path: root/fs
2014-09-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "I've got a revert to fix a regression with btrfs device registration, and Filipe has part two of his fsync fix from last week" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Revert "Btrfs: device_list_add() should not update list when mounted" Btrfs: set inode's logged_trans/last_log_commit after ranged fsync
2014-09-19Merge tag 'nfs-for-3.17-5' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client fixes from Trond Myklebust: "Highligts: - fix an Oops in nfs4_open_and_get_state - fix an Oops in the nfs4_state_manager - fix another bug in the close/open_downgrade code" * tag 'nfs-for-3.17-5' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Fix another bug in the close/open_downgrade code NFSv4: nfs4_state_manager() vs. nfs_server_remove_lists() NFS: remove BUG possibility in nfs4_open_and_get_state
2014-09-18Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs/smb3 fixes from Steve French: "Fixes for problems found during testing and debugging at the SMB3 storage test event (plugfest) this week" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: Fix mfsymlinks file size check Update version number displayed by modinfo for cifs.ko cifs: remove dead code Revert "cifs: No need to send SIGKILL to demux_thread during umount" [SMB3] Fix oops when creating symlinks on smb3 [CIFS] Fix setting time before epoch (negative time values)
2014-09-18NFSv4: Fix another bug in the close/open_downgrade codeTrond Myklebust
James Drew reports another bug whereby the NFS client is now sending an OPEN_DOWNGRADE in a situation where it should really have sent a CLOSE: the client is opening the file for O_RDWR, but then trying to do a downgrade to O_RDONLY, which is not allowed by the NFSv4 spec. Reported-by: James Drews <drews@engr.wisc.edu> Link: http://lkml.kernel.org/r/541AD7E5.8020409@engr.wisc.edu Fixes: aee7af356e15 (NFSv4: Fix problems with close in the presence...) Cc: stable@vger.kernel.org # 2.6.33+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-18NFSv4: nfs4_state_manager() vs. nfs_server_remove_lists()Steve Dickson
There is a race between nfs4_state_manager() and nfs_server_remove_lists() that happens during a nfsv3 mount. The v3 mount notices there is already a supper block so nfs_server_remove_lists() called which uses the nfs_client_lock spin lock to synchronize access to the client list. At the same time nfs4_state_manager() is running through the client list looking for work to do, using the same lock. When nfs4_state_manager() wins the race to the list, a v3 client pointer is found and not ignored properly which causes the panic. Moving some protocol checks before the state checking avoids the panic. CC: Stable Tree <stable@vger.kernel.org> Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-18Revert "Btrfs: device_list_add() should not update list when mounted"Chris Mason
This reverts commit b96de000bc8bc9688b3a2abea4332bd57648a49f. This commit is triggering failures to mount by subvolume id in some configurations. The main problem is how many different ways this scanning function is used, both for scanning while mounted and unmounted. A proper cleanup is too big for late rcs. For now, just revert the commit and we'll put a better fix into a later merge window. Signed-off-by: Chris Mason <clm@fb.com>
2014-09-16Btrfs: set inode's logged_trans/last_log_commit after ranged fsyncFilipe Manana
When a ranged fsync finishes if there are still extent maps in the modified list, still set the inode's logged_trans and last_log_commit. This is important in case an inode is fsync'ed and unlinked in the same transaction, to ensure its inode ref gets deleted from the log and the respective dentries in its parent are deleted too from the log (if the parent directory was fsync'ed in the same transaction). Instead make btrfs_inode_in_log() return false if the list of modified extent maps isn't empty. This is an incremental on top of the v4 version of the patch: "Btrfs: fix fsync data loss after a ranged fsync" which was added to its v5, but didn't make it on time. Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-16Merge tag 'gfs2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes Pull gfs2 fixes from Steven Whitehouse: "Here are a number of small fixes for GFS2. There is a fix for FIEMAP on large sparse files, a negative dentry hashing fix, a fix for flock, and a bug fix relating to d_splice_alias usage. There are also (patches 1 and 5) a couple of updates which are less critical, but small and low risk" * tag 'gfs2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: fix d_splice_alias() misuses GFS2: Don't use MAXQUOTAS value GFS2: Hash the negative dentry during inode lookup GFS2: Request demote when a "try" flock fails GFS2: Change maxlen variables to size_t GFS2: fs/gfs2/super.c: replace seq_printf by seq_puts
2014-09-16vfs: workaround gcc <4.6 build error in link_path_walk()James Hogan
Commit d6bb3e9075bb ("vfs: simplify and shrink stack frame of link_path_walk()") introduced build problems with GCC versions older than 4.6 due to the initialisation of a member of an anonymous union in struct qstr without enclosing braces. This hits GCC bug 10676 [1] (which was fixed in GCC 4.6 by [2]), and causes the following build error: fs/namei.c: In function 'link_path_walk': fs/namei.c:1778: error: unknown field 'hash_len' specified in initializer This is worked around by adding explicit braces. [1] https://gcc.gnu.org/bugzilla/show_bug.cgi?id=10676 [2] https://gcc.gnu.org/viewcvs/gcc?view=revision&revision=159206 Fixes: d6bb3e9075bb (vfs: simplify and shrink stack frame of link_path_walk()) Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-fsdevel@vger.kernel.org Cc: linux-metag@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-16Fix mfsymlinks file size checkSteve French
If the mfsymlinks file size has changed (e.g. the file no longer represents an emulated symlink) we were not returning an error properly. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Stefan Metzmacher <metze@samba.org>
2014-09-16Update version number displayed by modinfo for cifs.koSteve French
Update cifs.ko version to 2.05 Signed-off-by: Steve French <smfrench@gmail.com>w
2014-09-16cifs: remove dead codeArnd Bergmann
cifs provides two dummy functions 'sess_auth_lanman' and 'sess_auth_kerberos' for the case in which the respective features are not defined. However, the caller is also under an #ifdef, so we just get warnings about unused code: fs/cifs/sess.c:1109:1: warning: 'sess_auth_kerberos' defined but not used [-Wunused-function] sess_auth_kerberos(struct sess_data *sess_data) Removing the dead functions gets rid of the warnings without any downsides that I can see. (Yalin Wang reported the identical problem and fix so added him) Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-09-16Revert "cifs: No need to send SIGKILL to demux_thread during umount"Steve French
This reverts commit 52a36244443eabb594bdb63622ff2dd7a083f0e2. Causes rmmod to fail for at least 7 seconds after unmount which makes automated testing a little harder when reloading cifs.ko between test runs. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> CC: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-09-15vfs: simplify and shrink stack frame of link_path_walk()Linus Torvalds
Commit 9226b5b440f2 ("vfs: avoid non-forwarding large load after small store in path lookup") made link_path_walk() always access the "hash_len" field as a single 64-bit entity, in order to avoid mixed size accesses to the members. However, what I didn't notice was that that effectively means that the whole "struct qstr this" is now basically redundant. We already explicitly track the "const char *name", and if we just use "u64 hash_len" instead of "long len", there is nothing else left of the "struct qstr". We do end up wanting the "struct qstr" if we have a filesystem with a "d_hash()" function, but that's a rare case, and we might as well then just squirrell away the name and hash_len at that point. End result: fewer live variables in the loop, a smaller stack frame, and better code generation. And we don't need to pass in pointers variables to helper functions any more, because the return value contains all the relevant information. So this removes more lines than it adds, and the source code is clearer too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-15[SMB3] Fix oops when creating symlinks on smb3Steve French
We were not checking for symlink support properly for SMB2/SMB3 mounts so could oops when mounted with mfsymlinks when try to create symlink when mfsymlinks on smb2/smb3 mounts Signed-off-by: Steve French <smfrench@gmail.com> Cc: <stable@vger.kernel.org> # 3.14+ CC: Sachin Prabhu <sprabhu@redhat.com>
2014-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "double iput() on failure exit in lustre, racy removal of spliced dentries from ->s_anon in __d_materialise_dentry() plus a bunch of assorted RCU pathwalk fixes" The RCU pathwalk fixes end up fixing a couple of cases where we incorrectly dropped out of RCU walking, due to incorrect initialization and testing of the sequence locks in some corner cases. Since dropping out of RCU walk mode forces the slow locked accesses, those corner cases slowed down quite dramatically. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: be careful with nd->inode in path_init() and follow_dotdot_rcu() don't bugger nd->seq on set_root_rcu() from follow_dotdot_rcu() fix bogus read_seqretry() checks introduced in b37199e move the call of __d_drop(anon) into __d_materialise_unique(dentry, anon) [fix] lustre: d_make_root() does iput() on dentry allocation failure
2014-09-14vfs: avoid non-forwarding large load after small store in path lookupLinus Torvalds
The performance regression that Josef Bacik reported in the pathname lookup (see commit 99d263d4c5b2 "vfs: fix bad hashing of dentries") made me look at performance stability of the dcache code, just to verify that the problem was actually fixed. That turned up a few other problems in this area. There are a few cases where we exit RCU lookup mode and go to the slow serializing case when we shouldn't, Al has fixed those and they'll come in with the next VFS pull. But my performance verification also shows that link_path_walk() turns out to have a very unfortunate 32-bit store of the length and hash of the name we look up, followed by a 64-bit read of the combined hash_len field. That screws up the processor store to load forwarding, causing an unnecessary hickup in this critical routine. It's caused by the ugly calling convention for the "hash_name()" function, and easily fixed by just making hash_name() fill in the whole 'struct qstr' rather than passing it a pointer to just the hash value. With that, the profile for this function looks much smoother. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-14[CIFS] Fix setting time before epoch (negative time values)Steve French
xfstest generic/258 sets the time on a file to a negative value (before 1970) which fails since do_div can not handle negative numbers. In addition 'normal' division of 64 bit values does not build on 32 bit arch so have to workaround this by special casing negative values in cifs_NTtimeToUnix Samba server also has a bug with this (see samba bugzilla 7771) but it works to Windows server. Signed-off-by: Steve French <smfrench@gmail.com>
2014-09-14be careful with nd->inode in path_init() and follow_dotdot_rcu()Al Viro
in the former we simply check if dentry is still valid after picking its ->d_inode; in the latter we fetch ->d_inode in the same places where we fetch dentry and its ->d_seq, under the same checks. Cc: stable@vger.kernel.org # 2.6.38+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-14don't bugger nd->seq on set_root_rcu() from follow_dotdot_rcu()Al Viro
return the value instead, and have path_init() do the assignment. Broken by "vfs: Fix absolute RCU path walk failures due to uninitialized seq number", which was Cc-stable with 2.6.38+ as destination. This one should go where it went. To avoid dummy value returned in case when root is already set (it would do no harm, actually, since the only caller that doesn't ignore the return value is guaranteed to have nd->root *not* set, but it's more obvious that way), lift the check into callers. And do the same to set_root(), to keep them in sync. Cc: stable@vger.kernel.org # 2.6.38+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-13fix bogus read_seqretry() checks introduced in b37199eAl Viro
read_seqretry() returns true on mismatch, not on match... Cc: stable@vger.kernel.org # 3.15+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-13move the call of __d_drop(anon) into __d_materialise_unique(dentry, anon)Al Viro
and lock the right list there Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-13vfs: fix bad hashing of dentriesLinus Torvalds
Josef Bacik found a performance regression between 3.2 and 3.10 and narrowed it down to commit bfcfaa77bdf0 ("vfs: use 'unsigned long' accesses for dcache name comparison and hashing"). He reports: "The test case is essentially for (i = 0; i < 1000000; i++) mkdir("a$i"); On xfs on a fio card this goes at about 20k dir/sec with 3.2, and 12k dir/sec with 3.10. This is because we spend waaaaay more time in __d_lookup on 3.10 than in 3.2. The new hashing function for strings is suboptimal for < sizeof(unsigned long) string names (and hell even > sizeof(unsigned long) string names that I've tested). I broke out the old hashing function and the new one into a userspace helper to get real numbers and this is what I'm getting: Old hash table had 1000000 entries, 0 dupes, 0 max dupes New hash table had 12628 entries, 987372 dupes, 900 max dupes We had 11400 buckets with a p50 of 30 dupes, p90 of 240 dupes, p99 of 567 dupes for the new hash My test does the hash, and then does the d_hash into a integer pointer array the same size as the dentry hash table on my system, and then just increments the value at the address we got to see how many entries we overlap with. As you can see the old hash function ended up with all 1 million entries in their own bucket, whereas the new one they are only distributed among ~12.5k buckets, which is why we're using so much more CPU in __d_lookup". The reason for this hash regression is two-fold: - On 64-bit architectures the down-mixing of the original 64-bit word-at-a-time hash into the final 32-bit hash value is very simplistic and suboptimal, and just adds the two 32-bit parts together. In particular, because there is no bit shuffling and the mixing boundary is also a byte boundary, similar character patterns in the low and high word easily end up just canceling each other out. - the old byte-at-a-time hash mixed each byte into the final hash as it hashed the path component name, resulting in the low bits of the hash generally being a good source of hash data. That is not true for the word-at-a-time case, and the hash data is distributed among all the bits. The fix is the same in both cases: do a better job of mixing the bits up and using as much of the hash data as possible. We already have the "hash_32|64()" functions to do that. Reported-by: Josef Bacik <jbacik@fb.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Chris Mason <clm@fb.com> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-12GFS2: fix d_splice_alias() misusesAl Viro
Callers of d_splice_alias(dentry, inode) don't need iput(), neither on success nor on failure. Either the reference to inode is stored in a previously negative dentry, or it's dropped. In either case inode reference the caller used to hold is consumed. __gfs2_lookup() does iput() in case when d_splice_alias() has failed. Double iput() if we ever hit that. And gfs2_create_inode() ends up not only with double iput(), but with link count dropped to zero - on an inode it has just found in directory. Cc: stable@vger.kernel.org # v3.14+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-09-12Merge tag 'nfs-for-3.17-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client fixes from Trond Myklebust: "Highlights: - fix a kernel warning when removing /proc/net/nfsfs - revert commit 49a4bda22e18 due to Oopses - fix a typo in the pNFS file layout commit code" * tag 'nfs-for-3.17-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: pnfs: fix filelayout_retry_commit when idx > 0 nfs: revert "nfs4: queue free_lock_state job submission to nfsiod" nfs: fix kernel warning when removing proc entry
2014-09-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is doing a careful pass through fsync problems, and these are the fixes so far. I'll have one more for rc6 that we're still testing. My big commit is fixing up some inode hash races that Al Viro found (thanks Al)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use insert_inode_locked4 for inode creation Btrfs: fix fsync data loss after a ranged fsync Btrfs: kfree()ing ERR_PTRs Btrfs: fix crash while doing a ranged fsync Btrfs: fix corruption after write/fsync failure + fsync + log recovery Btrfs: fix autodefrag with compression
2014-09-12NFS: remove BUG possibility in nfs4_open_and_get_stateNeilBrown
commit 4fa2c54b5198d09607a534e2fd436581064587ed NFS: nfs4_do_open should add negative results to the dcache. used "d_drop(); d_add();" to ensure that a dentry was hashed as a negative cached entry. This is not safe if the dentry has an non-NULL ->d_inode. It will trigger a BUG_ON in d_instantiate(). In that case, d_delete() is needed. Also, only d_add if the dentry is currently unhashed, it seems pointless removed and re-adding it unchanged. Reported-by: Christoph Hellwig <hch@infradead.org> Fixes: 4fa2c54b5198d09607a534e2fd436581064587ed Cc: Jeff Layton <jeff.layton@primarydata.com> Link: http://lkml.kernel.org/r/20140908144525.GB19811@infradead.org Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-11GFS2: Don't use MAXQUOTAS valueJan Kara
MAXQUOTAS value defines maximum number of quota types VFS supports. This isn't necessarily the number of types gfs2 supports and with addition of project quotas these two numbers stop matching. So make gfs2 use its private definition. CC: cluster-devel@redhat.com Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-09-11GFS2: Hash the negative dentry during inode lookupBenjamin Coddington
Fix a regression introduced by: 6d4ade986f9c8df31e68 GFS2: Add atomic_open support where an early return misses d_splice_alias() which had been adding the negative dentry. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-09-10Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "10 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: fs/notify: don't show f_handle if exportfs_encode_inode_fh failed fsnotify/fdinfo: use named constants instead of hardcoded values kcmp: fix standard comparison bug mm/mmap.c: use pr_emerg when printing BUG related information shm: add memfd.h to UAPI export list checkpatch: allow commit descriptions on separate line from commit id sh: get_user_pages_fast() must flush cache eventpoll: fix uninitialized variable in epoll_ctl kernel/printk/printk.c: fix faulty logic in the case of recursive printk mem-hotplug: let memblock skip the hotpluggable memory regions in __next_mem_range()
2014-09-10fs/notify: don't show f_handle if exportfs_encode_inode_fh failedAndrey Vagin
Currently we handle only ENOSPC. In case of other errors the file_handle variable isn't filled properly and we will show a part of stack. Signed-off-by: Andrey Vagin <avagin@openvz.org> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-10fsnotify/fdinfo: use named constants instead of hardcoded valuesAndrey Vagin
MAX_HANDLE_SZ is equal to 128, but currently the size of pad is only 64 bytes, so exportfs_encode_inode_fh can return an error. Signed-off-by: Andrey Vagin <avagin@openvz.org> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-10eventpoll: fix uninitialized variable in epoll_ctlNicolas Iooss
When calling epoll_ctl with operation EPOLL_CTL_DEL, structure epds is not initialized but ep_take_care_of_epollwakeup reads its event field. When this unintialized field has EPOLLWAKEUP bit set, a capability check is done for CAP_BLOCK_SUSPEND in ep_take_care_of_epollwakeup. This produces unexpected messages in the audit log, such as (on a system running SELinux): type=AVC msg=audit(1408212798.866:410): avc: denied { block_suspend } for pid=7754 comm="dbus-daemon" capability=36 scontext=unconfined_u:unconfined_r:unconfined_t tcontext=unconfined_u:unconfined_r:unconfined_t tclass=capability2 permissive=1 type=SYSCALL msg=audit(1408212798.866:410): arch=c000003e syscall=233 success=yes exit=0 a0=3 a1=2 a2=9 a3=7fffd4d66ec0 items=0 ppid=1 pid=7754 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="dbus-daemon" exe="/usr/bin/dbus-daemon" subj=unconfined_u:unconfined_r:unconfined_t key=(null) ("arch=c000003e syscall=233 a1=2" means "epoll_ctl(op=EPOLL_CTL_DEL)") Remove use of epds in epoll_ctl when op == EPOLL_CTL_DEL. Fixes: 4d7e30d98939 ("epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are ready") Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Arve Hjønnevåg <arve@android.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-10Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF fixes from Jan Kara: "Fixes for UDF handling of NFS handles and one fix for proper handling of corrupted media" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: saner calling conventions for udf_new_inode() udf: fix the udf_iget() vs. udf_new_inode() races udf: merge the pieces inserting a new non-directory object into directory udf: Set i_generation field udf: Properly detect stale inodes udf: Make udf_read_inode() and udf_iget() return error udf: Avoid infinite loop when processing indirect ICBs udf: Fold udf_fill_inode() into __udf_read_inode() udf: Avoid dir link count to go negative
2014-09-10pnfs: fix filelayout_retry_commit when idx > 0Weston Andros Adamson
filelayout_retry_commit was recently split out from alloc_ds_commits, but was done in such a way that the bucket pointer always starts at index 0 no matter what the @idx argument is set to. The intention of the @idx argument is to retry commits starting at bucket @idx. This is called when alloc_ds_commits fails for a bucket. Signed-off-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-09Merge branch 'for-next-3.17' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs/smb3 fixes from Steve French: "This includes various cifs and smb3 bug fixes including those for bugs found with the recently updated xfstests. Also I am working fixes for two additional cifs problems found by xfstests which I plan to send later (when reviewed and run additional tests)" * 'for-next-3.17' of git://git.samba.org/sfrench/cifs-2.6: Clarify Kconfig help text for CIFS and SMB2/SMB3 CIFS: Fix wrong filename length for SMB2 CIFS: Fix wrong restart readdir for SMB1 CIFS: Fix directory rename error cifs: No need to send SIGKILL to demux_thread during umount cifs: Allow directIO read/write during cache=strict cifs: remove unneeded check of null checking in if condition cifs: fix a possible use of uninit variable in SMB2_sess_setup cifs: fix memory leak when password is supplied multiple times cifs: fix a possible null pointer deref in decode_ascii_ssetup Trivial whitespace fix
2014-09-08nfs: revert "nfs4: queue free_lock_state job submission to nfsiod"Jeff Layton
This reverts commit 49a4bda22e186c4d0eb07f4a36b5b1a378f9398d. Christoph reported an oops due to the above commit: generic/089 242s ...[ 2187.041239] general protection fault: 0000 [#1] SMP [ 2187.042899] Modules linked in: [ 2187.044000] CPU: 0 PID: 11913 Comm: kworker/0:1 Not tainted 3.16.0-rc6+ #1151 [ 2187.044287] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 2187.044287] Workqueue: nfsiod free_lock_state_work [ 2187.044287] task: ffff880072b50cd0 ti: ffff88007a4ec000 task.ti: ffff88007a4ec000 [ 2187.044287] RIP: 0010:[<ffffffff81361ca6>] [<ffffffff81361ca6>] free_lock_state_work+0x16/0x30 [ 2187.044287] RSP: 0018:ffff88007a4efd58 EFLAGS: 00010296 [ 2187.044287] RAX: 6b6b6b6b6b6b6b6b RBX: ffff88007a947ac0 RCX: 8000000000000000 [ 2187.044287] RDX: ffffffff826af9e0 RSI: ffff88007b093c00 RDI: ffff88007b093db8 [ 2187.044287] RBP: ffff88007a4efd58 R08: ffffffff832d3e10 R09: 000001c40efc0000 [ 2187.044287] R10: 0000000000000000 R11: 0000000000059e30 R12: ffff88007fc13240 [ 2187.044287] R13: ffff88007fc18b00 R14: ffff88007b093db8 R15: 0000000000000000 [ 2187.044287] FS: 0000000000000000(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 [ 2187.044287] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 2187.044287] CR2: 00007f93ec33fb80 CR3: 0000000079dc2000 CR4: 00000000000006f0 [ 2187.044287] Stack: [ 2187.044287] ffff88007a4efdd8 ffffffff810cc877 ffffffff810cc80d ffff88007fc13258 [ 2187.044287] 000000007a947af0 0000000000000000 ffffffff8353ccc8 ffffffff82b6f3d0 [ 2187.044287] 0000000000000000 ffffffff82267679 ffff88007a4efdd8 ffff88007fc13240 [ 2187.044287] Call Trace: [ 2187.044287] [<ffffffff810cc877>] process_one_work+0x1c7/0x490 [ 2187.044287] [<ffffffff810cc80d>] ? process_one_work+0x15d/0x490 [ 2187.044287] [<ffffffff810cd569>] worker_thread+0x119/0x4f0 [ 2187.044287] [<ffffffff810fbbad>] ? trace_hardirqs_on+0xd/0x10 [ 2187.044287] [<ffffffff810cd450>] ? init_pwq+0x190/0x190 [ 2187.044287] [<ffffffff810d3c6f>] kthread+0xdf/0x100 [ 2187.044287] [<ffffffff810d3b90>] ? __init_kthread_worker+0x70/0x70 [ 2187.044287] [<ffffffff81d9873c>] ret_from_fork+0x7c/0xb0 [ 2187.044287] [<ffffffff810d3b90>] ? __init_kthread_worker+0x70/0x70 [ 2187.044287] Code: 0f 1f 44 00 00 31 c0 5d c3 66 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 8d b7 48 fe ff ff 48 8b 87 58 fe ff ff 48 89 e5 48 8b 40 30 <48> 8b 00 48 8b 10 48 89 c7 48 8b 92 90 03 00 00 ff 52 28 5d c3 [ 2187.044287] RIP [<ffffffff81361ca6>] free_lock_state_work+0x16/0x30 [ 2187.044287] RSP <ffff88007a4efd58> [ 2187.103626] ---[ end trace 0f11326d28e5d8fa ]--- The original reason for this patch was because the fl_release_private operation couldn't sleep. With commit ed9814d85810 (locks: defer freeing locks in locks_delete_lock until after i_lock has been dropped), this is no longer a problem so we can revert this patch. Reported-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-08nfs: fix kernel warning when removing proc entryCong Wang
I saw the following kernel warning: [ 1852.321222] ------------[ cut here ]------------ [ 1852.326527] WARNING: CPU: 0 PID: 118 at fs/proc/generic.c:521 remove_proc_entry+0x154/0x16b() [ 1852.335630] remove_proc_entry: removing non-empty directory 'fs/nfsfs', leaking at least 'volumes' [ 1852.344084] CPU: 0 PID: 118 Comm: kworker/u8:2 Not tainted 3.16.0+ #540 [ 1852.350036] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 1852.354992] Workqueue: netns cleanup_net [ 1852.358701] 0000000000000000 ffff880116f2fbd0 ffffffff819c03e9 ffff880116f2fc18 [ 1852.366474] ffff880116f2fc08 ffffffff810744ee ffffffff811e0e6e ffff8800d4e96238 [ 1852.373507] ffffffff81dbe665 ffff8800d46a5948 0000000000000005 ffff880116f2fc68 [ 1852.380224] Call Trace: [ 1852.381976] [<ffffffff819c03e9>] dump_stack+0x4d/0x66 [ 1852.385495] [<ffffffff810744ee>] warn_slowpath_common+0x7a/0x93 [ 1852.389869] [<ffffffff811e0e6e>] ? remove_proc_entry+0x154/0x16b [ 1852.393987] [<ffffffff8107457b>] warn_slowpath_fmt+0x4c/0x4e [ 1852.397999] [<ffffffff811e0e6e>] remove_proc_entry+0x154/0x16b [ 1852.402034] [<ffffffff8129c73d>] nfs_fs_proc_net_exit+0x53/0x56 [ 1852.406136] [<ffffffff812a103b>] nfs_net_exit+0x12/0x1d [ 1852.409774] [<ffffffff81785bc9>] ops_exit_list+0x44/0x55 [ 1852.413529] [<ffffffff81786389>] cleanup_net+0xee/0x182 [ 1852.417198] [<ffffffff81088c9e>] process_one_work+0x209/0x40d [ 1852.502320] [<ffffffff81088bf7>] ? process_one_work+0x162/0x40d [ 1852.587629] [<ffffffff810890c1>] worker_thread+0x1f0/0x2c7 [ 1852.673291] [<ffffffff81088ed1>] ? process_scheduled_works+0x2f/0x2f [ 1852.759470] [<ffffffff8108e079>] kthread+0xc9/0xd1 [ 1852.843099] [<ffffffff8109427f>] ? finish_task_switch+0x3a/0xce [ 1852.926518] [<ffffffff8108dfb0>] ? __kthread_parkme+0x61/0x61 [ 1853.008565] [<ffffffff819cbeac>] ret_from_fork+0x7c/0xb0 [ 1853.076477] [<ffffffff8108dfb0>] ? __kthread_parkme+0x61/0x61 [ 1853.140653] ---[ end trace 69c4c6617f78e32d ]--- It looks wrong that we add "/proc/net/nfsfs" in nfs_fs_proc_net_init() while remove "/proc/fs/nfsfs" in nfs_fs_proc_net_exit(). Fixes: commit 65b38851a17 (NFS: Fix /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes) Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Dan Aloni <dan@kernelim.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> [Trond: replace uses of remove_proc_entry() with remove_proc_subtree() as suggested by Al Viro] Cc: stable@vger.kernel.org # 3.4.x : 65b38851a17: NFS: Fix /proc/fs/nfsfs/servers Cc: stable@vger.kernel.org # 3.4.x Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-08Merge branch 'for_linus_urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bugfix from Ted Ts'o. [ Hmm. It's possible we should make kfree() aware of error pointers, and use IS_ERR_OR_NULL rather than a NULL check. But in the meantime this is obviously the right fix. - Linus ] * 'for_linus_urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: avoid trying to kfree an ERR_PTR pointer
2014-09-08Merge branch 'for-3.17' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd bugfixes from Bruce Fields: "A couple minor nfsd bugfixes" * 'for-3.17' of git://linux-nfs.org/~bfields/linux: lockd: fix rpcbind crash on lockd startup failure nfsd4: fix rd_dircount enforcement
2014-09-08Btrfs: use insert_inode_locked4 for inode creationChris Mason
Btrfs was inserting inodes into the hash table before we had fully set the inode up on disk. This leaves us open to rare races that allow two different inodes in memory for the same [root, inode] pair. This patch fixes things by using insert_inode_locked4 to insert an I_NEW inode and unlock_new_inode when we're ready for the rest of the kernel to use the inode. It also makes sure to init the operations pointers on the inode before going into the error handling paths. Signed-off-by: Chris Mason <clm@fb.com> Reported-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-08Btrfs: fix fsync data loss after a ranged fsyncFilipe Manana
While we're doing a full fsync (when the inode has the flag BTRFS_INODE_NEEDS_FULL_SYNC set) that is ranged too (covers only a portion of the file), we might have ordered operations that are started before or while we're logging the inode and that fall outside the fsync range. Therefore when a full ranged fsync finishes don't remove every extent map from the list of modified extent maps - as for some of them, that fall outside our fsync range, their respective ordered operation hasn't finished yet, meaning the corresponding file extent item wasn't inserted into the fs/subvol tree yet and therefore we didn't log it, and we must let the next fast fsync (one that checks only the modified list) see this extent map and log a matching file extent item to the log btree and wait for its ordered operation to finish (if it's still ongoing). A test case for xfstests follows. Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-08Btrfs: kfree()ing ERR_PTRsDan Carpenter
The "inherit" in btrfs_ioctl_snap_create_v2() and "vol_args" in btrfs_ioctl_rm_dev() are ERR_PTRs so we can't call kfree() on them. These kind of bugs are "One Err Bugs" where there is just one error label that does everything. I could set the "inherit = NULL" and keep the single out label but it ends up being more complicated that way. It makes the code simpler to re-order the unwind so it's in the mirror order of the allocation and introduce some new error labels. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-09-08lockd: fix rpcbind crash on lockd startup failureJ. Bruce Fields
Nikita Yuschenko reported that booting a kernel with init=/bin/sh and then nfs mounting without portmap or rpcbind running using a busybox mount resulted in: # mount -t nfs 10.30.130.21:/opt /mnt svc: failed to register lockdv1 RPC service (errno 111). lockd_up: makesock failed, error=-111 Unable to handle kernel paging request for data at address 0x00000030 Faulting instruction address: 0xc055e65c Oops: Kernel access of bad area, sig: 11 [#1] MPC85xx CDS Modules linked in: CPU: 0 PID: 1338 Comm: mount Not tainted 3.10.44.cge #117 task: cf29cea0 ti: cf35c000 task.ti: cf35c000 NIP: c055e65c LR: c0566490 CTR: c055e648 REGS: cf35dad0 TRAP: 0300 Not tainted (3.10.44.cge) MSR: 00029000 <CE,EE,ME> CR: 22442488 XER: 20000000 DEAR: 00000030, ESR: 00000000 GPR00: c05606f4 cf35db80 cf29cea0 cf0ded80 cf0dedb8 00000001 1dec3086 00000000 GPR08: 00000000 c07b1640 00000007 1dec3086 22442482 100b9758 00000000 10090ae8 GPR16: 00000000 000186a5 00000000 00000000 100c3018 bfa46edc 100b0000 bfa46ef0 GPR24: cf386ae0 c07834f0 00000000 c0565f88 00000001 cf0dedb8 00000000 cf0ded80 NIP [c055e65c] call_start+0x14/0x34 LR [c0566490] __rpc_execute+0x70/0x250 Call Trace: [cf35db80] [00000080] 0x80 (unreliable) [cf35dbb0] [c05606f4] rpc_run_task+0x9c/0xc4 [cf35dbc0] [c0560840] rpc_call_sync+0x50/0xb8 [cf35dbf0] [c056ee90] rpcb_register_call+0x54/0x84 [cf35dc10] [c056f24c] rpcb_register+0xf8/0x10c [cf35dc70] [c0569e18] svc_unregister.isra.23+0x100/0x108 [cf35dc90] [c0569e38] svc_rpcb_cleanup+0x18/0x30 [cf35dca0] [c0198c5c] lockd_up+0x1dc/0x2e0 [cf35dcd0] [c0195348] nlmclnt_init+0x2c/0xc8 [cf35dcf0] [c015bb5c] nfs_start_lockd+0x98/0xec [cf35dd20] [c015ce6c] nfs_create_server+0x1e8/0x3f4 [cf35dd90] [c0171590] nfs3_create_server+0x10/0x44 [cf35dda0] [c016528c] nfs_try_mount+0x158/0x1e4 [cf35de20] [c01670d0] nfs_fs_mount+0x434/0x8c8 [cf35de70] [c00cd3bc] mount_fs+0x20/0xbc [cf35de90] [c00e4f88] vfs_kern_mount+0x50/0x104 [cf35dec0] [c00e6e0c] do_mount+0x1d0/0x8e0 [cf35df10] [c00e75ac] SyS_mount+0x90/0xd0 [cf35df40] [c000ccf4] ret_from_syscall+0x0/0x3c The addition of svc_shutdown_net() resulted in two calls to svc_rpcb_cleanup(); the second is no longer necessary and crashes when it calls rpcb_register_call with clnt=NULL. Reported-by: Nikita Yushchenko <nyushchenko@dev.rtsoft.ru> Fixes: 679b033df484 "lockd: ensure we tear down any live sockets when socket creation fails during lockd_up" Cc: stable@vger.kernel.org Acked-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-09-08nfsd4: fix rd_dircount enforcementJ. Bruce Fields
Commit 3b299709091b "nfsd4: enforce rd_dircount" totally misunderstood rd_dircount; it refers to total non-attribute bytes returned, not number of directory entries returned. Bring the code into agreement with RFC 3530 section 14.2.24. Cc: stable@vger.kernel.org Fixes: 3b299709091b "nfsd4: enforce rd_dircount" Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull filesystem fixes from Al Viro: "Several bugfixes (all of them -stable fodder). Alexey's one deals with double mutex_lock() in UFS (apparently, nobody has tried to test "ufs: sb mutex merge + mutex_destroy" on something like file creation/removal on ufs). Mine deal with two kinds of umount bugs, in umount propagation and in handling of automounted submounts, both resulting in bogus transient EBUSY from umount" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ufs: fix deadlocks introduced by sb mutex merge fix EBUSY on umount() from MNT_SHRINKABLE get rid of propagate_umount() mistakenly treating slaves as busy.
2014-09-07ufs: fix deadlocks introduced by sb mutex mergeAlexey Khoroshilov
Commit 0244756edc4b ("ufs: sb mutex merge + mutex_destroy") introduces deadlocks in ufs_new_inode() and ufs_free_inode(). Most callers of that functions acqure the mutex by themselves and ufs_{new,free}_inode() do that via lock_ufs(), i.e we have an unavoidable double lock. The patch proposes to resolve the issue by making sure that ufs_{new,free}_inode() are not called with the mutex held. Found by Linux Driver Verification project (linuxtesting.org). Cc: stable@vger.kernel.org # 3.16 Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-06Merge tag 'xfs-for-linus-3.17-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs Pull xfs fixes from Dave Chinner: "The fixes all address recently discovered data corruption issues. The original Direct IO issue was discovered by Chris Mason @ Facebook on a production workload which mixed buffered reads with direct reads and writes IO to the same file. The fix for that exposed other issues with page invalidation (exposed by millions of fsx operations) failing due to dirty buffers beyond EOF. Finally, the collapse_range code could also cause problems due to racing writeback changing the extent map while it was being shifted around. The commits for that problem are simple mitigation fixes that prevent the problem from occuring. A more robust fix for 3.18 that addresses the underlying problem is currently being worked on by Brian. Summary of fixes: - a direct IO read/buffered read data corruption - the associated fallout from the DIO data corruption fix - collapse range bugs that are potential data corruption issues" * tag 'xfs-for-linus-3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: xfs: trim eofblocks before collapse range xfs: xfs_file_collapse_range is delalloc challenged xfs: don't log inode unless extent shift makes extent modifications xfs: use ranged writeback and invalidation for direct IO xfs: don't zero partial page cache pages during O_DIRECT writes xfs: don't zero partial page cache pages during O_DIRECT writes xfs: don't dirty buffers beyond EOF
2014-09-05Export sync_filesystem() for modular ->remount_fs() useAnton Altaparmakov
This patch changes sync_filesystem() to be EXPORT_SYMBOL(). The reason this is needed is that starting with 3.15 kernel, due to Theodore Ts'o's commit 02b9984d6408 ("fs: push sync_filesystem() down to the file system's remount_fs()"), all file systems that have dirty data to be written out need to call sync_filesystem() from their ->remount_fs() method when remounting read-only. As this is now a generically required function rather than an internal only function it should be EXPORT_SYMBOL() so that all file systems can call it. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-04Merge git://git.kvack.org/~bcrl/aio-fixesLinus Torvalds
Pull aio bugfixes from Ben LaHaise: "Two small fixes" * git://git.kvack.org/~bcrl/aio-fixes: aio: block exit_aio() until all context requests are completed aio: add missing smp_rmb() in read_events_ring
