path: root/fs
2010-02-22fs/exec.c: fix initial stack reservationMichael Neuling
803bf5ec259941936262d10ecc84511b76a20921 ("fs/exec.c: restrict initial stack space expansion to rlimit") attempts to limit the initial stack to 20*PAGE_SIZE. Unfortunately, in attempting ensure the stack is not reduced in size, we ended up not changing the stack at all. This size reduction check is not necessary as the expand_stack call does this already. This caused a regression in UML resulting in most guest processes being killed. Signed-off-by: Michael Neuling <mikey@neuling.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jouni Malinen <j@w1.fi> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-20CacheFiles: Fix a race in cachefiles_delete_object() vs renameDavid Howells
cachefiles_delete_object() can race with rename. It gets the parent directory of the object it's asked to delete, then locks it - but rename may have changed the object's parent between the get and the completion of the lock. However, if such a circumstance is detected, we abandon our attempt to delete the object - since it's no longer in the index key path, it won't be seen again by lookups of that key. The assumption is that cachefilesd may have culled it by renaming it to the graveyard for later destruction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-20vfs: don't call ima_file_check() unconditionally in nfsd_open()Chuck Ebbert
commit 1e41568d7378d1ba8c64ba137b9ddd00b59f893a ("Take ima_path_check() in nfsd past dentry_open() in nfsd_open()") moved this code back to its original location but missed the "else". Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-19Switch proc/self to nd_set_link()Al Viro
2010-02-19fix LOOKUP_FOLLOW on automount "symlinks"Al Viro
Make sure that automount "symlinks" are followed regardless of LOOKUP_FOLLOW; it should have no effect on them. Cc: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-16sysfs: sysfs_sd_setattr set iattrs unconditionallyEric W. Biederman
There is currently a bug in sysfs_sd_setattr inherited from sysfs_setattr in 2.6.32 where the first time we set the attributes on a sysfs file we allocate backing store but do not set the backing store attributes. Resulting in overly restrictive permissions on sysfs files. The fix is to simply modify the code so that it always executes when we update the sysfs attributes, as we did in 2.6.31 and earlier. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Jean Delvare <khali@linux-fr.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: btrfs_mark_extent_written uses the wrong slot
2010-02-15NFS: Too many GETATTR and ACCESS calls after direct I/OChuck Lever
The cached read and write paths initialize fattr->time_start in their setup procedures. The value of fattr->time_start is propagated to read_cache_jiffies by nfs_update_inode(). Subsequent calls to nfs_attribute_timeout() will then use a good time stamp when computing the attribute cache timeout, and squelch unneeded GETATTR calls. Since the direct I/O paths erroneously leave the inode's fattr->time_start field set to zero, read_cache_jiffies for that inode is set to zero after any direct read or write operation. This triggers an otw GETATTR or ACCESS call to update the file's attribute and access caches properly, even when the NFS READ or WRITE replies have usable post-op attributes. Make sure the direct read and write setup code performs the same fattr initialization as the cached I/O paths to prevent unnecessary GETATTR calls. This was likely introduced by commit 0e574af1 in 2.6.15, which appears to add new nfs_fattr_init() call sites in the cached read and write paths, but not in the equivalent places in fs/nfs/direct.c. A subsequent commit in the same series, 33801147, introduces the fattr->time_start field. Interestingly, the direct write reschedule path already has a call to nfs_fattr_init() in the right place. Reported-by: Quentin Barnes <qbarnes@yahoo-inc.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-15Merge branch 'reiserfs/kill-bkl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'reiserfs/kill-bkl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: reiserfs: Fix softlockup while waiting on an inode
2010-02-14reiserfs: Fix softlockup while waiting on an inodeFrederic Weisbecker
When we wait for an inode through reiserfs_iget(), we hold the reiserfs lock. And waiting for an inode may imply waiting for its writeback. But the inode writeback path may also require the reiserfs lock, which leads to a deadlock. We just need to release the reiserfs lock from reiserfs_iget() to fix this. Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Chris Mason <chris.mason@oracle.com>
2010-02-12Btrfs: btrfs_mark_extent_written uses the wrong slotShaohua Li
My test do: fallocate a big file and do write. The file is 512M, but after file write is done btrfs-debug-tree shows: item 6 key (257 EXTENT_DATA 0) itemoff 3516 itemsize 53 extent data disk byte 1103101952 nr 536870912 extent data offset 0 nr 399634432 ram 536870912 extent compression 0 Looks like a regression introducted by 6c7d54ac87f338c479d9729e8392eca3f76e11e1, where we set wrong slot. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-12GFS2: Fix bmap allocation corner-case bugSteven Whitehouse
This patch solves a corner case during allocation which occurs if both metadata (indirect) and data blocks are required but there is an obstacle in the filesystem (e.g. a resource group header or another allocated block) such that when the allocation is requested only enough blocks for the metadata are returned. By changing the exit condition of this loop, we ensure that a minimum of one data block will always be returned. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-02-12GFS2: Fix error codeAbhijith Das
We need this one-liner to signal the mount helper of the 'insufficient journals' condition. Signed-off-by: Abhijith Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-02-11Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Fix the mapping of the NFSERR_SERVERFAULT error NFS: Remove a redundant check for PageFsCache in nfs_migrate_page() NFS: Fix a bug in nfs_fscache_release_page()
2010-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] qla2xxx: Obtain proper host structure during response-queue processing. [SCSI] compat_ioct: fix bsg SG_IO [SCSI] qla2xxx: make msix interrupt handler safe for irq [SCSI] zfcp: Report FC BSG errors in correct field [SCSI] mptfusion : mptscsih_abort return value should be SUCCESS instead of value 0.
2010-02-11fs/exec.c: restrict initial stack space expansion to rlimitMichael Neuling
When reserving stack space for a new process, make sure we're not attempting to expand the stack by more than rlimit allows. This fixes a bug caused by b6a2fea39318e43fee84fa7b0b90d68bed92d2ba ("mm: variable length argument support") and unmasked by fc63cf237078c86214abcb2ee9926d8ad289da9b ("exec: setup_arg_pages() fails to return errors"). This bug means that when limiting the stack to less the 20*PAGE_SIZE (eg. 80K on 4K pages or 'ulimit -s 79') all processes will be killed before they start. This is particularly bad with 64K pages, where a ulimit below 1280K will kill every process. To test, do: 'ulimit -s 15; ls' before and after the patch is applied. Before it's applied, 'ls' should be killed. After the patch is applied, 'ls' should no longer be killed. A stack limit of 15KB since it's small enough to trigger 20*PAGE_SIZE. Also 15KB not a multiple of PAGE_SIZE, which is a trickier case to handle correctly with this code. 4K pages should be fine to test with. [kosaki.motohiro@jp.fujitsu.com: cleanup] [akpm@linux-foundation.org: cleanup cleanup] Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11compat_ioctl: add compat handler for TIOCGSID ioctlAndreas Schwab
This is used by tcgetsid(3). Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-10compat_ioctl: ignore RAID_VERSION ioctlArnd Bergmann
md ioctls are now handled by the md driver itself, but mdadm may call RAID_VERSION on other devices as well. Mark the command as IGNORE_IOCTL so this fails silently rather than printing an annoying message. Reported-by: "Michael S. Tsirkin" <m.s.tsirkin@gmail.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: fix dentry hash calculation for case-insensitive mounts [CIFS] Don't cache timestamps on utimes due to coarse granularity [CIFS] Maximum username length check in session setup does not match cifs: fix length calculation for converted unicode readdir names [CIFS] Add support for TCP_NODELAY
2010-02-09NFS: Fix the mapping of the NFSERR_SERVERFAULT errorTrond Myklebust
It was recently pointed out that the NFSERR_SERVERFAULT error, which is designed to inform the user of a serious internal error on the server, was being mapped to an error value that is internal to the kernel. This patch maps it to the error EREMOTEIO, which is exported to userland through errno.h. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2010-02-09NFS: Remove a redundant check for PageFsCache in nfs_migrate_page()Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: David Howells <dhowells@redhat.com>
2010-02-09NFS: Fix a bug in nfs_fscache_release_page()Trond Myklebust
Not having an fscache cookie is perfectly valid if the user didn't mount with the fscache option. This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=15234 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: David Howells <dhowells@redhat.com> Cc: stable@kernel.org
2010-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix p9_client_destroy unconditional calling v9fs_put_trans 9p: fix memory leak in v9fs_parse_options() 9p: Fix the kernel crash on a failed mount 9p: fix option parsing 9p: Include fsync support for 9p client net/9p: fix statsize inside twstat net/9p: fail when user specifies a transport which we can't find net/9p: fix virtio transport to correctly update status on connect
2010-02-08Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: Revert "nfsd4: fix error return when pseudoroot missing"
2010-02-08Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2/cluster: Make o2net connect messages KERN_NOTICE ocfs2/dlm: Fix printing of lockname ocfs2: Fix contiguousness check in ocfs2_try_to_merge_extent_map() ocfs2/dlm: Remove BUG_ON in dlm recovery when freeing locks of a dead node ocfs2: Plugs race between the dc thread and an unlock ast message ocfs2: Remove overzealous BUG_ON during blocked lock processing ocfs2: Do not downconvert if the lock level is already compatible ocfs2: Prevent a livelock in dlmglue ocfs2: Fix setting of OCFS2_LOCK_BLOCKED during bast ocfs2: Use compat_ptr in reflink_arguments. ocfs2/dlm: Handle EAGAIN for compatibility - v2 ocfs2: Add parenthesis to wrap the check for O_DIRECT. ocfs2: Only bug out when page size is larger than cluster size. ocfs2: Fix memory overflow in cow_by_page. ocfs2/dlm: Print more messages during lock migration ocfs2/dlm: Ignore LVBs of locks in the Blocked list ocfs2/trivial: Remove trailing whitespaces ocfs2: fix a misleading variable name ocfs2: Sync max_inline_data_with_xattr from tools. ocfs2: Fix refcnt leak on ocfs2_fast_follow_link() error path
2010-02-089p: fix memory leak in v9fs_parse_options()Eric Van Hensbergen
If match_strdup() fail this function exits without freeing the options string. Signed-off-by: Venkateswararao Jujjuri <jvrao@us.ibm.com> Sigend-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-02-089p: fix option parsingEric Van Hensbergen
Options pointer is being moved before calling kfree() which seems to cause problems. This uses a separate pointer to track and free original allocation. Signed-off-by: Venkateswararao Jujjuri <jvrao@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>w
2010-02-089p: Include fsync support for 9p clientM. Mohan Kumar
Implement the fsync in the client side by marking stat field values to 'don't touch' so that server may interpret it as a request to guarantee that the contents of the associated file are committed to stable storage before the Rwstat message is returned. Without this patch, calling fsync on a 9p file results in "Invalid argument" error. Please check the attached C program. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Acked-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-02-08ocfs2/cluster: Make o2net connect messages KERN_NOTICESunil Mushran
Connect and disconnect messages are more than informational as they are required during root cause analysis for failures. This patch changes them from KERN_INFO to KERN_NOTICE. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Mark Faseh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-08ocfs2/dlm: Fix printing of locknameSunil Mushran
The debug call printing the name of the lock resource was chopping off the last character. This patch fixes the problem. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-08Revert "nfsd4: fix error return when pseudoroot missing"J. Bruce Fields
Commit f39bde24b275ddc45d fixed the error return from PUTROOTFH in the case where there is no pseudofilesystem. This is really a case we shouldn't hit on a correctly configured server: in the absence of a root filehandle, there's no point accepting version 4 NFS rpc calls at all. But the shared responsibility between kernel and userspace here means the kernel on its own can't eliminate the possiblity of this happening. And we have indeed gotten this wrong in distro's, so new client-side mount code that attempts to negotiate v4 by default first has to work around this case. Therefore when commit f39bde24b275ddc45d arrived at roughly the same time as the new v4-default mount code, which explicitly checked only for the previous error, the result was previously fine mounts suddenly failing. We'll fix both sides for now: revert the error change, and make the client-side mount workaround more robust. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-02-08[SCSI] compat_ioct: fix bsg SG_IOFUJITA Tomonori
bsg's SG_IO doesn't work on 32-bit userspace and 64-bit kernelspace. The problem is that both sg and bsg drivers use SG_IO ioctl. sg_ioctl_trans() does 32/64-bit conversion even against bsg header. It messes up bsg header. bsg driver gets garbage. This patch fixes sg_ioctl_trans to handle only sg header (struct sg_io_hdr). Reported-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-08cifs: fix dentry hash calculation for case-insensitive mountsJeff Layton
case-insensitive mounts shouldn't use full_name_hash(). Make sure we use the parent dentry's d_hash routine when one is set. Reported-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-08[CIFS] Don't cache timestamps on utimes due to coarse granularitySteve French
force revalidate of the file when any of the timestamps are set since some filesytem types do not have finer granularity timestamps and we can not always detect which file systems round timestamps down to determine whether we can cache the mtime on setattr samba bugzilla 3775 Acked-by: Shirish Pargaonkar <sharishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Take ima_file_free() to proper place. ima: rename PATH_CHECK to FILE_CHECK ima: rename ima_path_check to ima_file_check ima: initialize ima before inodes can be allocated fix ima breakage Take ima_path_check() in nfsd past dentry_open() in nfsd_open() freeze_bdev: don't deactivate successfully frozen MS_RDONLY sb befs: fix leak
2010-02-07Fix race in tty_fasync() properlyLinus Torvalds
This reverts commit 703625118069 ("tty: fix race in tty_fasync") and commit b04da8bfdfbb ("fnctl: f_modown should call write_lock_irqsave/ restore") that tried to fix up some of the fallout but was incomplete. It turns out that we really cannot hold 'tty->ctrl_lock' over calling __f_setown, because not only did that cause problems with interrupt disables (which the second commit fixed), it also causes a potential ABBA deadlock due to lock ordering. Thanks to Tetsuo Handa for following up on the issue, and running lockdep to show the problem. It goes roughly like this: - f_getown gets filp->f_owner.lock for reading without interrupts disabled, so an interrupt that happens while that lock is held can cause a lockdep chain from f_owner.lock -> sighand->siglock. - at the same time, the tty->ctrl_lock -> f_owner.lock chain that commit 703625118069 introduced, together with the pre-existing sighand->siglock -> tty->ctrl_lock chain means that we have a lock dependency the other way too. So instead of extending tty->ctrl_lock over the whole __f_setown() call, we now just take a reference to the 'pid' structure while holding the lock, and then release it after having done the __f_setown. That still guarantees that 'struct pid' won't go away from under us, which is all we really ever needed. Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Américo Wang <xiyou.wangcong@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-07Take ima_file_free() to proper place.Al Viro
Hooks: Just Say No. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07ima: rename ima_path_check to ima_file_checkMimi Zohar
ima_path_check actually deals with files! call it ima_file_check instead. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07fix ima breakageMimi Zohar
The "Untangling ima mess, part 2 with counters" patch messed up the counters. Based on conversations with Al Viro, this patch streamlines ima_path_check() by removing the counter maintaince. The counters are now updated independently, from measuring the file, in __dentry_open() and alloc_file() by calling ima_counts_get(). ima_path_check() is called from nfsd and do_filp_open(). It also did not measure all files that should have been measured. Reason: ima_path_check() got bogus value passed as mask. [AV: mea culpa] [AV: add missing nfsd bits] Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07Take ima_path_check() in nfsd past dentry_open() in nfsd_open()Al Viro
2010-02-07freeze_bdev: don't deactivate successfully frozen MS_RDONLY sbJun'ichi Nomura
Thanks Thomas and Christoph for testing and review. I removed 'smp_wmb()' before up_write from the previous patch, since up_write() should have necessary ordering constraints. (I.e. the change of s_frozen is visible to others after up_write) I'm quite sure the change is harmless but if you are uncomfortable with Tested-by/Reviewed-by on the modified patch, please remove them. If MS_RDONLY, freeze_bdev should just up_write(s_umount) instead of deactivate_locked_super(). Also, keep sb->s_frozen consistent so that remount can check the frozen state. Otherwise a crash reported here can happen: http://lkml.org/lkml/2010/1/16/37 http://lkml.org/lkml/2010/1/28/53 This patch should be applied for 2.6.32 stable series, too. Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Thomas Backlund <tmb@mandriva.org> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07befs: fix leakAl Viro
2010-02-06[CIFS] Maximum username length check in session setup does not matchSteve French
Fix length check reported by D. Binderman (see below) d binderman <dcb314@hotmail.com> wrote: > > I just ran the sourceforge tool cppcheck over the source code of the > new Linux kernel 2.6.33-rc6 > > It said > > [./cifs/sess.c:250]: (error) Buffer access out-of-bounds May turn out to be harmless, but best to be safe. Note max username length is defined to 32 due to Linux (Windows maximum is 20). Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-06cifs: fix length calculation for converted unicode readdir namesJeff Layton
cifs_from_ucs2 returns the length of the converted name, including the length of the NULL terminator. We don't want to include the NULL terminator in the dentry name length however since that'll throw off the hash calculation for the dentry cache. I believe that this is the root cause of several problems that have cropped up recently that seem to be papered over with the "noserverino" mount option. More confirmation of that would be good, but this is clearly a bug and it fixes at least one reproducible problem that was reported. This patch fixes at least this reproducer in this kernel.org bug: http://bugzilla.kernel.org/show_bug.cgi?id=15088#c12 Reported-by: Bjorn Tore Sund <bjorn.sund@it.uib.no> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: stable@kernel.org Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-05ocfs2: Fix contiguousness check in ocfs2_try_to_merge_extent_map()Roel Kluin
The wrong member was compared in the continguousness check. Acked-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: apply updated fallocate i_size fix Btrfs: do not try and lookup the file extent when finishing ordered io Btrfs: Fix oopsen when dropping empty tree. Btrfs: remove BUG_ON() due to mounting bad filesystem Btrfs: make error return negative in btrfs_sync_file() Btrfs: fix race between allocate and release extent buffer.
2010-02-04Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Don't clobber the attribute type in nfs_update_inode() NFS: Fix a umount race NFS: Fix an Oops when truncating a file NFS: Ensure that we handle NFS4ERR_STALE_STATEID correctly NFSv4.1: Don't call nfs4_schedule_state_recovery() unnecessarily NFSv4: Don't allow posix locking against servers that don't support it NFSv4: Ensure that the NFSv4 locking can recover from stateid errors NFS: Avoid warnings when CONFIG_NFS_V4=n NFS: Make nfs_commitdata_release static NFS: Try to commit unstable writes in nfs_release_page() NFS: Fix a reference leak in nfs_wb_cancel_page()
2010-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: GFS2: Extend umount wait coverage to full glock lifetime GFS2: Wait for unlock completion on umount
2010-02-04Btrfs: apply updated fallocate i_size fixAneesh Kumar K.V
This version of the i_size fix for fallocate makes sure we only update the i_size when the current fallocate is really operating outside of i_size. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: do not try and lookup the file extent when finishing ordered ioJosef Bacik
When running the following fio job [torrent] filename=torrent-test rw=randwrite size=4g filesize=4g bs=4k ioengine=sync you would see long stalls where no work was being done. That is because we were doing all this extra work to read in the file extent outside of the transaction, however in the random io case this ends up hurting us because the file extents are not there to begin with. So axe this logic, since we end up reading in the file extent when we go to update it anyway. This took the fio job from 11 mb/s with several ~10 second stalls to 24 mb/s to a couple of 1-2 second stalls. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
