path: root/fs
2016-10-23Merge tag 'upstream-4.9-rc2' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI[FS] fixes from Richard Weinberger: "This contains fixes for issues in both UBI and UBIFS: - Fallout from the merge window, refactoring UBI code introduced some issues. - Fixes for an UBIFS readdir bug which can cause getdents() to busy loop for ever and a bug in the UBIFS xattr code" * tag 'upstream-4.9-rc2' of git://git.infradead.org/linux-ubifs: ubifs: Abort readdir upon error UBI: Fix crash in try_recover_peb() ubi: fix swapped arguments to call to ubi_alloc_aeb ubifs: Fix xattr_names length in exit paths ubifs: Rename ubifs_rename2
2016-10-23Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 fixes from Ted Ts'o: "A few bug fixes and add some missing KERN_CONT annotations" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: add missing KERN_CONT to a few more debugging uses fscrypto: lock inode while setting encryption policy ext4: correct endianness conversion in __xattr_check_inode() fscrypto: make XTS tweak initialization endian-independent ext4: do not advertise encryption support when disabled jbd2: fix incorrect unlock on j_list_lock ext4: super.c: Update logging style using KERN_CONT
2016-10-22Merge branch 'mm-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull vmap stack fixes from Ingo Molnar: "This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack accesses that used to be just somewhat questionable are now totally buggy. These changes try to do it without breaking the ABI: the fields are left there, they are just reporting zero, or reporting narrower information (the maps file change)" * 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm: Change vm_is_stack_for_task() to vm_is_stack_for_current() fs/proc: Stop trying to report thread stacks fs/proc: Stop reporting eip and esp in /proc/PID/stat mm/numa: Remove duplicated include from mprotect.c
2016-10-21Merge tag 'nfs-for-4.9-2' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Anna Schumaker: "Just two bugfixes this time: Stable bugfix: - Fix last_write_offset incorrectly set to page boundary Other bugfix: - Fix missing-braces warning" * tag 'nfs-for-4.9-2' of git://git.linux-nfs.org/projects/anna/linux-nfs: nfs4: fix missing-braces warning pnfs/blocklayout: fix last_write_offset incorrectly set to page boundary
2016-10-20Merge tag 'ceph-for-4.9-rc2' of git://github.com/ceph/ceph-clientLinus Torvalds
Pull Ceph fixes from Ilya Dryomov: "An rbd exclusive-lock edge case fix and several filesystem fixups. Nikolay's error path patch is tagged for stable, everything else but readdir vs frags race was introduced in this merge window" * tag 'ceph-for-4.9-rc2' of git://github.com/ceph/ceph-client: ceph: fix non static symbol warning ceph: fix uninitialized dentry pointer in ceph_real_mount() ceph: fix readdir vs fragmentation race ceph: fix error handling in ceph_read_iter rbd: don't retry watch reregistration if header object is gone rbd: don't wait for the lock forever if blacklisted
2016-10-20Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull misc filesystem fixes from Jan Kara: "A fix for an isofs change apparently breaking mount(8) in some cases and one ext2 warning fix" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext2: avoid bogus -Wmaybe-uninitialized warning isofs: Do not return EACCES for unknown filesystems
2016-10-20fs/proc: Stop trying to report thread stacksAndy Lutomirski
This reverts more of: b76437579d13 ("procfs: mark thread stack correctly in proc/<pid>/maps") ... which was partially reverted by: 65376df58217 ("proc: revert /proc/<pid>/maps [stack:TID] annotation") Originally, /proc/PID/task/TID/maps was the same as /proc/TID/maps. In current kernels, /proc/PID/maps (or /proc/TID/maps even for threads) shows "[stack]" for VMAs in the mm's stack address range. In contrast, /proc/PID/task/TID/maps uses KSTK_ESP to guess the target thread's stack's VMA. This is racy, probably returns garbage and, on arches with CONFIG_TASK_INFO_IN_THREAD=y, is also crash-prone: KSTK_ESP is not safe to use on tasks that aren't known to be running ordinary process-context kernel code. This patch removes the difference and just shows "[stack]" for VMAs in the mm's stack range. This is IMO much more sensible -- the actual "stack" address really is treated specially by the VM code, and the current thread stack isn't even well-defined for programs that frequently switch stacks on their own. Reported-by: Jann Horn <jann@thejh.net> Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux API <linux-api@vger.kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tycho Andersen <tycho.andersen@canonical.com> Link: http://lkml.kernel.org/r/3e678474ec14e0a0ec34c611016753eea2e1b8ba.1475257877.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-20fs/proc: Stop reporting eip and esp in /proc/PID/statAndy Lutomirski
Reporting these fields on a non-current task is dangerous. If the task is in any state other than normal kernel code, they may contain garbage or even kernel addresses on some architectures. (x86_64 used to do this. I bet lots of architectures still do.) With CONFIG_THREAD_INFO_IN_TASK=y, it can OOPS, too. As far as I know, there are no use programs that make any material use of these fields, so just get rid of them. Reported-by: Jann Horn <jann@thejh.net> Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux API <linux-api@vger.kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: Tycho Andersen <tycho.andersen@canonical.com> Link: http://lkml.kernel.org/r/a5fed4c3f4e33ed25d4bb03567e329bc5a712bcc.1475257877.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-20ubifs: Abort readdir upon errorRichard Weinberger
If UBIFS is facing an error while walking a directory, it reports this error and ubifs_readdir() returns the error code. But the VFS readdir logic does not make the getdents system call fail in all cases. When the readdir cursor indicates that more entries are present, the system call will just return and the libc wrapper will try again since it also knows that more entries are present. This causes the libc wrapper to busy loop for ever when a directory is corrupted on UBIFS. A common approach do deal with corrupted directory entries is skipping them by setting the cursor to the next entry. On UBIFS this approach is not possible since we cannot compute the next directory entry cursor position without reading the current entry. So all we can do is setting the cursor to the "no more entries" position and make getdents exit. Cc: stable@vger.kernel.org Signed-off-by: Richard Weinberger <richard@nod.at>
2016-10-20ubifs: Fix xattr_names length in exit pathsRichard Weinberger
When the operation fails we also have to undo the changes we made to ->xattr_names. Otherwise listxattr() will report wrong lengths. Cc: stable@vger.kernel.org Signed-off-by: Richard Weinberger <richard@nod.at>
2016-10-20ubifs: Rename ubifs_rename2Richard Weinberger
Since ->rename2 is gone, rename ubifs_rename2() to ubifs_rename(). Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Richard Weinberger <richard@nod.at>
2016-10-19nfs4: fix missing-braces warningArnd Bergmann
A bugfix introduced a harmless warning for update_open_stateid: fs/nfs/nfs4proc.c:1548:2: error: missing braces around initializer [-Werror=missing-braces] Removing the zero in the initializer will do the right thing here and initialize the entire structure to zero. Fixes: 1393d9612ba0 ("NFSv4: Fix a race when updating an open_stateid") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-10-19Merge branch 'gup_flag-cleanups'Linus Torvalds
Merge the gup_flags cleanups from Lorenzo Stoakes: "This patch series adjusts functions in the get_user_pages* family such that desired FOLL_* flags are passed as an argument rather than implied by flags. The purpose of this change is to make the use of FOLL_FORCE explicit so it is easier to grep for and clearer to callers that this flag is being used. The use of FOLL_FORCE is an issue as it overrides missing VM_READ/VM_WRITE flags for the VMA whose pages we are reading from/writing to, which can result in surprising behaviour. The patch series came out of the discussion around commit 38e088546522 ("mm: check VMA flags to avoid invalid PROT_NONE NUMA balancing"), which addressed a BUG_ON() being triggered when a page was faulted in with PROT_NONE set but having been overridden by FOLL_FORCE. do_numa_page() was run on the assumption the page _must_ be one marked for NUMA node migration as an actual PROT_NONE page would have been dealt with prior to this code path, however FOLL_FORCE introduced a situation where this assumption did not hold. See https://marc.info/?l=linux-mm&m=147585445805166 for the patch proposal" Additionally, there's a fix for an ancient bug related to FOLL_FORCE and FOLL_WRITE by me. [ This branch was rebased recently to add a few more acked-by's and reviewed-by's ] * gup_flag-cleanups: mm: replace access_process_vm() write parameter with gup_flags mm: replace access_remote_vm() write parameter with gup_flags mm: replace __access_remote_vm() write parameter with gup_flags mm: replace get_user_pages_remote() write/force parameters with gup_flags mm: replace get_user_pages() write/force parameters with gup_flags mm: replace get_vaddr_frames() write/force parameters with gup_flags mm: replace get_user_pages_locked() write/force parameters with gup_flags mm: replace get_user_pages_unlocked() write/force parameters with gup_flags mm: remove write/force parameters from __get_user_pages_unlocked() mm: remove write/force parameters from __get_user_pages_locked() mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
2016-10-19mm: replace access_remote_vm() write parameter with gup_flagsLorenzo Stoakes
This removes the 'write' argument from access_remote_vm() and replaces it with 'gup_flags' as use of this function previously silently implied FOLL_FORCE, whereas after this patch callers explicitly pass this flag. We make this explicit as use of FOLL_FORCE can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-19mm: replace get_user_pages_remote() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' from get_user_pages_remote() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-18Merge tag 'for-f2fs-4.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs bugfix from Jaegeuk Kim: "This fixes a bug which referenced the wrong pointer, sum_page, in f2fs_gc. It was newly introduced in 4.9-rc1. * tag 'for-f2fs-4.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: f2fs: fix wrong sum_page pointer in f2fs_gc
2016-10-18Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two fixes: - a file locks fix (missing critical section, bug introduced in this merge window) - an x86 down_write() stack frame annotation" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking, fs/locks: Add missing file_sem locks locking/rwsem/x86: Add stack frame dependency for ____down_write()
2016-10-18ceph: fix non static symbol warningWei Yongjun
Fixes the following sparse warning: fs/ceph/xattr.c:19:28: warning: symbol 'ceph_other_xattr_handler' was not declared. Should it be static? Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2016-10-18locking, fs/locks: Add missing file_sem locksPeter Zijlstra
I overlooked a few code-paths that can lead to locks_delete_global_locks(). Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Jeff Layton <jlayton@poochiereds.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Bruce Fields <bfields@fieldses.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-fsdevel@vger.kernel.org Cc: syzkaller <syzkaller@googlegroups.com> Link: http://lkml.kernel.org/r/20161008081228.GF3142@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-18ceph: fix uninitialized dentry pointer in ceph_real_mount()Geert Uytterhoeven
fs/ceph/super.c: In function ‘ceph_real_mount’: fs/ceph/super.c:818: warning: ‘root’ may be used uninitialized in this function If s_root is already valid, dentry pointer root is never initialized, and returned by ceph_real_mount(). This will cause a crash later when the caller dereferences the pointer. Fixes: ce2728aaa82bbeba ("ceph: avoid accessing / when mounting a subpath") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2016-10-18ceph: fix readdir vs fragmentation raceYan, Zheng
following sequence of events tigger the race - client readdir frag 0* -> got item 'A' - MDS merges frag 0* and frag 1* - client send readdir request (frag 1*, offset 2, readdir_start 'A') - MDS reply items (that are after item 'A') in frag * Link: http://tracker.ceph.com/issues/17286 Signed-off-by: Yan, Zheng <zyan@redhat.com>
2016-10-18ext2: avoid bogus -Wmaybe-uninitialized warningArnd Bergmann
On ARM, we get this false-positive warning since the rework of the ext2_get_blocks interface: fs/ext2/inode.c: In function 'ext2_get_block': include/linux/buffer_head.h:340:16: error: 'bno' may be used uninitialized in this function [-Werror=maybe-uninitialized] The calling conventions for this function are rather complex, and it's not surprising that the compiler gets this wrong, I spent a long time trying to understand how it all fits together myself. This change to avoid the warning makes sure the compiler sees that we always set 'bno' pointer whenever we have a positive return code. The transformation is correct because we always arrive at the 'got_it' label with a positive count that gets used as the return value, while any branch to the 'cleanup' label has a negative or zero 'err'. Fixes: 6750ad71986d ("ext2: stop passing buffer_head to ext2_get_blocks") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-10-18isofs: Do not return EACCES for unknown filesystemsJan Kara
When isofs_mount() is called to mount a device read-write, it returns EACCES even before it checks that the device actually contains an isofs filesystem. This may confuse mount(8) which then tries to mount all subsequent filesystem types in read-only mode. Fix the problem by returning EACCES only once we verify that the device indeed contains an iso9660 filesystem. CC: stable@vger.kernel.org Fixes: 17b7f7cf58926844e1dd40f5eb5348d481deca6a Reported-by: Kent Overstreet <kent.overstreet@gmail.com> Reported-by: Karel Zak <kzak@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-10-17btrfs: assign error values to the correct bio structsJunjie Mao
Fixes: 4246a0b63bd8 ("block: add a bi_error field to struct bio") Signed-off-by: Junjie Mao <junjie.mao@enight.me> Acked-by: David Sterba <dsterba@suse.cz> Cc: stable@vger.kernel.org # 4.3+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-15ceph: fix error handling in ceph_read_iterNikolay Borisov
In case __ceph_do_getattr returns an error and the retry_op in ceph_read_iter is not READ_INLINE, then it's possible to invoke __free_page on a page which is NULL, this naturally leads to a crash. This can happen when, for example, a process waiting on a MDS reply receives sigterm. Fix this by explicitly checking whether the page is set or not. Cc: stable@vger.kernel.org # 3.19+ Signed-off-by: Nikolay Borisov <kernel@kyup.com> Reviewed-by: Yan, Zheng <zyan@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2016-10-15Merge tag 'befs-v4.9-rc1' of git://github.com/luisbg/linux-befsLinus Torvalds
Pull befs fixes from Luis de Bethencourt: "I recently took maintainership of the befs file system [0]. This is the first time I send you a git pull request, so please let me know if all the below is OK. Salah Triki and myself have been cleaning the code and fixing a few small bugs. Sorry I couldn't send this sooner in the merge window, I was waiting to have my GPG key signed by kernel members at ELCE in Berlin a few days ago." [0] https://lkml.org/lkml/2016/7/27/502 * tag 'befs-v4.9-rc1' of git://github.com/luisbg/linux-befs: (39 commits) befs: befs: fix style issues in datastream.c befs: improve documentation in datastream.c befs: fix typos in datastream.c befs: fix typos in btree.c befs: fix style issues in super.c befs: fix comment style befs: add check for ag_shift in superblock befs: dump inode_size superblock information befs: remove unnecessary initialization befs: fix typo in befs_sb_info befs: add flags field to validate superblock state befs: fix typo in befs_find_key befs: remove unused BEFS_BT_PARMATCH fs: befs: remove ret variable fs: befs: remove in vain variable assignment fs: befs: remove unnecessary *befs_sb variable fs: befs: remove useless initialization to zero fs: befs: remove in vain variable assignment fs: befs: Insert NULL inode to dentry fs: befs: Remove useless calls to brelse in befs_find_brun_dblindirect ...
2016-10-15Merge tag 'gcc-plugins-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull gcc plugins update from Kees Cook: "This adds a new gcc plugin named "latent_entropy". It is designed to extract as much possible uncertainty from a running system at boot time as possible, hoping to capitalize on any possible variation in CPU operation (due to runtime data differences, hardware differences, SMP ordering, thermal timing variation, cache behavior, etc). At the very least, this plugin is a much more comprehensive example for how to manipulate kernel code using the gcc plugin internals" * tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: latent_entropy: Mark functions with __latent_entropy gcc-plugins: Add latent_entropy plugin
2016-10-15ext4: add missing KERN_CONT to a few more debugging usesJoe Perches
Recent commits require line continuing printks to always use pr_cont or KERN_CONT. Add these markings to a few more printks. Miscellaneaous: o Integrate the ea_idebug and ea_bdebug macros to use a single call to printk(KERN_DEBUG instead of 3 separate printks o Use the more common varargs macro style Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Andreas Dilger <adilger@dilger.ca>
2016-10-15fscrypto: lock inode while setting encryption policyEric Biggers
i_rwsem needs to be acquired while setting an encryption policy so that concurrent calls to FS_IOC_SET_ENCRYPTION_POLICY are correctly serialized (especially the ->get_context() + ->set_context() pair), and so that new files cannot be created in the directory during or after the ->empty_dir() check. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Richard Weinberger <richard@nod.at> Cc: stable@vger.kernel.org
2016-10-15ext4: correct endianness conversion in __xattr_check_inode()Eric Biggers
It should be cpu_to_le32(), not le32_to_cpu(). No change in behavior. Found with sparse, and this was the only endianness warning in fs/ext4/. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz>
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more misc uaccess and vfs updates from Al Viro: "The rest of the stuff from -next (more uaccess work) + assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: score: traps: Add missing include file to fix build error fs/super.c: don't fool lockdep in freeze_super() and thaw_super() paths fs/super.c: fix race between freeze_super() and thaw_super() overlayfs: Fix setting IOP_XATTR flag iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector() blackfin: no access_ok() for __copy_{to,from}_user() arm64: don't zero in __copy_from_user{,_inatomic} arm: don't zero in __copy_from_user_inatomic()/__copy_from_user() arc: don't leak bits of kernel stack into coredump alpha: get rid of tail-zeroing in __copy_user()
2016-10-14Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "Including: - nine bug fixes for stable. Some of these we found at the recent two weeks of SMB3 test events/plugfests. - significant improvements in reconnection (e.g. if server or network crashes) especially when mounted with "persistenthandles" or to server which advertises Continuous Availability on the share. - a new mount option "idsfromsid" which improves POSIX compatibility in some cases (when winbind not configured e.g.) by better (and faster) fetching uid/gid from acl (when "cifsacl" mount option is enabled). NB: we are almost complete work on "cifsacl" (querying mode/uid/gid from ACL) for SMB3, but SMB3 support for cifsacl is not included in this set. - improved handling for SMB3 "credits" (even if server is buggy) Still working on two sets of changes: - cifsacl enablement for SMB3 - cleanup of RFC1001 length calculation (so we can handle encryption and multichannel and RDMA) And a couple of new bugs were reported recently (unrelated to above) so will probably have another merge request next week" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: (21 commits) CIFS: Retrieve uid and gid from special sid if enabled CIFS: Add new mount option to set owner uid and gid from special sids in acl CIFS: Reset read oplock to NONE if we have mandatory locks after reopen CIFS: Fix persistent handles re-opening on reconnect SMB2: Separate RawNTLMSSP authentication from SMB2_sess_setup SMB2: Separate Kerberos authentication from SMB2_sess_setup Expose cifs module parameters in sysfs Cleanup missing frees on some ioctls Enable previous version support Do not send SMB3 SET_INFO request if nothing is changing SMB3: Add mount parameter to allow user to override max credits fs/cifs: reopen persistent handles on reconnect Clarify locking of cifs file and tcon structures and make more granular Fix regression which breaks DFS mounting fs/cifs: keep guid when assigning fid to fileinfo SMB3: GUIDs should be constructed as random but valid uuids Set previous session id correctly on SMB3 reconnect cifs: Limit the overall credit acquired Display number of credits available Add way to query creation time of file via cifs xattr ...
2016-10-14Merge branch 'for-linus-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Some fixes from Omar and Dave Sterba for our new free space tree. This isn't heavily used yet, but as we move toward making it the new default we wanted to nail down an endian bug" * 'for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: tests: uninline member definitions in free_space_extent btrfs: tests: constify free space extent specs Btrfs: expand free space tree sanity tests to catch endianness bug Btrfs: fix extent buffer bitmap tests on big-endian systems Btrfs: catch invalid free space trees Btrfs: fix mount -o clear_cache,space_cache=v2 Btrfs: fix free space tree bitmaps on big-endian systems
2016-10-14fs/super.c: don't fool lockdep in freeze_super() and thaw_super() pathsOleg Nesterov
sb_wait_write()->percpu_rwsem_release() fools lockdep to avoid the false-positives. Now that xfs was fixed by Dave's commit dbad7c993053 ("xfs: stop holding ILOCK over filldir callbacks") we can remove it and change freeze_super() and thaw_super() to run with s_writers.rw_sem locks held; we add two trivial helpers for that, lockdep_sb_freeze_release() and lockdep_sb_freeze_acquire(). xfstests-dev/check `grep -il freeze tests/*/???` does not trigger any warning from lockdep. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14Merge branch 'overlayfs-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull overlayfs updates from Miklos Szeredi: "This update contains fixes to the "use mounter's permission to access underlying layers" area, and miscellaneous other fixes and cleanups. No new features this time" * 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: ovl: use vfs_get_link() vfs: add vfs_get_link() helper ovl: use generic_readlink ovl: explain error values when removing acl from workdir ovl: Fix info leak in ovl_lookup_temp() ovl: during copy up, switch to mounter's creds early ovl: lookup: do getxattr with mounter's permission ovl: copy_up_xattr(): use strnlen
2016-10-14fs/super.c: fix race between freeze_super() and thaw_super()Oleg Nesterov
Change thaw_super() to check frozen != SB_FREEZE_COMPLETE rather than frozen == SB_UNFROZEN, otherwise it can race with freeze_super() which drops sb->s_umount after SB_FREEZE_WRITE to preserve the lock ordering. In this case thaw_super() will wrongly call s_op->unfreeze_fs() before it was actually frozen, and call sb_freeze_unlock() which leads to the unbalanced percpu_up_write(). Unfortunately lockdep can't detect this, so this triggers misc BUG_ON()'s in kernel/rcu/sync.c. Reported-and-tested-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14overlayfs: Fix setting IOP_XATTR flagVivek Goyal
ovl_fill_super calls ovl_new_inode to create a root inode for the new superblock before initializing sb->s_xattr. This wrongly causes IOP_XATTR to be cleared in i_opflags of the new inode, causing SELinux to log the following message: SELinux: (dev overlay, type overlay) has no xattr support Fix this by initializing sb->s_xattr and similar fields before calling ovl_new_inode. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector()Vegard Nossum
Both import_iovec() and rw_copy_check_uvector() take an array (typically small and on-stack) which is used to hold an iovec array copy from userspace. This is to avoid an expensive memory allocation in the fast path (i.e. few iovec elements). The caller may have to check whether these functions actually used the provided buffer or allocated a new one -- but this differs between the too. Let's just add a kernel doc to clarify what the semantics are for each function. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14CIFS: Retrieve uid and gid from special sid if enabledSteve French
New mount option "idsfromsid" indicates to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids. This patch adds the code to parse the owner sids in the ACL to see if they match, and if so populate the uid and/or gid from them. This is faster than upcalling for them and asking winbind, and is a fairly common case, and is also helpful when cifs.upcall and idmapping is not configured. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-14CIFS: Add new mount option to set owner uid and gid from special sids in aclSteve French
Add "idsfromsid" mount option to indicate to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids in the ACL if present. This first patch just adds the parsing for the mount option. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-14Merge branch 'for-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - tracepoints for basic cgroup management operations added - kernfs and cgroup path formatting functions updated to behave in the style of strlcpy() - non-critical bug fixes * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: blkcg: Unlock blkcg_pol_mutex only once when cpd == NULL cgroup: fix error handling regressions in proc_cgroup_show() and cgroup_release_agent() cpuset: fix error handling regression in proc_cpuset_show() cgroup: add tracepoints for basic operations cgroup: make cgroup_path() and friends behave in the style of strlcpy() kernfs: remove kernfs_path_len() kernfs: make kernfs_path*() behave in the style of strlcpy() kernfs: add dummy implementation of kernfs_path_from_node()
2016-10-14ovl: use vfs_get_link()Miklos Szeredi
Resulting in a complete removal of a function basically implementing the inverse of vfs_readlink(). As a bonus, now the proper security hook is also called. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-10-14vfs: add vfs_get_link() helperMiklos Szeredi
This helper is for filesystems that want to read the symlink and are better off with the get_link() interface (returning a char *) rather than the readlink() interface (copy into a userspace buffer). Also call the LSM hook for readlink (not get_link) since this is for symlink reading not following. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-10-14ovl: use generic_readlinkMiklos Szeredi
All filesystems that are backers for overlayfs would also use generic_readlink(). Move this logic to the overlay itself, which is a nice cleanup. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-10-14ovl: explain error values when removing acl from workdirMiklos Szeredi
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-10-13Merge tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client updates from Anna Schumaker: "Highlights include: Stable bugfixes: - sunrpc: fix writ espace race causing stalls - NFS: Fix inode corruption in nfs_prime_dcache() - NFSv4: Don't report revoked delegations as valid in nfs_have_delegation() - NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid - NFSv4: Open state recovery must account for file permission changes - NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic Features: - Add support for tracking multiple layout types with an ordered list - Add support for using multiple backchannel threads on the client - Add support for pNFS file layout session trunking - Delay xprtrdma use of DMA API (for device driver removal) - Add support for xprtrdma remote invalidation - Add support for larger xprtrdma inline thresholds - Use a scatter/gather list for sending xprtrdma RPC calls - Add support for the CB_NOTIFY_LOCK callback - Improve hashing sunrpc auth_creds by using both uid and gid Bugfixes: - Fix xprtrdma use of DMA API - Validate filenames before adding to the dcache - Fix corruption of xdr->nwords in xdr_copy_to_scratch - Fix setting buffer length in xdr_set_next_buffer() - Don't deadlock the state manager on the SEQUENCE status flags - Various delegation and stateid related fixes - Retry operations if an interrupted slot receives EREMOTEIO - Make nfs boot time y2038 safe" * tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits) NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic fs: nfs: Make nfs boot time y2038 safe sunrpc: replace generic auth_cred hash with auth-specific function sunrpc: add RPCSEC_GSS hash_cred() function sunrpc: add auth_unix hash_cred() function sunrpc: add generic_auth hash_cred() function sunrpc: add hash_cred() function to rpc_authops struct Retry operation on EREMOTEIO on an interrupted slot pNFS: Fix atime updates on pNFS clients sunrpc: queue work on system_power_efficient_wq NFSv4.1: Even if the stateid is OK, we may need to recover the open modes NFSv4: If recovery failed for a specific open stateid, then don't retry NFSv4: Fix retry issues with nfs41_test/free_stateid NFSv4: Open state recovery must account for file permission changes NFSv4: Mark the lock and open stateids as invalid after freeing them NFSv4: Don't test open_stateid unless it is set NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation NFSv4: Fix a race when updating an open_stateid NFSv4: Fix a race in nfs_inode_reclaim_delegation() ...
2016-10-13Merge tag 'nfsd-4.9' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Some RDMA work and some good bugfixes, and two new features that could benefit from user testing: - Anna Schumacker contributed a simple NFSv4.2 COPY implementation. COPY is already supported on the client side, so a call to copy_file_range() on a recent client should now result in a server-side copy that doesn't require all the data to make a round trip to the client and back. - Jeff Layton implemented callbacks to notify clients when contended locks become available, which should reduce latency on workloads with contended locks" * tag 'nfsd-4.9' of git://linux-nfs.org/~bfields/linux: NFSD: Implement the COPY call nfsd: handle EUCLEAN nfsd: only WARN once on unmapped errors exportfs: be careful to only return expected errors. nfsd4: setclientid_confirm with unmatched verifier should fail nfsd: randomize SETCLIENTID reply to help distinguish servers nfsd: set the MAY_NOTIFY_LOCK flag in OPEN replies nfs: add a new NFS4_OPEN_RESULT_MAY_NOTIFY_LOCK constant nfsd: add a LRU list for blocked locks nfsd: have nfsd4_lock use blocking locks for v4.1+ locks nfsd: plumb in a CB_NOTIFY_LOCK operation NFSD: fix corruption in notifier registration svcrdma: support Remote Invalidation svcrdma: Server-side support for rpcrdma_connect_private rpcrdma: RDMA/CM private message data structure svcrdma: Skip put_page() when send_reply() fails svcrdma: Tail iovec leaves an orphaned DMA mapping nfsd: fix dprintk in nfsd4_encode_getdeviceinfo nfsd: eliminate cb_minorversion field nfsd: don't set a FL_LAYOUT lease for flexfiles layouts
2016-10-13Merge tag 'xfs-reflink-for-linus-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs < XFS has gained super CoW powers! > ---------------------------------- \ ^__^ \ (oo)\_______ (__)\ )\/\ ||----w | || || Pull XFS support for shared data extents from Dave Chinner: "This is the second part of the XFS updates for this merge cycle. This pullreq contains the new shared data extents feature for XFS. Given the complexity and size of this change I am expecting - like the addition of reverse mapping last cycle - that there will be some follow-up bug fixes and cleanups around the -rc3 stage for issues that I'm sure will show up once the code hits a wider userbase. What it is: At the most basic level we are simply adding shared data extents to XFS - i.e. a single extent on disk can now have multiple owners. To do this we have to add new on-disk features to both track the shared extents and the number of times they've been shared. This is done by the new "refcount" btree that sits in every allocation group. When we share or unshare an extent, this tree gets updated. Along with this new tree, the reverse mapping tree needs to be updated to track each owner or a shared extent. This also needs to be updated ever share/unshare operation. These interactions at extent allocation and freeing time have complex ordering and recovery constraints, so there's a significant amount of new intent-based transaction code to ensure that operations are performed atomically from both the runtime and integrity/crash recovery perspectives. We also need to break sharing when writes hit a shared extent - this is where the new copy-on-write implementation comes in. We allocate new storage and copy the original data along with the overwrite data into the new location. We only do this for data as we don't share metadata at all - each inode has it's own metadata that tracks the shared data extents, the extents undergoing CoW and it's own private extents. Of course, being XFS, nothing is simple - we use delayed allocation for CoW similar to how we use it for normal writes. ENOSPC is a significant issue here - we build on the reservation code added in 4.8-rc1 with the reverse mapping feature to ensure we don't get spurious ENOSPC issues part way through a CoW operation. These mechanisms also help minimise fragmentation due to repeated CoW operations. To further reduce fragmentation overhead, we've also introduced a CoW extent size hint, which indicates how large a region we should allocate when we execute a CoW operation. With all this functionality in place, we can hook up .copy_file_range, .clone_file_range and .dedupe_file_range and we gain all the capabilities of reflink and other vfs provided functionality that enable manipulation to shared extents. We also added a fallocate mode that explicitly unshares a range of a file, which we implemented as an explicit CoW of all the shared extents in a file. As such, it's a huge chunk of new functionality with new on-disk format features and internal infrastructure. It warns at mount time as an experimental feature and that it may eat data (as we do with all new on-disk features until they stabilise). We have not released userspace suport for it yet - userspace support currently requires download from Darrick's xfsprogs repo and build from source, so the access to this feature is really developer/tester only at this point. Initial userspace support will be released at the same time the kernel with this code in it is released. The new code causes 5-6 new failures with xfstests - these aren't serious functional failures but things the output of tests changing slightly due to perturbations in layouts, space usage, etc. OTOH, we've added 150+ new tests to xfstests that specifically exercise this new functionality so it's got far better test coverage than any functionality we've previously added to XFS. Darrick has done a pretty amazing job getting us to this stage, and special mention also needs to go to Christoph (review, testing, improvements and bug fixes) and Brian (caught several intricate bugs during review) for the effort they've also put in. Summary: - unshare range (FALLOC_FL_UNSHARE) support for fallocate - copy-on-write extent size hints (FS_XFLAG_COWEXTSIZE) for fsxattr interface - shared extent support for XFS - copy-on-write support for shared extents - copy_file_range support - clone_file_range support (implements reflink) - dedupe_file_range support - defrag support for reverse mapping enabled filesystems" * tag 'xfs-reflink-for-linus-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (71 commits) xfs: convert COW blocks to real blocks before unwritten extent conversion xfs: rework refcount cow recovery error handling xfs: clear reflink flag if setting realtime flag xfs: fix error initialization xfs: fix label inaccuracies xfs: remove isize check from unshare operation xfs: reduce stack usage of _reflink_clear_inode_flag xfs: check inode reflink flag before calling reflink functions xfs: implement swapext for rmap filesystems xfs: refactor swapext code xfs: various swapext cleanups xfs: recognize the reflink feature bit xfs: simulate per-AG reservations being critically low xfs: don't mix reflink and DAX mode for now xfs: check for invalid inode reflink flags xfs: set a default CoW extent size of 32 blocks xfs: convert unwritten status of reverse mappings for shared files xfs: use interval query for rmap alloc operations on shared files xfs: add shared rmap map/unmap/convert log item types xfs: increase log reservations for reflink ...
2016-10-13CIFS: Reset read oplock to NONE if we have mandatory locks after reopenPavel Shilovsky
We are already doing the same thing for an ordinary open case: we can't keep read oplock on a file if we have mandatory byte-range locks because pagereading can conflict with these locks on a server. Fix it by setting oplock level to NONE. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com>
2016-10-13CIFS: Fix persistent handles re-opening on reconnectPavel Shilovsky
openFileList of tcon can be changed while cifs_reopen_file() is called that can lead to an unexpected behavior when we return to the loop. Fix this by introducing a temp list for keeping all file handles that need to be reopen. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com>
