Even though we don't use the OOB for MLC nand flash,
we should use the bad block information to skip the bad block.
Patch url:
http://patchwork.ozlabs.org/linux-mtd/patch?q=mlc&filter=none&id=15477
Author:Kyungmin Park
Signed-off-by: Jason Liu <r64343@freescale.com>
JFFS2 community fix with not use OOB at MLC NAND, this patch
is coming from the MTD community
Since v9ses->uid is unsigned, it would seem better to use simple_strtoul that
simple_strtol.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r2@
long e;
position p;
e = simple_strtol@p(...)
position p != r2.p;
type T;
T e;
e =
- simple_strtol@p
+ simple_strtoul
// </smpl>
Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
d_iname is rubbish for long file names.
Use d_name.name in printks instead.
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
Signed-off-by: Duane Griffin <duaneg@dghda.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2:
ocfs2: Add JBD2 compat feature bit.
ocfs2: Always update xattr search when creating bucket.
While testing a kernel with memory poisoning enabled, I saw some warnings
about the redzone getting clobbered when chasing DFS referrals. The
buffer allocation for the unicode converted version of the searchName is
too small and needs to take null termination into account.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Steve French <sfrench@us.ibm.com>
Define the OCFS2_FEATURE_COMPAT_JBD2 bit in the filesystem header.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
When we create xattr bucket during the process of xattr set, we always
need to update the ocfs2_xattr_search since even if the bucket size is
the same as block size, the offset will change because of the removal
of the ocfs2_xattr_block header.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland
* 'to-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland:
tracehook: exec double-reporting fix
Miles Lane tailing /sys files hit a BUG which Pekka Enberg has tracked
to my 966c8c12dc9e77f931e2281ba25d2f0244b06949 sprint_symbol(): use
less stack exposing a bug in slub's list_locations() -
kallsyms_lookup() writes a 0 to namebuf[KSYM_NAME_LEN-1], but that was
beyond the end of page provided.
The 100 slop which list_locations() allows at end of page looks roughly
enough for all the other stuff it might print after the symbol before
it checks again: break out KSYM_SYMBOL_LEN earlier than before.
Latencytop and ftrace and are using KSYM_NAME_LEN buffers where they
need KSYM_SYMBOL_LEN buffers, and vmallocinfo a 2*KSYM_NAME_LEN buffer
where it wants a KSYM_SYMBOL_LEN buffer: fix those before anyone copies
them.
[akpm@linux-foundation.org: ftrace.h needs module.h]
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Cc Miles Lane <miles.lane@gmail.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Steven Rostedt <srostedt@redhat.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
On umount two event will be dispatched to watcher:
1: inotify_dev_queue_event(.., IN_UNMOUNT,..)
2: remove_watch(watch, dev)
->inotify_dev_queue_event(.., IN_IGNORED, ..)
But if watcher has IN_ONESHOT bit set then the watcher will be released
inside first event. Which result in accessing invalid object later. IMHO
it is not pure regression. This bug wasn't triggered while initial
inotify interface testing phase because of another bug in IN_ONESHOT
handling logic :)
commit ac74c00e499ed276a965e5b5600667d5dc04a84a
Author: Ulisses Furquim <ulissesf@gmail.com>
Date: Fri Feb 8 04:18:16 2008 -0800
inotify: fix check for one-shot watches before destroying them
As the IN_ONESHOT bit is never set when an event is sent we must check it
in the watch's mask and not in the event's mask.
TESTCASE:
mkdir mnt
mount -ttmpfs none mnt
mkdir mnt/d
./inotify mnt/d&
umount mnt ## << lockup or crash here
TESTSOURCE:
/* gcc -oinotify inotify.c */
#include <stdio.h>
#include <stdlib.h>
#include <sys/inotify.h>
int main(int argc, char **argv)
char buf[1024];
struct inotify_event *ie;
char *p;
int i;
ssize_t l;
p = argv[1];
i = inotify_init();
inotify_add_watch(i, p, ~0);
l = read(i, buf, sizeof(buf));
printf("read %d bytes\n", l);
ie = (struct inotify_event *) buf;
printf("event mask: %d\n", ie->mask);
return 0;
Signed-off-by: Dmitri Monakhov <dmonakhov@openvz.org>
Cc: John McCutchan <ttb@tentacle.dhs.org>
Cc: Robert Love <rlove@google.com>
Cc: Ulisses Furquim <ulissesf@gmail.com>
The large pages fix from bcf8039ed45 broke 32-bit pagemap by pulling the
pagemap entry code out into a function with the wrong return type.
Pagemap entries are 64 bits on all systems and unsigned long is only 32
bits on 32-bit systems.
Signed-off-by: Matt Mackall <mpm@selenic.com>
Reported-by: Doug Graham <dgraham@nortel.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: <stable@kernel.org> [2.6.26.x, 2.6.27.x]
Revert
commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e
Author: Mingming Cao <cmm@us.ibm.com>
Date: Fri Jul 11 19:27:31 2008 -0400
percpu_counter: new function percpu_counter_sum_and_set
As described in
revert "percpu counter: clean up percpu_counter_sum_and_set()"
the new percpu_counter_sum_and_set() is racy against updates to the
cpu-local accumulators on other CPUs. Revert that change.
This means that ext4 will be slow again. But correct.
Reported-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: Mingming Cao <cmm@us.ibm.com>
Cc: <linux-ext4@vger.kernel.org>
Cc: <stable@kernel.org> [2.6.27.x]
Revert
commit 1f7c14c62ce63805f9574664a6c6de3633d4a354
Date: Thu Oct 9 12:50:59 2008 -0400
Before this patch we had the following:
percpu_counter_sum(): return the percpu_counter's value
percpu_counter_sum_and_set(): return the percpu_counter's value, copying
that value into the central value and zeroing the per-cpu counters before
returning.
After this patch, percpu_counter_sum_and_set() has gone, and
percpu_counter_sum() gets the old percpu_counter_sum_and_set()
functionality.
Problem is, as Eric points out, the old percpu_counter_sum_and_set()
functionality was racy and wrong. It zeroes out counters on "other" cpus,
without holding any locks which will prevent races agaist updates from
those other CPUS.
This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means
that percpu_counter_sum_and_set() still has the race, but
percpu_counter_sum() does not.
Note that this is not a simple revert - ext4 has since started using
percpu_counter_sum() for its dirty_blocks counter as well.
Note that this revert patch changes percpu_counter_sum() semantics.
Before the patch, a call to percpu_counter_sum() will bring the counter's
central counter mostly up-to-date, so a following percpu_counter_read()
will return a close value.
After this patch, a call to percpu_counter_sum() will leave the counter's
central accumulator unaltered, so a subsequent call to
percpu_counter_read() can now return a significantly inaccurate result.
If there is any code in the tree which was introduced after
e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends
upon the new percpu_counter_sum() semantics, that code will break.
The patch 6341c39 "tracehook: exec" introduced a small regression in
2.6.27 regarding binfmt_misc exec event reporting. Since the reporting
is now done in the common search_binary_handler() function, an exec
of a misc binary will result in two (or possibly multiple) exec events
being reported, instead of just a single one, because the misc handler
contains a recursive call to search_binary_handler.
To add to the confusion, if PTRACE_O_TRACEEXEC is not active, the multiple
SIGTRAP signals will in fact cause only a single ptrace intercept, as the
signals are not queued. However, if PTRACE_O_TRACEEXEC is on, the debugger
will actually see multiple ptrace intercepts (PTRACE_EVENT_EXEC).
The test program included below demonstrates the problem.
This change fixes the bug by calling tracehook_report_exec() only in the
outermost search_binary_handler() call (bprm->recursion_depth == 0).
The additional change to restore bprm->recursion_depth after each binfmt
load_binary call is actually superfluous for this bug, since we test the
value saved on entry to search_binary_handler(). But it keeps the use of
of the depth count to its most obvious expected meaning. Depending on what
binfmt handlers do in certain cases, there could have been false-positive
tests for recursion limits before this change.
/* Test program using PTRACE_O_TRACEEXEC.
This forks and exec's the first argument with the rest of the arguments,
while ptrace'ing. It expects to see one PTRACE_EVENT_EXEC stop and
then a successful exit, with no other signals or events in between.
Test for kernel doing two PTRACE_EVENT_EXEC stops for a binfmt_misc exec:
$ gcc -g traceexec.c -o traceexec
$ sudo sh -c 'echo :test:M::foobar::/bin/cat: > /proc/sys/fs/binfmt_misc/register'
$ echo 'foobar test' > ./foobar
$ chmod +x ./foobar
$ ./traceexec ./foobar; echo $?
==> good <==
foobar test
0
==> bad <==
foobar test
unexpected status 0x4057f != 0
3
#include <stdio.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <sys/ptrace.h>
#include <unistd.h>
#include <signal.h>
#include <stdlib.h>
static void
wait_for (pid_t child, int expect)
int status;
pid_t p = wait (&status);
if (p != child)
perror ("wait");
exit (2);
if (status != expect)
fprintf (stderr, "unexpected status %#x != %#x\n", status, expect);
exit (3);
int
main (int argc, char **argv)
pid_t child = fork ();
if (child < 0)
perror ("fork");
return 127;
else if (child == 0)
ptrace (PTRACE_TRACEME);
raise (SIGUSR1);
execv (argv[1], &argv[1]);
perror ("execve");
_exit (127);
wait_for (child, W_STOPCODE (SIGUSR1));
if (ptrace (PTRACE_SETOPTIONS, child,
0L, (void *) (long) PTRACE_O_TRACEEXEC) != 0)
perror ("PTRACE_SETOPTIONS");
return 4;
if (ptrace (PTRACE_CONT, child, 0L, 0L) != 0)
perror ("PTRACE_CONT");
return 5;
wait_for (child, W_STOPCODE (SIGTRAP | (PTRACE_EVENT_EXEC << 8)));
return 6;
wait_for (child, W_EXITCODE (0, 0));
return 0;
CC: Ulrich Weigand <ulrich.weigand@de.ibm.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
While 440037287c5 "[PATCH] switch all filesystems over to
d_obtain_alias" removed some cases where fh_to_dentry() and
fh_to_parent() could return NULL, there are still a few NULL returns
left in individual filesystems. Thus it was a mistake for that commit
to remove the handling of NULL returns in the callers.
Revert those parts of 440037287c5 which removed the NULL handling.
(We could, alternatively, modify all implementations to return -ESTALE
instead of NULL, but that proves to require fixing a number of
filesystems, and in some cases it's arguably more natural to return
NULL.)
Thanks to David for original patch and Linus, Christoph, and Hugh for
review.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Cc: Hugh Dickins <hugh@veritas.com>
Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync()
functions without the BKL) introduced a race which could leave
file->f_flags in a state inconsistent with what the underlying
driver/filesystem believes. Revert that change, and also fix the same
races in ioctl_fioasync() and ioctl_fionbio().
This is a minimal, short-term fix; the real fix will not involve the
BKL.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: stable@kernel.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev:
[PATCH] fix bogus argument of blkdev_put() in pktcdvd
[PATCH 2/2] documnt FMODE_ constants
[PATCH 1/2] kill FMODE_NDELAY_NOW
[PATCH] clean up blkdev_get a little bit
[PATCH] Fix block dev compat ioctl handling
[PATCH] kill obsolete temporary comment in swsusp_close()
When project quota is active and is being used for directory tree
quota control, we disallow rename outside the current directory
tree. This requires a check to be made after all the inodes
involved in the rename are locked. We fail to unlock the inodes
correctly if we disallow the rename when the target is outside the
current directory tree. This results in a hang on the next access
to the inodes involved in failed rename.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Signed-off-by: Dave Chinner <david@fromorbit.com>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Update FMODE_NDELAY before each ioctl call so that we can kill the
magic FMODE_NDELAY_NOW. It would be even better to do this directly
in setfl(), but for that we'd need to have FMODE_NDELAY for all files,
not just block special files.
The way the bd_claim for the FMODE_EXCL case is implemented is rather
confusing. Clean it up to the most logical style.
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux:
NLM: client-side nlm_lookup_host() should avoid matching on srcaddr
nfsd: use of unitialized list head on error exit in nfs4recover.c
Add a reference to sunrpc in svc_addsock
nfsd: clean up grace period on early exit
* 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: pre-allocate bulk-read buffer
UBIFS: do not allocate too much
UBIFS: do not print scary memory allocation warnings
UBIFS: allow for gaps when dirtying the LPT
UBIFS: fix compilation warnings
MAINTAINERS: change UBI/UBIFS git tree URLs
UBIFS: endian handling fixes and annotations
UBIFS: remove printk
kernel-doc handles macros now (it has for quite some time), so change the
ntfs_debug() macro's kernel-doc to be just before the macro instead of
before a phony function prototype.
Cc: Anton Altaparmakov <aia21@cantab.net>
It has been thought that the per-user file descriptors limit would also
limit the resources that a normal user can request via the epoll
interface. Vegard Nossum reported a very simple program (a modified
version attached) that can make a normal user to request a pretty large
amount of kernel memory, well within the its maximum number of fds. To
solve such problem, default limits are now imposed, and /proc based
configuration has been introduced. A new directory has been created,
named /proc/sys/fs/epoll/ and inside there, there are two configuration
max_user_instances = Maximum number of devices - per user
max_user_watches = Maximum number of "watched" fds - per user
The current default for "max_user_watches" limits the memory used by epoll
to store "watches", to 1/32 of the amount of the low RAM. As example, a
256MB 32bit machine, will have "max_user_watches" set to roughly 90000.
That should be enough to not break existing heavy epoll users. The
default value for "max_user_instances" is set to 128, that should be
enough too.
This also changes the userspace, because a new error code can now come out
from EPOLL_CTL_ADD (-ENOSPC). The EMFILE from epoll_create() was already
listed, so that should be ok.
[akpm@linux-foundation.org: use get_current_user()]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Reported-by: Vegard Nossum <vegardno@ifi.uio.no>
We're panicing in ocfs2_read_blocks_sync() if a jbd-managed buffer is seen.
At first glance, this seems ok but in reality it can happen. My test case
was to just run 'exorcist'. A struct inode is being pushed out of memory but
is then re-read at a later time, before the buffer has been checkpointed by
jbd. This causes a BUG to be hit in ocfs2_read_blocks_sync().
Reviewed-by: Joel Becker <joel.becker@oracle.com>
In init_dlmfs_fs(), if calling kmem_cache_create() failed, the code will use return value from
calling bdi_init(). The correct behavior should be set status as -ENOMEM before going to "bail:".
Signed-off-by: Coly Li <coyli@suse.de>
Acked-by: Sunil Mushran <sunil.mushran@oracle.com>
In ocfs2_unlock_ast(), call wake_up() on lockres before releasing
the spin lock on it. As soon as the spin lock is released, the
lockres can be freed.
Signed-off-by: David Teigland <teigland@redhat.com>
The locking_state dump, ocfs2_dlm_seq_show, reads the lvb on locks where it
has not yet been initialized by a lock call.
Acked-by: Joel Becker <joel.becker@oracle.com>
This patch fixes two typos in comments of ocfs2.
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
[CIFS] fix regression in cifs_write_begin/cifs_write_end
udf_clear_inode() can leave behind buffers on mapping's i_private list (when
we truncated preallocation). Call invalidate_inode_buffers() so that the list
is properly cleaned-up before we return from udf_clear_inode(). This is ugly
and suggest that we should cleanup preallocation earlier than in clear_inode()
but currently there's no such call available since drop_inode() is called under
inode lock and thus is unusable for disk operations.
The conversion to write_begin/write_end interfaces had a bug where we
were passing a bad parameter to cifs_readpage_worker. Rather than
passing the page offset of the start of the write, we needed to pass the
offset of the beginning of the page. This was reliably showing up as
data corruption in the fsx-linux test from LTP.
It also became evident that this code was occasionally doing unnecessary
read calls. Optimize those away by using the PG_checked flag to indicate
that the unwritten part of the page has been initialized.
CC: Nick Piggin <npiggin@suse.de>
Acked-by: Dave Kleikamp <shaggy@us.ibm.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Since commit c98451bd, the loop in nlm_lookup_host() unconditionally
compares the host's h_srcaddr field to the incoming source address.
For client-side nlm_host entries, both are always AF_UNSPEC, so this
check is unnecessary.
Since commit 781b61a6, which added support for AF_INET6 addresses to
nlm_cmp_addr(), nlm_cmp_addr() now returns FALSE for AF_UNSPEC
addresses, which causes nlm_lookup_host() to create a fresh nlm_host
entry every time it is called on the client.
These extra entries will eventually expire once the server is
unmounted, so the impact of this regression, introduced with lockd
IPv6 support in 2.6.28, should be minor.
We could fix this by adding an arm in nlm_cmp_addr() for AF_UNSPEC
addresses, but really, nlm_lookup_host() shouldn't be matching on the
srcaddr field for client-side nlm_host lookups.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Thanks to Matthew Dodd for this bug report:
A file label issue while running SELinux in MLS mode provoked the
following bug, which is a result of use before init on a 'struct list_head'.
In nfsd4_list_rec_dir() if the call to dentry_open() fails the 'goto
out' skips INIT_LIST_HEAD() which results in the normally improbable
case where list_entry() returns NULL.
Trace follows.
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
SELinux: Context unconfined_t:object_r:var_lib_nfs_t:s0 is not valid
(left unmapped).
type=1400 audit(1227298063.609:282): avc: denied { read } for
pid=1890 comm="rpc.nfsd" name="v4recovery" dev=dm-0 ino=148726
scontext=system_u:system_r:nfsd_t:s0-s15:c0.c1023
tcontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tclass=dir
BUG: unable to handle kernel NULL pointer dereference at 00000004
IP: [<c050894e>] list_del+0x6/0x60
*pde = 0d9ce067 *pte = 00000000
Oops: 0000 [#1] SMP
Modules linked in: nfsd lockd nfs_acl auth_rpcgss exportfs autofs4
sunrpc ipv6 dm_multipath scsi_dh ppdev parport_pc sg parport floppy
ata_piix pata_acpi ata_generic libata pcnet32 i2c_piix4 mii pcspkr
i2c_core dm_snapshot dm_zero dm_mirror dm_log dm_mod BusLogic sd_mod
scsi_mod crc_t10dif ext3 jbd mbcache uhci_hcd ohci_hcd ehci_hcd [last
unloaded: microcode]
Pid: 1890, comm: rpc.nfsd Not tainted (2.6.27.5-37.fc9.i686 #1)
EIP: 0060:[<c050894e>] EFLAGS: 00010217 CPU: 0
EIP is at list_del+0x6/0x60
EAX: 00000000 EBX: 00000000 ECX: 00000000 EDX: cd99e480
ESI: cf9caed8 EDI: 00000000 EBP: cf9caebc ESP: cf9caeb8
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process rpc.nfsd (pid: 1890, ti=cf9ca000 task=cf4de580 task.ti=cf9ca000)
Stack: 00000000 cf9caef0 d0a9f139 c0496d04 d0a9f217 fffffff3 00000000
00000000
00000000 00000000 cf32b220 00000000 00000008 00000801 cf9caefc
d0a9f193
00000000 cf9caf08 d0a9b6ea 00000000 cf9caf1c d0a874f2 cf9c3004
00000008
Call Trace:
[<d0a9f139>] ? nfsd4_list_rec_dir+0xf3/0x13a [nfsd]
[<c0496d04>] ? do_path_lookup+0x12d/0x175
[<d0a9f217>] ? load_recdir+0x0/0x26 [nfsd]
[<d0a9f193>] ? nfsd4_recdir_load+0x13/0x34 [nfsd]
[<d0a9b6ea>] ? nfs4_state_start+0x2a/0xc5 [nfsd]
[<d0a874f2>] ? nfsd_svc+0x51/0xff [nfsd]
[<d0a87f2d>] ? write_svc+0x0/0x1e [nfsd]
[<d0a87f48>] ? write_svc+0x1b/0x1e [nfsd]
[<d0a87854>] ? nfsctl_transaction_write+0x3a/0x61 [nfsd]
[<c04b6a4e>] ? sys_nfsservctl+0x116/0x154
[<c04975c1>] ? putname+0x24/0x2f
[<c048d49f>] ? do_sys_open+0xad/0xb7
[<c048d337>] ? filp_close+0x50/0x5a
[<c048d4eb>] ? sys_open+0x1e/0x26
[<c0403cca>] ? syscall_call+0x7/0xb
[<c064007b>] ? init_cyrix+0x185/0x490
Code: 75 e1 8b 53 08 8d 4b 04 8d 46 04 e8 75 00 00 00 8b 53 10 8d 4b 0c
8d 46 0c e8 67 00 00 00 5b 5e 5f 5d c3 90 90 55 89 e5 53 89 c3 <8b> 40
04 8b 00 39 d8 74 16 50 53 68 3e d6 6f c0 6a 30 68 78 d6
EIP: [<c050894e>] list_del+0x6/0x60 SS:ESP 0068:cf9caeb8
---[ end trace a89c4ad091c4ad53 ]---
Cc: Matthew N. Dodd <Matthew.Dodd@spart.com>
If nfsd was shut down before the grace period ended, we could end up
with a freed object still on grace_list. Thanks to Jeff Moyer for
reporting the resulting list corruption warnings.
Tested-by: Jeff Moyer <jmoyer@redhat.com>
To avoid memory allocation failure during bulk-read, pre-allocate
a bulk-read buffer, so that if there is only one bulk-reader at
a time, it would just use the pre-allocated buffer and would not
do any memory allocation. However, if there are more than 1 bulk-
reader, then only one reader would use the pre-allocated buffer,
while the other reader would allocate the buffer for itself.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Bulk-read allocates 128KiB or more using kmalloc. The allocation
starts failing often when the memory gets fragmented. UBIFS still
works fine in this case, because it falls-back to standard
(non-optimized) read method, though. This patch teaches bulk-read
to allocate exactly the amount of memory it needs, instead of
allocating 128KiB every time.
This patch is also a preparation to the further fix where we'll
have a pre-allocated bulk-read buffer as well. For example, now
the @bu object is prepared in 'ubifs_bulk_read()', so we could
path either pre-allocated or allocated information to
'ubifs_do_bulk_read()' later. Or teaching 'ubifs_do_bulk_read()'
not to allocate 'bu->buf' if it is already there.
Bulk-read allocates a lot of memory with 'kmalloc()', and when it
is/gets fragmented 'kmalloc()' fails with a scarry warning. But
because bulk-read is just an optimization, UBIFS keeps working fine.
Supress the warning by passing __GFP_NOWARN option to 'kmalloc()'.
This patch also introduces a macro for the magic 128KiB constant.
This is just neater.
Note, this is not really fixes the problem we had, but just hides
the warnings. The further patches fix the problem.
[CIFS] Do not attempt to close invalidated file handles
[CIFS] fix check for dead tcon in smb_init
If a connection with open file handles has gone down
and come back up and reconnected without reopening
the file handle yet, do not attempt to send an SMB close
request for this handle in cifs_close. We were
checking for the connection being invalid in cifs_close
but since the connection may have been reconnected
we also need to check whether the file handle
was marked invalid (otherwise we could close the
wrong file handle by accident).
Acked-by: Jeff Layton <jlayton@redhat.com>
fs/hostfs/hostfs_user.c defines do_readlink() as non-static, and so does
fs/xfs/linux-2.6/xfs_ioctl.c when CONFIG_XFS_DEBUG=y. So rename
do_readlink() in hostfs to hostfs_do_readlink().
I think it's better if XFS guys will also rename their do_readlink(),
it's not necessary to use such a general name.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Cc: Jeff Dike <jdike@addtoit.com>
Peter Cordes is sorry that he rm'ed his swapfiles while they were in use,
he then had no pathname to swapoff. It's a curious little oversight, but
not one worth a lot of hackery. Kudos to Willy Tarreau for turning this
around from a discussion of synthetic pathnames to how to prevent unlink.
Mimic immutable: prohibit unlinking an active swapfile in may_delete()
(and don't worry my little head over the tiny race window).
Cc: Willy Tarreau <w@1wt.eu>
Acked-by: Christoph Hellwig <hch@infradead.org>
Cc: Peter Cordes <peter@cordes.ca>
Cc: Bodo Eggert <7eggert@gmx.de>
Cc: David Newall <davidn@davidnewall.com>
I have received some reports of out-of-memory errors on some older AMD
architectures. These errors are what I would expect to see if
crypt_stat->key were split between two separate pages. eCryptfs should
not assume that any of the memory sent through virt_to_scatterlist() is
all contained in a single page, and so this patch allocates two
scatterlist structs instead of one when processing keys. I have received
confirmation from one person affected by this bug that this patch resolves
the issue for him, and so I am submitting it for inclusion in a future
stable release.
Note that virt_to_scatterlist() runs sg_init_table() on the scatterlist
structs passed to it, so the calls to sg_init_table() in
decrypt_passphrase_encrypted_session_key() are redundant.
Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com>
Reported-by: Paulo J. S. Silva <pjssilva@ime.usp.br>
Cc: "Leon Woestenberg" <leon.woestenberg@gmail.com>
Cc: Tim Gardner <tim.gardner@canonical.com>
This was recently changed to check for need_reconnect, but should
actually be a check for a tidStatus of CifsExiting.
Block ext devt conversion missed md_autodetect_dev() call in
rescan_partitions() leaving md autodetect unable to see partitions.
Fix it.
Cc: Neil Brown <neilb@suse.de>
Make add_partition() return pointer to the new hd_struct on success
and ERR_PTR() value on failure. This change will be used to fix md
autodetection bug.
Partition stats structure was not freed on devt allocation failure
path. Fix it.
prevent cifs_writepages() from skipping unwritten pages
Fixed parsing of mount options when doing DFS submount
[CIFS] Fix check for tcon seal setting and fix oops on failed mount from earlier patch
[CIFS] Fix build break
cifs: reinstate sharing of tree connections
[CIFS] minor cleanup to cifs_mount
cifs: reinstate sharing of SMB sessions sans races
cifs: disable sharing session and tcon and add new TCP sharing code
[CIFS] clean up server protocol handling
[CIFS] remove unused list, add new cifs sock list to prepare for mount/umount fix
[CIFS] Fix cifs reconnection flags
[CIFS] Can't rely on iov length and base when kernel_recvmsg returns error
