commit 3d2660d0c9c2f296837078c189b68a47f6b2e3b5 upstream.
The set_flexbg_block_bitmap() function assumed that the number of
blocks in a blockgroup was sb->blocksize * 8, which is normally true,
but not always! Use EXT4_BLOCKS_PER_GROUP(sb) instead, to fix block
bitmap corruption after:
mke2fs -t ext4 -g 3072 -i 4096 /dev/vdd 1G
mount -t ext4 /dev/vdd /vdd
resize2fs /dev/vdd 8G
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Jon Bernard <jbernard@tuxion.com>
commit b93c95353413041a8cebad915a8109619f66bcc6 upstream.
If a file system has a large number of inodes per block group, all of
the metadata blocks in a flex_bg may be larger than what can fit in a
single block group. Unfortunately, ext4_alloc_group_tables() in
resize.c was never tested to see if it would handle this case
correctly, and there were a large number of bugs which caused the
following sequence to result in a BUG_ON:
kernel bug at fs/ext4/resize.c:409!
call trace:
[<ffffffff81256768>] ext4_flex_group_add+0x1448/0x1830
[<ffffffff81257de2>] ext4_resize_fs+0x7b2/0xe80
[<ffffffff8123ac50>] ext4_ioctl+0xbf0/0xf00
[<ffffffff811c111d>] do_vfs_ioctl+0x2dd/0x4b0
[<ffffffff811b9df2>] ? final_putname+0x22/0x50
[<ffffffff811c1371>] sys_ioctl+0x81/0xa0
[<ffffffff81676aa9>] system_call_fastpath+0x16/0x1b
code: c8 4c 89 df e8 41 96 f8 ff 44 89 e8 49 01 c4 44 29 6d d4 0
rip [<ffffffff81254fa1>] set_flexbg_block_bitmap+0x171/0x180
This can be reproduced with the following command sequence:
mke2fs -t ext4 -i 4096 /dev/vdd 1G
To fix this, we need to make sure the right thing happens when a block
group's inode table straddles two block groups, which means the
following bugs had to be fixed:
1) Not clearing the BLOCK_UNINIT flag in the second block group in
ext4_alloc_group_tables --- the was proximate cause of the BUG_ON.
2) Incorrectly determining how many block groups contained contiguous
free blocks in ext4_alloc_group_tables().
3) Incorrectly setting the start of the next block range to be marked
in use after a discontinuity in setup_new_flex_group_blocks().
commit 23301410972330c0ae9a8afc379ba2005e249cc6 upstream.
If an ext4 file system is created by some tool other than mke2fs
(perhaps by someone who has a pathalogical fear of the GPL) that
doesn't set one or the other of the EXT2_FLAGS_{UN}SIGNED_HASH flags,
and that file system is then mounted read-only, don't try to modify
the s_flags field. Otherwise, if dm_verity is in use, the superblock
will change, causing an dm_verity failure.
commit 30d29b119ef01776e0a301444ab24defe8d8bef3 upstream.
In swap_inode_boot_loader() we forgot to release ->i_mutex and resume
unlocked dio for inode and inode_bl if there is an error starting the
journal handle. This commit fixes this issue.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Dr. Tilmann Bubeck <t.bubeck@reinform.de>
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
commit 087787959ce851d7bbb19f10f6e9241b7f85a3ca upstream.
Commit 9f060e2231ca changed the way we handle allocations for the
integrity vectors. When the vectors are inline there is no associated
slab and consequently bvec_nr_vecs() returns 0. Ensure that we check
against BIP_INLINE_VECS in that case.
Reported-by: David Milburn <dmilburn@redhat.com>
Tested-by: David Milburn <dmilburn@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 2ec197db1a56c9269d75e965f14c344b58b2a4f6 upstream.
If an NFS client attempts to get a lock (using NLM) and the lock is
not available, the server will remember the request and when the lock
becomes available it will send a GRANT request to the client to
provide the lock.
If the client already held an adjacent lock, the GRANT callback will
report the union of the existing and new locks, which can confuse the
client.
This happens because __posix_lock_file (called by vfs_lock_file)
updates the passed-in file_lock structure when adjacent or
over-lapping locks are found.
To avoid this problem we take a copy of the two fields that can
be changed (fl_start and fl_end) before the call and restore them
afterwards.
An alternate would be to allocate a 'struct file_lock', initialise it,
use locks_copy_lock() to take a copy, then locks_release_private()
after the vfs_lock_file() call. But that is a lot more work.
Reported-by: Olaf Kirch <okir@suse.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
v1 had a couple of issues (large on-stack struct and didn't really work properly).
This version is much better tested.
commit 83e3bc23ef9ce7c03b7b4e5d3d790246ea59db3e upstream.
The get/set ACL xattr support for CIFS ACLs attempts to send old
cifs dialect protocol requests even when mounted with SMB2 or later
dialects. Sending cifs requests on an smb2 session causes problems -
the server drops the session due to the illegal request.
This patch makes CIFS ACL operations protocol specific to fix that.
Attempting to query/set CIFS ACLs for SMB2 will now return
EOPNOTSUPP (until we add worker routines for sending query
ACL requests via SMB2) instead of sending invalid (cifs)
requests.
A separate followon patch will be needed to fix cifs_acl_to_fattr
(which takes a cifs specific u16 fid so can't be abstracted
to work with SMB2 until that is changed) and will be needed
to fix mount problems when "cifsacl" is specified on mount
with e.g. vers=2.1
Signed-off-by: Steve French <smfrench@gmail.com>
Reviewed-by: Shirish Pargaonkar <spargaonkar@suse.com>
commit d979f3b0a1f0b5499ab85e68cdf02b56852918b6 upstream.
Changeset 666753c3ef8fc88b0ddd5be4865d0aa66428ac35 added protocol
operations for get/setxattr to avoid calling cifs operations
on smb2/smb3 mounts for xattr operations and this changeset
adds the calls to cifs specific protocol operations for xattrs
(in order to reenable cifs support for xattrs which was
temporarily disabled by the previous changeset. We do not
have SMB2/SMB3 worker function for setting xattrs yet so
this only enables it for cifs.
CCing stable since without these two small changsets (its
small coreq 666753c3ef8fc88b0ddd5be4865d0aa66428ac35 is
also needed) calling getfattr/setfattr on smb2/smb3 mounts
causes problems.
commit 666753c3ef8fc88b0ddd5be4865d0aa66428ac35 upstream.
When mounting with smb2 (or smb2.1 or smb3) we need to check to make
sure that attempts to query or set extended attributes do not
attempt to send the request with the older cifs protocol instead
(eventually we also need to add the support in SMB2
to query/set extended attributes but this patch prevents us from
using the wrong protocol for extended attribute operations).
commit 96c7a2ff21501691587e1ae969b83cbec8b78e08 upstream.
Recently due to a spike in connections per second memcached on 3
separate boxes triggered the OOM killer from accept. At the time the
OOM killer was triggered there was 4GB out of 36GB free in zone 1. The
problem was that alloc_fdtable was allocating an order 3 page (32KiB) to
hold a bitmap, and there was sufficient fragmentation that the largest
page available was 8KiB.
I find the logic that PAGE_ALLOC_COSTLY_ORDER can't fail pretty dubious
but I do agree that order 3 allocations are very likely to succeed.
There are always pathologies where order > 0 allocations can fail when
there are copious amounts of free memory available. Using the pigeon
hole principle it is easy to show that it requires 1 page more than 50%
of the pages being free to guarantee an order 1 (8KiB) allocation will
succeed, 1 page more than 75% of the pages being free to guarantee an
order 2 (16KiB) allocation will succeed and 1 page more than 87.5% of
the pages being free to guarantee an order 3 allocate will succeed.
A server churning memory with a lot of small requests and replies like
memcached is a common case that if anything can will skew the odds
against large pages being available.
Therefore let's not give external applications a practical way to kill
linux server applications, and specify __GFP_NORETRY to the kmalloc in
alloc_fdmem. Unless I am misreading the code and by the time the code
reaches should_alloc_retry in __alloc_pages_slowpath (where
__GFP_NORETRY becomes signification). We have already tried everything
reasonable to allocate a page and the only thing left to do is wait. So
not waiting and falling back to vmalloc immediately seems like the
reasonable thing to do even if there wasn't a chance of triggering the
OOM killer.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Cong Wang <cwang@twopensource.com>
commit 227d53b397a32a7614667b3ecaf1d89902fb6c12 upstream.
To use spin_{un}lock_irq is dangerous if caller disabled interrupt.
During aio buffer migration, we have a possibility to see the following
call stack.
aio_migratepage [disable interrupt]
migrate_page_copy
clear_page_dirty_for_io
set_page_dirty
__set_page_dirty_buffers
__set_page_dirty
spin_lock_irq
This mean, current aio migration is a deadlockable. spin_lock_irqsave
is a safer alternative and we should use it.
Reported-by: David Rientjes rientjes@google.com>
commit 8101c8dbf6243ba517aab58d69bf1bc37d8b7b9c upstream.
It's just broken and it's taking a lot of effort to fix it, so for now just
disable it so people can defrag in peace. Thanks,
Signed-off-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Chris Mason <clm@fb.com>
commit ed7e5423014ad89720fcf315c0b73f2c5d0c7bd2 upstream.
An NFS4ERR_RECALLCONFLICT is returned by server from a GET_LAYOUT
only when a Server Sent a RECALL do to that GET_LAYOUT, or
the RECALL and GET_LAYOUT crossed on the wire.
In any way this means we want to wait at most until in-flight IO
is finished and the RECALL can be satisfied.
So a proper wait here is more like 1/10 of a second, not 15 seconds
like we have now. In case of a server bug we delay exponentially
longer on each retry.
Current code totally craps out performance of very large files on
most pnfs-objects layouts, because of how the map changes when the
file has grown into the next raid group.
[Stable: This will patch back to 3.9. If there are earlier still
maintained trees, please tell me I'll send a patch]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit abad2fa5ba67725a3f9c376c8cfe76fbe94a3041 upstream.
If clp is new (cl_count = 1) and it matches another client in
nfs4_discover_server_trunking, the nfs_put_client will free clp before
->cl_preserve_clid is set.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
commit 64590daa9e0dfb3aad89e3ab9230683b76211d5b upstream.
Both nfs41_walk_client_list and nfs40_walk_client_list expect the
'status' variable to be set to the value -NFS4ERR_STALE_CLIENTID
if the loop fails to find a match.
The problem is that the 'pos->cl_cons_state > NFS_CS_READY' changes
the value of 'status', and sets it either to the value '0' (which
indicates success), or to the value EINTR.
commit 78b19bae0813bd6f921ca58490196abd101297bd upstream.
Don't check for -NFS4ERR_NOTSUPP, it's already been mapped to -ENOTSUPP
by nfs4_stat_to_errno.
This allows the client to mount v4.1 servers that don't support
SECINFO_NO_NAME by falling back to the "guess and check" method of
nfs4_find_root_sec.
commit c7848f69ec4a8c03732cde5c949bd2aa711a9f4b upstream.
decode_op_hdr() cannot distinguish between an XDR decoding error and
the perfectly valid errorcode NFS4ERR_IO. This is normally not a
problem, but for the particular case of OPEN, we need to be able
to increment the NFSv4 open sequence id when the server returns
a valid response.
Reported-by: J Bruce Fields <bfields@fieldses.org>
Link: http://lkml.kernel.org/r/20131204210356.GA19452@fieldses.org
commit aad560b7f63b495f48a7232fd086c5913a676e6f upstream.
At IO preparation we calculate the max pages at each device and
allocate a BIO per device of that size. The calculation was wrong
on some unaligned corner cases offset/length combination and would
make prepare return with -ENOMEM. This would be bad for pnfs-objects
that would in that case IO through MDS. And fatal for exofs were it
would fail writes with EIO.
Fix it by doing the proper math, that will work in all cases. (I
ran a test with all possible offset/length combinations this time
round).
Also when reading we do not need to allocate for the parity units
since we jump over them.
Also lower the max_io_length to take into account the parity pages
so not to allocate BIOs bigger than PAGE_SIZE
commit d8d14bd09cddbaf0168d61af638455a26bd027ff upstream.
Commit d5dc77bfeeab ("consolidate compat lookup_dcookie()") coverted all
architectures to the new compat_sys_lookup_dcookie() syscall.
The "len" paramater of the new compat syscall must have the type
compat_size_t in order to enforce zero extension for architectures where
the ABI requires that the caller of a function performed zero and/or
sign extension to 64 bit of all parameters.
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
commit dfd948e32af2e7b28bcd7a490c0a30d4b8df2a36 upstream.
We got a report that the pwritev syscall does not work correctly in
compat mode on s390.
It turned out that with commit 72ec35163f9f ("switch compat readv/writev
variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a
couple of syscall parameters because the some parameter types haven't
been converted from unsigned long to compat_ulong_t.
This is needed for architectures where the ABI requires that the caller
of a function performed zero and/or sign extension to 64 bit of all
parameters.
commit 592f6b842f64e416c7598a1b97c649b34241e22d upstream.
Commit 91c2e0bcae72 ("unify compat fanotify_mark(2), switch to
COMPAT_SYSCALL_DEFINE") added a new unified compat fanotify_mark syscall
to be used by all architectures.
Unfortunately the unified version merges the split mask parameter in a
wrong way: the lower and higher word got swapped.
This was discovered with glibc's tst-fanotify test case.
Reported-by: Andreas Krebbel <krebbel@linux.vnet.ibm.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Acked-by: "David S. Miller" <davem@davemloft.net>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
commit 28a625cbc2a14f17b83e47ef907b2658576a32aa upstream.
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit d024206133ce21936b3d5780359afc00247655b7 upstream.
Currently, any user can snapshot any subvolume if the path is accessible and
thus indirectly create and keep files he does not own under his direcotries.
This is not possible with traditional directories.
In security context, a user can snapshot root filesystem and pin any
potentially buggy binaries, even if the updates are applied.
All the snapshots are visible to the administrator, so it's possible to
verify if there are suspicious snapshots.
Another more practical problem is that any user can pin the space used
by eg. root and cause ENOSPC.
Original report:
https://bugs.launchpad.net/ubuntu/+source/apparmor/+bug/484786
Signed-off-by: David Sterba <dsterba@suse.cz>
commit 90515e7f5d7d24cbb2a4038a3f1b5cfa2921aa17 upstream.
We may return early in btrfs_drop_snapshot(), we shouldn't
call btrfs_std_err() for this case, fix it.
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
commit 260a459d2e39761fbd39803497205ce1690bc7b1 upstream.
A bug was introduced with the is_mounted helper function in
commit f7a99c5b7c8bd3d3f533c8b38274e33f3da9096e
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sat Jun 9 00:59:08 2012 -0400
get rid of ->mnt_longterm
it's enough to set ->mnt_ns of internal vfsmounts to something
distinct from all struct mnt_namespace out there; then we can
just use the check for ->mnt_ns != NULL in the fast path of
mntput_no_expire()
The intent was to test if the real_mount(vfsmount)->mnt_ns was
NULL_OR_ERR but the code is actually testing real_mount(vfsmount)
and always returning true.
The result is d_absolute_path returning paths it should be hiding.
commit 09c455aaa8f47a94d5bafaa23d58365768210507 upstream.
A missing cast means that when we are truncating a file which is less
than 60 bytes, we don't clear the correct area of memory, and in fact
we can end up truncating the next inode in the inode table, or worse
yet, some other kernel data structure.
Addresses-Coverity-Id: #751987
commit 70f2fe3a26248724d8a5019681a869abdaf3e89a upstream.
There is a bug in the function nilfs_segctor_collect, which results in
active data being written to a segment, that is marked as clean. It is
possible, that this segment is selected for a later segment
construction, whereby the old data is overwritten.
The problem shows itself with the following kernel log message:
nilfs_sufile_do_cancel_free: segment 6533 must be clean
Usually a few hours later the file system gets corrupted:
NILFS: bad btree node (blocknr=8748107): level = 0, flags = 0x0, nchildren = 0
NILFS error (device sdc1): nilfs_bmap_last_key: broken bmap (inode number=114660)
The issue can be reproduced with a file system that is nearly full and
with the cleaner running, while some IO intensive task is running.
Although it is quite hard to reproduce.
This is what happens:
1. The cleaner starts the segment construction
2. nilfs_segctor_collect is called
3. sc_stage is on NILFS_ST_SUFILE and segments are freed
4. sc_stage is on NILFS_ST_DAT current segment is full
5. nilfs_segctor_extend_segments is called, which
allocates a new segment
6. The new segment is one of the segments freed in step 3
7. nilfs_sufile_cancel_freev is called and produces an error message
8. Loop around and the collection starts again
9. sc_stage is on NILFS_ST_SUFILE and segments are freed
including the newly allocated segment, which will contain active
data and can be allocated at a later time
10. A few hours later another segment construction allocates the
segment and causes file system corruption
This can be prevented by simply reordering the statements. If
nilfs_sufile_cancel_freev is called before nilfs_segctor_extend_segments
the freed segments are marked as dirty and cannot be allocated any more.
Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net>
Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Andreas Rohner <andreas.rohner@gmx.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit f9b0e058cbd04ada76b13afffa7e1df830543c24 upstream.
Commit 4f8ad655dbc8 "writeback: Refactor writeback_single_inode()" added
a condition to skip clean inode. However this is wrong in WB_SYNC_ALL
mode because there we also want to wait for outstanding writeback on
possibly clean inode. This was causing occasional data corruption issues
on NFS because it uses sync_inode() to make sure all outstanding writes
are flushed to the server before truncating the inode and with
sync_inode() returning prematurely file was sometimes extended back
by an outstanding write after it was truncated.
So modify the test to also check for pages under writeback in
WB_SYNC_ALL mode.
Fixes: 4f8ad655dbc82cf05d2edc11e66b78a42d38bf93
Reported-and-tested-by: Dan Duval <dan.duval@oracle.com>
commit f48cfddc6729ef133933062320039808bafa6f45 upstream.
Aditya Kali (adityakali@google.com) wrote:
> Commit bf056bfa80596a5d14b26b17276a56a0dcb080e5:
> "proc: Fix the namespace inode permission checks." converted
> the namespace files into symlinks. The same commit changed
> the way namespace bind mounts appear in /proc/mounts:
> $ mount --bind /proc/self/ns/ipc /mnt/ipc
> Originally:
> $ cat /proc/mounts | grep ipc
> proc /mnt/ipc proc rw,nosuid,nodev,noexec 0 0
> After commit bf056bfa80596a5d14b26b17276a56a0dcb080e5:
> proc ipc:[4026531839] proc rw,nosuid,nodev,noexec 0 0
> This breaks userspace which expects the 2nd field in
> /proc/mounts to be a valid path.
The symlink /proc/<pid>/ns/{ipc,mnt,net,pid,user,uts} point to
dentries allocated with d_alloc_pseudo that we can mount, and
that have interesting names printed out with d_dname.
When these files are bind mounted /proc/mounts is not currently
displaying the mount point correctly because d_dname is called instead
of just displaying the path where the file is mounted.
Solve this by adding an explicit check to distinguish mounted pseudo
inodes and unmounted pseudo inodes. Unmounted pseudo inodes always
use mount of their filesstem as the mnt_root in their path making
these two cases easy to distinguish.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Aditya Kali <adityakali@google.com>
commit 62e96cf81988101fe9e086b2877307b6adda5197 upstream.
This patch calls get_write_access in function gfs2_setattr_chown,
which merely increases inode->i_writecount for the duration of the
function. That will ensure that any file closes won't delete the
inode's multi-block reservation while the function is running.
It also ensures that a multi-block reservation exists when needed
for quota change operations during the chown.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit d0abafac8c9162f39c4f6b2f8141b772a09b3770 upstream.
Commit f5a44db5d2 introduced a regression on filesystems created with
the bigalloc feature (cluster size > blocksize). It causes xfstests
generic/006 and /013 to fail with an unexpected JBD2 failure and
transaction abort that leaves the test file system in a read only state.
Other xfstests run on bigalloc file systems are likely to fail as well.
The cause is the accidental use of a cluster mask where a cluster
offset was needed in ext4_ext_map_blocks().
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
Cc: Theodore Ts'o <tytso@mit.edu>
commit ee7289bfadda5f4ef60884547ebc9989c8fb314a upstream.
For sync_read/write, it may do multi stripe operations.If one of those
met erro, we return the former successed size rather than a error value.
There is a exception for write-operation met -EOLDSNAPC.If this occur,we
retry the whole write again.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
commit 02ae66d8b229708fd94b764f6c17ead1c7741fcf upstream.
cephfs . show_layout
>layyout.data_pool: 0
>layout.object_size: 4194304
>layout.stripe_unit: 4194304
>layout.stripe_count: 1
TestA:
>dd if=/dev/urandom of=test bs=1M count=2 oflag=direct
>dd if=/dev/urandom of=test bs=1M count=2 seek=4 oflag=direct
>dd if=test of=/dev/null bs=6M count=1 iflag=direct
The messages from func striped_read are:
ceph: file.c:350 : striped_read 0~6291456 (read 0) got 2097152 HITSTRIPE SHORT
ceph: file.c:350 : striped_read 2097152~4194304 (read 2097152) got 0 HITSTRIPE SHORT
ceph: file.c:381 : zero tail 4194304
ceph: file.c:390 : striped_read returns 6291456
The hole of file is from 2M--4M.But actualy it zero the last 4M include
the last 2M area which isn't a hole.
Using this patch, the messages are:
ceph: file.c:358 : zero gap 2097152 to 4194304
ceph: file.c:350 : striped_read 4194304~2097152 (read 4194304) got 2097152
ceph: file.c:384 : striped_read returns 6291456
TestB:
>echo majianpeng > test
>dd if=test of=/dev/null bs=2M count=1 iflag=direct
The messages are:
ceph: file.c:350 : striped_read 0~6291456 (read 0) got 11 HITSTRIPE SHORT
ceph: file.c:350 : striped_read 11~6291445 (read 11) got 0 HITSTRIPE SHORT
ceph: file.c:390 : striped_read returns 11
For this case,it did once more striped_read.It's no meaningless.
Using this patch, the message are:
ceph: file.c:384 : striped_read returns 11
Big thanks to Yan Zheng for the patch.
Reviewed-by: Yan, Zheng <zheng.z.yan@intel.com>
commit 2fbcbff1d6b9243ef71c64a8ab993bc3c7bb7af1 upstream.
Func ceph_calc_ceph_pg maybe failed.So add check for returned value.
Reviewed-by: Sage Weil <sage@inktank.com>
Signed-off-by: Sage Weil <sage@inktank.com>
commit 688bac461ba3e9d221a879ab40b687f5d7b5b19c upstream.
We pass in a u64 value for "len" and then immediately truncate away the
upper 32 bits.
Reviewed-by: Alex Elder <alex.elder@linaro.org>
commit c338c07c51e3106711fad5eb599e375eadb6855d upstream.
When register_session() is given an out-of-range argument for mds,
ceph_mdsmap_get_addr() will return a null pointer, which would be given to
ceph_con_open() & be dereferenced, causing a kernel oops. This fixes bug #4685
in the Ceph bug tracker <http://tracker.ceph.com/issues/4685>.
Signed-off-by: Nathaniel Yazdani <n1ght.4nd.d4y@gmail.com>
commit 5446429630257f4723829409337a26c076907d5d upstream.
when mounting ceph with a dev name that starts with a slash, ceph
would attempt to access the character before that slash. Since we
don't actually own that byte of memory, we would trigger an
invalid access:
[ 43.499934] BUG: unable to handle kernel paging request at ffff880fa3a97fff
[ 43.500984] IP: [<ffffffff818f3884>] parse_mount_options+0x1a4/0x300
[ 43.501491] PGD 743b067 PUD 10283c4067 PMD 10282a6067 PTE 8000000fa3a97060
[ 43.502301] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 43.503006] Dumping ftrace buffer:
[ 43.503596] (ftrace buffer empty)
[ 43.504046] CPU: 0 PID: 10879 Comm: mount Tainted: G W 3.10.0-sasha #1129
[ 43.504851] task: ffff880fa625b000 ti: ffff880fa3412000 task.ti: ffff880fa3412000
[ 43.505608] RIP: 0010:[<ffffffff818f3884>] [<ffffffff818f3884>] parse_mount_options$
[ 43.506552] RSP: 0018:ffff880fa3413d08 EFLAGS: 00010286
[ 43.507133] RAX: ffff880fa3a98000 RBX: ffff880fa3a98000 RCX: 0000000000000000
[ 43.507893] RDX: ffff880fa3a98001 RSI: 000000000000002f RDI: ffff880fa3a98000
[ 43.508610] RBP: ffff880fa3413d58 R08: 0000000000001f99 R09: ffff880fa3fe64c0
[ 43.509426] R10: ffff880fa3413d98 R11: ffff880fa38710d8 R12: ffff880fa3413da0
[ 43.509792] R13: ffff880fa3a97fff R14: 0000000000000000 R15: ffff880fa3413d90
[ 43.509792] FS: 00007fa9c48757e0(0000) GS:ffff880fd2600000(0000) knlGS:000000000000$
[ 43.509792] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 43.509792] CR2: ffff880fa3a97fff CR3: 0000000fa3bb9000 CR4: 00000000000006b0
[ 43.509792] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 43.509792] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 43.509792] Stack:
[ 43.509792] 0000e5180000000e ffffffff85ca1900 ffff880fa38710d8 ffff880fa3413d98
[ 43.509792] 0000000000000120 0000000000000000 ffff880fa3a98000 0000000000000000
[ 43.509792] ffffffff85cf32a0 0000000000000000 ffff880fa3413dc8 ffffffff818f3c72
[ 43.509792] Call Trace:
[ 43.509792] [<ffffffff818f3c72>] ceph_mount+0xa2/0x390
[ 43.509792] [<ffffffff81226314>] ? pcpu_alloc+0x334/0x3c0
[ 43.509792] [<ffffffff81282f8d>] mount_fs+0x8d/0x1a0
[ 43.509792] [<ffffffff812263d0>] ? __alloc_percpu+0x10/0x20
[ 43.509792] [<ffffffff8129f799>] vfs_kern_mount+0x79/0x100
[ 43.509792] [<ffffffff812a224d>] do_new_mount+0xcd/0x1c0
[ 43.509792] [<ffffffff812a2e8d>] do_mount+0x15d/0x210
[ 43.509792] [<ffffffff81220e55>] ? strndup_user+0x45/0x60
[ 43.509792] [<ffffffff812a2fdd>] SyS_mount+0x9d/0xe0
[ 43.509792] [<ffffffff83fd816c>] tracesys+0xdd/0xe2
[ 43.509792] Code: 4c 8b 5d c0 74 0a 48 8d 50 01 49 89 14 24 eb 17 31 c0 48 83 c9 ff $
[ 43.509792] RIP [<ffffffff818f3884>] parse_mount_options+0x1a4/0x300
[ 43.509792] RSP <ffff880fa3413d08>
[ 43.509792] ---[ end trace 22469cd81e93af51 ]---
Reviewed-by: Sage Weil <sage@inktan.com>
commit fb3101b6f0db9ae3f35dc8e6ec908d0af8cdf12e upstream.
commit c213b50b7dcbf06abcfbf1e4eee5b76586718bd9 upstream.
This patch makes the following improvements to the error handling
in the ceph_mdsmap_decode function:
- Add a NULL check for return value from kcalloc
- Make use of the variable err
Signed-off-by: Emil Goode <emilgoode@gmail.com>
commit f6c07cad081ba222d63623d913aafba5586c1d2c upstream.
If a handle runs out of space, we currently stop the kernel with a BUG
in jbd2_journal_dirty_metadata(). This makes it hard to figure out
what might be going on. So return an error of ENOSPC, so we can let
the file system layer figure out what is going on, to make it more
likely we can get useful debugging information). This should make it
easier to debug problems such as the one which was reported by:
https://bugzilla.kernel.org/show_bug.cgi?id=44731
The only two callers of this function are ext4_handle_dirty_metadata()
and ocfs2_journal_dirty(). The ocfs2 function will trigger a
BUG_ON(), which means there will be no change in behavior. The ext4
function will call ext4_error_inode() which will print the useful
debugging information and then handle the situation using ext4's error
handling mechanisms (i.e., which might mean halting the kernel or
remounting the file system read-only).
Also, since both file systems already call WARN_ON(), drop the WARN_ON
from jbd2_journal_dirty_metadata() to avoid two stack traces from
being displayed.
Cc: ocfs2-devel@oss.oracle.com
Acked-by: Joel Becker <jlbec@evilplan.org>
commit dfd11184d894cd0a92397b25cac18831a1a6a5bc upstream.
In patch 209806aba9d540dde3db0a5ce72307f85f33468f we allowed
local deferred locks to be granted against a cached exclusive
lock. That opened up a corner case which this patch now
fixes.
The solution to the problem is to check whether we have cached
pages each time we do direct I/O and if so to unmap, flush
and invalidate those pages. Since the glock state machine
normally does that for us, mostly the code will be a no-op.
commit dfe5b9ad83a63180f358b27d1018649a27b394a9 upstream.
This is a GFS2 version of Tejun's patch:
4f331f01b9c43bf001d3ffee578a97a1e0633eac
vfs: don't hold s_umount over close_bdev_exclusive() call
In this case its blkdev_put itself that is the issue and this
patch uses the same solution of dropping and retaking s_umount.
Reported-by: Tejun Heo <tj@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
commit 56f91aad69444d650237295f68c195b74d888d95 upstream.
If the length of data to be read in readpage() is exactly
PAGE_CACHE_SIZE, the original code does not flush d-cache
for data consistency after finishing reading. This patches fixes
this.
Signed-off-by: Li Wang <liwang@ubuntukylin.com>
commit 8f9ff189205a6817aee5a1f996f876541f86e07c upstream.
When using FITRIM ioctl on a file system without journal it will
only trim the block group once, no matter how many times you invoke
FITRIM ioctl and how many block you release from the block group.
It is because we only clear EXT4_GROUP_INFO_WAS_TRIMMED_BIT in journal
callback. Fix this by clearing the bit in no journal mode as well.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Reported-by: Jorge Fábregas <jorge.fabregas@gmail.com>
commit f5a44db5d2d677dfbf12deee461f85e9ec633961 upstream.
The missing casts can cause the high 64-bits of the physical blocks to
be lost. Set up new macros which allows us to make sure the right
thing happen, even if at some point we end up supporting larger
logical block numbers.
Thanks to the Emese Revfy and the PaX security team for reporting this
issue.
Reported-by: PaX Team <pageexec@freemail.hu>
Reported-by: Emese Revfy <re.emese@gmail.com>
commit 34cf865d54813aab3497838132fb1bbd293f4054 upstream.
Akira-san has been reporting rare deadlocks of his machine when running
xfstests test 269 on ext4 filesystem. The problem turned out to be in
ext4_da_reserve_metadata() and ext4_da_reserve_space() which called
ext4_should_retry_alloc() while holding i_data_sem. Since
ext4_should_retry_alloc() can force a transaction commit, this is a
lock ordering violation and leads to deadlocks.
Fix the problem by just removing the retry loops. These functions should
just report ENOSPC to the caller (e.g. ext4_da_write_begin()) and that
function must take care of retrying after dropping all necessary locks.
Reported-and-tested-by: Akira Fujita <a-fujita@rs.jp.nec.com>
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
commit 30fac0f75da24dd5bb43c9e911d2039a984ac815 upstream.
When the filesystem doesn't support extents (like in ext2/3
compatibility modes), there is no need to reserve any clusters. Space
estimates for writing are exact, hole punching doesn't need new
metadata, and there are no unwritten extents to convert.
This fixes a problem when filesystem still having some free space when
accessed with a native ext2/3 driver suddently reports ENOSPC when
accessed with ext4 driver.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit 5946d089379a35dda0e531710b48fca05446a196 upstream.
A corrupted ext4 may have out of order leaf extents, i.e.
extent: lblk 0--1023, len 1024, pblk 9217, flags: LEAF UNINIT
extent: lblk 1000--2047, len 1024, pblk 10241, flags: LEAF UNINIT
^^^^ overlap with previous extent
Reading such extent could hit BUG_ON() in ext4_es_cache_extent().
BUG_ON(end < lblk);
The problem is that __read_extent_tree_block() tries to cache holes as
well but assumes 'lblk' is greater than 'prev' and passes underflowed
length to ext4_es_cache_extent(). Fix it by checking for overlapping
extents in ext4_valid_extent_entries().
I hit this when fuzz testing ext4, and am able to reproduce it by
modifying the on-disk extent by hand.
Also add the check for (ee_block + len - 1) in ext4_valid_extent() to
make sure the value is not overflow.
Ran xfstests on patched ext4 and no regression.
Cc: Lukáš Czerner <lczerner@redhat.com>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 4e8d2139802ce4f41936a687f06c560b12115247 upstream.
ext4_mb_put_pa should hold pa->pa_lock before accessing pa->pa_count.
While ext4_mb_use_preallocated checks pa->pa_deleted first and then
increments pa->count later, ext4_mb_put_pa decrements pa->pa_count
before holding pa->pa_lock and then sets pa->pa_deleted.
* Free sequence
ext4_mb_put_pa (1): atomic_dec_and_test pa->pa_count
ext4_mb_put_pa (2): lock pa->pa_lock
ext4_mb_put_pa (3): check pa->pa_deleted
ext4_mb_put_pa (4): set pa->pa_deleted=1
ext4_mb_put_pa (5): unlock pa->pa_lock
ext4_mb_put_pa (6): remove pa from a list
ext4_mb_pa_callback: free pa
* Use sequence
ext4_mb_use_preallocated (1): iterate over preallocation
ext4_mb_use_preallocated (2): lock pa->pa_lock
ext4_mb_use_preallocated (3): check pa->pa_deleted
ext4_mb_use_preallocated (4): increase pa->pa_count
ext4_mb_use_preallocated (5): unlock pa->pa_lock
ext4_mb_release_context: access pa
* Use-after-free sequence
[initial status] <pa->pa_deleted = 0, pa_count = 1>
[pa_count decremented] <pa->pa_deleted = 0, pa_count = 0>
[pa_count incremented] <pa->pa_deleted = 0, pa_count = 1>
[race condition!] <pa->pa_deleted = 1, pa_count = 1>
AddressSanitizer has detected use-after-free in ext4_mb_new_blocks
Bug report: http://goo.gl/rG1On3
Signed-off-by: Junho Ryu <jayr@google.com>
commit ae1495b12df1897d4f42842a7aa7276d920f6290 upstream.
While it's true that errors can only happen if there is a bug in
jbd2_journal_dirty_metadata(), if a bug does happen, we need to halt
the kernel or remount the file system read-only in order to avoid
further data loss. The ext4_journal_abort_handle() function doesn't
do any of this, and while it's likely that this call (since it doesn't
adjust refcounts) will likely result in the file system eventually
deadlocking since the current transaction will never be able to close,
it's much cleaner to call let ext4's error handling system deal with
this situation.
There's a separate bug here which is that if certain jbd2 errors
errors occur and file system is mounted errors=continue, the file
system will probably eventually end grind to a halt as described
above. But things have been this way in a long time, and usually when
we have these sorts of errors it's pretty much a disaster --- and
that's why the jbd2 layer aggressively retries memory allocations,
which is the most likely cause of these jbd2 errors.
