a00 RDI: ffff880148745b78
RBP: ffff880148745c48 R08: 0000000000000048 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880181864a00
R13: ffff880148745c90 R14: 0000000000000048 R15: 0000000000000048
FS: 0000000000000000(0000) GS:ffff88021e200000(0000) knlGS:0000000000000000
CR2: 0000000000000088 CR3: 000000020c42c000 CR4: 00000000001407b0
Oops#2 Part7
Stack:
ffff880148745b30 ffffffff810c4af9 0000004848745b30 ffff880181864a00
ffffffff81ffbc40 0000000000000000 ffff880148745c90 ffffffff810a5aab
ffff880148745bc0 ffffffff81ffbc40 ffff880148745b60 ffffffff815a9fb8
Call Trace:
[<ffffffff810c4af9>] ? finish_task_switch+0x49/0xe0
[<ffffffff810a5aab>] ? lock_timer_base.isra.36+0x2b/0x50
[<ffffffff815a9fb8>] ? _raw_spin_unlock_irqrestore+0x18/0x40
[<ffffffff810a673f>] ? try_to_del_timer_sync+0x4f/0x70
[<ffffffff815aa38f>] ? _raw_spin_unlock_bh+0x1f/0x30
[<ffffffff814dcc87>] kernel_sendmsg+0x37/0x50
[<ffffffffa081a0e0>] smb_send_kvec+0xd0/0x1d0 [cifs]
[<ffffffffa081a263>] smb_send_rqst+0x83/0x1f0 [cifs]
[<ffffffffa081ab6c>] cifs_call_async+0xec/0x1b0 [cifs]
[<ffffffffa08245e0>] ? free_rsp_buf+0x40/0x40 [cifs]
Oops#2 Part6
[<ffffffffa082606e>] SMB2_echo+0x8e/0xb0 [cifs]
[<ffffffffa0808789>] cifs_echo_request+0x79/0xa0 [cifs]
[<ffffffff810b45b3>] process_one_work+0x173/0x4a0
[<ffffffff810b52a1>] worker_thread+0x121/0x3a0
[<ffffffff810b5180>] ? manage_workers.isra.27+0x2b0/0x2b0
[<ffffffff810bae00>] kthread+0xc0/0xd0
[<ffffffff810bad40>] ? kthread_create_on_node+0x120/0x120
[<ffffffff815b199c>] ret_from_fork+0x7c/0xb0
Code: 84 24 b8 00 00 00 4c 89 f1 4c 89 ea 4c 89 e6 48 89 df 4c 89 60 18 48 c7 40 28 00 00 00 00 4c 89 68 30 44 89 70 14 49 8b 44 24 28 <ff> 90 88 00 00 00 3d ef fd ff ff 74 10 48 8d 65 e0 5b 41 5c 41
RIP [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
RSP <ffff880148745b00>
The client was in the middle of trying to send a frame when the
server->ssocket pointer got zeroed out. In most places, that we access
that pointer, the srv_mutex is held. There's only one spot that I see
that the server->ssocket pointer gets set and the srv_mutex isn't held.
This patch corrects that.
The upstream bug report was here:
https://bugzilla.kernel.org/show_bug.cgi?id=60557
Reported-by: Oleksii Shevchuk <alxchk@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 44512449c0ab368889dd13ae0031fba74ee7e1d2 upstream.
NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..),
but jfs allows a value of 2 for a non-special entry. This incompatibility
can result in the nfs client reporting a readdir loop.
This patch doesn't change the value stored internally, but adds one to
the value exposed to the iterate method.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
[bwh: Backported to 3.2:
- Adjust context
- s/ctx->pos/filp->f_pos/]
Tested-by: Christian Kujau <lists@nerdbynature.de>
commit 35dc248383bbab0a7203fca4d722875bc81ef091 upstream.
There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances
leads to one process writing data into the address space of some other
random unrelated process if the ioctl is interrupted by a signal.
What happens is the following:
- A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the
underlying SCSI command will transfer data from the SCSI device to
the buffer provided in the ioctl)
- Before the command finishes, a signal is sent to the process waiting
in the ioctl. This will end up waking up the sg_ioctl() code:
result = wait_event_interruptible(sfp->read_wait,
(srp_done(sfp, srp) || sdp->detached));
but neither srp_done() nor sdp->detached is true, so we end up just
setting srp->orphan and returning to userspace:
srp->orphan = 1;
write_unlock_irq(&sfp->rq_list_lock);
return result; /* -ERESTARTSYS because signal hit process */
At this point the original process is done with the ioctl and
blithely goes ahead handling the signal, reissuing the ioctl, etc.
- Eventually, the SCSI command issued by the first ioctl finishes and
ends up in sg_rq_end_io(). At the end of that function, we run through:
write_lock_irqsave(&sfp->rq_list_lock, iflags);
if (unlikely(srp->orphan)) {
if (sfp->keep_orphan)
srp->sg_io_owned = 0;
else
done = 0;
srp->done = done;
write_unlock_irqrestore(&sfp->rq_list_lock, iflags);
if (likely(done)) {
/* Now wake up any sg_read() that is waiting for this
* packet.
wake_up_interruptible(&sfp->read_wait);
kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN);
kref_put(&sfp->f_ref, sg_remove_sfp);
} else {
INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext);
schedule_work(&srp->ew.work);
Since srp->orphan *is* set, we set done to 0 (assuming the
userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN
ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext()
to run in a workqueue.
- In workqueue context we go through sg_rq_end_io_usercontext() ->
sg_finish_rem_req() -> blk_rq_unmap_user() -> ... ->
bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user().
The key point here is that we are doing copy_to_user() on a
workqueue -- that is, we're on a kernel thread with current->mm
equal to whatever random previous user process was scheduled before
this kernel thread. So we end up copying whatever data the SCSI
command returned to the virtual address of the buffer passed into
the original ioctl, but it's quite likely we do this copying into a
different address space!
As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>,
add a check for current->mm (which is NULL if we're on a kernel thread
without a real userspace address space) in bio_uncopy_user(), and skip
the copy if we're on a kernel thread.
There's no reason that I can think of for any caller of bio_uncopy_user()
to want to do copying on a kernel thread with a random active userspace
address space.
Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the
original pointer to this bug in the sg code.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: David Milburn <dmilburn@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
error detection
commit 4bf93b50fd04118ac7f33a3c2b8a0a1f9fa80bc9 upstream.
Fix the issue with improper counting number of flying bio requests for
BIO_EOPNOTSUPP error detection case.
The sb_nbio must be incremented exactly the same number of times as
complete() function was called (or will be called) because
nilfs_segbuf_wait() will call wail_for_completion() for the number of
times set to sb_nbio:
do {
wait_for_completion(&segbuf->sb_bio_event);
} while (--segbuf->sb_nbio > 0);
Two functions complete() and wait_for_completion() must be called the
same number of times for the same sb_bio_event. Otherwise,
wait_for_completion() will hang or leak.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
error
commit 2df37a19c686c2d7c4e9b4ce1505b5141e3e5552 upstream.
Remove double call of bio_put() in nilfs_end_bio_write() for the case of
BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter
and he suggests first version of the fix too.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 52e220d357a38cb29fa2e29f34ed94c1d66357f4 upstream.
This should actually be returning an ERR_PTR on error instead of NULL.
That was how it was designed and all the callers expect it.
[AV: actually, that's what "VFS: Make clone_mnt()/copy_tree()/collect_mounts()
return errors" missed - originally collect_mounts() was expected to return
NULL on failure]
commit 91aa11fae1cf8c2fd67be0609692ea9741cdcc43 upstream.
When jbd2_journal_dirty_metadata() returns error,
__ext4_handle_dirty_metadata() stops the handle. However callers of this
function do not count with that fact and still happily used now freed
handle. This use after free can result in various issues but very likely
we oops soon.
The motivation of adding __ext4_journal_stop() into
__ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to
improve error reporting. So replace __ext4_journal_stop() with
ext4_journal_abort_handle() which was there before that commit and add
WARN_ON_ONCE() to dump stack to provide useful information.
Reported-by: Sage Weil <sage@inktank.com>
commit 2b047252d087be7f2ba088b4933cd904f92e6fce upstream.
Ben Tebulin reported:
"Since v3.7.2 on two independent machines a very specific Git
repository fails in 9/10 cases on git-fsck due to an SHA1/memory
failures. This only occurs on a very specific repository and can be
reproduced stably on two independent laptops. Git mailing list ran
out of ideas and for me this looks like some very exotic kernel issue"
and bisected the failure to the backport of commit 53a59fc67f97 ("mm:
limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT").
That commit itself is not actually buggy, but what it does is to make it
much more likely to hit the partial TLB invalidation case, since it
introduces a new case in tlb_next_batch() that previously only ever
happened when running out of memory.
The real bug is that the TLB gather virtual memory range setup is subtly
buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather:
enable tlb flush range in generic mmu_gather"), and the range handling
was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB
range flushed when __tlb_remove_page() runs out of slots"), but that fix
was not complete.
The problem with the TLB gather virtual address range is that it isn't
set up by the initial tlb_gather_mmu() initialization (which didn't get
the TLB range information), but it is set up ad-hoc later by the
functions that actually flush the TLB. And so any such case that forgot
to update the TLB range entries would potentially miss TLB invalidates.
Rather than try to figure out exactly which particular ad-hoc range
setup was missing (I personally suspect it's the hugetlb case in
zap_huge_pmd(), which didn't have the same logic as zap_pte_range()
did), this patch just gets rid of the problem at the source: make the
TLB range information available to tlb_gather_mmu(), and initialize it
when initializing all the other tlb gather fields.
This makes the patch larger, but conceptually much simpler. And the end
result is much more understandable; even if you want to play games with
partial ranges when invalidating the TLB contents in chunks, now the
range information is always there, and anybody who doesn't want to
bother with it won't introduce subtle bugs.
Ben verified that this fixes his problem.
Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com>
Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au>
Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 8c8296223f3abb142be8fc31711b18a704c0e7d8 upstream.
Recently we met quite a lot of random kernel panic issues after enabling
CONFIG_PROC_PAGE_MONITOR. After debuggind we found this has something
to do with following bug in pagemap:
In struct pagemapread:
struct pagemapread {
int pos, len;
pagemap_entry_t *buffer;
bool v2;
pos is number of PM_ENTRY_BYTES in buffer, but len is the size of
buffer, it is a mistake to compare pos and len in add_page_map() for
checking buffer is full or not, and this can lead to buffer overflow and
random kernel panic issue.
Correct len to be total number of PM_ENTRY_BYTES in buffer.
[akpm@linux-foundation.org: document pagemapread.pos and .len units, fix PM_ENTRY_BYTES definition]
Signed-off-by: Yonghua Zheng <younghua.zheng@gmail.com>
commit 672fe15d091ce76d6fb98e489962e9add7c1ba4c upstream.
Since remove_proc_entry() started to wait for IO in progress (i.e.
since 2007 or so), the locking in fs/reiserfs/proc.c became wrong;
if procfs read happens between the moment when umount() locks the
victim superblock and removal of /proc/fs/reiserfs/<device>/*,
we'll get a deadlock - read will wait for s_umount (in sget(),
called by r_start()), while umount will wait in remove_proc_entry()
for that read to finish, holding s_umount all along.
Fortunately, the same change allows a much simpler race avoidance -
all we need to do is remove the procfs entries in the very beginning
of reiserfs ->kill_sb(); that'll guarantee that pointer to superblock
will remain valid for the duration for procfs IO, so we don't need
sget() to keep the sucker alive. As the matter of fact, we can
get rid of the home-grown iterator completely, and use single_open()
instead.
commit 776164c1faac4966ab14418bb0922e1820da1d19 upstream.
debugfs_remove_recursive() is wrong,
1. it wrongly assumes that !list_empty(d_subdirs) means that this
dir should be removed.
This is not that bad by itself, but:
2. if d_subdirs does not becomes empty after __debugfs_remove()
it gives up and silently fails, it doesn't even try to remove
other entries.
However ->d_subdirs can be non-empty because it still has the
already deleted !debugfs_positive() entries.
3. simple_release_fs() is called even if __debugfs_remove() fails.
Suppose we have
dir1/
dir2/
file2
file1
and someone opens dir1/dir2/file2.
Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes
away.
But debugfs_remove_recursive(dir1) silently fails and doesn't remove
this directory. Because it tries to delete (the already deleted)
dir1/dir2/file2 again and then fails due to "Avoid infinite loop"
logic.
Test-case:
#!/bin/sh
cd /sys/kernel/debug/tracing
echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events
sleep 1000 < events/probe/sigprocmask/id &
echo -n >| kprobe_events
[ -d events/probe ] && echo "ERR!! failed to rm probe"
And after that it is not possible to create another probe entry.
With this patch debugfs_remove_recursive() skips !debugfs_positive()
files although this is not strictly needed. The most important change
is that it does not try to make ->d_subdirs empty, it simply scans
the whole list(s) recursively and removes as much as possible.
Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
revalidated immediately
commit 757c4f6260febff982276818bb946df89c1105aa upstream.
David reported that commit c2b93e06 (cifs: only set ops for inodes in
I_NEW state) caused a regression with mfsymlinks. Prior to that patch,
if a mfsymlink dentry was instantiated at readdir time, the inode would
get a new set of ops when it was revalidated. After that patch, this
did not occur.
This patch addresses this by simply skipping instantiating dentries in
the readdir codepath when we know that they will need to be immediately
revalidated. The next attempt to use that dentry will cause a new lookup
to occur (which is basically what we want to happen anyway).
Reported-and-Tested-by: David McBride <dwm37@cam.ac.uk>
Cc: "Stefan (metze) Metzmacher" <metze@samba.org>
Cc: Sachin Prabhu <sprabhu@redhat.com>
commit 057d6332b24a4497c55a761c83c823eed9e3f23b upstream.
For cifs_set_cifscreds() in "fs/cifs/connect.c", 'desc' buffer length
is 'CIFSCREDS_DESC_SIZE' (56 is less than 256), and 'ses->domainName'
length may be "255 + '\0'".
The related sprintf() may cause memory overflow, so need extend related
buffer enough to hold all things.
It is also necessary to be sure of 'ses->domainName' must be less than
256, and define the related macro instead of hard code number '256'.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Reviewed-by: Scott Lovenberg <scott.lovenberg@gmail.com>
commit cde2d7a796f7e895e25b43471ed658079345636d upstream.
Previously we weren't swapping only some of the extent_status LRU
fields during the processing of the EXT4_IOC_SWAP_BOOT ioctl. The
much safer thing to do is to just completely flush the extent status
tree when doing the swap.
Cc: Zheng Liu <gnehzuil.liu@gmail.com>
commit 6ae6514b33f941d3386da0dfbe2942766eab1577 upstream.
Commit 5688978 ("ext4: improve handling of conflicting mount options")
introduced incorrect messages shown while choosing wrong mount options.
First of all, both cases of incorrect mount options,
"data=journal,delalloc" and "data=journal,dioread_nolock" result in
the same error message.
Secondly, the problem above isn't solved for remount option: the
mismatched parameter is simply ignored. Moreover, ext4_msg states
that remount with options "data=journal,delalloc" succeeded, which is
not true.
To fix it up, I added a simple check after parse_options() call to
ensure that data=journal and delalloc/dioread_nolock parameters are
not present at the same time.
Signed-off-by: Piotr Sarna <p.sarna@partner.samsung.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 59d9fa5c2e9086db11aa287bb4030151d0095a17 upstream.
Commit 26092bf ("ext4: use a table-driven handler for mount options")
wrongly disallows the specifying the mount options nodelalloc and
data=journal simultaneously. This is incorrect; it should have only
disallowed the combination of delalloc and data=journal
simultaneously.
Reported-by: Piotr Sarna <p.sarna@partner.samsung.com>
commit 9a1b6bf818e74bb7aabaecb59492b739f2f4d742 upstream.
Firstly, nlmclnt_setlockargs can be called from a reclaimer thread, in
which case we're in entirely the wrong namespace.
Secondly, commit 8aac62706adaaf0fab02c4327761561c8bda9448 (move
exit_task_namespaces() outside of exit_notify()) now means that
exit_task_work() is called after exit_task_namespaces(), which
triggers an Oops when we're freeing up the locks.
Fix this by ensuring that we initialise the nlm_host's rpc_client at mount
time, so that the cl_nodename field is initialised to the value of
utsname()->nodename that the net namespace uses. Then replace the
lockd callers of utsname()->nodename.
Cc: Toralf Förster <toralf.foerster@gmx.de>
Cc: Nix <nix@esperi.org.uk>
Cc: Jeff Layton <jlayton@redhat.com>
commit f3b15ccdbb9a79781578249a63318805e55a6c34 upstream.
The ceph guys tripped over this bug where we were still holding onto the
original path that we used to copy the inode with when logging. This is based
on Chris's fix which was reported to fix the problem. We need to drop the paths
in two cases anyway so just move the drop up so that we don't have duplicate
code. Thanks,
commit 94eec0fc3520c759831763d866421b4d60b599b4 upstream.
We tested for ENOMEM instead of -ENOMEM. Oops.
commit a34eb503742fd25155fd6cff6163daacead9fbc3 upstream.
When we try to allocate an inode, and there is a race between two
CPU's trying to grab the same inode, _and_ this inode is the last free
inode in the block group, make sure the group number is bumped before
we continue searching the rest of the block groups. Otherwise, we end
up searching the current block group twice, and we end up skipping
searching the last block group. So in the unlikely situation where
almost all of the inodes are allocated, it's possible that we will
return ENOSPC even though there might be free inodes in that last
block group.
commit dd12ed144e9797094c04736f97aa27d5fe401476 upstream.
Without this, module can't be reloaded.
[ 500.521980] kmem_cache_sanity_check (ext4_extent_status): Cache name already exists.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit 35f0399db6658f465b00893bdd13b992a0acfef0 upstream.
Several users reported this crash of NULL pointer or general protection,
the story is that we add a rbtree for speedup ulist iteration, and we
use krealloc() to address ulist growth, and krealloc() use memcpy to copy
old data to new memory area, so it's OK for an array as it doesn't use
pointers while it's not OK for a rbtree as it uses pointers.
So krealloc() will mess up our rbtree and it ends up with crash.
Reviewed-by: Wang Shilong <wangsl-fnst@cn.fujitsu.com>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Cc: BJ Quinn <bj@placs.net>
commit de1e0c40aceb9d5bff09c3a3b97b2f1b178af53f upstream.
The ->reserved field isn't cleared so we leak one byte of stack
information to userspace.
Cc: Eric Paris <eparis@redhat.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
