path: root/fs
2011-05-09fs: fixup warning part_discard_alignment_show()Jens Axboe
Stephen reports: ----- After merging the block tree, today's linux-next build (x86_64 allmodconfig) produced this warning: fs/partitions/check.c: In function 'part_discard_alignment_show': fs/partitions/check.c:263: warning: format '%u' expects type 'unsigned int', but argument 3 has type 'long long unsigned int' Introduced by commit ("block: Remove extra discard_alignment from hd_struct") ----- Fix it up by just removing the cast, we return an int already. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06block: Remove extra discard_alignment from hd_struct.Tao Ma
Currently, hd_struct.discard_alignment is only used when we show /sys/block/sdx/sdx/discard_alignment. So remove it and calculate when it is asked to show. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21block: don't block events on excl write for non-optical devicesTejun Heo
Disk event code automatically blocks events on excl write. This is primarily to avoid issuing polling commands while burning is in progress. This behavior doesn't fit other types of devices with removeable media where polling commands don't have adverse side effects and door locking usually doesn't exist. This patch introduces new genhd flag which controls the auto-blocking behavior and uses it to enable auto-blocking only on optical devices. Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21block: rescan partitions on invalidated devices on -ENOMEDIA tooTejun Heo
__blkdev_get() doesn't rescan partitions if disk->fops->open() fails, which leads to ghost partition devices lingering after medimum removal is known to both the kernel and userland. The behavior also creates a subtle inconsistency where O_NONBLOCK open, which doesn't fail even if there's no medium, clears the ghots partitions, which is exploited to work around the problem from userland. Fix it by updating __blkdev_get() to issue partition rescan after -ENOMEDIA too. This was reported in the following bz. https://bugzilla.kernel.org/show_bug.cgi?id=13029 Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: David Zeuthen <zeuthen@gmail.com> Reported-by: Martin Pitt <martin.pitt@ubuntu.com> Reported-by: Kay Sievers <kay.sievers@vrfy.org> Tested-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (24 commits) Btrfs: fix free space cache leak Btrfs: avoid taking the chunk_mutex in do_chunk_alloc Btrfs end_bio_extent_readpage should look for locked bits Btrfs: don't force chunk allocation in find_free_extent Btrfs: Check validity before setting an acl Btrfs: Fix incorrect inode nlink in btrfs_link() Btrfs: Check if btrfs_next_leaf() returns error in btrfs_real_readdir() Btrfs: Check if btrfs_next_leaf() returns error in btrfs_listxattr() Btrfs: make uncache_state unconditional btrfs: using cached extent_state in set/unlock combinations Btrfs: avoid taking the trans_mutex in btrfs_end_transaction Btrfs: fix subvolume mount by name problem when default mount subvolume is set fix user annotation in ioctl.c Btrfs: check for duplicate iov_base's when doing dio reads btrfs: properly handle overlapping areas in memmove_extent_buffer Btrfs: fix memory leaks in btrfs_new_inode() Btrfs: check for duplicate iov_base's when doing dio reads Btrfs: reuse the extent_map we found when calling btrfs_get_extent Btrfs: do not use async submit for small DIO io's Btrfs: don't split dio bios if we don't have to ...
2011-04-18proc: do proper range check on readdir offsetLinus Torvalds
Rather than pass in some random truncated offset to the pid-related functions, check that the offset is in range up-front. This is just cleanup, the previous commit fixed the real problem. Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-18Btrfs: fix free space cache leakChris Mason
The free space caching code was recently reworked to cache all the pages it needed instead of using find_get_page everywhere. One loop was missed though, so it ended up leaking pages. This fixes it to use our page array instead of find_get_page. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-17fs: synchronize_rcu when unregister_filesystem success not failureMilton Miller
While checking unregister_filesystem for saftey vs extra calls for "ext4: register ext2 and ext3 alias after ext4" I realized that the synchronize_rcu() was called on the error path but not on the success path. Cc: stable (2.6.38) Signed-off-by: Milton Miller <miltonm@bga.com> [ This probably won't really make a difference since commit d863b50ab013 ("vfs: call rcu_barrier after ->kill_sb()"), but it's the right thing to do. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-16Btrfs: avoid taking the chunk_mutex in do_chunk_allocJosef Bacik
Everytime we try to allocate disk space we try and see if we can pre-emptively allocate a chunk, but in the common case we don't allocate anything, so there is no sense in taking the chunk_mutex at all. So instead if we are allocating a chunk, mark it in the space_info so we don't get two people trying to allocate at the same time. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Reviewed-by: Liu Bo <liubo2009@cn.fujitsu.com>
2011-04-16Btrfs end_bio_extent_readpage should look for locked bitsChris Mason
A recent commit caches the extent state in end_bio_extent_readpage, but the search it does should look for locked extents. This fixes things to make it more effective. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: net/9p: nwname should be an unsigned int 9p: Fix sparse error fs/9p: Fix error reported by coccicheck 9p: revert tsyncfs related changes fs/9p: Use write_inode for data sync on server fs/9p: Fix revalidate to return correct value
2011-04-15vfs: Fix absolute RCU path walk failures due to uninitialized seq numberTim Chen
During RCU walk in path_lookupat and path_openat, the rcu lookup frequently failed if looking up an absolute path, because when root directory was looked up, seq number was not properly set in nameidata. We dropped out of RCU walk in nameidata_drop_rcu due to mismatch in directory entry's seq number. We reverted to slow path walk that need to take references. With the following patch, I saw a 50% increase in an exim mail server benchmark throughput on a 4-socket Nehalem-EX system. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: stable@kernel.org (v2.6.38) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-15fs/9p: Fix error reported by coccicheckAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-159p: revert tsyncfs related changesAneesh Kumar K.V
Now that we use write_inode to flush server cache related to fid, we don't need tsyncfs either fort dotl or dotu protocols. For dotu this helps to do a more efficient server flush. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-15fs/9p: Use write_inode for data sync on serverAneesh Kumar K.V
2011-04-15fs/9p: Fix revalidate to return correct valueAneesh Kumar K.V
revalidate should return > 0 on success. Also return 0 on ENOENT to force do_revalidate to return NULL dentry; Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-15Btrfs: don't force chunk allocation in find_free_extentChris Mason
find_free_extent likes to allocate in contiguous clusters, which makes writeback faster, especially on SSD storage. As the FS fragments, these clusters become harder to find and we have to decide between allocating a new chunk to make more clusters or giving up on the cluster to allocate from the free space we have. Right now it creates too many chunks, and you can end up with a whole FS that is mostly empty metadata chunks. This commit changes the allocation code to be more strict and only allocate new chunks when we've made good use of the chunks we already have. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-15Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: fix compilation warnings when compiling with gcc 4.5 UBIFS: fix oops when R/O file-system is fsync'ed
2011-04-15vfs: fix incorrect dentry_update_name_case() BUG_ON() testLinus Torvalds
The case we should be verifying when updating the dentry name is that the _parent_ inode (the directory) semaphore is held, not the semaphore for the dentry itself. It's the directory locking that rename and readdir() etc all care about. The comment just above even says so - but then the BUG_ON() still checked the dentry inode itself. Very few people noticed, because this helper function really isn't used for very much, so you had to be using ncpfs to ever hit it. I think I should just remove the BUG_ON (the function really has just one user), but let's run with it fixed for a while before getting rid of it entirely. Reported-and-tested-by: Bongani Hlope <bonganih@bankservafrica.com> Reported-and-tested-by: Bernd Feige <bernd.feige@uniklinik-freiburg.de> Cc: Petr Vandrovec <petr@vandrovec.name>, Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14ramfs: fix memleak on no-mmu archBob Liu
On no-mmu arch, there is a memleak during shmem test. The cause of this memleak is ramfs_nommu_expand_for_mapping() added page refcount to 2 which makes iput() can't free that pages. The simple test file is like this: int main(void) { int i; key_t k = ftok("/etc", 42); for ( i=0; i<100; ++i) { int id = shmget(k, 10000, 0644|IPC_CREAT); if (id == -1) { printf("shmget error\n"); } if(shmctl(id, IPC_RMID, NULL ) == -1) { printf("shm rm error\n"); return -1; } } printf("run ok...\n"); return 0; } And the result: root:/> free total used free shared buffers Mem: 60320 17912 42408 0 0 -/+ buffers: 17912 42408 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 19096 41224 0 0 -/+ buffers: 19096 41224 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 20296 40024 0 0 -/+ buffers: 20296 40024 ... After this patch the test result is:(no memleak anymore) root:/> free total used free shared buffers Mem: 60320 16668 43652 0 0 -/+ buffers: 16668 43652 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 16668 43652 0 0 -/+ buffers: 16668 43652 Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14fs/fhandle.c: add <linux/personality.h> for ia64Jeff Mahoney
force_o_largefile() on ia64 is defined in <asm/fcntl.h> and requires <linux/personality.h>. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14brk: COMPAT_BRK: fix detection of randomized brkJiri Kosina
5520e89 ("brk: fix min_brk lower bound computation for COMPAT_BRK") tried to get the whole logic of brk randomization for legacy (libc5-based) applications finally right. It turns out that the way to detect whether brk has actually been randomized in the end or not introduced by that patch still doesn't work for those binaries, as reported by Geert: : /sbin/init from my old m68k ramdisk exists prematurely. : : Before the patch: : : | brk(0x80005c8e) = 0x80006000 : : After the patch: : : | brk(0x80005c8e) = 0x80005c8e : : Old libc5 considers brk() to have failed if the return value is not : identical to the requested value. I don't like it, but currently see no better option than a bit flag in task_struct to catch the CONFIG_COMPAT_BRK && randomize_va_space == 2 case. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14fs/partitions/ldm.c: fix oops caused by corrupted partition tableTimo Warns
The kernel automatically evaluates partition tables of storage devices. The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains a bug that causes a kernel oops on certain corrupted LDM partitions. A kernel subsystem seems to crash, because, after the oops, the kernel no longer recognizes newly connected storage devices. The patch validates the value of vblk_size. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Timo Warns <warns@pre-sense.de> Cc: Eugene Teo <eugeneteo@kernel.sg> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: Richard Russon <rich@flatcap.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-13UBIFS: fix compilation warnings when compiling with gcc 4.5Maksim Rayskiy
When compiling UBIFS with CONFIG_UBIFS_FS_DEBUG not set, gcc-4.5.2 generates a slew of "warning: statement with no effect" on references to non-void functions defined as 0. To avoid these warnings, replace #defines with dummy inline functions. Artem: massage the patch a bit, also remove the duplicate 'dbg_check_lprops()' prototype. Signed-off-by: Maksim Rayskiy <maksim.rayskiy@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-13UBIFS: fix oops when R/O file-system is fsync'edArtem Bityutskiy
This patch fixes severe UBIFS bug: UBIFS oopses when we 'fsync()' an file on R/O-mounter file-system. We (the UBIFS authors) incorrectly thought that VFS would not propagate 'fsync()' down to the file-system if it is read-only, but this is not the case. It is easy to exploit this bug using the following simple perl script: use strict; use File::Sync qw(fsync sync); die "File path is not specified" if not defined $ARGV[0]; my $path = $ARGV[0]; open FILE, "<", "$path" or die "Cannot open $path: $!"; fsync(\*FILE) or die "cannot fsync $path: $!"; close FILE or die "Cannot close $path: $!"; Thanks to Reuben Dowle <Reuben.Dowle@navico.com> for reporting about this issue. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reported-by: Reuben Dowle <Reuben.Dowle@navico.com> Cc: stable@kernel.org
2011-04-13Btrfs: Check validity before setting an aclMiao Xie
Call posix_acl_valid() to check if an acl is valid or not. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-04-13Btrfs: Fix incorrect inode nlink in btrfs_link()Miao Xie
Link count of the inode is not decreased if btrfs_set_inode_index() fails. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Singed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-04-13Btrfs: Check if btrfs_next_leaf() returns error in btrfs_real_readdir()Li Zefan
btrfs_next_leaf() can return -errno, and we should propagate it to userspace. This also simplifies how we walk the btree path. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-04-13Btrfs: Check if btrfs_next_leaf() returns error in btrfs_listxattr()Li Zefan
2011-04-12Btrfs: make uncache_state unconditionalChris Mason
The extent_io code can take cached pointers into the extent state trees, and these can make lookups much faster in common operations. The caching only happens when specific bits are set that prevent merging and splitting of the extent state. A help function was added to uncache the state, and it was testing the same set of conditionals. This can leak in very strange corner cases where the lock bit goes away unexpectedly. The uncaching should be unconditional. Once we have a ref on the extent we should always give it up. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: don't allow mmap'ed pages to be dirtied while under writeback (try #3) [CIFS] Warn on requesting default security (ntlm) on mount [CIFS] cifs: clarify the meaning of tcpStatus == CifsGood cifs: wrap received signature check in srv_mutex cifs: clean up various nits in unicode routines (try #2) cifs: clean up length checks in check2ndT2 cifs: set ra_pages in backing_dev_info cifs: fix broken BCC check in is_valid_oplock_break cifs: always do is_path_accessible check in cifs_mount various endian fixes to cifs Elminate sparse __CHECK_ENDIAN__ warnings on port conversion Max share size is too small Allow user names longer than 32 bytes cifs: replace /proc/fs/cifs/Experimental with a module parm cifs: check for private_data before trying to put it
2011-04-12nfs: don't call __mark_inode_dirty while holding i_lockDave Chinner
nfs_scan_commit() is called with the inode->i_lock held, but it then calls __mark_inode_dirty() while still holding the lock. This causes a deadlock. Push the inode->i_lock into nfs_scan_commit() so it can protect only the parts of the code it needs to and can be dropped before the call to __mark_inode_dirty() to avoid the deadlock. Signed-off-by: Dave Chinner <dchinner@redhat.com> Tested-by: Will Simoneau <simoneau@ele.uri.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-12Revert "vfs: Export file system uuid via /proc/<pid>/mountinfo"Linus Torvalds
This reverts commit 93f1c20bc8cdb757be50566eff88d65c3b26881f. It turns out that libmount misparses it because it adds a '-' character in the uuid string, which libmount then incorrectly confuses with the separator string (" - ") at the end of all the optional arguments. Upstream libmount (in the util-linux tree) has been fixed, but until that fix actually percolates up to users, we'd better not expose this change in the kernel. Let's revisit this later (possibly by exposing the UUID without any '-' characters in it, avoiding the user-space bug). Reported-by: Dave Jones <davej@redhat.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Karel Zak <kzak@redhat.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-12cifs: don't allow mmap'ed pages to be dirtied while under writeback (try #3)Jeff Layton
This is more or less the same patch as before, but with some merge conflicts fixed up. If a process has a dirty page mapped into its page tables, then it has the ability to change it while the client is trying to write the data out to the server. If that happens after the signature has been calculated then that signature will then be wrong, and the server will likely reset the TCP connection. This patch adds a page_mkwrite handler for CIFS that simply takes the page lock. Because the page lock is held over the life of writepage and writepages, this prevents the page from becoming writeable until the write call has completed. With this, we can also remove the "sign_zero_copy" module option and always inline the pages when writing. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12[CIFS] Warn on requesting default security (ntlm) on mountSteve French
Warn once if default security (ntlm) requested. We will update the default to the stronger security mechanism (ntlmv2) in 2.6.41. Kerberos is also stronger than ntlm, but more servers support ntlmv2 and ntlmv2 does not require an upcall, so ntlmv2 is a better default. Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12[CIFS] cifs: clarify the meaning of tcpStatus == CifsGoodSteve French
When the TCP_Server_Info is first allocated and connected, tcpStatus == CifsGood means that the NEGOTIATE_PROTOCOL request has completed and the socket is ready for other calls. cifs_reconnect however sets tcpStatus to CifsGood as soon as the socket is reconnected and the optional RFC1001 session setup is done. We have no clear way to tell the difference between these two states, and we need to know this in order to know whether we can send an echo or not. Resolve this by adding a new statusEnum value -- CifsNeedNegotiate. When the socket has been connected but has not yet had a NEGOTIATE_PROTOCOL request done, set it to this value. Once the NEGOTIATE is done, cifs_negotiate_protocol will set tcpStatus to CifsGood. This also fixes and cleans the logic in cifs_reconnect and cifs_reconnect_tcon. The old code checked for specific states when what it really wants to know is whether the state has actually changed from CifsNeedReconnect. Reported-and-Tested-by: JG <jg@cms.ac> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: wrap received signature check in srv_mutexJeff Layton
While testing my patchset to fix asynchronous writes, I hit a bunch of signature problems when testing with signing on. The problem seems to be that signature checks on receive can be running at the same time as a process that is sending, or even that multiple receives can be checking signatures at the same time, clobbering the same data structures. While we're at it, clean up the comments over cifs_calculate_signature and add a note that the srv_mutex should be held when calling this function. This patch seems to fix the problems for me, but I'm not clear on whether it's the best approach. If it is, then this should probably go to stable too. Cc: stable@kernel.org Cc: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: clean up various nits in unicode routines (try #2)Jeff Layton
Minor revision to the original patch. Don't abuse the __le16 variable on the stack by casting it to wchar_t and handing it off to char2uni. Declare an actual wchar_t on the stack instead. This fixes a valid sparse warning. Fix the spelling of UNI_ASTERISK. Eliminate the unneeded len_remaining variable in cifsConvertToUCS. Also, as David Howells points out. We were better off making cifsConvertToUCS *not* use put_unaligned_le16 since it means that we can't optimize the mapped characters at compile time. Switch them instead to use cpu_to_le16, and simply use put_unaligned to set them in the string. Reported-and-acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: clean up length checks in check2ndT2Jeff Layton
Thus spake David Howells: The code that follows this: remaining = total_data_size - data_in_this_rsp; if (remaining == 0) return 0; else if (remaining < 0) { generates better code if you drop the 'remaining' variable and compare the values directly. Clean it up per his recommendation... Reported-and-acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: set ra_pages in backing_dev_infoJeff Layton
Commit 522440ed made cifs set backing_dev_info on the mapping attached to new inodes. This change caused a fairly significant read performance regression, as cifs started doing page-sized reads exclusively. By virtue of the fact that they're allocated as part of cifs_sb_info by kzalloc, the ra_pages on cifs BDIs get set to 0, which prevents any readahead. This forces the normal read codepaths to use readpage instead of readpages causing a four-fold increase in the number of read calls with the default rsize. Fix it by setting ra_pages in the BDI to the same value as that in the default_backing_dev_info. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=31662 Cc: stable@kernel.org Reported-and-Tested-by: Till <till2.schaefer@uni-dortmund.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: fix broken BCC check in is_valid_oplock_breakJeff Layton
The BCC is still __le16 at this point, and in any case we need to use the get_bcc_le macro to make sure we don't hit alignment problems. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: always do is_path_accessible check in cifs_mountJeff Layton
Currently, we skip doing the is_path_accessible check in cifs_mount if there is no prefixpath. I have a report of at least one server however that allows a TREE_CONNECT to a share that has a DFS referral at its root. The reporter in this case was using a UNC that had no prefixpath, so the is_path_accessible check was not triggered and the box later hit a BUG() because we were chasing a DFS referral on the root dentry for the mount. This patch fixes this by removing the check for a zero-length prefixpath. That should make the is_path_accessible check be done in this situation and should allow the client to chase the DFS referral at mount time instead. Cc: stable@kernel.org Reported-and-Tested-by: Yogesh Sharma <ysharma@cymer.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12various endian fixes to cifsSteve French
make modules C=2 M=fs/cifs CF=-D__CHECK_ENDIAN__ Found for example: CHECK fs/cifs/cifssmb.c fs/cifs/cifssmb.c:728:22: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:728:22: expected unsigned short [unsigned] [usertype] Tid fs/cifs/cifssmb.c:728:22: got restricted __le16 [usertype] <noident> fs/cifs/cifssmb.c:1883:45: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:1883:45: expected long long [signed] [usertype] fl_start fs/cifs/cifssmb.c:1883:45: got restricted __le64 [usertype] start fs/cifs/cifssmb.c:1884:54: warning: restricted __le64 degrades to integer fs/cifs/cifssmb.c:1885:58: warning: restricted __le64 degrades to integer fs/cifs/cifssmb.c:1886:43: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:1886:43: expected unsigned int [unsigned] fl_pid fs/cifs/cifssmb.c:1886:43: got restricted __le32 [usertype] pid In checking new smb2 code for missing endian conversions, I noticed some endian errors had crept in over the last few releases into the cifs code (symlink, ntlmssp, posix lock, and also a less problematic warning in fscache). A followon patch will address a few smb2 endian problems. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12Elminate sparse __CHECK_ENDIAN__ warnings on port conversionSteve French
Ports are __be16 not unsigned short int Eliminates the remaining fixable endian warnings: ~/cifs-2.6$ make modules C=1 M=fs/cifs CF=-D__CHECK_ENDIAN__ CHECK fs/cifs/connect.c fs/cifs/connect.c:2408:23: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2408:23: expected unsigned short *sport fs/cifs/connect.c:2408:23: got restricted __be16 *<noident> fs/cifs/connect.c:2410:23: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2410:23: expected unsigned short *sport fs/cifs/connect.c:2410:23: got restricted __be16 *<noident> fs/cifs/connect.c:2416:24: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2416:24: expected unsigned short [unsigned] [short] <noident> fs/cifs/connect.c:2416:24: got restricted __be16 [usertype] <noident> fs/cifs/connect.c:2423:24: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2423:24: expected unsigned short [unsigned] [short] <noident> fs/cifs/connect.c:2423:24: got restricted __be16 [usertype] <noident> fs/cifs/connect.c:2326:23: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2326:23: expected unsigned short [unsigned] sport fs/cifs/connect.c:2326:23: got restricted __be16 [usertype] sin6_port fs/cifs/connect.c:2330:23: warning: incorrect type in assignment (different base types) fs/cifs/connect.c:2330:23: expected unsigned short [unsigned] sport fs/cifs/connect.c:2330:23: got restricted __be16 [usertype] sin_port fs/cifs/connect.c:2394:22: warning: restricted __be16 degrades to integer Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12Max share size is too smallSteve French
Max share name was set to 64, and (at least for Windows) can be 80. Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-11Merge branch 'for-chris' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus
2011-04-11btrfs: using cached extent_state in set/unlock combinationsArne Jansen
In several places the sequence (set_extent_uptodate, unlock_extent) is used. This leads to a duplicate lookup of the extent state. This patch lets set_extent_uptodate return a cached extent_state which can be passed to unlock_extent_cached. The occurences of the above sequences are updated to use the cache. Only end_bio_extent_readpage is updated that it first gets a cached state to pass it to the readpage_end_io_hook as the prototype requested and is later on being used for set/unlock. Signed-off-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-11Btrfs: avoid taking the trans_mutex in btrfs_end_transactionJosef Bacik
I've been working on making our O_DIRECT latency not suck and I noticed we were taking the trans_mutex in btrfs_end_transaction. So to do this we convert num_writers and use_count to atomic_t's and just decrement them in btrfs_end_transaction. Instead of deleting the transaction from the trans list in put_transaction we do that in btrfs_commit_transaction() since that's the only time it actually needs to be removed from the list. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-04-12Allow user names longer than 32 bytesSteve French
We artificially limited the user name to 32 bytes, but modern servers handle larger. Set the maximum length to a reasonable 256, and make the user name string dynamically allocated rather than a fixed size in session structure. Also clean up old checkpatch warning. Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12cifs: replace /proc/fs/cifs/Experimental with a module parmJeff Layton
This flag currently only affects whether we allow "zero-copy" writes with signing enabled. Typically we map pages in the pagecache directly into the write request. If signing is enabled however and the contents of the page change after the signature is calculated but before the write is sent then the signature will be wrong. Servers typically respond to this by closing down the socket. Still, this can provide a performance benefit so the "Experimental" flag was overloaded to allow this. That's really not a good place for this option however since it's not clear what that flag does. Move that flag instead to a new module parameter that better describes its purpose. That's also better since it can be set at module insertion time by configuring modprobe.d. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
