d_add_ci was lifted 1:1 from ntfs. Change ntfs to use the common
version.
As pointed out during review d_add_ci argument order should match d_add,
so switch the dentry and inode arguments.
it needs to use d_splice_alias(), not d_add()
Ouch, if number taken from IDA is too big, the intent was to signal an
error, not check for overflow and still do overflowing addition.
One still needs 2^28 proc entries to notice this.
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
configfs_rmdir()
It appears that configfs_rmdir() can protect configfs_detach_prep() retries with
less calls to {spin,mutex}_{lock,unlock}, and a cleaner code.
This patch does not change any behavior, except that it removes two useless
lock/unlock pairs having nothing inside to protect and providing a useless
barrier.
Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com>
Signed-off-by: Joel Becker <Joel.Becker@oracle.com>
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
We were setting i_blocks based on allocation before the extent insert, which
is wrong as the value is a calculation based on ip_clusters which gets
updated as a result of the insert. This patch moves the line in question
to just after the call to ocfs2_insert_extent().
Without this fix, inline directories were temporarily having an i_blocks
value of zero immediately after expansion to extents.
Reported-and-tested-by: Tristan Ye <tristan.ye@oracle.com>
When we fail to insert extent in ocfs2_expand_inline_dir(), we should go to
out_commit, not out.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
This fixes a bug introduced with 539d8264093560b917ee3afe4c7f74e5da09d6a5:
[PATCH 2/2] ocfs2: Fix race between mount and recovery
ocfs2_mark_dead_nodes() was reading journal inodes while holding the
spinlock protecting our in-memory recovery state. The fix is very simple -
the disk state is protected by a cluster lock that's already held, so we
just move the spinlock down past the read.
Reviewed-by: Joel Becker <joel.becker@oracle.com>
ocfs2/cluster/netdebug.c: fix warning
fs/ocfs2/cluster/netdebug.c:154: warning: format '%lu' expects
type 'long unsigned int', but argument 17 has type 'suseconds_t'
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Commit 0f475b2abed6cbccee1da20a0bef2895eb2a0edd (ocfs2/net: Silence build
warnings) made sense as far as it fixed compile warnings, but it was not
required that it made the functions global.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Update documentation to remind users to update mke2fs.conf
ext4: Fix small file fragmentation
ext4: Initialize writeback_index to 0 when allocating a new inode
ext4: make sure ext4_has_free_blocks returns 0 for ENOSPC
ext4: journal credit fix for the delayed allocation's writepages() function
ext4: Rework the ext4_da_writepages() function
ext4: journal credits reservation fixes for DIO, fallocate
ext4: journal credits reservation fixes for extent file writepage
ext4: journal credits calulation cleanup and fix for non-extent writepage
ext4: Fix bug where we return ENOSPC even though we have plenty of inodes
ext4: don't try to resize if there are no reserved gdt blocks left
ext4: Use ext4_discard_reservations instead of mballoc-specific call
ext4: Fix ext4_dx_readdir hash collision handling
ext4: Fix delalloc release block reservation for truncate
ext4: Fix potential truncate BUG due to i_prealloc_list being non-empty
ext4: Handle unwritten extent properly with delayed allocation
Always allow truncations to zero, even if budgeting thinks there
is no space. UBIFS reserves some space for deletions anyway.
Otherwise, the following happans:
1. create a file, and write as much as possible there, until ENOSPC
2. truncate the file, which fails with ENOSPC, which is not good.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
After commit a97c9bf33f4612e2aed6f000f6b1d268b6814f3c (fix cramfs
making duplicate entries in inode cache) in kernel 2.6.14, named-pipe
on cramfs does not work properly.
It seems the commit make all named-pipe on cramfs share their inode
(and named-pipe buffer).
Make ..._test() refuse to merge inodes with ->i_ino == 1, take inode setup
back to get_cramfs_inode() and make ->drop_inode() evict ones with ->i_ino
== 1 immediately.
Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: <stable@kernel.org> [2.6.14 and later]
When user calls sys_setpriority(PRIO_PGRP ...) on a NPTL style multi-LWP
process, only the task leader of the process is affected, all other
sibling LWP threads didn't receive the setting. The problem was that the
iterator used in sys_setpriority() only iteartes over one task for each
process, ignoring all other sibling thread.
Introduce a new macro do_each_pid_thread / while_each_pid_thread to walk
each thread of a process. Convert 4 call sites in {set/get}priority and
ioprio_{set/get}.
Signed-off-by: Ken Chen <kenchen@google.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
In case the binfmt_misc binary handler is registered *before* the e.g.
script one (when for example being compiled as a module) the following
situation may occur:
1. user launches a script, whose interpreter is a misc binary;
2. the load_misc_binary sets the misc_bang and returns -ENOEVEC,
since the binary is a script;
3. the load_script_binary loads one and calls for search_binary_hander
to run the interpreter;
4. the load_misc_binary is called again, but refuses to load the
binary due to misc_bang bit set.
The fix is to move the misc_bang setting lower - prior to the actual
call to the search_binary_handler.
Caused by the commit 3a2e7f47 (binfmt_misc.c: avoid potential kernel
stack overflow)
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Reported-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@kernel.org> [2.6.26.x]
This addresses
http://bugzilla.kernel.org/show_bug.cgi?id=11318
In function show_map (file: fs/proc/task_mmu.c), if vma->vm_pgoff > 2^20
than (vma->vm_pgoff << PAGE_SIZE) is greater than 2^32 (with PAGE_SIZE
equal to 4096 (i.e. 2^12). The next seq_printf use an unsigned long for
the conversion of (vma->vm_pgoff << PAGE_SIZE), as a result the offset
value displayed in /proc/self/maps is truncated if the page offset is
greater than 2^20.
A test that shows this issue:
#define _GNU_SOURCE
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/mman.h>
#include <stdlib.h>
#include <stdio.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#define PAGE_SIZE (getpagesize())
#if __i386__
# define U64_STR "%llx"
#elif __x86_64
# define U64_STR "%lx"
#else
# error "Architecture Unsupported"
#endif
int main(int argc, char *argv[])
int fd;
char *addr;
off64_t offset = 0x10000000;
char *filename = "/dev/zero";
fd = open(filename, O_RDONLY);
if (fd < 0) {
perror("open");
return 1;
offset *= 0x10;
printf("offset = " U64_STR "\n", offset);
addr = (char*)mmap64(NULL, PAGE_SIZE, PROT_READ, MAP_PRIVATE, fd,
offset);
if ((void*)addr == MAP_FAILED) {
perror("mmap64");
return 1;
FILE *fmaps;
char *line = NULL;
size_t len = 0;
ssize_t read;
size_t filename_len = strlen(filename);
fmaps = fopen("/proc/self/maps", "r");
if (!fmaps) {
perror("fopen");
return 1;
while ((read = getline(&line, &len, fmaps)) != -1) {
if ((read > filename_len + 1)
&& (strncmp(&line[read - filename_len - 1], filename, filename_len) == 0))
printf("%s", line);
if (line)
free(line);
fclose(fmaps);
close(fd);
return 0;
Signed-off-by: Clement Calmels <cboulte@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh/for-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Provide a FLAT_PLAT_INIT() definition.
binfmt_flat: Stub in a FLAT_PLAT_INIT().
video: export sh_mobile_lcdc panel size
sh: select memchunk size using kernel cmdline
sh: export sh7723 VEU as VEU2H
input: migor_ts compile and detection fix
sh: remove MSTPCR defines from Migo-R header file
sh: Update sh7763rdp defconfig
sh: Add support sh7760fb to sh7763rdp board
sh: Add support sh_eth to sh7763rdp board
sh: Disable 64kB hugetlbpage size when using 64kB PAGE_SIZE.
sh: Don't export __{s,u}divsi3_i4i from SH-2 libgcc.
fix SH7705_CACHE_32KB compilation
sh: mach-x3proto: Fix up smc91x platform data.
There was another FAT BKL conversion deadlock reported by Bart
Trojanowski due to the BKL being used as a recursive lock by FAT, which
was missed because it only triggers with 'sync' (or 'dirsync') mounts.
The recursion worked for the BKL, but after the conversion to lock_super
(which uses a mutex), it just deadlocks.
Thanks to Bart for debugging this and testing the fix. The lock
debugging information from the original report:
[ INFO: possible recursive locking detected ]
2.6.27-rc3-bisect-00448-ga7f5aaf #16
mv/4020 is trying to acquire lock:
(&type->s_lock_key#9){--..}, at: [<c01a90fe>] lock_super+0x1e/0x20
but task is already holding lock:
3 locks held by mv/4020:
#0: (&sb->s_type->i_mutex_key#9/1){--..}, at: [<c01b2336>] do_unlinkat+0x66/0x140
#1: (&sb->s_type->i_mutex_key#9){--..}, at: [<c01b0954>] vfs_unlink+0x84/0x110
#2: (&type->s_lock_key#9){--..}, at: [<c01a90fe>] lock_super+0x1e/0x20
stack backtrace:
Pid: 4020, comm: mv Not tainted 2.6.27-rc3-bisect-00448-ga7f5aaf #16
[<c014e694>] validate_chain+0x984/0xea0
[<c0108d70>] ? native_sched_clock+0x0/0xf0
[<c014ee9c>] __lock_acquire+0x2ec/0x9b0
[<c014f5cf>] lock_acquire+0x6f/0x90
[<c01a90fe>] ? lock_super+0x1e/0x20
[<c044e5fd>] mutex_lock_nested+0xad/0x300
[<f8b3a700>] fat_write_inode+0x60/0x2b0 [fat]
[<c0450878>] ? _spin_unlock_irqrestore+0x48/0x80
[<f8b3a953>] ? fat_sync_inode+0x3/0x20 [fat]
[<f8b3a962>] fat_sync_inode+0x12/0x20 [fat]
[<f8b37c7e>] fat_remove_entries+0xbe/0x120 [fat]
[<f8b422ef>] vfat_unlink+0x5f/0x90 [vfat]
[<f8b42290>] ? vfat_unlink+0x0/0x90 [vfat]
[<c01b0968>] vfs_unlink+0x98/0x110
[<c01b2400>] do_unlinkat+0x130/0x140
[<c016a8f5>] ? audit_syscall_entry+0x105/0x150
[<c01b253b>] sys_unlinkat+0x3b/0x40
[<c01040d3>] sysenter_do_call+0x12/0x3f
where the deadlock is due to the nesting of lock_super from vfat_unlink
to fat_write_inode:
- do_unlinkat
- vfs_unlink
- vfat_unlink
* lock_super
- fat_remove_entries
- fat_sync_inode
- fat_write_inode
* lock_super
and the fix is to simply remove the use of lock_super() in fat_write_inode.
The lock_super() there had been just an automatic conversion of the
kernel lock to the superblock lock, but no locking was actually needed
there, since the code in fat_write_inode already protected all relevant
accesses with a spinlock (sbi->inode_hash_lock to be exact). The only
code inside the BKL (and thus the superblock lock) was accesses tp local
variables or calls to functions that have long been SMP-safe (i.e.
sb_bread, mark_buffe_dirty and brlese).
Bart reports:
"Looks good. I ran 10 parallel processes creating 1M files truncating
them, writing to them again and then deleting them. This patch fixes
the issue I ran into.
Signed-off-by: Bart Trojanowski <bart@jukie.net>"
Reported-and-tested-by: Bart Trojanowski <bart@jukie.net>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Properly handle MSKRB5 by passing sec=mskrb5 to the upcall so that the
spengo blob can be generated appropriately. Also, make
decode_negTokenInit prefer whichever mechanism is first in the list.
Needed for some NetApp servers, and possibly some older
versions of Windows which treat the two KRB5 mechanisms differently.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
cifs_setup_session references pSesInfo->server several times. That
pointer shouldn't change during the life of the function so grab it
once and store it in a local var. This makes the code look a little
cleaner too.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
I case we failed to allocate memory for inode when creating it, we did not
properly free block already allocated for this inode. Move memory allocation
before the block allocation which fixes this issue (thanks for the idea go to
Ingo Oeser <ioe-lkml@rameria.de>). Also remove a few superfluous
initializations already done in udf_alloc_inode().
Reviewed-by: Ingo Oeser <ioe-lkml@rameria.de>
A memory allocation inside alloc_mutex must not recurse back into the
filesystem itself because that leads to lock inversion between iprune_mutex and
alloc_mutex (and thus to deadlocks - see traces below). alloc_mutex is actually
needed only to update allocation statistics in the superblock so we can drop it
before we start allocating memory for the inode.
tar D ffff81015b9c8c90 0 6614 6612
ffff8100d5a21a20 0000000000000086 0000000000000000 00000000ffff0000
ffff81015b9c8c90 ffff81015b8f0cd0 ffff81015b9c8ee0 0000000000000000
0000000000000003 0000000000000000 0000000000000000 0000000000000000
Call Trace:
[<ffffffff803c1d8a>] __mutex_lock_slowpath+0x64/0x9b
[<ffffffff803c1bef>] mutex_lock+0xa/0xb
[<ffffffff8027f8c2>] shrink_icache_memory+0x38/0x200
[<ffffffff80257742>] shrink_slab+0xe3/0x15b
[<ffffffff802579db>] try_to_free_pages+0x221/0x30d
[<ffffffff8025657e>] isolate_pages_global+0x0/0x31
[<ffffffff8025324b>] __alloc_pages_internal+0x252/0x3ab
[<ffffffff8026b08b>] cache_alloc_refill+0x22e/0x47b
[<ffffffff8026ae37>] kmem_cache_alloc+0x3b/0x61
[<ffffffff8026b15b>] cache_alloc_refill+0x2fe/0x47b
[<ffffffff8026b34e>] __kmalloc+0x76/0x9c
[<ffffffffa00751f2>] :udf:udf_new_inode+0x202/0x2e2
[<ffffffffa007ae5e>] :udf:udf_create+0x2f/0x16d
[<ffffffffa0078f27>] :udf:udf_lookup+0xa6/0xad
kswapd0 D ffff81015b9d9270 0 125 2
ffff81015b903c28 0000000000000046 ffffffff8028cbb0 00000000fffffffb
ffff81015b9d9270 ffff81015b8f0cd0 ffff81015b9d94c0 000000000271b490
ffffe2000271b458 ffffe2000271b420 ffffe20002728dc8 ffffe20002728d90
Call Trace:
[<ffffffff8028cbb0>] __set_page_dirty+0xeb/0xf5
[<ffffffff8025403a>] get_dirty_limits+0x1d/0x22f
[<ffffffffa0073f58>] :udf:udf_bitmap_free_blocks+0x47/0x1eb
[<ffffffffa007df31>] :udf:udf_discard_prealloc+0xc6/0x172
[<ffffffffa007875a>] :udf:udf_clear_inode+0x1e/0x48
[<ffffffff8027f121>] clear_inode+0x6d/0xc4
[<ffffffff8027f7f2>] dispose_list+0x56/0xee
[<ffffffff8027fa5a>] shrink_icache_memory+0x1d0/0x200
[<ffffffff80257e93>] kswapd+0x346/0x447
Reported-by: Tibor Tajti <tibor.tajti@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
[CIFS] mount of IPC$ breaks with iget patch
[CIFS] remove trailing whitespace
[CIFS] if get root inode fails during mount, cleanup tree connection
* 'linux-next' of git://git.infradead.org/~dedekind/ubifs-2.6: (29 commits)
UBIFS: xattr bugfixes
UBIFS: remove unneeded check
UBIFS: few commentary fixes
UBIFS: fix budgeting request alignment in xattr code
UBIFS: improve arguments checking in debugging messages
UBIFS: always set i_generation to 0
UBIFS: correct spelling of "thrice".
UBIFS: support splice_write
UBIFS: minor tweaks in commit
UBIFS: reserve more space for index
UBIFS: print pid in dump function
UBIFS: align inode data to eight
UBIFS: improve budgeting checks
UBIFS: correct orphan deletion order
UBIFS: fix typos in comments
UBIFS: do not union creat_sqnum and del_cmtno
UBIFS: optimize deletions
UBIFS: increment commit number earlier
UBIFS: remove another unneeded function parameter
UBIFS: remove unneeded function parameter
A fuzzed fileystem image failed with OMFS when the extent count was
used in a loop without being checked against the max number of extents.
It also provoked a signed division for an array index that was checked
as if unsigned, leading to index by -1.
omfsck will be updated to fix these cases, in the meantime bail out
gracefully.
Reported-by: Eric Sesterhenn <snakebyte@gmx.de>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Testing with a modified fsfuzzer reveals a couple of locations in omfs
where filesystem variables are ultimately used as loop counters with
insufficient sanity checking. In this case, dir->i_size is used to
compute the number of buckets in the directory hash. If too large,
readdir will overrun a buffer.
Since it's an invariant that dir->i_size is equal to the sysblock
size, and we already sanity check that, just use that value instead.
This fixes the following oops:
BUG: unable to handle kernel paging request at c978e004
IP: [<c032298e>] omfs_readdir+0x18e/0x32f
Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC
Modules linked in:
Pid: 4796, comm: ls Not tainted (2.6.27-rc2 #12)
EIP: 0060:[<c032298e>] EFLAGS: 00010287 CPU: 0
EIP is at omfs_readdir+0x18e/0x32f
EAX: c978d000 EBX: 00000000 ECX: cbfcfaf8 EDX: cb2cf100
ESI: 00001000 EDI: 00000800 EBP: cb2d3f68 ESP: cb2d3f0c
DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
Process ls (pid: 4796, ti=cb2d3000 task=cb175f40 task.ti=cb2d3000)
Stack: 00000002 00000000 00000000 c018a820 cb2d3f94 cb2cf100 cbfb0000 ffffff10
cbfb3b80 cbfcfaf8 000001c9 00000a09 00000000 00000000 00000000 cbfcfbc8
c9697000 cbfb3b80 22222222 00001000 c08e6cd0 cb2cf100 cbfb3b80 cb2d3f88
Call Trace:
[<c018a820>] ? filldir64+0x0/0xcd
[<c018a9f2>] ? vfs_readdir+0x56/0x82
[<c018aa7c>] ? sys_getdents64+0x5e/0xa0
[<c01038bd>] ? sysenter_do_call+0x12/0x31
Code: 00 89 f0 89 f3 0f ac f8 14 81 e3 ff ff 0f 00 48 8d
14 c5 b8 01 00 00 89 45 cc 89 55 f0 e9 8c 01 00 00 8b 4d c8 8b 75 f0 8b
41 18 <8b> 54 30 04 8b 04 30 31 f6 89 5d dc 89 d1 8b 55 b8 0f c8 0f c9
write_cache_pages() uses i_mapping->writeback_index to pick up where it
left off the last time a given inode was found by pdflush or
balance_dirty_pages (or anyone else who sets wbc->range_cyclic)
alloc_inode() should set it to a sane value so that writeback doesn't
start in the middle of a file. It is somewhat difficult to notice the bug
since write_cache_pages will loop around to the start of the file and the
elevator helps hide the resulting seeks.
For whatever reason, Btrfs hits this often. Unpatched, untarring 30
copies of the linux kernel in series runs at 47MB/s on a single sata
drive. With this fix, it jumps to 62MB/s.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Xattr code has not been tested for a while and there were
serveral bugs. One of them is using wrong inode in
'ubifs_jnl_change_xattr()'. The other is a deadlock in
'ubifs_setxattr()': the i_mutex is locked in
'cap_inode_need_killpriv()' path, so deadlock happens when
'ubifs_setxattr()' tries to lock it again.
Thanks to Zoltan Sogor for finding these bugs.
In looking at network named pipe support on cifs, I noticed that
Dave Howell's iget patch:
iget: stop CIFS from using iget() and read_inode()
broke mounts to IPC$ (the interprocess communication share), and don't
handle the error case (when getting info on the root inode fails).
Thanks to Gunter who noted a typo in a debug line in the original
version of this patch.
CC: David Howells <dhowells@redhat.com>
CC: Gunter Kukkukk <linux@kukkukk.com>
CC: Stable Kernel <stable@kernel.org>
The patches that are intended to introduce copy-on-write credentials for 2.6.28
require abstraction of access to some fields of the task structure,
particularly for the case of one task accessing another's credentials where RCU
will have to be observed.
Introduced here are trivial no-op versions of the desired accessors for current
and other tasks so that other subsystems can start to be converted over more
easily.
Wrappers are introduced into a new header (linux/cred.h) for UID/GID,
EUID/EGID, SUID/SGID, FSUID/FSGID, cap_effective and current's subscribed
user_struct. These wrappers are macros because the ordering between header
files mitigates against making them inline functions.
linux/cred.h is #included from linux/sched.h.
Further, XFS is modified such that it no longer defines and uses parameterised
versions of current_fs[ug]id(), thus getting rid of the namespace collision
otherwise incurred.
Signed-off-by: James Morris <jmorris@namei.org>
* git://oss.sgi.com:8090/xfs/linux-2.6: (45 commits)
[XFS] Fix use after free in xfs_log_done().
[XFS] Make xfs_bmap_*_count_leaves void.
[XFS] Use KM_NOFS for debug trace buffers
[XFS] use KM_MAYFAIL in xfs_mountfs
[XFS] refactor xfs_mount_free
[XFS] don't call xfs_freesb from xfs_unmountfs
[XFS] xfs_unmountfs should return void
[XFS] cleanup xfs_mountfs
[XFS] move root inode IRELE into xfs_unmountfs
[XFS] stop using file_update_time
[XFS] optimize xfs_ichgtime
[XFS] update timestamp in xfs_ialloc manually
[XFS] remove the sema_t from XFS.
[XFS] replace dquot flush semaphore with a completion
[XFS] replace inode flush semaphore with a completion
[XFS] extend completions to provide XFS object flush requirements
[XFS] replace the XFS buf iodone semaphore with a completion
[XFS] clean up stale references to semaphores
[XFS] use get_unaligned_* helpers
[XFS] Fix compile failure in xfs_buf_trace()
Add a dlm_ prefix to the struct names in config.c. This resolves a
conflict with struct node in particular, when include/linux/node.h
happens to be included.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Teigland <teigland@redhat.com>
A couple of unlikely error conditions were missing a kfree on the error
exit path.
Reported-by: Juha Leppanen <juha_motorsportcom@luukku.com>
Commit d70b67c8bc72ee23b55381bd6a884f4796692f77 fixed VFS and
it never calls FS lookup function in deleted directories now.
We may remove corresponding UBIFS check.
Data length has to be aligned in the budgeting request. Code
in xattr.c did not do this.
Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu>
Use "if (0) printk()" construct in debugging print macros to
make the debugging messages be checked even if debugging is
off.
This patch also removes some unneeded spaces and blank lines.
UBIFS does not presently re-use inode numbers, so leaving
i_generation zero is most appropriate for now.
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
No functional changes, just lessen the amount of indentations.
At the moment UBIFS reserves twice old index size space for the
index. But this is not enough in some cases, because if the indexing
node are very fragmented and there are many small gaps, while the
dirty index has big znodes - in-the-gaps method would fail.
Thus, reserve trise as more, in which case we are guaranteed that
we can commit in any case.
Useful when something fails and there are many processes
racing.
UBIFS aligns node lengths to 8, so budgeting has to do the
same. Well, direntry, inode, and page budgets are already
aligned, but not inode data budget (e.g., data in special
devices or symlinks). Do this for inode data as well.
Also, add corresponding debugging checks.
Budgeting is a crucial UBIFS subsystem - add more assertions
to improve requests checking. This is not compiled in when
UBIFS debugging is disabled.
The debug function that checks orphans, does so using the
TNC mutex. That means it will not see a correct picture
if the inode is removed from the orphan tree before it is
removed from TNC.
